Maps 2018 NAR Alltrack S with 6-speed DSG and 1.8T (CXBB) maps
Maps
Dana
Western PA, USA
This 2018 left over Alltrack S is the latest addition to our family. It doesn't have much but we did get a RLS (Auto wipers/Auto headlights w/coming and leaving home) and heated (fake leather) front seats.
Original files located here: https://drive.google.com/drive/folders/1-Z71JvypNLqjodVhgRDcUQ7RRCF1gV7W?usp=sharing
Scan shortly after delivery @ Mileage: 138km-85mi:
Sunday,26,August,2018,11:23:08:04045
VCDS Version: 18.7.2.1 (x64)  HEX-V2 CB: 0.4432.4
Data version: 20180808 DS295.0
VIN: 3VWH17AU5JM758941   License Plate: 2018 ALLTRACK MAP SCAN
Mileage: 138km-85mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VWH17AU5JM758941   Mileage: 138km-85miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 311D00122426002F0000
   Shop #: WSC 00066 790 00075
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264M.rod
   VCID: 46D65C71682711E7EBE-8012
Readiness: 0000 0100
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01706220029
   ROD: EV_TCMDQ250021.rod
   VCID: 59EC870DC9998E1FB6C-800C
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 52407000000109
   Coding: 43FA6AA1342509748080030480C429C2562C9001C001943C00435050E009430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 005A8A690A83FFD7912-8054
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 02020004200110000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4CC26E59764BEBB73DA-8018
          B10CD 00 [008] -  -
                    Reset counter: 58
                    Mileage: 58 km
                    Date: 2011.10.25
                    Time: 06:30:10
                    Voltage terminal 30: 11.9 V
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C864290917029K
   Shop #: WSC 00066 790 00249
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B40AD4533C5AC8FF40-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170803  043 0551
   Serial number: 97022066170820234314
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S7Y17M07D24H00M23S20
   Coding: 00A8DD
   Serial number: 003GCR08WNXP
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47C851756F2D08EF108-8012
   Occupant Detection:
   Serial number: IBH000000000007SMW28
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 000 508 17
   Serial number: 3570000000099CB0A62V
   Subsystem 3 - Part No SW: -----------    HW: 480 000 508 17
   Serial number: 35800000000CACB0A62-
   Subsystem 4 - Part No SW: -----------    HW: 480 401 209 17
   Serial number: 351000199270BC657721
   Subsystem 5 - Part No SW: -----------    HW: 480 401 109 17
   Serial number: 3520001AB269FFC4D2D.
   Subsystem 6 - Part No SW: -----------    HW: 480 400 707 17
   Serial number: 3550002B324F3852D140
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 707 17
   Serial number: 3560002B124F3852108X
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 29091708490917
   Coding: 0410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 025E8061048FEDC7876-8056
   Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
   Component: KOMBI         242 0310
   Coding: 0BB4100DA180CF0502082B001000000000000000
   VCID: 2708F1F5CF6DE8EFF08-8072
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 11101700842535
   Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00067
   ROD: EV_GatewNF_VW27.rod
   VCID: 323E10A1F4AF9D47576-8066
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 26170001893500121439
   Coding: 31FFFF
   Serial number: HA1-00010.07.17
   Coding: 0001
   VCID: 4ACE68417C3FF5870F6-801E
   Serial number: 5037727600716
   Coding: 003A03200000020000000000
   Serial number: 00000000000007088038
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FF87955875DD0AF588-801A
   Serial number: 6038726301305
   Serial number: 00000000000007073405
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 07081700021741
   Coding: 02731200FF00000041220001001000009F0008D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 70BADAA93A23EF57612-8024
End------(Elapsed Time: 10:17, VBatt start/end: 14.4V/14.4V, Deb=2)--------
Vehicle Identification No.3VWH17AU5JM758941
ModelGolf variant 1,8
GOV
Date of production30.10.2017
Year2018
Sales typeBX6CN7
Engine CodeCXBB
Transmission CodeSYL
Axle drive6A
EquipmentXW
Roof color2T
Carpet color code
Exterior color / Paint Code2T / C9X
Special editionsE0ANo special edition
Lockable wheel bolts1PFStandard wheel bolts
Vehicle class differentiation
units/platform components
7IIVehicle class differentiation -5GM-
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG1Hill hold control
Emission standard0GTEmission standard SULEV
Trailer hitch1D0without trailer towing
airbag4UMAirbag für Fahrer und Beifahrer (NAR)
mit Beifahrer-Airbag-Deaktivierung
(zweistufig)
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling
Tray areas packageQE0Without tray areas package/box
Storage compartment7N3Comfort overhead storage compartment
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/
separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Electronic engine sound measuresGM1Standard electronic engine sound
Right exterior mirror5RRRight exterior mirror, convex (US)
Alternative drive system0K0Without alternative drive system
Drive type1X1Four-wheel drive
"Multimedia"video/DVD/notebook connection9WTMirror Link
Equipment levelsA8TExecutive equipment
Area monitoring systems6K0Without forward collision warning/
autonomous emergency braking
Brake type in rear1KSDisc brakes in rear (Geomet D)
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZDDisc brakes in front (Geomet D)
Components with special surface6FJBlack exterior mirror housings
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with
country-specific design requirements
B0DAssembly kit, USA corresponding vehicle
version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U0Without brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
"Charism"2H5Driving profile selection and
conventional shock absorber
Chrome packageQJ1Chrome package
General operating permit, alterationsC00Operating permit, initial registration
Roof rails/roof load rack3S1Bright roof rails
Roof insert/convertible top3FAroof without cut out
Suspension system in rearUC5Rear shock absorption
Suspension system in frontG25Shock absorption in front
Differential lock1Y3Electronic differential lock XDS,
dynamic traction support
ECO function for driving profiles and
Drive select
EF0Without ECO function
Installation differentiation for components0ESInstallation differentiation for
transmission DQ250
-- vehicle components --
Theft protection system7AZPreparation for anti-theft alarm system
Inserts5MQDecorative inserts
Scuff plates7M5Without protective film for scuff plate
Park distance control7X0Without park distance control
Extended safety system7W0Without extended safety system
Electric interface for external useUI5External, USB type A, 1x USB socket
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and
circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF1pedal cluster
Headlight activation9C9Separate daytime running light and
automatic headlight control -NAR- with
Coming Home and Leaving Home feature
Fresh air intake for passenger
compartment (with particulate filter)
2V5Fresh air intake with activated charcoal filter
Parking brakeUH0Parking brake
Alternators9G2Alternator 100-150 A
Weight category rear axle0YKWeight range 10
installation control only, no
requirement forecast
Weight category front axleL47Suspension range 47
Base engineTI54-cylinder SI engine 1.8 l unit 06K.K
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U2Sliding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Transmission specificationsG0R6-speed automatic transmission for
four-wheel drive
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper and washer system
with intermittent control
Rear axle0N44-link rear suspension
Molded headliner6NAUnsplit molding roof liner
Rear seats3NURücksitzbank ungeteilt, Lehne geteilt
umlegbar mit Mittelarmlehne
Heating and air-conditioning systemKH6Air conditioning system with electronic control
Headlamps8IEH7 headlamps with separate LED daytime
running lights
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer
- USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror,
dimming
Body styleK8DWagon/Avant
Camera/distance sensorQK0Without multifunction camera
Folding table1U8W/o folding table on front seat backrest
Climatic zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR8without road sign recognition
headrest for seat, rear3Q9Three rear head restraints
Head restraints5ZFFront head restraints
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A5Fuel system for SI engine
Body measures5C1Body measures for increased safety
requirements
Camera systems/accident sensorsKA1With rear view camera system (type 1)
Radiator grille6KGRadiator grille
refrigerantKK3Refrigerant R1234yf
License plate lightingKL1LED license plate lighting
License plate carrier31NLicense plate carrier in front and rear
(NAR)
Paint preservative/transit coating5K7Transport protection film (minimum
protection) with additional transport
protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GDPlane rear cargo area
Light package (lighting)QQ3Interior ambient lighting and surround
lighting
Vehicle inletES0Without vehicle inlet
Steering system arrangementL0LLeft-hand drive
Reading lamp8S62 reading lights in front
steering1N3Speed-related variable steering assist
(Servotronic)
Backrest release3H0Without backrest release for front seats
Light control systems8G0Without Light Assist
Lumbar support7P4Manually adjustable lumbar support in
front seats
steering wheels1XXLeather-wrapped multi-function sports
steering wheel with tiptronic
Driving on the left/on the rightAV2Driving on the right (NAR)
Speaker installation8RM8 speakers (passive)
Headlight range control8Q0Without headlight range control
Center armrest6E3Front center armrest
VersionsFM0Basic equipment variant
Multi-function display/trip computer9S5Multi-function display/trip computer
"Medium"
center console3D2center console
Driver alert systemEM0Without driver alert system
Engine cooling8Z6Hot country
Engine specificationsD6J4-cylinder SI engine 1.8 l/125 kW (16V)
turbo FSI, homogeneous, base engine is
TH2/TJ2/TF6/TQ6/TF5/TK5/TI5
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WHFront fog lamp and cornering lamp
Online servicesEL0Without online service
Rear of platform module base4P3Rear floor panel module, type 4
Hubcaps1NLTrims for alloy wheels
WheelsU89Alloy wheels 7J x 17
RadiosI8C.
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Regional code for radioER3Regional code " NAR " for radio
Tire pressure monitoring system7K6Tire pressure monitoring system
tireI84All-season tires 205/55 R17 95H xl (NAR)
Tire suppliersV0ATires without specification of tire
brand
Spare wheel/breakdown kit1G9Space-saving spare wheel for temporary
use, radial tire
(5-hole)
Wheelbases0B1Wheelbase
Restraint systems, front4QQ3-point seat belts in front with
pretensioner and height adjustment,
US label
Side airbag4X3Side airbag in front, with curtain
airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SCLabels in English
Tail lamp assemblies8SQLED rear combination lamp
Service indicatorQI7Service indicator 10 000 miles or
1 year (fix)
Seat belt check9P7Visual and acoustic seat belt reminder,
electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US
label
Center rear seat belts3C83-point seat belt, center rear with US
label
seat coversN4QSeat trim covers in leatherette
Seat adjustment3PTManual height adjustment for front seats
seat heater4A3Seat heater for front seats
separately controlled
Start-stop system/regenerative braking7L3Without start/stop system without
Horns8Y1Two-tone horn
sun visors5XXSun visors with mirror, illuminated
(NAR)
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0Without lane change assist
Side and rear windows4KCSide and rear windows in heat-insulating
glass
power outlet7B312-volt socket(s)
Bumper2JEPartially painted bumpers
Rear stabilizer0BFRear stabilizer
Front stabilizer bar0AFFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/
light/rain sensor
8N6Windshield wiper intermittent control
with light/rain sensor
Nameplate set0NWNameplate set "TSI"
Mass damper for steering wheels1Q2Mass damper for steering wheel, 36 Hz
Door and lid locking system4K0Central locking w/ radio remote control
and interior controls
Type approval countries/countries with
special requirements
BU2Legal requirements for USA 2
States with CARB requirement
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAWithout partition
Door and side trim panels3LJDoor and side trim panel in foam film,
insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SBAdditional front underbody guard
Identification plates1EBOhne Typschild
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Front seatsQ2Jconvenience seat
Rear seat catchUK3Mechanical rear seat release
Telephone / telematics9ZXTelephone preparation for cellphone
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFloor mats in front and rear
Decorative trims4ZNBright decorative trims
Additional child seat anchors3B7Child seat anchors as per Canadian
requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
Press release info https://newspress-vwusamedia.s3.amazonaws.com/documents/original/8671-2018VolkswagenGolfAlltrackRelease.pdf
Press kit main page: https://media.vw.com/press-kits/2018-golf-alltrack-press-kit
Dana
Western PA, USA
01-Engine
adpmap-01-8V0-906-264-M_3VWH17AU5JM758941-20180826-1114.CSV
;SW:8V0-906-264-M   HW:06K-907-425-B ---  Engine
;Component:1.8l R4 TFSI  H13 0001	 Coding:311D00122426002F0000
;EV_ECM18TFS0208V0906264M	1003	EV_ECM18TFS0208V0906264M.rod
;Sunday	26	August	2018	11:14:48:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 46D65C71682711E7EBE-8012
IDE00001-Production mode	00 00 00 	3
IDE00259-Idle RPM correction	0 /min	1
IDE01945-Engine run-in oil pressure	active 	1
IDE02332-Deactivate production mode	00 00 00 	3
IDE04158-Activation of start-stop function	not active 	1
IDE04617-Protective function	Enabled 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06726-Timing deviation after chain replacement: intake bank 1	-1.44 °	2
IDE06728-Timing deviation after chain replacement: exhaust bank 1	0.00 °	2
IDE06730-Timing deviation after other repairs: intake bank 1	0.00 °	2
IDE06732-Timing deviation after other repairs: exhaust bank 1	0.00 °	2
IDE06734-Timing deviation: current value intake bank 1	0.00 °	2
IDE06736-Timing deviation: current value exhaust bank 1	0.00 °	2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1	1	1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1	0	1
IDE06742-Chain elongation: initial values valid: intake bank 1	not active 	1
IDE06744-Chain elongation: initial values valid: exhaust bank 1	not active 	1
IDE10261-MAS10172-Operating mode selec.-DI operation	not activated 	4
IDE10261-MAS10174-Operating mode selec.-CNG operation	not activated 	4
IDE10261-Operating mode selec.-	not activated 	4
Elapsed Time: 00:04
blockmap-01-8V0-906-264-M_3VWH17AU5JM758941-20180826-1113.CSV
KOEO
;Sunday	26	August	2018	11:13:42:04045
Group	Description	Actual
IDE00011	Vehicle Identification Number (VIN)	3VWH17AU5JM758941
IDE00018	Voltage terminal 15	14.082	 V
IDE00019	Voltage terminal 30	14.453	 V
IDE00021	Engine speed	0	 /min
IDE00025	Coolant temperature	81	 °C
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00076	Status of initial fuel filling	was not yet started
IDE00078	Time since engine start	0	 s
IDE00083	Throttle valve position (absolute)	15.3	 %
IDE00084	Absolute load value	0	 %
IDE00085	Normed load value	0	 %
IDE00086	Accelerator position	16	 %
IDE00090	selected gear	Shifting process active
IDE00097	OBD - requirements for which this vehicle is designed	OBD + OBD II
IDE00102	Control Module temperature	52	 °
IDE00148	Median injection timing	0	 ms
IDE00149	Ignition angle of current cylinder: actual value	-1.12	 °
IDE00150	Pressure in brake booster	1.15	 bar
IDE00151	Oil fill level	90	 mm
IDE00155	Timing angle retardation cylinder 1	0	 °
IDE00156	Timing angle retardation cylinder 2	0	 °
IDE00157	Timing angle retardation cylinder 3	0	 °
IDE00158	Timing angle retardation cylinder 4	0	 °
IDE00167	Exhaust temperature 1 bank 1	264.9	 °C
IDE00172	A/C compressor torque	0	 Nm
IDE00173	Cruise Control System: specified speed	0	 km/h
IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	0	 °
IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	0	 °
IDE00178	Camshaft adjustment intake bank 1: specified value	0	 °
IDE00179	Camshaft adjustment intake bank 1: actual value	0	 °
IDE00182	Camshaft adaptation intake bank 1: phase position	-1.1	 °
IDE00184	Camshaft adaptation exhaust bank 1: phase position	47.6	 °
IDE00186	Fuel low pressure: actual value	11.003	 bar
IDE00187	Coolant temperature at engine start	82.5	 °
IDE00188	Fuel high pressure: actual value	44.6	 bar
IDE00189	Activation of fuel pump electronics	10	 %
IDE00190	Charge air pressure specified value	0.986	 bar
IDE00191	Charge air pressure: actual value	0.982	 bar
IDE00192	Coolant temperature at radiator outlet: actual value	30.1	 °
IDE00193	Coolant temperature at engine outlet: specified value	81.7	 °
IDE00194	Coolant temperature at radiator output: specified value	-48	 °
IDE00195	Coolant temperature difference between engine and radiator	51	 °
IDE00196	Engine oil temperature	80	 °C
IDE00199	Mean engine air mass	0	 kg/h
IDE00200	Median vehicle speed	0	 km/h
IDE00201	High fuel pressure: specified value	103	 bar
IDE00202	Low fuel pressure: specified value	5.462	 bar
IDE00252	Brake system vacuum pump	Pump off
IDE00304	Fuel level	49	 l
IDE00322	Status of basic setting	not active
IDE00323	Security Access: Number of invalid keys	0
IDE00348	Intake air temperature	54	 °C
IDE00349	Throttle valve position: normed	5	 %
IDE00350	Air mass: specified value	0	 kg/h
IDE00355	Cruise Control System (CCS): status	main switch off
IDE00357	Fuel temperature	79.5	 °
IDE00358	Limitation: torque	290	 Nm
IDE00371	Fuel consumption	0	 l/h
IDE00375	Generator: load signal	0.03	 %
IDE00380	Coolant fan 1: activation	10.16	 %
IDE00381	Coolant fan 2: activation	0	 %
IDE00392	Accelerator pedal: sensor voltage 1	0.796	 V
IDE00393	Accelerator pedal: sensor voltage 2	0.386	 V
IDE00396	Charge Pressure Actuator: acknowledgment	1.284	 V
IDE00400	Intake manifold Runner Control (IMRC): activation	100	 %
IDE00401	Intake manifold Runner Control (IMRC): acknowledgment	100	 %
IDE00404	Throttle valve: activation	0	 %
IDE00405	Crankshaft speed (RPM)	0	 /min
IDE00406	Camshaft speed (RPM)	0	 /min
IDE00407	Rail pressure regulation: status	Control operation
IDE00408	Engine mount 1	not active
IDE00409	Engine mount 2	not active
IDE00412	Starter control: terminal 50	not active
IDE00413	Starter control: Interlock- or P/N-signal	0
IDE00414	Starter control: relay 1	0
IDE00415	Starter control: relay 2	0
IDE00416	Starter control: terminal 50 acknowledgment	1
IDE00417	Starter control: shut-off conditions 1	00 00
IDE00445	Unlearning counter according OBD	255
IDE00450	Operating Instructions	--no display--
IDE00451	Currently running routine	Unknown (0)
IDE00472	Mean injection quantity	19	 mg/stroke
IDE00474	Ambient air pressure	98	 kPa abs
IDE00476	Fuel Metering Valve	0	 %
IDE00477	Torque request: sum of auxiliary aggregate	0	 Nm
IDE00478	Engine-drag torque	16.5	 Nm
IDE00482	Limitation: torque of clutch protection	1024	 Nm
IDE00495	Calculated oil temperature	80	 °
IDE00496	Activation of oil pressure switch valve	High pressure
IDE00497-MAS00627	Status of oil pressure switches-Oil pressure switch for high pressure	Open
IDE00497-MAS00628	Status of oil pressure switches-Oil pressure switch for low pressure	Open
IDE00556	Outside air temperature	23	 °C
IDE00559	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)	0.000 Lambda / -128.000 mA
IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	1.275	 V
IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
IDE00582	Equivalence ratio target value	1	 Lambda
IDE00583	Throttle valve specified value	5	 %
IDE00584	Distance driven since erasing DTC memory	121	 km
IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
IDE00588	Fuel tank fill level	92.2	 %
IDE00589	Fuel pressure	4330	 kPa rel
IDE00592	Oxygen sensor control status	Engine off
IDE00593	Ignition timing adjustment cylinder 1	-1	 Degrees
IDE00594	Absolute intake pressure	98	 kPa abs
IDE00595	Allocation of oxygen sensors	B1S1 B1S2
IDE00597	Long term adaptation of mixture formation bank 1	4.7	 %
IDE00601	Monitoring status since erasing DTC memory
IDE00602	Monitoring status in current driving cycle
IDE00603	Number of driving cycles since erasing DTC memory	22
IDE00604	Short term adaptation of mixture formation bank 1	0	 %
IDE00608	Type of fuel	Gasoline
IDE00612	Target position of EVAP canister valve	0	 %
IDE00727	Test steps still to be performed	0
IDE00787	Cause for cancellation	0
IDE00949-ENG98517	Hide cylinder-Cylinder 1	active
IDE00949-ENG98491	Hide cylinder-Cylinder 10	not active
IDE00949-ENG98492	Hide cylinder-Cylinder 11	not active
IDE00949-ENG98493	Hide cylinder-Cylinder 12	not active
IDE00949-ENG98518	Hide cylinder-Cylinder 13	not active
IDE00949-ENG98519	Hide cylinder-Cylinder 14	not active
IDE00949-ENG98520	Hide cylinder-Cylinder 15	not active
IDE00949-ENG98494	Hide cylinder-Cylinder 16	not active
IDE00949-ENG98521	Hide cylinder-Cylinder 2	active
IDE00949-ENG98522	Hide cylinder-Cylinder 3	active
IDE00949-ENG98523	Hide cylinder-Cylinder 4	active
IDE00949-ENG98495	Hide cylinder-Cylinder 5	not active
IDE00949-ENG98524	Hide cylinder-Cylinder 6	not active
IDE00949-ENG98496	Hide cylinder-Cylinder 7	not active
IDE00949-ENG98497	Hide cylinder-Cylinder 8	not active
IDE00949-ENG98498	Hide cylinder-Cylinder 9	not active
IDE00968	Compressor speed	0	 /min
IDE01076-MAS00109	Time since ignition off-Hours	0	 H
IDE01076-MAS00110	Time since ignition off-Minutes	6	 min
IDE01076-MAS00111	Time since ignition off-Seconds	36	 s
IDE01098	Test of knock sensors: short trip result	Test not started
IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	0
IDE01266	Coolant shut-off valve	closed
IDE01369	Intake manifold runner control (IMRC): offset closed	0	 V
IDE01377	Throttle valve adapter: actual value	6.1	 °
IDE01378	High fuel pressure: control deviation	58.6	 bar
IDE01385	Wear index	0
IDE01405-MAS05513	Status of starter activation-Bit 0	OK
IDE01405-MAS05514	Status of starter activation-Bit 1	Before starter activation
IDE01405-MAS05515	Status of starter activation-Bit 2	After starter activation
IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test not started
IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.592	 V
IDE01649	Throttle valve position 1	0.791	 V
IDE01650	Throttle valve position 2	16	 %
IDE01665	Result of test of camshaft adjustment intake bank 1	Test not started
IDE01667	Result of test of camshaft adjustment outlet bank 1	Test not started
IDE01670	Short trip status for oil pressure control	Test not started
IDE01671	Starter control: clutch switch	not pressed
IDE01672	Starter control: automatic start	not possible
IDE01673-MAS05513	Starter control: readiness bits-Bit 0	Mech. test of starter not complete
IDE01673-MAS05514	Starter control: readiness bits-Bit 1	Test of starter relay switching contacts not complete
IDE01673-MAS05515	Starter control: readiness bits-Bit 2	Test of starter relay activation not complete
IDE01673-MAS05516	Starter control: readiness bits-Bit 3	Test of terminal 50R return measuring line not completed
IDE01673-MAS05517	Starter control: readiness bits-Bit 4	Test of starter request double injection not complete
IDE01673-MAS05518	Starter control: readiness bits-Bit 5	Test of PN signal not complete
IDE01673-MAS05519	Starter control: readiness bits-Bit 6	Test of interlock switch not complete
IDE01673-MAS05520	Starter control: readiness bits-Bit 7	Test of clutch pedal switch not complete
IDE01677	Result of O2 sensor test ready bank 1 after cat. conv.	Test not started
IDE01683-MAS05304	Valve stroke switch of AVS from small to large-Cylinder 1	switched
IDE01683-MAS05305	Valve stroke switch of AVS from small to large-Cylinder 2	switched
IDE01683-MAS05306	Valve stroke switch of AVS from small to large-Cylinder 3	switched
IDE01683-MAS05307	Valve stroke switch of AVS from small to large-Cylinder 4	switched
IDE01683-MAS05308	Valve stroke switch of AVS from small to large-Cylinder 5	switched
IDE01683-MAS05309	Valve stroke switch of AVS from small to large-Cylinder 6	switched
IDE01683-MAS05310	Valve stroke switch of AVS from small to large-Cylinder 7	switched
IDE01683-MAS05311	Valve stroke switch of AVS from small to large-Cylinder 8	switched
IDE01684-MAS05304	Valve stroke switch of AVS from large to small-Cylinder 1	switched
IDE01684-MAS05305	Valve stroke switch of AVS from large to small-Cylinder 2	switched
IDE01684-MAS05306	Valve stroke switch of AVS from large to small-Cylinder 3	switched
IDE01684-MAS05307	Valve stroke switch of AVS from large to small-Cylinder 4	switched
IDE01684-MAS05308	Valve stroke switch of AVS from large to small-Cylinder 5	switched
IDE01684-MAS05309	Valve stroke switch of AVS from large to small-Cylinder 6	switched
IDE01684-MAS05310	Valve stroke switch of AVS from large to small-Cylinder 7	switched
IDE01684-MAS05311	Valve stroke switch of AVS from large to small-Cylinder 8	switched
IDE01685	Result of test of valve stroke switch AVS	Test not started
IDE01773	Misfire sum counter	0
IDE01774	Status misfire recognition	not active
IDE01775	Misfires per 1000 revolutions of cylinder 1	0
IDE01776	Misfires per 1000 revolutions of cylinder 2	0
IDE01777	Misfires per 1000 revolutions of cylinder 3	0
IDE01778	Misfires per 1000 revolutions of cylinder 4	0
IDE01870	Oxygen sensor after catalytic converter: operating status	Bank 1: sensor 1 not OK
IDE01873	Test of catalytic converter: measured value	0.016
IDE01874	Test of catalytic converter: result	Test not started
IDE01876	Adaptation of loss torque	-0.1	 Nm
IDE01878	Adaptation of throttle valve	Test of closing springs ended
IDE01880	Accelerator position 2	15	 %
IDE01881	Adaptation of kick-down shifting point	4.126	 V
IDE01884	Camshaft adjustment intake bank 1: activation	9.38	 %
IDE01886	Number of high pressure incursions	0
IDE01894	Charge press. ctrl.: adapt. higher than max. threshold	0.39	 %
IDE01895	Charge pressure control: less than min. threshold adaptation	0.78	 %
IDE01901	Lost torque adaptation: idle	-1	 Nm
IDE01905	Average of ignition timing angle delay adjustment	0	 °
IDE01906	Dynamic average of ignition timing angle delay adjustment	-1.12	 °
IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
IDE01922	Vehicle distance driven	138	 km
IDE01923	Control module distance driven	138	 km
IDE01924	Load shift flaps: actual value	closed
IDE01925	Load shift flaps: specified value	closed
IDE01926	Adaptation of load shift flaps	Cancel: prerequisites have not been met
IDE01928	Close cam shaft angle at quantity control valve	0	 °
IDE01929	Open cam shaft angle at quantity control valve	0	 °
IDE01931	High pressure pump injection volume control deviation	114	 mg/stroke
IDE01932	High pressure pump injection volume	0	 mg/stroke
IDE01975	Numb.of misfir.: cylinder 1	0
IDE01976	Numb.of misfir.: cylinder 2	0
IDE01977	Numb.of misfir.: cylinder 3	0
IDE01978	Numb.of misfir.: cylinder 4	0
IDE01986	Contact for tank leak test	Open
IDE02116	Exhaust gas temperature before catalytic converter	224.8	 °
IDE02119	Long term adaptation of oxygen sensor control: bank 1	0	 %
IDE02229	Exh.gas temp.sen 1	1110	 °
IDE02756	Number of manual engine starts	123
IDE02757	Number of automatic engine starts	0
IDE03008-MAS04415	Stop process prevented-Ambient air pressure	not active
IDE03008-MAS04416	Stop process prevented-Sporadic function restriction	not active
IDE03008-MAS04417	Stop process prevented-Poor start detection	not active
IDE03008-MAS04590	Stop process prevented-Mixture adaptation	not active
IDE03008-MAS06602	Stop process prevented-Engine temperature	active
IDE03008-MAS06604	Stop process prevented-Start-stop sensor system	not active
IDE03008-MAS06605	Stop process prevented-Regeneration operation	not active
IDE03008-MAS06606	Stop process prevented-Brake under pressure too low	not active
IDE03010-IDE00924	Number of prevented stop processes-Steering angle	0
IDE03010-MAS01627	Number of prevented stop processes-Steering	0
IDE03010-MAS02040	Number of prevented stop processes-Play protection	0
IDE03010-MAS04415	Number of prevented stop processes-Ambient air pressure	0
IDE03010-MAS04416	Number of prevented stop processes-Sporadic function restriction	36
IDE03010-MAS04417	Number of prevented stop processes-Poor start detection	0
IDE03010-MAS04589	Number of prevented stop processes-Diagnosis of exhaust system	0
IDE03010-MAS04590	Number of prevented stop processes-Mixture adaptation	0
IDE03010-MAS04591	Number of prevented stop processes-Diagnosis of air system	0
IDE03010-MAS04592	Number of prevented stop processes-Hybrid battery power insufficient	0
IDE03010-MAS04593	Number of prevented stop processes-Auxiliary consumers power too high	0
IDE03010-MAS04595	Number of prevented stop processes-Deceleration takeover active	0
IDE03010-MAS04805	Number of prevented stop processes-Clutch protection K0	0
IDE03010-MAS04870	Number of prevented stop processes-Test of thermostat not complete	0
IDE03010-MAS05758	Number of prevented stop processes-Driving situation	0
IDE03010-MAS06602	Number of prevented stop processes-Engine temperature	274
IDE03010-MAS06605	Number of prevented stop processes-Regeneration operation	0
IDE03010-MAS06606	Number of prevented stop processes-Brake under pressure too low	0
IDE03010-MAS08032	Number of prevented stop processes-Event memory entry in engine control module	0
IDE03010-MAS09416	Number of prevented stop processes-Adaptation active	0
IDE03010-MAS11563	Number of prevented stop processes-Engine hood open	0
IDE03010-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
IDE03010-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
IDE03010-MAS12864	Number of prevented stop processes-Tighter traffic flow detected	0
IDE03010-MAS13643	Number of prevented stop processes-E machine output too low	0
IDE03010-MAS13644	Number of prevented stop processes-Motor protection active	0
IDE03010-MAS13645	Number of prevented stop processes-Fuel salinization protection active	0
IDE03010-MAS13661	Number of prevented stop processes-Exhaust emission control diagnosis	0
IDE03010-MAS16918	Number of prevented stop processes-Restriction in the start system	0
IDE03011-MAS01627	Number of requested start processes-Steering	0
IDE03011-MAS04369	Number of requested start processes-Engine temperature too high	0
IDE03011-MAS04370	Number of requested start processes-Engine temperature too low	0
IDE03011-MAS04416	Number of requested start processes-Sporadic function restriction	0
IDE03011-MAS04592	Number of requested start processes-Hybrid battery power insufficient	0
IDE03011-MAS04593	Number of requested start processes-Auxiliary consumers power too high	0
IDE03011-MAS04595	Number of requested start processes-Deceleration takeover active	0
IDE03011-MAS06606	Number of requested start processes-Brake under pressure too low	0
IDE03011-MAS06607	Number of requested start processes-SCR System requires restart	0
IDE03011-MAS09730	Number of requested start processes-Cat. heater	0
IDE03011-MAS11563	Number of requested start processes-Engine hood open	0
IDE03011-MAS11834	Number of requested start processes-Rolling vehicle	0
IDE03011-MAS13644	Number of requested start processes-Motor protection active	0
IDE03011-MAS13645	Number of requested start processes-Fuel salinization protection active	0
IDE03011-MAS16918	Number of requested start processes-Restriction in the start system	0
IDE03108	Result of test of oxygen sensors bank 1	Test not started
IDE03235	Neutral position sensor: current transmission angle	20	 °
IDE03236	Neutral position sensor: adapted transmission angle	-179.96	 °
IDE03246	Neutral position sensor: upper adaptation value	0	 V
IDE03247	Neutral position sensor: lower adaptation value	0	 V
IDE03262	Adapt of angle sensor 1 f throttle valve	0.503	 V
IDE03263	Adapt of angle sensor 2 f throttle valve	4.488	 V
IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.791	 V
IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.199	 V
IDE03267	Intake air temperature: unconditioned voltage	1.084	 V
IDE03276	Charge air pressure sensor: unconditioned voltage	1.587	 V
IDE03277	Intake manifold Runner Control (IMRC): unconditioned voltage	3.916	 V
IDE03328	Transmission neutral position sensor voltage	0	 V
IDE03361	Driver request torque	20.5	 Nm
IDE03362	Requested transmission torque	1024	 Nm
IDE03375	Adaptation status for transmission neutral position sensor	0
IDE03377	Coolant temp at radiator output: unconditioned voltage	3.126	 V
IDE03582	Temperature sensor for engine temperature management	81	 °
IDE03585	System status for the start/stop function master	System malfunction
IDE03587-IDE02697	Stop overrides for active participants-Multifunction unit control module	not active
IDE03587-MAS00124	Stop overrides for active participants-A/C	not active
IDE03587-MAS00127	Stop overrides for active participants-brakes	not active
IDE03587-MAS00506	Stop overrides for active participants-Adaptive Cruise Control	not active
IDE03587-MAS00832	Stop overrides for active participants-Convertible top control module	not active
IDE03587-MAS01090	Stop overrides for active participants-Transmission	not active
IDE03587-MAS01106	Stop overrides for active participants-Level control system	not active
IDE03587-MAS01490	Stop overrides for active participants-Energy management	not active
IDE03587-MAS01627	Stop overrides for active participants-Steering	not active
IDE03587-MAS02237	Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.	not active
IDE03587-MAS02569	Stop overrides for active participants-All-wheel electronics	not active
IDE03587-MAS03757	Stop overrides for active participants-Quattro Sport	not active
IDE03587-MAS05129	Stop overrides for active participants-Engine	active
IDE03587-MAS06709	Stop overrides for active participants-Keyless operation	not active
IDE03587-MAS08785	Stop overrides for active participants-Parking aid	not active
IDE03587-MAS13018	Stop overrides for active participants-Front sensor system for driver assistance systems	not active
IDE03588-IDE02697	System malfunctions for active participants start/stop-Multifunction unit control module	not active
IDE03588-MAS00124	System malfunctions for active participants start/stop-A/C	not active
