Wednesday,07,November,2018,20:53:44:13952
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: 1VWAT7A37FC047902 License Plate: EBD
Mileage: 168390km-104632mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2B 2E 42 44 46 4C 4F 52 56 62
72 75 77 A6
VIN: 1VWAT7A37FC047902 Mileage: 168390km-104632miles
2B-Steer. Col. Lock -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0001
4C-Tire Pressure II -- Status: Not registered 0001
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 997 071 G HW: 06K 907 425 C
Component: R4 1.8l TFS H13 9372
Revision: --H13---
Coding: 001A0012242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K997071G 001005
ROD: EV_ECM18TFS02006K997071E.rod
VCID: 392F2E0C19DAFACF99B-806C
15211 - Oile Pressure Regulating Valve
P164E 00 [039] - Electrical Malfunction
Mileage: 168399 km
Date: 2018.11.07
Time: 04:20:08
Coolant temperature: 23 °C
Intake air temperature: 26 °C
Voltage terminal 30: 9.960 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 96 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 18.359375 %
FUP_H_SAE: 290.0 kPa
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 B HW: 09G 927 749 B
Component: AISIN AG6 G3 109 2855
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001_VW25.rod
VCID: 38292B0822D0E3C7665-806C
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F549260001A31403E4921B0041A5140012
VCID: 04518FF82E187727BAD-8050
Reset counter: 200
Mileage: 168399 km
Date: 2018.11.07
Time: 04:12:54
Count: 2
Count: 14
Count: 20480
Count: 16390
Count: 35840
Count: 255
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D67DA9CAD32A6EF953-8048
B10AB F0 [009] - Too Low
Reset counter: 200
Mileage: 168399 km
Date: 2018.11.07
Time: 04:12:48
Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB
Component: BCM PQ35 B+ 122 0174
Revision: BH122001
Coding: EF290EB8C00904DC40120001230000E047F1A0004480D507008022000C71
VCID: 73B3DC247BB6409F937-8026
Fault Frequency: 11
Reset counter: 240
Mileage: 168365 km
Date: 2018.11.06
Time: 19:50:17
Voltage: 10.55 V
Part No SW: 5C0 959 655 AA HW: 5C0 959 655 AA
Component: AirbagVW10 500 0975
Serial number: 003LYD01RTA9
Coding: 00004832
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 71BFD62C012A728F61B-8024
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y14000194TV03
Coding: 303044
Serial number: 3572MSME352C7848ZZZ%
Serial number: 3582MSME04601C49ZZZU
Serial number: 3516KSME65582131ZZZK
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME253C6931ZZZV
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME28250F31ZZZU
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME69624331ZZZT
Part No SW: 1K5 953 521 BN HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140818100836
Coding: 488A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7AADF1005C5C31D7D01-802E
Subsystem 1 - Part No SW: 561 959 537 HW: 561 959 537
Component: E221__MFL-8LP H07 0023
Coding: 620000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 960 D HW: 561 920 960 D
Component: KOMBI H04 0809
Coding: 030E01
VCID: 1A6DD180BC1CD1D7701-804E
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 26101403000053
Coding: 461000
VCID: 005983E83A006B079E5-8054
Fault Frequency: 9
Mileage: 168365 km
Date: 2018.11.06
Time: 19:49:06
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 200
Mileage: 168399 km
Date: 2018.11.07
Time: 04:14:37
03753 - Control Module for Microphone
Reset counter: 200
Mileage: 168399 km
Date: 2018.11.07
Time: 04:14:37
Component: IMMO H04 0809
VCID: 6A8DC1402CFC8157201-803E
Address 2B: Steer. Col. Lock
Address 2E: Media Player 3
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0009041441
Coding: 040495
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE39484F3A6E8DFAB7-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630141028191045
Coding: 800000
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 200
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Reset counter: 200
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 211 3501
Revision: 00H22000
VCID: 392F2E0C155AFACF99B-806C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 10.1 V
PD
Temperature: 24.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 00000008
VCID: 6FBBD054179E647F77F-803A
Subsystem 1 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0009064413
Coding: 040494
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE19798F6A8EFE7A2D-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631141110134555
Coding: 800000
Reset counter: 200
Reset counter: 200
Part No SW: 1K0 035 164 F HW: 1K0 035 164 F
Component: LOW NAR SDARS H05 0006
Revision: -----09S Serial number: VWZ4Z6P3850735
Coding: 0100040002000B
VCID: 2517F27C85E26E2FCD3-8070
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140528
Coding: 02140102C2161A107F1606000000
ROD: EV_OCULow_001.rod
VCID: 53F37CA49B76209F737-8006
U1400 00 [009] - -
[restriction due to undervoltage]
Reset counter: 200
2103041 - Control Module
Fault Priority: 8
Reset counter: 200
Mileage: 168399 km
Date: 2018.11.07
Time: 04:22:38
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666616802
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 323D1920C4AC0997581-8066
Address A6: Microphone
End--(Elapsed Time: 01:07, VBatt start/end: 9.8V/9.8V. VIgn 9.8V, udsna)---
