Jetta 2005 2.5 L lost battery due to a big leak 2A constant.
peter11742
C?ID=356126
Thanks I will do this tomorrow.
Can you look the injectors the car smells good I thing is the wiring.
The other Box gives me the same errors and of course the key imobilizer.
I will look at the pulses of the heating element in the injectors under the car first.
I must see pulses of the heating ground around 3 volts with my oscilloscope.
peter11742
peter11742
C?ID=356126
OK.
DRL is gone.
The engine light is on failing Oxygen Sensors.
My oscilloscope has pulses of 4 volts at the end that goes to J220.
The wires have color brown/blue T121/6 and Brown/green T121/63 to the ground.
My background tells me the heaters work.
I will measure next the injector outputs and see what I get.
I will add the measurement here.
Between T121/10 White/brown and T121/11 green/brown 1.5 ac signal pic to pic.
Between T121/68 white/Yellow and T121/69 green/yellow 1.5 ac signal pip to pic.
Now whoever did this before he can compare the values and inform me.
This is a good test and the answer will help many people.
peter11742
dafrazi
Norristown, PA
C?ID=173774
You are writing injectors. Do you mean oxygen sensors? The reported faults are with the oxygen sensors, not the fuel injectors.
If evaluating the oxygen sensors, use the measuring block function in VCDS to log the sensors over a short drive.
   #44
peter11742
C?ID=356126
Sorry.
I meant oxygen sensors, I corrected my error.
You see the values I need someone who did the same test to tell me if he has better values.
I will shortly do this but I do not know what it will be accomplished with the software.
Shortly I will have the results from the software part of the Oxygen Sensors.
I will guess digital values will be show us if Oxygen Sensors work.
I did what you mentioned but I see the Oxygen Sensor with value 0.0 not working and I can not read any other option to see more information. Any other option to try.
peter11742
peter11742
C?ID=356126
Uwe.
I need help with Jetta's 2017 Radio.
The radio is model L56VM2 561035150A.
My VIN 3VWDG71KX5M602637
They do not much I get error: components protection active.
The dealer wants big time money to fix it.
Is it possible to be done if not let me know.
peter11742
   #47
peter11742
C?ID=356126
OK.
This sounds reasonable.
I will find my next options.
Thanks for the answer.
I found a fix for the radio in your web but i lost the internet and I can not find it again.
My radio is cheep and we can do anything on the mother board.
Any one has fix the (components protection active) VW radio 2016-2017 plain no options.
Please let me know.
peter11742
peter11742
C?ID=356126
This information is for the support group.
Today I installed a new oxygen sensor on the top at the engine's exhaust.
For my surprise I scan the system and I got the same results.
Wednesday,09,January,2019,12:18:35:56328
VCDS Version: 18.9.0.4  HEX-V2 CB: 0.4437.4
VIN: 3VWDG71KX5M602637   License Plate:
Mileage:    Repair Order: 1
                Address 01: Engine       Labels: 06A-906-032-BGQ.lbl
Control Module Part Number: 06A 906 032 QC    HW: Hardware No
  Component and/or Version: 2.5l R5/4V      G   6605
           Software Coding: 0000003
            Work Shop Code: WSC 00066 000 00000
                      VCID: 6FBBD1C63B90CCFF771-803A
16426 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
            P0042 - 004 - Malfunction /Open Circuit - MIL ON
16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
            P0036 - 004 - Malfunction / Open Circuit - MIL ON
16415 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
            P0031 - 002 - Short to Ground - MIL ON
17925 - Power Supply Relay for ECU
            P1517 - 004 - Electrical Malfunction - MIL ON
17069 - ECM Power Relay Control Circuit
            P0685 - 004 - Open Circuit - Intermittent
Readiness: 0010 1101
I will give you the all scan.
