Parking assistance Audi A5 8T 2014
bittuning
C?ID=347418
park assistance Audi A5 2014
I try to enable the park assistance in the MMI display on an Audi A5 2014. The car has only parking sensor at the back. But the module 10 isn't available. In the MMI menu I could only configure the parking sound. When I enable the module 10 in the gateway installatiemonteur list I get an error message when I do the autoscan. Hopefully anybody has aan idea How I Could fix this?
VIN: WAUZZZ8T3EA047960 License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8T3EA047960 Mileage: 91140km-56631miles
You can't just enable a module that doesn't exist. ;)
Please post your whole scan. There's not much that can be seen from just the Gateway Installation List.
bittuning
C?ID=347418
Thursday,20,December,2018,19:11:12:05254
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
Dealer/Shop Name: Bittuning
VIN: WAUZZZ8T3EA047960   License Plate: 6TJH45
Mileage: 91140km-56631mi   Repair Order:
Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264 A    HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H09 0004
   Revision: --H09---
   Coding: 1A030032242401022000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
   ROD: EV_ECM18TFS0218K0906264A.rod
   VCID: AF2E6EA0F6094A32FC-80FA
15077 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
15262 - Oxygen (Lambda) Sensor B1 S1
          P2196 00 [096] - Signal too High (Rich)
14880 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
   Part No SW: 8K5 927 155 F    HW: 0AW 927 156 K
   Component: 0AW_18TFSIRdW H06 0004
   Revision: --H06---    Serial number: 0000001495
   Coding: 000002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: BB364AF03271A69240-80EE
   Part No SW: 8K0 907 379 CL    HW: 8K0 907 379 CL
   Component: ESP8 front    H09 0020
   Coding: 05154401
   VCID: 8542EC080C35206266-80D0
   Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
   Component: BCM2 2.0      H14 0650
   Coding: 01A44000000000000000
   VCID: FCB489EC7FFF61AA09-80A8
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000003964007
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0121
   Revision: A1000000    Serial number: 01160120142670
   Coding: 642002C000
   VCID: B73E56C0065982F2A4-80E2
   Revision: 08016001    Serial number: 00000058767701
   Coding: 260000108034AFC00081400300001D0D001C430826090201000004004401020100000020000000
   VCID: F8BC95FC4BC74D8A6D-80AC
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 160114  H15 0080
   Serial number: SWF14010165042
   Coding: 00FD11
   Serial number: 22144122
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000801141780
   Serial number: 7559C907000000000001
01854 - Heated Seat; Front Right (Z46)
                    Fault Status: 01101100
                    Reset counter: 242
                    Mileage: 89387 km
                    Date: 2018.10.03
                    Time: 20:27:45
01853 - Heated Seat; Left Front (Z45)
                    Reset counter: 243
                    Mileage: 89388 km
                    Date: 2018.10.12
                    Time: 10:28:02
   Serial number: 003KFDB3R39I
   Coding: 30513938363030303030554A304C38543053
   VCID: C8DC253C73A7FD0ADD-809C
   Serial number: 6334MSME416A451BF
   Serial number: 6344MSME416D1914D
   Serial number: 6352QSME6B3B1B4C-
   Serial number: 6362QSME733B0678N
   Serial number: 63732SME0A3C1D465
   Serial number: 63832SME0A3C2E6CG
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NAI000UC
   Coding: 000016
   VCID: C8DC253C7BA7FD0ADD-809C
   Part No SW: 8T0 920 932 L    HW: 8T0 920 932 L
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9D30861F
   Coding: 13873000020100080D0000
   VCID: C1CA3818589DCC421A-8094
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y141030839
   Coding: 80CF07FF00
   VCID: CAD81F3465AB0F1ACB-809E
   Serial number: 8000132203
   Serial number: 14010004675011200181
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H09 0305
   Coding: 011003624000450005
   VCID: D7FEF640A61962F244-8082
