Full long coding helper
Amarton
Europe - Hungary
C?ID=338434
I read out my and my friend car. The two car are similar but the 01: Engine ECU long coding a litle bit different.
I would like two know what are the differences but the long code helper hide some bit.
I am looking for for example what does the Byte5 Bit4 means.
I copied the 2 long code underneath each other to see the differences.
Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AL HW: 05E 907 309
Component: R4 1.5l TFS H22 6084
Revision: 81H22000
Coding:
0119003224341D0800000000000000000000000000000000
011900322324190800000000000000000000000000000000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
ROD: EV_ECM15TFS01105E906018AL.rod
VCID: 6FBBD0C76712BBEF777-803B
_Val
Latvia
C?ID=356659
It's not hiding it, just not documented yet.
NEtech
C?ID=56995
Trailer installed
But it is not used for all controllers, that is used for the label: 04E-907-309-V1.clb
Amarton
Europe - Hungary
C?ID=338434
Trailer installed
How can I use the long code helper without car?
How can I load the label files to helper?
You can't, because of clones illegal misusing the labels files they've had to be encrypted and are only unencrypted & used when connected to the appropriate ECU.
Blame the clones for this change which Ross-Tech were forced to take to protect their IPR
It loads them automatically.
It wasn't so much the clones as so many other wannabe vendor of diagnostic tools taking the data verbatim from VCDS. Some of them we cheap Chinese hand-helds, and others were well-known industry players.
Bruce
Near Philadelphia, PA, USA
Some of them were cheap Chinese hand-helds, and others were well-known industry players.
Whose customers then called Ross-Tech for support and service since their tool told them to do so...... yep, in the old days, some fault descriptions and such suggested a call to Ross-Tech for assistance. Imagine our surprise when a well known brand customer called asking for help. "What tool are you using? Send us a photo..." We were very very surprised....
Yep!
