The Amarok is both the first VW and the first pickup I have ever owned and this is my first experience of VCDS (Christmas present from the family) and therefore my first post here, of course.
Using information from the internet, with slight variations, I have managed to activate the Alt Speed Dis option to remove the KPH display which UK buyers are afflicted with, and also to change the Comfort Turn Signal from 3 flashes to 5, although this option was found in Channel 43 of Central Electrics adaptation, as indicated in a yellow help pop-up, rather than the channel usually suggested online.
However, the Amarok has a stop/start function which drives me mad. It can be turned off each engine start with a button but I always forget until the first time it stops so I'd like to change the default to "stop/start" off or just disable it completely.
I've found various suggestions on the internet which involve finding a drop-down listing which says "Start/stop start voltage limit" but I don't seem to have any drop-down with that entry. In fact, in the place where that option is supposed to be found, 19 CAN Control Gateway / Adaptation 10, I only have one entry in the drop-down, something to do with Fatigue Alarm or similar. My controllers all seem to be CAN rather than UDS although I don't know if that is relevant.
I've also found online references to an adaptation of module 09-Central elect., channel 34 by adding or subtracting numbers from the number present by default. I can find this channel which has a default entry of 30 on my Amarok, so could add or subtract but I've no idea whether this is really the right place. I tried subtracting 4 and then pressed "Test" but nothing seemed to happen, although I'm not sure what should happen anyway.
I decided not to make any changes unless I can discover whether this is really the right place.
I also have a complete VCDS auto scan which I assume I need to add as an attachment to this post but, as I can't see how to attach at the moment, I will provide a link to it: https://www.dropbox.com/s/xf2pfdvzwoay65y/VW Fault Codes using Auto Scan.pdf?dl=0
Thanks, in advance, for any help.
Richard
Richard
Wednesday,26,December,2018,13:51:28:28075
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: WV1ZZZ2HZKH005968 License Plate:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 5F 61 65 69 0B
VIN: WV1ZZZ2HZKH005968 Mileage: 2030km-1261miles
Address 01: Engine (J623-DDXE) Labels: None
Part No SW: 2H6 907 311 K HW: 059 907 309 J
Component: 3.0l V6 TDI H23 0002
Revision: 9AH23---
Coding: 012A4032233601030001
Shop #: WSC 02776 790 50316
ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
ROD: EV_ECM30TDI0112H6907311K.rod
VCID: 3038E6D56AA589372EB-8064
Address 02: Auto Trans (J217) Labels:| 0CM-325-025.clb
Part No SW: 2H0 927 158 M HW: 0DR 325 025 B
Component: 0CM 30TDIRdW H22 1001
Revision: --H22---
ASAM Dataset: EV_TCMAL450211 002011
ROD: EV_TCMAL450211.rod
VCID: 372ADDC98FCB5E0F6F1-8062
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2H6 907 379 A HW: 2H6 907 379
Component: ESC H06 0310
Revision: 00000000 Serial number: 62848000000643
Coding: 207364B64994B69A04AB26A992586D85390000
ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
ROD: EV_Brake1ESCCONTIVN817GP_008.rod
VCID: 3430EAC59EBDB5174A3-8060
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 05101813470993
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA408EDE071AF47EC7-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H6 907 040 B HW: 2H6 907 040 B
Component: ClimatronicT5 H04 0613
Revision: 00001K05
Coding: 0000000003
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 2614008D5861D787C47-8072
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 C HW: 7E0 937 089 C
Component: BCM PQ25 MMI4 H82 0762
Revision: BB082001 Serial number: 8701 289180738
Coding: 240002380C61140093380F316CCB86D4B280654F60CE7160310000030803
Shop #: WSC 66305 512 1451434
VCID: 3332E9D99B33B22F539-8066
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 051018 05 50 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 802 EJ HW: 6R0 959 802 EJ Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2332
Serial number: 12102844180919142031
Subsystem 3 - Part No SW: 6R0 959 801 EF HW: 6R0 959 801 EF Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2332
Serial number: 13202847180919074545
Subsystem 4 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Subsystem 6 - Part No: 5C0 951 171
Subsystem 7 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180001911110078395
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 P HW: 6R0 959 811 P
Component: J388__TSG_HL 022 1334
Serial number: 12102709180919171512
Subsystem 9 - Part No SW: 6R0 959 812 P HW: 6R0 959 812 P
Component: J389__TSG_HR 022 1334
Serial number: 12102708180919105908
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231825102314
Coding: 31810E
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BE23D1A12FC03F615-8024
Part No SW: 2K5 959 655 D HW: 2K5 959 655 D
Component: VW10Airbag01S 010 0018
Revision: -------- Serial number: 003EL003S6RG
Coding: 000000000000000000000000000000003153
Shop #: WSC 02774 790 50316
VCID: 3D26CFE1ADF7745FB5D-8068
Serial number: 3495RRB40045E1GUBPL2
Serial number: 3505RRB40555L22OHGMT
Serial number: 3555YRB405T5L22K71O
Serial number: 3565YRB405T5L22K61KY
Part No SW: 2H6 920 983 A HW: 2H6 920 983 A
Component: KOMBI H02 2030
Coding: 431E000300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 089 C
Component: GW-K-CAN TP20 H82 0762
Revision: BB082001
Coding: 742303
VCID: 68884EB5927501F736B-803C
Component: IMMO H02 2030
Coding: 000002
VCID: 6A8C34BD8CF933E720F-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 B HW: 2H0 927 771
Component: Quersperre H04 0018
Revision: 11001001 Serial number: 4DG 04.09.18 00
ASAM Dataset: EV_QuersUDSAAMVN817 002001
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2D06FFA17D97E4DF05D-8078
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0472
Serial number: VWZAZ2U1612708
Coding: 06180701BE00000011111101008808001F0100D6002001004F
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 251607812567DC9FCDD-8070
Subsystem 1 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
Part No SW: 7E0 907 534 HW: 7E0 937 089 C
Component: Batt.regelung H82 0762
Coding: 330B18AF
Shop #: WSC 02776 790 00000
Subsystem 1 - Part No SW: 2H6 915 181 HW: 2H6 915 181
Serial number: 74975408001810030347
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 2H6 907 273 HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000031077
ASAM Dataset: EV_RDKBERU30 006003
ROD: EV_RDKBERU30_006_VW48.rod
VCID: 6C8032A5860D2DD7523-8038
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000492663969
Coding: 010D000100000000
VCID: 3038E6D56A2589372EB-8064
End----------(Elapsed Time: 02:13, VBatt start/end: 12.1V/12.1V)-----------
