Steering Wheel Module
Rtcook
C?ID=344486
Steering Wheel Module/Paddle Shifters
I have 2018 Beetle Dune. From the factory it came with a multifunction steering wheel, but no paddle shifters. I can shift my tranny with the stick, but prefer paddle shifters. So, I purchased a brand new, exact same steering wheel except it has the paddle shifters on it. I have not installed it yet as I have been doing research. Not much out there on Beetle retrofits. Its seems to be a straight forward swap with some VCDS coding in the Steering Wheel module based on swaps I read about on other cars. But, I do not have a Steering Wheel module when I hook my car up to my VCDS. So, how do I get the paddle shifters to work? Will they automatically work once I install it or is there some place else in VCDS I should be looking. Thanks in advance for any help.
Roger
If you don't have a Steering Wheel Control Module, then the steering wheel controls are likely handled by the BCM. Please post an Auto-Scan so people can see exactly what control modules are installed in this car and how they are configured.
Rtcook
C?ID=344486
Ok. I will do that. Thanks for responding.
Roger
Posted below.
Rtcook
C?ID=344486
Sunday,16,September,2018,12:21:33:35972
VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
VIN: 3VWSD7AT7JM711334   License Plate:
Mileage: 2130km-1323mi   Repair Order:
Chassis Type: AT-VW32 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 25 2B 44 47 5F 61
VIN: 3VWSD7AT7JM711334   Mileage: 2130km-1323miles
Address 01: Engine (J623-DDSA)       Labels: None
   Part No SW: 06K 906 016 B    HW: 06K 907 309
   Component: R4 2.0l TFS   H30 4948
   Revision: 1EH30000
   Coding: 411A00922424000F1000
   Shop #: WSC 00066 790 00450
   ASAM Dataset: EV_ECM20TFS01106K906016B 002004
   ROD: EV_ECM20TFS01106K906016B_002.rod
   VCID: 290FFE9C5971EA0F06A-807C
2813 - Accelerator Position Sensor (G79)
          P2122 00 [032] - Signal too Low
                    Time: 00:00:00
                    Coolant temperature: 77 °C
                    Intake air temperature: 67 °C
                    Voltage terminal 30: 12.520 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 98 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 0.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
2815 - Accelerator Position Sensor 2 (G185)
          P2127 00 [032] - Signal too Low
                    Time: 00:00:00
   Part No SW: 09G 927 158 AC    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3319
   Coding: 010200000C000000000000000000000000000000
   Shop #: WSC 00066 790 00439
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 74B1DFE8CE33E7E765C-8020
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: F14B4016492300FB8F0E02E7921D004120100012
   Shop #: WSC 00066 790 00019
   VCID: 75B7E2ECC5C9FEEF522-8020
   Part No SW: 5K0 959 434 J    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1403
   Revision: 00092000    Serial number: 0449794365
   Coding: 032C0C
   Shop #: WSC 00066 790 00326
   VCID: 3C2137C8A6E36FA76DC-8068
   Part No SW: 5C0 907 044 AN    HW: 5C0 907 044 AN
   Component: Climatronic   H08 0911
   Revision: 00001K04
   Coding: 3050019002
   Shop #: WSC 00066 790 00150
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 6FBBD084A715C43F98E-803A
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 189 B    HW: 7E0 937 189 B
   Component: BCM PQ25 MMI3 H82 0752
   Revision: BA082001    Serial number: 58227308172461
   Coding: 3BAC690B08AB080009AD2F9164C986C578C265C960AD7970B2A014332804
   VCID: 33331CF48B3DA0DFBC6-8066
   Component: RLS 110717 05  54  0403
   Coding: 02300A
   Subsystem 2 - Part No SW: 6R0 959 801 DL    HW: 6R0 959 801 DL  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 0660
   Serial number: KU0KU008091772511114
   Coding: 2010A4
   Subsystem 3 - Part No SW: 6R0 959 802 DR    HW: 6R0 959 802 DR  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 0660
   Serial number: KU0KU012091772550778
   Coding: 3010A4
   Subsystem 4 - Part No SW: 5C5 959 591 B    HW: 6R0 959 591 D
   Component: J245 PS71.402  H03 0004
   Serial number: 0000FST001Q7E7J00000
   Coding: 381000
   Subsystem 5 - Part No SW: 5C0 959 442 C    HW: 5C0 959 442 C
   Component: E221__MFL-8LP  H02 0104
   Serial number: 00000000000002463676
   Coding: E20000
01800 - Light Switch (E1)
                    Fault Frequency: 12
                    Reset counter: 77
                    Mileage: 387 km
                    Date: 2018.08.03
                    Time: 19:08:09
