Driver door does not unlock with key fob
Otto
C?ID=178462
I have a 2009 Audi A4 (B8) 2.0. Assistance needed, the front driver's door does not unlock all of the time with the remote key fob. When it does happen - I use a regular key and unlock the door. This happened 2 days ago for the first time ever. The (drivers side) door lock operates just fine from the inside as far as locking and unlocking. I ran a scan today and found fault codes in 05, 42 & 46. If I had to take a quick guess - I would say it is the door lock actuator assembly inside the driver side door. Has anybody come across this problem before? I have attached my recent scan. Thank you in advance.
Sunday,09,December,2018,12:30:56:24553
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
VIN: XXXXXXXXXXXXX   License Plate:
Mileage: 117880km-73247mi   Repair Order: 120918 - 1
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          65 72 77
VIN: WAUSF78K39N023758   Mileage: 117880km-73247miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 26142 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: F9BAA47978863B8212-80AD
7780 - Engine Off Timer Performance
          P150A 00 [032] - -
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0030
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: B6206F45091814FABF-80E3
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 150500
   Shop #: WSC 02399 823 56573
   VCID: F9BAA47970863B8212-80AD
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0141
   Coding: 090100
   VCID: B3265651126A01D298-80E7
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0508000043807010
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000046520008
00956 - Key 2
                    Fault Status: 00100101
                    Reset counter: 97
                    Mileage: 117879 km
                    Date: 2018.12.08
                    Time: 14:27:25
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0125.08.080763
   Coding: 64002000
   VCID: F2A893552DF048DA53-80A7
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000208444
   Coding: 26005295063CAF010000080300003D0D0F1C520800010161000000
   VCID: B02C595DE37C3ACAE5-80E5
   Component: WWS 150808  H06 0070
   Serial number: SWFBIE 0000194
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10232262
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000209081197
   Component: UGDO HL US  H04 0060
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD1426P/
   Coding: 303836354230303030304A55304C384B3053
   VCID: C0CC099D5BDCAA4A15-8095
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Component: BF-Gewichtss.  H01 0030
   Serial number: 5810000R0800001U8G
   Serial number: 6334MSME3F560157F
   Serial number: 6344MSME3E735127G
   Serial number: 6352QSME7808312CI
   Serial number: 6362QSME47030500/
   Serial number: 63732SME1608503CY
   Serial number: 63832SME7E071B0EB
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315HHN000BG
   Coding: 000016
   VCID: BD327069242EC7A27E-80E9
   Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00000000    Serial number: 9DR11UX88
   Coding: 831709000300D705020000
   VCID: AD124029F44E5722CE-80F9
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0094
   Revision: 4GB20042    Serial number: 4200G088038040
   Coding: 000303
   VCID: C6C01F8571F8847A2F-8093
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1803C283130808
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785     HW: 8T0 035 785
   Component: SG ext.Player H06 0210
   Revision: 00000000
   Coding: 020302
   VCID: F8BCA17D4B8C228A6D-80AD
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001136122
   Coding: 00581300000000000000
   VCID: F7BEA24146922DF264-80A3
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000007618410
   Coding: 011C03204E00410001
   VCID: C1CA0C9958D6A3421A-8095
                    Reset counter: 98
                    Mileage: 117606 km
                    Date: 2018.12.07
                    Time: 13:51:16
   Revision: 00002001    Serial number: 0113865630
   Coding: 0106063A007A440402B001
   Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
   Component: GTO BF  H06 0040
   Serial number: 00000000000000065345
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 58
                    Mileage: 104876 km
                    Date: 2016.12.01
                    Time: 14:23:17
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S2100000
   Coding: 0203010102
   VCID: EE90872539C86C3AB7-80BB
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007593984
   VCID: C0CC099D53DCAA4A15-8095
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000199850
   VCID: B12A5C59E87633C2EA-80E5
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000004
   VCID: B424554DD76406EA81-80E1
   Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
   Component: Symph3 Sirius H02 0211
   Revision: 00000004    Serial number: AUZ5Z4H1038695
   Coding: 040200020101850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100223112
   Coding: 010C03204000210001
   VCID: C4C4058D47C4B66A31-8091
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140786081891
   Coding: 0CD154
   Revision:             Serial number: 0000100223109
   Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
   Component: FSE_256x BT     H33 0550
   Revision: 00000000    Serial number: 00000005017358
   Coding: 0010370
   VCID: BB367E71FA3AC99240-80EF
End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
Yeah, looks like something wonky with the door control module in the driver's door.
golfi_vend
Tartu, Estonia
C?ID=195131
Has anyone come across? - This is like the 2nd main issue on 8K/8T and 8R platform.
Yup.....water gets in the lock unit and corrosion causes glitches, worse on very humid days. I shield them and no issues going forward. Stupid problem but I'm okay with it for job security purposes.
Otto
C?ID=178462
When you say "I shield them". What do you exactly mean?
Thx
Thx
Diagnosis is dirty VAG door lock discharge.
I take the lock unit out, tank them and clean dried, lube it up, then make a rain wrap to stop water from draining on the lock unit directly.
The 8K0 lock unit meat flap cover............or curtain, whichever politically incorrect definition you prefer & used with a homemade condom, ziplock bag or plastic wrap to stop the spread of car STD's!
Filthy filthy car.........
Zenerdiode
Newcastle, England
C?ID=24330
:) It's up there with the 'Fuel Flap Solenoid'. What are you putting 1[SUP]st[/SUP] Magnus?
Otto
C?ID=178462
Just to close out this thread. I replaced the lock assembly. The (drivers side) door locks and unlocks with the key FOB. Reset error with VAG-COM. All is good.
Thx
