Hi Guys , My 1st post and a relative beginner to VCDS. I had a bit of use with older versions of VCDS used on MK4 Golfs but that was a long while back.
I know this will have been asked a hundred times before over various cars but is it possible to change from Direct TPMS to Indirect TPMS
I have the HEX-V2 and my car is a May 2018 UK Audi RS3 which had the performance pack upgrade which gave it the Direct TPMS system over the standard Indirect system.
I have fitted my winter alloys which do not have the TPMS sensor valves installed, after which several tyre fitters said, not to bother installing the TPMS valves as they caused more trouble than they was worth and either just put up with the warning or turn the system off until you put the original alloys back on the vehicle.
I would rather if possible convert to the standard Indirect system and then switch back to Direct once my original alloys go back on, is this possible please.
Simon
Simon
Monday,31,December,2018,16:08:52:16116
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
VIN: WUAZZZ8V3JA908135 License Plate:
Mileage: 3623km-2251mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 42 44 47 4B
52 5F 65 6C BB BC D6 D7
VIN: WUAZZZ8V3JA908135 Mileage: 3623km-2251miles
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 E HW: 07K 907 309 E
Component: R5 2.5l TFSI X22 0003
Revision: 53X22000
Coding: 12250032242601033600
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM25TFS0118V0907404E 001003
ROD: EV_ECM25TFS0118V0907404A.rod
VCID: 3B23CAB513E64F9F8B7-806E
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2110
Revision: 00H06V07
ROD: EV_TCMDQ500021.rod
VCID: 2E05F3E1D094AA373C9-807A
Part No SW: 8V0 614 517 E HW: 8V0 614 517 C
Component: ESC H25 0625
Revision: 00000000 Serial number: 60938000000563
Coding: 2F9C938DD49913B18B920B67419669F4C92BC8D1D082967702415084020812
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035_VW41.rod
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0476815539
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C21C9A916E848A782D-8068
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001523544
Coding: 03100015000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 76B51B816844D2F7B49-8022
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 9960512900PAG0MUFU03
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001810100634
ROD: EV_BCMBOSCH_018.rod
VCID: 0849657912B0D407D65-805C
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 180308 043 0580
Serial number: 180316112804
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21314945X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 17 01 2018 00001798
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY180570ACZ
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099685382
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST0020ZRXP00000
Coding: 901E00
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018078
Coding: 0470151011
VCID: 4BC39A754346FF1F3B7-801E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 H HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0083
Serial number: 270318062
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 46D5AB4158240277E49-8012
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR43GTT2
Coding: 98CCC000008000005C5400CA00C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F607D09BAAD0FC9B-805C
Subsystem 1 - Part No SW: ----------- HW: 480 000 904 18
Serial number: 35700000000C28947F2V
Subsystem 2 - Part No SW: ----------- HW: 480 000 904 18
Serial number: 35800000000F86E47F21
Subsystem 3 - Part No SW: ----------- HW: 480 400 904 18
Serial number: 3510001A729A27C48342
Subsystem 4 - Part No SW: ----------- HW: 480 400 904 18
Serial number: 3520001A729A27C3C706
Subsystem 5 - Part No SW: ----------- HW: 480 400 604 18
Serial number: 3550002BB252D8614080
Part No SW: 8V0 953 521 JR HW: 5Q0 953 549 E
Revision: -------- Serial number: 07041804220191
Coding: 2418
VCID: 137342155BF667DF337-8046
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
Component: FBenRDW H16 0066
Coding: 242D08D23A8006000104EC041000001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3A2DCFB11CDC7697901-806E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Mileage: 3623 km
Date: 2018.12.31
Time: 16:00:16
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 27031810800889
Coding: 030100043F0860005B00806AB80B00000001010000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 3829D5B922D06487665-806C
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180403160347 21425
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3098487204
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00026.02.18
Coding: 0601
VCID: 4DC7946DBD52F12F253-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 42DDB751740C3E57C81-8016
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000113406003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E1893EB880E74AD-8060
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Component: TSG FS 020 0041
Serial number: 190318ECJ11866
Coding: 005D9A205C01040000001002
VCID: 43D3B2556B16375FC37-8016
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5F01GL4.
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 241111C98E581067DAD-8070
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 28031810800457
Coding: 000000050100147606102B03020000000000000000000000000000000000
VCID: 72BD2791042CCED7981-8026
Component: TSG BFS 020 0041
Serial number: 180318ECI09376
Coding: 005D92205E01040000001002
Part No SW: 8V1 035 035 D HW: 8V1 035 035
Component: MU-P-LND-EU 054 1168
Serial number: A698D0JS015553
Coding: 017363010000000011111102000A00332F0028E701700100DE
VCID: 3333E2953BB687DF537-8066
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y09UWD
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL130011800050620
Component: Gracenote2 --- 1016
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 218
Mileage: 3589 km
Date: 2018.12.28
Time: 14:01:39
Voltage terminal 30: 12.2 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 8S0 907 273 HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0002
Serial number: 30000000004938
ASAM Dataset: EV_RDKHUFAU736 002007
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 77AB16856F4EABFFAFF-8022
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273100102002001400040
VCID: 392FD0BD19DA7D8F99B-806C
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 220318ECM16567
Coding: 000C92204001040000001002
VCID: 45D7AC4D6522096FED3-8010
Component: TSG HBFS 020 0041
Serial number: 220318ECM16909
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176B36054F0E4BFF4FF-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----(Elapsed Time: 01:51, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
