- Nov 23, 2014
- 154
- 45
- Los Angeles CA.
- C?ID=242342
hello Ross Tech:
i have a question related to Immobilizer. I got this vehicle: 2010 audi A4 2.0T is there a way using the scanner to id the immo version on this car? whether using VCDS or other scan tool.
Thursday,29,November,2018,11:53:47:23194
VIN: WAUAFAFL9AN068793 License Plate: 7ECM136
Mileage: 144090km-89533mi Repair Order: 41247
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUAFAFL9AN068793 Mileage: 144090km-89533miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H17 0001
Revision: E1H17---
Coding: 0104010A02070160
Shop #: WSC 22145 444 85933
VCID: 79BA0A4AF883C88292-802C
4201 - Fuel Level too Low
P1250 00 [096] - -
7666 - EVAP System
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 8K1 927 155 J HW: 0AW 927 156 H
Component: 0AW 20TAVSUSA H05 0003
Revision: --H05--- Serial number: 0000000876
Shop #: WSC 02149 785 00200
ASAM Dataset: EV_TCMVL381 A02017
ROD: EV_TCMVL381.rod
VCID: 3B36D042B23F3A92C0-806E
Part No SW: 8K0 907 379 BT HW: 8K0 907 379 BT
Component: ESP8 front H04 0030
Coding: 080D10
Shop #: WSC 02391 823 56573
VCID: 0C54439EAF11CD2AB9-8058
Part No SW: 8K0 907 064 DF HW: 8K0 907 064 DF
Component: BCM2 1.1 H02 0328
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 77BE0C72C697DEF2E4-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H50 0070
Serial number: 0510000025642006
Component: J764 ELV MLB H37 0042
Serial number: 0210000058716007
Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM
Component: KLIMA 1 ZONE H08 0180
Revision: A0000000 Serial number: 01030520101883
Coding: 64002000
VCID: 7CB4135EFFB1FDAA89-8028
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H29 0380
Revision: 09029001 Serial number: 00000000658611
Coding: 690000B1063C00010000080000007F5F0F14520802000021000000
VCID: 3A38D546B505039ADB-806E
Component: WWS 050510 H06 0070
Serial number: SWF10050055690
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AK HW: 8K0 941 531 AK
Component: E1 - LDS H08 0090
Serial number: 00000000002104100502
Subsystem 3 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H41 0610
Serial number: 003GLD0G031U
Coding: 303837354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
VCID: 45C2B6BAC4FB7C62A6-8010
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R1000006U1R
Serial number: 6334MSME53204C69E
Serial number: 6344MSME53262D70C
Serial number: 6352QSME2C5C3236M
Serial number: 6362QSME145E3234E
Serial number: 63732SME2F5E25245
Serial number: 63832SME1259171A-
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JE6000JP
Coding: 000014
VCID: 3D32DE5AA42B34A2FE-8068
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
Component: KOMBIINSTR. H20 0255
Revision: 00300000 Serial number: CIM31RP4A
Coding: 8B1209000300D705020000
VCID: 312AF26A6873C0C26A-8064
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1042682A0
Coding: 00C303
VCID: 014A62AA98539042DA-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 10016B7B220410
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010590273
Coding: 011C03204000410001
VCID: 45C2B6BACCFB7C62A6-8010
Revision: 00002001 Serial number: 0129792353
Coding: 0106023A007A400400B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000254379
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74A43B7ED7E1B5EAC1-8020
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010594358
VCID: 44C4ABBEC7C1456AB1-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000501680
VCID: 3424FB7E9761F5EA01-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1399786
Coding: 05020002010185004119070000
VCID: 46C0B1B6F1FD777AAF-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 151
Mileage: 133865 km
Date: 2018.06.27
Time: 17:12:38
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000103970772
Coding: 010C03204000210001
VCID: 42C8ADA6DDD54B5A83-8016
Component: TSG HR H10 0306
Revision: Serial number: 0000103970737
Part No SW: 8T0 862 336 D HW: 8T0 862 336 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005078111
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3C34D35E7F313DAAC9-8068
End----------(Elapsed Time: 01:36, VBatt start/end: 12.0V/12.0V)-----------
Address 01: Engine (8K2 907 115 AL)
12:10:05
IDE00151 Oil fill level 63.416 mm
IDE00152 Oil warning threshold 56.232 mm