IDE03588-MAS00127	System malfunctions for active participants start/stop-brakes	not active
IDE03588-MAS00506	System malfunctions for active participants start/stop-Adaptive Cruise Control	not active
IDE03588-MAS00832	System malfunctions for active participants start/stop-Convertible top control module	not active
IDE03588-MAS01090	System malfunctions for active participants start/stop-Transmission	not active
IDE03588-MAS01106	System malfunctions for active participants start/stop-Level control system	not active
IDE03588-MAS01490	System malfunctions for active participants start/stop-Energy management	not active
IDE03588-MAS01627	System malfunctions for active participants start/stop-Steering	not active
IDE03588-MAS02237	System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.	not active
IDE03588-MAS02569	System malfunctions for active participants start/stop-All-wheel electronics	not active
IDE03588-MAS03757	System malfunctions for active participants start/stop-Quattro Sport	not active
IDE03588-MAS05129	System malfunctions for active participants start/stop-Engine	not active
IDE03588-MAS06709	System malfunctions for active participants start/stop-Keyless operation	not active
IDE03588-MAS08785	System malfunctions for active participants start/stop-Parking aid	not active
IDE03588-MAS13018	System malfunctions for active participants start/stop-Front sensor system for driver assistance systems	not active
IDE03589-MAS01161	Error status for start-stop related sensors-Communication error	not active
IDE03589-MAS11563	Error status for start-stop related sensors-Engine hood open	active
IDE03589-MAS11868	Error status for start-stop related sensors-Driver door status	active
IDE03589-MAS12097	Error status for start-stop related sensors-driver door open	active
IDE03589-MAS12098	Error status for start-stop related sensors-Start/Stop deactivated with button	active
IDE03589-MAS12099	Error status for start-stop related sensors-Clutch signal error	not active
IDE03589-MAS12100	Error status for start-stop related sensors-Brake or speed signal error	not active
IDE03589-MAS12101	Error status for start-stop related sensors-Steering signal error	not active
IDE03692-MAS05513	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0	Test of camshaft adjustment bank 2 outlet not complete
IDE03692-MAS05514	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1	Test of camshaft adjustment bank 1 outlet not complete
IDE03692-MAS05515	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2	Test of camshaft adjustment bank 2 intake not complete
IDE03692-MAS05516	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3	Test of camshaft adjustment bank 1 intake complete
IDE03692-MAS05517	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4	Test of knock sensor 4 not complete
IDE03692-MAS05518	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5	Test of knock sensor 3 not complete
IDE03692-MAS05519	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6	Test of knock sensor 2 not complete
IDE03692-MAS05520	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7	Test of knock sensor 1 complete
IDE03693-MAS05513	Monitoring status of additional Onboard Diagnosis-Bit 0	Test of brake light switch not complete
IDE03693-MAS05514	Monitoring status of additional Onboard Diagnosis-Bit 1	Test of clutch switch not complete
IDE03693-MAS05515	Monitoring status of additional Onboard Diagnosis-Bit 2	Test of idle control complete
IDE03693-MAS05516	Monitoring status of additional Onboard Diagnosis-Bit 3	Test of coolant temperature sensor not complete
IDE03693-MAS05517	Monitoring status of additional Onboard Diagnosis-Bit 4	Test of throttle valve potentiometer not complete
IDE03693-MAS05518	Monitoring status of additional Onboard Diagnosis-Bit 5	Test of thermostat complete
IDE03693-MAS05519	Monitoring status of additional Onboard Diagnosis-Bit 6	Test of charge pressure control complete
IDE03693-MAS05520	Monitoring status of additional Onboard Diagnosis-Bit 7	Test of CCS switch not complete
IDE03693-MAS05521	Monitoring status of additional Onboard Diagnosis-Bit 8	Test of oxygen adaptation bank 1 complete
IDE03711	Mass flow through throttle valve	0	 kg/h
IDE03767	Engine status	Stop
IDE03795	Camshaft adjustment: exhaust: bank 1: activation	9.37	 %
IDE03806	Oxygen sensor bank 1 sensor 1: status	0
IDE03807	Oxygen sensor bank 1 sensor 2: status	0
IDE03816	Exhaust flap bank 1	Open
IDE03818	Heated oxygen sensor bank 1: sensor 2: resistance	65535	 Ohm
IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	0	 %
IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	16383	 Ohm
IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	0	 %
IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 ms
IDE03834	Oxygen sensor bank 1 sensor 2: response time filtered	0	 ms
IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	Test not started
IDE03892	Fuel high pressure sensor: unconditioned voltage	1.117	 V
IDE03918	Engine reverse rotation recognition	not recognized
IDE03919	Oxygen regulation operability and status	OFF
IDE03920	Oxygen adaptation status	Initializing
IDE03921	Mixture adaptation factor at partial load	-1.77	 %
IDE03922	Mixture adaptation factor at idle speed	0	 %
IDE03923	Adaptive long-term value of mix. condition after cat. conv	0
IDE03924	Relay for reserve coolant pump: status	not activated
IDE03928	Counter for fuel entry in oil	0
IDE03930	Charge pressure actuator: operating status	Operating mode
IDE03931	Charge pressure actuator: actual position	57.98	 %
IDE03932	Charge pressure actuator: specified position	0	 %
IDE03933	Charge pressure actuator: specified value	0	 %
IDE03934	Charge pressure actuator: adaptation for lower stop	3.525	 V
IDE03935	Charge pressure actuator: adaptation for upper stop	0.57	 V
IDE03953	Oxygen control: adaptation value at partial load: bank 1	-1.77	 %
IDE03957	Throttle valve angle: specified value	6	 °
IDE03963	Low fuel pressure adaptation value for EFP	1200	 mbar
IDE03966	Transmission neutral position sensor PWM signal	0	 %
IDE03998	Clutch Position Sensor	99.61	 %
IDE04002	Charge press. ctrl.	BP_A act:98	 kPa
IDE04405	Mixture deviation in adapted partial load range 1	0	 %
IDE04409	Intake manifold pressure: corrected	0.982	 bar
IDE04410	Intake manifold pressure: target value	0	 bar
IDE04412	Pressure before throttle valve: corrected	0.982	 bar
IDE04415	Oxygen ctrl factor with precontrol correction	0	 %
IDE04420	Activation of secondary air system	Atmosphere/off
IDE04629	AVS operating condition	No enabling
IDE04630	AVS valve stroke position: current	Standard
IDE04632-MAS05304	AVS error status of last switch-over standard stroke direction-Cylinder 1	OK
IDE04632-MAS05305	AVS error status of last switch-over standard stroke direction-Cylinder 2	OK
IDE04632-MAS05306	AVS error status of last switch-over standard stroke direction-Cylinder 3	OK
IDE04632-MAS05307	AVS error status of last switch-over standard stroke direction-Cylinder 4	OK
IDE04632-MAS05308	AVS error status of last switch-over standard stroke direction-Cylinder 5	OK
IDE04632-MAS05309	AVS error status of last switch-over standard stroke direction-Cylinder 6	OK
IDE04632-MAS05310	AVS error status of last switch-over standard stroke direction-Cylinder 7	OK
IDE04632-MAS05311	AVS error status of last switch-over standard stroke direction-Cylinder 8	OK
IDE04633-MAS05304	AVS error status of last switch-over AVS stroke direction-Cylinder 1	OK
IDE04633-MAS05305	AVS error status of last switch-over AVS stroke direction-Cylinder 2	OK
IDE04633-MAS05306	AVS error status of last switch-over AVS stroke direction-Cylinder 3	OK
IDE04633-MAS05307	AVS error status of last switch-over AVS stroke direction-Cylinder 4	OK
IDE04633-MAS05308	AVS error status of last switch-over AVS stroke direction-Cylinder 5	OK
IDE04633-MAS05309	AVS error status of last switch-over AVS stroke direction-Cylinder 6	OK
IDE04633-MAS05310	AVS error status of last switch-over AVS stroke direction-Cylinder 7	OK
IDE04633-MAS05311	AVS error status of last switch-over AVS stroke direction-Cylinder 8	OK
IDE04634	AVS switch-over meter for reg activation of curr. drive cycle	0
IDE04635	AVS switch-over meter: total	8
IDE04636	AVS overflow meter for all switch-overs	0
IDE04637	Engine temperature management actuator	99.75	 %
IDE04638	Transmission coolant valve	closed
IDE04677	O2 sensor 1 bank 1: O2 sensor actual value	1
IDE04680	O2 sensor 1: bank 1: voltage raw value O2 signal	1.997	 V
IDE04713	Active brake system status	Not operated
IDE04814	Transmission oil cooler valve	closed
IDE04937	Sensor for engine block temperature: raw value	-48	 °
IDE05140	Intake manifold pressure raw value	0.984	 bar
IDE05259	Gear position sensor: raw value	0	 %
IDE05260	Gear position sensor: current value	Neutral
IDE05261	Gear position sensor: last valid value	Neutral
IDE05262	Gear position sensor: gear position valid	invalid
IDE05310	Charge air pressure control valve position: target value	0	 %
IDE05311	Charge air pressure control valve position: actual value	57.98	 %
IDE05312	Charge air pressure control valve uncond voltage sensor	1.2842	 V
IDE05313	Charge air pressure control valve activation pulse duty factor	0	 %
IDE05314-ENG112584	Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]	0
IDE05315	Charge air pressure control valve voltage: position closed	3.5254	 V
IDE05316	Charge air pressure control valve voltage: position open	0.5701	 V
IDE05317-ENG112583	Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0]	0
IDE05508	Adaptation val cyl 1 with slow diagnosis	0
IDE05509	Adaptation val cyl 3 with slow diagnosis	0
IDE05510	Adaptation val cyl 4 with slow diagnosis	0
IDE05511	Adaptation val cyl 2 with slow diagnosis	0
IDE05512	Adaptation val cyl 1 with fast diagnosis	0
IDE05513	Adaptation val cyl 3 with fast diagnosis	0
IDE05514	Adaptation val cyl 4 with fast diagnosis	0
IDE05515	Adaptation val cyl 2 with fast diagnosis	0
IDE05593	Secondary air injection sensor 1	0.984	 bar
IDE05622-ENG125277	Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL	0
IDE06006	Idle speed specified value	1100	 /min
IDE06192	Knock sensor: cylinder 2: voltage	2.5	 V
IDE06193	Knock sensor: cylinder 3: voltage	2.5	 V
IDE06194	Knock sensor: cylinder 4: voltage	2.5	 V
IDE06195	Knock sensor: cylinder 1: voltage	2.5	 V
IDE06296-ENG104200	Activation of oxygen control after main cat-Lambda probe 2: bank 1: status	0
IDE06307-MAS00106	Stop prevention history data-Year	2018
IDE06307-MAS00107	Stop prevention history data-Month	8
IDE06307-MAS00108	Stop prevention history data-Day	26
IDE06307-MAS00109	Stop prevention history data-Hours	10
IDE06307-MAS00110	Stop prevention history data-Minutes	33
IDE06307-MAS00111	Stop prevention history data-Seconds	2
IDE06307	Stop prevention history data	not active
IDE06307	Stop prevention history data	Engine temperature
IDE06308-MAS00106	Start request history data-Year	2127
IDE06308-MAS00107	Start request history data-Month	15
IDE06308-MAS00108	Start request history data-Day	31
IDE06308-MAS00109	Start request history data-Hours	31
IDE06308-MAS00110	Start request history data-Minutes	63
IDE06308-MAS00111	Start request history data-Seconds	63
IDE06308	Start request history data	Hybrid battery power insufficient
IDE06308	Start request history data	Steering
IDE06308	Start request history data	Cat. heater
IDE06308	Start request history data	Restriction in the start system
IDE06308	Start request history data	Engine temperature too low
IDE06308	Start request history data	Brake under pressure too low
IDE06308	Start request history data	Fuel salinization protection active
IDE06308	Start request history data	Deceleration takeover active
IDE06308	Start request history data	Motor protection active
IDE06308	Start request history data	SCR System requires restart
IDE06308	Start request history data	Engine hood open
IDE06308	Start request history data	Rolling vehicle
IDE06308	Start request history data	Auxiliary consumers power too high
IDE06308	Start request history data	Engine temperature too high
IDE06308	Start request history data	Sporadic function restriction
IDE06386	Oil level: static measurement	0	 mm
IDE06387	Oil level: last valid dynamic value	0	 mm
IDE06388	Oil level: condition for static measurement fulfilled	Condition not met
IDE06389	Oil level: maximum value	-127	 mm
IDE06390	Oil level: minimum value	127	 mm
IDE06391	Oil temperature sensor 2	66	 °
IDE06392	Oil temperature sensor 2: raw value	65.535	 V
IDE06393	Oil level: dynamic average value	0	 mm
IDE06394	Sensor 1 for secondary air pressure: unconditioned voltage	2.437	 V
IDE06395	Fuel low pressure sensor: unconditioned voltage	4.995	 V
IDE06396	Coolant temperature at engine outlet: unconditioned voltage	1.168	 V
IDE06397	Temperature sensor for engine temp. management: target value	107.3	 °
IDE06398	Temperature sensor for engine temp. management: uncond. voltage	1.167	 V
IDE06399	Manifold absolute pressure sensor: unconditioned voltage	1.689	 V
IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
IDE06432	Oxygen sensor 1 bank 1 signal status	not active
IDE06444	Oxygen sensor before cat bank 1 (LSB) voltage	1.997	 V
IDE06567	Start-stop function deactivation frequency counter	0
IDE06568	Stop prevention by driver frequency counter	0
IDE06569	Vehicle stopped frequency counter	0
IDE06573	Long-term adaptation of intake manifold injection	0	 %
IDE06574	Long-term adaptation of intake manifold injection in idle	0	 mg/stroke
IDE06610	Vehicle standstill with stop frequency counter	0
IDE06703-IDE12714	Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration	No
IDE06703-MAS14977	Drivetrain coordinator: ACC fault status-ACC active: although TSK passive	No
IDE06703-MAS14978	Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set	No
IDE06703-MAS14979	Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously	No
IDE06703-MAS14980	Drivetrain coordinator: ACC fault status-ACC active: although limiter active	No
IDE06703-MAS14981	Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking	No
IDE06703-MAS14982	Drivetrain coordinator: ACC fault status-ACC sends undefined signals	No
IDE06703-MAS14983	Drivetrain coordinator: ACC fault status-ACC active although main switch off	No
IDE06703-MAS14984	Drivetrain coordinator: ACC fault status-ACC is active despite driver braking	No
IDE06703-MAS14985	Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling	No
IDE06704-MAS14986	Drivetrain coordinator: brake fault status-Deceleration sensor not available	No
IDE06704-MAS14987	Drivetrain coordinator: brake fault status-Deceleration sensor malfunction	No
IDE06704-MAS14988	Drivetrain coordinator: brake fault status-ESP system error	No
IDE06704-MAS14989	Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque	No
IDE06704-MAS14990	Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error	No
IDE06704-MAS14991	Drivetrain coordinator: brake fault status-TSK/ESP handshake error	No
IDE06704-MAS14992	Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction	No
IDE06704-MAS14993	Drivetrain coordinator: brake fault status-Brake light implausible	No
IDE06705-MAS05179	Drivetrain coordinator: brake function status-ABS intervention	No
IDE06705-MAS05180	Drivetrain coordinator: brake function status-ESP intervention	No
IDE06705-MAS05181	Drivetrain coordinator: brake function status-EDL intervention	No
IDE06705-MAS05186	Drivetrain coordinator: brake function status-ASR intervention	No
IDE06705-MAS05187	Drivetrain coordinator: brake function status-MSR intervention	No
IDE06705-MAS05192	Drivetrain coordinator: brake function status-Driver braking	No
IDE06705-MAS05195	Drivetrain coordinator: brake function status-HDC active	No
IDE06705-MAS15001	Drivetrain coordinator: brake function status-ESP invokes TSK braking	No
IDE06705-MAS15002	Drivetrain coordinator: brake function status-EPB active	No
IDE06705-MAS15003	Drivetrain coordinator: brake function status-ASP intervention	No
IDE06705-MAS15004	Drivetrain coordinator: brake function status-ADS intervention	No
IDE06705-MAS15006	Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt	No
IDE06705-MAS15007	Drivetrain coordinator: brake function status-ESP sampled passive (ESP off)	No
IDE06705-MAS15008	Drivetrain coordinator: brake function status-ASR sampled passive (ASR off)	No
IDE06705-MAS15009	Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest	No
IDE06705-MAS15010	Drivetrain coordinator: brake function status-ACC stopping distance control active	No
IDE06706	ACC variants	ACC
IDE06707	CCS Switch	CCS operating unit
IDE06709	ACC variants (coding)	CCS
IDE06710	Cruise control system: permanent deactivation	No switch-off occurs
IDE06726	Timing deviation after chain replacement: intake bank 1	-1.44	 °
IDE06728	Timing deviation after chain replacement: exhaust bank 1	0	 °
IDE06730	Timing deviation after other repairs: intake bank 1	0	 °
IDE06732	Timing deviation after other repairs: exhaust bank 1	0	 °
IDE06734	Timing deviation: current value intake bank 1	0	 °
IDE06736	Timing deviation: current value exhaust bank 1	0	 °
IDE06738	Chain elongation: no. of valid initial values: intake bank 1	1
IDE06740	Chain elongation: no. of valid initial values: exhaust bank 1	0
IDE06742	Chain elongation: initial values valid: intake bank 1	not active
IDE06744	Chain elongation: initial values valid: exhaust bank 1	not active
IDE07001	Piston-cooling jets: activation	On
IDE07008	Tank leak: number no leak detected	19
IDE07011	Tank leak: number communication errors to engine control	6
IDE07014	Tank leak: number very small leaks detected	0
IDE07019	Number of ignitions direct injection	1021392
IDE07020	Number of ignitions intake manifold injection	0
IDE07023	Misfires per 1000 revolutions of cyl. 1 intake manif. injection	0
IDE07024	Misfires per 1000 revolutions of cyl. 2 intake manif. injection	0
IDE07025	Misfires per 1000 revolutions of cyl. 3 intake manif. injection	0
IDE07026	Misfires per 1000 revolutions of cyl. 4 intake manif. injection	0
IDE07027	Heat quantity that was transported via the catalytic converter	2.43E+08	 J
IDE07031	Oil pressure switch for piston-cooling jets: status	Open
IDE07242	Heater support pump: spec. value	10	 %
IDE07548	Engine temp. mangmt. actuator: specified value of angle	88.75	 °
IDE07549	Engine temp. mangmt. actuator: actual value of angle	88.72	 °
IDE07550	Engine temp. management actuator: raw value	1470
IDE07551	Engine temp. management actuator: duty cycle activation	0	 %
IDE07552	Engine temper.managem.actuator adaptation: result adaptation	Adaptation successfully finished
IDE07553	Engine temperature management actuator: after-run stop	3961
IDE07554	Engine temperature management actuator: stop open	141
IDE07564	Required torque adjustment by idling regulator	0	 Nm
IDE07571	Engine torque	-16.5	 Nm
IDE07572	High pressure regulation: adaptation value	-5.3	 mg
IDE07574	Long-term fuel trim bank 1 at idle	0	 mg/stroke
IDE07575	Driver request torque	4	 Nm
IDE07576	Lost torque adaptation driving mode	3.3	 Nm
IDE07577	Lost torque adaptation A/C compressor and driving mode	-6.8	 Nm
IDE07598-MAS00320	Cruise control switch actuation-Main switch	not activated
IDE07598-MAS00325	Cruise control switch actuation-Setting	not activated
IDE07598-MAS00326	Cruise control switch actuation-Activation	not activated
IDE07598-MAS01632	Cruise control switch actuation-Status	OK
IDE07598-MAS02309	Cruise control switch actuation-Accelerate	not activated
IDE07598-MAS02310	Cruise control switch actuation-Decelerate	not activated
IDE07598-MAS05172	Cruise control switch actuation-Cancel	not activated
IDE07598-MAS05806	Cruise control switch actuation-Main switch hardware	not activated
IDE07598-MAS05807	Cruise control switch actuation-Coding	plausible
IDE07598-MAS05809	Cruise control switch actuation-Limit function	not selected
IDE07598-MAS05812	Cruise control switch actuation-Limit button	not activated
IDE07598-MAS05813	Cruise control switch actuation-Main switch CAN	not activated
IDE07598-MAS05842	Cruise control switch actuation-Large increment	not activated
IDE07598-MAS05843	Cruise control switch actuation-Control component verified	Yes
IDE07599-MAS01505	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off	Yes
IDE07599-MAS03849	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal	No
IDE07599-MAS04795	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off	Yes
IDE07599-MAS05135	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected	No
IDE07599-MAS05136	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control	No
IDE07599-MAS05190	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated	No
IDE07599-MAS05192	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking	No
IDE07599-MAS05196	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error	No
IDE07599-MAS05814	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error	No
IDE07599-MAS05815	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error	No
IDE07599-MAS05816	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error	No
IDE07599-MAS05817	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation	No
IDE07599-MAS05818	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible	No
IDE07599-MAS05819	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking	No
IDE07599-MAS05820	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error	No
IDE07599-MAS05821	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak	No
IDE07599-MAS05822	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available	No
IDE07599-MAS05823	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization	No
IDE07599-MAS05824	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation	No
IDE07599-MAS05825	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault	No
IDE07599-MAS05826	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault	No
IDE07599-MAS05827	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met	No
IDE07599-MAS05828	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature	No
IDE07599-MAS05829	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault	No
IDE07599-MAS05830	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component	No
IDE07599-MAS05831	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component	No
IDE07599-MAS05832	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error	No
IDE07599-MAS05833	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error	No
IDE07599-MAS05834	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault	No
IDE07599-MAS05835	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault	No
IDE07599-MAS05836	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error	No
IDE07599-MAS05837	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error	No
IDE07605	Cruise control system: temporary deactivation	No switch-off
IDE07669	Oxygen sensor 2 Bank 1 after cat operation readiness Status	not active
IDE07901	Error counter bad fuel	0
IDE07904-ENG118117	Brake test switch status-actuated__activated	not activated
IDE07904-ENG114825	Brake test switch status-Ident_32	0
IDE07905-ENG118117	Brake light switch status-actuated__activated	not activated
IDE07905-ENG114825	Brake light switch status-Ident_32	0
IDE07906-ENG118117	Upper clutch switch: status-actuated__activated	not activated
IDE07906-ENG114825	Upper clutch switch: status-Ident_32	0
IDE07945-MAS00334	Status of intermittent monitoring-Catalytic converter monitoring	completed successfully
IDE07945-MAS00335	Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature	completed successfully
IDE07945-MAS00336	Status of intermittent monitoring-Monitoring of tank ventilation system	not completed successfully
IDE07945-MAS00337	Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system	completed successfully
IDE07945-MAS00338	Status of intermittent monitoring-Monitoring of A/C system refrigerant	completed successfully
IDE07945-MAS00339	Status of intermittent monitoring-Monitoring of oxygen sensor	completed successfully
IDE07945-MAS00340	Status of intermittent monitoring-Monitoring of oxygen sensor heater	completed successfully
IDE07945-MAS00341	Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR)	not completed successfully
IDE08071-ENG119931	Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1	0
IDE08072-ENG119932	Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2	0
IDE08073-ENG119933	Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3	0
IDE08074-ENG119934	Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4	0
IDE08075-ENG119935	Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5	0
IDE08495	Activation radiator shutter result	0	 %
IDE08805	EVAP valve diag. activation condition at minimal load	0	 counts
IDE08806	EVAP valve diag. activation condition at maximum load	2	 mbar
IDE10366	Chg. press. ctrl. valve: sensor voltage max. value	3.568	 V
IDE10380	Knock sensor average voltage bank 1	0	 V
IDE10551-MAS05304	Pre-ignition counter for oxygen shift-Cylinder 1	0
IDE10551-MAS05305	Pre-ignition counter for oxygen shift-Cylinder 2	0
IDE10551-MAS05306	Pre-ignition counter for oxygen shift-Cylinder 3	0
IDE10551-MAS05307	Pre-ignition counter for oxygen shift-Cylinder 4	0
IDE10551-MAS05308	Pre-ignition counter for oxygen shift-Cylinder 5	0
IDE10551-MAS05309	Pre-ignition counter for oxygen shift-Cylinder 6	0
IDE10551-MAS05310	Pre-ignition counter for oxygen shift-Cylinder 7	0
IDE10551-MAS05311	Pre-ignition counter for oxygen shift-Cylinder 8	0
IDE10552-MAS05304	Pre-ignition counter for torque reduction-Cylinder 1	0
IDE10552-MAS05305	Pre-ignition counter for torque reduction-Cylinder 2	0
IDE10552-MAS05306	Pre-ignition counter for torque reduction-Cylinder 3	0
IDE10552-MAS05307	Pre-ignition counter for torque reduction-Cylinder 4	0
IDE10552-MAS05308	Pre-ignition counter for torque reduction-Cylinder 5	0
IDE10552-MAS05309	Pre-ignition counter for torque reduction-Cylinder 6	0
IDE10552-MAS05310	Pre-ignition counter for torque reduction-Cylinder 7	0
IDE10552-MAS05311	Pre-ignition counter for torque reduction-Cylinder 8	0
IDE10553-MAS05304	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1	0
IDE10553-MAS05305	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2	0
IDE10553-MAS05306	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3	0
IDE10553-MAS05307	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4	0
IDE10553-MAS05308	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5	0
IDE10553-MAS05309	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6	0
IDE10553-MAS05310	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7	0
IDE10553-MAS05311	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8	0
IDE10554-MAS05304	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1	0
IDE10554-MAS05305	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2	0
IDE10554-MAS05306	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3	0
IDE10554-MAS05307	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4	0
IDE10554-MAS05308	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5	0
IDE10554-MAS05309	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6	0
IDE10554-MAS05310	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7	0
IDE10554-MAS05311	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8	0
IDE10922	Pump current of tank leakage diag.: corrected & filtered	0	 mA
IDE10970-MAS11563	Number of prevented stop processes-Engine hood open	0
IDE10970-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
IDE10970-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
IDE10989-MAS00106	Immobilizer: historic data-Year	2127
IDE10989-MAS00107	Immobilizer: historic data-Month	15
IDE10989-MAS00108	Immobilizer: historic data-Day	31
IDE10989-MAS00109	Immobilizer: historic data-Hours	31
IDE10989-MAS00110	Immobilizer: historic data-Minutes	63
IDE10989-MAS00111	Immobilizer: historic data-Seconds	63
IDE10989	Immobilizer: historic data	Engine hood open
IDE10989	Immobilizer: historic data	Brake pedal information: plausibility
IDE10989	Immobilizer: historic data	Function locked due to excessive stalling
IDE10994	Poor start counter at start-stop	0
IDE11115	Start/stop driver request: counter restart by starter	0
IDE11116	Start/stop driver request: counter internal-motor restart	0
IDE11598	Tank deaeration valve diagnosis: unweighted input value	0	 counts
IDE11599	Tank deaeration valve diagnosis: weighted output value	0	 counts
IDE11600	Tank tightness: ambient temperature	-48	 °C
IDE11919	Lock time for cooling down of secondary air pump	0	 s
IDE12137	Tank fill level diagnostic reference value	54	 l
IDE12138	Fuel consumption per driving cycle	92.52	 l/100km
ENG102981	AC compressor: speed increase	0
ENG103860	AC request: speed increase	0
ENG103042	Accelerator pedal sender: learned end stop	4.126	 V
ENG103719	Accelerator position	0	 %
ENG101488	ACF: load	0
ENG103474	Activation of oil pressure switching valve	0
ENG103323	Additional water pump	1
ENG101828	Air mass	0	 kg/h
ENG104264	Alternator load	0	 W
ENG103910	Ambient temperature	21	 °C
ENG112539	AR_THR_AD_ADD_MMV	-0.008	 cm²
ENG98377	As	none
ENG103165	Battery voltage	14.4	 V
ENG07601	Bypasstool_a2l_name	ORIGINAL A2L
ENG07600	Bypasstool_manipulation_bit	not active
ENG101413	Calibration Identification	8V0264M 0001AXAK
ENG99697	Calibration Verification Number	C8 7B A4 D6
ENG128780	CAM_DIF_VCP[EX_1]	0	 °
ENG128781	CAM_DIF_VCP[IN_1]	0	 °
ENG102002	CAM_OFS_IVVT_IN[1]	0	 °
ENG112540	CAM_PHA_ENG[GES_EX][CBK_1]	0	 °
ENG112541	CAM_PHA_ENG[GES_IN][CBK_1]	0	 °
ENG101169	CAM_PHA_OFS_MAF[IN][1]	0	 °
ENG112542	CAM_SP_IND_VCP[EX_1]	0	 °
ENG112543	CAM_SP_IND_VCP[IN_1]	0	 °
ENG112544	CAM_VCP[EX_1]	0	 °
ENG112545	CAM_VCP[IN_1]	0	 °
ENG103849	Cat. ageing: bank 1: actual	0.016
ENG101785	Cat. temperature: bank 1	262.0375	 °C
ENG102214	CPU_LOAD	41.4	 %
ENG125189	CTR_CAM_IN_SP_PI_DET_REQ[0]	0
ENG125190	CTR_CAM_IN_SP_PI_DET_REQ[1]	0
ENG125191	CTR_CAM_IN_SP_PI_DET_REQ[2]	0
ENG125192	CTR_CAM_IN_SP_PI_DET_REQ[3]	0
ENG101127	CTR_CDN_OBD_RBM	6
ENG114826	CTR_EDGE_CAM_EX[1]	0
ENG114827	CTR_EDGE_CAM_IN[1]	0
ENG100536	CTR_IGK_CYC_RBM	123
ENG125193	CTR_LAMB_SP_PI_REQ[0]	0
ENG125194	CTR_LAMB_SP_PI_REQ[1]	0
ENG125195	CTR_LAMB_SP_PI_REQ[2]	0
ENG125196	CTR_LAMB_SP_PI_REQ[3]	0
ENG112554	CTR_MIS_DC_MMV_CYL_SAE[0]	0
ENG112555	CTR_MIS_DC_MMV_CYL_SAE[1]	0
ENG112556	CTR_MIS_DC_MMV_CYL_SAE[2]	0
ENG112557	CTR_MIS_DC_MMV_CYL_SAE[3]	1
ENG112558	CTR_MIS_TOT_NVMY_SAE	120
ENG125197	CTR_REQ_IV_OFF_PI_FAST[0]	0
ENG125198	CTR_REQ_IV_OFF_PI_FAST[1]	0
ENG125199	CTR_REQ_IV_OFF_PI_FAST[2]	0
ENG125200	CTR_REQ_IV_OFF_PI_FAST[3]	0
ENG125201	CTR_REQ_IV_OFF_PI_SLOW[0]	0
ENG125202	CTR_REQ_IV_OFF_PI_SLOW[1]	0
ENG125203	CTR_REQ_IV_OFF_PI_SLOW[2]	0
ENG125204	CTR_REQ_IV_OFF_PI_SLOW[3]	0
ENG128782	CTR_REQ_IV_OFF_PI_SLOW_TMP[0]	0
ENG128783	CTR_REQ_IV_OFF_PI_SLOW_TMP[1]	0
ENG128784	CTR_REQ_IV_OFF_PI_SLOW_TMP[2]	0
ENG128785	CTR_REQ_IV_OFF_PI_SLOW_TMP[3]	0
ENG100764	CTR_SUM_SRV_INTL	0
ENG125205	CTR_TQI_POW_MAX_PI_REQ[0]	0
ENG125206	CTR_TQI_POW_MAX_PI_REQ[1]	0
ENG125207	CTR_TQI_POW_MAX_PI_REQ[2]	0
ENG125208	CTR_TQI_POW_MAX_PI_REQ[3]	0
ENG119929	CTR_VLD_CAT_GAP_AFL[1]	0
ENG119930	CTR_VLD_CAT_GAP_AFR[1]	0
ENG99428	CTR_VLFT_1_SWI_NOT[0]	0
ENG103626	CTR_VLFT_1_SWI_NOT[1]	0
ENG100809	CTR_VLFT_1_SWI_NOT[2]	0
ENG99336	CTR_VLFT_1_SWI_NOT[3]	0
ENG103025	CTR_VLFT_STND_SWI_NOT[0]	0
ENG100017	CTR_VLFT_STND_SWI_NOT[1]	0
ENG100438	CTR_VLFT_STND_SWI_NOT[2]	0
ENG100736	CTR_VLFT_STND_SWI_NOT[3]	0
ENG112559	CTR_VVL_LIH_ACT	0
ENG101271	CTR_VVL_LIH_DEAC	0
ENG100551	CTR_VVL_SWI_DC	0
ENG99561	CTR_VVL_SWI_H	0
ENG101173	CTR_VVL_SWI_L	8
ENG99084	Cycle flags: (completed cycles): cat: lambda probe heater	57
ENG100943	Cycle flags: (completed cycles): lambda probes: EGR	0
ENG99495	Cycle flags: (completed tests): lambda adaption:	8
ENG103597	Cycle flags:(completed cycles):lambda probes:sec.air sys.	59
ENG101652	Cylinder shut-off: cylinder suppression	1
ENG102657	DIAG_INST[0]	NO_ERROR
ENG99120	DIAG_INST[1]	NO_ERROR
ENG103260	DIAG_INST[2]	NO_ERROR
ENG99710	DIAG_INST[3]	NO_ERROR
ENG102667	DIAG_INST[4]	NO_ERROR
ENG102739	DIAG_INST[5]	NO_ERROR
ENG100162	DIAG_INST[6]	NO_ERROR
ENG99103	DIAG_INST[7]	NO_ERROR
ENG99261	DIAG_INST[8]	NO_ERROR
ENG103622	DIAG_INST[9]	NO_ERROR
ENG112560	DIST_ACT_MIL_SAE	0	 km
ENG112561	DIST_DTC_CLR_SAE	121	 km
ENG103766	DIST_ENG_RUN_IN	138386.7	 m
ENG100531	DIST_ST	138400	 m
ENG100131	ECU_STATE	ENG_STOP
ENG100152-ENG104003	ECUNAME-ECU	ECM
ENG100152	ECUNAME	EngineControl
ENG103712	EFPPWM_MIN_AD	0	 %
ENG104044	Engine load	0	 %
ENG102494	Engine speed: actual	0	 /min
ENG102783	Engine: operating status	ES
ENG103667	ENVD_0_MON	0
ENG100777	ENVD_0_MON_3	0
ENG126934	ENVD_0_MON_3_VD	0
ENG99424	ENVD_1_MON	0
ENG100344	ENVD_1_MON_3	0
ENG126935	ENVD_1_MON_3_VD	0
ENG99790	ENVD_2_MON	0
ENG100541	ENVD_2_MON_3	0
ENG126936	ENVD_2_MON_3_VD	0
ENG99455	ENVD_3_MON	0
ENG101268	ENVD_3_MON_3	0
ENG126937	ENVD_3_MON_3_VD	0
ENG01743	ENVD_4_MON	0
ENG01744	ENVD_5_MON	0
ENG01745	ENVD_6_MON	0
ENG99752	Error flags: (completed cycles): cat: lambda probe heater	0
ENG101275	Error flags: (completed cycles): lambda probes: EGR	0
ENG104132	Error flags: (completed cycles): lambda probes:sec.air sys.	0
ENG101942	ESI (extended service intervals) oil warning threshold	59.25	 mm
ENG112562	FAC_AR_THR_AD	0	 %
ENG104194	FAC_H_RNG_LAM_AD[1]	0	 %
ENG104151	FAC_L_RNG_LAM_AD[1]	0	 %
ENG100298	FAC_LAM_CP	0	 %
ENG100108	FAC_LAM_LIM[1]	0	 %
ENG99722	FAC_LAM_TCO_A[1]	0	 %
ENG103521	FAC_LAM_TCO_B[1]	0	 %
ENG103641	FAC_LAM_TCO_C[1]	0	 %
ENG101578	FAC_LAM_TCO_D[1]	0	 %
ENG100685	FAC_LAM_TCO_E[1]	0	 %
ENG103307	FAC_MAF_MAX	0
ENG99791	FAC_SLOP_IV[1]	0
ENG102306	FAC_TPS_1_SAE	15.625	 %
ENG102292	FAC_TPS_1_SAE	16.015625	 %
ENG99630	Fan control relay: fan run-on	2
ENG101437	Fan request from air conditioner	0	 %
ENG103644	FRF_IMMO_SNAPSHOT_BYTE1	0
ENG102892	FRF_IMMO_SNAPSHOT_BYTE2	0
ENG100521	FRF_IMMO_SNAPSHOT_BYTE3	0
ENG101852	FRF_IMMO_SNAPSHOT_BYTE4	0
ENG99312	FRF_IMMO_SNAPSHOT_BYTE5	0
ENG103956	FRF_IMMO_SNAPSHOT_BYTE6	0
ENG128786	FTL_SAE	92.15686426	 %
ENG104248	Fuel consumption signal	0	 µl
ENG101667	Fuel pump: adaption value	0	 %
ENG100969	Fuel pump: fuel pressure: I-controller	0	 %
ENG100250	Fuel regulating valve: duty cycle	0	 %
ENG101692	Fuel supply system: high-pressure regulator	59360.3	 hPa
ENG114828	FUP_EFP_MES	11000.8	 hPa
ENG103553	FUP_EFP_ST_H	0	 hPa
ENG101056	FUP_EFP_ST_L	0	 hPa
ENG99950	FUP_EFP_STOP_H	0	 hPa
ENG100784	FUP_EFP_STOP_L	0	 hPa
ENG102108	FUP_H	43562.9	 hPa
ENG112563	FUP_H_SAE	4260	 kPa
ENG103368	Gearbox -CAN bus messages	126839
ENG99170	Height correction	985.64	 hPa
ENG103575	High-pressure system: regulator	119.03	 mg
ENG103879	High-pressure system: regulator: mobile part	0	 mg
ENG102603	High-pressure system: status	VCV_OPEN
ENG101567	Idling speed stabilisation: duty cycle/AC compressor torque	0.5	 Nm
ENG101946	Idling stabilisation: operating status	0
ENG100345	IGA_ADJ_KNK[0]	0	 °
ENG103593	IGA_ADJ_KNK[1]	0	 °
