Hi There,
First time post and user of VCDS - pretty impressed so far!
Here's a quick recap to explain how my problem started. The car was recently moved from the UK to Spain. The lights are not compatible for the local inspection test. I took the car to a main dealer to see if anything could be done with the original LHS lights. They had it for a day and upon return I was told that they had turned "tourist mode" on, but the downside was this fault appearing in the dash.
This appears at startup every time.
Anyhow I've decided to buy the correct RHS lights for the Q7 and swap them over but I'd also like to remove whatever the main dealer has done and put the current light settings back to factory settings. I bought the HEX-V2 to do this but not sure how.
See below the auto-scan I took today. I've found the Wiki for the 4L here but not quite sure what I need to do next.
Any help welcome.
Thanks,
Con.
Any help welcome.
Thanks,
Con.
Saturday,17,November,2018,16:13:25:26317
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WAUZZZ4L3CD038015 License Plate: RE12ZXU_004
Mileage: 86540km-53773mi Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 06 08 09 15 16 17 18 19 28 34 36 3D 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WAUZZZ4L3CD038015 Mileage: 86540km-53773miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 B HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0001
Revision: 53H37--- Serial number:
Coding: 2A2A4012A53701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401B 001001
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 2313EC715B5394CFA37-8077
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AL HW: 0C8 927 750 AL
Component: AL1000 AISIN 001 2096
Coding: 001578
Shop #: WSC 34145 003 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 76B5E525B8415167B49-8023
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200673
VCID: 34311F2DE23D03774AD-8061
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H07 0200
Revision: 00H07000 Serial number: 10603501979764
Coding: 0000215
VCID: 2517F26959E76AFFCD3-8071
Subsystem 1 - Part No: 4F0 910 132 G
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0053
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-BFS H08 0064
Revision: AA000000 Serial number: 00000026557389
Coding: 01387200000011110000
VCID: 323D193514290D47581-8067
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH
Revision: 00---026 Serial number: 00000000319990
Coding: 01029416
VCID: 2517F26955E76AFFCD3-8071
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133121
VCID: 6E85CD45CC9169A77C9-803B
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D090YVM
Coding: 0014129
VCID: 2E050D450C1129A73C9-807B
Subsystem 1 - Serial number: 6332QSME04113870%
Subsystem 2 - Serial number: 6342QSME0011535E5
Subsystem 3 - Serial number: 6352QSME00113A7CB
Subsystem 4 - Serial number: 6362QSME7E101874K
Subsystem 5 - Serial number: 63734SME2311105CQ
Subsystem 6 - Serial number: 63834SME23111362L
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026120660212
Coding: 0112142
VCID: 2809FB5D2EF57797F65-807D
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 P HW: 4L0 920 984 P
Component: KOMBIINSTR. H22 0411
Revision: 00200000 Serial number: LMX02T24D
Coding: 3356630401012600010404
VCID: 40D943FDAA85AFD7DE5-8015
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000101
VCID: 6099A37D0645CFD7FE5-8035
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0057
Revision: LB500035 Serial number: 3500L12319008E
Coding: 00CF07
VCID: 3E253D05D071D927AC9-806B
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790704379
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12072001469011200181
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AA
Revision: 00---010 Serial number: 00000030235300
Coding: 0000006
VCID: 6889BB5DEE75B797365-803D
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 H HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7870
Revision: --H04001 Serial number: 15.1528-0150.2
Coding: 0015520
VCID: 2F3B10410B1B20AF37F-807B
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000026555212
Coding: 01387B00000111110000
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000056512
Coding: 01010101000000000001000202
VCID: 6B83C451FF839C8F5B7-803F
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000027707387
Coding: 011F56205E61440204
VCID: 48C95BDD82B59797165-801D
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01734784480000
Coding: 4071675
VCID: 38292B1DFE55E717665-806D
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000012520
Coding: 030000
VCID: 290FFE5939FF4E9FE9B-807D
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190163533
Coding: 0758729
VCID: 2313EC7157D394CFA37-8077
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000283549
Coding: 0011101
VCID: 5EE59D853C31F927CC9-800B
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000027217468
VCID: 47CB58E18FAB98EF1FF-8013
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 120403-0002-053
Coding: 11476F1010000500
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD49F5A409BDC7C81-8017
393989 - Headlight
Reset counter: 250
Mileage: 86541 km
Date: 2018.11.17
Time: 16:54:44
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109C30C7558389
Coding: 010103010000000000
VCID: 1F1BE08177BBB02F87F-804B
Part No SW: 4L2 035 670 A HW: 4L2 035 670
Component: H-BNT-EU H43 0467
Revision: -------- Serial number: 075CW0C7508171
Coding: 180101060004F3EF41002355EF632003040000000100000000
VCID: 2809FB5D22F57797F65-807D
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130D60CS138148
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002000998
Component: CD-Database 3638
Reset counter: 250
Mileage: 86541 km
Date: 2018.11.17
Time: 16:54:02
Text: DUA130,Front,M,0,0,6
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000027694301
Coding: 010E56204061230204
VCID: 46D555E588A181E7E49-8013
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000173786886
Coding: 0100000000000000
VCID: 313F1639112F365F21B-8065
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H05--- Serial number: 525PA8-J1Y432P
Coding: 1030701
Shop #: WSC 33050 001 1048576
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C74DFA8D9BB752D-8039
Subsystem 3 - Serial number: RD05.04.12--H57001001C0074ˇ
Subsystem 4 - Serial number: 1C0074ˇ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 125996815-----
Coding: 0003587
VCID: 2615F56524E161E7C49-8073
Component: J_245_EE16_SKB10H12 0220
Component: J_394_EE16_SKB10H12 0220
Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000027694298
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37361209000980
Coding: 0231066
VCID: 2C01074D3A0D5BB712D-8079
End----------(Elapsed Time: 02:19, VBatt start/end: 14.5V/14.5V)-----------
