2013 GTi - ABS Coding (MK60EC1)
rc2211
C?ID=111593
Can someone help me out? I took off my dash to clean but I did not download de data VSCS . So now ABS, Traction Control and trac are blinking! ABS lost coding! There is anyway that I can input the code again! Thank you so much
   Revision: 00H31001
   VCID: 7DF1BCB6E44E9FA2B6-8028
                    Reset counter: 118
                    Date: 2013.08.09
                    Time: 02:24:13
rc2211
C?ID=111593
2013 GTI - ABS CODING - HELP
Hello guys
Can someone help me out, I took off the cluster off my car to clean. BUG INSIDE :facepalm:
Now my dash looks like a Christman three with ABS, Traction Control, Track Blinking
As far that I know looks like I lost the ABS code, and I did not run auto scan before :mad:
So I dont have the code! There is anyway that I can get this code from somewhere?
I'll me able to imput the new code with my VCDS??
How can I do that?
Thank you very much!
Tuesday,19,March,2019,19:28:17:49137
VCDS Version: 18.9.1.0 (x64)
VIN: WVWHD7AJ8DW037226   License Plate: 13GTI
Mileage: 156900km-97493mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
          56 62 72
VIN: WVWHD7AJ8DW037226   Mileage: 156900km-97493miles
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78FFADA20B6CBA8AE5-802C
049493 - No Communication with Instrument Cluster
               U0155 - 000 -  - Intermittent
                    Mileage: 156895 km
                    Date: 2013.08.09
                    Time: 00:12:29
                    Temperature: 91.0°C
                    Temperature: 54.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.557 V
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Mileage: 130915 km
                    Date: 2018.02.15
                    Time: 00:07:00
                    RPM: 1165 /min
                    Load: 11.0 %
                    Temperature: 94.0°C
                    Temperature: 40.0°C
                    Voltage: 11.938 V
Readiness: 0110 1101
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3509
   Revision: 05551213    Serial number: 00001206122246
   VCID: 275DBEDE9652E572BC-8072
   Revision: 00H31001
                    Reset counter: 118
                    Date: 2013.08.09
                    Time: 02:24:13
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 43520
                    Fault Status: 01100101
                    Reset counter: 118
                    Mileage: 156900 km
                    Date: 2013.08.09
                    Time: 02:19:58
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 279
                    Count: 43776
                    Reset counter: 118
                    Mileage: 156900 km
                    Date: 2013.08.09
                    Time: 02:19:58
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 295
                    Count: 43776
   Revision: 00085000    Serial number: 0179551523
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 346759929F849EEA09-8060
1057291 - Antenna for Keyless Entry System; Passenger Side
          B1170 13 [009] - Open Circuit
                    Reset counter: 118
                    Mileage: 156900 km
                    Date: 2019.03.19
                    Time: 02:00:30
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   VCID: 7BF5B2AEF25A919288-802E
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AB111709
   Coding: 6F180A3AD8272EC4108802C170008DE44E852086474D8DB0E48420248040
   VCID: 41890046D8363B4292-8014
   Component: Wischer 12061  26  0512
   Coding: 009795
            000 -  -  - Intermittent
                    Reset counter: 158
                    Mileage: 156895 km
                    Date: 2013.08.09
                    Time: 01:46:49
                    Voltage: 11.65 V
                        Term 50 On
   Serial number: 003GVRA2FZX0
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3F8D06BEA6C24DB2E4-806A
   Serial number: ---0000R--00003B1500
   Serial number: 3572MSME50044567ZZZO
   Serial number: 3582MSME5676147DZZZ0
   Serial number: 3512QSME58391501ZZZN
   Serial number: 3522QSME54431817ZZZP
   Serial number: 35527SME3366002EZZZA
   Serial number: 35627SME6965012EZZZK
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120619301028
   Coding: 101A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DF1BCB6EC4E9FA2B6-8028
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Coding: 270F01
   VCID: 377D6E9E8EF275F22C-8062
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 170612F1002721
   Coding: 350002
   VCID: 3F8D06BEAEC24DB2E4-806A
   Coding: 000007
   VCID: 6ADB87EA8DC0181A63-803E
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000141441002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F6D56FE76A2BD3274-807A
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662875275
   Coding: 020100
   VCID: 2A5B47EA4540D81AA3-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4233925
   Coding: 04050001010005000000100A
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 2541B4D6245EF7628E-8070
          B11CF 53 [009] - Deactivated
                    Reset counter: 118
                    Mileage: 156895 km
                    Date: 2019.03.19
                    Time: 01:46:48
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001204
   VCID: 377D6E9E46F275F22C-8062
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0032796
   VCID: 2959B8E64846D302AA-807C
9462803 - Front Right Treble Speaker
          B1064 13 [008] - Open Circuit
                    Reset counter: 158
                    Mileage: 156895 km
                    Date: 2019.03.19
                    Time: 01:46:51
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001204
   VCID: 387F6DA24BEC7A8A25-806C
   Coding: 1446940
   VCID: 3467599257849EEA09-8060
   Coding: 00000022
   Coding: 00000022
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 356164965CFE87E23E-8060
   Coding: 0001168
   VCID: 3663639A41F88CFA37-8062
End-------------------------(Elapsed Time: 03:14)--------------------------
rc2211
C?ID=111593
Sorry about that, I was trying to delete the previous one!
I just got th VCDS, the car I have for about 2 months
rc2211
C?ID=111593
Hahahahaha I got from a friend of mine! That’s why! Idk much how to use , I’m learning here! Thanks for merge! Best
rc2211
C?ID=111593
Thank you so much for your help!
I imput the code on the ABS , lighs are not blinking anymore. Just on ABS/Traction.
Now Ill try to do the all process (Basics) to make the lights go off!! I just did the first part, but now I need to wait to ABS cool down!
Ill let you know!
Thanks again
rc2211
C?ID=111593
Please try:
114B600C49250001880D06E6921F0041B70800
You will need to run basic setting for ABS/ESP stuff in 1 session.
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1))
Ill let you know!
Thanks agai
rc2211
C?ID=111593
I Can’t thank enough
Thank you so much!! Everything working fine the way was suppose to be! You guys rock! Best Regards
