2015 Passat Wolfsburg 1.8T CPRA
Mike0p
Murrieta, CA
C?ID=350514
Hello wonderful world of irritated VW owners who routinely seem to experience mystery problems with their car due to over engineering. Sure are fun tough aren’t they! I have one of those issues at the moment and here it is: Low oil pressure light at start up during warm up phase and at 3200 RPM and when the engine kicks down.(the light always extinguishes when the regulator switches back to low pressure and I don’t receive a tone of any kind just the light popping on then back off. Items replaced:
Both pressure sensors on the filter assembly Oil pressure regulator Oil filter/engine oil
Items inspected/cleaned: Oil pan(was spotless when removed) Oil pump screen(was clear) All vacuum lines, secure and no leaks Checked N80, works 4.0 Verified oil pressure is within OEM guidelines with a mechanical gauge as per the VW service manual obtained from Erwin Checked wires for signs of corrosion/damage/ground. None.
Anomalies: In the instrument cluster control module one of the adaptations reads: SID or ESI off/no oil level evaluation/oil thermal sensor not connected to instr panel/static oil pressure. At about the same time that the initial light illuminated I noticed that I could not access the remaining service interval from the instrument cluster keys.
The light illuminates at the exact moment that the pressure regulator switches from low presssure to high pressure and simultaneously the oil pressure switch for high pressure reads OPEN. I currently have a code in the ECU which reads: 15190 unknown error code A code in the CAN bus: 01044 module incorrectly coded
I am pretty sure that this is a data transfer issue and not a mechanical issue. But I seriously need some guidance. I’m buying Ross-Tech tomorrow to hopefully solve the problem. Any help is appreciated
South Molton, UK
When you get your VCDS cable from Ross-Tech the first thing to do is post a full unedited Auto-Scan so we can see the details of the code and how your car is equipped.
Mike0p
Murrieta, CA
C?ID=350514
Ok, expedited shipping it is.
Mike0p
Murrieta, CA
C?ID=350514
Where can I find literature on exactly how the lubrication system works. Step by step?
Mike0p
Murrieta, CA
C?ID=350514
Wednesday,07,November,2018,20:53:44:13952
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: 1VWAT7A37FC047902   License Plate: EBD
Mileage: 168390km-104632mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2B 2E 42 44 46 4C 4F 52 56 62
          72 75 77 A6
VIN: 1VWAT7A37FC047902   Mileage: 168390km-104632miles
2B-Steer. Col. Lock -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0001
4C-Tire Pressure II -- Status: Not registered 0001
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 997 071 G    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 9372
   Revision: --H13---
   Coding: 001A0012242400170000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K997071G 001005
   ROD: EV_ECM18TFS02006K997071E.rod
   VCID: 392F2E0C19DAFACF99B-806C
15211 - Oile Pressure Regulating Valve
          P164E 00 [039] - Electrical Malfunction
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:20:08
                    Engine speed: 0.00 /min
                    Coolant temperature: 23 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 9.960 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 96 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 18.359375 %
                    FUP_H_SAE: 290.0 kPa
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 B    HW: 09G 927 749 B
   Component: AISIN AG6 G3  109 2855
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 001004
   ROD: EV_TCMAQ250031_001_VW25.rod
   VCID: 38292B0822D0E3C7665-806C
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: C54BC0F549260001A31403E4921B0041A5140012
   VCID: 04518FF82E187727BAD-8050
                    Reset counter: 200
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:12:54
                    Count: 2
                    Count: 14
                    Count: 20480
                    Count: 16390
                    Count: 35840
                    Count: 255
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D67DA9CAD32A6EF953-8048
          B10AB F0 [009] - Too Low
                    Reset counter: 200
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:12:48
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF290EB8C00904DC40120001230000E047F1A0004480D507008022000C71
   VCID: 73B3DC247BB6409F937-8026
                    Fault Frequency: 11
                    Reset counter: 240
                    Mileage: 168365 km
                    Date: 2018.11.06
                    Time: 19:50:17
                    Voltage: 10.55 V
   Part No SW: 5C0 959 655 AA    HW: 5C0 959 655 AA
   Component: AirbagVW10    500 0975
   Serial number: 003LYD01RTA9
   Coding: 00004832
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 71BFD62C012A728F61B-8024
   Serial number: 6940000Y14000194TV03
   Coding: 303044
   Serial number: 3572MSME352C7848ZZZ%
   Serial number: 3582MSME04601C49ZZZU
   Serial number: 3516KSME65582131ZZZK
   Serial number: 3526KSME253C6931ZZZV
   Serial number: 3556LSME28250F31ZZZU
   Serial number: 3566LSME69624331ZZZT
   Part No SW: 1K5 953 521 BN    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20140818100836
   Coding: 488A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7AADF1005C5C31D7D01-802E
   Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
   Component: E221__MFL-8LP  H07 0023
   Coding: 620000
   Part No SW: 561 920 960 D    HW: 561 920 960 D
   Component: KOMBI         H04 0809
   Coding: 030E01
   VCID: 1A6DD180BC1CD1D7701-804E
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 26101403000053
   Coding: 461000
   VCID: 005983E83A006B079E5-8054
            000 -  -
                    Fault Frequency: 9
                    Mileage: 168365 km
                    Date: 2018.11.06
                    Time: 19:49:06
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 200
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:14:37
03753 - Control Module for Microphone
                    Reset counter: 200
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:14:37
