2014 plate Seat Alhambra - Rear Heaters are not blowing hot air
Chimpy
C?ID=114147
Hi there,
I have a 2014 plate Seat Alhambra LUX (Same as Volkswagen Sharan SEL).
It comes with almost every extra
I have a Micro-CAN usb Dongle for the Scan
basically the element heater works and heat comes from the front
ventilators, however, the rear ventilators are supposed to blow heat
after the main water heater matrix system heats up and supplys
warm air to both the front and rear ventilators.
hoping I got the above statement correct, seems to me the heater
element is not turning off or some sort of valve is not switching to let the
heat from the heater matrix supply heat to the whole car.
could you let me know who to email so I can let them know this problem
please ? my car is also showing no errors on a full scan relating the
heater problem....
Also I do not know what the headlight range fault is....
Here is a Scan I have just done below..
Friday,09,November,2018,11:56:11:02076
VCDS Version: 18.9.0.2
VIN: VSSZZZ7NZEV509772   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4C 4F
          52 53 55 56 61 62 6C 6D 72 BE BF
VIN: VSSZZZ7NZEV509772   Mileage: 66690km-41439miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFGC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RJ    HW: 03L 906 018 M
   Component: R4 2,0L EDC   H28 4827
   Revision: 44H28---    Serial number:
   Coding: 001D001A042501080000
   Shop #: WSC 00000 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018RJ 003003
   ROD: EV_ECM20TDI01103L906018F.rod
   VCID: 032B5E498A1D0452C8-8056
   Part No SW: 02E 300 062 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4007
   Revision: 05652104    Serial number: 00001310160498
   Shop #: WSC 00020 000 90108
   VCID: 1F633239CEB5C0B2CC-804A
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 P    HW: 7N0 614 109 P
   Component: J104   C3 450M VDCC 0030
   Revision: --H07---    Serial number: 00000007543888
   Coding: 0028295
   Shop #: WSC 00020 790 00000
   VCID: 3A55E3AD7557859ADB-806E
   Part No SW: 7N0 907 044 AA    HW: 7N0 907 044 AA
   Component: Clima-Sharan  H02 0404
   Revision: 00001K02
   Coding: 021010C549
   Shop #: WSC 00020 999 00000
   VCID: 6FC302F9B69510323C-803A
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20131028000000136258
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 40590A3BE925F1C0508800C87400896443559388636D2F626484C72000C1
   Shop #: WSC 00020 790 12345
   VCID: 42A59B4DDD87CD5A83-8016
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    130831  31  0032
   Serial number:         130902203702
   Coding: 004DBD
   Component: RLFS  024 0042
   Serial number: Y13M10D23H18M54S19S1
   Coding: 0728DD
   Subsystem 3 - Part No: 7N0 951 171 A
   Component: DWA-Sensor 00  002 0206
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 157
                    Reset counter: 204
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 02:35:40
                        Term 15 Off
                    Voltage: 11.90 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28231330101259
   Coding: 308102
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3957FCA1B8518E82D2-806C
   Part No SW: 7N0 959 655 C    HW: 7N0 959 655 C
   Component: VW10Airbag00M H12 0014
   Serial number: 003LGPMY81WX
   Coding: 00304D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3FA392B9A675A0B2EC-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60FCC3C318DDG
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS603D30DC18DD
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS6027D6DB189D0
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60150EDC189D.
