Evening Folks,
I’m about to go order a new G395 sensor to hopefully resolve the error on module 09. It looks to me that whatever those errors on module 8 are, they might also be resolved by replacing the faulty sensor on module 9. However, do you think the error in module 28 may also be due to the potentially faulty G395 sensor on module 9?
ps I didn’t update to the latest SW version last night before I canned as I wasn’t sure if the experimental clb files Dana sent me in November would be affected.
Monday,04,February,2019,18:01:47:12530
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WAUZZZ4G8GN095717 License Plate:
Mileage: 45117km-28034mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 72 A9 AC C0
VIN: WAUZZZ4G8GN095717 Mileage: 45117km-28034miles
Address 01: Engine (J623-CVUA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 589 D HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0002
Revision: 54H23---
Coding: 0A2A4032252603030000
ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
ROD: EV_ECM30BTD0114G0907589D.rod
VCID: 3537DC9805C2798F7D3-8060
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1005
Revision: --H19---
Coding: 000001
VCID: 77AB16905F4E4B9FAFF-8022
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 49A79E4192E579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DFB848410AC52FD1B-8014
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01B8704E000000000000
VCID: 7BA30AA063E66FFFCB7-802E
Serial number: 0215000188678006
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Component: KLIMA 4 ZONEN H14 0112
Serial number: 08101500040560
Coding: 36211178210000
VCID: 629D57C4E4CCBE37E81-8036
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
Reset counter: 57
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:15
Voltage terminal 30: 11.65 V
Outside air temperature: 5.5 °C
Engine speed: 999 /min
0387 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 211
Reset counter: 109
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:14
Voltage terminal 30: 11.34 V
Engine speed: 1017 /min
Address 09: Cent. Elect. (J519) Labels:. User\4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001182453302
Coding: 0105801440349FE0410140C0000018000F9DC3082F08020100000894E100150200400024030000
VCID: 71BF288831AA15AF61B-8024
Component: WWS57X 150715 H38 0080
Serial number: 150819223949
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20763505
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 13 10 2015 00000873
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: ED8880D7000000000001
Reset counter: 57
Mileage: 42778 km
Date: 2018.12.16
Time: 12:44:15
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1006SWY0
Coding: 30333130313730323737554A305234473053
VCID: 3B23CAA023E6AFFF8B7-806E
Serial number: 3575HRB40633JUD03OCK
Serial number: 3585HRB40573KGI0APDP
Serial number: 3515JRB404T3JK6259MM
Serial number: 3525JRB40633FSTU6HIG
Serial number: 3554VRB400S553HED8T/
Serial number: 3564VRB400S553HED90D
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OJC00068
Coding: 000034
VCID: 3B23CAA02366AFFF8B7-806E
Serial number: 01 09 2015 C0002893
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 986 M HW: 4G8 920 986 M
Component: TDieGb H11 0106
Revision: 07001088 Serial number: 658150915596041
Coding: 23A70A000B412600010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
VCID: 42DDB744440CDE37C81-8016
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002004092
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 1931577903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 150725000000000004E9
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 678B46D00F6EDB1F3FF-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 09101500040125
Coding: 22
VCID: 3D27C4B83DF2A1CFB53-8068
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 149
Mileage: 45111 km
Date: 2019.02.04
Time: 15:44:27
Outside air temperature: 6.5 °C
Left rear vent temperature: 10.3 °C
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720KW0DP
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3333E2800BB667BF537-8066
Component: TSG FA H03 0511
Coding: 011C16014001620002080002
VCID: 47CBA6506FAEFB1F1FF-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000002 Serial number: 0000283456
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2DCFA42CDC96F7901-806E
Revision: 00002001 Serial number: 0382488804
Coding: 011F062280B90000C320080400010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Component: TSG BF H03 0511
VCID: 46D5AB5468A4E217E49-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001619448
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D07F4F8ED92314F053-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A630200
VCID: 3431E19C0EB860874AD-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 021 E HW: 4G1 035 021
Component: MU-H-LND-EU 042 0335
Serial number: A588J0F7528209
Coding: 017501010000000013111102000A00132F0006E7F1700100DF
VCID: 1C61293C8628C8C762D-8048
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY802QD8
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OJ6000EJ
Component: Gracenote --- 1010
Component: TSG HL H03 0511
VCID: 49CFA06879BA0D6F09B-801C
Component: TSG HR H03 0511
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 151002203103
VCID: 2E05F3F4E0944A573C9-807A
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 152451062
ROD: EV_RDCMA00100_008.rod
VCID: 2F3BEEF0E79E435F37F-807A
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0011
Serial number: 151001200324
VCID: 270B06D0CF6E1B1FFFF-8072
End----------(Elapsed Time: 02:05, VBatt start/end: 13.5V/14.4V)-----------