Wednesday,09,January,2019,12:05:23:56328
Mileage: 174340km-108329mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
          72 77
VIN: 3VWDG71KX5M602637   Mileage: 174340km-108329miles
56-Radio -- Status: Sporadic communication error 1000
77-Telephone -- Status: Not registered 0001
   Part No SW: 06A 906 032 QC    HW: Hardware No
   Component: 2.5l R5/4V      G   6605
   Revision: 00000000    Serial number: VWZ7Z0D1108127
   Coding: 0000003
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   VCID: 025D88721802D19788F-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A2D30923052595790F-806E
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 6889BADA1E7E1BC736B-803C
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000006675
   Coding: 44058E03400418000014000000140000002077035C
   VCID: 2F3B11C6FB108CFF371-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 12345
10 Faults Found:
01335 - Drivers Seat/Mirror Position Control Module (J543)
02092 - Enabling Heated Seat
02403 - Terminal 15 for Interior
02402 - Control Circuit for Terminal 15 for Interior
00061 - Footwell Lights
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0060
   Revision: 00000000    Serial number: AUZ4Z7D7020608
   VCID: 2B0305D6CF08F0DF1B9-807E
                    Reset counter: 193
                    Mileage: 174349 km
                    Time: 00:00:04
01304 - Radio
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 00:53:14
                    Fault Status: 00101110
                    Reset counter: 229
                    Mileage: 174349 km
                    Time: 19:54:28
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:06:14
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD009JN8
   Coding: 0012627
   VCID: 2E050CC2FC1A85F73C7-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME06015E276
   Subsystem 3 - Serial number: 6342MSME0738210E7
   Subsystem 4 - Serial number: 6351HSME041B522B3
   Subsystem 5 - Serial number: 6361HSME040D4E1FJ
   Subsystem 6 - Serial number: 63727SME052B4110R
   Subsystem 7 - Serial number: 63827SME052C093A2
00591 - Seat Belt Switch; Driver (E24)
   Part No SW: 1K0 953 549 AC    HW: 1K0 953 549 AC
   Component: J0527           010 0045
   Coding: 0012041
   VCID: 73B3DDB657B8E81F939-8026
   Component: E0221           004 0030
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104A120448
   Coding: 3F7F03620F1002
   VCID: 290FFFDEC5F4E2CFE95-807C
                    Fault Frequency: 67
                    Reset counter: 193
                    Mileage: 174349 km
                    Time: 01:50:16
01304 - Radio
                    Reset counter: 233
                    Mileage: 174349 km
                    Time: 01:52:50
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TMVE903
   VCID: 78A9EA9A4EDE8B47A6B-802C
                    Reset counter: 229
            015 - Cannot Be Tested at this Time - Intermittent - MIL ON
                    Fault Status: 10111111
                    Fault Frequency: 15
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 01:25:07
                    Reset counter: 229
                    Mileage: 174349 km
                    Time: 19:54:28
   Component: IMMO            3HL 2120
02241 - Engine Control Module; Immobilizer Data not Adapted
            000 -  -  - Intermittent
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
02327 - Position Sensor for Front Seat Height Adjustment (G438)
02341 - Position Sensor for Seat Fore/Aft Adjustment (G441)
02328 - Position Sensor for Rear Seat Height Adjustment (G439)
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 363524A2044ABD37747-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 303912BAE62E93072EB-8064
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
   Component: LIN BACKUP HORN H02 1301
9 Faults Found:
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 124
                    Reset counter: 193
                    Fault Status: 01101101
                    Reset counter: 193
                    Mileage: 174349 km
                    Time: 21:02:14
                    Fault Status: 01110011
                    Fault Frequency: 19
                    Reset counter: 193
            002 - Lower Limit Exceeded
                    Fault Status: 01110010
                    Fault Frequency: 9
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:11:24
                    Reset counter: 232
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:33:57
                    Reset counter: 232
                    Reset counter: 232
                    Mileage: 174349 km
                    Time: 00:06:54
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000002248
   VCID: 698FBFDE057422CF295-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 372B29A60340443F6F1-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F17BEED249A0F215-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D18B2E822A11758F-8066
Address 77: Telephone
End----(Elapsed Time: 01:16, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
I want only to get rid of the oxygen sensors errors so I can inspect the car for use.
I also read somewhere that the coding of the controller is not good.
Please tell me if you need it, maybe you can reload it.
Please let me know.
peter11742
peter11742
C?ID=356126
So far no one is answering. it is difficult and this is the first time I deal with VW.
At this point I will see if any other help will come soon.
I will replace the other 2 oxygen sensors and I will stop working in the car until I have some news.
   #50
_Val
Latvia
C?ID=356659
Have you atleast tried deleting all fault codes to see what comes up again?
Have you found wiring diagram to check oxygen sensor heating and you check is it working? It should be basic task for "engineer" with simple 12v voltmeter or light bulb.
   #51
peter11742
C?ID=356126
Val.
Thanks.
