Amarok V6 3.0 - 2018 Model - Disabling Stop/Start
RichardS
C?ID=351800
The Amarok is both the first VW and the first pickup I have ever owned and this is my first experience of VCDS (Christmas present from the family) and therefore my first post here, of course.
Using information from the internet, with slight variations, I have managed to activate the Alt Speed Dis option to remove the KPH display which UK buyers are afflicted with, and also to change the Comfort Turn Signal from 3 flashes to 5, although this option was found in Channel 43 of Central Electrics adaptation, as indicated in a yellow help pop-up, rather than the channel usually suggested online.
However, the Amarok has a stop/start function which drives me mad. It can be turned off each engine start with a button but I always forget until the first time it stops so I'd like to change the default to "stop/start" off or just disable it completely.
I've found various suggestions on the internet which involve finding a drop-down listing which says "Start/stop start voltage limit" but I don't seem to have any drop-down with that entry. In fact, in the place where that option is supposed to be found, 19 CAN Control Gateway / Adaptation 10, I only have one entry in the drop-down, something to do with Fatigue Alarm or similar. My controllers all seem to be CAN rather than UDS although I don't know if that is relevant.
I've also found online references to an adaptation of module 09-Central elect., channel 34 by adding or subtracting numbers from the number present by default. I can find this channel which has a default entry of 30 on my Amarok, so could add or subtract but I've no idea whether this is really the right place. I tried subtracting 4 and then pressed "Test" but nothing seemed to happen, although I'm not sure what should happen anyway.
I decided not to make any changes unless I can discover whether this is really the right place. :o
I also have a complete VCDS auto scan which I assume I need to add as an attachment to this post but, as I can't see how to attach at the moment, I will provide a link to it: https://www.dropbox.com/s/xf2pfdvzwoay65y/VW Fault Codes using Auto Scan.pdf?dl=0
Thanks, in advance, for any help.
Richard
Wednesday,26,December,2018,13:51:28:28075
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
VIN: WV1ZZZ2HZKH005968   License Plate:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 5F 61 65 69 0B
VIN: WV1ZZZ2HZKH005968   Mileage: 2030km-1261miles
Address 01: Engine (J623-DDXE)       Labels: None
   Part No SW: 2H6 907 311 K    HW: 059 907 309 J
   Component: 3.0l V6 TDI   H23 0002
   Revision: 9AH23---
   Coding: 012A4032233601030001
   Shop #: WSC 02776 790 50316
   ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
   ROD: EV_ECM30TDI0112H6907311K.rod
   VCID: 3038E6D56AA589372EB-8064
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 M    HW: 0DR 325 025 B
   Component: 0CM  30TDIRdW H22 1001
   Revision: --H22---
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211.rod
   VCID: 372ADDC98FCB5E0F6F1-8062
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 62848000000643
   Coding: 207364B64994B69A04AB26A992586D85390000
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   VCID: 3430EAC59EBDB5174A3-8060
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 05101813470993
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA408EDE071AF47EC7-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
   Component: ClimatronicT5 H04 0613
   Revision: 00001K05
   Coding: 0000000003
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2614008D5861D787C47-8072
   Part No SW: 7E0 937 089 C    HW: 7E0 937 089 C
   Component: BCM PQ25 MMI4 H82 0762
   Revision: BB082001    Serial number: 8701 289180738
   Coding: 240002380C61140093380F316CCB86D4B280654F60CE7160310000030803
   Shop #: WSC 66305 512 1451434
   VCID: 3332E9D99B33B22F539-8066
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 051018 05  50  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 802 EJ    HW: 6R0 959 802 EJ  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2332
   Serial number: 12102844180919142031
   Subsystem 3 - Part No SW: 6R0 959 801 EF    HW: 6R0 959 801 EF  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2332
   Serial number: 13202847180919074545
   Subsystem 4 - Part No: 5C0 951 171
   Component: Sensor, DWA 0  005 0502
   Subsystem 5 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
   Subsystem 6 - Part No: 5C0 951 171
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180001911110078395
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
   Component: J388__TSG_HL  022 1334
   Serial number: 12102709180919171512
   Subsystem 9 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
   Component: J389__TSG_HR  022 1334
   Serial number: 12102708180919105908
