Audi Q3 fault code 1048578 - No Basic Setting
   #21
darkmatter
C?ID=224357
My car has been to the Audi dealer who has correctly reset the service interval counter, this has cleared the fault. It looks like the previous dealer who serviced the car made a mistake.
Here is the final control module map.
;SW:8U0-920-990-A   HW:8U0-920-990-A ---  Instruments,,,,
;Component:KOMBI_COLOUR  H14 0030, Coding:42CF00,,,
;EV_Kombi_UDS_VDD_AU10,A04391,EV_Kombi_UDS_VDD_AU10.rod,,
;Tuesday,24,February,2015,17:01:18:04481
;VCDS Version: Release 14.10.1 (x64)  Data version: 20150130,,,,
;VCID: 3B7502F6B27421F97B2-806E,,,,
Activating and deactivating all development messages,not active ,,,
Automatic door locking,Display ,,,
Day,24,,,
Day counter,1160 d,,,
Deactivate seat belt warning,No ,,,
Display correction of consumptions and operating range,100%,,,
Display correction of fuel gauge,0.0 °,,,
Display format,not active ,,,
Distance,27960 km,,,
Driving profiled for range remaining,6.4,,,
(1)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,,,
(2)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,,,
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,,,
(4)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,,,
ESI: distance driven from inspection,13000 km,,,
ESI: maximum value km-driving distance/inspection,30000 km,,,
ESI: maximum value of time between inspections,730 d,,,
ESI: minimum value km-driving distance/inspection,15000 km,,,
ESI: minimum value of time between inspections,730 d,,,
ESI: oil quality,good oil quality ,,,
ESI: Resetting ESI,no warning ,,,
ESI: soot entry,14700 km,,,
ESI: thermal load,7800 km,,,
ESI: time from inspection,287 d,,,
Expanded display of traffic sign detection,On ,,,
FIX: Distance covered since last mileage-dependent inspection,13000 km,,,
Fix: Max. distance until next mileage-related inspection,30500 km,,,
FIX: Maximum time until next time-dependent inspection,730 d,,,
FIX: Time since last time-dependent inspection,1 d,,,
Hour,17 H,,,
Indicator light for start-stop operation,On ,,,
Language version,English ,,,
Language version in instrument panel insert control module,English ,,,
Minute,1 min,,,
Month,2,,,
Seat belt warning,Version 4 ,,,
(1)-Service-key settings-p_write_delay_time,40 s,,,
(2)-Service-key settings-p_write_delay_speed,20 km/h,,,
(3)-Service-key settings-p_write_distance,20 km,,,
(4)-Service-key settings-p_forcewrite_qual_time,10 s,,,
(5)-Service-key settings-p_main_switch_keyless,On ,,,
(6)-Service-key settings-p_main_switch_basis,On ,,,
SIA: maximum value of distance to service,14500 km,,,
SIA: maximum value of time to service,365 d,,,
Source for synchronization of time,GPS ,,,
Speed threshold of dynamic oil pressure warning,kein Offset ,,,
(1)-Speed warning-,active ,,,
(2)-Speed warning-Unit,Miles per hour ,,,
(3)-Speed warning-Speed,80,,,
Staging,not active ,,,
Synchronization duration radio clock,0 min,,,
(1)-Units adjusted-Temperature,°C ,,,
(2)-Units adjusted-Distance,miles ,,,
(3)-Units adjusted-Speed,Miles per hour ,,,
(4)-Units adjusted-Pressure,bar ,,,
(5)-Units adjusted-Volume,gallons (UK) ,,,
(6)-Units adjusted-Time,24h ,,,
(7)-Units adjusted-Date,dd_mm_yy ,,,
(8)-Units adjusted-Consumption,Miles per gallon (UK) ,,,
Upshift display in center panel,not active ,,,
Year,2015,,,
Service_Key_Clear_All_Counters,Yes ,,,
   #22
CocoPops
C?ID=65608
Interestingly, I'm now suffering from the same issue.
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 E    HW: 8U0 920 990 E
   Component: KOMBI_COLOUR  H01 0240
   Coding: 42CF01
   Shop #: WSC 00049 770 00118
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3F868C35A65840B9E2-806A
          B2010 00 [009] -  -
                    Reset counter: 138
                    Mileage: 29559 km
                    Date: 2016.09.01
                    Time: 11:17:36
Oh and guess when my car was serviced.... Yup, 1st September 2016!
   #23
Who serviced it?
Feel free to post an Adaptation map from the cluster, maybe we can figure out what it's unhappy about.