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6002DEE1189DQ
   Part No SW: 5K0 953 521 BD    HW: 5K0 953 569 B
   Revision: FF010042    Serial number: 20131025300890
   Coding: 189A240000
   ROD: EV_SMLSNGVOLWS.rod
   Subsystem 1 - Part No SW: 1P0 959 538 B    HW: 1P0 959 538 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0103
   Coding: E30000
   Part No SW: 7N5 920 970 J    HW: 7N5 920 970 J
   Component: KOMBI         H04 0811
   Coding: 441F01
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 E
   Component: Zuheizer        051 2940
   Revision: 00051000    Serial number: 09024297000000
   Coding: 0000041
   VCID: 364DF79D414F61FA3F-8062
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 151013F1001117
   Coding: 468203
   VCID: 7BDB26A9FAED7C9280-802E
   Part No SW: 7N0 857 511 P    HW: 8P0 857 511 C
   Revision: AA001002
   Coding: 0202816B74745D545420363E01
   VCID: 40A19145D38BDF4A95-8014
   Component: IMMO          H04 0811
   VCID: 6AF513ED8D77F51A6B-803E
   Revision: A1001003    Serial number: 7665387944
   Coding: 020100
   VCID: 2B7BD6E94A0D2C1250-807E
   Part No SW: 5P0 035 192 D    HW: 5P0 035 192 D
   Component: RNS315-EU   H76 0415
   Serial number: SEZAZ2N0585055
   Coding: 040004010400240000061002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2D7FD8F17C1922224E-8078
   Component: EUR_W_V5  0055
8 Faults Found:
1048593 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:32
1048594 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:32
1048595 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:32
1048596 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:32
1048597 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:34
1048598 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:34
1048599 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:34
1048600 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 63
                    Mileage: 64168 km
                    Date: 2018.08.23
                    Time: 00:50:34
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 G    HW: 7N0 959 793 G
   Component: TSG FA        H03 0553
   Revision:             Serial number: 0000077764455
   Coding: 01112E209001411011
   VCID: 46AD875DF1AFF17AAF-8012
Address 44: Steering Assist        Labels: None
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 278    3501
   Revision: 00H21000
   VCID: 42A59B4D1D87CD5A83-8016
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1642
   Coding: 050B0500
   VCID: 6FC302F9BE9510323C-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 G    HW: 7N0 959 792 G
   Component: TSG BF        H03 0553
   Revision:             Serial number: 0000079376892
   Coding: 01112C209E01411011
   VCID: 45AF8051CCA9FA62A6-8010
   Revision:   H19       Serial number: 00000001541669
   Coding: 0024167
   Component: AFS-ECU       H04 0111
   Coding: 068600000B000000
   Shop #: WSC 00020 999 39850
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 3753FA998E4598F224-8062
   Subsystem 1 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329 B  Labels: 3D0-941-329.CLB
5275648 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 184
                    Mileage: 66332 km
                    Date: 2018.10.30
                    Time: 11:51:52
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1642
   Coding: 030F1859
   VCID: 71C70481A8A106C22A-8024
   Component: J367-BDM  H07 0180
   Serial number: 40306749381491323443
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 H    HW: 7N0 959 794 H
   Component: TSG HL        H01 0554
   Revision:             Serial number: 0000078074546
   Coding: 01006C200001411001
   VCID: 48B18965FBBBE70A5D-801C
   Part No SW: 7N0 907 441     HW: 7N0 907 441
   Component: J772__Rearview      0020
   Revision: 00H13000    Serial number: 525 PA8J393971
   Coding: 0020011
   VCID: 6EFD1FFD799F193A37-803A
   Part No SW: 7N0 959 107 E    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0243
   Revision: 41011001    Serial number: 284300352
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H01 0554
   Revision:             Serial number: 0000078077249
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 A    HW: 7N0 959 244 A
   Component: Schiebetuer_l 005 2314
   Serial number: 13404369
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2314
   Serial number: 13404108
   ROD: EV_AST.rod
End-------------------------(Elapsed Time: 03:36)--------------------------
The "Left/Right Driving Switch-Over Active" fault is an advisory. There's an Adaptation channel in that module:
IDE03787-IDE03632 -- Activate left/right hand drive switch-over (not active / active)
This is intended to be activated when one is driving in countries where the configuration of the vehicle is incorrect for the side that traffic uses there.