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231825102314
   Coding: 31810E
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BE23D1A12FC03F615-8024
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag01S 010 0018
   Revision: --------    Serial number: 003EL003S6RG
   Coding: 000000000000000000000000000000003153
   Shop #: WSC 02774 790 50316
   VCID: 3D26CFE1ADF7745FB5D-8068
   Serial number: 3495RRB40045E1GUBPL2
   Serial number: 3505RRB40555L22OHGMT
   Serial number: 3555YRB405T5L22K71O
   Serial number: 3565YRB405T5L22K61KY
   Part No SW: 2H6 920 983 A    HW: 2H6 920 983 A
   Component: KOMBI         H02 2030
   Coding: 431E000300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   Part No SW: 7E0 909 901     HW: 7E0 937 089 C
   Component: GW-K-CAN TP20 H82 0762
   Revision: BB082001
   Coding: 742303
   VCID: 68884EB5927501F736B-803C
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A8C34BD8CF933E720F-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771 B    HW: 2H0 927 771
   Component: Quersperre    H04 0018
   Revision: 11001001    Serial number: 4DG 04.09.18 00
   ASAM Dataset: EV_QuersUDSAAMVN817 002001
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 2D06FFA17D97E4DF05D-8078
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U1612708
   Coding: 06180701BE00000011111101008808001F0100D6002001004F
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 251607812567DC9FCDD-8070
   Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 7E0 907 534     HW: 7E0 937 089 C
   Component: Batt.regelung H82 0762
   Coding: 330B18AF
   Shop #: WSC 02776 790 00000
   Subsystem 1 - Part No SW: 2H6 915 181     HW: 2H6 915 181
   Serial number: 74975408001810030347
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 2H6 907 273     HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000031077
   ASAM Dataset: EV_RDKBERU30 006003
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 6C8032A5860D2DD7523-8038
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000492663969
   Coding: 010D000100000000
   VCID: 3038E6D56A2589372EB-8064
End----------(Elapsed Time: 02:13, VBatt start/end: 12.1V/12.1V)-----------
Hi and welcome to our forum.
I don't know the Amarok well enough to offer any suggestions on the start/stop question.
However, I need to make an "Admin Request": Please don't use the PRINT function in VCDS to post scans or other data here; the formatting it produces is good for a sheet-fed printer but is quite hard to read here. Please just copy & paste the original, plain text that VCDS produces when you use the COPY or SAVE functions.
RichardS
C?ID=351800
Sorry about that. I can see the problem now so I've reformatted the auto scan and re-posted it above.
It's much better, I hope. :)
Richard
golfi_vend
Tartu, Estonia
C?ID=195131
Richard
Better, but somehow spaces and whitespace is still lost.
OK .... tried again. :)
It's pretty legible now. :thumbs:
Pro-Tip: If you've done an Auto-Scan, even if you didn't explicitly save it in its native text format, VCDS did so surreptitiously in its Scans sub-folder. :cool:
RichardS
C?ID=351800
Now that's a great tip Uwe, many thanks.
I've now inserted the genuine article into my OP. :)
Richard
darkchina811
ITALY
C?ID=333184
go on the bay and buy the interface that will "press" your S&S button every time you switch the ignition on. that's the cleanest way to get rid of it.
RichardS
C?ID=351800
I'm still playing around with VCDS and trying to understand things better.
I stumbled upon this today:
I don't have the option listed to disable stop/start using the HVAC temperature parameters often mentioned on the web but this option looks as if it might have a similar effect. However, the language leaves me confused so I haven't tried it yet.
If I select it I will change "stop release for stop-start function" from "according to function requirements" to "always" .... but what does "always stop release" mean in plain English, I wonder? If "release" means "operation" then it might work providing it doesn't reset every engine start like some of the stop/start options do.
Has anyone tried this option?
Richard
OK, I've tried the "Always" setting and the good news is that the control module the remembers the setting but the bad news is that it doesn't disable stop/start. I don't know what it does .... maybe it sets stop/start so that it always engages without checking the HVAC function requirements .... but, either way, it's not what I'm hoping for. :(
BavarianCare
Ireland
C?ID=11022
Try this...
VAG Stop/Start Adaption – 2018.08.23
1. 09-Central Electrics
2. Security Access (16) – 20113
3. Adaption 10
4. Channel 34
Values:
4: Standard, Default ON, light when off
-4 Default OFF, light when off
+32 Default LAST USED SETTING, light when off
+64 Reverses warning indicator, light when on
RichardS
C?ID=351800
Try this...