I have done all the question that you asked.
The errors I delete them I wait for 1 minute and they come back and I use 2 different instruments.
I also did measurements with my oscilloscope and also replaced one of oxygen sensors.
The errors are always there.
I do not know why this problem can not go away.
It will take time but I will get the solution.
peter11742
   #52
Andy
Sector 7G
HC424490
Is there any wiring harness damage, possibly ground related?
   #53
peter11742
C?ID=356126
Andy.
I did not find any bad ground.
By the way do you know what is J220 in the jetta and where is located.
I am getting errors P1517 and P0685. All my relays are checked and work on 12 v.
I also have a confusion Oxygen B1 S3 ,Oxygen B1 S2, Oxygen B1 S3 a diagram or description where are located.
I have a new one on the exhaust on the back of the Engine. All failed in my last check.
I will change the other 2 oxygen sensors and then I will know the oxygen sensors can not be the problem.
They all Bosh.
peter11742
FYI: NostraJackASS above clearance intelligence wildcard!
Bad new FACTORY IMITATED cloned pirated OXS sensors, are indeed in circulation & will cause this!
   #55
peter11742
C?ID=356126
Thanks for the info.
I have one already out how to check it? if is an original with bad markings.
I need help with S1,S2,S3 Oxygen sensors locations.
Can you tell me what is the S number on the one that you see from the top of the engine.
This is the only one with different part number.
The ones I have they are from AutoZone and they are made by Bosch hopefully are good.
I also started the Jetta this morning with -5 degrees F. it started instantly.
I scan the can buss and I get 2 errors oxygen sensors 1,2,3 and *****controller incorrectly coded*****.
This is a message that I got many times do we have any software person to inform us.
Can it be a fake message?.
peter11742
Component and/or Version: 2.5l R5/4V G 6605 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed 9422 or higher!
:banghead:
New auto-scan please and complete!
Fuses for Heaters sir check and tone out wires with load light + measure current draw with DVOM AMP probe!
WD and component locations but sir counting form manifold 1 2 3 .................red light!
123 Load lights
peter11742
C?ID=356126
Jack.
Thanks for the location of oxygen sensors.
VW has no picture of them.
Now the #1 oxygen sensor is brand new and still fails.
If you read my work you will see that I gave a good overview of my work with my oscilloscope.
As far the the power supply relay problem I will continue weather permitting.
I know my business do not send any more nasty answers.
You probably know well the car business I know the medical business CAT, MRI, Special procedure X-ray Cath. labs Medical Lasers.
As you know I do not know the VW.
I will fix it on my own.
This is my last report I am getting out of this site.
Uwe you the only person that I liked just control the people around here.
peter11742
   #58
If there is someone here whose help you do not wish to receive, just go to that person's profile and click on "Add to ignore list".
peter11742
C?ID=356126
Uwe.
Thanks.
I will do this thanks for the information.
Today I change my laptop to win 10 32 bit.
The option LT3 was not available at the car but in the house was back strange.
I try a new project I have an extra good J519 I want to make it the same like my car's J519.
If you know the procedure please say a few words to help.
Peter11742
   #60
Jack.
peter11742
Peter,
Yes the RTFB does have pictures of the locations of the OXS sensors......
https://i.postimg.cc/vMc1sN72/OXS-yes.png?dl=1
Sorry if you think my questions are offensive, that is not the intent, I'm just trying to make you think.
Let's make it all about me because I'm the asshole, so dump it all on me as the scapegoat, okay? I can't but help feel your pain, release it to me and set it free!
Your test paths, aforementioned reading/comprehension or choice of type of WD were & are indeed poor or as you describe with a scope even.
Please keep in mind the heater circuits are all shared in the OXS sensors & within the controller & with a shared fuse.
You may have changed the OXS sensor but the controller may also possibly already be actually damaged & there is indeed a problem within the AFT for poorly rated parts for this car and all ME7 for VAG suffer issues with this circuit.
Each heater circuit is a duty cycle ground completion pulsed bus type circuit and the controller adds up the heater circuits to also perform a DTC diagnosis which can be observed in VCDS during basic setting tests for readiness & a cross check algorithm & to deliberately make aftermarket parts fail in second or third drive cycles being completed to mess up your day.
0x01-04-041>
You haven't posted the data I requested or a DTC number and your old scan shows no evidence of a coding issue but your car is coded correctly.
