A8 D3 Optical Bus test returns all errors
mattylondon
United Kingdom
C?ID=219022
Hi all,
When I perform the optical bus test it returns all errors on both electrical and optical for all controllers in the MOST loop. The infotainment does work fully with no faults in the autoscan. My main question is how does the optical bus test work and what could cause all the errors?
When I say 'work' there has been two issues recently. 1) I noticed a crackling sound from one of the rear speakers and 2) driving two days ago the MMI did die on me. It came alive after it was locked then unlocked. In other MMI / MOST related posts you usually see only one electrical error and therefore easy to spot the faulting module.
I guess one module isn't happy and have an suspicion it could be the digital radio as I notice sometimes the signal strength dropped to zero (near the time in the attached photo is [0], that's the signal strength). I have a few optical loop leads so I'll remove one module at a time and test.
Sunday,02,December,2018,11:19:28:04620
VCDS Version: 17.2.2.1 (x64)
VIN: WAUZZZ4E04N008970   License Plate:
Mileage: 142960km-88831mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 25 34 36 37 38
          42 46 47 4F 52 53 55 56 57 61 62 72 76
VIN: WAUZZZ4E04N012970   Mileage: 142960km-88831miles
Address 01: Engine        Labels: None
   Part No SW: 4E0 910 560 H    HW: 4E0 907 560
   Component: 3.7L V8/5V      G   0020
   Revision: 00000000    Serial number: AUX3Z0C8121858
   Coding: 0011773
   Shop #: WSC 02313 785 00200
   VCID: 2643EF9F91F501701C-8072
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit - Intermittent
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 D    HW: 09E 927 156 A
   Component: AG6 09E 3,7L5V RdW  0070
   Revision: 00000001    Serial number:        0019919
   Coding: 0000001
   VCID: 2345F68BE2C7F4587B-8076
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 A    HW: 4E0 614 517 A
   Component: ESP 5.7 allrad  H29 0420
   Coding: 0008597
   Shop #: WSC 02313 000 00000
   VCID: 2149FC83F8DBE64869-8074
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131
   Component:     FBS AUDID3  H03 0120
   Revision: 01203603    Serial number: AUX3Z0C8121858
   Coding: 0264192
   Shop #: WSC 02311 785 00200
   VCID: 58BF9167EB0167805E-800C
   Subsystem 1 - Part No: 4E0 905 852 C
   Component: ELV                 1734
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H06  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 769 E    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5150
   Revision: 00000000    Serial number: 300HJ037524663
   VCID: 2E5317BFB9054930E4-807A
   Subsystem 1 - Part No: 4E0 910 609
   Component: Bedienteil MMI  H41 0010
   Subsystem 2 - Serial number: 322GF037503551
   Subsystem 3 - Serial number: ÿÿ09.07.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Address 08: Auto HVAC        Labels: User\4E0-910-043.lbl
   Part No SW: 4E0 910 043     HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    015 0240
   Revision: 00000018    Serial number: 00000000023996
   Coding: 1069057
   VCID: 5ABB8B6F950D759068-800E
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0110001
   VCID: 2A5B1BAF85ED251038-807E
   Subsystem 1 - Part No: 4E2 910 113
   Component: Wischer WWS D3  H30 0320
   Coding: 00000030
   Shop #: WSC 02311
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Revision: 00000501    Serial number: AUZ5ZBC1020046
   VCID: 1C37CD77DFB9CBA0BA-8048
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7100089
   Coding: 0000001
   Shop #: WSC 02152 785 00200
   VCID: 2447F597E7C9F36002-8070
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655     HW: 4E0 959 655
   Component: Airbag 8.4E+    H09 0940
   Coding: 0431707
   VCID: 63C5B68BA247B4583B-8036
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H09 0030
   Coding: 0112141
   VCID: 65C1A893AC73CA68D5-8030
   Component: Lenkradmodul    H02 0050
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 CX
   Component: KOMBIINSTR. VDO H54 0090
   Revision: D21         Serial number: AUDID3F7000147
   Coding: 0000403
   Shop #: WSC 00388 210 99160
   VCID: 5CB78D779F398BA07A-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468     HW: 4E0 907 468 A
   Component: Gateway         H07 0050
   Revision: 07          Serial number: 130030371617BF
   Coding: FCFE7BDC3B2D04
   Shop #: WSC 12345 128 00289
Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   VCID: 2B551EAB4A173C18C3-807E
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0264192
   Component: ELV                 1734
   4E0905852C  ELV                 1734
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 F    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 6260
   Coding: 0015510
   Component: Sitzmemory FS  H06  0060
   Coding: 4063330
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
   Component: MNS ECE         H41 1060
   Revision: 00000000    Serial number: 305HS037537933
   VCID: 3B752EEB7A77AC9853-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H01 0080
   Serial number: 00000321700038
   Coding: 0035968
   VCID: 1D31C073C4A3C2A84D-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 802
   Component: Türsteuer.FS BRM005 0100
   Coding: 0028454
   VCID: 5EB3877F892599B014-800A
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040308140067
   Coding: 0004313
   VCID: 275DE29B96FF187827-8072
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H02 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 P    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H00 0460
   Serial number: é�Õ¿qÆm
   Coding: 0000017
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 33
                    Mileage: 134152 km
                    Date: 2014.07.09
                    Time: 19:02:43
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280     HW: 4E0 907 280 A
   Component: ILM Beifahrer   H07 0070
   Revision:             Serial number: 00000000021465
   Coding: 0010101
   VCID: 5DB18073842382A80D-8008
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E2 959 801
   Component: Türsteuer.BF BRM005 0110
   Coding: 0028454
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 B    HW: 4E0 907 801 A
   Component: EPB  A22HC020   H02 0200
   Revision: A22HC020
   Coding: 0000331
   Shop #: WSC 27634 002 1048576
   VCID: 1E33C77FC9A5D9B054-804A
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0030
   Coding: 0000001
   VCID: 62CBB38FBD5DBD5030-8036
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0620
   Revision: 00000000    Serial number: 304HN037540818
   Coding: 0000001
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 B    HW: 4E0 919 148
   Component: R0078 TVhybridTuner 0360
   Revision: R0H05000    Serial number: 76300700272401
   Coding: 0000003
   Shop #: WSC 00000 785 00200
   VCID: 224BF38FFDDDFD5070-8076
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181     HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0160
   Revision: 00000000    Serial number: 00000000013302
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  1308200306
   Coding: 303030393135313035414B56413031333038323030333036
   Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM005 0110
   Coding: 0028454
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0028454
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0020
   Revision: 00H12000    Serial number: 08720519200155
   Coding: 0201108
End-------------------------(Elapsed Time: 03:30)--------------------------
Uhm...
No. Old versions do not qualify for "Product Support". :p
I suggest you obtain and install current Release from this page and then start a thread in Car Repair Support.
