Saturday,22,September,2018,11:45:44:19936
VCDS Version: 18.2.1.5
VIN: WAUBGAFC4CN00xxxx License Plate:
Mileage: 85711km-53258mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 3C 42 44 46 47 52
53 55 56 5F 62 6C 72 8F 90
VIN: WAUBGAFC4CN006710 Mileage: 85711km-53258miles
47-Sound System -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH05 0010
Revision: --H05---
Coding: 0A2A0032052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 275DCB7A5EA0F47C45-8072
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 E HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 1006
Revision: --H08---
Coding: 000002
Shop #: WSC 39022 001 1048576
ASAM Dataset: EV_TCMAL551211 002018
VCID: 306F20266B6EB3C494-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 44A70F0022E5F0005B00
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6ED3FE5EB1DAE534C6-803A
Part No SW: 4H0 907 064 AQ HW: 4H0 907 064 AQ
Component: BCM2 2.0 H24 0217
Coding: 09883000000000000000
VCID: 78FFD806CB9EAB841C-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000088093015
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 N HW: 4G0 820 043 N
Component: KLIMA 2 ZONEN H10 0056
Serial number: 06051100040918
Coding: 6601201808
ASAM Dataset: EV_AirCondiBasisUDS 002033
VCID: 2A5B324E4DB2C9145A-807E
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000894873
Coding: 06002091063C9FE08100088380003908CF9CD208A2090121000004402000
VCID: 2C5734564F46D724A8-8078
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110427 H35 0051
Serial number: 110430073309
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11422017
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 03 05 2011 00000088
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0GAH06
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: BB08C6A5000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000006
VCID: 2D513952745CDE2CBF-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901111600201
Coding: 300105
Shop #: WSC 25101 444 124019
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 377D1B3A8E0064FCD5-8062
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80015M3C
Coding: 303234373131303030314A55304C34473053
VCID: 33652F2A9A7888DCE9-8066
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y11000043GK0C
Serial number: 3575HRB404V0H0LU30IV
Serial number: 3585HRB405P0HJHG60AN
Serial number: 3515JRB405P0I4AGLOO7
Serial number: 3525JRB40570H4DUAGBH
Serial number: 3554VRB40550FAMAN0FN
Serial number: 3564VRB40550FAMAOGM5
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505001254
Coding: 000034
VCID: 306F2026636EB3C494-8064
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 981 E HW: 4G8 920 981 E
Component: TBenUsa H34 0312
Revision: 19100074 Serial number: 658270411593019
Coding: 0BEF09040B01D705020000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 35611132940C96ECC7-8060
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000146290
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650381715
6226 - Radio
U1066 00 [009] - No Communication
Fault Frequency: 10
Reset counter: 128
Mileage: 85102 km
Date: 2018.08.26
Time: 19:53:43
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.8 V
Control Module temperature: 38 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
6227 - Digital sound System control module
U106A 00 [009] - No Communication
Reset counter: 111
Mileage: 85551 km
Date: 2018.09.17
Time: 19:34:36
Voltage terminal 30: 13.8 V
Voltage terminal 15: 13.8 V
Control Module temperature: 68 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0268 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 167
Mileage: 85102 km
Date: 2018.08.26
Time: 21:12:22
Voltage terminal 30: 11.6 V
Voltage terminal 15: 11.6 V
Control Module temperature: 46 °C
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Reset counter: 165
Mileage: 85614 km
Date: 2018.09.19
Time: 09:49:23
Voltage terminal 30: 12.0 V
Voltage terminal 15: 0.0 V
Control Module temperature: 31 °C
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
U140B 00 [008] - -
Reset counter: 167
Mileage: 85700 km
Date: 2018.09.21
Time: 00:52:22
Voltage terminal 30: 12.1 V
Control Module temperature: 25 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006121673
Coding: 0058130000002001000001010101102030303232203232
VCID: 77FDDB3AC680A4FC15-8022
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UPZ40
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D5139527C5CDE2CBF-8078
3801346 - Function Restricted due to Missing Message(s)
U1111 00 [032] - -
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
VCID: 2F6D235ABE50AC3C8D-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F01.05.1100H010003CD21092ÿ
Subsystem 4 - Serial number: D21092ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
Fault Status: 00101010
Reset counter: 147
Mileage: 85506 km
Date: 2018.09.15
Time: 11:22:05
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F07205E00628002000002
Shop #: WSC 02312 785 00200
VCID: 408F70E6D3CE234464-8014
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0007071648
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326B2A2E656281D4E2-8066
Revision: 00002001 Serial number: 0148792113
Coding: 0106063A00FA448480B00800020500000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000032195
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1201026T
Coding: 001F00
Address 47: Sound System
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3F8D731AAE305CBC1D-806A
02117 - Motor for Mirror Folding
Reset counter: 126
Mileage: 85711 km
Date: 2018.09.21
Time: 15:38:49
Fault Status: 00100110
Fault Frequency: 87
Reset counter: 168
Mileage: 79246 km
Date: 2018.03.31
Time: 10:58:29
01482 - Motors for Central Locking
Fault Frequency: 87
Reset counter: 168
Mileage: 79246 km
Date: 2018.03.31
Time: 10:59:02
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000071543
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 110511-0004-016
Coding: 1221A6101002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C5734564746D724A8-8078
Address 56: Radio
Part No SW: 4G0 035 746 E HW: 4G0 035 746
Component: H-BNT-NA H48 0735
Revision: -------- Serial number: 031EN0B7506018
Coding: 050200000003E0EF55128B2E00000003100001000000000000
VCID: 2959CD4240B4C20C53-807C
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QSQB
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Serial number: 90349KE9000DV
Component: CD-Database 2712
Reset counter: 127
Mileage: 85711 km
Date: 2018.09.21
Time: 16:50:03
Text: AMPLCPKO,,D,0,0,5
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 167
Mileage: 85711 km
Date: 2018.09.21
Time: 16:42:26
Voltage: 12.00 V
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F07204000628002000002
VCID: 428B7AEEDDC2315472-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J15F04W
Coding: 1020004
VCID: 2541C172ECACE66C77-8070
Component: TSG HR H03 0210
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FEDE35AB6D0EC3CCD-803A
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EFE026ABEEF3C4D4-8024
End-------------------------(Elapsed Time: 05:22)--------------------------
