Hello
I know someone helped me here before with coding for this type of work so I
ask if possible to help me to get this right.
The faults on the brake module gives me Incorrectly coding and I wonder if someone can help me
calculate the right coding for it
I have scan all faults and I just need long coding for brakes / abs if its possible
Here is the auto scan
Thursday,17,January,2019,08:38:41:00001
VCDS Version: 17.8.0.1
VIN: TMBJM65J6D3087842 License Plate: UUC373
Mileage: 80430km-49976mi Repair Order: 2019/1/17
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56 69
VIN: TMBJM65J6D3087842 Mileage: 80430km-49976miles
Address 01: Engine (J623-CBZA) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 HH HW: 03F 907 309 AK
Component: SIMOS10.22AH10 4040
Revision: --H10--- Serial number:
Coding: 001100D6202400080000
Shop #: WSC 13765 031 00015
ASAM Dataset: EV_ECM12TFS02103F906070HH 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6FECEB20B69D0D3E63-803A
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AT HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0001
Serial number: --------------
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 102E88DCCB6372C61A-8044
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Reset counter: 136
Mileage: 21707 km
Date: 2020.09.03
Time: 00:00:06
0887 - Control Module
C104A F0 [137] - Incorrect VIN
Reset counter: 136
Mileage: 21707 km
Date: 2020.09.03
Time: 00:00:06
0897 - Coding Not Possible
U10BC 00 [009] - -
Reset counter: 136
Mileage: 80435 km
Date: 2019.01.17
Time: 00:08:57
0883 - Control module not coded
U1013 00 [137] - -
Reset counter: 136
Time: 00:00:00
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H09 0103
Revision: K0000000
VCID: 2A5A3A3445FF2816F4-807E
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 M HW: 6R7 937 087 M
Component: PQ25 BCM H28 0555
Revision: -1------ Serial number: --------------
Coding: 64980B3808010000003008006C2B09C000C0400F608C0000020000000000
Shop #: WSC 13765 790 00015
VCID: 4E9256A419D7243648-801A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0003
Revision: --H10--- Serial number: 32961233500452
Coding: 110002
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72EAE254A5AF20D68C-8026
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10AirbagT23 H10 0020
Revision: -------- Serial number: 003GY0082LA8
Coding: 003233
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 4B945FB0E2C5111E2F-801E
Serial number: 3495RRB401A4UP64J0Q0
Serial number: 3505RRB400E4UO8889V3
Serial number: 3515RRB401A4UP64P9D
Serial number: 3525RRB401E4UP66D9M%
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5J0 920 841 E HW: 5J0 920 841 E
Component: KOMBI H05 0306
Coding: 110E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
VCID: 2C563C2C470B362606-8078
Part No SW: 6N0 909 901 HW: 6R7 937 087 M
Component: GW-K-CAN TP20 H28 0555
Revision: -1------
Coding: 232200
VCID: 70EEE85CA3A312C67A-8024
Component: IMMO H05 0306
VCID: 6ADAFA348D7FE81634-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11240
Shop #: WSC 13765
VCID: 306E285CF72352C63A-8064
Part No SW: 5J0 035 161 D HW: 5J0 035 161 D
Component: Radio-SWING 004 0003
Revision: -----07S Serial number: SKZ4Z2M1419979
Coding: 0D0004000006
VCID: 2344D71022D5F95EB7-8076
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030335413
Coding: 410D000100000000
VCID: 306E285C632352C63A-8064
End-------------------------(Elapsed Time: 02:29)--------------------------