ENG103360	IGA_ADJ_KNK[2]	0	 °
ENG99404	IGA_ADJ_KNK[3]	0	 °
ENG100425	IGA_IGC[0]	-1.125	 °
ENG101655	IGA_IGC[1]	-1.125	 °
ENG100410	IGA_IGC[2]	-1.125	 °
ENG100407	IGA_IGC[3]	-1.125	 °
ENG112564	IGA_IGC_SAE	-1	 °
ENG101741	Intake air temperature	54	 °C
ENG100634	In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1	6	 counts
ENG125209	KNKS_ERR_REL[0]	0	 V
ENG99741	LAMB_DELTA_AD_LAM_ADJ[1]	0.00006
ENG99601	LAMB_DELTA_I_LAM_ADJ[1]	0
ENG112565	LAMB_DELTA_SUM_LAM_ADJ_AD[1]	0.00006
ENG99674	Lambda controller: bank 1 (averaged value)	0	 %
ENG101381	Lambda probe 1: bank 1: status	0
ENG101039	Lambda probe 1: bank 1: status	0
ENG102886	Lambda probe 1: bank 1: status	0
ENG104200	Lambda probe 2: bank 1: status	0
ENG101336	Lambda probe 2: bank 1: status	0
ENG99661	Lambda probe ageing: bank 1: dynamic factor	0
ENG101869	Lambda probe ageing: bank 1: probe 1: short trip result	228.6625	 °C
ENG100478	Lambda probe correction: duty cycle offset: bank 1	0
ENG103776	Lambda probe heater: bank 1: probe 2: short trip result	1
ENG102380	Lambda probe heater: resistance: bank 1: probe 2	65535	 Ohm
ENG99353	Lambda probe voltage: bank 1: probe 1 (broadband probe)	1.997	 V
ENG102763	Lambda probes actual: bank1	1
ENG104114	Lambda probes specified: bank1	0
ENG06592	LF_COSI_CTL_ERR_A	0
ENG06593	LF_COSI_CTL_ERR_B	0
ENG112566	LF_DPS_CYC_ERR_RAW_BSW[1]	0
ENG112567	LF_DPS_CYC_ERR_RAW_BSW[2]	0
ENG112568	LF_DPS_CYC_ERR_VLD_BSW[1]	0
ENG112569	LF_DPS_CYC_ERR_VLD_BSW[2]	0
ENG112570	LF_DPS_INI_ERR_RAW_BSW[1]	0
ENG112571	LF_DPS_INI_ERR_RAW_BSW[2]	0
ENG112572	LF_IV_ERR_RAW_BSW[0]	0
ENG112573	LF_IV_ERR_RAW_BSW[1]	0
ENG112574	LF_IV_ERR_RAW_BSW[2]	0
ENG112575	LF_IV_ERR_RAW_BSW[3]	0
ENG112576	LF_IV_ERR_VLD_BSW[0]	0
ENG112577	LF_IV_ERR_VLD_BSW[1]	0
ENG112578	LF_IV_ERR_VLD_BSW[2]	0
ENG112579	LF_IV_ERR_VLD_BSW[3]	0
ENG101645	LF_VVL_DIAG_SWI_NOT	0
ENG127734-MAS00106	Life_cycle_data_start_requirement_development-Year	2127
ENG127734-MAS00107	Life_cycle_data_start_requirement_development-Month	15
ENG127734-MAS00108	Life_cycle_data_start_requirement_development-Day	31
ENG127734-MAS00109	Life_cycle_data_start_requirement_development-Hours	31
ENG127734-MAS00110	Life_cycle_data_start_requirement_development-Minutes	63
ENG127734-MAS00111	Life_cycle_data_start_requirement_development-Seconds	63
ENG127734	Life_cycle_data_start_requirement_development	Steering
ENG127734	Life_cycle_data_start_requirement_development	Quattro Sport
ENG127734	Life_cycle_data_start_requirement_development	Multifunction unit control module
ENG127734	Life_cycle_data_start_requirement_development	Parking aid
ENG127734	Life_cycle_data_start_requirement_development	brakes
ENG127734	Life_cycle_data_start_requirement_development	Immobilizer
ENG127734	Life_cycle_data_start_requirement_development	Kessy
ENG127734	Life_cycle_data_start_requirement_development	Engine
ENG127734	Life_cycle_data_start_requirement_development	Level control system
ENG127734	Life_cycle_data_start_requirement_development	ACC
ENG127734	Life_cycle_data_start_requirement_development	Front sensor system for driver assistance systems
ENG127734	Life_cycle_data_start_requirement_development	All-wheel electronics
ENG127734	Life_cycle_data_start_requirement_development	12 V electrical system
ENG127734	Life_cycle_data_start_requirement_development	Transmission
ENG127734	Life_cycle_data_start_requirement_development	Front axis lift system
ENG127734	Life_cycle_data_start_requirement_development	A/C
ENG127734	Life_cycle_data_start_requirement_development	Convertible top control module
ENG127735-MAS00106	Life_cycle_data_stop_prohibition_development-Year	2127
ENG127735-MAS00107	Life_cycle_data_stop_prohibition_development-Month	15
ENG127735-MAS00108	Life_cycle_data_stop_prohibition_development-Day	31
ENG127735-MAS00109	Life_cycle_data_stop_prohibition_development-Hours	31
ENG127735-MAS00110	Life_cycle_data_stop_prohibition_development-Minutes	63
ENG127735-MAS00111	Life_cycle_data_stop_prohibition_development-Seconds	63
ENG127735	Life_cycle_data_stop_prohibition_development	Engine
ENG127735	Life_cycle_data_stop_prohibition_development	A/C
ENG127735	Life_cycle_data_stop_prohibition_development	Convertible top control module
ENG127735	Life_cycle_data_stop_prohibition_development	Steering
ENG127735	Life_cycle_data_stop_prohibition_development	Multifunction unit control module
ENG127735	Life_cycle_data_stop_prohibition_development	Parking aid
ENG127735	Life_cycle_data_stop_prohibition_development	ACC
ENG127735	Life_cycle_data_stop_prohibition_development	12 V electrical system
ENG127735	Life_cycle_data_stop_prohibition_development	Transmission
ENG127735	Life_cycle_data_stop_prohibition_development	Front axis lift system
ENG127735	Life_cycle_data_stop_prohibition_development	Quattro Sport
ENG127735	Life_cycle_data_stop_prohibition_development	Level control system
ENG127735	Life_cycle_data_stop_prohibition_development	Front sensor system for driver assistance systems
ENG127735	Life_cycle_data_stop_prohibition_development	All-wheel electronics
ENG127735	Life_cycle_data_stop_prohibition_development	brakes
ENG127735	Life_cycle_data_stop_prohibition_development	Immobilizer
ENG127735	Life_cycle_data_stop_prohibition_development	Kessy
ENG127733-MAS00106	Life_cycle_data_system_failure-Year	2127
ENG127733-MAS00107	Life_cycle_data_system_failure-Month	15
ENG127733-MAS00108	Life_cycle_data_system_failure-Day	31
ENG127733-MAS00109	Life_cycle_data_system_failure-Hours	31
ENG127733-MAS00110	Life_cycle_data_system_failure-Minutes	63
ENG127733-MAS00111	Life_cycle_data_system_failure-Seconds	63
ENG127733	Life_cycle_data_system_failure	Quattro Sport
ENG127733	Life_cycle_data_system_failure	Steering
ENG127733	Life_cycle_data_system_failure	Immobilizer
ENG127733	Life_cycle_data_system_failure	Kessy
ENG127733	Life_cycle_data_system_failure	Engine
ENG127733	Life_cycle_data_system_failure	Multifunction unit control module
ENG127733	Life_cycle_data_system_failure	Parking aid
ENG127733	Life_cycle_data_system_failure	12 V electrical system
ENG127733	Life_cycle_data_system_failure	Transmission
ENG127733	Life_cycle_data_system_failure	Convertible top control module
ENG127733	Life_cycle_data_system_failure	A/C
ENG127733	Life_cycle_data_system_failure	Level control system
ENG127733	Life_cycle_data_system_failure	ACC
ENG127733	Life_cycle_data_system_failure	Front sensor system for driver assistance systems
ENG127733	Life_cycle_data_system_failure	All-wheel electronics
ENG127733	Life_cycle_data_system_failure	brakes
ENG127733	Life_cycle_data_system_failure	Front axis lift system
ENG122701	LMVDes_st_Mod_Out_VW	8
ENG122702	LMVDes_v_Max_Man_Lim_VW	511.992	 km/h
ENG122703	LMVLim_v_Auth_Max_Out_VW	200	 km/h
ENG100402	LOIL_SUM_SRV_INTL	0	 mm
ENG99162	LV_ACC_RED_CMD	0
ENG102235	LV_ATB_ACT_1	0
ENG102541	LV_ATB_ACT_2	0
ENG114829	LV_BPA_LIH_REQ[0]	0
ENG99095	LV_CAN_HOOD_SWI	1
ENG128787	LV_CMD_RCL_OPEN	0
ENG128788	LV_ECRAS_FB_DIAG_POS_RESP[0]	0
ENG103049	LV_EFPPWM_AD_STOP	1
ENG101712	LV_ENG_RUN_IN	1
ENG100267	LV_ENG_RUN_IN_EXT_ADJ	0
ENG103319	LV_ERR_VLFT_1_SWI[1]	0
ENG103549	LV_ERR_VLFT_1_SWI[2]	0
ENG103191	LV_ERR_VLFT_1_SWI[3]	0
ENG101989	LV_ERR_VLFT_1_SWI[4]	0
ENG102313	LV_ERR_VLFT_STND_SWI[1]	0
ENG103044	LV_ERR_VLFT_STND_SWI[2]	0
ENG103443	LV_ERR_VLFT_STND_SWI[3]	0
ENG100487	LV_ERR_VLFT_STND_SWI[4]	0
ENG112471	LV_IGK	1
ENG103773	LV_INH_STR_RLY	0
ENG100044	LV_LOIL_L_WARN	0
ENG103492	LV_LOIL_L_WARN_ACT	0
ENG103908	LV_LOIL_L_WARN_TMP	0
ENG103716	LV_POIL_SWI_H	0
ENG100912	LV_POIL_SWI_L	0
ENG112586	LV_PWR_RLY[0]	1
ENG102417	LV_TPS_AD_ACT	0
ENG100842	LV_TPS_AD_DIAG_ERR	0
ENG103996	LV_TPS_AD_REQ	0
ENG112587	LV_VCP_AD_END	0
ENG102523	MAF	0	 mg/stroke
ENG99288	MAF_DIF_CAM_OFS_AD_SQ_TOT	0	 kg²/h²
ENG112588	MAP_MES_SAE	98	 kPa
ENG103501	MASS_SA_REL[0]	0
ENG100896	MASS_SA_REL_21_PHA	0
ENG103045	MASS_SA_REL_22_PHA	0
ENG103346	MFF_ADD_LAM_AD[1]	0	 mg/stroke
ENG126493	MFF_MPL_ADD_LAM_AD[1][1]	0.53	 mg/stroke
ENG101360	Misfire detection active	1
ENG102335	Misfires all cylinders per 1000 rpm	0
ENG128796	N_SP_IS_CLC	1100	 /min
ENG103004	N_TCHA	12908.9	 /min
ENG112590	N_TOOTH	0	 /min
ENG107737-ENG112538	NC_NR_DIAG_RBM-NC Value	154
ENG126111	NL_PRE[0]	0	 V
ENG126112	NL_PRE[1]	0	 V
ENG126113	NL_PRE[2]	0	 V
ENG126114	NL_PRE[3]	0	 V
ENG128789	NR_CYC_AD_DC_BAL_HOM[RNG_H]	0
ENG128790	NR_CYC_AD_DC_BAL_HOM[RNG_IS]	0
ENG128791	NR_CYC_AD_DC_BAL_HOM[RNG_L]	0
ENG128792	NR_CYC_AD_DIAG_BAL_HOM[0]	0
ENG128793	NR_CYC_AD_DIAG_BAL_HOM[1]	0
ENG128794	NR_CYC_AD_DIAG_BAL_HOM[2]	0
ENG128795	NR_CYC_AD_DIAG_BAL_HOM[3]	0
ENG112589	NR_CYL_FIRST_VVL_SWI	0
ENG99776	NR_CYL_VVL_H_ACK	4
ENG119936	O2L_MAX_CAT_GAP_AFL_MV[1]	0	 g
ENG119937	O2L_MAX_CAT_GAP_AFR_MV[1]	0	 g
ENG99157	PRS_SA_DIF	0	 hPa
ENG02464	PRS_UP_THR_MES	981.66	 hPa
ENG112591	PSN_EDGE_REL_AD_CAM_EX[1][1]	0	 °
ENG112592	PSN_EDGE_REL_AD_CAM_IN[1][1]	-0.25	 °
ENG114830	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1]	0	 °
ENG114831	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2]	0	 °
ENG114832	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1]	-0.25	 °
ENG114833	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2]	-1.5625	 °
ENG128797	PV	0	 %
ENG102195	PV_AV_1	0	 %
ENG99137	PV_AV_2	0	 %
ENG101068	PV_AV_H	0	 %
ENG112593	PWM_ACT_VCP[EX_1]	90.002	 %
ENG112594	PWM_ACT_VCP[IN_1]	90.002	 %
ENG101350	PWM_ETC	0	 %
ENG112595	PWM_HLD_VCP[EX_1]	9.375	 %
ENG112596	PWM_HLD_VCP[IN_1]	9.375	 %
ENG112597	PWM_PAS_VCP[EX_1]	9.375	 %
ENG112598	PWM_PAS_VCP[IN_1]	9.375	 %
ENG101201	Radiator fan 1: run-on: status	600W
ENG102359	Radiator fan 2: run-on: status	NO_ECF
ENG119939	RATIO_O2L_LIM_CAT_GAP_AFL_MV[1]	0
ENG119940	RATIO_O2L_LIM_CAT_GAP_AFR_MV[1]	0
ENG102377	Ready and error flags	4
ENG112599	RVC_AV	88.72	 °
ENG112601	RVC_SP	88.75	 °
ENG112600	RVCPWM	0	 %
ENG103248	SEG_AD_MMV_ER[0]	0	 ‰
ENG101135	SEG_AD_MMV_ER[1]	0.4027	 ‰
ENG99078	SEG_AD_MMV_ER[2]	-0.0865	 ‰
ENG103257	SEG_AD_MMV_ER[3]	0.4614	 ‰
ENG102511	SEG_AD_MMV_ER_H[0]	0	 ‰
ENG103258	SEG_AD_MMV_ER_H[1]	0.6588	 ‰
ENG99291	SEG_AD_MMV_ER_H[2]	-0.0665	 ‰
ENG99954	SEG_AD_MMV_ER_H[3]	0.7043	 ‰
ENG100568	SEG_AD_MMV_ER_L[0]	0	 ‰
ENG100601	SEG_AD_MMV_ER_L[1]	0.4027	 ‰
ENG102668	SEG_AD_MMV_ER_L[2]	-0.0865	 ‰
ENG101232	SEG_AD_MMV_ER_L[3]	0.4614	 ‰
ENG101561	SEG_AD_MMV_ER_MID[0]	0	 ‰
ENG102964	SEG_AD_MMV_ER_MID[1]	0.6271	 ‰
ENG100890	SEG_AD_MMV_ER_MID[2]	-0.0624	 ‰
ENG99793	SEG_AD_MMV_ER_MID[3]	0.6712	 ‰
ENG103381	Shut-off time	3.5	 s
ENG109006-ENG100882	Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX	15	 %
ENG109007-ENG99938	Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX	0	 %
ENG102971	Start adaption: temperature adaption factor 1	1
ENG102489	Start adaption: temperature adaption factor 2	1
ENG100723	Start adaption: temperature adaption factor 3	1
ENG100919	Starter control: interlock switch	0
ENG100800	Starter: start relay 1	0
ENG99979	Starter: start relay 2	0
ENG102033	STATE_BPA[0]	OPM
ENG102127	STATE_COMC_NVLD	Wait
ENG112602	STATE_CRK_STST	CRK_STST_PAS
ENG114834	STATE_CRU_OFF_IRR_CUS	0
ENG114835	STATE_CRU_OFF_REV_CUS	18416704
ENG112603	STATE_EOL_VVL	DEAC
ENG112605	STATE_LS_SAE[1]	INI
ENG104238	STATE_NVLD	READ_INI
ENG112606	STATE_PWM_VCP[EX_1]	HLD
ENG112607	STATE_PWM_VCP[IN_1]	HLD
ENG101078	STATE_READY_OBD_1	7
ENG100369	STATE_READY_OBD_3	0
ENG100342	STATE_REQ_NVLD	NO_REQ
ENG109090	STATE_SW_MVB	SC8S5010 CBS00I0
ENG128798	STATE_T_ES_RD	0
ENG128799	STATE_T_ES_VLD_RD	1
ENG112608	STATE_VCP	passive
ENG114836	STATE_VCV_CLOSE_SL	OFF
ENG103723	STATE_VVL_MNG	VVL_H
ENG112609	T_ACT_MIL_SAE	0	 min
ENG112494	T_AST_SAE	0	 s
ENG104148	T_COOL_LOIL	372.3	 ms
ENG112613	T_DTC_CLR_SAE	251	 min
ENG102790	T_EFP_MEM_H	0	 s
ENG102123	T_EFP_MEM_L	0	 s
ENG109299	T_ES	7	 min
ENG112615	T_ES_CNT	0
ENG112616	T_ES_DC	3	 min
ENG99463	T_ES_H	448	 s
ENG128802	T_IGK	263.44	 s
ENG99398	T_POP_COC_INTER_1	0	 s
ENG102747	T_PWL	0	 s
ENG128803	T_PWL_CAN	76	 s
ENG112636	T_SWI_VVL_ACR	0	 ms
ENG101325	T_TEMP_SIG_LOIL	54.5	 ms
ENG99126	T_VS_TOL_LOCK	0	 min
ENG125440	TAA	21	 °C
ENG102048	Tank breather valve: duty cycle	0	 %
ENG101339	Tank breather valve: short trip result	0	 kg/h
ENG100439	Tank level	0
ENG112610	TCO_1_FIRST_ST	83	 °C
ENG112611	TCO_1_ST	83	 °C
ENG112612	TCO_1_SYS	81	 °C
ENG103434	TCO_A_LAM_AD_WUP[1]	-5.25	 °C
ENG100381	TCO_B_LAM_AD_WUP[1]	9.75	 °C
ENG101581	TCO_C_LAM_AD_WUP[1]	24.75	 °C
ENG100354	TCO_D_LAM_AD_WUP[1]	35.25	 °C
ENG101973	TCO_E_LAM_AD_WUP[1]	45	 °C
ENG128800	TCO_MDL[STUCK_L_COOL_MON]	70	 °C
ENG124460	TCO_MDL[TH]	73.68	 °C
ENG100390	TCO_MIN_INTER_LAM_AD_WUP[1]	81	 °C
ENG100853	TCO_MIN_LAM_AD_WUP[1]	50.25	 °C
ENG102279	TCS/ESP: specified torque	16.53	 Nm
ENG99857	TCS: status	0
ENG110436	TEG_DYN_LS_DOWN[1]	242.35	 °C
ENG110437	TEG_DYN_LS_UP[1]	220.725	 °C
ENG101941	TEMP_CAT_STAT_MDL[1]	19.975	 °C
ENG112614	TEMP_CAT_UP_1_SAE	259.8	 °C
ENG114837	TFPA	77	 °C
ENG114838	TFU_HPP	79.5	 °C
ENG99608	Throttle valve adjuster: adaption status	ST_CHK_END
ENG101411	Throttle valve angle	6.098	 °
ENG102845	Throttle valve deviation	0	 %
ENG126115	TI_1_MES_MPI[0]	0	 ms
ENG126116	TI_1_MES_MPI[1]	0	 ms
ENG126117	TI_1_MES_MPI[2]	0	 ms
ENG126118	TI_1_MES_MPI[3]	0	 ms
ENG126119	TI_MES_4[PLS_1][0]	0	 ms
ENG126120	TI_MES_4[PLS_1][1]	0	 ms
ENG126121	TI_MES_4[PLS_1][2]	0	 ms
ENG126122	TI_MES_4[PLS_1][3]	0	 ms
ENG126123	TI_MES_4[PLS_2][0]	0	 ms
ENG126124	TI_MES_4[PLS_2][1]	0	 ms
ENG126125	TI_MES_4[PLS_2][2]	0	 ms
ENG126126	TI_MES_4[PLS_2][3]	0	 ms
ENG126127	TI_MES_4[PLS_3][0]	0	 ms
ENG126128	TI_MES_4[PLS_3][1]	0	 ms
ENG126129	TI_MES_4[PLS_3][2]	0	 ms
ENG126130	TI_MES_4[PLS_3][3]	0	 ms
ENG128801	TIA_CHA_DOWN_MV	67.494	 °C
ENG125276	TIG_MES_SAE[IM]	54	 °C
ENG103351	Time since engine start	0	 s
ENG112634	TLTS_MES[TCE]	81.203	 °C
ENG112635	TMAG_VCP	80	 °C
ENG110444	TPS_AD_CDN_MIS	0
ENG114839	TPS_ETC	6.098	 °
ENG99274	TPS_SP	6.047	 °
ENG103021	TQ_CONV	4	 Nm
ENG128804	TQI_ADD_ACT	0.03125	 Nm
ENG101426	TQI_GS_FAST_INC	0	 Nm
ENG128805	TQI_N_TCHA_MAX	1023.96875	 Nm
ENG102329	TTIP_MES_LS_UP[1]	-2048	 °C
ENG100355	V_FUP_EFP_MV	4.995	 V
ENG100739	V_PVS_1_BAS	0.7959	 V
ENG114840	V_PVS_KD	0	 V
ENG99514	VBOOST	64.5	 V
ENG103201	VCV_CLOSE_RNG	0	 °
ENG102311	Vehicle speed: filtered	0	 km/h
ENG122704	VLCAvl_st_Pt_VW	4
ENG122705	VLCReq_st_Dem_VW	0
ENG112639	VLS_DOWN_SAE[1]	1.275	 V
ENG128806	VOL_FLOW_CHA_UP_RED_MV	0	 m³/s
ENG101929	VP_TPS_1	0.791	 V
ENG102985	VP_TPS_2	4.1943	 V
ENG100421	VP_TPS_AD_EL_BOL_1	0.5029	 V
ENG103444	VP_TPS_AD_EL_BOL_2	4.4876	 V
ENG101674	VP_TPS_AD_LIH_1	0.791	 V
ENG99507	VP_TPS_AD_LIH_2	4.1992	 V
Elapsed Time: 01:05
Idle
;SW:8V0-906-264-M   HW:06K-907-425-B ---  Engine
;Component:1.8l R4 TFSI  H13 0001	 Coding:311D00122426002F0000
;EV_ECM18TFS0208V0906264M	1003	EV_ECM18TFS0208V0906264M.rod
;Sunday	26	August	2018	11:27:28:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 46D65C71682711E7EBE-8012
Group	Description	Actual
IDE00011	Vehicle Identification Number (VIN)	3VWH17AU5JM758941
IDE00018	Voltage terminal 15	13.574	 V
IDE00019	Voltage terminal 30	13.867	 V
IDE00021	Engine speed	699	 /min
IDE00025	Coolant temperature	96	 °C
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00076	Status of initial fuel filling	was not yet started
IDE00078	Time since engine start	114	 s
IDE00083	Throttle valve position (absolute)	11.4	 %
IDE00084	Absolute load value	20	 %
IDE00085	Normed load value	25.1	 %
IDE00086	Accelerator position	16	 %
IDE00090	selected gear	Shifting process active
IDE00097	OBD - requirements for which this vehicle is designed	OBD + OBD II
IDE00102	Control Module temperature	57	 °
IDE00148	Median injection timing	1	 ms
IDE00149	Ignition angle of current cylinder: actual value	-1.12	 °
IDE00150	Pressure in brake booster	1.15	 bar
IDE00151	Oil fill level	79	 mm
IDE00155	Timing angle retardation cylinder 1	0	 °
IDE00156	Timing angle retardation cylinder 2	0	 °
IDE00157	Timing angle retardation cylinder 3	0	 °
IDE00158	Timing angle retardation cylinder 4	0	 °
IDE00167	Exhaust temperature 1 bank 1	643.7	 °C
IDE00172	A/C compressor torque	0	 Nm
IDE00173	Cruise Control System: specified speed	0	 km/h
IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	0	 °
IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	0	 °
IDE00178	Camshaft adjustment intake bank 1: specified value	0	 °
IDE00179	Camshaft adjustment intake bank 1: actual value	0	 °
IDE00182	Camshaft adaptation intake bank 1: phase position	-1.1	 °
IDE00184	Camshaft adaptation exhaust bank 1: phase position	47.6	 °
IDE00186	Fuel low pressure: actual value	11.003	 bar
IDE00187	Coolant temperature at engine start	75.7	 °
IDE00188	Fuel high pressure: actual value	45.2	 bar
IDE00189	Activation of fuel pump electronics	62.82	 %
IDE00190	Charge air pressure specified value	0.981	 bar
IDE00191	Charge air pressure: actual value	0.981	 bar
IDE00192	Coolant temperature at radiator outlet: actual value	30.1	 °
IDE00193	Coolant temperature at engine outlet: specified value	96.7	 °
IDE00194	Coolant temperature at radiator output: specified value	-48	 °
IDE00195	Coolant temperature difference between engine and radiator	66	 °
IDE00196	Engine oil temperature	77	 °C
IDE00199	Mean engine air mass	9	 kg/h
IDE00200	Median vehicle speed	0	 km/h
IDE00201	High fuel pressure: specified value	45.1	 bar
IDE00202	Low fuel pressure: specified value	5	 bar
IDE00252	Brake system vacuum pump	Pump off
IDE00304	Fuel level	49	 l
IDE00322	Status of basic setting	not active
IDE00323	Security Access: Number of invalid keys	0
IDE00348	Intake air temperature	44	 °C
IDE00349	Throttle valve position: normed	2	 %
IDE00350	Air mass: specified value	9	 kg/h
IDE00355	Cruise Control System (CCS): status	main switch off
IDE00357	Fuel temperature	64.5	 °
IDE00358	Limitation: torque	290	 Nm
IDE00371	Fuel consumption	1.31	 l/h
IDE00375	Generator: load signal	29.05	 %
IDE00380	Coolant fan 1: activation	10.16	 %
IDE00381	Coolant fan 2: activation	0	 %
IDE00392	Accelerator pedal: sensor voltage 1	0.796	 V
IDE00393	Accelerator pedal: sensor voltage 2	0.386	 V
IDE00396	Charge Pressure Actuator: acknowledgment	3.477	 V
IDE00400	Intake manifold Runner Control (IMRC): activation	100	 %
IDE00401	Intake manifold Runner Control (IMRC): acknowledgment	100	 %
IDE00404	Throttle valve: activation	13.95	 %
IDE00405	Crankshaft speed (RPM)	694	 /min
IDE00406	Camshaft speed (RPM)	0	 /min
IDE00407	Rail pressure regulation: status	Regulated operation via quantity control valve
IDE00408	Engine mount 1	not active
IDE00409	Engine mount 2	not active
IDE00412	Starter control: terminal 50	not active
IDE00413	Starter control: Interlock- or P/N-signal	0
IDE00414	Starter control: relay 1	0
IDE00415	Starter control: relay 2	0
IDE00416	Starter control: terminal 50 acknowledgment	1
IDE00417	Starter control: shut-off conditions 1	00 01
IDE00445	Unlearning counter according OBD	255
IDE00450	Operating Instructions	--no display--
IDE00451	Currently running routine	Unknown (0)
IDE00472	Mean injection quantity	7	 mg/stroke
IDE00474	Ambient air pressure	98	 kPa abs
IDE00476	Fuel Metering Valve	26.37	 %
IDE00477	Torque request: sum of auxiliary aggregate	4.7	 Nm
IDE00478	Engine-drag torque	21	 Nm
IDE00482	Limitation: torque of clutch protection	1024	 Nm
IDE00495	Calculated oil temperature	77	 °
IDE00496	Activation of oil pressure switch valve	High pressure
IDE00497-MAS00627	Status of oil pressure switches-Oil pressure switch for high pressure	closed
IDE00497-MAS00628	Status of oil pressure switches-Oil pressure switch for low pressure	closed
IDE00556	Outside air temperature	23	 °C
IDE00559	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)	1.004 Lambda / -0.012 mA
IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	0.82	 V
IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
IDE00582	Equivalence ratio target value	1.01	 Lambda
IDE00583	Throttle valve specified value	2	 %
IDE00584	Distance driven since erasing DTC memory	121	 km
IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
IDE00588	Fuel tank fill level	92.2	 %
IDE00589	Fuel pressure	4420	 kPa rel
IDE00592	Oxygen sensor control status	Closed loop	  / using O2 sensors
IDE00593	Ignition timing adjustment cylinder 1	-4.5	 Degrees
IDE00594	Absolute intake pressure	36	 kPa abs
IDE00595	Allocation of oxygen sensors	B1S1 B1S2
IDE00597	Long term adaptation of mixture formation bank 1	5.5	 %
IDE00601	Monitoring status since erasing DTC memory
IDE00602	Monitoring status in current driving cycle
IDE00603	Number of driving cycles since erasing DTC memory	22
IDE00604	Short term adaptation of mixture formation bank 1	-9.4	 %
IDE00608	Type of fuel	Gasoline
IDE00612	Target position of EVAP canister valve	12.2	 %
IDE00727	Test steps still to be performed	0
IDE00787	Cause for cancellation	0
IDE00949-ENG98517	Hide cylinder-Cylinder 1	not active
IDE00949-ENG98491	Hide cylinder-Cylinder 10	not active
IDE00949-ENG98492	Hide cylinder-Cylinder 11	not active
IDE00949-ENG98493	Hide cylinder-Cylinder 12	not active
IDE00949-ENG98518	Hide cylinder-Cylinder 13	not active
IDE00949-ENG98519	Hide cylinder-Cylinder 14	not active
IDE00949-ENG98520	Hide cylinder-Cylinder 15	not active
IDE00949-ENG98494	Hide cylinder-Cylinder 16	not active
IDE00949-ENG98521	Hide cylinder-Cylinder 2	not active
IDE00949-ENG98522	Hide cylinder-Cylinder 3	not active
IDE00949-ENG98523	Hide cylinder-Cylinder 4	not active
IDE00949-ENG98495	Hide cylinder-Cylinder 5	not active
IDE00949-ENG98524	Hide cylinder-Cylinder 6	not active
IDE00949-ENG98496	Hide cylinder-Cylinder 7	not active
IDE00949-ENG98497	Hide cylinder-Cylinder 8	not active
IDE00949-ENG98498	Hide cylinder-Cylinder 9	not active
IDE00968	Compressor speed	0	 /min
IDE01076-MAS00109	Time since ignition off-Hours	0	 H
IDE01076-MAS00110	Time since ignition off-Minutes	0	 min
IDE01076-MAS00111	Time since ignition off-Seconds	0	 s
IDE01098	Test of knock sensors: short trip result	Test not started
IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	0
IDE01266	Coolant shut-off valve	closed
IDE01369	Intake manifold runner control (IMRC): offset closed	0	 V
IDE01377	Throttle valve adapter: actual value	1.8	 °
IDE01378	High fuel pressure: control deviation	-0.8	 bar
IDE01385	Wear index	0.00000028
IDE01405-MAS05513	Status of starter activation-Bit 0	OK
IDE01405-MAS05514	Status of starter activation-Bit 1	Before starter activation
IDE01405-MAS05515	Status of starter activation-Bit 2	After starter activation
IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test not started
IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.823	 V
IDE01649	Throttle valve position 1	0.586	 V
IDE01650	Throttle valve position 2	11	 %
IDE01665	Result of test of camshaft adjustment intake bank 1	Test not started
IDE01667	Result of test of camshaft adjustment outlet bank 1	Test not started
IDE01670	Short trip status for oil pressure control	Test not started
IDE01671	Starter control: clutch switch	not pressed
IDE01672	Starter control: automatic start	not possible
IDE01673-MAS05513	Starter control: readiness bits-Bit 0	Mech. test of starter not complete
IDE01673-MAS05514	Starter control: readiness bits-Bit 1	Test of starter relay switching contacts not complete
IDE01673-MAS05515	Starter control: readiness bits-Bit 2	Test of starter relay activation not complete
IDE01673-MAS05516	Starter control: readiness bits-Bit 3	Test of terminal 50R return measuring line not completed
IDE01673-MAS05517	Starter control: readiness bits-Bit 4	Test of starter request double injection not complete
IDE01673-MAS05518	Starter control: readiness bits-Bit 5	Test of PN signal not complete
IDE01673-MAS05519	Starter control: readiness bits-Bit 6	Test of interlock switch not complete
IDE01673-MAS05520	Starter control: readiness bits-Bit 7	Test of clutch pedal switch not complete
IDE01677	Result of O2 sensor test ready bank 1 after cat. conv.	Test not started
IDE01683-MAS05304	Valve stroke switch of AVS from small to large-Cylinder 1	switched
IDE01683-MAS05305	Valve stroke switch of AVS from small to large-Cylinder 2	switched
IDE01683-MAS05306	Valve stroke switch of AVS from small to large-Cylinder 3	switched
IDE01683-MAS05307	Valve stroke switch of AVS from small to large-Cylinder 4	switched
IDE01683-MAS05308	Valve stroke switch of AVS from small to large-Cylinder 5	switched
IDE01683-MAS05309	Valve stroke switch of AVS from small to large-Cylinder 6	switched
IDE01683-MAS05310	Valve stroke switch of AVS from small to large-Cylinder 7	switched
IDE01683-MAS05311	Valve stroke switch of AVS from small to large-Cylinder 8	switched
IDE01684-MAS05304	Valve stroke switch of AVS from large to small-Cylinder 1	switched
IDE01684-MAS05305	Valve stroke switch of AVS from large to small-Cylinder 2	switched
IDE01684-MAS05306	Valve stroke switch of AVS from large to small-Cylinder 3	switched
IDE01684-MAS05307	Valve stroke switch of AVS from large to small-Cylinder 4	switched
IDE01684-MAS05308	Valve stroke switch of AVS from large to small-Cylinder 5	switched
IDE01684-MAS05309	Valve stroke switch of AVS from large to small-Cylinder 6	switched
IDE01684-MAS05310	Valve stroke switch of AVS from large to small-Cylinder 7	switched
IDE01684-MAS05311	Valve stroke switch of AVS from large to small-Cylinder 8	switched
IDE01685	Result of test of valve stroke switch AVS	Test not started
IDE01773	Misfire sum counter	0
IDE01774	Status misfire recognition	active
IDE01775	Misfires per 1000 revolutions of cylinder 1	0
IDE01776	Misfires per 1000 revolutions of cylinder 2	0
IDE01777	Misfires per 1000 revolutions of cylinder 3	0
IDE01778	Misfires per 1000 revolutions of cylinder 4	0
IDE01870	Oxygen sensor after catalytic converter: operating status	Bank 1: sensor 1 OK
IDE01873	Test of catalytic converter: measured value	0.016
IDE01874	Test of catalytic converter: result	Test not started
IDE01876	Adaptation of loss torque	-0.1	 Nm
IDE01878	Adaptation of throttle valve	Test of closing springs ended
IDE01880	Accelerator position 2	15	 %
IDE01881	Adaptation of kick-down shifting point	4.126	 V
IDE01884	Camshaft adjustment intake bank 1: activation	10.08	 %
IDE01886	Number of high pressure incursions	0
IDE01894	Charge press. ctrl.: adapt. higher than max. threshold	0.39	 %
IDE01895	Charge pressure control: less than min. threshold adaptation	0.78	 %
IDE01901	Lost torque adaptation: idle	-5.2	 Nm
IDE01905	Average of ignition timing angle delay adjustment	14.25	 °
IDE01906	Dynamic average of ignition timing angle delay adjustment	-3	 °
IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
IDE01922	Vehicle distance driven	138	 km
IDE01923	Control module distance driven	138	 km
IDE01924	Load shift flaps: actual value	closed
IDE01925	Load shift flaps: specified value	closed
IDE01926	Adaptation of load shift flaps	Cancel: prerequisites have not been met
IDE01928	Close cam shaft angle at quantity control valve	33.9	 °
IDE01929	Open cam shaft angle at quantity control valve	-32	 °
IDE01931	High pressure pump injection volume control deviation	2	 mg/stroke
IDE01932	High pressure pump injection volume	7	 mg/stroke
IDE01975	Numb.of misfir.: cylinder 1	0
IDE01976	Numb.of misfir.: cylinder 2	0
IDE01977	Numb.of misfir.: cylinder 3	0
IDE01978	Numb.of misfir.: cylinder 4	0
IDE01986	Contact for tank leak test	closed
IDE02116	Exhaust gas temperature before catalytic converter	409.4	 °
IDE02119	Long term adaptation of oxygen sensor control: bank 1	0	 %
IDE02229	Exh.gas temp.sen 1	1110	 °
IDE02756	Number of manual engine starts	125
IDE02757	Number of automatic engine starts	0
IDE03008-MAS04415	Stop process prevented-Ambient air pressure	not active
IDE03008-MAS04416	Stop process prevented-Sporadic function restriction	not active
IDE03008-MAS04417	Stop process prevented-Poor start detection	not active
IDE03008-MAS04590	Stop process prevented-Mixture adaptation	not active
IDE03008-MAS06602	Stop process prevented-Engine temperature	not active
IDE03008-MAS06604	Stop process prevented-Start-stop sensor system	not active
IDE03008-MAS06605	Stop process prevented-Regeneration operation	not active
IDE03008-MAS06606	Stop process prevented-Brake under pressure too low	not active
IDE03010-IDE00924	Number of prevented stop processes-Steering angle	0
IDE03010-MAS01627	Number of prevented stop processes-Steering	0
IDE03010-MAS02040	Number of prevented stop processes-Play protection	0
IDE03010-MAS04415	Number of prevented stop processes-Ambient air pressure	0
IDE03010-MAS04416	Number of prevented stop processes-Sporadic function restriction	36
IDE03010-MAS04417	Number of prevented stop processes-Poor start detection	0
IDE03010-MAS04589	Number of prevented stop processes-Diagnosis of exhaust system	0
IDE03010-MAS04590	Number of prevented stop processes-Mixture adaptation	0
IDE03010-MAS04591	Number of prevented stop processes-Diagnosis of air system	0
IDE03010-MAS04592	Number of prevented stop processes-Hybrid battery power insufficient	0
IDE03010-MAS04593	Number of prevented stop processes-Auxiliary consumers power too high	0
IDE03010-MAS04595	Number of prevented stop processes-Deceleration takeover active	0
IDE03010-MAS04805	Number of prevented stop processes-Clutch protection K0	0
IDE03010-MAS04870	Number of prevented stop processes-Test of thermostat not complete	0
IDE03010-MAS05758	Number of prevented stop processes-Driving situation	0
IDE03010-MAS06602	Number of prevented stop processes-Engine temperature	274
IDE03010-MAS06605	Number of prevented stop processes-Regeneration operation	0
IDE03010-MAS06606	Number of prevented stop processes-Brake under pressure too low	0
IDE03010-MAS08032	Number of prevented stop processes-Event memory entry in engine control module	0
IDE03010-MAS09416	Number of prevented stop processes-Adaptation active	0
IDE03010-MAS11563	Number of prevented stop processes-Engine hood open	0
IDE03010-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
IDE03010-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
IDE03010-MAS12864	Number of prevented stop processes-Tighter traffic flow detected	0
IDE03010-MAS13643	Number of prevented stop processes-E machine output too low	0
IDE03010-MAS13644	Number of prevented stop processes-Motor protection active	0
IDE03010-MAS13645	Number of prevented stop processes-Fuel salinization protection active	0
IDE03010-MAS13661	Number of prevented stop processes-Exhaust emission control diagnosis	0
IDE03010-MAS16918	Number of prevented stop processes-Restriction in the start system	0
IDE03011-MAS01627	Number of requested start processes-Steering	0
IDE03011-MAS04369	Number of requested start processes-Engine temperature too high	0
IDE03011-MAS04370	Number of requested start processes-Engine temperature too low	0
IDE03011-MAS04416	Number of requested start processes-Sporadic function restriction	0
IDE03011-MAS04592	Number of requested start processes-Hybrid battery power insufficient	0
IDE03011-MAS04593	Number of requested start processes-Auxiliary consumers power too high	0
IDE03011-MAS04595	Number of requested start processes-Deceleration takeover active	0
IDE03011-MAS06606	Number of requested start processes-Brake under pressure too low	0
IDE03011-MAS06607	Number of requested start processes-SCR System requires restart	0
IDE03011-MAS09730	Number of requested start processes-Cat. heater	0
IDE03011-MAS11563	Number of requested start processes-Engine hood open	0
IDE03011-MAS11834	Number of requested start processes-Rolling vehicle	0
IDE03011-MAS13644	Number of requested start processes-Motor protection active	0
IDE03011-MAS13645	Number of requested start processes-Fuel salinization protection active	0
IDE03011-MAS16918	Number of requested start processes-Restriction in the start system	0
IDE03108	Result of test of oxygen sensors bank 1	Test not started
IDE03235	Neutral position sensor: current transmission angle	20	 °
IDE03236	Neutral position sensor: adapted transmission angle	-179.96	 °
IDE03246	Neutral position sensor: upper adaptation value	0	 V
IDE03247	Neutral position sensor: lower adaptation value	0	 V
IDE03262	Adapt of angle sensor 1 f throttle valve	0.503	 V
IDE03263	Adapt of angle sensor 2 f throttle valve	4.488	 V
IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.791	 V
IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.199	 V
IDE03267	Intake air temperature: unconditioned voltage	1.401	 V
IDE03276	Charge air pressure sensor: unconditioned voltage	1.587	 V
IDE03277	Intake manifold Runner Control (IMRC): unconditioned voltage	3.911	 V
IDE03328	Transmission neutral position sensor voltage	0	 V
IDE03361	Driver request torque	25.5	 Nm
IDE03362	Requested transmission torque	1024	 Nm
IDE03375	Adaptation status for transmission neutral position sensor	0
IDE03377	Coolant temp at radiator output: unconditioned voltage	3.121	 V
IDE03582	Temperature sensor for engine temperature management	96.7	 °
IDE03585	System status for the start/stop function master	System malfunction
IDE03587-IDE02697	Stop overrides for active participants-Multifunction unit control module	not active
IDE03587-MAS00124	Stop overrides for active participants-A/C	not active
IDE03587-MAS00127	Stop overrides for active participants-brakes	not active
IDE03587-MAS00506	Stop overrides for active participants-Adaptive Cruise Control	not active
IDE03587-MAS00832	Stop overrides for active participants-Convertible top control module	not active
IDE03587-MAS01090	Stop overrides for active participants-Transmission	not active
IDE03587-MAS01106	Stop overrides for active participants-Level control system	not active
IDE03587-MAS01490	Stop overrides for active participants-Energy management	not active
IDE03587-MAS01627	Stop overrides for active participants-Steering	not active
IDE03587-MAS02237	Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.	not active
IDE03587-MAS02569	Stop overrides for active participants-All-wheel electronics	not active
IDE03587-MAS03757	Stop overrides for active participants-Quattro Sport	not active
IDE03587-MAS05129	Stop overrides for active participants-Engine	not active
IDE03587-MAS06709	Stop overrides for active participants-Keyless operation	not active
IDE03587-MAS08785	Stop overrides for active participants-Parking aid	not active
IDE03587-MAS13018	Stop overrides for active participants-Front sensor system for driver assistance systems	not active
IDE03588-IDE02697	System malfunctions for active participants start/stop-Multifunction unit control module	not active
IDE03588-MAS00124	System malfunctions for active participants start/stop-A/C	not active
IDE03588-MAS00127	System malfunctions for active participants start/stop-brakes	not active
IDE03588-MAS00506	System malfunctions for active participants start/stop-Adaptive Cruise Control	not active
IDE03588-MAS00832	System malfunctions for active participants start/stop-Convertible top control module	not active
IDE03588-MAS01090	System malfunctions for active participants start/stop-Transmission	not active