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0003179000
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B5225CC8145570E2B6-80E0
   Revision: 00002001    Serial number: 0323372658
   Coding: 013B0638A0B900008330043680000047
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H08 0305
   Coding: 011003224000450005
   VCID: D6E0FB44A1135BFA5F-8082
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 10000000313226
   ROD: EV_ParkiBrake_AU48.rod
   VCID: B93A50F8384D948252-80EC
   Part No SW: 4G1 035 053 H    HW: 4G1 035 053
   Component: Radio U Basic H41 0134
   Revision: AB001007    Serial number: 226AZ0E7874116
   Coding: 010003020100000001
   VCID: A404918CA7CFF96A11-80F0
   Part No SW: 8R1 035 652 D    HW: 8R1 035 652
   Component: B-BN-EU       H62 0188
   Revision: --------    Serial number: 148A-0E7762640
   Coding: 01010004000681ED01800B4E000000030001
   VCID: B42461CC172F69EA81-80E0
   Subsystem 1 - Part No: 4G0 919 884 N
   Component: EUR 2014  1702
   Subsystem 2 - Part No SW: 8T0 919 604 B    HW: 8T0 919 604 B
   Component: DU6 Basic  H43 0098
   Serial number: 9465LB0D2696295
   Subsystem 3 - Part No SW: 8T0 919 611     HW: 8T0 919 611
   Component: E0380 Bedient  H01 0100
   Serial number: 00000001725012
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010003224000450005
   VCID: D9FAF078D00D748272-808C
   Component: TSG HR        H07 0305
End----------(Elapsed Time: 01:37, VBatt start/end: 13.8V/13.7V)-----------
Address 5F,8R1 035 652 D,channel 6,adapted from,0,to,1,
Address 19,8R0 907 468 N,recoded (Installation List),from,FF30742C00028100,to,FF30742D00028100,,
Address 19,8R0 907 468 N,recoded (Installation List),from,FF30742D00028100,to,FF30742C00028100,,
Address 19: DTCs cleared
Address 09: DTCs cleared
Gateway Installation List:  8R0 907 468 N
Address 52,8T0 959 792 Q,recoded (Long Coding),from,011003224000450005,to,011003224C00450005,(06325/000/00000),Thursday,20,December,2018,20:02:19:05254
   Revision: --H09---
          U0164 00 [032] - -
   Coding: 000002
   Coding: 05154401
   Coding: 642002C000
   Coding: 260000118134AFE01481400300001D0D009C430826090201000004004401020100000020000000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000016
   Coding: 138F3000020100080D0000
   Coding: 80CF07FF00
   Coding: 011003224C00450005
   Coding: 01010004000681ED05800F4E000000030001
End----------(Elapsed Time: 01:35, VBatt start/end: 13.8V/13.8V)-----------
Address 09,8K0 907 063 DH,recoded (Long Coding),from,260000118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,to,260080118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,(06325/000/00000),
Address 09-02,8U0 955 559 B,recoded (Long Coding),from,02005D,to,03005D,(06325/000/00000),
Address 44,8K0 909 144 G,recoded (Long Coding-exp),from,100000000001,to,100000010001,(06324/000/00000),
Address 09,8K0 907 063 DH,recoded (Long Coding),from,260080118134AFE01481400300001D0D009C430826090201000004004401020100000020000000,to,260080118134AFE01481400000001D0D009C430826090201000004004401020100000020000000,(06325/000/00000),
Thursday,20,December,2018,21:01:45:05254
   Revision: --H09---
          U0164 00 [032] - -
   Coding: 000002
   Coding: 05154401
   Coding: 642002C000
   Coding: 260080118134AFE01781400000001D0D009C430826090201000004004401020100000020000000
   Coding: 00FD11
   Coding: 03005D
   Coding: 000016
   Coding: 80CF07FF00
   Coding: 100000010001
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.2V)-----------
bittuning
C?ID=347418
thanks for the fast response, hopefully you had a solution. thanks for reaction.
I don't think I understand exactly what it is you are trying to accomplish.
siLc
Tallinn, Estonia
C?ID=330192
If there are sensors in the back and no module 10, then it could be an aftermarket installation with no integration with the rest of the car. PL24 users can verify if this car is equipped with PDC from the factory.
bittuning
C?ID=347418
Thanks for reaction, in my opion the sensors are from factory default because they are integrated in the MMI for the sound settings.