CocoPops
C?ID=65608
Sure thing:
;SW:8U0-920-990-E   HW:8U0-920-990-E ---  Instruments
;Component:KOMBI_COLOUR  H01 0240, Coding:42CF01
;EV_Kombi_UDS_VDD_AU10,A04399,EV_Kombi_UDS_VDD_AU10.rod
;Thursday,26,January,2017,21:17:30:09724
;VCDS Version: Release 17.1.1 (x64)  Data version: 20170107 DS267.0
;VCID: 3F868C35A65840B9E2-806A
IDE00301-Distance,34260 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,English
IDE00344-Seat belt warning,Version 4
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
IDE00493-Display correction of fuel gauge,0.0 °
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,21 H
IDE00501-Minute,17 min
IDE00502-Year,2017
IDE00503-Month,1
IDE00504-Day,26
IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset
IDE00510-ESI: distance driven from inspection,4700 km
IDE00511-ESI: time from inspection,147 d
IDE00512-ESI: minimum value km-driving distance/inspection,14500 km
IDE00513-ESI: maximum value km-driving distance/inspection,30600 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,6000 km
IDE00518-ESI: thermal load,3400 km
IDE00819-Day counter,939 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,730 d
IDE01087-Staging,active
IDE01153-SIA: maximum value of distance to service,14500 km
IDE01154-SIA: maximum value of time to service,365 d
IDE02327-Indicator light for start-stop operation,On
IDE02494-Automatic door locking,Display
IDE03329-Driving profiled for range remaining,6.8
IDE03346-IDE00301-Units adjusted-Distance,miles
IDE03346-IDE00316-Units adjusted-Time,24h
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour
IDE03346-MAS02201-Units adjusted-Temperature,°C
IDE03346-MAS03032-Units adjusted-Volume,gallons (UK)
IDE03346-MAS03033-Units adjusted-Consumption,Miles per gallon (UK)
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03348-MAS01456-Speed warning-Speed,85
IDE03348-MAS01561-Speed warning-Unit,Miles per hour
IDE03348-MAS03206-Speed warning-Speed warning,active
IDE03349-FIX: Max. distance until next mileage-related inspection,31600 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,4700 km
IDE03352-FIX: Time since last time-dependent inspection,147 d
IDE03360-Upshift display in center panel,not active
IDE03371-Synchronization duration radio clock,0 min
IDE03372-Source for synchronization of time,GPS
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04103-Language version in instrument panel insert control module,English
IDE04112-Display format,not active
IDE05193-Expanded display of traffic sign detection,On
IDE06425-Roller test bench mode: functional,not active
IDE07221-Cylinder shut-off,No display
MAS03555-Lap counter,On
ENG119824-boost_pressure,On
ENG108924-Service_Key_Clear_All_Counters,Yes
ENG114944-Start_up_screen,No display
ENG112416-IDE01766-velocity_detection-Distance impulses,4
ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses
Elapsed Time: 00:18
CocoPops
C?ID=65608
Just followed Wolfgangs ma/min values from 30600 to 30000 and 14500 to 15000.
Sorted!
Definitely worth storing this somewhere...
It was serviced by local Audi dealer btw (official)
   #26
CocoPops
C?ID=65608
For completeness, here is the channel map POST change:
;Thursday,26,January,2017,21:26:42:09724
IDE00500-Hour,21 H
IDE00501-Minute,26 min
IDE00502-Year,2017
IDE00503-Month,1
IDE00504-Day,26
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
Elapsed Time: 00:18
PS Glad it's resolved, I'm headin back inside... it's reading 0.0degrees out here :D
   #27
Sorted!
I wonder if there was a version of ODIS that had incorrect scripts in it for a while?
AJB
C?ID=61832
Moin,
maybe I'm too many tolate but I think, the reason for this basic setting issue is based here:
Please change the values max driving distance to 30000,
Please change the values min driving distance to 15000 km.
and minimum value of time between inspections to 365 d
GOOD LUCK:)
Thank You! In case it helps anyone else, I came across this thread as I had the "No Basic Setting" fault code on Instruments on my 2013 Audi A3 (8V model, UK spec). This exact same fix (including the exact same original distances of 30600 and 14500) worked perfectly.
My car didn't have the fault code when new, but had been serviced by an Audi main dealer, so I guess they introduced the troublesome distances during their service reset.
Thanks again!