IDE03588-MAS01106	System malfunctions for active participants start/stop-Level control system	not active
IDE03588-MAS01490	System malfunctions for active participants start/stop-Energy management	not active
IDE03588-MAS01627	System malfunctions for active participants start/stop-Steering	not active
IDE03588-MAS02237	System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.	not active
IDE03588-MAS02569	System malfunctions for active participants start/stop-All-wheel electronics	not active
IDE03588-MAS03757	System malfunctions for active participants start/stop-Quattro Sport	not active
IDE03588-MAS05129	System malfunctions for active participants start/stop-Engine	not active
IDE03588-MAS06709	System malfunctions for active participants start/stop-Keyless operation	not active
IDE03588-MAS08785	System malfunctions for active participants start/stop-Parking aid	not active
IDE03588-MAS13018	System malfunctions for active participants start/stop-Front sensor system for driver assistance systems	not active
IDE03589-MAS01161	Error status for start-stop related sensors-Communication error	not active
IDE03589-MAS11563	Error status for start-stop related sensors-Engine hood open	active
IDE03589-MAS11868	Error status for start-stop related sensors-Driver door status	not active
IDE03589-MAS12097	Error status for start-stop related sensors-driver door open	active
IDE03589-MAS12098	Error status for start-stop related sensors-Start/Stop deactivated with button	active
IDE03589-MAS12099	Error status for start-stop related sensors-Clutch signal error	not active
IDE03589-MAS12100	Error status for start-stop related sensors-Brake or speed signal error	not active
IDE03589-MAS12101	Error status for start-stop related sensors-Steering signal error	not active
IDE03692-MAS05513	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0	Test of camshaft adjustment bank 2 outlet not complete
IDE03692-MAS05514	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1	Test of camshaft adjustment bank 1 outlet not complete
IDE03692-MAS05515	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2	Test of camshaft adjustment bank 2 intake not complete
IDE03692-MAS05516	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3	Test of camshaft adjustment bank 1 intake complete
IDE03692-MAS05517	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4	Test of knock sensor 4 not complete
IDE03692-MAS05518	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5	Test of knock sensor 3 not complete
IDE03692-MAS05519	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6	Test of knock sensor 2 not complete
IDE03692-MAS05520	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7	Test of knock sensor 1 complete
IDE03693-MAS05513	Monitoring status of additional Onboard Diagnosis-Bit 0	Test of brake light switch not complete
IDE03693-MAS05514	Monitoring status of additional Onboard Diagnosis-Bit 1	Test of clutch switch not complete
IDE03693-MAS05515	Monitoring status of additional Onboard Diagnosis-Bit 2	Test of idle control not complete
IDE03693-MAS05516	Monitoring status of additional Onboard Diagnosis-Bit 3	Test of coolant temperature sensor not complete
IDE03693-MAS05517	Monitoring status of additional Onboard Diagnosis-Bit 4	Test of throttle valve potentiometer not complete
IDE03693-MAS05518	Monitoring status of additional Onboard Diagnosis-Bit 5	Test of thermostat not complete
IDE03693-MAS05519	Monitoring status of additional Onboard Diagnosis-Bit 6	Test of charge pressure control complete
IDE03693-MAS05520	Monitoring status of additional Onboard Diagnosis-Bit 7	Test of CCS switch not complete
IDE03693-MAS05521	Monitoring status of additional Onboard Diagnosis-Bit 8	Test of oxygen adaptation bank 1 complete
IDE03711	Mass flow through throttle valve	6	 kg/h
IDE03767	Engine status	Idling
IDE03795	Camshaft adjustment: exhaust: bank 1: activation	14.92	 %
IDE03806	Oxygen sensor bank 1 sensor 1: status	1
IDE03807	Oxygen sensor bank 1 sensor 2: status	1
IDE03816	Exhaust flap bank 1	Open
IDE03818	Heated oxygen sensor bank 1: sensor 2: resistance	328	 Ohm
IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	32.42	 %
IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	304	 Ohm
IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	27.73	 %
IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 ms
IDE03834	Oxygen sensor bank 1 sensor 2: response time filtered	0	 ms
IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	Test not started
IDE03892	Fuel high pressure sensor: unconditioned voltage	1.127	 V
IDE03918	Engine reverse rotation recognition	not recognized
IDE03919	Oxygen regulation operability and status	On
IDE03920	Oxygen adaptation status	Condition not met
IDE03921	Mixture adaptation factor at partial load	-1.77	 %
IDE03922	Mixture adaptation factor at idle speed	7.77	 %
IDE03923	Adaptive long-term value of mix. condition after cat. conv	0.0001
IDE03924	Relay for reserve coolant pump: status	not activated
IDE03928	Counter for fuel entry in oil	0
IDE03930	Charge pressure actuator: operating status	Operating mode
IDE03931	Charge pressure actuator: actual position	1.32	 %
IDE03932	Charge pressure actuator: specified position	0	 %
IDE03933	Charge pressure actuator: specified value	0	 %
IDE03934	Charge pressure actuator: adaptation for lower stop	3.53	 V
IDE03935	Charge pressure actuator: adaptation for upper stop	0.57	 V
IDE03953	Oxygen control: adaptation value at partial load: bank 1	-1.77	 %
IDE03957	Throttle valve angle: specified value	1.8	 °
IDE03963	Low fuel pressure adaptation value for EFP	1200	 mbar
IDE03966	Transmission neutral position sensor PWM signal	0	 %
IDE03998	Clutch Position Sensor	99.61	 %
IDE04002	Charge press. ctrl.	BP_A act:98	 kPa
IDE04405	Mixture deviation in adapted partial load range 1	0	 %
IDE04409	Intake manifold pressure: corrected	0.363	 bar
IDE04410	Intake manifold pressure: target value	0.368	 bar
IDE04412	Pressure before throttle valve: corrected	0.98	 bar
IDE04415	Oxygen ctrl factor with precontrol correction	-13.67	 %
IDE04420	Activation of secondary air system	Atmosphere/off
IDE04629	AVS operating condition	Test is running
IDE04630	AVS valve stroke position: current	Standard
IDE04632-MAS05304	AVS error status of last switch-over standard stroke direction-Cylinder 1	OK
IDE04632-MAS05305	AVS error status of last switch-over standard stroke direction-Cylinder 2	OK
IDE04632-MAS05306	AVS error status of last switch-over standard stroke direction-Cylinder 3	OK
IDE04632-MAS05307	AVS error status of last switch-over standard stroke direction-Cylinder 4	OK
IDE04632-MAS05308	AVS error status of last switch-over standard stroke direction-Cylinder 5	OK
IDE04632-MAS05309	AVS error status of last switch-over standard stroke direction-Cylinder 6	OK
IDE04632-MAS05310	AVS error status of last switch-over standard stroke direction-Cylinder 7	OK
IDE04632-MAS05311	AVS error status of last switch-over standard stroke direction-Cylinder 8	OK
IDE04633-MAS05304	AVS error status of last switch-over AVS stroke direction-Cylinder 1	OK
IDE04633-MAS05305	AVS error status of last switch-over AVS stroke direction-Cylinder 2	OK
IDE04633-MAS05306	AVS error status of last switch-over AVS stroke direction-Cylinder 3	OK
IDE04633-MAS05307	AVS error status of last switch-over AVS stroke direction-Cylinder 4	OK
IDE04633-MAS05308	AVS error status of last switch-over AVS stroke direction-Cylinder 5	OK
IDE04633-MAS05309	AVS error status of last switch-over AVS stroke direction-Cylinder 6	OK
IDE04633-MAS05310	AVS error status of last switch-over AVS stroke direction-Cylinder 7	OK
IDE04633-MAS05311	AVS error status of last switch-over AVS stroke direction-Cylinder 8	OK
IDE04634	AVS switch-over meter for reg activation of curr. drive cycle	0
IDE04635	AVS switch-over meter: total	8
IDE04636	AVS overflow meter for all switch-overs	0
IDE04637	Engine temperature management actuator	99.75	 %
IDE04638	Transmission coolant valve	closed
IDE04677	O2 sensor 1 bank 1: O2 sensor actual value	1
IDE04680	O2 sensor 1: bank 1: voltage raw value O2 signal	1.997	 V
IDE04713	Active brake system status	Not operated
IDE04814	Transmission oil cooler valve	closed
IDE04937	Sensor for engine block temperature: raw value	-48	 °
IDE05140	Intake manifold pressure raw value	0.369	 bar
IDE05259	Gear position sensor: raw value	0	 %
IDE05260	Gear position sensor: current value	Neutral
IDE05261	Gear position sensor: last valid value	Neutral
IDE05262	Gear position sensor: gear position valid	invalid
IDE05310	Charge air pressure control valve position: target value	0	 %
IDE05311	Charge air pressure control valve position: actual value	1.32	 %
IDE05312	Charge air pressure control valve uncond voltage sensor	3.4766	 V
IDE05313	Charge air pressure control valve activation pulse duty factor	-15.08	 %
IDE05314-ENG112584	Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]	0
IDE05315	Charge air pressure control valve voltage: position closed	3.5303	 V
IDE05316	Charge air pressure control valve voltage: position open	0.5701	 V
IDE05317-ENG112583	Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0]	0
IDE05508	Adaptation val cyl 1 with slow diagnosis	0
IDE05509	Adaptation val cyl 3 with slow diagnosis	0
IDE05510	Adaptation val cyl 4 with slow diagnosis	0
IDE05511	Adaptation val cyl 2 with slow diagnosis	0
IDE05512	Adaptation val cyl 1 with fast diagnosis	0
IDE05513	Adaptation val cyl 3 with fast diagnosis	0
IDE05514	Adaptation val cyl 4 with fast diagnosis	0
IDE05515	Adaptation val cyl 2 with fast diagnosis	0
IDE05593	Secondary air injection sensor 1	0.983	 bar
IDE05622-ENG125277	Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL	0
IDE06006	Idle speed specified value	700	 /min
IDE06192	Knock sensor: cylinder 2: voltage	0.281	 V
IDE06193	Knock sensor: cylinder 3: voltage	0.302	 V
IDE06194	Knock sensor: cylinder 4: voltage	0.239	 V
IDE06195	Knock sensor: cylinder 1: voltage	0.259	 V
IDE06296-ENG104200	Activation of oxygen control after main cat-Lambda probe 2: bank 1: status	1
IDE06307-MAS00106	Stop prevention history data-Year	2018
IDE06307-MAS00107	Stop prevention history data-Month	8
IDE06307-MAS00108	Stop prevention history data-Day	26
IDE06307-MAS00109	Stop prevention history data-Hours	10
IDE06307-MAS00110	Stop prevention history data-Minutes	33
IDE06307-MAS00111	Stop prevention history data-Seconds	2
IDE06307	Stop prevention history data	not active
IDE06307	Stop prevention history data	Engine temperature
IDE06308-MAS00106	Start request history data-Year	2127
IDE06308-MAS00107	Start request history data-Month	15
IDE06308-MAS00108	Start request history data-Day	31
IDE06308-MAS00109	Start request history data-Hours	31
IDE06308-MAS00110	Start request history data-Minutes	63
IDE06308-MAS00111	Start request history data-Seconds	63
IDE06308	Start request history data	Hybrid battery power insufficient
IDE06308	Start request history data	Steering
IDE06308	Start request history data	Cat. heater
IDE06308	Start request history data	Restriction in the start system
IDE06308	Start request history data	Engine temperature too low
IDE06308	Start request history data	Brake under pressure too low
IDE06308	Start request history data	Fuel salinization protection active
IDE06308	Start request history data	Deceleration takeover active
IDE06308	Start request history data	Motor protection active
IDE06308	Start request history data	SCR System requires restart
IDE06308	Start request history data	Engine hood open
IDE06308	Start request history data	Rolling vehicle
IDE06308	Start request history data	Auxiliary consumers power too high
IDE06308	Start request history data	Engine temperature too high
IDE06308	Start request history data	Sporadic function restriction
IDE06386	Oil level: static measurement	0	 mm
IDE06387	Oil level: last valid dynamic value	0	 mm
IDE06388	Oil level: condition for static measurement fulfilled	Condition not met
IDE06389	Oil level: maximum value	-127	 mm
IDE06390	Oil level: minimum value	127	 mm
IDE06391	Oil temperature sensor 2	70	 °
IDE06392	Oil temperature sensor 2: raw value	65.535	 V
IDE06393	Oil level: dynamic average value	0	 mm
IDE06394	Sensor 1 for secondary air pressure: unconditioned voltage	2.437	 V
IDE06395	Fuel low pressure sensor: unconditioned voltage	4.995	 V
IDE06396	Coolant temperature at engine outlet: unconditioned voltage	0.844	 V
IDE06397	Temperature sensor for engine temp. management: target value	99.8	 °
IDE06398	Temperature sensor for engine temp. management: uncond. voltage	0.845	 V
IDE06399	Manifold absolute pressure sensor: unconditioned voltage	0.776	 V
IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
IDE06432	Oxygen sensor 1 bank 1 signal status	active
IDE06444	Oxygen sensor before cat bank 1 (LSB) voltage	1.982	 V
IDE06567	Start-stop function deactivation frequency counter	0
IDE06568	Stop prevention by driver frequency counter	0
IDE06569	Vehicle stopped frequency counter	0
IDE06573	Long-term adaptation of intake manifold injection	0	 %
IDE06574	Long-term adaptation of intake manifold injection in idle	0	 mg/stroke
IDE06610	Vehicle standstill with stop frequency counter	0
IDE06703-IDE12714	Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration	No
IDE06703-MAS14977	Drivetrain coordinator: ACC fault status-ACC active: although TSK passive	No
IDE06703-MAS14978	Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set	No
IDE06703-MAS14979	Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously	No
IDE06703-MAS14980	Drivetrain coordinator: ACC fault status-ACC active: although limiter active	No
IDE06703-MAS14981	Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking	No
IDE06703-MAS14982	Drivetrain coordinator: ACC fault status-ACC sends undefined signals	No
IDE06703-MAS14983	Drivetrain coordinator: ACC fault status-ACC active although main switch off	No
IDE06703-MAS14984	Drivetrain coordinator: ACC fault status-ACC is active despite driver braking	No
IDE06703-MAS14985	Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling	No
IDE06704-MAS14986	Drivetrain coordinator: brake fault status-Deceleration sensor not available	No
IDE06704-MAS14987	Drivetrain coordinator: brake fault status-Deceleration sensor malfunction	No
IDE06704-MAS14988	Drivetrain coordinator: brake fault status-ESP system error	No
IDE06704-MAS14989	Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque	No
IDE06704-MAS14990	Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error	No
IDE06704-MAS14991	Drivetrain coordinator: brake fault status-TSK/ESP handshake error	No
IDE06704-MAS14992	Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction	No
IDE06704-MAS14993	Drivetrain coordinator: brake fault status-Brake light implausible	No
IDE06705-MAS05179	Drivetrain coordinator: brake function status-ABS intervention	No
IDE06705-MAS05180	Drivetrain coordinator: brake function status-ESP intervention	No
IDE06705-MAS05181	Drivetrain coordinator: brake function status-EDL intervention	No
IDE06705-MAS05186	Drivetrain coordinator: brake function status-ASR intervention	No
IDE06705-MAS05187	Drivetrain coordinator: brake function status-MSR intervention	No
IDE06705-MAS05192	Drivetrain coordinator: brake function status-Driver braking	No
IDE06705-MAS05195	Drivetrain coordinator: brake function status-HDC active	No
IDE06705-MAS15001	Drivetrain coordinator: brake function status-ESP invokes TSK braking	No
IDE06705-MAS15002	Drivetrain coordinator: brake function status-EPB active	No
IDE06705-MAS15003	Drivetrain coordinator: brake function status-ASP intervention	No
IDE06705-MAS15004	Drivetrain coordinator: brake function status-ADS intervention	No
IDE06705-MAS15006	Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt	No
IDE06705-MAS15007	Drivetrain coordinator: brake function status-ESP sampled passive (ESP off)	No
IDE06705-MAS15008	Drivetrain coordinator: brake function status-ASR sampled passive (ASR off)	No
IDE06705-MAS15009	Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest	No
IDE06705-MAS15010	Drivetrain coordinator: brake function status-ACC stopping distance control active	No
IDE06706	ACC variants	ACC
IDE06707	CCS Switch	CCS operating unit
IDE06709	ACC variants (coding)	CCS
IDE06710	Cruise control system: permanent deactivation	No switch-off occurs
IDE06726	Timing deviation after chain replacement: intake bank 1	-1.44	 °
IDE06728	Timing deviation after chain replacement: exhaust bank 1	0	 °
IDE06730	Timing deviation after other repairs: intake bank 1	0	 °
IDE06732	Timing deviation after other repairs: exhaust bank 1	0	 °
IDE06734	Timing deviation: current value intake bank 1	0	 °
IDE06736	Timing deviation: current value exhaust bank 1	0	 °
IDE06738	Chain elongation: no. of valid initial values: intake bank 1	1
IDE06740	Chain elongation: no. of valid initial values: exhaust bank 1	0
IDE06742	Chain elongation: initial values valid: intake bank 1	not active
IDE06744	Chain elongation: initial values valid: exhaust bank 1	not active
IDE07001	Piston-cooling jets: activation	On
IDE07008	Tank leak: number no leak detected	19
IDE07011	Tank leak: number communication errors to engine control	6
IDE07014	Tank leak: number very small leaks detected	0
IDE07019	Number of ignitions direct injection	1026209
IDE07020	Number of ignitions intake manifold injection	0
IDE07023	Misfires per 1000 revolutions of cyl. 1 intake manif. injection	0
IDE07024	Misfires per 1000 revolutions of cyl. 2 intake manif. injection	0
IDE07025	Misfires per 1000 revolutions of cyl. 3 intake manif. injection	0
IDE07026	Misfires per 1000 revolutions of cyl. 4 intake manif. injection	0
IDE07027	Heat quantity that was transported via the catalytic converter	2.44E+08	 J
IDE07031	Oil pressure switch for piston-cooling jets: status	Open
IDE07242	Heater support pump: spec. value	10	 %
IDE07548	Engine temp. mangmt. actuator: specified value of angle	129.25	 °
IDE07549	Engine temp. mangmt. actuator: actual value of angle	128.78	 °
IDE07550	Engine temp. management actuator: raw value	2070
IDE07551	Engine temp. management actuator: duty cycle activation	0	 %
IDE07552	Engine temper.managem.actuator adaptation: result adaptation	Adaptation successfully finished
IDE07553	Engine temperature management actuator: after-run stop	3961
IDE07554	Engine temperature management actuator: stop open	141
IDE07564	Required torque adjustment by idling regulator	-2.8	 Nm
IDE07571	Engine torque	5.4	 Nm
IDE07572	High pressure regulation: adaptation value	-3.2	 mg
IDE07574	Long-term fuel trim bank 1 at idle	0.53	 mg/stroke
IDE07575	Driver request torque	1.2	 Nm
IDE07576	Lost torque adaptation driving mode	3.3	 Nm
IDE07577	Lost torque adaptation A/C compressor and driving mode	-6.8	 Nm
IDE07598-MAS00320	Cruise control switch actuation-Main switch	not activated
IDE07598-MAS00325	Cruise control switch actuation-Setting	not activated
IDE07598-MAS00326	Cruise control switch actuation-Activation	not activated
IDE07598-MAS01632	Cruise control switch actuation-Status	OK
IDE07598-MAS02309	Cruise control switch actuation-Accelerate	not activated
IDE07598-MAS02310	Cruise control switch actuation-Decelerate	not activated
IDE07598-MAS05172	Cruise control switch actuation-Cancel	not activated
IDE07598-MAS05806	Cruise control switch actuation-Main switch hardware	not activated
IDE07598-MAS05807	Cruise control switch actuation-Coding	plausible
IDE07598-MAS05809	Cruise control switch actuation-Limit function	not selected
IDE07598-MAS05812	Cruise control switch actuation-Limit button	not activated
IDE07598-MAS05813	Cruise control switch actuation-Main switch CAN	not activated
IDE07598-MAS05842	Cruise control switch actuation-Large increment	not activated
IDE07598-MAS05843	Cruise control switch actuation-Control component verified	Yes
IDE07599-MAS01505	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off	No
IDE07599-MAS03849	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal	No
IDE07599-MAS04795	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off	Yes
IDE07599-MAS05135	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected	No
IDE07599-MAS05136	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control	No
IDE07599-MAS05190	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated	No
IDE07599-MAS05192	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking	No
IDE07599-MAS05196	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error	No
IDE07599-MAS05814	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error	No
IDE07599-MAS05815	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error	No
IDE07599-MAS05816	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error	No
IDE07599-MAS05817	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation	No
IDE07599-MAS05818	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible	No
IDE07599-MAS05819	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking	No
IDE07599-MAS05820	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error	No
IDE07599-MAS05821	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak	No
IDE07599-MAS05822	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available	No
IDE07599-MAS05823	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization	No
IDE07599-MAS05824	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation	No
IDE07599-MAS05825	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault	No
IDE07599-MAS05826	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault	No
IDE07599-MAS05827	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met	No
IDE07599-MAS05828	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature	No
IDE07599-MAS05829	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault	No
IDE07599-MAS05830	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component	No
IDE07599-MAS05831	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component	No
IDE07599-MAS05832	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error	No
IDE07599-MAS05833	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error	No
IDE07599-MAS05834	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault	No
IDE07599-MAS05835	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault	No
IDE07599-MAS05836	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error	No
IDE07599-MAS05837	Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error	No
IDE07605	Cruise control system: temporary deactivation	No switch-off
IDE07669	Oxygen sensor 2 Bank 1 after cat operation readiness Status	active
IDE07901	Error counter bad fuel	0
IDE07904-ENG118117	Brake test switch status-actuated__activated	not activated
IDE07904-ENG114825	Brake test switch status-Ident_32	0
IDE07905-ENG118117	Brake light switch status-actuated__activated	not activated
IDE07905-ENG114825	Brake light switch status-Ident_32	0
IDE07906-ENG118117	Upper clutch switch: status-actuated__activated	not activated
IDE07906-ENG114825	Upper clutch switch: status-Ident_32	0
IDE07945-MAS00334	Status of intermittent monitoring-Catalytic converter monitoring	completed successfully
IDE07945-MAS00335	Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature	completed successfully
IDE07945-MAS00336	Status of intermittent monitoring-Monitoring of tank ventilation system	not completed successfully
IDE07945-MAS00337	Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system	completed successfully
IDE07945-MAS00338	Status of intermittent monitoring-Monitoring of A/C system refrigerant	completed successfully
IDE07945-MAS00339	Status of intermittent monitoring-Monitoring of oxygen sensor	completed successfully
IDE07945-MAS00340	Status of intermittent monitoring-Monitoring of oxygen sensor heater	completed successfully
IDE07945-MAS00341	Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR)	not completed successfully
IDE08071-ENG119931	Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1	0
IDE08072-ENG119932	Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2	0
IDE08073-ENG119933	Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3	0
IDE08074-ENG119934	Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4	0
IDE08075-ENG119935	Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5	0
IDE08495	Activation radiator shutter result	0	 %
IDE08805	EVAP valve diag. activation condition at minimal load	0.267	 counts
IDE08806	EVAP valve diag. activation condition at maximum load	613	 mbar
IDE10366	Chg. press. ctrl. valve: sensor voltage max. value	3.568	 V
IDE10380	Knock sensor average voltage bank 1	0.234	 V
IDE10551-MAS05304	Pre-ignition counter for oxygen shift-Cylinder 1	0
IDE10551-MAS05305	Pre-ignition counter for oxygen shift-Cylinder 2	0
IDE10551-MAS05306	Pre-ignition counter for oxygen shift-Cylinder 3	0
IDE10551-MAS05307	Pre-ignition counter for oxygen shift-Cylinder 4	0
IDE10551-MAS05308	Pre-ignition counter for oxygen shift-Cylinder 5	0
IDE10551-MAS05309	Pre-ignition counter for oxygen shift-Cylinder 6	0
IDE10551-MAS05310	Pre-ignition counter for oxygen shift-Cylinder 7	0
IDE10551-MAS05311	Pre-ignition counter for oxygen shift-Cylinder 8	0
IDE10552-MAS05304	Pre-ignition counter for torque reduction-Cylinder 1	0
IDE10552-MAS05305	Pre-ignition counter for torque reduction-Cylinder 2	0
IDE10552-MAS05306	Pre-ignition counter for torque reduction-Cylinder 3	0
IDE10552-MAS05307	Pre-ignition counter for torque reduction-Cylinder 4	0
IDE10552-MAS05308	Pre-ignition counter for torque reduction-Cylinder 5	0
IDE10552-MAS05309	Pre-ignition counter for torque reduction-Cylinder 6	0
IDE10552-MAS05310	Pre-ignition counter for torque reduction-Cylinder 7	0
IDE10552-MAS05311	Pre-ignition counter for torque reduction-Cylinder 8	0
IDE10553-MAS05304	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1	0
IDE10553-MAS05305	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2	0
IDE10553-MAS05306	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3	0
IDE10553-MAS05307	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4	0
IDE10553-MAS05308	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5	0
IDE10553-MAS05309	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6	0
IDE10553-MAS05310	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7	0
IDE10553-MAS05311	Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8	0
IDE10554-MAS05304	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1	0
IDE10554-MAS05305	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2	0
IDE10554-MAS05306	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3	0
IDE10554-MAS05307	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4	0
IDE10554-MAS05308	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5	0
IDE10554-MAS05309	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6	0
IDE10554-MAS05310	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7	0
IDE10554-MAS05311	Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8	0
IDE10922	Pump current of tank leakage diag.: corrected & filtered	0	 mA
IDE10970-MAS11563	Number of prevented stop processes-Engine hood open	0
IDE10970-MAS11835	Number of prevented stop processes-Function locked due to excessive stalling	0
IDE10970-MAS12085	Number of prevented stop processes-Brake pedal information: plausibility	0
IDE10989-MAS00106	Immobilizer: historic data-Year	2127
IDE10989-MAS00107	Immobilizer: historic data-Month	15
IDE10989-MAS00108	Immobilizer: historic data-Day	31
IDE10989-MAS00109	Immobilizer: historic data-Hours	31
IDE10989-MAS00110	Immobilizer: historic data-Minutes	63
IDE10989-MAS00111	Immobilizer: historic data-Seconds	63
IDE10989	Immobilizer: historic data	Engine hood open
IDE10989	Immobilizer: historic data	Brake pedal information: plausibility
IDE10989	Immobilizer: historic data	Function locked due to excessive stalling
IDE10994	Poor start counter at start-stop	0
IDE11115	Start/stop driver request: counter restart by starter	0
IDE11116	Start/stop driver request: counter internal-motor restart	0
IDE11598	Tank deaeration valve diagnosis: unweighted input value	0	 counts
IDE11599	Tank deaeration valve diagnosis: weighted output value	0	 counts
IDE11600	Tank tightness: ambient temperature	-48	 °C
IDE11919	Lock time for cooling down of secondary air pump	0	 s
IDE12137	Tank fill level diagnostic reference value	54	 l
IDE12138	Fuel consumption per driving cycle	92.52	 l/100km
ENG102981	AC compressor: speed increase	0
ENG103860	AC request: speed increase	0
ENG103042	Accelerator pedal sender: learned end stop	4.126	 V
ENG103719	Accelerator position	0	 %
ENG101488	ACF: load	0.064
ENG103474	Activation of oil pressure switching valve	0
ENG103323	Additional water pump	1
ENG101828	Air mass	6.31	 kg/h
ENG104264	Alternator load	350	 W
ENG103910	Ambient temperature	21	 °C
ENG112539	AR_THR_AD_ADD_MMV	-0.008	 cm²
ENG98377	As	none
ENG103165	Battery voltage	13.9	 V
ENG07601	Bypasstool_a2l_name	ORIGINAL A2L
ENG07600	Bypasstool_manipulation_bit	not active
ENG101413	Calibration Identification	8V0264M 0001AXAK
ENG99697	Calibration Verification Number	C8 7B A4 D6
ENG128780	CAM_DIF_VCP[EX_1]	0	 °
ENG128781	CAM_DIF_VCP[IN_1]	0	 °
ENG102002	CAM_OFS_IVVT_IN[1]	0	 °
ENG112540	CAM_PHA_ENG[GES_EX][CBK_1]	0	 °
ENG112541	CAM_PHA_ENG[GES_IN][CBK_1]	0	 °
ENG101169	CAM_PHA_OFS_MAF[IN][1]	0	 °
ENG112542	CAM_SP_IND_VCP[EX_1]	0	 °
ENG112543	CAM_SP_IND_VCP[IN_1]	0	 °
ENG112544	CAM_VCP[EX_1]	0	 °
ENG112545	CAM_VCP[IN_1]	0	 °
ENG103849	Cat. ageing: bank 1: actual	0.016
ENG101785	Cat. temperature: bank 1	563.2875	 °C
ENG102214	CPU_LOAD	46.8	 %
ENG125189	CTR_CAM_IN_SP_PI_DET_REQ[0]	0
ENG125190	CTR_CAM_IN_SP_PI_DET_REQ[1]	0
ENG125191	CTR_CAM_IN_SP_PI_DET_REQ[2]	0
ENG125192	CTR_CAM_IN_SP_PI_DET_REQ[3]	0
ENG101127	CTR_CDN_OBD_RBM	6
ENG114826	CTR_EDGE_CAM_EX[1]	0
ENG114827	CTR_EDGE_CAM_IN[1]	11
ENG100536	CTR_IGK_CYC_RBM	124
ENG125193	CTR_LAMB_SP_PI_REQ[0]	0
ENG125194	CTR_LAMB_SP_PI_REQ[1]	0
ENG125195	CTR_LAMB_SP_PI_REQ[2]	0
ENG125196	CTR_LAMB_SP_PI_REQ[3]	0
ENG112554	CTR_MIS_DC_MMV_CYL_SAE[0]	0
ENG112555	CTR_MIS_DC_MMV_CYL_SAE[1]	0
ENG112556	CTR_MIS_DC_MMV_CYL_SAE[2]	0
ENG112557	CTR_MIS_DC_MMV_CYL_SAE[3]	1
ENG112558	CTR_MIS_TOT_NVMY_SAE	120
ENG125197	CTR_REQ_IV_OFF_PI_FAST[0]	0
ENG125198	CTR_REQ_IV_OFF_PI_FAST[1]	0
ENG125199	CTR_REQ_IV_OFF_PI_FAST[2]	0
ENG125200	CTR_REQ_IV_OFF_PI_FAST[3]	0
ENG125201	CTR_REQ_IV_OFF_PI_SLOW[0]	0
ENG125202	CTR_REQ_IV_OFF_PI_SLOW[1]	0
ENG125203	CTR_REQ_IV_OFF_PI_SLOW[2]	0
ENG125204	CTR_REQ_IV_OFF_PI_SLOW[3]	0
ENG128782	CTR_REQ_IV_OFF_PI_SLOW_TMP[0]	0
ENG128783	CTR_REQ_IV_OFF_PI_SLOW_TMP[1]	0
ENG128784	CTR_REQ_IV_OFF_PI_SLOW_TMP[2]	0
ENG128785	CTR_REQ_IV_OFF_PI_SLOW_TMP[3]	0
ENG100764	CTR_SUM_SRV_INTL	0
ENG125205	CTR_TQI_POW_MAX_PI_REQ[0]	0
ENG125206	CTR_TQI_POW_MAX_PI_REQ[1]	0
ENG125207	CTR_TQI_POW_MAX_PI_REQ[2]	0
ENG125208	CTR_TQI_POW_MAX_PI_REQ[3]	0
ENG119929	CTR_VLD_CAT_GAP_AFL[1]	0
ENG119930	CTR_VLD_CAT_GAP_AFR[1]	0
ENG99428	CTR_VLFT_1_SWI_NOT[0]	0
ENG103626	CTR_VLFT_1_SWI_NOT[1]	0
ENG100809	CTR_VLFT_1_SWI_NOT[2]	0
ENG99336	CTR_VLFT_1_SWI_NOT[3]	0
ENG103025	CTR_VLFT_STND_SWI_NOT[0]	0
ENG100017	CTR_VLFT_STND_SWI_NOT[1]	0
ENG100438	CTR_VLFT_STND_SWI_NOT[2]	0
ENG100736	CTR_VLFT_STND_SWI_NOT[3]	0
ENG112559	CTR_VVL_LIH_ACT	0
ENG101271	CTR_VVL_LIH_DEAC	0
ENG100551	CTR_VVL_SWI_DC	0
ENG99561	CTR_VVL_SWI_H	0
ENG101173	CTR_VVL_SWI_L	8
ENG99084	Cycle flags: (completed cycles): cat: lambda probe heater	9
ENG100943	Cycle flags: (completed cycles): lambda probes: EGR	0
ENG99495	Cycle flags: (completed tests): lambda adaption:	8
ENG103597	Cycle flags:(completed cycles):lambda probes:sec.air sys.	48
ENG101652	Cylinder shut-off: cylinder suppression	0
ENG102657	DIAG_INST[0]	NO_ERROR
ENG99120	DIAG_INST[1]	NO_ERROR
ENG103260	DIAG_INST[2]	NO_ERROR
ENG99710	DIAG_INST[3]	NO_ERROR
ENG102667	DIAG_INST[4]	NO_ERROR
ENG102739	DIAG_INST[5]	NO_ERROR
ENG100162	DIAG_INST[6]	NO_ERROR
ENG99103	DIAG_INST[7]	NO_ERROR
ENG99261	DIAG_INST[8]	NO_ERROR
ENG103622	DIAG_INST[9]	NO_ERROR
ENG112560	DIST_ACT_MIL_SAE	0	 km
ENG112561	DIST_DTC_CLR_SAE	121	 km
ENG103766	DIST_ENG_RUN_IN	138386.7	 m
ENG100531	DIST_ST	138400	 m
ENG100131	ECU_STATE	SYN_ENG_IGK_ON
ENG100152-ENG104003	ECUNAME-ECU	ECM
ENG100152	ECUNAME	EngineControl
ENG103712	EFPPWM_MIN_AD	0	 %
ENG104044	Engine load	8.984375	 %
ENG102494	Engine speed: actual	704	 /min
ENG102783	Engine: operating status	IS
ENG103667	ENVD_0_MON	0
ENG100777	ENVD_0_MON_3	0
ENG126934	ENVD_0_MON_3_VD	0
ENG99424	ENVD_1_MON	0
ENG100344	ENVD_1_MON_3	0
ENG126935	ENVD_1_MON_3_VD	0
ENG99790	ENVD_2_MON	0
ENG100541	ENVD_2_MON_3	0
ENG126936	ENVD_2_MON_3_VD	0
ENG99455	ENVD_3_MON	0
ENG101268	ENVD_3_MON_3	0
ENG126937	ENVD_3_MON_3_VD	0
ENG01743	ENVD_4_MON	0
ENG01744	ENVD_5_MON	0
ENG01745	ENVD_6_MON	0
ENG99752	Error flags: (completed cycles): cat: lambda probe heater	0
ENG101275	Error flags: (completed cycles): lambda probes: EGR	0
ENG104132	Error flags: (completed cycles): lambda probes:sec.air sys.	0
ENG101942	ESI (extended service intervals) oil warning threshold	53.8125	 mm
ENG112562	FAC_AR_THR_AD	0	 %
ENG104194	FAC_H_RNG_LAM_AD[1]	0	 %
ENG104151	FAC_L_RNG_LAM_AD[1]	-1.772	 %
ENG100298	FAC_LAM_CP	-12.939	 %
ENG100108	FAC_LAM_LIM[1]	-13.141	 %
ENG99722	FAC_LAM_TCO_A[1]	0	 %
ENG103521	FAC_LAM_TCO_B[1]	0	 %
ENG103641	FAC_LAM_TCO_C[1]	0	 %
ENG101578	FAC_LAM_TCO_D[1]	0	 %
ENG100685	FAC_LAM_TCO_E[1]	0	 %
ENG103307	FAC_MAF_MAX	0.26297
ENG99791	FAC_SLOP_IV[1]	0
ENG102306	FAC_TPS_1_SAE	11.71875	 %
ENG102292	FAC_TPS_1_SAE	11.71875	 %
ENG99630	Fan control relay: fan run-on	2
ENG101437	Fan request from air conditioner	0	 %
ENG103644	FRF_IMMO_SNAPSHOT_BYTE1	0
ENG102892	FRF_IMMO_SNAPSHOT_BYTE2	0
ENG100521	FRF_IMMO_SNAPSHOT_BYTE3	0
ENG101852	FRF_IMMO_SNAPSHOT_BYTE4	0
ENG99312	FRF_IMMO_SNAPSHOT_BYTE5	0
ENG103956	FRF_IMMO_SNAPSHOT_BYTE6	0
ENG128786	FTL_SAE	92.15686426	 %
ENG104248	Fuel consumption signal	11474	 µl
ENG101667	Fuel pump: adaption value	0	 %
ENG100969	Fuel pump: fuel pressure: I-controller	0	 %
ENG100250	Fuel regulating valve: duty cycle	15.39	 %
ENG101692	Fuel supply system: high-pressure regulator	344.588	 hPa
ENG114828	FUP_EFP_MES	11000.8	 hPa
ENG103553	FUP_EFP_ST_H	0	 hPa
ENG101056	FUP_EFP_ST_L	0	 hPa
ENG99950	FUP_EFP_STOP_H	0	 hPa
ENG100784	FUP_EFP_STOP_L	0	 hPa
ENG102108	FUP_H	45192	 hPa
ENG112563	FUP_H_SAE	4420	 kPa
ENG103368	Gearbox -CAN bus messages	126839
ENG99170	Height correction	981.25	 hPa
ENG103575	High-pressure system: regulator	-0.55	 mg
ENG103879	High-pressure system: regulator: mobile part	2.46	 mg
ENG102603	High-pressure system: status	MFP_CTL
ENG101567	Idling speed stabilisation: duty cycle/AC compressor torque	0.5	 Nm
ENG101946	Idling stabilisation: operating status	0
ENG100345	IGA_ADJ_KNK[0]	0	 °
ENG103593	IGA_ADJ_KNK[1]	0	 °
ENG103360	IGA_ADJ_KNK[2]	0	 °
ENG99404	IGA_ADJ_KNK[3]	0	 °
ENG100425	IGA_IGC[0]	-6	 °
ENG101655	IGA_IGC[1]	-6.375	 °
ENG100410	IGA_IGC[2]	-5.25	 °
ENG100407	IGA_IGC[3]	-4.5	 °
ENG112564	IGA_IGC_SAE	-3.5	 °
ENG101741	Intake air temperature	44.25	 °C