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C5 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0019
   Revision: --------    Serial number: 67781726301372
   Coding: 308103
   ASAM Dataset: EV_EPHVA18VW3240000 001009
   ROD: EV_EPHVA18VW3240000.rod
   VCID: 34311FE88EB3A7E7A5C-8060
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    501 0976
   Serial number: 003LZD0ALYX+
   Coding: 00003137
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDD9F0B427E9D7770-8026
   Serial number: 6940000Y170001NCK70
   Coding: 303144
   Serial number: 3572MSME07386C5EZZZ5
   Serial number: 3582MSME59386C5EZZZD
   Serial number: 3516KSME5E255B43ZZZ
   Serial number: 3526KSME15714843ZZZN
   Serial number: 3556LSME6A03023BZZZT
   Serial number: 3566LSME2A4F0337ZZZ$
   Part No SW: 5C5 920 976 J    HW: 5C5 920 976 J
   Component: KOMBI         H63 0508
   Revision: X0063001    Serial number:
   Coding: 220E010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 38292BD892DB4387894-806C
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 189 B
   Component: GW-K-CAN TP20 H82 0752
   Revision: BA082001
   Coding: 402001
   VCID: 6889BB98827B1307D94-803C
   Part No SW: 5K0 953 234     HW: 5C5 920 976 J
   Component: IMMO          H63 0508
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6A8DC1909CF72117CF0-803E
9456433 - Key
          B104B 31 [009] - No Signal
                    Reset counter: 57
                    Mileage: 2130 km
                    Date: 2018.09.16
                    Time: 12:17:15
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000280178009
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 313F16FC71A192CFCEA-8064
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 392F2EDCA5515A8F76A-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0145478
   VCID: 2809FB98427BD307194-807C
   Part No SW: 5C0 035 200 D    HW: 5C0 035 200 D
   Component: MU-S-S-US     H42 0447
   Serial number: VWZAZ2T1620887
   Coding: 02230400AA00000011220003001808009F0100D40020010002
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 1675C560F80F55F7BB8-8042
6720 - Rear View Camera
          B1102 31 [008] - No Signal
                    Reset counter: 91
                    Mileage: 1919 km
                    Date: 2018.09.11
                    Time: 06:34:21
                    Voltage terminal 30: 13.7 V
   Part No SW: 7E0 907 534     HW: 7E0 937 189 B
   Component: Batt.regelung H82 0752
   Coding: E1200A59
   Shop #: WSC 00066 790 00231
End----------(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.0V)-----------
Sunday,16,September,2018,12:29:58:35972
   Revision: 1EH30000
                    Time: 00:00:00
                    Time: 00:00:00
   Revision: 00H46001
   Coding: 032C0C
   Revision: 00001K04
   Coding: 3050019002
   Coding: 02300A
   Coding: 2010A4
   Coding: 3010A4
   Coding: 381000
   Coding: E20000
                    Fault Frequency: 12
                    Reset counter: 77
                    Mileage: 387 km
                    Date: 2018.08.03
                    Time: 19:08:09
   Coding: 308103
   Coding: 00003137
   Coding: 303144
   Coding: 220E010000
   Revision: BA082001
   Coding: 402001
   Coding: 000007
9456433 - Key
                    Reset counter: 57
                    Mileage: 2130 km
                    Date: 2018.09.16
                    Time: 12:17:15
   Revision: 00H22000
                    Reset counter: 91
                    Mileage: 1919 km
                    Date: 2018.09.11
                    Time: 06:34:21
   Coding: E1200A59
End----------(Elapsed Time: 01:25, VBatt start/end: 12.0V/12.0V)-----------
Sunday,16,September,2018,18:28:06:35972
   Revision: 1EH30000
                    Time: 00:00:00
                    Time: 00:00:00
   Revision: 00H46001
   Coding: 032C0C
   Revision: 00001K04
   Coding: 3050019002
   Coding: 02300A
   Coding: 2010A4
   Coding: 3010A4
   Coding: 381000
   Coding: E20000
                    Fault Frequency: 12
                    Reset counter: 77
                    Mileage: 387 km
                    Date: 2018.08.03
                    Time: 19:08:09
   Coding: 308103
   Coding: 00003137
   Coding: 303144
   Coding: 220E010000
   Revision: BA082001
   Coding: 402001
   Coding: 000007
   Revision: 00H22000
                    Reset counter: 91
                    Mileage: 1919 km
                    Date: 2018.09.11
                    Time: 06:34:21
   Coding: E1200A59
End----------(Elapsed Time: 01:27, VBatt start/end: 12.0V/12.0V)-----------
Sunday,16,September,2018,18:57:04:35972
