gdallas
C?ID=95831
Evening Folks,
I’m about to go order a new G395 sensor to hopefully resolve the error on module 09. It looks to me that whatever those errors on module 8 are, they might also be resolved by replacing the faulty sensor on module 9. However, do you think the error in module 28 may also be due to the potentially faulty G395 sensor on module 9?
ps I didn’t update to the latest SW version last night before I canned as I wasn’t sure if the experimental clb files Dana sent me in November would be affected.
Monday,04,February,2019,18:01:47:12530
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20181017 DS296.0
VIN: WAUZZZ4G8GN095717   License Plate:
Mileage: 45117km-28034mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
          62 72 A9 AC C0
VIN: WAUZZZ4G8GN095717   Mileage: 45117km-28034miles
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 D    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0002
   Revision: 54H23---
   Coding: 0A2A4032252603030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
   ROD: EV_ECM30BTD0114G0907589D.rod
   VCID: 3537DC9805C2798F7D3-8060
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1005
   Revision: --H19---
   VCID: 77AB16905F4E4B9FAFF-8022
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 49A79E4192E579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB848410AC52FD1B-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B8704E000000000000
   VCID: 7BA30AA063E66FFFCB7-802E
   Serial number: 0215000188678006
   Part No SW: 4G0 820 043 CC    HW: 4G0 820 043 CC
   Serial number: 08101500040560
   Coding: 36211178210000
   VCID: 629D57C4E4CCBE37E81-8036
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
                    Reset counter: 57
                    Mileage: 42778 km
                    Date: 2018.12.16
                    Time: 12:44:15
                    Voltage terminal 30: 11.65 V
                    Outside air temperature: 5.5 °C
                    Engine speed: 999 /min
0387 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Fault Frequency: 211
                    Reset counter: 109
                    Mileage: 42778 km
                    Date: 2018.12.16
                    Time: 12:44:14
                    Voltage terminal 30: 11.34 V
                    Engine speed: 1017 /min
Address 09: Cent. Elect. (J519)       Labels:. User\4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001182453302
   Coding: 0105801440349FE0410140C0000018000F9DC3082F08020100000894E100150200400024030000
   VCID: 71BF288831AA15AF61B-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150715  H38 0080
   Serial number:         150819223949
   Coding: 0045F7
   Serial number: 20763505
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 10 2015  00000873
   Serial number: ED8880D7000000000001
                    Reset counter: 57
                    Mileage: 42778 km
                    Date: 2018.12.16
                    Time: 12:44:15
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1006SWY0
   Coding: 30333130313730323737554A305234473053
   VCID: 3B23CAA023E6AFFF8B7-806E
   Serial number: 3575HRB40633JUD03OCK
   Serial number: 3585HRB40573KGI0APDP
   Serial number: 3515JRB404T3JK6259MM
   Serial number: 3525JRB40633FSTU6HIG
   Serial number: 3554VRB400S553HED8T/
   Serial number: 3564VRB400S553HED90D
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OJC00068
   Coding: 000034
   VCID: 3B23CAA02366AFFF8B7-806E
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 01 09 2015  C0002893
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 986 M    HW: 4G8 920 986 M
   Component: TDieGb        H11 0106
   Revision: 07001088    Serial number: 658150915596041
   Coding: 23A70A000B412600010000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   VCID: 42DDB744440CDE37C81-8016
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002004092
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 1931577903
   Voltage stabilizer:
   Serial number: 150725000000000004E9
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 678B46D00F6EDB1F3FF-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 09101500040125
   Coding: 22
   VCID: 3D27C4B83DF2A1CFB53-8068
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 149
                    Mileage: 45111 km
                    Date: 2019.02.04
                    Time: 15:44:27
                    Outside air temperature: 6.5 °C
                    Left rear vent temperature: 10.3 °C
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720KW0DP
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3333E2800BB667BF537-8066
   Component: TSG FA        H03 0511
   Coding: 011C16014001620002080002
   VCID: 47CBA6506FAEFB1F1FF-8012
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000283456
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2DCFA42CDC96F7901-806E
   Revision: 00002001    Serial number: 0382488804
   Coding: 011F062280B90000C320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Component: TSG BF        H03 0511
   VCID: 46D5AB5468A4E217E49-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001619448
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D07F4F8ED92314F053-8078
   Coding: 04FE02102A630200
   VCID: 3431E19C0EB860874AD-8060
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 021 E    HW: 4G1 035 021
   Component: MU-H-LND-EU   042 0335
   Serial number: A588J0F7528209
   Coding: 017501010000000013111102000A00132F0006E7F1700100DF
   VCID: 1C61293C8628C8C762D-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY802QD8
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OJ6000EJ
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 49CFA06879BA0D6F09B-801C
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 151002203103
   VCID: 2E05F3F4E0944A573C9-807A
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152451062
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F3BEEF0E79E435F37F-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 151001200324
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 270B06D0CF6E1B1FFFF-8072
End----------(Elapsed Time: 02:05, VBatt start/end: 13.5V/14.4V)-----------
Gone But Not Forgotten
Check connectivity and LIN for proper function before changing the G395 sensor by testing with DVOM and WD in the RTFB.