ENG100634	In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1	6	 counts
ENG125209	KNKS_ERR_REL[0]	0.0977	 V
ENG99741	LAMB_DELTA_AD_LAM_ADJ[1]	0.00006
ENG99601	LAMB_DELTA_I_LAM_ADJ[1]	0.00006
ENG112565	LAMB_DELTA_SUM_LAM_ADJ_AD[1]	0.00006
ENG99674	Lambda controller: bank 1 (averaged value)	-12.929	 %
ENG101381	Lambda probe 1: bank 1: status	1
ENG101039	Lambda probe 1: bank 1: status	0
ENG102886	Lambda probe 1: bank 1: status	0
ENG104200	Lambda probe 2: bank 1: status	0
ENG101336	Lambda probe 2: bank 1: status	1
ENG99661	Lambda probe ageing: bank 1: dynamic factor	0
ENG101869	Lambda probe ageing: bank 1: probe 1: short trip result	311.85	 °C
ENG100478	Lambda probe correction: duty cycle offset: bank 1	-0.00592
ENG103776	Lambda probe heater: bank 1: probe 2: short trip result	0
ENG102380	Lambda probe heater: resistance: bank 1: probe 2	328	 Ohm
ENG99353	Lambda probe voltage: bank 1: probe 1 (broadband probe)	1.987	 V
ENG102763	Lambda probes actual: bank1	1.0107
ENG104114	Lambda probes specified: bank1	1.0029
ENG06592	LF_COSI_CTL_ERR_A	0
ENG06593	LF_COSI_CTL_ERR_B	0
ENG112566	LF_DPS_CYC_ERR_RAW_BSW[1]	16384
ENG112567	LF_DPS_CYC_ERR_RAW_BSW[2]	16384
ENG112568	LF_DPS_CYC_ERR_VLD_BSW[1]	65535
ENG112569	LF_DPS_CYC_ERR_VLD_BSW[2]	65535
ENG112570	LF_DPS_INI_ERR_RAW_BSW[1]	0
ENG112571	LF_DPS_INI_ERR_RAW_BSW[2]	0
ENG112572	LF_IV_ERR_RAW_BSW[0]	0
ENG112573	LF_IV_ERR_RAW_BSW[1]	0
ENG112574	LF_IV_ERR_RAW_BSW[2]	0
ENG112575	LF_IV_ERR_RAW_BSW[3]	0
ENG112576	LF_IV_ERR_VLD_BSW[0]	8191
ENG112577	LF_IV_ERR_VLD_BSW[1]	8191
ENG112578	LF_IV_ERR_VLD_BSW[2]	8191
ENG112579	LF_IV_ERR_VLD_BSW[3]	8191
ENG101645	LF_VVL_DIAG_SWI_NOT	0
ENG127734-MAS00106	Life_cycle_data_start_requirement_development-Year	2127
ENG127734-MAS00107	Life_cycle_data_start_requirement_development-Month	15
ENG127734-MAS00108	Life_cycle_data_start_requirement_development-Day	31
ENG127734-MAS00109	Life_cycle_data_start_requirement_development-Hours	31
ENG127734-MAS00110	Life_cycle_data_start_requirement_development-Minutes	63
ENG127734-MAS00111	Life_cycle_data_start_requirement_development-Seconds	63
ENG127734	Life_cycle_data_start_requirement_development	Steering
ENG127734	Life_cycle_data_start_requirement_development	Quattro Sport
ENG127734	Life_cycle_data_start_requirement_development	Multifunction unit control module
ENG127734	Life_cycle_data_start_requirement_development	Parking aid
ENG127734	Life_cycle_data_start_requirement_development	brakes
ENG127734	Life_cycle_data_start_requirement_development	Immobilizer
ENG127734	Life_cycle_data_start_requirement_development	Kessy
ENG127734	Life_cycle_data_start_requirement_development	Engine
ENG127734	Life_cycle_data_start_requirement_development	Level control system
ENG127734	Life_cycle_data_start_requirement_development	ACC
ENG127734	Life_cycle_data_start_requirement_development	Front sensor system for driver assistance systems
ENG127734	Life_cycle_data_start_requirement_development	All-wheel electronics
ENG127734	Life_cycle_data_start_requirement_development	12 V electrical system
ENG127734	Life_cycle_data_start_requirement_development	Transmission
ENG127734	Life_cycle_data_start_requirement_development	Front axis lift system
ENG127734	Life_cycle_data_start_requirement_development	A/C
ENG127734	Life_cycle_data_start_requirement_development	Convertible top control module
ENG127735-MAS00106	Life_cycle_data_stop_prohibition_development-Year	2127
ENG127735-MAS00107	Life_cycle_data_stop_prohibition_development-Month	15
ENG127735-MAS00108	Life_cycle_data_stop_prohibition_development-Day	31
ENG127735-MAS00109	Life_cycle_data_stop_prohibition_development-Hours	31
ENG127735-MAS00110	Life_cycle_data_stop_prohibition_development-Minutes	63
ENG127735-MAS00111	Life_cycle_data_stop_prohibition_development-Seconds	63
ENG127735	Life_cycle_data_stop_prohibition_development	Engine
ENG127735	Life_cycle_data_stop_prohibition_development	A/C
ENG127735	Life_cycle_data_stop_prohibition_development	Convertible top control module
ENG127735	Life_cycle_data_stop_prohibition_development	Steering
ENG127735	Life_cycle_data_stop_prohibition_development	Multifunction unit control module
ENG127735	Life_cycle_data_stop_prohibition_development	Parking aid
ENG127735	Life_cycle_data_stop_prohibition_development	ACC
ENG127735	Life_cycle_data_stop_prohibition_development	12 V electrical system
ENG127735	Life_cycle_data_stop_prohibition_development	Transmission
ENG127735	Life_cycle_data_stop_prohibition_development	Front axis lift system
ENG127735	Life_cycle_data_stop_prohibition_development	Quattro Sport
ENG127735	Life_cycle_data_stop_prohibition_development	Level control system
ENG127735	Life_cycle_data_stop_prohibition_development	Front sensor system for driver assistance systems
ENG127735	Life_cycle_data_stop_prohibition_development	All-wheel electronics
ENG127735	Life_cycle_data_stop_prohibition_development	brakes
ENG127735	Life_cycle_data_stop_prohibition_development	Immobilizer
ENG127735	Life_cycle_data_stop_prohibition_development	Kessy
ENG127733-MAS00106	Life_cycle_data_system_failure-Year	2127
ENG127733-MAS00107	Life_cycle_data_system_failure-Month	15
ENG127733-MAS00108	Life_cycle_data_system_failure-Day	31
ENG127733-MAS00109	Life_cycle_data_system_failure-Hours	31
ENG127733-MAS00110	Life_cycle_data_system_failure-Minutes	63
ENG127733-MAS00111	Life_cycle_data_system_failure-Seconds	63
ENG127733	Life_cycle_data_system_failure	Quattro Sport
ENG127733	Life_cycle_data_system_failure	Steering
ENG127733	Life_cycle_data_system_failure	Immobilizer
ENG127733	Life_cycle_data_system_failure	Kessy
ENG127733	Life_cycle_data_system_failure	Engine
ENG127733	Life_cycle_data_system_failure	Multifunction unit control module
ENG127733	Life_cycle_data_system_failure	Parking aid
ENG127733	Life_cycle_data_system_failure	12 V electrical system
ENG127733	Life_cycle_data_system_failure	Transmission
ENG127733	Life_cycle_data_system_failure	Convertible top control module
ENG127733	Life_cycle_data_system_failure	A/C
ENG127733	Life_cycle_data_system_failure	Level control system
ENG127733	Life_cycle_data_system_failure	ACC
ENG127733	Life_cycle_data_system_failure	Front sensor system for driver assistance systems
ENG127733	Life_cycle_data_system_failure	All-wheel electronics
ENG127733	Life_cycle_data_system_failure	brakes
ENG127733	Life_cycle_data_system_failure	Front axis lift system
ENG122701	LMVDes_st_Mod_Out_VW	8
ENG122702	LMVDes_v_Max_Man_Lim_VW	511.992	 km/h
ENG122703	LMVLim_v_Auth_Max_Out_VW	200	 km/h
ENG100402	LOIL_SUM_SRV_INTL	0	 mm
ENG99162	LV_ACC_RED_CMD	0
ENG102235	LV_ATB_ACT_1	0
ENG102541	LV_ATB_ACT_2	0
ENG114829	LV_BPA_LIH_REQ[0]	0
ENG99095	LV_CAN_HOOD_SWI	1
ENG128787	LV_CMD_RCL_OPEN	0
ENG128788	LV_ECRAS_FB_DIAG_POS_RESP[0]	0
ENG103049	LV_EFPPWM_AD_STOP	1
ENG101712	LV_ENG_RUN_IN	1
ENG100267	LV_ENG_RUN_IN_EXT_ADJ	0
ENG103319	LV_ERR_VLFT_1_SWI[1]	0
ENG103549	LV_ERR_VLFT_1_SWI[2]	0
ENG103191	LV_ERR_VLFT_1_SWI[3]	0
ENG101989	LV_ERR_VLFT_1_SWI[4]	0
ENG102313	LV_ERR_VLFT_STND_SWI[1]	0
ENG103044	LV_ERR_VLFT_STND_SWI[2]	0
ENG103443	LV_ERR_VLFT_STND_SWI[3]	0
ENG100487	LV_ERR_VLFT_STND_SWI[4]	0
ENG112471	LV_IGK	1
ENG103773	LV_INH_STR_RLY	0
ENG100044	LV_LOIL_L_WARN	0
ENG103492	LV_LOIL_L_WARN_ACT	0
ENG103908	LV_LOIL_L_WARN_TMP	0
ENG103716	LV_POIL_SWI_H	1
ENG100912	LV_POIL_SWI_L	1
ENG112586	LV_PWR_RLY[0]	1
ENG102417	LV_TPS_AD_ACT	0
ENG100842	LV_TPS_AD_DIAG_ERR	0
ENG103996	LV_TPS_AD_REQ	0
ENG112587	LV_VCP_AD_END	1
ENG102523	MAF	108.71	 mg/stroke
ENG99288	MAF_DIF_CAM_OFS_AD_SQ_TOT	0	 kg²/h²
ENG112588	MAP_MES_SAE	36	 kPa
ENG103501	MASS_SA_REL[0]	0
ENG100896	MASS_SA_REL_21_PHA	0
ENG103045	MASS_SA_REL_22_PHA	0
ENG103346	MFF_ADD_LAM_AD[1]	0.53	 mg/stroke
ENG126493	MFF_MPL_ADD_LAM_AD[1][1]	0.53	 mg/stroke
ENG101360	Misfire detection active	0
ENG102335	Misfires all cylinders per 1000 rpm	0
ENG128796	N_SP_IS_CLC	700	 /min
ENG103004	N_TCHA	15045.2	 /min
ENG112590	N_TOOTH	715	 /min
ENG107737-ENG112538	NC_NR_DIAG_RBM-NC Value	154
ENG126111	NL_PRE[0]	0.15327	 V
ENG126112	NL_PRE[1]	0.16365	 V
ENG126113	NL_PRE[2]	0.14938	 V
ENG126114	NL_PRE[3]	0.1722	 V
ENG128789	NR_CYC_AD_DC_BAL_HOM[RNG_H]	0
ENG128790	NR_CYC_AD_DC_BAL_HOM[RNG_IS]	0
ENG128791	NR_CYC_AD_DC_BAL_HOM[RNG_L]	0
ENG128792	NR_CYC_AD_DIAG_BAL_HOM[0]	0
ENG128793	NR_CYC_AD_DIAG_BAL_HOM[1]	0
ENG128794	NR_CYC_AD_DIAG_BAL_HOM[2]	0
ENG128795	NR_CYC_AD_DIAG_BAL_HOM[3]	0
ENG112589	NR_CYL_FIRST_VVL_SWI	0
ENG99776	NR_CYL_VVL_H_ACK	4
ENG119936	O2L_MAX_CAT_GAP_AFL_MV[1]	0	 g
ENG119937	O2L_MAX_CAT_GAP_AFR_MV[1]	0	 g
ENG99157	PRS_SA_DIF	0	 hPa
ENG02464	PRS_UP_THR_MES	980.75	 hPa
ENG112591	PSN_EDGE_REL_AD_CAM_EX[1][1]	0	 °
ENG112592	PSN_EDGE_REL_AD_CAM_IN[1][1]	-0.25	 °
ENG114830	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1]	0	 °
ENG114831	PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2]	0	 °
ENG114832	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1]	-0.25	 °
ENG114833	PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2]	-1.625	 °
ENG128797	PV	0	 %
ENG102195	PV_AV_1	0	 %
ENG99137	PV_AV_2	0	 %
ENG101068	PV_AV_H	0	 %
ENG112593	PWM_ACT_VCP[EX_1]	90.002	 %
ENG112594	PWM_ACT_VCP[IN_1]	90.002	 %
ENG101350	PWM_ETC	-12.546	 %
ENG112595	PWM_HLD_VCP[EX_1]	14.923	 %
ENG112596	PWM_HLD_VCP[IN_1]	10.077	 %
ENG112597	PWM_PAS_VCP[EX_1]	10.236	 %
ENG112598	PWM_PAS_VCP[IN_1]	10.077	 %
ENG101201	Radiator fan 1: run-on: status	600W
ENG102359	Radiator fan 2: run-on: status	NO_ECF
ENG119939	RATIO_O2L_LIM_CAT_GAP_AFL_MV[1]	0
ENG119940	RATIO_O2L_LIM_CAT_GAP_AFR_MV[1]	0
ENG102377	Ready and error flags	4
ENG112599	RVC_AV	128.78	 °
ENG112601	RVC_SP	128.5	 °
ENG112600	RVCPWM	0	 %
ENG103248	SEG_AD_MMV_ER[0]	0	 ‰
ENG101135	SEG_AD_MMV_ER[1]	0.4027	 ‰
ENG99078	SEG_AD_MMV_ER[2]	-0.0865	 ‰
ENG103257	SEG_AD_MMV_ER[3]	0.4614	 ‰
ENG102511	SEG_AD_MMV_ER_H[0]	0	 ‰
ENG103258	SEG_AD_MMV_ER_H[1]	0.6588	 ‰
ENG99291	SEG_AD_MMV_ER_H[2]	-0.0665	 ‰
ENG99954	SEG_AD_MMV_ER_H[3]	0.7043	 ‰
ENG100568	SEG_AD_MMV_ER_L[0]	0	 ‰
ENG100601	SEG_AD_MMV_ER_L[1]	0.4027	 ‰
ENG102668	SEG_AD_MMV_ER_L[2]	-0.0865	 ‰
ENG101232	SEG_AD_MMV_ER_L[3]	0.4614	 ‰
ENG101561	SEG_AD_MMV_ER_MID[0]	0	 ‰
ENG102964	SEG_AD_MMV_ER_MID[1]	0.6271	 ‰
ENG100890	SEG_AD_MMV_ER_MID[2]	-0.0624	 ‰
ENG99793	SEG_AD_MMV_ER_MID[3]	0.6712	 ‰
ENG103381	Shut-off time	3.5	 s
ENG109006-ENG100882	Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX	15	 %
ENG109007-ENG99938	Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX	0	 %
ENG102971	Start adaption: temperature adaption factor 1	1
ENG102489	Start adaption: temperature adaption factor 2	1
ENG100723	Start adaption: temperature adaption factor 3	1
ENG100919	Starter control: interlock switch	0
ENG100800	Starter: start relay 1	0
ENG99979	Starter: start relay 2	0
ENG102033	STATE_BPA[0]	OPM
ENG102127	STATE_COMC_NVLD	Wait
ENG112602	STATE_CRK_STST	CRK_STST_ACQ_SHO_LEVEL
ENG114834	STATE_CRU_OFF_IRR_CUS	0
ENG114835	STATE_CRU_OFF_REV_CUS	18415680
ENG112603	STATE_EOL_VVL	DEAC
ENG112605	STATE_LS_SAE[1]	CL
ENG104238	STATE_NVLD	COMPLETE_DIAG
ENG112606	STATE_PWM_VCP[EX_1]	pas
ENG112607	STATE_PWM_VCP[IN_1]	HLD
ENG101078	STATE_READY_OBD_1	7
ENG100369	STATE_READY_OBD_3	0
ENG100342	STATE_REQ_NVLD	NO_REQ
ENG109090	STATE_SW_MVB	SC8S5010 CBS00I0
ENG128798	STATE_T_ES_RD	0
ENG128799	STATE_T_ES_VLD_RD	1
ENG112608	STATE_VCP	ACT_ADAPT
ENG114836	STATE_VCV_CLOSE_SL	AD_ON
ENG103723	STATE_VVL_MNG	VVL_H
ENG112609	T_ACT_MIL_SAE	0	 min
ENG112494	T_AST_SAE	173	 s
ENG104148	T_COOL_LOIL	454.8	 ms
ENG112613	T_DTC_CLR_SAE	254	 min
ENG102790	T_EFP_MEM_H	0	 s
ENG102123	T_EFP_MEM_L	0	 s
ENG109299	T_ES	0	 min
ENG112615	T_ES_CNT	0
ENG112616	T_ES_DC	3	 min
ENG99463	T_ES_H	0	 s
ENG128802	T_IGK	176.55	 s
ENG99398	T_POP_COC_INTER_1	0	 s
ENG102747	T_PWL	0	 s
ENG128803	T_PWL_CAN	37.6	 s
ENG112636	T_SWI_VVL_ACR	69.4	 ms
ENG101325	T_TEMP_SIG_LOIL	56.3	 ms
ENG99126	T_VS_TOL_LOCK	0	 min
ENG125440	TAA	21	 °C
ENG102048	Tank breather valve: duty cycle	21.09375	 %
ENG101339	Tank breather valve: short trip result	0.5452	 kg/h
ENG100439	Tank level	0
ENG112610	TCO_1_FIRST_ST	76	 °C
ENG112611	TCO_1_ST	76	 °C
ENG112612	TCO_1_SYS	98	 °C
ENG103434	TCO_A_LAM_AD_WUP[1]	-5.25	 °C
ENG100381	TCO_B_LAM_AD_WUP[1]	9.75	 °C
ENG101581	TCO_C_LAM_AD_WUP[1]	24.75	 °C
ENG100354	TCO_D_LAM_AD_WUP[1]	35.25	 °C
ENG101973	TCO_E_LAM_AD_WUP[1]	45	 °C
ENG128800	TCO_MDL[STUCK_L_COOL_MON]	53.289	 °C
ENG124460	TCO_MDL[TH]	64.031	 °C
ENG100390	TCO_MIN_INTER_LAM_AD_WUP[1]	97.5	 °C
ENG100853	TCO_MIN_LAM_AD_WUP[1]	50.25	 °C
ENG102279	TCS/ESP: specified torque	23.75	 Nm
ENG99857	TCS: status	0
ENG110436	TEG_DYN_LS_DOWN[1]	481.1625	 °C
ENG110437	TEG_DYN_LS_UP[1]	408.6625	 °C
ENG101941	TEMP_CAT_STAT_MDL[1]	437.6	 °C
ENG112614	TEMP_CAT_UP_1_SAE	529.7	 °C
ENG114837	TFPA	80	 °C
ENG114838	TFU_HPP	66	 °C
ENG99608	Throttle valve adjuster: adaption status	ST_CHK_END
ENG101411	Throttle valve angle	1.736	 °
ENG102845	Throttle valve deviation	1.547	 %
ENG126115	TI_1_MES_MPI[0]	0	 ms
ENG126116	TI_1_MES_MPI[1]	0	 ms
ENG126117	TI_1_MES_MPI[2]	0	 ms
ENG126118	TI_1_MES_MPI[3]	0	 ms
ENG126119	TI_MES_4[PLS_1][0]	0.876	 ms
ENG126120	TI_MES_4[PLS_1][1]	0.832	 ms
ENG126121	TI_MES_4[PLS_1][2]	0.844	 ms
ENG126122	TI_MES_4[PLS_1][3]	0.944	 ms
ENG126123	TI_MES_4[PLS_2][0]	0	 ms
ENG126124	TI_MES_4[PLS_2][1]	0	 ms
ENG126125	TI_MES_4[PLS_2][2]	0	 ms
ENG126126	TI_MES_4[PLS_2][3]	0	 ms
ENG126127	TI_MES_4[PLS_3][0]	0	 ms
ENG126128	TI_MES_4[PLS_3][1]	0	 ms
ENG126129	TI_MES_4[PLS_3][2]	0	 ms
ENG126130	TI_MES_4[PLS_3][3]	0	 ms
ENG128801	TIA_CHA_DOWN_MV	55.77	 °C
ENG125276	TIG_MES_SAE[IM]	45	 °C
ENG103351	Time since engine start	179.2	 s
ENG112634	TLTS_MES[TCE]	98.555	 °C
ENG112635	TMAG_VCP	78	 °C
ENG110444	TPS_AD_CDN_MIS	32
ENG114839	TPS_ETC	1.736	 °
ENG99274	TPS_SP	1.729	 °
ENG103021	TQ_CONV	4	 Nm
ENG128804	TQI_ADD_ACT	29.84375	 Nm
ENG101426	TQI_GS_FAST_INC	0	 Nm
ENG128805	TQI_N_TCHA_MAX	1023.96875	 Nm
ENG102329	TTIP_MES_LS_UP[1]	785	 °C
ENG100355	V_FUP_EFP_MV	4.995	 V
ENG100739	V_PVS_1_BAS	0.7959	 V
ENG114840	V_PVS_KD	0	 V
ENG99514	VBOOST	64.5	 V
ENG103201	VCV_CLOSE_RNG	25.5	 °
ENG102311	Vehicle speed: filtered	0	 km/h
ENG122704	VLCAvl_st_Pt_VW	4
ENG122705	VLCReq_st_Dem_VW	0
ENG112639	VLS_DOWN_SAE[1]	0.78	 V
ENG128806	VOL_FLOW_CHA_UP_RED_MV	0.001526	 m³/s
ENG101929	VP_TPS_1	0.5859	 V
ENG102985	VP_TPS_2	4.4043	 V
ENG100421	VP_TPS_AD_EL_BOL_1	0.5029	 V
ENG103444	VP_TPS_AD_EL_BOL_2	4.4876	 V
ENG101674	VP_TPS_AD_LIH_1	0.791	 V
ENG99507	VP_TPS_AD_LIH_2	4.1992	 V
Elapsed Time: 01:06
blockmap-OBD_3VWH17AU5JM758941-20180826-1121.CSV
;33-OBD2
;Sunday	26	August	2018	11:21:36:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 70BADAA93A23EF57612-8024
3	Fuel system 1/2 status	Engine off	Engine off
4	Calculated load value	0.00%
5	Engine coolant temperature	77 °C
6	Short Term Trim - Bank 1	0.00%
7	Long Term Trim - Bank 1	4.70%
0B	Intake Manifold Absolute Pressure	98 kPa abs
0C	Engine RPM	0 /min
0D	Vehicle speed	0 km/h
0E	Ignition timing advance for cyl #1	-1.0 Degrees
0F	Intake air temperature	54 °C
11	Throttle position sensor	15.30%
12	Secondary Air Status	Atmosphere/off
13	Location of O2 sensors	B1S1 B1S2
15	Bank 1 Sensor 2 Status	1.275 V
1C	OBD Requirements Met	OBD + OBD II
1F	Time since engine start	0 s
21	Distance travelled with MIL on	0 km
23	Fuel Rail Press (rel)	3010 kPa rel
2E	Commanded Evaporative Purge	0.00%
2F	Fuel Level Input	92.20%
30	Warm-ups since DTC cleared	22
31	Distance since DTC cleared	121 km
33	Barometric pressure	98 kPa abs
34	Bank 1 Sensor 1 Status	0.000 Lambda	-128.000 mA
3C	B1S1 Cat. Temp.	225.0 °C
42	Control module voltage	14.433 V	14.000 V
43	Absolute Load Value	0%
44	Commanded Equivalence Ratio	1.000 Lambda
45	Relative Throttle Position	5%
46	Ambient Air Temp	24 °C
47	Absolute Throttle Position B	16%
49	Accelerator Pedal Position D	16%	16%
4A	Accelerator Pedal Position E	15%
4C	Commanded Throttle Actuator Control	5%
51	Fuel type	Gasoline
56	Long term sec. O2 trim bank 1/3	0.00%
70	Boost Press Ctrl A/B	BP_A act:98 kPa
Mode 9 : Calibration Identification
Type 02 - VIN : 3VWH17AU5JM758941 (Address E8)
Type 04 - Calibration ID : 8V0264M 0001AXAK (Address E8)
Type 04 - Calibration ID : 0D9300018   5201 (Address E9)
Type 06 - Calibration Verification Number : C87BA4D6 (Address E8)
Type 06 - Calibration Verification Number : 0000F57F (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 6
    Ignition cycle count : 123
    Conditions completion count / Specified conditions encountered count
         Catalyst monitor bank 1 : 5 / 6
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 7 / 6
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 26 / 6
         AIR monitor : 32 / 3
         EVAP monitor : 9 / 3
         Secondary O2 Sensor monitor bank 1 : 4 / 6
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Dana
Western PA, USA
02-Auto Trans
adpmap-02-0D9-300-018_3VWH17AU5JM758941-20180826-1115.CSV
KOEO
;SW:0D9-300-018   HW:02E-927-770-AS ---  Auto Trans
;Component:DQ250-6A MQB  H54 5201	 Coding:0014
;EV_TCMDQ250021	1001	EV_TCMDQ250021.rod
;Sunday	26	August	2018	11:15:16:04045
;VCID: 59EC870DC9998E1FB6C-800C
IDE06425-Roller test bench mode: functional	not activated 	1
Elapsed Time: 00:00
blockmap-02-0D9-300-018_3VWH17AU5JM758941-20180826-1114.CSV
KOEO
;Sunday	26	August	2018	11:14:55:04045
Group	Description	Actual
IDE00018	Voltage terminal 15	14	 V
IDE00019	Voltage terminal 30	14	 V
IDE00021-ENG99543	Engine speed-Engine RPM	0	 /min
IDE00022-ENG103074	Transmission input speed-Transmission Input Speed Sensor	0	 /min
IDE00024	Transmission fluid temperature	59	 °C
IDE00075-ENG99967	Vehicle speed-Vehicle Speed Sensor	0	 km/h
IDE00086-ENG98363	Accelerator position-Accelerator pedal position	0	 %
IDE00091-ENG101172	Status of starter lock-Status Engine Starter Lock	Activate
IDE00094	Kick-down status	OFF
IDE00095-ENG101643	Status of selector lever lock-Status Shift Lock	active
IDE00096-ENG100569	Selector lever position-Shift Position	Position P Stop
IDE00102-ENG102028	Control Module temperature-Control modul temperature	61	 °C
IDE00130-ENG103124	Transmission specified idle RPM-Idle Speed Commanded Value	600	 /min
IDE00322-ENG100540	Status of basic setting-Basic Settings Status	0
IDE00323-ENG09093	Security Access: Number of invalid keys-Counter Value	0
IDE00451-ENG103018	Currently running routine-Current Test Routine	0
IDE00872-ENG102188	Current of main pressure valve-Oil Pressure Actual Current	0	 mA
IDE01588-ENG101855	Driving direction-M015 SvnNAbRichtung	not known
IDE02221	Engine torque: qualification	valid
IDE02713	Brake Light Switch	not activated
IDE02714	Brake test switch	not activated
IDE02717-ENG102076	Tiptronic upshift-Tiptronic Up	OFF
IDE02718-ENG101063	Tiptronic downshift-Tiptronic Down	OFF
IDE02719-ENG99606	Selector lever position made plausible-Shift Position Plausible	P
IDE02720-ENG103810	Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1	0	 /min
IDE02721-ENG100916	Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2	0	 /min
IDE02722-ENG101964	Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1	0	 /min
IDE02723-ENG100382	Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2	0	 /min
IDE02735-ENG100209	Display of driving mode in instrument panel-Display Driving Position	P
IDE02736-ENG100252	Display of gear in instrument panel-Display Driving Gear	no gear engaged
IDE02790-ENG104124	Specified torque clutch 1-Clutch 1 Commanded Torque	-600	 Nm
IDE02796-ENG103463	Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value	0	 mA
IDE02797-ENG100730	Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value	0	 mA
IDE02800-ENG100171	Specified torque clutch 2-Clutch 2 Commanded Torque	-600	 Nm
IDE02805-ENG99237	Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value	0	 mA
IDE02806-ENG103118	Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value	0.4	 mA
IDE02862-ENG103213	Production data transmission-Aggregatekennzeichnung (Getriebe)	6
IDE02862-ENG103083	Production data transmission-Baudatum	170718
IDE02862-ENG104019	Production data transmission-Getriebekennbuchstabe	SYL
IDE02862-ENG99175	Production data transmission-Kassel	K
IDE02862-ENG101707	Production data transmission-Kennung der Montagelinie	D11
IDE02862-ENG103830	Production data transmission-Lfd.-Nr	3257
IDE02864-ENG99505	Actual position of gear positioner A-Gearpositioner A Actual Position	-0.16	 mm
IDE02865-ENG104121	AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1	2058
IDE02870-ENG120871	Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor	0	 %
IDE02872-ENG102218	Actual position of gear adjuster B-Gearpositioner B Actual Position	-8.16	 mm
IDE02873-ENG101728	AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1	1083
IDE02878-ENG120875	Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor	0	 %
IDE02880-ENG103036	Actual position of gear positioner C-Gearpositioner C Actual Position	-0.3	 mm
IDE02881-ENG99453	AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1	2055
IDE02886-ENG120879	Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor	0	 %
IDE02888-ENG103826	Actual position of gear positioner D-Gearpositioner D Actual Position	-8.06	 mm
IDE02889-ENG100525	AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1	1172
IDE02894-ENG120883	Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor	0	 %
IDE03008-ENG122550	Stop process prevented-GE_StartStopp_Info	Stop release
IDE03008-ENG122551	Stop process prevented-MO_StartStopp_Status	0
IDE03008-ENG122546	Stop process prevented-Stopp-Verbot-Grund 1	not active
IDE03008-ENG122547	Stop process prevented-Stopp-Verbot-Grund 2	not active
IDE03008-ENG122548	Stop process prevented-Stopp-Verbot-Grund 3	not active
IDE03008-ENG122549	Stop process prevented-Stopp-Verbot-Grund 4	not active
IDE03008-ENG122552	Stop process prevented-Stopp-Verbot-Grund 5	not active
IDE03008-ENG122553	Stop process prevented-Stopp-Verbot-Grund 6	not active
IDE03008-ENG122554	Stop process prevented-Stopp-Verbot-Grund 8	not active
IDE03171-ENG102987	Driving strategy transmission mileage-Q002 Total Driving Time	137.4	 km
IDE03172-ENG100789	Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological	87	 %
IDE03173-ENG103567	Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty	0	 %
IDE03174-ENG100415	Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual	10	 %
IDE03180-ENG103176	Number of standard trips-General Denominator	6
IDE03181-ENG102823	Number of ignition cycles-Ignition Cycle Counter	123
IDE03182-ENG120927	Lower adapted coupling point K1 from kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption	0.26	 A
IDE03183-ENG120930	Lower adapted coupling point K2 from kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption	0.23	 A
IDE03184-ENG120928	Upper adapted coupling point K1 from microslip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption	0.76	 A
IDE03185-ENG120929	Upper adapted coupling point K2 from microslip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption	0.695	 A
IDE03189-ENG110524	Number of prevented stop processes (statistics)-Basic setting	not active
IDE03189-ENG28506	Number of prevented stop processes (statistics)-Demontagestellung	not active
IDE03189-ENG28505	Number of prevented stop processes (statistics)-Drucksensorausfall	not active
IDE03189-ENG28507	Number of prevented stop processes (statistics)-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber	not active
IDE03189-ENG110508	Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots	0	 km
IDE03189-ENG28638	Number of prevented stop processes (statistics)-Motorstoppverbote Anzahl Stoppverbote	0
IDE03189-ENG110525	Number of prevented stop processes (statistics)-Stop prohibition via application	not active
IDE03189-ENG28504	Number of prevented stop processes (statistics)-Temperaturbedingung	not active
IDE03189-ENG122385	Number of prevented stop processes (statistics)-unsortierte Gangsteller im Stand	not active
IDE04612-ENG101246	Clutch temperature air / splash oil-Centrifugal oil temperature	59	 °C
IDE04805-IDE02955	Driving profile selection-System status	not_available
IDE04805-IDE02955	Driving profile selection-System status	Available
IDE04805-IDE06419	Driving profile selection-Driving profile switchover	performed
IDE04805-IDE06419	Driving profile selection-Driving profile switchover	no request
IDE04805-MAS01447	Driving profile selection-Act.val.	0
IDE04805-MAS01447	Driving profile selection-Act.val.	2
IDE04805-MAS01448	Driving profile selection-Specified value	2
IDE04805-MAS01448	Driving profile selection-Specified value	0
IDE04805-MAS05058	Driving profile selection-Compatibility	Yes
IDE05987-ENG110524	Engine stop prohibitions-Basic setting	not active
IDE05987-ENG28506	Engine stop prohibitions-Demontagestellung	not active
IDE05987-ENG28505	Engine stop prohibitions-Drucksensorausfall	not active
IDE05987-ENG28507	Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber	not active
IDE05987-ENG110508	Engine stop prohibitions-km-Stand des letzten Stoppverbots	0	 km
IDE05987-ENG28638	Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote	0
IDE05987-ENG110525	Engine stop prohibitions-Stop prohibition via application	not active
IDE05987-ENG28504	Engine stop prohibitions-Temperaturbedingung	not active
IDE05987-ENG122385	Engine stop prohibitions-unsortierte Gangsteller im Stand	not active
IDE05988-ENG110505	Pressure of clutch 2: actual value-Clutch_2_actual_value	0	 bar
IDE05989-ENG110503	Pressure of clutch 1: actual value-Clutch_1_actual_value	0	 bar
IDE06425	Roller test bench mode: functional	not activated
IDE80001-ENG100467	Analysis 1-Snapshot 1 Failure ID	65535
IDE80002-ENG102386	Analysis 2-Snapshot 1 Mileage	0	 km
IDE80003-ENG101467	Analysis 3-Snapshot 1 Counter	0
IDE80005-ENG103330	Analysis 5-Snapshot 1 Shift Position Plausible	ERROR
IDE80007-ENG101090	Analysis 7-Snapshot 1  Commanded Gear	GANG N
IDE80008-ENG100048	Analysis 8-Snapshot 1 Preselection Gear	GANG N
IDE80009-ENG102100	Analysis 9-Snapshot 1 Transmission Input Speed	0	 /min
IDE80010-ENG101565	Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1	0	 /min
IDE80011-ENG100379	Analysis 11-Snapshot 1 Transmission Speed Shaft 1	0	 /min
IDE80012-ENG103459	Analysis 12-Snapshot 1 Transmission Speed Shaft 2	0	 /min
IDE80021-ENG102762	Analysis 21-Snapshot 1 Clutch 1 Actual Pressure	0	 bar
IDE80022-ENG100347	Analysis 22-Snapshot 1 Clutch 2 Actual Pressure	0	 bar
IDE80023-ENG99119	Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value	0	 mA
IDE80024-ENG101123	Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value	0	 mA
IDE80025-ENG103611	Analysis 25-Snapshot 1 Accelerator Pedal Position	0	 %
IDE80026-ENG101503	Analysis 26-Snapshot 1 Engine torque	-50	 Nm
IDE80029-ENG103070	Analysis 29-Snapshot 1 Voltage Terminal 15	0	 V
IDE80031-ENG102899	Analysis 31-Snapshot 1 Transmission Fluid Temperature	-60	 °C
IDE80033-ENG103098	Analysis 33-Snapshot 2 Failure ID	65535
IDE80034-ENG101047	Analysis 34-Snapshot 2 Mileage	0	 km
IDE80035-ENG99915	Analysis 35-Snapshot 2 Counter	0
IDE80037-ENG99369	Analysis 37-Snapshot 2 Shift Position Plausible	ERROR
IDE80039-ENG101369	Analysis 39-Snapshot 2  Commanded Gear	GANG N
IDE80040-ENG103638	Analysis 40-Snapshot 2 Preselection Gear	GANG N
IDE80041-ENG103367	Analysis 41-Snapshot 2 Transmission Input Speed	0	 /min
IDE80042-ENG102476	Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1	0	 /min
IDE80043-ENG102699	Analysis 43-Snapshot 2 Transmission Speed Shaft 1	0	 /min
IDE80044-ENG101900	Analysis 44-Snapshot 2 Transmission Speed Shaft 2	0	 /min
IDE80053-ENG102973	Analysis 53-Snapshot 2 Clutch 1 Actual Pressure	0	 bar
IDE80054-ENG100122	Analysis 54-Snapshot 2 Clutch 2 Actual Pressure	0	 bar
IDE80055-ENG103189	Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value	0	 mA
IDE80056-ENG103616	Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value	0	 mA
IDE80057-ENG102447	Analysis 57-Snapshot 2 Accelerator Pedal Position	0	 %
IDE80058-ENG103198	Analysis 58-Snapshot 2 Engine torque	-50	 Nm
IDE80061-ENG101449	Analysis 61-Snapshot 2 Voltage Terminal 15	0	 V
IDE80063-ENG104157	Analysis 63-Snapshot 2 Transmission Fluid Temperature	-60	 °C
IDE80065-ENG122555	Analysis 65-Snapshot 1 Weg Gangsteller 1-3	0
IDE80065-ENG122556	Analysis 65-Snapshot 1 Weg Gangsteller 2-4	0
IDE80065-ENG122557	Analysis 65-Snapshot 1 Weg Gangsteller 5-N	0
IDE80065-ENG122558	Analysis 65-Snapshot 1 Weg Gangsteller 6-R	0
IDE80066-ENG122559	Analysis 66-Snapshot 2 Weg Gangsteller 1-3	0
IDE80066-ENG122560	Analysis 66-Snapshot 2 Weg Gangsteller 2-4	0
IDE80066-ENG122561	Analysis 66-Snapshot 2 Weg Gangsteller 5-N	0
IDE80066-ENG122562	Analysis 66-Snapshot 2 Weg Gangsteller 6-R	0
IDE80071-ENG127839	Analysis 71-FID event memory entry 1	FF FF
IDE80071-ENG127848	Analysis 71-FID event memory entry 10	FF FF
IDE80071-ENG127849	Analysis 71-FID event memory entry 11	FF FF
IDE80071-ENG127850	Analysis 71-FID event memory entry 12	FF FF
IDE80071-ENG127840	Analysis 71-FID event memory entry 2	FF FF
IDE80071-ENG127841	Analysis 71-FID event memory entry 3	FF FF
IDE80071-ENG127842	Analysis 71-FID event memory entry 4	FF FF
IDE80071-ENG127843	Analysis 71-FID event memory entry 5	FF FF
IDE80071-ENG127844	Analysis 71-FID event memory entry 6	FF FF
IDE80071-ENG127845	Analysis 71-FID event memory entry 7	FF FF
IDE80071-ENG127846	Analysis 71-FID event memory entry 8	FF FF
IDE80071-ENG127847	Analysis 71-FID event memory entry 9	FF FF
IDE80296-ENG127853	Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter	28
IDE80298-ENG127880	Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter	23
IDE80302-ENG122492	Selector lever information-Datenstand	L4
IDE80302-ENG111628	Selector lever information-Part Number	5Q1713025A
IDE80302-ENG98856	Selector lever information-Programmability	0
IDE80302-ENG122491	Selector lever information-Programm-Stand	 V
IDE80303-ENG127833	Overall software description-Software full name	F52M
IDE80304-ENG120779	Mechatronics identification DQ250-Änderungsstand BorgWarner	64
IDE80304-ENG120778	Mechatronics identification DQ250-Mechatronik-Identifikation	T25W0432
IDE80305-ENG125922	Parameter set description-Data set name	0D9300018_5201_HDYH
IDE80312-ENG122524	CAN bus installation information-ACC_06	Unknown
IDE80312-ENG122528	CAN bus installation information-BEM_05	installed
IDE80312-ENG113024	CAN bus installation information-Charisma_01	installed
IDE80312-ENG122522	CAN bus installation information-EPB_01	not installed
IDE80312-ENG122525	CAN bus installation information-GRA_ACC_01	installed
IDE80312-ENG122511	CAN bus installation information-TSK_06	installed
ENG120958	Abbruchcode	GSA_ABBRUCH_CODE_OK
ENG122365-ENG104207	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0	Abschalten ENA erfolgreich
ENG122365-ENG102209	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1	Abschalten WDA erfolgreich
ENG122365-ENG99197	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2	EInschalten Endstufen erfolgreich
ENG122365-ENG102937	Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3	Keine Unterspannung im Abschaltpfadtest
ENG122363	Abschaltpfadtest Maximaler AD-Wert im Off-Fall	247
ENG122364	Abschaltpfadtest Minimaler AD-Wert im On-Fall	353
ENG120920	Abtriebsdrehzahl CAN	0	 /min
ENG98625-ENG103724	Accelerator position: qualification-Accelerator pedal position: qualification	OK
ENG100091	Ambient temperature	22	 °C
ENG120963	Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur	0
ENG120964	Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur	0
ENG122366	Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests	470
ENG120970	Anzahl Ereignisse auf K1	0
ENG120972	Anzahl Ereignisse auf K2	0
ENG98482-ENG99180	Checksum of flash-Calibration Checksumme	EA E8 B9 6C
ENG98482-ENG100495	Checksum of flash-Cboot Checksumme	31 82 84 67
ENG98482-ENG100117	Checksum of flash-Checksumme ECU + CAL	00 00 F5 7F
ENG98482-ENG102221	Checksum of flash-ECU Checksumme	68 DF BC 44
ENG110530	Clutch 1 adaption kiss point part 1 fault counter	0
ENG110536	Clutch 2 adaption kiss point part 1 fault counter	0
ENG99212	Common highside 1 specified condition	Common Highside soll ausgeschaltet werden
ENG99878	Common highside 2 specified condition	Common Highside soll ausgeschaltet werden
ENG103403	Converter Loss Torque	4	 Nm
ENG100625	Coolant temperature	69	 °C
ENG98602	Driver request torque	4	 Nm
ENG100746	Driving strategy: sport factor	0	 %
ENG120931	Eingelegtposition Seite A: Gangsteller 1-3	0	 %
ENG120932	Eingelegtposition Seite A: Gangsteller 2-4	0	 %
ENG120933	Eingelegtposition Seite A: Gangsteller 5-N	0	 %
ENG120934	Eingelegtposition Seite A: Gangsteller 6-R	0	 %
ENG120943	Eingelegtposition Seite B: Gangsteller 1-3	0	 %
ENG120944	Eingelegtposition Seite B: Gangsteller 2-4	0	 %
ENG120945	Eingelegtposition Seite B: Gangsteller 5-N	0	 %
ENG120946	Eingelegtposition Seite B: Gangsteller 6-R	0	 %
ENG101251	Empty	kein Leergas
ENG98756	Engine torque	-17	 Nm
ENG104230	Engine torque loss	-17	 Nm
ENG123019-ENG99024	Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission	0	 km/h
ENG120799	Gangsteller A Adaption Flags	00 1F
ENG120808	Gangsteller B Adaption Flags	00 1F
ENG120817	Gangsteller C Adaption Flags	00 15
ENG120826	Gangsteller D Adaption Flags	00 1F
ENG121005	Gangsteller Synchronposition G1 (Prozent)	55.29	 %
ENG121006	Gangsteller Synchronposition G2 (Prozent)	45.36	 %
ENG121007	Gangsteller Synchronposition G3 (Prozent)	46.37	 %
ENG121008	Gangsteller Synchronposition G4 (Prozent)	54	 %
ENG121009	Gangsteller Synchronposition G5 (Prozent)	53.94	 %
ENG121010	Gangsteller Synchronposition G6 (Prozent)	54.53	 %
ENG121011	Gangsteller Synchronposition GR (Prozent)	46.59	 %
ENG120961	Gangsteller_Index	GS_13
ENG120962	Gangsteller_Seite	Neutrallage
ENG120957	Gangstellerposition zum Zeitpunkt eines Abbruchs	Neutral
ENG120969	Gefahrene km seit letztem Ereignis auf K1	10	 km
ENG120971	Gefahrene km seit letztem Ereignis auf K2	10	 km
ENG99720	Height info	974	 mbar
ENG98604	Hill factor driving strategy	0	 %
ENG99596	Indicated engine torque without external interventions	0	 Nm
ENG99582	Intake air temperature	2	 °C
ENG122357-ENG122524	Kommunikationsstatus Datenbus 1 MQB-ACC_06	Unknown
ENG122357-ENG122528	Kommunikationsstatus Datenbus 1 MQB-BEM_05	received
ENG122357-ENG113024	Kommunikationsstatus Datenbus 1 MQB-Charisma_01	received
ENG122357-ENG122523	Kommunikationsstatus Datenbus 1 MQB-Diagnose_01	received
ENG122357-ENG122522	Kommunikationsstatus Datenbus 1 MQB-EPB_01	Unknown
ENG122357-ENG122513	Kommunikationsstatus Datenbus 1 MQB-ESP_02	received
ENG122357-ENG122514	Kommunikationsstatus Datenbus 1 MQB-ESP_05	received
ENG122357-ENG110808	Kommunikationsstatus Datenbus 1 MQB-ESP_07	received
ENG122357-ENG122515	Kommunikationsstatus Datenbus 1 MQB-ESP_10	Unknown
ENG122357-ENG122516	Kommunikationsstatus Datenbus 1 MQB-ESP_19	received
ENG122357-ENG122517	Kommunikationsstatus Datenbus 1 MQB-ESP_20	received
ENG122357-ENG122518	Kommunikationsstatus Datenbus 1 MQB-ESP_21	received
ENG122357-ENG122519	Kommunikationsstatus Datenbus 1 MQB-Gateway_72	received