Chimpy
C?ID=114147
Hi Uwe,
I can see IDE03787, when i try to change stored value of active to new value of not active and hit the do it button, i get asked to replace value, i click yes, and i get a pop up window saying error, Security access required and alli can press is ok
Have you tried going to Security Access and waiting there a bit to see if VCDS makes a suggestion? I'm confident it will.
myounus
Northwest UK
C?ID=321059
You have a very well known common fault. There is a valve which is underneath the car that requires a software update and replacement depending on which one you have. I think the part number you need is 7n0819810e. It has to be 'e' or later and then it requires a software update.
Chimpy
C?ID=114147
Hi everyone,
I found the diverter valve. It is above the drivers driveshaft. It is a struggle to take the whole diverter valve off, as the nut is only accessible form the top of the cars engine bay, and there are aluminium air con pipes in the way, so you need an angled socket or something like that ( i couldn't open it with angled socket - too tricky ) , plus more time consuming as you will need to disconnect the incoming and outgoing hoses, and wiring. plus possibly re-programming.
Luckily after seeing the most recent information above, i took the side panel off which was three screws. You need to take the under engine protection panel and you can access the side panel of the diverter valve.
The shaft that breaks....one side breaks in a cog. That side can be taken out using a stanley blade to pry it out against the cog. This cog sits on a pivot on the side panel that you have just taken off.
The other side can be pried put with a thin flat screwdriver. it is on the main unit that is still attached to the car. I pried out the arm......the arm will be facing 9 o'clock position or maybe 6 o'clock or different. (i just remembered this as not sure if important, and put the replacement part with the arm facing the same way)
The aluminium part above came in 5 working days. Worked out about £42.00 delivered which is expensive, but saves waiting for another plastic one to break in the next 4 years (not a good idea, and not sue if its available separately from main dealer)
i would post pictures but they need to be uploaded to a URL, and i don't really know how to.
Thanks for the information above. I hope this can help solve future problems, as these are relativity new cars. Took 3 months to solve, but well worth it, and it is getting cold now here in the UK, so will hopefully be useful, and it works now!
DanPhil
C?ID=255627
Great thread! and great forum.
I have the same problem with my 2012 Sharan rear heater valve, and have swapped the little cog inside once already.
@myounus Do you have any info on what the software update does? I can't decide if i should just get the aluminium cog, or if the right thing to do is to get a version 'e' valve and the software update.
As far as i can see the cog doesn't break because of a stuck valve. ( i can easily turn the valve by hand using a small screw driver).
And lastly, where can i do an output test for this valve in VCDS? I assume it would be in 08 -Auto HVAC module but there is nothing there for any heater valve or N317 valve??
any help would be appreciated.
PHil
myounus
Northwest UK
C?ID=321059
Hi Phil
I've not read a TSB but I presume the software update fixes a bug. Parts are routinely superseded due to technical improvements / recalls etc. Companies are always trying to cut costs and use shitty bits only to end up recalling cars, but if they get away with it then they do.
golfi_vend
Tartu, Estonia
C?ID=195131
Software update updates hvac module. I'm presuming somesort of map for valve is tweaked.
Chimpy
C?ID=114147
okay pictures here
itAzeD9
Chimpy
C?ID=114147
PHil
Its probably the cold weather causing weakness in the plastic, or causing a slight jam, as it is close to the inner arch/subframe
Chimpy
C?ID=114147
Thanks Uwe, as I turn, the lights follow, its made a huge difference
bofus
C?ID=310959
Looks like I have a failed N317 valve, is there any output test in VCDS to test a repaired valve?
mmosberg
Norway
C?ID=65477
Great thread. I am on my second diverter valve in my 2012 Sharan. It is stuck in cloded position. No warm air in the rear. My car has a Webasto parking heater and I am thinking of just setting the valve in open position. I realize it will take longer to get the engine to working temperature, but it is tempting.
Question: Would such a sollution lead to the rear heat exchanger deliver hot air constantly? Also during summer when AC is what you need?
myounus
Northwest UK
C?ID=321059
What’s the point, just replace it
mmosberg
Norway
C?ID=65477
myounus
Northwest UK
C?ID=321059
Take it to a garage or a friend’s maybe??