Jef
HQ
I made this image, I'm going to use it:
G395
  • /1 ground
  • /2 LIN Bus Data to J519
  • /3 Power (Terminal 15)
Have you verified those are to factory design?
G395 uses a LIN Bus for the Data. Other items can be on that same LIN Bus and screw up communication. Looking at your VIN in Partslink24, no garage door opener, no vented seats. I've seen a lot of garage door openers screw the LIN Bus over... but since your car doesn't have it, rule that out. The only other sensor that might be on the LIN Bus would be an air quality or humidity sensor, but I don't see codes for that.... so, back to the Holy Trinity.
I suspect maybe a button was sticking. Clear it out, if it comes back then put more effort into it, but I'd not be concerned if it clears out.
I think there's a good chance of that.
My guess is: No.
If they're in your User sub-folder (one level down from Labels), they should be unaffected, but make a backup copy of them someplace else, just in case.
gdallas
C?ID=95831
well I took a gamble and replaced the sensor with a new OEM version today. I thought this would be the path of least resistance. disappointingly the gamble didn't however pay off. The faults persist. When you clear the sensor fault it reappears instantly every single time. Back to the drawing board I go. there is no value being measured in adv measuring block, just a - symbol.
Shame shame....that is like not checking fuses or doing the JPPSG?
Is that part replaced with possible FOD?
gdallas
C?ID=95831
As I said, I took a gamble on the path of least resistance for me personally. I do not have any wiring diagrams to help me check continuity, nor do I know which fuse terminal feeds this. I hoped replacement would be a quick 5 min fix, rather than finding diagrams and doing some proper mandrolic fault finding.
where would one find said wiring diagrams does anyone know?
Cheers bud. The rest of world link doesn't however work 😕
Hmm, the erwin-portal site does indeed seem to be down. :facepalm:
gdallas
C?ID=95831
So, I bought the Erwin manuals and have been outside most of the day trying to diagnose without success, though I’m closing in for sure!
I have verified that the plug at G395 senor end has a healthy supply/ground. Therefore, I can only assume that the issue lies somewhere with the LIN cable between J519 and G395.
I was somewhat surprised by the current flow diagrams in Erwin. Given that I have a right-hand drive car, and the G395 is on the left-hand side of the car in front of the radiator. LIN cable from the sensor allegedly goes to socket T17o, pin 16 (RIGHT A PILLAR coupling station), then from T17i pin 16, (LEFT A PILLAR coupling station) to Socket C pin 4 of the J519 controller which is back on the Right side! Like a big zig zag across the car. Seemed odd to me given this is (presumably) a multidropable protocol.
Anyway, I managed to remove passenger side A/B pillar trim to expose the T17i pin 16, (LEFT A PILLAR coupling station). With my DVM attached to the LIN pin at the G395 plug, and the other end attached to the pin 16 on T17i (LEFT A PILLAR coupling station), I failed to get continuity. I spent a good while trying to locate the J519 module, but as I write this, I think I will park that investigation for now as the issue appears to reside either:
- Wiring between the coupling stations
- or wiring between T17o, pin 16 (RIGHT A PILLAR coupling station) and the G395 sensor.
It became too cold and windy to continue ripping trim off, so I will continue my efforts tomorrow.
Meanwhile, if anyone can advise where the J519 is located, that would be useful, as I cannot tell exactly its location from Erwin, other than drivers’ side, under dash. See pic attached.
Thanks All.
Thanks All.
Beware of shared components on the LIN track BUS and that the G395 sensor you replaced is the correct part number, to avoid FOD!
gdallas
C?ID=95831
Im admitting defeat. I couldn't get a buzz from my DVM whilst checking for continuity on the LIN between the sensor and the coupling station, nor between both coupling stations. The wiring looked visually OK. No clue why it wouldn't buzz. Very frustrated now!
Don't give up, post the LIN tracks in WD in screen shots and let's trace it together!
Isolate other components on the LIN by unplugging them and verifying what one is causing an open or if an overlay tests good.
If it were me I'd go check the rain/photo sensor first!
gdallas
C?ID=95831
How would I determine all sensors on the LIN. Would my Erwin manuals help? By disconnecting each in turn, what will that achieve? I don't quite understand.
LIN is single wire communication and when a wire is possibly down or a another sensor is faulty sharing the track can bring the entire data bus loop down for those components.
In addition to the RTFB maybe have a read of this thread & watch these videos here:
https://forums.ross-tech.com/showth...-you-should-have-a-baseline-understanding-of-!
gdallas
C?ID=95831
Morning mate, I've had a thought. What if I were to swap the g395 and g238 to rule out this new part isn't indeed faulty too, plus this should confirm if there is an issue with the wiring should VCDS start reporting that G395 is now healthy, whilst G238 is bad? Is it possible to do that? Both of these sensors appear to have the same/similar 3 pin plug, albeit with a slightly different pinout, are on the same bus back to j519 and are fed by the same power supply. The only difference I can see is that the G395 first utilises the coupling station route for my car (RHD). I could fashion a couple of jumpers to allow me to interface the G395 with the plug intended for the G238
Welcome your thoughts. Cheers
link to wiring diagram. https://flic.kr/p/QWesD4