ENG122357-ENG122520	Kommunikationsstatus Datenbus 1 MQB-Gateway_74	received
ENG122357-ENG122525	Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01	received
ENG122357-ENG00240	Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01	received
ENG122357-ENG110802	Kommunikationsstatus Datenbus 1 MQB-Kombi_01	received
ENG122357-ENG122521	Kommunikationsstatus Datenbus 1 MQB-Kombi_02	received
ENG122357-ENG110799	Kommunikationsstatus Datenbus 1 MQB-LWI_01	received
ENG122357-ENG122512	Kommunikationsstatus Datenbus 1 MQB-Motor_04	received
ENG122357-ENG122502	Kommunikationsstatus Datenbus 1 MQB-Motor_07	received
ENG122357-ENG122503	Kommunikationsstatus Datenbus 1 MQB-Motor_11	received
ENG122357-ENG122504	Kommunikationsstatus Datenbus 1 MQB-Motor_12	received
ENG122357-ENG122505	Kommunikationsstatus Datenbus 1 MQB-Motor_14	received
ENG122357-ENG122506	Kommunikationsstatus Datenbus 1 MQB-Motor_16	received
ENG122357-ENG122507	Kommunikationsstatus Datenbus 1 MQB-Motor_17	received
ENG122357-ENG122529	Kommunikationsstatus Datenbus 1 MQB-Motor_18	received
ENG122357-ENG122508	Kommunikationsstatus Datenbus 1 MQB-Motor_20	received
ENG122357-ENG122509	Kommunikationsstatus Datenbus 1 MQB-Motor_26	Unknown
ENG122357-ENG06581	Kommunikationsstatus Datenbus 1 MQB-Motor_35	Unknown
ENG122357-ENG122510	Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01	received
ENG122357-ENG122526	Kommunikationsstatus Datenbus 1 MQB-OBD_01	received
ENG122357-ENG122511	Kommunikationsstatus Datenbus 1 MQB-TSK_06	received
ENG122357-ENG122527	Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03	received
ENG126632	Korrekturwerte Hauptdruckadaption	0.39	 bar
ENG121002	Korrekturwerte Hauptdruckadaption: großer Druck auf K1	0.3	 bar
ENG121004	Korrekturwerte Hauptdruckadaption: großer Druck auf K2	0.25	 bar
ENG121001	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1	0.35	 bar
ENG121003	Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2	0.2	 bar
ENG99297	Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
ENG100826	Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl	0
ENG120965	Kupplungsadaptionswerte: IKp0 fuer K1	260	 mA
ENG120966	Kupplungsadaptionswerte: IKp0 fuer K2	230	 mA
ENG120967	Kupplungsadaptionswerte: unterer Strompunkt Adaption K1	235	 mA
ENG120968	Kupplungsadaptionswerte: unterer Strompunkt Adaption K2	220	 mA
ENG110556-ENG110541	Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung	0
ENG110556-ENG110542	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß	0
ENG110556-ENG110543	Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein	0
ENG110556-ENG120771	Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen	124
ENG110557-ENG110545	Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung	0
ENG110557-ENG110546	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß	0
ENG110557-ENG110547	Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein	0
ENG110557-ENG110544	Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen	62
ENG120996	Maximale Spannung an UH1	9.2	 V
ENG120998	Maximale Spannung an UH2	4.9	 V
ENG120995	Minimale Spannung an UH1	0.2	 V
ENG120997	Minimale Spannung an UH2	4.9	 V
ENG111613-ENG101555	Motordrehmoment Begrenzung-Engine torque limitation	273	 Nm
ENG120939	Neutralposition: Gangsteller 1-3	50.2	 %
ENG120940	Neutralposition: Gangsteller 2-4	50.01	 %
ENG120941	Neutralposition: Gangsteller 5-N	50.03	 %
ENG120942	Neutralposition: Gangsteller 6-R	50.71	 %
ENG120993	Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption	760	 mA
ENG120994	Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption	695	 mA
ENG105329-ENG101124	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)	9.2	 H
ENG105329-ENG100216	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2)	0.6	 H
ENG105329-ENG103067	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3)	0	 H
ENG105329-ENG101168	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4)	0	 H
ENG105329-ENG104150	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5)	0	 H
ENG105329-ENG100130	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6)	0	 H
ENG120987	Ratio FID 256	100	 %
ENG120989	Ratio FID 257	100	 %
ENG120988	Ratio FID 330	100	 %
ENG120990	Ratio FID 333	100	 %
ENG120975	Ratio FID 52	100	 %
ENG120976	Ratio FID 53	100	 %
ENG120977	Ratio FID 54	100	 %
ENG120978	Ratio FID 55	100	 %
ENG120986	Ratio FID 56	100	 %
ENG120973	Ratio FID 57	100	 %
ENG120974	Ratio FID 58	100	 %
ENG120979	Ratio FID 78	100	 %
ENG120980	Ratio FID 79	100	 %
ENG120981	Ratio FID 80	100	 %
ENG120982	Ratio FID 81	100	 %
ENG120983	Ratio FID 82	100	 %
ENG120984	Ratio FID 83	100	 %
ENG120985	Ratio FID 84	100	 %
ENG100188	Reached maximum temperature control module	101	 °C
ENG123020-ENG102793	Rollwiderstand-Road Resistance	0	 %
ENG102748	Selector lever error flags	00 00
ENG122375-ENG122573	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
ENG122375-ENG122571	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
ENG122375-ENG122570	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
ENG122375-ENG122574	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
ENG122375-ENG122575	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
ENG122375-ENG122563	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
ENG122375-ENG122564	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
ENG122375-ENG122565	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
ENG122375-ENG122566	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
ENG122375-ENG122569	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
ENG122375-ENG122572	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
ENG122375-ENG122567	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
ENG122375-ENG122568	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
ENG122375-ENG122576	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
ENG122375-ENG122578	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
ENG122375-ENG122577	Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
ENG122369	Snapshot 1 Iststrom Hauptdruckventil	0	 mA
ENG122367	Snapshot 1 Kupplungszustand	New
ENG122371	Snapshot 1 unterer Strompunkt Adaption K1	0	 mA
ENG122372	Snapshot 1 unterer Strompunkt Adaption K2	0	 mA
ENG122376-ENG122573	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag	ABS-Flag nicht gesetzt
ENG122376-ENG122571	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag	ASR-Flag nicht gesetzt
ENG122376-ENG122570	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag	CHS1 oder CHS2 oder beide ausgeschaltet
ENG122376-ENG122574	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag	EDS-Flag nicht gesetzt
ENG122376-ENG122575	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag	FDR-Flag nicht gesetzt
ENG122376-ENG122563	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag	GV1-Flag nicht gesetzt
ENG122376-ENG122564	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag	GV2-Flag nicht gesetzt
ENG122376-ENG122565	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag	GV3-Flag nicht gesetzt
ENG122376-ENG122566	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag	GV4-Flag nicht gesetzt
ENG122376-ENG122569	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag	MPX-Flag nicht gesetzt
ENG122376-ENG122572	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag	MSR-Flag nicht gesetzt
ENG122376-ENG122567	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag	SV1-Flag nicht gesetzt
ENG122376-ENG122568	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag	SV2-Flag nicht gesetzt
ENG122376-ENG122576	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag	Tipp-Gasse-Flag nicht gesetzt
ENG122376-ENG122578	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag	Tipp-hoch-Flag nicht gesetzt
ENG122376-ENG122577	Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag	Tipp-runter-Flag nicht gesetzt
ENG122370	Snapshot 2 Iststrom Hauptdruckventil	0	 mA
ENG122368	Snapshot 2 Kupplungszustand	New
ENG122373	Snapshot 2 unterer Strompunkt Adaption K1	0	 mA
ENG122374	Snapshot 2 unterer Strompunkt Adaption K2	0	 mA
ENG120921	Sollgang der Fahrstrategie	 R
ENG101057	Specified idle speed	1100	 /min
ENG100803	Speed: output	0	 /min
ENG122358-ENG122550	Start Stopp Statusinformationen aktuell-GE_StartStopp_Info	Stop release
ENG122358-ENG122551	Start Stopp Statusinformationen aktuell-MO_StartStopp_Status	0
ENG122358-ENG122500	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1	0
ENG122358-ENG122501	Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2	0
ENG122358-ENG122546	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 1	not active
ENG122358-ENG122547	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 2	not active
ENG122358-ENG122548	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 3	not active
ENG122358-ENG122549	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 4	not active
ENG122358-ENG122552	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 5	not active
ENG122358-ENG122553	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 6	not active
ENG122358-ENG122554	Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 8	not active
ENG120924	Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	1000	 mA
ENG120926	Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	1000	 mA
ENG120923	Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption	235	 mA
ENG120925	Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption	220	 mA
ENG120935	Synchronposition Seite A: Gangsteller 1-3	46.37	 %
ENG120936	Synchronposition Seite A: Gangsteller 2-4	45.36	 %
ENG120937	Synchronposition Seite A: Gangsteller 5-N	47.12	 %
ENG120938	Synchronposition Seite A: Gangsteller 6-R	46.59	 %
ENG120947	Synchronposition Seite B: Gangsteller 1-3	55.29	 %
ENG120948	Synchronposition Seite B: Gangsteller 2-4	54	 %
ENG120949	Synchronposition Seite B: Gangsteller 5-N	53.94	 %
ENG120950	Synchronposition Seite B: Gangsteller 6-R	54.53	 %
ENG120999	Tastverhältnis Sicherheitsventil 1	0	 %
ENG121000	Tastverhältnis Sicherheitsventil 2	0	 %
ENG120991	Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption	245	 mA
ENG120992	Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption	235	 mA
ENG120960	Unterzustand Gangstelleradaption	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG120956	Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG101346	Version info driving strategy	Temic
ENG109005	Voltage Common Highside 1	0	 V
ENG99955	Voltage Common Highside 2	0	 V
ENG120922	Vorwahlgang der Fahrstrategie	2
ENG120952	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1	0
ENG120954	Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2	0
ENG120951	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1	17
ENG120953	Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2	12
ENG120959	Zustand Gangstelleradaption	Synchron_GSA_AUS
ENG120955	Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs	Synchron_GSA_AUS
Elapsed Time: 00:21
Idle in Park
;Sunday	26	August	2018	11:26:56:04045
IDE00018	Voltage terminal 15	13.3	 V
IDE00019	Voltage terminal 30	13.7	 V
IDE00021-ENG99543	Engine speed-Engine RPM	701	 /min
IDE00022-ENG103074	Transmission input speed-Transmission Input Speed Sensor	698	 /min
IDE00024	Transmission fluid temperature	61	 °C
IDE00872-ENG102188	Current of main pressure valve-Oil Pressure Actual Current	799.8	 mA
IDE02797-ENG100730	Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value	0.1	 mA
IDE02806-ENG103118	Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value	0.7	 mA
IDE02872-ENG102218	Actual position of gear adjuster B-Gearpositioner B Actual Position	-8.08	 mm
IDE02873-ENG101728	AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1	1096
IDE02888-ENG103826	Actual position of gear positioner D-Gearpositioner D Actual Position	-8	 mm
IDE02889-ENG100525	AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1	1181
IDE03181-ENG102823	Number of ignition cycles-Ignition Cycle Counter	124
IDE04612-ENG101246	Clutch temperature air / splash oil-Centrifugal oil temperature	61	 °C
IDE05988-ENG110505	Pressure of clutch 2: actual value-Clutch_2_actual_value	0.02	 bar
ENG122366	Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests	471
ENG99212	Common highside 1 specified condition	Common Highside soll eingeschaltet werden
ENG99878	Common highside 2 specified condition	Common Highside soll eingeschaltet werden
ENG100625	Coolant temperature	96	 °C
ENG98602	Driver request torque	-2	 Nm
ENG101251	Empty	Empty
ENG98756	Engine torque	-2	 Nm
ENG104230	Engine torque loss	-27	 Nm
ENG99720	Height info	965	 mbar
ENG99596	Indicated engine torque without external interventions	26	 Nm
ENG111613-ENG101555	Motordrehmoment Begrenzung-Engine torque limitation	263	 Nm
ENG105329-ENG101124	Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)	9.4	 H
ENG101057	Specified idle speed	700	 /min
ENG120999	Tastverhältnis Sicherheitsventil 1	18	 %
ENG121000	Tastverhältnis Sicherheitsventil 2	18	 %
ENG109005	Voltage Common Highside 1	13.7	 V
ENG99955	Voltage Common Highside 2	13.7	 V
Elapsed Time: 00:21
Dana
Western PA, USA
03-ABS Brakes
adpmap-03-5Q0-614-517-AQ_3VWH17AU5JM758941-20180826-1115.CSV
;SW:5Q0-614-517-AQ   HW:5Q0-614-517-AF ---  ABS Brakes
;Component:ESC           H62 0400	 Coding:43FA6AA1342509748080030480C429C2562C9001C001943C00435050E009430000010312121212B435351919323200
;EV_Brake1UDSContiMK100ESP	36010	EV_Brake1UDSContiMK100ESP_036.rod
;Sunday	26	August	2018	11:15:33:04045
;VCID: 005A8A690A83FFD7912-8054
IDE00001-Production mode	not active 	3
IDE00252-Brake system vacuum pump	5	1
IDE00820-Activating and deactivating all development messages	0	1
IDE02332-Deactivate production mode	Deactivating 	3
IDE03659-Roller test bench mode	Manual activation: possible 	1
IDE04456-Brake disk drying	Medium 	1
IDE04508-Hydraulic brake booster	8	1
IDE04643-Overboost in brake system	activated 	1
IDE04774-Vehicle and trailer stabilization	not activated 	1
IDE04939-Tire pressure monitoring display	2	1
IDE04949-Engine drag torque control	activated 	1
IDE04951-Brake booster	4	1
IDE04952-Braking torque boost for distance regulation	3	1
IDE05055-Hydraulic brake assistant	normal 	1
IDE05057-Brake prefill	activated 	1
IDE05161-Straight ahead brake stabilization	activated 	1
IDE05337-Starting vibration reduction-	Strong 	1
IDE05337-MAS02653-Starting vibration reduction-Torque limitation	Deactivated 	1
IDE07006-Tire pressure monitoring display: tire selection	1	1
IDE07292-Brake pre-filling	not completed successfully 	1
IDE07565-ABS in lower speed range	activated 	1
IDE07848-Thresholds for brake performance	activated 	1
IDE12030-Rough road optimization	activated 	1
MAS00122-Electronic Stability Program	not activated 	1
MAS00194---no display--	Standard 	1
MAS00970-Running manufacturer number	activated 	1
MAS01299-Offroad	0	1
MAS02080-XCP calibration protocol	not activated 	1
MAS02138-Hill-start assistant	normal 	1
ENG118148-Developer_Function_1	0	1
ENG130301-Developer_Function_121	not activated 	1
Elapsed Time: 00:10
blockmap-03-5Q0-614-517-AQ_3VWH17AU5JM758941-20180826-1115.CSV
;Sunday	26	August	2018	11:15:21:04045
IDE00323	Security Access: Number of invalid keys	0
IDE00609-MAS01155	Communication status of data bus 1-Control module	Engine Control Module 1
IDE00609-MAS01156	Communication status of data bus 1-Communication status	active
IDE00780	Mode	running_mode
IDE02270-IDE00086	CAN input signal(s) status-Accelerator position	0	 %
IDE02270-IDE02049	CAN input signal(s) status-Trailer detected	ERROR
IDE02270-IDE02713	CAN input signal(s) status-Brake Light Switch	not activated
IDE02270-MAS00025	CAN input signal(s) status-Driver seat belt switch	not connected
IDE02270-MAS00218	CAN input signal(s) status-Driver door	Open
IDE02270-MAS00314	CAN input signal(s) status-Clutch Pedal Switch	operated
IDE02270-MAS00364	CAN input signal(s) status-Shift lever / selector lever position	Neutral
IDE02270-MAS01281	CAN input signal(s) status-Back-up light	OFF
IDE02270-MAS02357	CAN input signal(s) status-Vehicle identification	AU58941
IDE02270-MAS03992	CAN input signal(s) status-Clutch pedal switch: interlock position	active
IDE02271-IDE03311	CAN output signal(s) status-Emergency brake display	not active
IDE02271-IDE03660	CAN output signal(s) status-Longitudinal acceleration	-0.15625	 m/s²
IDE02486	Data logger triggering	not active
IDE02492	Start-stop function: coding information	Start-stop function in control module not active
IDE02986-IDE04431	indicator lights-ASR and ESP indicator lamp	OFF
IDE02986-IDE04451	indicator lights-Tire press monitoring display indictor lamp	OFF
IDE02986-IDE04498	indicator lights--AUTO HOLD- Indicator Lamp	Not available due to specific system
IDE02986-IDE04771	indicator lights-Indicator lamp for electro-mechanical parking brake malfunction	Not available due to specific system
IDE02986-MAS00253	indicator lights-ABS indicator lamp	OFF
IDE02986-MAS00556	indicator lights-Electromechanical parking brake indicator lamp	Not available due to specific system
IDE02986-MAS01206	indicator lights-Hill descent control indicator lamp	OFF
IDE02986-MAS02925	indicator lights-Brake system indicator lamp	OFF
IDE02986-MAS03234	indicator lights-ESP_off indicator lamp	OFF
IDE03008-IDE04446	Stop process prevented-Hill descent control	not active
IDE03008-IDE05181	Stop process prevented-Emerg.brake	not active
IDE03008-IDE06139	Stop process prevented-AUTO HOLD slippage recognition	not active
IDE03008-MAS04485	Stop process prevented-ESP function deactivation	not active
IDE03008-MAS04513	Stop process prevented-Brake control module pump operation	not active
IDE03008-MAS04515	Stop process prevented-Roll-back detected	not active
IDE03008-MAS07931	Stop process prevented-Retaining function unavailable	not active
IDE03008-MAS07932	Stop process prevented-Inclination limit	not active
IDE03009-IDE04446	Start process requested-Hill descent control	not active
IDE03009-IDE06139	Start process requested-AUTO HOLD slippage recognition	not active
IDE03009-MAS02515	Start process requested-System malfunction	not active
IDE03009-MAS04485	Start process requested-ESP function deactivation	not active
IDE03009-MAS04515	Start process requested-Roll-back detected	not active
IDE03010-IDE04446	Number of prevented stop processes-Hill descent control	0
IDE03010-IDE05181	Number of prevented stop processes-Emerg.brake	0
IDE03010-IDE06139	Number of prevented stop processes-AUTO HOLD slippage recognition	0
IDE03010-MAS04485	Number of prevented stop processes-ESP function deactivation	0
IDE03010-MAS04513	Number of prevented stop processes-Brake control module pump operation	0
IDE03010-MAS04515	Number of prevented stop processes-Roll-back detected	0
IDE03010-MAS07931	Number of prevented stop processes-Retaining function unavailable	0
IDE03010-MAS07932	Number of prevented stop processes-Inclination limit	17
IDE03011-IDE04446	Number of requested start processes-Hill descent control	0
IDE03011-IDE06139	Number of requested start processes-AUTO HOLD slippage recognition	0
IDE03011-MAS02515	Number of requested start processes-System malfunction	0
IDE03011-MAS04485	Number of requested start processes-ESP function deactivation	0
IDE03011-MAS04515	Number of requested start processes-Roll-back detected	0
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2126
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	14
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	0
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	30
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	62
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	62
IDE03127	Prevented stop processes (ring memory)	Initial value
IDE03128-MAS00106	Requested start processes (ring memory)-Year	2126
IDE03128-MAS00107	Requested start processes (ring memory)-Month	14
IDE03128-MAS00108	Requested start processes (ring memory)-Day	0
IDE03128-MAS00109	Requested start processes (ring memory)-Hours	30
IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	62
IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	62
IDE03128	Requested start processes (ring memory)	Initial value
IDE03207	Hardware version for suppliers	Freescale
IDE03212	Start-stop conditions	System malfunction
IDE03213	Start-stop enabling	At least one release missing
IDE03527-IDE02070	CAN signals-Wake-up cause	1
IDE03527-IDE02445	CAN signals-Transmission type	19
IDE03651	Bleed brake system (rework bleeding)	0	 s
IDE03680-IDE00018	Supply voltages-Voltage terminal 15	On
IDE03680-IDE01232	Supply voltages-Supply voltage for external components	4.994	 V
IDE03680-IDE04444	Supply voltages-Terminal 30 voltage for pump	0.014	 V
IDE03680-IDE04445	Supply voltages-Terminal 30 voltage for valves	14.391	 V
IDE03680-IDE04500	Supply voltages-Terminal 30 voltage for logic	OFF
IDE04422-IDE04442	Brake system sensor-Vacuum sensor	-1	 mbar
IDE04422-IDE04450	Brake system sensor-Brake pressure sensor 1	-0.4	 bar
IDE04422-IDE04494	Brake system sensor-Brake pressure sensor 1: uncond voltage 1	Not available due to specific system
IDE04422-IDE04495	Brake system sensor-Brake pressure sensor 1: uncond voltage 2	Not available due to specific system
IDE04422-MAS00179	Brake system sensor-Brake Light Switch	not activated
IDE04422-MAS02152	Brake system sensor-EPB clutch pedal travel	Not available due to specific system
IDE04425-IDE00920	Left front ABS wheel speed sensor-Front left wheel speed	0	 km/h
IDE04425-IDE04435	Left front ABS wheel speed sensor-Air gap	65535	 mm
IDE04425-IDE04436	Left front ABS wheel speed sensor-Minimum division value	Condition not met
IDE04425-IDE04437	Left front ABS wheel speed sensor-Maximum division value	Condition not met
IDE04425-IDE04438	Left front ABS wheel speed sensor-Average division value	Condition not met
IDE04425-IDE04440	Left front ABS wheel speed sensor-Validity of direction of rotation	invalid
IDE04425-IDE04441	Left front ABS wheel speed sensor-Validity of gap information	invalid
IDE04425-MAS01466	Left front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
IDE04426-IDE00921	Right front ABS wheel speed sensor-Front right wheel speed	0	 km/h
IDE04426-IDE04435	Right front ABS wheel speed sensor-Air gap	65535	 mm
IDE04426-IDE04436	Right front ABS wheel speed sensor-Minimum division value	Condition not met
IDE04426-IDE04437	Right front ABS wheel speed sensor-Maximum division value	Condition not met
IDE04426-IDE04438	Right front ABS wheel speed sensor-Average division value	Condition not met
IDE04426-IDE04440	Right front ABS wheel speed sensor-Validity of direction of rotation	invalid
IDE04426-IDE04441	Right front ABS wheel speed sensor-Validity of gap information	invalid
IDE04426-MAS01466	Right front ABS wheel speed sensor-Direction of rotation	Not available due to specific system
IDE04427-IDE00922	Left rear ABS wheel speed sensor-Left rear wheel speed	0	 km/h
IDE04427-IDE04435	Left rear ABS wheel speed sensor-Air gap	65535	 mm
IDE04427-IDE04436	Left rear ABS wheel speed sensor-Minimum division value	Condition not met
IDE04427-IDE04437	Left rear ABS wheel speed sensor-Maximum division value	Condition not met
IDE04427-IDE04438	Left rear ABS wheel speed sensor-Average division value	Condition not met
IDE04427-IDE04440	Left rear ABS wheel speed sensor-Validity of direction of rotation	invalid
IDE04427-IDE04441	Left rear ABS wheel speed sensor-Validity of gap information	invalid
IDE04427-MAS01466	Left rear ABS wheel speed sensor-Direction of rotation	forwards
IDE04428-IDE00923	Right rear ABS wheel speed sensor-Right rear wheel speed	0	 km/h
IDE04428-IDE04435	Right rear ABS wheel speed sensor-Air gap	65535	 mm
IDE04428-IDE04436	Right rear ABS wheel speed sensor-Minimum division value	Condition not met
IDE04428-IDE04437	Right rear ABS wheel speed sensor-Maximum division value	Condition not met
IDE04428-IDE04438	Right rear ABS wheel speed sensor-Average division value	Condition not met
IDE04428-IDE04440	Right rear ABS wheel speed sensor-Validity of direction of rotation	invalid
IDE04428-IDE04441	Right rear ABS wheel speed sensor-Validity of gap information	invalid
IDE04428-MAS01466	Right rear ABS wheel speed sensor-Direction of rotation	forwards
IDE04442-IDE00009	Vacuum sensor-Date of manufacture	ÿÿÿÿÿÿÿÿÿÿ
IDE04442-IDE00010	Vacuum sensor-Serial number	FF FF FF FF FF
IDE04442-IDE00104	Vacuum sensor-DTC	0
IDE04442-IDE02955	Vacuum sensor-System status	Not available due to specific system
IDE04442-IDE03205	Vacuum sensor-Manufacturer code	65535
IDE04442	Vacuum sensor	-1	 mbar
IDE04442-MAS12759	Vacuum sensor-Type of individual vacuum sensor	65535
IDE04443-IDE02241	Traction control system sensor-Lateral acceleration sensor 1	0	 m/s²
IDE04443-IDE02538	Traction control system sensor-Longitudinal acceleration sensor	-0.27468	 m/s²
IDE04443-IDE04429	Traction control system sensor-Lateral acceleration sensor 1: offset	0	 m/s²
IDE04443-IDE04430	Traction control system sensor-Longitudinal acceleration sensor: offset	-0.1875	 m/s²
IDE04443-IDE04449	Traction control system sensor-Rotation rate sensor 1: Z-axis	-0.214	 °/s
IDE04443-IDE04460	Traction control system sensor-Steering angle sensor: offset straight line running	-4.287	 °
IDE04443-MAS00815	Traction control system sensor-Steering angle sensor	-4.287	 °
IDE04446-IDE01599	Hill descent control-Slope	-1	 %
IDE04446-IDE02955	Hill descent control-System status	Available
IDE04446-IDE03664	Hill descent control-Button for driving program	not activated
IDE04446-MAS03095	Hill descent control-Function status	not active
IDE04452-IDE03662	Brake system button-ASR/ESP button	not activated
IDE04452-IDE03663	Brake system button--AUTO HOLD- Button	Not available due to specific system
IDE04452-IDE03664	Brake system button-Button for driving program	not activated
IDE04452-IDE04432	Brake system button-Tire Pressure Monitoring Display Button	not activated
IDE04452-IDE04769	Brake system button-Electro-mechanical parking brake button: status	Not available due to specific system
IDE04456-IDE02955	Brake disk drying-System status	Available
IDE04456-IDE04775	Brake disk drying-Odometer reading of last activation	0	 km
IDE04456-MAS01282	Brake disk drying-Wiper	not active
IDE04456-MAS03095	Brake disk drying-Function status	not active
IDE04461-IDE03208	Internal measured values-Software version for suppliers	MZARAB00010
IDE04461-IDE03649	Internal measured values-Fill/bleed brake system	not completed successfully
IDE04461-IDE03659	Internal measured values-Roller test bench mode	not active
IDE04461-MAS01481	Internal measured values-Temperature in control module	48	 °C
IDE04461-MAS04484	Internal measured values-Flashloader version	 TSCBAE00004
IDE04499-IDE02955	Sensor for roof rack recognition-System status	Not available due to specific system
IDE04499-MAS03095	Sensor for roof rack recognition-Function status	not recognized
IDE04508-IDE02955	Hydraulic brake booster-System status	Not available due to specific system
IDE04508-IDE04442	Hydraulic brake booster-Vacuum sensor	ERROR
IDE04508-IDE04450	Hydraulic brake booster-Brake pressure sensor 1	-0.4	 bar
IDE04508-MAS03095	Hydraulic brake booster-Function status	not active
IDE04508-MAS04002	Hydraulic brake booster-Low intake manifold pressure	ERROR
IDE04644-IDE02955	Roll-over protection-System status	Available
IDE04644-IDE04775	Roll-over protection-Odometer reading of last activation	0	 km
IDE04644-MAS03095	Roll-over protection-Function status	not active
IDE04765-IDE02955	Counter steer support-System status	Available
IDE04765-IDE03735	Counter steer support-Steering torque	0	 Nm
IDE04765-IDE04775	Counter steer support-Odometer reading of last activation	81	 km
IDE04765-MAS03095	Counter steer support-Function status	not active
IDE04774-IDE02955	Vehicle and trailer stabilization-System status	Not available due to specific system
IDE04774-IDE04775	Vehicle and trailer stabilization-Odometer reading of last activation	0	 km
IDE04774-MAS03095	Vehicle and trailer stabilization-Function status	not active
IDE04939-IDE02955	Tire pressure monitoring display-System status	Available
IDE04939-IDE04248	Tire pressure monitoring display-Left front tire pressure diffusion indicator	251
IDE04939-IDE04249	Tire pressure monitoring display-Right front tire pressure diffusion indicator	251
IDE04939-IDE04250	Tire pressure monitoring display-Left rear tire pressure diffusion indicator	251
IDE04939-IDE04251	Tire pressure monitoring display-Right rear tire pressure diffusion indicator	246
IDE04939-IDE04432	Tire pressure monitoring display-Tire Pressure Monitoring Display Button	not activated
IDE04939-IDE04946	Tire pressure monitoring display-Odometer reading at last adaptation	0	 km
IDE04939-IDE04947	Tire pressure monitoring display-Odometer reading of last warning	0	 km
IDE04939-MAS04538	Tire pressure monitoring display-Odometer reading two adaptations ago	0	 km
IDE04939-MAS04539	Tire pressure monitoring display-Odometer reading three adaptations ago	0	 km
IDE04939-MAS04540	Tire pressure monitoring display-Odometer reading four adaptations ago	0	 km
IDE04939-MAS04541	Tire pressure monitoring display-Odometer reading of next-to-last warning	0	 km
IDE04939-MAS04542	Tire pressure monitoring display-Odometer reading of third-to-last warning	0	 km
IDE04939-MAS04543	Tire pressure monitoring display-Odometer reading of fourth-to-last warning	0	 km
IDE04939-MAS04544	Tire pressure monitoring display-Left front flat tire indicator	255
IDE04939-MAS04545	Tire pressure monitoring display-Right front flat tire indicator	248
IDE04939-MAS04546	Tire pressure monitoring display-Left rear flat tire indicator	252
IDE04939-MAS04547	Tire pressure monitoring display-Right rear flat tire indicator	248
IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
IDE06591-ENG118150	Pump load counter-Comp_Rotatation_of_pump_motor	1679
IDE06591-ENG118152	Pump load counter-Load_on_feeding_side_of_Pump	50169
IDE06591-ENG118151	Pump load counter-Load_on_suction_side_of_Pump	3
IDE06591-ENG118153	Pump load counter-Pump_motor_start_counter	95
IDE07280-IDE04775	Multiple collision brake-Odometer reading of last activation	0	 km
IDE07280-IDE06609	Multiple collision brake-Odometer reading of last deactivation	0	 km
IDE07280-MAS00106	Multiple collision brake-Year	2127
IDE07280-MAS00107	Multiple collision brake-Month	15
IDE07280-MAS00108	Multiple collision brake-Day	0
IDE07280-MAS00109	Multiple collision brake-Hours	31
IDE07280-MAS00110	Multiple collision brake-Minutes	63
IDE07280-MAS00111	Multiple collision brake-Seconds	63
IDE07280-MAS07659	Multiple collision brake-Frequency counter for multi-collision brake active	0
IDE07280-MAS07660	Multiple collision brake-Frequency counter for multi-collision brake deactivated	0
IDE07280-MAS07661	Multiple collision brake-Frequency counter function deactivated by driver	0
IDE07280-MAS07662	Multiple collision brake-Mileage reading of the last deactivation by driver	0	 km
IDE80101	Analysis 101	A3 32 38 35 31 35 34 37 31 33 31 33 30 30 30 30 35 31 37 38 32 38 30 30 30 36 44 2F 02 13 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE80102-ENG122580	Analysis 102-value_1_percentaged	94.1346	 %
IDE80102-ENG122579	Analysis 102-value_1_quantity	0
IDE80102-ENG122582	Analysis 102-value_2_percentaged	99.9936	 %
IDE80102-ENG122581	Analysis 102-value_2_quantity	0
IDE80102-ENG122584	Analysis 102-value_3_percentaged	94.9158	 %
IDE80102-ENG122583	Analysis 102-value_3_quantity	10
IDE80102-ENG122586	Analysis 102-value_4_percentaged	98.4312	 %
IDE80102-ENG122585	Analysis 102-value_4_quantity	8
IDE80102-ENG122588	Analysis 102-value_5_percentaged	98.0406	 %
IDE80102-ENG122587	Analysis 102-value_5_quantity	4
IDE80102-ENG122590	Analysis 102-value_6_percentaged	99.9936	 %
IDE80102-ENG122589	Analysis 102-value_6_quantity	0
IDE80103-MAS00976	Analysis 103-Counter	0
MAS00121-IDE02955	Electronic Differential Lock-System status	Available
MAS00121-IDE04504	Electronic Differential Lock-Calculated left front brake temperature	22.5	 °C
MAS00121-IDE04505	Electronic Differential Lock-Calculated right front brake temperature	22.5	 °C
MAS00121-IDE04506	Electronic Differential Lock-Calculated left rear brake temperature	22.5	 °C
MAS00121-IDE04507	Electronic Differential Lock-Calculated right rear brake temperature	22.5	 °C
MAS00121-MAS00179	Electronic Differential Lock-Brake Light Switch	not activated
MAS00121-MAS01853	Electronic Differential Lock-Left front	Available
MAS00121-MAS01854	Electronic Differential Lock-Right front	Available
MAS00121-MAS01855	Electronic Differential Lock-Left rear	Available
MAS00121-MAS01856	Electronic Differential Lock-Right rear	Available
MAS00121-MAS03095	Electronic Differential Lock-Function status	not active
MAS00911-IDE02955	All Wheel Drive (AWD)-System status	Available
MAS00911-IDE04502	All Wheel Drive (AWD)-Haldex clutch status	No malfunction detected
MAS00911-IDE04943	All Wheel Drive (AWD)-Haldex clutch	Fully open
MAS00911-MAS01464	All Wheel Drive (AWD)-Emergency running mode	not active
MAS00911-MAS04730	All Wheel Drive (AWD)-Degree of blockage	0	 %
MAS02138-IDE02955	Hill-start assistant-System status	Available
MAS02138-MAS00025	Hill-start assistant-Driver seat belt switch	not connected
MAS02138-MAS00218	Hill-start assistant-Driver door	Open
MAS02138-MAS00988	Hill-start assistant-Reverse gear	not selected
MAS02138-MAS03095	Hill-start assistant-Function status	Condition not met
MAS02426-MAS00580	Text display in instrument panel insert-Electromechanical parking brake text 1	0
MAS02426-MAS03359	Text display in instrument panel insert-Text	0
MAS02672-IDE02955	Start-stop-System status	Not available due to specific system
MAS02672-IDE03214	Start-stop-Engine stop using start-stop function	not active
MAS02672-IDE03215	Start-stop-Engine start using start-stop function	not active
MAS02672-MAS00025	Start-stop-Driver seat belt switch	not connected
MAS08072-MAS13685	Driving profile selection-Actual value of downhill driving assistant	2
MAS08072-MAS13686	Driving profile selection-Actual value uphill driving assistant	0
MAS08072-MAS13687	Driving profile selection-Actual value of differential lock	0
MAS08072-MAS13688	Driving profile selection-ESC actual value	2
MAS08072-MAS13689	Driving profile selection-Compatibility of downhill driving assistant	Yes
MAS08072-MAS13690	Driving profile selection-Compatibility of uphill driving assistant	Yes
MAS08072-MAS13691	Driving profile selection-Compatibility of differential lock	Yes
MAS08072-MAS13692	Driving profile selection-ESC compatibility	Yes
MAS08072-MAS13693	Driving profile selection-Spec. value of downhill driving assistant	2
MAS08072-MAS13694	Driving profile selection-Spec. value of uphill driving assistant	0
MAS08072-MAS13695	Driving profile selection-Spec. value of differential lock	0
MAS08072-MAS13696	Driving profile selection-ESC spec. value	2
MAS08072-MAS13697	Driving profile selection-System status of downhill driving assistant	Available