                Address 09: Cent. Elect.       Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 189 B    HW: 7E0 937 189 B
  Component and/or Version: BCM PQ25 MMI3 H82 0752
           Software Coding: 3BAC690B08AB080009AD2F9164C986C578C265C960AD7970B2A014332804
            Work Shop Code: WSC 00066 000 00000
                    Fault Frequency: 12
                    Reset counter: 77
                    Mileage: 387 km
                    Date: 2018.08.03
                    Time: 19:08:09
Sunday,16,September,2018,19:15:28:35972
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
Control Module Part Number: 5C0 035 200 D    HW: 5C0 035 200 D
  Component and/or Version: MU-S-S-US     H42 0447
           Software Coding: 02230400AA00000011220003001808009F0100D40020010002
            Work Shop Code: WSC 00066 790 00439
              ASAM Dataset: EV_MUStd4CTSAT 001022 (VW32)
                    Reset counter: 91
                    Mileage: 1919 km
                    Date: 2018.09.11
                    Time: 06:34:21
Address 5F: DTCs cleared
   Revision: 1EH30000
                    Time: 00:00:00
                    Time: 00:00:00
   Revision: 00H46001
   Coding: 032C0C
   Revision: 00001K04
   Coding: 3050019002
   Coding: 02300A
   Coding: 2010A4
   Coding: 3010A4
   Coding: 381000
   Coding: E20000
                    Fault Frequency: 12
                    Reset counter: 77
                    Mileage: 387 km
                    Date: 2018.08.03
                    Time: 19:08:09
   Coding: 308103
   Coding: 00003137
   Coding: 303144
   Coding: 220E010000
   Revision: BA082001
   Coding: 402001
   Coding: 000007
   Revision: 00H22000
                    Reset counter: 91
                    Mileage: 1919 km
                    Date: 2018.09.11
                    Time: 06:34:21
   Coding: E1200A59
End----(Elapsed Time: 01:25, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Address 09: DTCs clearedSunday,16,September,2018,19:22:57:35972
Gateway Installation List:  7E0 909 901
OK, the steering wheel module is definitely a LIN bus subsystem of the BCM in this car, but I don't see any obvious place to tell it you have shift paddles.
Rtcook
C?ID=344486
And where do you see that? Where in VCDS can I look?
Thanks,
Roger
Coding for the BCM (at address 09), Byte 09, Bit 3 defines whether a Multi-Function Steering Wheel is installed.
I think this is the module itself:
   Coding: E20000
Unfortunately, I've found nothing that documents the coding for that.
Rtcook
C?ID=344486
If I install the steering wheel will anything change by itself? Is it possible it will all work without doing anything?
Rtcook
C?ID=344486
I assume this would be done by a dealer service center?
Rtcook
C?ID=344486
Any particular name for the update that I should ask for? I have a feeling my dealer service center is not going to be cooperative.
iichel
Netherlands, eastern part
C?ID=284912
I'd just fit it and see what happens. I've done MFSW installs in a Polo quite often (the Beetle and Polo are on the same platform, PQ25). DSG paddles were never an issue so for, but with m87s valuable input in mind, I might have gotten lucky.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Let's go step by step here and clear up some misinformation.
#1 Shift paddles do not need to be coded, install the steering wheel and if the installed transmission control module supports the function, they will work right away.
#2 The mentioned update applies to early DQ500 (7-speed, wet clutch DSG) installed in the T5GP MY 2010-2011. Before said update, even with shift paddles installed, the TCM would not recognize them while the tiptronic via the shift lever worked fine. Since this is a AQ250/09G (which is a completely different ball game), there is little to say here. Rule of thumb, if the paddle shifters were available from factory with this specific transmission you're chances are high that you can get it to work.
#3 Just install the damn thing and see if it works or not.
Rtcook
C?ID=344486
Will do, Sebastian. I will install this weekend and post back.
Thank you,
Roger
Rtcook
C?ID=344486
Installed new DSG paddle wheel with my original air bag and harness. Everything works! No VCDS required. Plug and play. I'm very pleased. Thank you all for the help. If anyone has any questions or wants further information let me know and I can provide it.
Roger
Sometimes people over-think things. ;)
Rtcook
C?ID=344486
First time doing something like this. Wanted to get it right and not cause issues.
