Upsidedown
New Member
Haldex controllers used on VW group 4 wheel drive systems provide outputs to the ECU for diagnostics (e.g. Haldex clutch pump failure) However unlike some other manufactures using Haldex controllers, a fault does not bring up a warning light on the dashboard (e.g. Ford Kuga). Such a fault indication could save considerable money otherwise spent on expensive repairs (e.g. destroying the pump because of low oil flow rates) and potentially avoid some dangerous situations where the driver mistakenly believes they have 4 wheel drive but in fact they are actually only 2 wheel drive.
The query is therefore would it be possible to add a code to say for example the existing traction control light such that a fault in the Haldex registered in the diagnostics would bring up a warning?