MAS08072-MAS13698	Driving profile selection-System status uphill driving assistant	Not available
MAS08072-MAS13699	Driving profile selection-System status of differential lock	Not available
MAS08072-MAS13700	Driving profile selection-ESC system status	Available
MAS08072-MAS13701	Driving profile selection-Switchover status of downhill driving assistant	Shifting carried out
MAS08072-MAS13702	Driving profile selection-Switchover status of uphill driving assistant	Shifting carried out
MAS08072-MAS13703	Driving profile selection-ESC switchover status	Shifting carried out
MAS08072-MAS13704	Driving profile selection-Switchover status_differential lock	Shifting carried out
ENG26281-IDE01011	HBV_Event_Counter-Data record	0
Elapsed Time: 00:12
Dana
Western PA, USA
08-Auto HVAC
adpmap-08-5GM-907-426-G_3VWH17AU5JM758941-20180826-1116.CSV
;SW:5GM-907-426-G   HW:5GM-907-426-G ---  Auto HVAC
;Component:AC Manuell    H03 2001	 Coding:02020004200110000000000000000002
;EV_ACManueBHBVW37X	4134	EV_ACManueBHBVW37X_004_VW37.rod
;Sunday	26	August	2018	11:16:07:04045
;VCID: 4CC26E59764BEBB73DA-8018
IDE00001-Production mode	Deactivating 	3
IDE01067-Retention of driver's seat heater level	active for 10 minutes 	1
IDE01478-Ignore compressor switch-off by Engine Control Module	Do not ignore 	1
IDE01479-Gear ratio of engine - A/C compressor	0	1
IDE01483-Blower voltage for voice operation	not activated 	1
IDE01488-Retrofitting of parking heater without CAN	not installed 	1
IDE01503-Runtime for compressor run-in basic setting	60 s	1
IDE02155-Reset all counters	not activated 	1
IDE02332-Deactivate production mode	0	3
IDE03176-Duration of compressor run in	60 s	1
IDE03251-Stop release for start-stop function	According to function requirements 	1
IDE04159-Deactivation of start-stop function	not active 	1
IDE06097-Target temperature of A/C - heater function via remote control	22.0 °C	1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed)	1500 /min	1
IDE06545-Blower voltage for production routines	9.0 V	1
IDE06546-Interior target temperature for production routines	22 °C	1
IDE06547-Air distribution for production routines	No effect 	1
IDE06593-Recirculation air for production routines	No effect 	1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
IDE07301-Remote start function: activation of seat heating	Seat heater front 	1
IDE07302-Remote start function: interior climate control status	Remote start function with fixed rated temperature active 	1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.	4 °C	1
IDE07304-Remote start function: activation of seat ventilation	activated 	1
IDE07305-Rem. start funct.: activat.temper. of seat heating	15 °C	1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation	20 °C	1
IDE07307-Remote start function: activation stage of seat heating	2	1
IDE07308-Remote start function: activation stage of seat ventilation	2	1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost	not active 	1
IDE07948-Retention of frt.pass. seat heater level	not active 	1
IDE12229-Filtering of interior air: store	Service life-dependent store 	1
IDE80007-Analysis 7	00000000 00000000  	2
IDE80008-Analysis 8	not active 	1
MAS14860-Remote start function: windshield defogger takeover	activated 	1
MAS14861-Remote start function: windshield defogger	activated 	1
ENG122844-ENG101574-dimming_characteristic_1-X1	0	12
ENG122844-ENG99557-dimming_characteristic_1-X2	6	12
ENG122844-ENG102140-dimming_characteristic_1-X3	40	12
ENG122844-ENG102936-dimming_characteristic_1-X4	60	12
ENG122844-ENG103548-dimming_characteristic_1-X5	80	12
ENG122844-ENG113992-dimming_characteristic_1-X6	100	12
ENG122844-ENG99777-dimming_characteristic_1-Y1	0%	12
ENG122844-ENG100480-dimming_characteristic_1-Y2	6%	12
ENG122844-ENG100773-dimming_characteristic_1-Y3	40%	12
ENG122844-ENG100631-dimming_characteristic_1-Y4	60%	12
ENG122844-ENG102174-dimming_characteristic_1-Y5	80%	12
ENG122844-ENG113993-dimming_characteristic_1-Y6	100%	12
ENG122845-ENG101574-dimming_characteristic_2-X1	0	12
ENG122845-ENG99557-dimming_characteristic_2-X2	6	12
ENG122845-ENG102140-dimming_characteristic_2-X3	40	12
ENG122845-ENG102936-dimming_characteristic_2-X4	60	12
ENG122845-ENG103548-dimming_characteristic_2-X5	80	12
ENG122845-ENG113992-dimming_characteristic_2-X6	100	12
ENG122845-ENG99777-dimming_characteristic_2-Y1	0%	12
ENG122845-ENG100480-dimming_characteristic_2-Y2	6%	12
ENG122845-ENG100773-dimming_characteristic_2-Y3	40%	12
ENG122845-ENG100631-dimming_characteristic_2-Y4	60%	12
ENG122845-ENG102174-dimming_characteristic_2-Y5	80%	12
ENG122845-ENG113993-dimming_characteristic_2-Y6	100%	12
ENG122846-ENG101574-dimming_characteristic_3-X1	0	12
ENG122846-ENG99557-dimming_characteristic_3-X2	6	12
ENG122846-ENG102140-dimming_characteristic_3-X3	40	12
ENG122846-ENG102936-dimming_characteristic_3-X4	60	12
ENG122846-ENG103548-dimming_characteristic_3-X5	80	12
ENG122846-ENG113992-dimming_characteristic_3-X6	100	12
ENG122846-ENG99777-dimming_characteristic_3-Y1	0%	12
ENG122846-ENG100480-dimming_characteristic_3-Y2	6%	12
ENG122846-ENG100773-dimming_characteristic_3-Y3	40%	12
ENG122846-ENG100631-dimming_characteristic_3-Y4	60%	12
ENG122846-ENG102174-dimming_characteristic_3-Y5	80%	12
ENG122846-ENG113993-dimming_characteristic_3-Y6	100%	12
ENG122847-ENG101574-dimming_characteristic_4-X1	0	12
ENG122847-ENG99557-dimming_characteristic_4-X2	6	12
ENG122847-ENG102140-dimming_characteristic_4-X3	40	12
ENG122847-ENG102936-dimming_characteristic_4-X4	60	12
ENG122847-ENG103548-dimming_characteristic_4-X5	80	12
ENG122847-ENG113992-dimming_characteristic_4-X6	100	12
ENG122847-ENG99777-dimming_characteristic_4-Y1	0%	12
ENG122847-ENG100480-dimming_characteristic_4-Y2	6%	12
ENG122847-ENG100773-dimming_characteristic_4-Y3	40%	12
ENG122847-ENG100631-dimming_characteristic_4-Y4	60%	12
ENG122847-ENG102174-dimming_characteristic_4-Y5	80%	12
ENG122847-ENG113993-dimming_characteristic_4-Y6	100%	12
ENG122848-ENG101574-dimming_characteristic_5-X1	0	12
ENG122848-ENG99557-dimming_characteristic_5-X2	10	12
ENG122848-ENG102140-dimming_characteristic_5-X3	50	12
ENG122848-ENG102936-dimming_characteristic_5-X4	100	12
ENG122848-ENG103548-dimming_characteristic_5-X5	220	12
ENG122848-ENG113992-dimming_characteristic_5-X6	253	12
ENG122848-ENG99777-dimming_characteristic_5-Y1	2%	12
ENG122848-ENG100480-dimming_characteristic_5-Y2	2%	12
ENG122848-ENG100773-dimming_characteristic_5-Y3	5%	12
ENG122848-ENG100631-dimming_characteristic_5-Y4	10%	12
ENG122848-ENG102174-dimming_characteristic_5-Y5	85%	12
ENG122848-ENG113993-dimming_characteristic_5-Y6	100%	12
ENG122849-illumination index grain rotary knob	search illumination 	1
ENG130577-Knockout_timer_activation	not activated 	1
Elapsed Time: 00:11
blockmap-08-5GM-907-426-G_3VWH17AU5JM758941-20180826-1115.CSV
;Sunday	26	August	2018	11:15:59:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
Group	Description	Actual
IDE00019	Voltage terminal 30	14.5	 V
IDE00021	Engine speed	0	 /min
IDE00025	Coolant temperature	68	 °C
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00198	Refrigerant pressure	6.6	 bar
IDE00322	Status of basic setting	was not yet started
IDE00767	No. of unscheduled ECU resets	1
IDE00965	Compressor shut-off requirement	A/C off or fan control switch in 0 position
IDE00966	Compressor current: actual value	0	 A
IDE00967	Compressor current: specified value	0	 A
IDE00968	Compressor speed	0	 /min
IDE00969	Compressor load	0.5	 Nm
IDE00970	Coolant fan activation: actual value	10	 %
IDE00971	Coolant fan activation: specified value	0	 %
IDE00973	Outside air temperature	23.5	 °C
IDE00974	Outside air temperature internally calculated	21	 °C
IDE00982	Temperature after evaporator	29	 °C
IDE00987	Blower voltage: specified value	0	 V
IDE00989	Blower status	not active
IDE00992	Recirculation flap specified value	Fresh air
IDE01046	Temperature flap: actual value	55
IDE01046	Temperature flap: actual value	12.5	 %
IDE01047	Temperature flap: specified value	55
IDE01048	Temperature flap: cold stop	29
IDE01049	Temperature flap: warm stop	234
IDE01059	Air distribution flap: actual value	79
IDE01059	Air distribution flap: actual value	19.5	 %
IDE01060	Air distribution flap: specified value	78
IDE01063	Status of recirculation air	Fresh air
IDE01066	Convertible top status	closed
IDE01076	Time since ignition off	3	 min
IDE01217-MAS01447	Left heated seat stage-Act.val.	0
IDE01217-MAS01448	Left heated seat stage-Specified value	0
IDE01218-MAS01447	Right heated seat stage-Act.val.	0
IDE01218-MAS01448	Right heated seat stage-Specified value	0
IDE01226	Blower voltage: actual value	0	 V
IDE01227	Blower current	0	 A
IDE01232	Supply voltage for external components	5.1	 V
IDE01264	Remaining time of parking heater/ventilation operation	0	 min
IDE01287-MAS01260	Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN	57
IDE01287-MAS01265	Counter of compressor switch-offs-Speed shut-off	0
IDE01419	Compressor shut-off condition: last	Low pressure event
IDE01420	Compressor shut-off requirement: penultimate	Low pressure event
IDE01421	Compressor shut-off requirement: antepenultimate	Low pressure event
IDE01442-MAS01533	Pressing a button-Defrost	not activated
IDE01442-MAS01534	Pressing a button-Recirculating air	not activated
IDE01442-MAS01535	Pressing a button-Rear window defogger	not activated
IDE01442-MAS01550	Pressing a button-AC	not activated
IDE01442-MAS01554	Pressing a button-Left heated seat	not activated
IDE01442-MAS01556	Pressing a button-Right heated seat	not activated
IDE01442-MAS01560	Pressing a button-OFF	not activated
IDE01442-MAS01577	Pressing a button-Parking heater	not activated
IDE01442-MAS02015	Pressing a button-AUTO	not activated
IDE01442-MAS02192	Pressing a button-SYNC	not activated
IDE01442-MAS03196	Pressing a button-Menu	not activated
IDE01442-MAS03830	Pressing a button-Footwell air distribution	not activated
IDE01442-MAS03831	Pressing a button-Upper body vent air distribution	not activated
IDE01442-MAS03832	Pressing a button-Air distribution up	not activated
IDE01442-MAS04605	Pressing a button-AC MAX	not activated
IDE01443	Left push-and-rotary knob counter	82
IDE01444	Right push-and-rotary knob counter	148
IDE02270-IDE00002	CAN input signal(s) status-Transport mode	OFF
IDE02270-IDE01211	CAN input signal(s) status-Static current measuring mode	OFF
IDE02270-IDE01268	CAN input signal(s) status-Windshield wiper	OFF
IDE02270-IDE01457	CAN input signal(s) status-Energy management deactivation stage	Deactivation stage 0
IDE02270-MAS01269	CAN input signal(s) status-Wipe wash	OFF
IDE02270-MAS01277	CAN input signal(s) status-Rear window heater actual value	OFF
IDE02270-MAS01283	CAN input signal(s) status-Actual value of windshield heater	OFF
IDE02271-IDE00972	CAN output signal(s) status-Idle speed increase	not active
IDE02271-MAS00130	CAN output signal(s) status-Compressor on	OFF
IDE03008-MAS01517	Stop process prevented-Defrost active	not active
IDE03008-MAS01564	Stop process prevented-Windshield defogger	not active
IDE03008-MAS02802	Stop process prevented-Interior temperature difference to setting	not active
IDE03008-MAS02803	Stop process prevented-Interior vent difference to setting	not active
IDE03008-MAS02804	Stop process prevented-Manual fan speed increase	not active
IDE03008-MAS04353	Stop process prevented-Fogging hazard (humidity sensor)	not active
IDE03008-MAS04354	Stop process prevented-Interior comfort humidity too high (humidity sensor)	not active
IDE03008-MAS05009	Stop process prevented-A/C request: auxil. heat mode	not active
IDE03008-MAS05047	Stop process prevented-Maximum cooling and heating set	not active
IDE03008-MAS06551	Stop process prevented-Seat ventilation	not active
IDE03008-MAS09538	Stop process prevented-max A/C	not active
IDE03009-MAS01517	Start process requested-Defrost active	not active
IDE03009-MAS01564	Start process requested-Windshield defogger	not active
IDE03009-MAS02802	Start process requested-Interior temperature difference to setting	not active
IDE03009-MAS02803	Start process requested-Interior vent difference to setting	not active
IDE03009-MAS02804	Start process requested-Manual fan speed increase	not active
IDE03009-MAS04353	Start process requested-Fogging hazard (humidity sensor)	not active
IDE03009-MAS04354	Start process requested-Interior comfort humidity too high (humidity sensor)	not active
IDE03009-MAS05009	Start process requested-A/C request: auxil. heat mode	not active
IDE03009-MAS05047	Start process requested-Maximum cooling and heating set	not active
IDE03009-MAS06551	Start process requested-Seat ventilation	not active
IDE03009-MAS09538	Start process requested-max A/C	not active
IDE03010-MAS00478	Number of prevented stop processes-Reserved	0
IDE03010-MAS01517	Number of prevented stop processes-Defrost active	0
IDE03010-MAS01564	Number of prevented stop processes-Windshield defogger	0
IDE03010-MAS02802	Number of prevented stop processes-Interior temperature difference to setting	0
IDE03010-MAS02803	Number of prevented stop processes-Interior vent difference to setting	0
IDE03010-MAS02804	Number of prevented stop processes-Manual fan speed increase	0
IDE03010-MAS04353	Number of prevented stop processes-Fogging hazard (humidity sensor)	0
IDE03010-MAS04354	Number of prevented stop processes-Interior comfort humidity too high (humidity sensor)	0
IDE03010-MAS05009	Number of prevented stop processes-A/C request: auxil. heat mode	0
IDE03010-MAS05047	Number of prevented stop processes-Maximum cooling and heating set	0
IDE03010-MAS06551	Number of prevented stop processes-Seat ventilation	0
IDE03010-MAS09538	Number of prevented stop processes-max A/C	0
IDE03011-MAS00478	Number of requested start processes-Reserved	0
IDE03011-MAS01517	Number of requested start processes-Defrost active	0
IDE03011-MAS01564	Number of requested start processes-Windshield defogger	0
IDE03011-MAS02802	Number of requested start processes-Interior temperature difference to setting	0
IDE03011-MAS02803	Number of requested start processes-Interior vent difference to setting	0
IDE03011-MAS02804	Number of requested start processes-Manual fan speed increase	0
IDE03011-MAS04353	Number of requested start processes-Fogging hazard (humidity sensor)	0
IDE03011-MAS04354	Number of requested start processes-Interior comfort humidity too high (humidity sensor)	0
IDE03011-MAS05009	Number of requested start processes-A/C request: auxil. heat mode	0
IDE03011-MAS05047	Number of requested start processes-Maximum cooling and heating set	0
IDE03011-MAS06551	Number of requested start processes-Seat ventilation	0
IDE03011-MAS09538	Number of requested start processes-max A/C	0
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2127
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	15
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	31
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	31
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	63
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	63
IDE03127	Prevented stop processes (ring memory)	Measured value not available
IDE03128-MAS00106	Requested start processes (ring memory)-Year	2127
IDE03128-MAS00107	Requested start processes (ring memory)-Month	15
IDE03128-MAS00108	Requested start processes (ring memory)-Day	31
IDE03128-MAS00109	Requested start processes (ring memory)-Hours	31
IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	63
IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	63
IDE03128	Requested start processes (ring memory)	Measured value not available
IDE03212	Start-stop conditions	Stop release
IDE03213	Start-stop enabling	System malfunction
IDE03214	Engine stop using start-stop function	not active
IDE03215	Engine start using start-stop function	not active
IDE03488	Driving time remaining for basic setting of compressor run in	0	 s
IDE04312-IDE04095	System run time-Engine running time	0	 s
IDE04312-MAS00084	System run time-Terminal 15 on	255	 s
IDE04797	Center push-and-rotary knob counter	61
IDE05725	Terminal 58xs dimmer	0	 %
IDE05726	Terminal 58xd dimmer	253
IDE06201	Blower reduction	No switch-off: no reduction
IDE07159-MAS01155	Control module switch-off: counter-Control module	0
IDE07159-MAS05583	Control module switch-off: counter-Data bus	0
IDE12141-MAS00106	History memory: parking heater-Year	2127
IDE12141-MAS00107	History memory: parking heater-Month	15
IDE12141-MAS00108	History memory: parking heater-Day	31
IDE12141-MAS00109	History memory: parking heater-Hours	31
IDE12141-MAS00110	History memory: parking heater-Minutes	63
IDE12141-MAS00111	History memory: parking heater-Seconds	63
IDE12141-MAS02526	History memory: parking heater-Activation	Measured value not available
IDE12141-MAS04390	History memory: parking heater-Active source	Measured value not available
IDE12499-IDE08704	A/C compressor initial running in: start prevention-Load mgmnt.	not active
IDE12499-MAS01250	A/C compressor initial running in: start prevention-Malfunction on fresh air blower	not active
IDE12499-MAS01493	A/C compressor initial running in: start prevention-Engine running	Yes
IDE12499-MAS10030	A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written	Yes
IDE12499-MAS14625	A/C compressor initial running in: start prevention-High-voltage vehicle electrical system	active
IDE12499-MAS14626	A/C compressor initial running in: start prevention-High-voltage current limitations	not active
IDE12499-MAS14891	A/C compressor initial running in: start prevention-Flaps not calibrated	not active
IDE12500-MAS01250	A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower	not active
IDE12500-MAS01254	A/C compressor initial running in: interruption conditions-AC button off	not active
IDE12500-MAS01256	A/C compressor initial running in: interruption conditions-Outside air temperature too low	not active
IDE12500-MAS01261	A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger	not active
IDE12500-MAS01263	A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path	not active
IDE12500-MAS01264	A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor	not active
IDE12500-MAS01265	A/C compressor initial running in: interruption conditions-Speed shut-off	not active
IDE12500-MAS01504	A/C compressor initial running in: interruption conditions-Supply voltage too high	not active
IDE12500-MAS01508	A/C compressor initial running in: interruption conditions-High pressure event	not active
IDE12500-MAS01509	A/C compressor initial running in: interruption conditions-Low pressure event	not active
IDE12500-MAS14892	A/C compressor initial running in: interruption conditions-Pressure test not successful	not active
IDE12500-MAS14893	A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor	not active
MAS00464-MAS00106	Standard - ambient data 1-Year	2018
MAS00464-MAS00107	Standard - ambient data 1-Month	8
MAS00464-MAS00108	Standard - ambient data 1-Day	26
MAS00464-MAS00109	Standard - ambient data 1-Hours	11
MAS00464-MAS00110	Standard - ambient data 1-Minutes	15
MAS00464-MAS00111	Standard - ambient data 1-Seconds	45
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
Elapsed Time: 00:07
Dana
Western PA, USA
09-Cent. Elect.
adpmap-09-5Q0-937-087-AR_3VWH17AU5JM758941-20180826-1117.CSV
;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0243	 Coding:
;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
;Sunday	26	August	2018	11:17:05:04045
;VCID: 0B40AD4533C5AC8FF40-805E
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01550-Service position	170.494336 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE03787-Activate left/right hand drive switch-over	not active 	1
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	not active 	8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	not installed 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05143-MAS02985-Writing parameter-Value	130	5
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
IDE05144-Read parameter address	FE 00 00 	3
IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	34.00 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	34.00 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	50.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	49.00 °C	30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07356-Position during interval mode	31.494474 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	not active 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	255 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	not installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
IDE10298-Alternating park position 1	7.494498 °	2
IDE10299-Alternating park position 2	29.494476 °	2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	not active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS05055-lower turn position	31.494474 °	2
MAS05056-upper turn position	170.494336 °	2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	Yes 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	true 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	1	2
ENG99457-ENG98971-Head area heater-Temperature	-2	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	58.50%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	58.50%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	58.50%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	58.50%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	54.50%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	49.50%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	46.50%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	35.50%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	31.50%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	20.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	36	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	only_if_closed 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	35	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	only_if_closed 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	54	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	53	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	43 - allgemeine LED 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	43 - allgemeine LED 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	43 - allgemeine LED 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	28	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	28	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen) 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Nebellicht links 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	28	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	28	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen) 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Nebellicht rechts 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 13 00 3D 18 02 64 03 00 80 00 00 00 00 00 00 2B 23 00 3E 18 04 64 05 00 80 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.00%	62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-101.5 ms	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	1.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	10.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	1.00 s	62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	not installed 	8
ENG124714-ENG142044-OCU-DWA_push	not active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	not active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	0 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	0 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	0 ms	10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	25	10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	100%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	not active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	not active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	not active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	not active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	not active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	not active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	not active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	not active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Contact control 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	not active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
Elapsed Time: 01:47
09 Adps with SA code 31347
;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect. --- SA: 31347
;Component:BCM PQ37BOSCH 034 0243	 Coding:
;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
;Sunday	26	August	2018	11:29:50:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 0B40AD4533C5AC8FF40-805E
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01550-Service position	170.494336 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
IDE02332-Deactivate production mode	0	3
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE03787-Activate left/right hand drive switch-over	not active 	1
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	not active 	8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	not installed 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05143-MAS02985-Writing parameter-Value	130	5
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
IDE05144-Read parameter address	FE 00 00 	3
IDE05145-Light configuration	0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 06 12 9C 08 09 1C 00 00 00 04 4C 00 4C 14 00 64 07 13 9C 08 0A 1C 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 	224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	34.00 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	34.00 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	50.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	49.00 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	50.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	49.00 °C	30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.0 V	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07356-Position during interval mode	31.494474 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	not active 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	255 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	not installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	active 	19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	not active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
IDE10298-Alternating park position 1	7.494498 °	2
IDE10299-Alternating park position 2	29.494476 °	2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	not installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	not installed 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	not active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	not active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS05055-lower turn position	31.494474 °	2
MAS05056-upper turn position	170.494336 °	2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	Yes 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	true 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	not installed 	18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	10 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	10 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	Basis 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	1	2
ENG99457-ENG98971-Head area heater-Temperature	-2	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	100.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	100.00%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	100.00%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	100.00%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	83.00%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	67.00%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	50.00%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	33	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	17.00%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	0.00%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	58.50%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	58.50%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	58.50%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	58.50%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	54.50%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	49.50%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	46.50%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	35.50%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	31.50%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	20.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	127	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	36	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	only_if_closed 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	127	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	35	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	only_if_closed 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	0	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	0	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	not active 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	not active 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	0	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	0	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	not active 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	not active 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E 	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	minimize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	minimize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	127	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	54	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	127	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	53	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	43 - allgemeine LED 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	43 - allgemeine LED 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	43 - allgemeine LED 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	minimize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	28	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	28	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A 	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights 	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Blinken links aktiv (beide Phasen) 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Nebellicht links 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	minimize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	28	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	28	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C 	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C 	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights 	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Blinken rechts aktiv (beide Phasen) 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Nebellicht rechts 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	minimize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	127	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A 	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Blinken links aktiv (beide Phasen) 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	127	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B 	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Blinken rechts aktiv (beide Phasen) 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	100	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	11 - Abblendlicht 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	100	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	11 - Abblendlicht 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	100	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	1C 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	37	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	10 - allgemeine Scheinwerfer 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Left high beam 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Lichthupe generell 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	100	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	1D 	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	41	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	10 - allgemeine Scheinwerfer 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Right high beam 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Lichthupe generell 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 13 00 3D 18 02 64 03 00 80 00 00 00 00 00 00 2B 23 00 3E 18 04 64 05 00 80 00 00 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	100.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	0.00%	62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-101.5 ms	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	2.50%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	1.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	10.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	1.00 s	62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	not installed 	8
ENG124714-ENG142044-OCU-DWA_push	not active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	not active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	0 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	0 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	0 ms	10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	not active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	not active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	25	10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	100%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	not active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	not installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	not active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	not active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	not active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	not active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	not active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	not active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	not active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	not active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	not installed 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Contact control 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	not active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
Elapsed Time: 01:47
blockmap-09-5Q0-937-087-AR_3VWH17AU5JM758941-20180826-1116.CSV
;SW:5Q0-937-087-AR   HW:5Q0-937-087-AN ---  Cent. Elect.