   #29
EDBOC
C?ID=225153
Same Issue on Audi A1 62 Plate that went into local UK Audi dealer for a service
Thanks for sharing AIB Wolfgang
Originally Posted by AIB Wolfgang View Post
Moin,
   #30
vmmltu
Lithuania
C?ID=394547
Hello, I'm new to VCDS. My mothers Golf VII has 2 remaining DTC's after deleting all and test driving. One is as above and I think that numbers are okay. Need a little help. Thank you :) Here is Auto-Scan and adaptation map of address 17:
Monday,04,May,2020,12:57:03:12071
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZAUZGW198440   License Plate: JCG545
Mileage: 74321km-46180mi   Repair Order: 2020_05_04_patikrinimas
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZGW198440   Mileage: 74321km-46180miles
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 2328
   Revision: R7H25---
   Coding: 0125003223241D082000
   ASAM Dataset: EV_ECM14TFS01104E906027HB 001004
   ROD: EV_ECM14TFS01104E906027HB.rod
   VCID: 6B83C1EF33070223969-803E
   CAN Converter 01:
Readiness: 0010 0001
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0612
   Revision: 00005005    Serial number: CU501511125842
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44D14A537E192D5B373-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 93105000012122
   Coding: 01FA6AA124291174077B060441C32980562488E0608294F300220078C202
   VCID: 79AFEBA7495BA0B3145-802C
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A8DC4EB3CFD1B2BEDF-803E
   Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061532800105
   Coding: 00001A46C24122F30BA44080B11C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9B6719BBB033045-805C
   Component: WWS    151030  043 0551
   Serial number:         151114191639
   Component: RLHS  037 0059
   Serial number: S2Y15M12D01H02M54S38
   Coding: 90A8DD
   Serial number: 000000000ZY1529308VQ
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033487141
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 231
                    Mileage: 74316 km
                    Date: 2020.05.01
                    Time: 17:58:54
   Revision: --------    Serial number: 39391532504511
   Coding: 0031051011
   VCID: 43D3494F7B172A630E9-8016
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R19MW5Y
   VCID: 41DF4347610B38731C5-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 3576700000094581D71X
   Subsystem 2 - Part No SW: -----------    HW: 480 001 211 15
   Serial number: 3586700000054281D71R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 35165029B1E34435D2CH
   Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3526502A51E34431109Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3556502A11E34434422Z
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151201500178
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB45BF17FF4E836A1-806A
   Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
   Component: KOMBI         202 6420
   Coding: 07A419082B80000801082A001400000000000000
   VCID: 2411EAD39E590D5B173-8070
          B2010 00 [009] - -
          [Steuergerдt keine oder falsche Grundeinstellung]
                    Reset counter: 231
                    Mileage: 74316 km
                    Date: 2020.05.01
                    Time: 17:58:54
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004243096
   Coding: 030100043F085700FB00024A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29150002329470015475
   Coding: 28FFFF
   Serial number: 3959488403
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 101015BJ916677
   Coding: 003002208000040000001000
   Serial number: 00000000000008165141
   Coding: 110000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0103
   Serial number: 141015BJE03294
   Coding: 003000208E00040000801000
   VCID: 42DD4C4B640D236B05F-8016
   Serial number: 00000000000008199730
   Coding: 090000
   Coding: 029A00000B000200
   VCID: 40D946436A01317B13B-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 819 A    HW: 3Q0 035 819 A
   Component: MU-S--ER      523 0629
   Coding: 02730000FF00000051110001000908001F0100840120010001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2F3B15FFC79FBE03FA1-807A
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9R3311321
End----------(Elapsed Time: 01:35, VBatt start/end: 14.9V/13.1V)-----------
;SW:5G1-920-740-A   HW:5G1-920-740-A ---  Instruments
;Component:KOMBI         202 6420	 Coding:07A419082B80000801082A001400000000000000
;EV_DashBoardVDDMQBAB	9046	EV_DashBoardVDDMQBAB_009_VW37.rod
;Monday	4	May	2020	13:14:21:12071
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 2411EAD39E590D5B173-8070
IDE00295-Oil temperature display	On 	1
IDE00301-Distance	74321 km	3
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	English 	1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	13 H	1
IDE00501-Minute	14 min	1
IDE00502-Year	2020 yr	2
IDE00503-Month	5 mon	1
IDE00504-Day	4 d	1
IDE00510-ESI: distance driven from inspection	3302 km	3
IDE00511-ESI: time from inspection	227 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	0 km	2
IDE00518-ESI: thermal load	4900 km	2
IDE00711-Trip recorder	not installed 	1
IDE00819-Day counter	1612 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	20000 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	12.7 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	6.0 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
IDE03346-MAS01230-Units adjusted-Date	yy_mm_dd 	3
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
IDE03346-MAS02957-Units adjusted-Time	24h 	3
IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	30000 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	365 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	3300 km	2
IDE03352-FIX: Time since last time-dependent inspection	227 d	2
IDE03372-Source for synchronization of time	internal clock 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE04169-Display correction of consumption and operating range: gas	100%	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	30000 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	365 d	2
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	Unknown (2)	1
IDE07221-Cylinder shut-off	Display 	1
IDE08140-Driving profiled for range remaining CNG	6.0 kg/100 km	2
IDE08247-Driving profile for range remaining LPG	10.0 l/100km	2
IDE11086-Service notification	30 d	1
MAS03685-Digital speedometer	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	9 l	1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC 	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	17	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	32	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	46	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32	12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64	12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3	12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3	12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	8	12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	20	12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55	12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96	12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5	12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5	12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C 	12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17	12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32	12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96	12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1	12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1	12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7	12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	12	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E 	12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
ENG119882-init_fuel_algorithm	No 	1
ENG130585-Leaving_warning_delay	1.6 s	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG130584-Statistic_phev_mileage	5 km	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.20 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
Elapsed Time: 00:29