Coding: 0000003
https://forums.ross-tech.com/showth...ak-2A-constant&p=152088&viewfull=1#post152088
Please let me know.
peter11742
https://forums.ross-tech.com/showth...ak-2A-constant&p=152117&viewfull=1#post152117
Val.
Thanks.
peter11742
peter11742
These posts are not the type of reports or questions I'd expect from any engineer in any field!
Instead of this myopic approach and spouting off credentials or about other systems, maybe ask more educated questions or read the SSP on design and function?
Ground fault loop......and exists in your medical equipment too, alarm and fire systems and the aforementioned car.
I figured after over a month you needed someone to give you a push and or kick in the ass & since you were crying in aforementioned posts and it looked like you were/are simply frustrated.
Now let's focus that anger and have some fun?
Have you checked SB fuse 45?
Is real power with amperage to drive a load circuit available at each OXS sensor for the heaters?
https://i.postimg.cc/kD3mfh5L/ROTTEN-PETER.png
https://i.postimg.cc/NGLjG3vG/ROTTEN-PETER.png?dl=1
Tired of the steady drip drip drip of this thread?
https://www.youtube.com/watch?v=7KNQFGU1qj0
Vehicle Identification No.3VWDG71KX5M602637
ModelJetta
JEM
Date of production01.03.2005
Year2005
Sales type1K27N3
Engine CodeBGQ
Transmission CodeHFU
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HMVehicle class differentiation -1KM- Build status corresponds to production in Mexico
tail pipe0P1Rear side exhaust tailpipe
Emission standard0GTEmission standard SULEV
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XCExterior mirrors: power-adjustable
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
Equipment levelsA8XUS comfort equipment
Brake type in rear1KEDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Controls (steering wheel/steering column)4LCRadio and telephone controls
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ1Chrome package
General operating permit, alterationsC08Operating permit, alteration
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG46Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AJElectronic immobilizer, with anti-theft alarm system and backup horn
Inserts5TKDecorative inserts, wood trim
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Manufacturing sequence differentiation0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Without extended pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K9Daytime headlights with automatic headlight control and coming home function
Antifreeze1C2Antifreeze up to -35 degree celsius tolerance up to -40 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YFWeight range 6 installation control only, no requirement forecast
Weight category front axleL14Suspension range 14 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U0Without luggage compartment cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC1Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG1A6-speed automatic transmission
glove box4Z3Lockable glove compartment door, with light
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M0Without rear window wiper and washer system
Rear seats3NQRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body styleK8BNotchback
coolbox1W2Glove compartment cooling system
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Compass/road sign displayQR1With compass
headrest for seat, rear3Q6Three rear head restraints
Head restraints5ZHHead restraints for front seats, tilt- and height-adjustable with integrated adjustment mechanism
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Radiator grille6KGRadiator grille
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K0with no paint conversation
Paint coatingFB0standard paint coating
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P1Power adjustable lumbar support in front seats
steering wheels2ZBLeather-wrapped multi-function steering wheel
Speaker installation9VGSound system "Monsoon"
Headlight range control8Q0without beam length regulator
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q5Multi-function display with control
Engine cooling8Z7Cold country
Engine specificationsD4F5-cylinder SI engine 2.5 l/110 kW (20V) (R-5) base engine is T8K/TQ7
engine compartment lighting9L0without engine compartment lighting
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Rear of platform module base4P1Rear floor panel module, type 2
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCM5Alloy wheels 6.5J x 16
Radios8USRadio "Premium" (double-size standard radio)
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Spare wheel with full tyre, steel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PHG"Highline" package
PMCemissions concept for California
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q3Gearshift knob/handle in wood
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Nameplates for sales nameQD3Lettering for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN1XSeat trim covers in part leather
Seat adjustment3L4Electric seat adjustment for both front seats, driver's seat with memory system
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K1with safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Control number (no PR family)S0CIntroductory volume
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B0with no protective side strip
Sunroof roller blind for rear/side windows3Y1roller blind for rear window
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B512-volt outlet(s)
Bumper2JCComfort bumpers
Rear stabilizer0BGRear stabilizer
Front stabilizer bar0AGFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Nameplate set0NVNameplate set "2.5"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQV4Satellite radio reception USA
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TBAdditional warning lights (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung0RBIgnition/starter switch locking system
Auxiliary heating system9M0Without auxiliary heater/parking heater
