Saturday,05,January,2019,20:22:56:30756
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(Parallels)
VCDS Version 18.9.0.4 HEX-NET CB: 0.4437.4
VIN: WAUZZZ4G9DNxxxxxx License Plate:
Mileage: 142401km-88483mi Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 3B 42 44 46 47 52 53
5F 62 72
VIN: WAUZZZ4G9DNxxxxxx Mileage: 142401km-88483miles
Address 01: Engine (J623-CLAA) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 E HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0001
Revision: 53H37---
Coding: 32254012052F09020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907311E 001001
ROD: EV_ECM30TDI0114G0907311E.rod
VCID: 2502F5382499226288-8071
Part No SW: 4G0 927 156 S HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0004
Revision: --H10--- Serial number: 0000000481
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 3C34305CB71383AAC7-8069
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 27A6C705E465E3A0CB00
VCID: 36202274893F59FA31-8063
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.CLB
Part No SW: 4H0 907 064 FG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0560
Coding: 01B93006000000000000
Shop #: WSC 53484 001 1048576
VCID: 73A6DB60D2CD0CD2D6-8027
Serial number: 2312000068673013
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 17041200040582
Coding: 3622007820
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 271EFF305E953072BA-8073
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.CLB
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001287572
Coding: 690000108034A7E00905008300005F5FCF9DC70827080101000008402000
VCID: 77BEEF70C6B560F2EA-8023
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120309 H35 0080
Serial number: 120317110929
Coding: 0045F7
Component: RLS H04 0003
Serial number: 20139503
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 04 04 2012 00000812
Serial number: E9A80326000000000001
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0060
Revision: 11001001 Serial number: 55901208901402
Coding: 08030C
ASAM Dataset: EV_EPHVA18AU57X0000 004005
VCID: 40CC44ACDBFBE74A9B-8015
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG0084EL%
Coding: 30323436313330303537554A305234473053
Serial number: 3575HRB405V1BEPSCHPX
Serial number: 3585HRB404V1BBH2C88D
Serial number: 3515JRB400E4UHGCIHF3
Serial number: 3525JRB401E4UHGC9P0W
Serial number: 3554VRB405D18E5G118X
Serial number: 3564VRB400M4UHPKL0FU
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.CLB
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120417000975
Coding: 000035
VCID: 302C146C635B77CA6B-8065
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Part No SW: 4G9 920 980 B HW: 4G9 920 980 B
Component: TDieGb Nv H78 0416
Revision: 28131177 Serial number: 658190312596036
Coding: 33A7230813012600010600
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 32281E64655745DA1D-8067
Address 19: CAN Gateway Labels: None
Part No SW: 4G5 907 468 A HW: 4G5 907 468
Component: J533--Gateway H10 0028
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 33261B609A4D4CD216-8067
Subsystem 1 - Part No: 8X0 915 181
Component: J367-BDM
Voltage stabilizer:
Subsystem 2 - Part No: 8K0 959 663 F
Component: J532_DCDCStab
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 19041200040530
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 2F2E17107665683272-807B
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
VCID: 2E100A14716F613A79-807B
Component: SARA 6D H01 0051
Revision: -------- Serial number: EJ1BPA8200198M
ASAM Dataset: EV_SARA2 004010
ROD: EV_SARA2_004.rod
Address 42: Door Elect, Driver (J386) Labels: NONE
Part No SW: 4G8 959 793 G HW: 4G8 959 793 G
Component: TSG FA H03 0505
Coding: 011F16004001620002080002
VCID: 44C448BCC7E3FB6ABF-8011
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0027470277
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.CLB
Revision: 00002001 Serial number: 0174000735
Coding: 013F062220B9040083200904000104000000000000000000000000000000
Address 47: Sound System (J525) Labels: NONE
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000043861
Coding: 030000
VCID: 1D72DDD804C9EAA2D0-8049
Address 52: Door Elect, Pass. (J387) Labels: NONE
Part No SW: 4G8 959 792 G HW: 4G8 959 792 G
Component: TSG BF H03 0505
VCID: 43C64BA0C2EDFC5286-8017
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000319415
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A1806044D870D1AA5-807F
Address 5F: Information Electr. (J794) Labels: NONE
Part No SW: 4G0 035 193 E HW: 4G0 035 193 D
Component: RMC Cnct Nav H52 0775
Coding: 0101050001E15B67082B060301020100000000
VCID: 2502F5382C99226288-8071
Subsystem 1 - Part No: 8X0 919 884 D
Component: P13-50-11.06 0002
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464CT0C2521366
Subsystem 3 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Serial number: 90349LDC0017V
Address 62: Door, Rear Left (J388) Labels: NONE
Part No SW: 4G8 959 795 G HW: 4G8 959 795 G
Component: TSG HL H03 0505
Coding: 010F14004001620002080002
VCID: 46C052B4F1DFC97AA1-8013
Address 72: Door, Rear Right (J389) Labels: NONE
Component: TSG HR H03 0505
End------(Elapsed Time: 20:47, VBatt start/end: 14.6V/14.6V, Deb=2)--------
