MK60 ABS blockage?
NZDubNurd
New Zealand
C?ID=230482
Do'h!
I think I broke R32ran...
During some "spirited" driving, the ESP and traction control was activated.
I parked for a while and then ever since, the right rear brake hasn't been working!
I've run the Basic Settings group 1 and bled the ABS under pressure through the 2 front brakes, then tried bleeding all the wheels - no bubbles etc, and bled heaps of fluid through both fronts and left rear... but nothing will come out the right rear!!!
I checked the junction under the floor, and nothing there either, which makes me think the ABS module has a blockage or fault.
Does that sound feasible to the collective clever clogs??? I haven't checked AT the ABS outlet to the right rear as it's difficult to get to, but I guess that's the next step. In my mind, the ABS is more liekly blocked than the OUTlet of the ABS block...
Any clever suggestions, of advice?
I guess if it's the ABS block, I *could* upgrade to MK60EC1 :D
Give me your thoughts - please :cool:
Thanks,
Allan
slightly aged evidence of the FOD, that IS my car ;)
Friday,03,August,2018,17:15:16:42165
VCDS Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
VIN: WVWZZZ1KZ6W124470   License Plate:
Mileage: 125990km-78286mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ6W124470   Mileage: 125990km-78286miles
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CD    HW:
   Component: MOTRONIC ME7.1.1    7802
   Revision: --H07---    Serial number: VWZ7Z0E3138758
   Coding: 0000172
   Shop #: WSC 12345 123 45678
   VCID: 4FAD5C06DE79993CED-801A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004738
   VCID: 72EBF5F26D0B94D422-8026
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   VCID: 6ADBED9245DB5C149A-803E
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005382893
   Coding: 008D07010004100000120C000000000000097B075C
   VCID: 2A5B2D92855B9C145A-807E
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00063445
   Shop #: WSC 12345
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0H4NRK
   Coding: 0012338
   Shop #: WSC 01324 785 00200
   VCID: 35610EEE5CE5C3ECC7-8060
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E3C9E2016388F40E-8022
   Part No: 1K6 920 862 F
   Component: KOMBIINSTRUMENT VDD 4316
   Coding: 0001103
   VCID: 336530F65291DDDCE9-8066
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 200917F1001094
   Coding: 358003
   VCID: 7BF5D8D6FA41D59C71-802E
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554
   Component: HALDEX 4Motion      0101
   Coding: 0000001
   Component: IMMO            VDD 4316
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2302
   Coding: 0000765
   VCID: 366309E241E3C8F4CE-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.0   D06 1701
   VCID: 346733EA579FDAE4F0-8060
   Part No: 1K0 959 433 AK
   Coding: 00C802087F008405485FC61010CC
   Shop #: WSC 12345 678 910111
   VCID: 79F9C2DE307DE78C63-802C
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
            000 -  -
   Part No: 1T0 959 702 B
   Coding: 0000756
   VCID: 377D04E646E931FCD5-8062
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         541 5515
   Revision: --------    Serial number: VWZZZ4H6290453
   Coding: 16000400040000
   VCID: 46837922F10358745E-8012
                    Reset counter: 164
                    Mileage: 125999 km
                    Time: 17:10:39
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2428
   Coding: 0000144
   VCID: 326B35F2AD8BD4D4E2-8066
   Part No: 1K0 959 704 E
   Coding: 0000144
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D51268EB4B58B2CBF-8078
End-------------------------(Elapsed Time: 01:48)--------------------------
NZDubNurd
New Zealand
C?ID=230482
Urgh... also - my garage floor has no shortage of brake fluid... and the paint on the concrete has been removed... and I need a new brake bleeding container...
note to self: Don't leave the brake bleeding container UNDER the car when you drop it down :D
NZDubNurd
New Zealand
C?ID=230482
Handy information to know:
MK60 Hydraulic units, that share the same "block" number... are the same hydraulic unit. The block number is stamped into the block.
I could have left the oriinal Touran hydraulic unit in this car, and just swapped the Electronics across - My MK60 4motion ABD unit has a 2054 block, as does the Touran original, and the A3 donor car I used. A VW repair block fits all units with the same number :D
So I actually have 3 hydraulic blocks to pick from.
My next move, is to strip the car down to access the ABS, remove the ABS unit, and replace the Hydraulic unit with the Touran original. I'll swap the ECU over, and flush ALL the lines, drain the system and refill from fresh...
... but possibly not until I take some time of work :D It doesn't much look like fun!
NZDubNurd
New Zealand
C?ID=230482
I installed a spare 2054 Hydraulic block (actually the unit originally installed in the Touran), fitted my R32 4motion electronics module/motor and away it goes! Perfect - no blockage. It appears the right rear inlet valve was activated (to close, it's a normally open valve), and has jammed in the activated/closed position - not allowing fluid to get to the output.
The fluid pours out happily with the pressure bleeder attached and I ran the module basic setting to bleed the hydraulic unit.
YAY!
iichel
Eindhoven, NB, NL
C?ID=284912
good to hear you fixed it Allan. Now let's talk about that MK60EC1... :D
NZDubNurd
New Zealand
C?ID=230482
Hahaha... I'm still interested... but I really don't know if I can be bothered :-)