   Component: IMMO          H04 0809
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1402CFC8157201-803E
Address 2B: Steer. Col. Lock
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0009041441
   Coding: 040495
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE39484F3A6E8DFAB7-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630141028191045
   Coding: 800000
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 200
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 200
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 211    3501
   Revision: 00H22000
   VCID: 392F2E0C155AFACF99B-806C
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 10.1 V
                        PD
                    Temperature: 24.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Component: EZE_2         H55 1653
   Coding: 00000008
   VCID: 6FBBD054179E647F77F-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  009 0005
   Revision: 15110009    Serial number: 0009064413
   Coding: 040494
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE19798F6A8EFE7A2D-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631141110134555
   Coding: 800000
                    Reset counter: 200
                    Reset counter: 200
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H05 0006
   Revision: -----09S    Serial number: VWZ4Z6P3850735
   Coding: 0100040002000B
   VCID: 2517F27C85E26E2FCD3-8070
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140528
   Coding: 02140102C2161A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53F37CA49B76209F737-8006
          U1400 00 [009] - -
          [restriction due to undervoltage]
                    Reset counter: 200
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 200
                    Mileage: 168399 km
                    Date: 2018.11.07
                    Time: 04:22:38
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666616802
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 323D1920C4AC0997581-8066
Address A6: Microphone
End--(Elapsed Time: 01:07, VBatt start/end: 9.8V/9.8V. VIgn 9.8V, udsna)---
Gateway Installation List:  7N0 907 530 AR
Mike0p
Murrieta, CA
C?ID=350514
note that my oil pump is currently removed and my AC compressor. the centr elec is my main concern and the CAN bus
OP is verified now. Moving to Car Repair Support.
Seems to me this car has a screwed up Gateway Installation List.
[Select]
[19-CAN Gateway]
[Installation List]
Uncheck the stuff in the list that says, "Cannot Be Reached", check the stuff that says "Not Registered", then:
[Save Coding].
Back out gracefully, cycle the ignition, and post a fresh scan.
Mike0p
Murrieta, CA
C?ID=350514
that's what I figured I needed to do, just wanted some confirmation since the HEX-V2 has so much more it is able to do than what I was previously using. as for the dynamic vs static oil pressure in the instrument panel adaptations and the SID not being available it took me about 3 minutes to correct both issues. I now just need to install my new oil pump and AC compressor and hopefully the whole situation is solved. the only unknown is the cent elec coding, there are a few items that I'm not familiar with, is there a reference I can look at that describes what each option is? i.e. window regulators, central locking without safe function terminal 75/x on-off etc. ive been trying to find a reference scan from an identical vehicle due to the variety of configurations VW uses and the Wolfsburg is kind of an anomaly but it appears I'm the only one on the planet that owns one.....
NostraJackAss
Be sure to check why voltages dropped to 9 volts and inspect for fuel in sump for washing oil and conduct oil pressure and volume tests on the proper temp engine because if done cold it may fool your gauge readings.
Do running tests too.
Be advised the oil PSI valve is under warranty as a PZEV SULEV for 15/150K & since responsible for mileage and SMOG ratings that would display any P code!
Mike0p
Murrieta, CA
C?ID=350514
The voltage drop is a due to extended period of time with the ignition on just prior to removing the oil pump. I have checked the pressure and the regulator was replaced by the dealership. concerning the volume test, I’ll have to do some research on how exactly that is performed, I’m a helicopter hydraulics mech by trade so advanced auto diagnostics is somewhat foreign, but I’m learning. Can you recommend a good instructional resource to learn how to measure the volume? A little background, the oil pressure light began coming on completely out of the blue, no flickering no warning buzzer immediately following me changing coding in the instrument cluster and cent electric and i also began receiving code 19150(unknown error) in the ECM the dealership and I both verified pressures were within limitations. Changing the oil pump is due to the presence of miniscual shavings(almost glitter) found in the oil pan.
NostraJackAss
All that Glitters is gold dude and sounds like you are due a brand new engine under warranty, if that is indeed the case?
Install all correct parts and revert your induced FOD!
Mike0p
Murrieta, CA
C?ID=350514
The dealership told me it would cost me 14,000 to replace the engine. How would I go about getting that covered with 104,000 miles
Mike0p
Murrieta, CA
C?ID=350514
Is there anything I need to do via VCDS in order to ensure I leave no trace.
NostraJackAss
I suggest you fist that 14K up thy ASS?
Yes sir FOD indeed! & you as a HH QT guy ........? :p
I am a master of hydraulics myself with an asshole twist and understand your significance in the industry!
May the power of VCDS legacy scans compel you, may there be light from the torch in the room & that which doesn't run out of oil?
Mike0p
Murrieta, CA
C?ID=350514
Ironically I didn’t apply the same standard to my engine oil as I would a flight control hydraulic system. Yea, I’m going to put it back to the boring configuration and drive my ass back over there. I have all the oil change receipts and can prove the services have been performed as scheduled.
Mike0p
Murrieta, CA
C?ID=350514
SO, ALL I DID WAS CHANGE THE STATIC TO DYNAMIC OIL PRESSURE IN THE INSTRUMENT CTRL MODULE AND IT FIXED IT
