- Nov 10, 2014
- 1,527
- 2,270
- New Zealand
- C?ID=230482
Do'h!
I think I broke R32ran...
During some "spirited" driving, the ESP and traction control was activated.
I parked for a while and then ever since, the right rear brake hasn't been working!
I've run the Basic Settings group 1 and bled the ABS under pressure through the 2 front brakes, then tried bleeding all the wheels - no bubbles etc, and bled heaps of fluid through both fronts and left rear... but nothing will come out the right rear!!!
I checked the junction under the floor, and nothing there either, which makes me think the ABS module has a blockage or fault.
Does that sound feasible to the collective clever clogs??? I haven't checked AT the ABS outlet to the right rear as it's difficult to get to, but I guess that's the next step. In my mind, the ABS is more liekly blocked than the OUTlet of the ABS block...
Any clever suggestions, of advice?
I guess if it's the ABS block, I *could* upgrade to MK60EC1
Give me your thoughts - please
Thanks,
Allan
slightly aged evidence of the FOD, that IS my car
Thanks,
Allan
Friday,03,August,2018,17:15:16:42165
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ1KZ6W124470 License Plate:
Mileage: 125990km-78286mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ6W124470 Mileage: 125990km-78286miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CD HW:
Component: MOTRONIC ME7.1.1 7802
Revision: --H07--- Serial number: VWZ7Z0E3138758
Coding: 0000172
Shop #: WSC 12345 123 45678
VCID: 4FAD5C06DE79993CED-801A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004738
VCID: 72EBF5F26D0B94D422-8026
Part No: 1K0 907 044 BD
Component: ClimatronicPQ35 090 0808
VCID: 6ADBED9245DB5C149A-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005382893
Coding: 008D07010004100000120C000000000000097B075C
VCID: 2A5B2D92855B9C145A-807E
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00063445
Shop #: WSC 12345
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0H4NRK
Coding: 0012338
Shop #: WSC 01324 785 00200
VCID: 35610EEE5CE5C3ECC7-8060
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76E3C9E2016388F40E-8022
Part No: 1K6 920 862 F
Component: KOMBIINSTRUMENT VDD 4316
Coding: 0001103
VCID: 336530F65291DDDCE9-8066
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 200917F1001094
Coding: 358003
VCID: 7BF5D8D6FA41D59C71-802E
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
Component: IMMO VDD 4316
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000765
VCID: 366309E241E3C8F4CE-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.0 D06 1701
VCID: 346733EA579FDAE4F0-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F008405485FC61010CC
Shop #: WSC 12345 678 910111
VCID: 79F9C2DE307DE78C63-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000756
VCID: 377D04E646E931FCD5-8062
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5515
Revision: -------- Serial number: VWZZZ4H6290453
Coding: 16000400040000
VCID: 46837922F10358745E-8012
Reset counter: 164
Mileage: 125999 km
Time: 17:10:39
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2428
Coding: 0000144
VCID: 326B35F2AD8BD4D4E2-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51268EB4B58B2CBF-8078
End-------------------------(Elapsed Time: 01:48)--------------------------