3. Adaption 10
4. Channel 34
Values:
I've tried something like that Audi process (I believe that my engine was used in Audis) although I didn't go through Security Access / 20113. Does this mean that my way would never have worked?
What I did was go straight from 09-Cent. Elect. to Adaptation 10 and then select Channel 34. I took the following screenshot:
My value in Channel 34 is currently stored as 30, so I increased it to 94 and then clicked "Test". I hoped that at this point the yellow light on the Stop/start switch would come on to indicate that its operation has been reversed but nothing happened, so I exited out without Saving in case I was going to mess something up. :(
I might have got that wrong and perhaps that's not how the "Test" function would operate in this circumstance?
Also, I wasn't sure whether I was supposed to add 64 or change the value to 64, so I "Tested" both but neither did anything.
Any advice you could give me would be most welcome.
Many thanks
Richard
BavarianCare
Ireland
C?ID=11022
You need to login
RichardS
C?ID=351800
You need to login
I finally had time today to try and login to 09-Central Electrics / 16-Security Access using 20113 but this is all that happens:
I don't seem to get locked out or anything bad .... just the error message and then I back out to the start.
This is the full list of documented adaptations in Cent Electrics. There's nothing about Start/Stop in there so presumably Channel 34, if it has anything to do with Stop/Start, is undocumented. There is a value of 30 in Channel 34 so presumably it does something but we just don't know what?
I'd be happy to try any further ideas.
Richard
NEtech
C?ID=56995
The procedure from BavarianCare, is not for your controller!
So that login is not used here.
Channel 34 in your 09-Central Electrics, is some turning light angle.
RichardS
C?ID=351800
I see. Thank you. Maybe it's the "Cornering Fog Lights" which come on when the steering wheel is turned more than a certain angle.
I wonder why that option does not appear in the drop-down list with the other documented adaptations? Having said that, I don't really understand what most of this VCDS stuff means anyway. :o
Do you know if there is a channel which relates to Start/Stop?
Richard
PS I think my Amarok is actually a 2019 model year if that makes any difference.
RichardS
C?ID=351800
I've been trying to explore VCDS and my Amarok 2H and gain more understanding of these coding bytes and bits and, with the help of a binary - hex calculator, it's beginning to make more sense. :)
This is where I think I have got to now but I'd be grateful if someone could advise me whether I've grasped the basics.
Firstly, my 2H truck scan includes the following:
09 Cent Elect (J519)
Coding: 240002380C63140093380F316CCB96D4B280654F60CE7160310000030803 (30 bytes)
I think I am right in saying that the Amarok is therefore built on the PQ25 platform and will be similar, in terms of VCDS tweaks, to other PQ25 vehicles.
The second controller which seems to be often mentioned in the context of start-stop is the CAN Gateway. My scan shows:
Coding: 742303 (3 bytes)
I have looked at other scans on this forum which include 09 Cent Elect (J519) Component: BCM PQ25 and they all seem to have 30 bytes in this module although with different bits, of course. These scans also seem to show 19: CAN Gateway (J533) Component: GW-K-CAN TP20 and they also seem to have only 3 bytes in use.
Am I therefore correct that if I could find an example of a car which has a Cent Elect (J519) BCM PQ25 and a CAN Gateway (J533) GW-K-CAN TP20 where start-stop has been modified by changing bits in Cent Elec or CAN Gateway, then I would be able to do the same .... or is it even more complicated than that?
From my searches so far, it does appear, as mentioned above, that there is no known way to modify start-stop with these two particular controllers but, if my logic above is correct, at least I know what I'm looking for.
Many thanks for any help.
Richard
Amarok_2019
Sweden
C?ID=578832
Hi Richard!
How did it go for you were you able to disconnect the start/stop function?
I have a Amarok V6 190 kW 2019 and have tried to find how to do this.
I have original Ross-tech tools and SW.
Thanks in advance
Kaj
AINils
Germany (AIB)
C?ID=56975
In 2019 Aamrok BCM it won't work anymore, but in Controller 61 -> Adaption -> Channel 13 it should be possible
1SVK1
Slovakia
C?ID=311579
amarok 61-battery regulation, go to adaptation select item Start/Stop stored value 10 new value 3D