;Component:BCM PQ37BOSCH 034 0243	 Coding:
;EV_BodyContrModul1UDSBosc	18001	EV_BCMBOSCH_018.rod
;Sunday	26	August	2018	11:16:23:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 0B40AD4533C5AC8FF40-805E
Group	Description	Actual
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00322	Status of basic setting	was not yet started
IDE00323	Security Access: Number of invalid keys	0
IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	not coded/not installed
IDE00356-MAS00125	Cruise Control System (CCS): switch position-Cruise control system	not coded/not installed
IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	not coded/not installed
IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	not coded/not installed
IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	not coded/not installed
IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	not coded/not installed
IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	not coded/not installed
IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	not_defined
IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	not coded/not installed
IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	not coded/not installed
IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	not coded/not installed
IDE00374-MAS05377	Electric auxiliary heater: relay activation-Low heat output relay	not coded/not installed
IDE00374-MAS05378	Electric auxiliary heater: relay activation-High heat output relay	not coded/not installed
IDE00844-MAS07314	Switch for engine hood-Status engine hood contact	Open
IDE00844-ENG122175	Switch for engine hood-Bonnet_Magnetic_Lock	not coded/not installed
IDE00973	Outside air temperature	23.5	 °C
IDE01066-IDE02092	Convertible top status-Tailgate condition	not coded/not installed
IDE01066	Convertible top status	not coded/not installed
IDE01285	Counter of component protection malfunctions	0
IDE01464-IDE04741	Rear window defogger-Rear window defogger button	not activated
IDE01464-IDE04744	Rear window defogger-Rear window defogger indicator lamp	OFF
IDE01464-MAS01580	Rear window defogger-Activation	not active
IDE01537-IDE04742	Windshield defogger-Windshield defogger button	not coded/not installed
IDE01537-IDE04743	Windshield defogger-Windshield defogger indicator lamp	not coded/not installed
IDE01537-MAS01580	Windshield defogger-Activation	not coded/not installed
IDE01943-MAS01737	Turn signal-Diagnosis	normal
IDE01943-MAS02248	Turn signal-Signal state	not active
IDE01943-MAS03873	Turn signal-Duty cycle	0	 %
IDE01943-MAS04351	Turn signal-Connector terminal number	36
IDE01943-MAS04352	Turn signal-Connector number	Plug B
IDE02092-IDE02093	Tailgate condition-Status of rear lid lock	not coded/not installed
IDE02092-IDE02133	Tailgate condition-Activation using rear lid unlocking button	OFF
IDE02092-MAS01872	Tailgate condition-Rear lid remote release button	not coded/not installed
IDE02092-MAS02405	Tailgate condition-Pre-engagement contact for rotary latch	closed
IDE02092-MAS02447	Tailgate condition-Release	Enabled
IDE02092-MAS06265	Tailgate condition-Release button in rear lid handle	not activated
IDE02092-MAS06430	Tailgate condition-Main notch contact of rotary latch	closed
IDE02486	Data logger triggering	not active
IDE02488-MAS01632	DWA Interior monitoring-Status	not coded/not installed
IDE02488-MAS04508	DWA Interior monitoring-Alarm detected	not coded/not installed
IDE02515-MAS01737	Low beam-Diagnosis	normal
IDE02515-MAS02248	Low beam-Signal state	not active
IDE02515-MAS03873	Low beam-Duty cycle	0	 %
IDE02515-MAS04351	Low beam-Connector terminal number	5
IDE02515-MAS04352	Low beam-Connector number	Plug C
IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	active
IDE02588-IDE00773	Terminal signals and start release-Terminal 15 status via CAN	active
IDE02588-IDE01351	Terminal signals and start release-Terminal 75 status	On
IDE02588-IDE01715	Terminal signals and start release-Status terminal S	active
IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
IDE02588-IDE06027	Terminal signals and start release-Terminal S status via CAN	active
IDE02588-MAS12787	Terminal signals and start release-Terminal 15 ignition switch signal 1	active
IDE02588-MAS12788	Terminal signals and start release-Terminal 15 ignition switch signal 2	active
IDE02614-MAS02788	Reversing light switch-CAN	not active
IDE02614-MAS05360	Reversing light switch-Discreet wire	not active
IDE02711	Rear Window Wiper	not active
IDE02743-MAS01737	High Beam-Diagnosis	normal
IDE02743-MAS02248	High Beam-Signal state	not active
IDE02743-MAS03873	High Beam-Duty cycle	0	 %
IDE02743-MAS04351	High Beam-Connector terminal number	39
IDE02743-MAS04352	High Beam-Connector number	Plug B
IDE02744-MAS01632	Steering wheel heater-Status	not coded/not installed
IDE02744-MAS02311	Steering wheel heater-Steering wheel heating button	not coded/not installed
IDE02744-MAS04136	Steering wheel heater-Current	0	 A
IDE02744-MAS09758	Steering wheel heater-Temperature sensor	188	 °C
IDE02857-IDE03111	Activation current-Interior light	0	 mA
IDE02857-IDE05533	Activation current-Spray nozzle heater	0	 mA
IDE02857-IDE06012	Activation current-Search lights	0	 mA
IDE02857-MAS01554	Activation current-Left heated seat	0	 mA
IDE02857-MAS01556	Activation current-Right heated seat	0	 mA
IDE02857-MAS05942	Activation current-Windshield and rear window washer pump	0	 mA
IDE02857-ENG128454	Activation current-Cockpittaster_1	65532	 mA
IDE02857-ENG128455	Activation current-Cockpittaster_2	65532	 mA
IDE02857-ENG128456	Activation current-Cockpittaster_3	0	 mA
IDE02857-ENG128457	Activation current-Cockpittaster_4	65532	 mA
IDE02857-ENG128458	Activation current-DWA_Einfachhorn	65532	 mV
IDE02857-ENG126436	Activation current-signal_horn	65533	 mV
IDE02957-MAS01737	Ambient lighting-Diagnosis	not coded/not installed
IDE02957-MAS02248	Ambient lighting-Signal state	not_defined
IDE02957-MAS03873	Ambient lighting-Duty cycle	0	 %
IDE02957-MAS04351	Ambient lighting-Connector terminal number	0
IDE02957-MAS04352	Ambient lighting-Connector number	not_defined
IDE02957-MAS06670	Ambient lighting-Channel	Not available
IDE03111-MAS01737	Interior light-Diagnosis	normal
IDE03111-MAS02248	Interior light-Signal state	active
IDE03111-MAS03873	Interior light-Duty cycle	87	 %
IDE03111-MAS04351	Interior light-Connector terminal number	12
IDE03111-MAS04352	Interior light-Connector number	Plug C
IDE03195-IDE03854	High values for automatic vertical headlight aim-Left front level control system sensor: height value current	0
IDE03195-IDE04144	High values for automatic vertical headlight aim-Left rear level control system sensor: height value current	0
IDE03195-IDE07143	High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage	0	 V
IDE03195-MAS13964	High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor	0
IDE03195-MAS13965	High values for automatic vertical headlight aim-Vehicle level sensor: control voltage	0	 V
IDE03310-MAS01737	Brake light-Diagnosis	normal
IDE03310-MAS02248	Brake light-Signal state	not active
IDE03310-MAS03873	Brake light-Duty cycle	0	 %
IDE03310-MAS04351	Brake light-Connector terminal number	71
IDE03310-MAS04352	Brake light-Connector number	Plug A
IDE03388-IDE01217	Left front heated seat: status-Left heated seat stage	OFF
IDE03388-MAS02201	Left front heated seat: status-Temperature	22.5	 °C
IDE03389-IDE01218	Right front heated seat: status-Right heated seat stage	OFF
IDE03389-MAS02201	Right front heated seat: status-Temperature	22	 °C
IDE03504-IDE02022	Personalized settings-Comfort opening	All windows
IDE03504-IDE03679	Personalized settings-Adaptive light functions	not active
IDE03504-IDE04036	Personalized settings-High beam assistant: status	active
IDE03504-MAS01597	Personalized settings-Sunroof	not active
IDE03504-MAS04322	Personalized settings-Masked continuous high beam	active
IDE03504-MAS06456	Personalized settings-Autolock	active
IDE03504-MAS06457	Personalized settings-autounlock	active
IDE03504-MAS06911	Personalized settings-Status Coming Home	active
IDE03504-MAS06912	Personalized settings-Status Leaving Home	active
IDE03504-MAS07014	Personalized settings-Tourist light	not active
IDE03504-MAS07967	Personalized settings-profile	1
IDE03504-MAS07971	Personalized settings-Electrical rear lid	not active
IDE03504-MAS07972	Personalized settings-Manual door unlock	all
IDE03504-MAS07973	Personalized settings-Rain closure	not active
IDE03504-MAS07978	Personalized settings-Mirror adjustment	INDIVIDUAL
IDE03504-MAS07980	Personalized settings-Mirror lowering	not active
IDE03504-MAS07981	Personalized settings-Automatic mirror fold-in	not active
IDE03504-MAS07982	Personalized settings-Activation sound: theft warning system	active
IDE03504-MAS07983	Personalized settings-Virtual pedal	not active
IDE03504-MAS07984	Personalized settings-Automatic rear window wiper	active
IDE03504-MAS07985	Personalized settings-Coming Home set point	5	 s
IDE03504-MAS07986	Personalized settings-Leaving Home set point	5	 s
IDE03504-MAS07987	Personalized settings-Light intensity	normal
IDE03504-MAS07990	Personalized settings-Comfort flasher	active
IDE03504-MAS07991	Personalized settings-Comfort flasher set point	3
IDE03504-MAS07992	Personalized settings-Sliding beam range	active
IDE03504-MAS07993	Personalized settings-Rain light	active
IDE03504-ENG29901	Personalized settings-Touristenlicht Einstellwert	not active
IDE03638-MAS01737	static AFS light-Diagnosis	normal
IDE03638-MAS02248	static AFS light-Signal state	not active
IDE03638-MAS03873	static AFS light-Duty cycle	0	 %
IDE03638-MAS04351	static AFS light-Connector terminal number	45
IDE03638-MAS04352	static AFS light-Connector number	Plug B
IDE04213	Central locking button	not coded/not installed
IDE04213-IDE07357	Central locking button-Indicator light for central locking	not coded/not installed
IDE04254-MAS06517	Play protection for central locking-Rear spoiler counter	not active
IDE04347-IDE00104	Expanded environmental conditions-DTC	00 00 00
IDE04347-IDE07836	Expanded environmental conditions-Log data	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04925-MAS01737	Daytime running lights-Diagnosis	not coded/not installed
IDE04925-MAS02248	Daytime running lights-Signal state	Measured value not available
IDE04925-MAS03873	Daytime running lights-Duty cycle	0	 %
IDE04925-MAS04351	Daytime running lights-Connector terminal number	0
IDE04925-MAS04352	Daytime running lights-Connector number	not coded/not installed
IDE05042-IDE05043	Emergency flasher button-Emergency flasher indicator lamp	On
IDE05042-MAS02158	Emergency flasher button-Actuation condition	Not operated
IDE05042-MAS03873	Emergency flasher button-Duty cycle	23	 %
IDE05045-IDE05183	Front windshield wiper module-Malfunction left	no error
IDE05045-IDE05184	Front windshield wiper module-Malfunction right	no error
IDE05045-MAS01632	Front windshield wiper module-Status	not active
IDE05045-MAS02282	Front windshield wiper module-Position	park position
IDE05045-MAS03638	Front windshield wiper module-Wipe speed	0	 /min
IDE05045-MAS05057	Front windshield wiper module-Number of wiper cycles	0
IDE05045-MAS05878	Front windshield wiper module-Stage	not coded/not installed
IDE05323-MAS01737	Fog light-Diagnosis	normal
IDE05323-MAS02248	Fog light-Signal state	not active
IDE05323-MAS03873	Fog light-Duty cycle	0	 %
IDE05323-MAS04351	Fog light-Connector terminal number	10
IDE05323-MAS04352	Fog light-Connector number	Plug B
IDE05434-MAS01737	Rear entry light-Diagnosis	not coded/not installed
IDE05434-MAS02248	Rear entry light-Signal state	Measured value not available
IDE05434-MAS03873	Rear entry light-Duty cycle	0	 %
IDE05434-MAS04150	Rear entry light-Side	not_defined
IDE05434-MAS04351	Rear entry light-Connector terminal number	0
IDE05434-MAS04352	Rear entry light-Connector number	not_defined
IDE05533	Spray nozzle heater	not active
IDE05719-IDE05534	Window washer system-Headlamp washer system	not coded/not installed
IDE05719-MAS02339	Window washer system-Windshield washer system	not active
IDE05719-MAS02341	Window washer system-Rear window washer system	not active
IDE05720-IDE02589	Front driver side door status-Rotary latch status	Open
IDE05720-IDE04213	Front driver side door status-Central locking button	Not operated
IDE05720-IDE04214	Front driver side door status-Key switch in door lock	Not operated
IDE05720-MAS06256	Front driver side door status-Status door lock	Signal from door lock: released
IDE05722-IDE02589	Door status: driver side rear-Rotary latch status	closed
IDE05722-IDE04213	Door status: driver side rear-Central locking button	not coded/not installed
IDE05722-MAS06256	Door status: driver side rear-Status door lock	Signal from door lock: released
IDE05727-IDE02589	Front passenger side door status-Rotary latch status	closed
IDE05727-IDE04213	Front passenger side door status-Central locking button	Not operated
IDE05727-IDE04214	Front passenger side door status-Key switch in door lock	Not operated
IDE05727-MAS06256	Front passenger side door status-Status door lock	Signal from door lock: released
IDE05729-IDE02589	Door status: frt. pass. side rear-Rotary latch status	closed
IDE05729-IDE04213	Door status: frt. pass. side rear-Central locking button	not coded/not installed
IDE05729-MAS06256	Door status: frt. pass. side rear-Status door lock	Signal from door lock: released
IDE05730-MAS01737	Luggage compartment light-Diagnosis	not coded/not installed
IDE05730-MAS02248	Luggage compartment light-Signal state	Measured value not available
IDE05730-MAS03873	Luggage compartment light-Duty cycle	0	 %
IDE05730-MAS04351	Luggage compartment light-Connector terminal number	0
IDE05730-MAS04352	Luggage compartment light-Connector number	not_defined
IDE05739-MAS01737	Footwell light-Diagnosis	normal
IDE05739-MAS02248	Footwell light-Signal state	active
IDE05739-MAS03873	Footwell light-Duty cycle	54.5	 %
IDE05739-MAS04351	Footwell light-Connector terminal number	72
IDE05739-MAS04352	Footwell light-Connector number	Plug C
IDE05742-IDE02515	Light switch position-Low beam	not activated
IDE05742-IDE05323	Light switch position-Fog light	not activated
IDE05742-IDE07956	Light switch position-redundant signal line	OFF
IDE05742-MAS00063	Light switch position-OFF	operated
IDE05742-MAS02462	Light switch position-Automatic high beam assist	not activated
IDE05742-MAS03835	Light switch position-Parking light	not activated
IDE05742-MAS03836	Light switch position-Rear fog light	not coded/not installed
IDE05822-MAS01632	DWA Vehicle inclination sensor-Status	not coded/not installed
IDE05822-MAS04508	DWA Vehicle inclination sensor-Alarm detected	not coded/not installed
IDE05825-MAS02594	DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch	not coded/not installed
IDE05825-MAS04247	DWA Interior monitoring/vehicle inclination sensor button-Button	not coded/not installed
IDE05826-MAS01632	DWA Sirens / alarm horn for anti-theft warning system-Status	not coded/not installed
IDE05826-MAS04508	DWA Sirens / alarm horn for anti-theft warning system-Alarm detected	No
IDE05826-MAS04509	DWA Sirens / alarm horn for anti-theft warning system-Alarm activated	No
IDE05827	Alarm horn for anti-theft warning system	not coded/not installed
IDE05829-ENG28562	Rear spoiler history data-Spoiler_Activation_Trigger	NoEntry
IDE05829-ENG28563	Rear spoiler history data-Spoiler_Activation_Trigger_Date	0
IDE05829-ENG28565	Rear spoiler history data-Spoiler_Activation_Trigger_Milage	0	 km
IDE05829-ENG28564	Rear spoiler history data-Spoiler_Activation_Trigger_Time	0
IDE05830-MAS02282	Rear Spoiler-Position	not coded/not installed
IDE05830-ENG115793	Rear Spoiler-Spoiler_Button	not coded/not installed
IDE05830-ENG115792	Rear Spoiler-Spoiler_Cycle_Protection	not coded/not installed
IDE05830-ENG115794	Rear Spoiler-Spoiler_Indication_Light	not coded/not installed
IDE05830-ENG115791	Rear Spoiler-Spoiler_Position	not coded/not installed
IDE05833-MAS00106	Anti-theft warning system: history data-Year	2000
IDE05833-MAS00107	Anti-theft warning system: history data-Month	0
IDE05833-MAS00108	Anti-theft warning system: history data-Day	0
IDE05833-MAS00109	Anti-theft warning system: history data-Hours	0
IDE05833-MAS00110	Anti-theft warning system: history data-Minutes	0
IDE05833-MAS00111	Anti-theft warning system: history data-Seconds	0
IDE05833-MAS00711	Anti-theft warning system: history data-Odometer reading	0	 km
IDE05833-MAS04478	Anti-theft warning system: history data-Cause for alarm activation	No alarm
IDE05834-IDE01718	Driver info-Crash signal	not active
IDE05834-MAS00211	Driver info-Insufficient brake fluid	not active
IDE05834-MAS00212	Driver info-Insufficient washer fluid	not active
IDE05834-MAS00213	Driver info-Insufficient coolant	not active
IDE05834-MAS00214	Driver info-Brake pad wear	not coded/not installed
IDE05836-MAS03637	Rain recognition sensor-Rain quantity	0
IDE05836-MAS03638	Rain recognition sensor-Wipe speed	0
IDE05836-MAS04806	Rain recognition sensor-Splash	not active
IDE05836-MAS04807	Rain recognition sensor-park position	active
IDE05837	Activation for signal horn	not active
IDE05838-MAS01794	Light recognition sensor-Freeway	OFF
IDE05838-MAS02248	Light recognition sensor-Signal state	active
IDE05838-MAS02475	Light recognition sensor-Brightness infrared	2400	 lx
IDE05838-MAS02851	Light recognition sensor-Brightness	240	 lx
IDE05838-MAS04808	Light recognition sensor-Rain	OFF
IDE05838-MAS04809	Light recognition sensor-Darkness	On
IDE05838-MAS04810	Light recognition sensor-Request for light activation	On
IDE05839-MAS01737	Parking light-Diagnosis	normal
IDE05839-MAS02248	Parking light-Signal state	not active
IDE05839-MAS03873	Parking light-Duty cycle	0	 %
IDE05839-MAS04351	Parking light-Connector terminal number	10
IDE05839-MAS04352	Parking light-Connector number	Plug B
IDE05841-MAS06441	Central locking history data-Control-section / cause	autounlock
IDE05841-MAS07519	Central locking history data-Command	Unlocking of entire vehicle
IDE05841-MAS07942	Central locking history data-Additional information	Measured value not available
IDE05841-ENG29969	Central locking history data-command_direction_locking	Lock door
IDE05841-ENG29970	Central locking history data-command_direction_unlocking	no_unlocking
IDE05842-MAS00218	Comfort function history data-Driver door	not active
IDE05842-MAS00219	Comfort function history data-Front Passenger Door	not active
IDE05842-MAS00220	Comfort function history data-Left rear door	not active
IDE05842-MAS00221	Comfort function history data-Right rear door	not active
IDE05842-MAS06441	Comfort function history data-Control-section / cause	keine Bedienstelle
IDE05842-MAS07560	Comfort function history data-Top	not active
IDE05842-MAS07561	Comfort function history data-Sun roof/tilt roof	not active
IDE05842-MAS07941	Comfort function history data-Operating command	Open
IDE06012-MAS01737	Search lights-Diagnosis	normal
IDE06012-MAS02248	Search lights-Signal state	not active
IDE06012-MAS03873	Search lights-Duty cycle	0	 %
IDE06012-MAS04351	Search lights-Connector terminal number	62
IDE06012-MAS04352	Search lights-Connector number	Plug C
IDE06012-MAS15156	Search lights-terminal	Variant A
IDE06091-IDE01440	Humidity sensor: internal-Windshield temperature	-38.1	 °C
IDE06091-MAS04629	Humidity sensor: internal-Sensor temperature	87.5	 °C
IDE06091-MAS04630	Humidity sensor: internal-Relative humidity	127	 %
IDE06091-MAS04647	Humidity sensor: internal-Dew point	-38.1	 °C
IDE06096-IDE03111	Interior lighting-Interior light	100	 %
IDE06096-IDE05724	Interior lighting-Terminal 58xt dimmer	100	 %
IDE06096-IDE05725	Interior lighting-Terminal 58xs dimmer	0	 %
IDE06096-IDE05726	Interior lighting-Terminal 58xd dimmer	100	 %
IDE06096-MAS01634	Interior lighting-Supply voltage	87	 %
IDE06096-MAS04528	Interior lighting-Instrument panel and switch illumination dimmer switch	100	 %
IDE06324-IDE04217	Tank cap lock-Fuel filler door release button	not coded/not installed
IDE06324-MAS01580	Tank cap lock-Activation	not active
IDE06324-MAS06251	Tank cap lock-Contact switch	not coded/not installed
IDE06470-MAS01737	Ambience lighting-Diagnosis	not coded/not installed
IDE06470-MAS02248	Ambience lighting-Signal state	Measured value not available
IDE06470-MAS03873	Ambience lighting-Duty cycle	0	 %
IDE06470-MAS04351	Ambience lighting-Connector terminal number	0
IDE06470-MAS04352	Ambience lighting-Connector number	not coded/not installed
IDE06507-MAS13127	Button in center console-Status of button 1	not coded/not installed
IDE06507-MAS13128	Button in center console-Indicator lamp button 1	not coded/not installed
IDE06507-MAS13130	Button in center console-Status of button 2	not coded/not installed
IDE06507-MAS13131	Button in center console-Indicator lamp button 2	not coded/not installed
IDE06507-MAS13133	Button in center console-Status of button 3	not activated
IDE06507-MAS13134	Button in center console-Indicator lamp button 3	OFF
IDE06507-MAS13136	Button in center console-Indicator lamp button 4	not coded/not installed
IDE06507-MAS13137	Button in center console-Status of button 4	not coded/not installed
IDE06592-MAS05002	Status: special functions-Showroom mode	OFF
IDE06592-MAS05003	Status: special functions-Debug functions	OFF
IDE06644-IDE06864	Vehicle positioning system-Daytime running lights	not coded/not installed
IDE06644-MAS01288	Vehicle positioning system-Signal horn	not coded/not installed
IDE06644-MAS03834	Vehicle positioning system-Emergency signal flashing	not coded/not installed
IDE06644-MAS03835	Vehicle positioning system-Parking light	not coded/not installed
IDE06695-IDE01459	Energy management: last critical state-Energy management heat output control status	0
IDE06695-MAS00107	Energy management: last critical state-Month	0
IDE06695-MAS00108	Energy management: last critical state-Day	0
IDE06695-MAS06555	Energy management: last critical state-Maximum switch-off priority while driving	0
IDE06695-MAS06570	Energy management: last critical state-Number of critical operation cycles	0
IDE06695-ENG28924	Energy management: last critical state-Anz_erreichte_Max_Freigaben	0
IDE06695-ENG28921	Energy management: last critical state-Anz_krit_Betriebszyklen	0
IDE06695-ENG28922	Energy management: last critical state-Bedingung_Tab_NQ	0
IDE06695-ENG28920	Energy management: last critical state-min_prio_Tab_K	0
IDE06695-ENG28919	Energy management: last critical state-min_prio_Tab_M	0
IDE06695-ENG28923	Energy management: last critical state-min_prio_Tab_NQ	0
IDE06695-ENG99063	Energy management: last critical state-Year	2000
IDE06864-MAS01737	Daytime running lights-Diagnosis	normal
IDE06864-MAS02248	Daytime running lights-Signal state	not active
IDE06864-MAS03873	Daytime running lights-Duty cycle	0	 %
IDE06864-MAS04351	Daytime running lights-Connector terminal number	10
IDE06864-MAS04352	Daytime running lights-Connector number	Plug B
IDE07145-MAS06772	Component protection properties-Component protection generation	2
IDE07145-MAS06773	Component protection properties-KS Standard software main version nummer	2
IDE07145-MAS06774	Component protection properties-KS Standard software secondary version number	0
IDE07145-MAS06775	Component protection properties-KS Standard software correct number	1
IDE07145-MAS06776	Component protection properties-Komponent protection role	KS Slave
IDE07145-MAS06781	Component protection properties-Secure Hardware Extension	Not Used
IDE07145-MAS06782	Component protection properties-Master ECU Key	not administered by component protection
IDE07145-MAS06785	Component protection properties-GFA key	used
IDE07145-MAS06786	Component protection properties-SSW RND Generation	Not Used
IDE07145-MAS06787	Component protection properties-Indiv Key Generation	Not Used
IDE07145-MAS06788	Component protection properties-SHE Secure Boot	Not Used
IDE07145-MAS07187	Component protection properties-KS Data version	1
IDE07145-MAS09609	Component protection properties-Status IKA start key	not active
IDE07145-MAS09610	Component protection properties-Status GFA Key	valid
IDE07145-MAS09611	Component protection properties-Status Master ECU Key	stored
IDE07187-MAS06538	Level control system sensor-Left Front Level Control System Sensor: PWM signal	655.35	 %
IDE07187-MAS06539	Level control system sensor-Left Rear Level Control System Sensor: PWM signal	655.35	 %
IDE07187-MAS06540	Level control system sensor-Left front level control system sensor: frequency	6553.5	 Hz
IDE07187-MAS06541	Level control system sensor-Left Rear Left Control System Sensor: frequency	6553.5	 Hz
IDE07187-MAS06542	Level control system sensor-Vehicle level sensor: supply voltage	65.535	 V
IDE07344-IDE00542	Sunroof shade-Excessive temperature protection	not active
IDE07344-IDE03114	Sunroof shade-Comfort function	not active
IDE07344-MAS01979	Sunroof shade-Adapting	Not adapted
IDE07344-MAS02282	Sunroof shade-Position	0	 %
IDE07344-MAS02447	Sunroof shade-Release	not active
IDE07344-MAS03656	Sunroof shade-Reverse	not active
IDE07344-MAS05563	Sunroof shade-Norming	not normed
IDE07345-MAS07997	Sunroof front closed position switch-Rotary switch activation	Implausible
IDE07345	Sunroof front closed position switch	not activated
IDE07345-ENG122183	Sunroof front closed position switch-rotary_switch_position	closed
IDE07346	Sunroof shade switches	not activated
IDE08125-MAS01458	Left cabin heater-Operating condition	not coded/not installed
IDE08125-MAS06651	Left cabin heater-PTC heater element: current consumption	not coded/not installed
IDE08125-MAS06652	Left cabin heater-Blower motor: speed	not coded/not installed
IDE08125-MAS06653	Left cabin heater-Indicator light for head area heater	not coded/not installed
IDE08126-MAS01458	Right cabin heater-Operating condition	not coded/not installed
IDE08126-MAS06651	Right cabin heater-PTC heater element: current consumption	not coded/not installed
IDE08126-MAS06652	Right cabin heater-Blower motor: speed	not coded/not installed
IDE08126-MAS06653	Right cabin heater-Indicator light for head area heater	not coded/not installed
IDE08177-MAS06456	Central locking-Autolock	not active
IDE08177-MAS06740	Central locking-Release button in rear lid handle locked	not active
IDE08177-MAS09894	Central locking-Status exterior skin	Open
IDE08177-MAS09896	Central locking-Act. condition: Status central locking internal locked	not active
IDE08177-MAS09897	Central locking-Act. condition: Status central locking external locked	not active
IDE08177-MAS09898	Central locking-Act. condition: Status central locking safe	not active
IDE08177-MAS09900	Central locking-Spec. condition: Status central lock	Signal from door lock: released
IDE08177-ENG09185	Central locking-Load_compartment_closing	not coded/not installed
IDE08211-MAS00106	History data control module reset-Year	2000
IDE08211-MAS00107	History data control module reset-Month	0
IDE08211-MAS00108	History data control module reset-Day	0
IDE08211-MAS00109	History data control module reset-Hours	0
IDE08211-MAS00110	History data control module reset-Minutes	0
IDE08211-MAS03129	History data control module reset-Reset counter	9
IDE08211-MAS06734	History data control module reset-last cause of reset	Application 9
IDE08343	Immobilizer Challenge	0A 62 FA E1
IDE08949-MAS07867	Operating current: light driver-Conn. pin 0	0	 mA
IDE08949-MAS07868	Operating current: light driver-Conn. pin 1	0	 mA
IDE08949-MAS07869	Operating current: light driver-Conn. pin 2	0	 mA
IDE08949-MAS07870	Operating current: light driver-Conn. pin 3	0	 mA
IDE08949-MAS07871	Operating current: light driver-Conn. pin 4	0	 mA
IDE08949-MAS07872	Operating current: light driver-Conn. pin 5	0	 mA
IDE08949-MAS07873	Operating current: light driver-Conn. pin 6	0	 mA
IDE08949-MAS07874	Operating current: light driver-Conn. pin 7	0	 mA
IDE08949-MAS07875	Operating current: light driver-Conn. pin 8	0	 mA
IDE08949-MAS07876	Operating current: light driver-Conn. pin 9	0	 mA
IDE08949-MAS07877	Operating current: light driver-Conn. pin 10	0	 mA
IDE08949-MAS07878	Operating current: light driver-Conn. pin 11	0	 mA
IDE08949-MAS07879	Operating current: light driver-Conn. pin 12	0	 mA
IDE08949-MAS07880	Operating current: light driver-Conn. pin 13	0	 mA
IDE08949-MAS07881	Operating current: light driver-Conn. pin 14	0	 mA
IDE08949-MAS07882	Operating current: light driver-Conn. pin 15	0	 mA
IDE08949-MAS07883	Operating current: light driver-Conn. pin 16	0	 mA
IDE08949-MAS07884	Operating current: light driver-Conn. pin 17	0	 mA
IDE08949-MAS07885	Operating current: light driver-Conn. pin 18	0	 mA
IDE08949-MAS07886	Operating current: light driver-Conn. pin 19	0	 mA
IDE08949-MAS07887	Operating current: light driver-Conn. pin 20	0	 mA
IDE08949-MAS07888	Operating current: light driver-Conn. pin 21	0	 mA
IDE08949-MAS07889	Operating current: light driver-Conn. pin 22	0	 mA
IDE08949-MAS07890	Operating current: light driver-Conn. pin 23	0	 mA
IDE08949-MAS07891	Operating current: light driver-Conn. pin 24	0	 mA
IDE08949-MAS07892	Operating current: light driver-Conn. pin 25	0	 mA
IDE08949-MAS07893	Operating current: light driver-Conn. pin 26	0	 mA
IDE08949-MAS07894	Operating current: light driver-Conn. pin 27	0	 mA
IDE08949-MAS07895	Operating current: light driver-Conn. pin 28	0	 mA
IDE08949-MAS07896	Operating current: light driver-Conn. pin 29	0	 mA
IDE08949-MAS07897	Operating current: light driver-Conn. pin 30	40	 mA
IDE08949-MAS07898	Operating current: light driver-Conn. pin 31	0	 mA
IDE08949-MAS07899	Operating current: light driver-Conn. pin 32	0	 mA
IDE08949-MAS07900	Operating current: light driver-Conn. pin 33	0	 mA
IDE08949-MAS07901	Operating current: light driver-Conn. pin 34	0	 mA
IDE09065-MAS07964	Status: remote start-Engine run time after remote start	0	 s
IDE09065-MAS16464	Status: remote start-Number of RemoteStarts carried out	0
IDE09850-MAS07146	Garage Door Opener Operating Unit-Button 1	not coded/not installed
IDE09850-MAS07147	Garage Door Opener Operating Unit-Button 2	not coded/not installed
IDE09850-MAS07148	Garage Door Opener Operating Unit-Button 3	not coded/not installed
IDE11134-IDE01943	Light sequence HU test result-Turn signal	Installed: not active
IDE11134-IDE02515	Light sequence HU test result-Low beam	Installed: not active
IDE11134-IDE02614	Light sequence HU test result-Reversing light switch	Installed: not active
IDE11134-IDE02743	Light sequence HU test result-High Beam	Installed: not active
IDE11134-IDE03310	Light sequence HU test result-Brake light	Installed: not active
IDE11134-IDE03638	Light sequence HU test result-static AFS light	Installed: not active
IDE11134-IDE05323	Light sequence HU test result-Fog light	Installed: not active
IDE11134-IDE05839	Light sequence HU test result-Parking light	not installed / not active
IDE11134-IDE06470	Light sequence HU test result-Ambience lighting	not installed / not active
IDE11134-IDE06864	Light sequence HU test result-Daytime running lights	Installed: not active
IDE11134-MAS02354	Light sequence HU test result-Headlamp flasher	Installed: not active
IDE11134-MAS03835	Light sequence HU test result-Parking light	Installed: not active
IDE11134-MAS03836	Light sequence HU test result-Rear fog light	not installed / not active
IDE11134-MAS11025	Light sequence HU test result-Status	no restriction
IDE11350-MAS12597	Sunlight photo sensor-Sun intensity left	327670	 W/m²
IDE11350-MAS12598	Sunlight photo sensor-Sun intensity right	327670	 W/m²
IDE11668-MAS06256	Driver side rear sliding door: central locking signals-Status door lock	not coded/not installed
IDE11668-MAS06431	Driver side rear sliding door: central locking signals-Door contact switch	not coded/not installed
IDE11668-MAS06433	Driver side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
IDE11669-MAS06256	Passenger side rear sliding door: central locking signals-Status door lock	not coded/not installed
IDE11669-MAS06431	Passenger side rear sliding door: central locking signals-Door contact switch	not coded/not installed
IDE11669-MAS06433	Passenger side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
IDE11670-MAS06256	Rear wing door: central locking signals-Status door lock	not coded/not installed
IDE11670-MAS06431	Rear wing door: central locking signals-Door contact switch	not coded/not installed
IDE11670-MAS06433	Rear wing door: central locking signals-Door lock: safe status	not coded/not installed
IDE11727-IDE04806	Function of the central console button-Driving profile selection button	LED installed
IDE11727-MAS13125	Function of the central console button-Function of button 1	not coded/not installed
IDE11727-MAS13129	Function of the central console button-Function of button 2	not coded/not installed
IDE11727-MAS13132	Function of the central console button-Function of button 3	Driving program
IDE11727-MAS13135	Function of the central console button-Function of button 4	not coded/not installed
IDE11943-MAS01737	Signature light-Diagnosis	not coded/not installed
IDE11943-MAS02248	Signature light-Signal state	Measured value not available
IDE11943-MAS03873	Signature light-Duty cycle	0	 %
IDE11943-MAS04351	Signature light-Connector terminal number	0
IDE11943-MAS04352	Signature light-Connector number	not coded/not installed
IDE11999-IDE03853	High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted	-100
IDE11999-IDE04143	High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted	-100
IDE12060	Headlight range adjustment counter	00 00 00 00
IDE12212	Cause control module incorrectly coded	Not Present
IDE12940-IDE01268	Lever functions of the steering column electronics-Windshield wiper	not coded/not installed
IDE12940-IDE02335	Lever functions of the steering column electronics-Signal light switch position	not coded/not installed
IDE12940-IDE02711	Lever functions of the steering column electronics-Rear Window Wiper	not coded/not installed
IDE12940-MAS00232	Lever functions of the steering column electronics-MFI button UP	not_defined
IDE12940-MAS00233	Lever functions of the steering column electronics-MFI button DOWN	not_defined
IDE12940-MAS00234	Lever functions of the steering column electronics-MFI button RESET / OK	not_defined
IDE12940-MAS00242	Lever functions of the steering column electronics-Driver assistance systems button	not coded/not installed
IDE12940-MAS00243	Lever functions of the steering column electronics-Buttons for driver assistance systems: status	not coded/not installed
IDE12940-MAS01288	Lever functions of the steering column electronics-Signal horn	not coded/not installed
IDE12940-MAS02338	Lever functions of the steering column electronics-Windshield wiper: intermittent stage	not coded/not installed
IDE12940-MAS02339	Lever functions of the steering column electronics-Windshield washer system	not coded/not installed
IDE12940-MAS02341	Lever functions of the steering column electronics-Rear window washer system	not coded/not installed
IDE12940	Lever functions of the steering column electronics	not coded/not installed
IDE80251-MAS06439	Head area heater-Crash status	not coded/not installed
IDE80251-MAS06646	Head area heater-Head area heater left: specified level	not coded/not installed
IDE80251-MAS06647	Head area heater-Head area heater right: specified level	not coded/not installed
IDE80251-MAS06648	Head area heater-Continuation at terminal 15 on	not coded/not installed
IDE80251-MAS06649	Head area heater-Left front seat occupation status	not coded/not installed
IDE80251-MAS06650	Head area heater-Right front occupation status	not coded/not installed
MAS00043-IDE00019	Supply voltage: Terminal 30-Voltage terminal 30	14.65	 V
MAS00043-IDE05835	Supply voltage: Terminal 30-Supply voltage for central locking	14.5	 V
MAS00043-IDE05967	Supply voltage: Terminal 30-Voltage terminal 30 left	14.55	 V
MAS00043-IDE05968	Supply voltage: Terminal 30-Voltage terminal 30 right	14.55	 V
MAS00043-IDE08734	Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system	14.45	 V
MAS00043-IDE08735	Supply voltage: Terminal 30-Supply voltage for seat heater	14.5	 V
MAS00043-MAS00362	Supply voltage: Terminal 30-Battery voltage	8.45	 V
MAS00043-MAS07472	Supply voltage: Terminal 30-Battery voltage BEM	14.4	 V
MAS00043-MAS07473	Supply voltage: Terminal 30-Test voltage rear window defogger	0	 V
MAS00043-MAS07474	Supply voltage: Terminal 30-Test voltage windshield defogger	0	 V
MAS00179-MAS04422	Brake Light Switch-Brake light signal via CAN	OFF
MAS00179-MAS07313	Brake Light Switch-Brake light signal via HW	OFF
MAS00464-MAS00106	Standard - ambient data 1-Year	2018
MAS00464-MAS00107	Standard - ambient data 1-Month	8
MAS00464-MAS00108	Standard - ambient data 1-Day	26
MAS00464-MAS00109	Standard - ambient data 1-Hours	11
MAS00464-MAS00110	Standard - ambient data 1-Minutes	16
MAS00464-MAS00111	Standard - ambient data 1-Seconds	26
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
MAS00829-MAS00244	Access and start authorization-Awakening wire	not coded/not installed
MAS00829-MAS01763	Access and start authorization-Signal Strength	0
MAS00829-MAS07866	Access and start authorization-Duration: last awakening wire actua.	0	 ms
MAS01281-MAS01737	Back-up light-Diagnosis	normal
MAS01281-MAS02248	Back-up light-Signal state	not active
MAS01281-MAS03873	Back-up light-Duty cycle	0	 %
MAS01281-MAS04351	Back-up light-Connector terminal number	11
MAS01281-MAS04352	Back-up light-Connector number	Plug C
MAS01431-IDE01442	Vehicle key with remote control-Pressing a button	not activated
MAS01431-IDE01839	Vehicle key with remote control-Battery charge condition	Not available
MAS01431-MAS00077	Vehicle key with remote control-Immobilizer	OK
MAS01431-MAS01551	Vehicle key with remote control-Key number	255
MAS01431-MAS05048	Vehicle key with remote control-Number of transmitters adapted	2
MAS01431-MAS06362	Vehicle key with remote control-Code in detection area	Not available
MAS01490-IDE02744	Energy management-Steering wheel heater	Enabled
MAS01490-IDE04216	Energy management-Mirror heater	Enabled
MAS01490-IDE80251	Energy management-Head area heater	not coded/not installed
MAS01490-MAS01535	Energy management-Rear window defogger	Enabled
MAS01490-MAS01563	Energy management-Auxiliary Air Heater	not coded/not installed
MAS01490-MAS01564	Energy management-Windshield defogger	not coded/not installed
MAS01490-MAS01632	Energy management-Status	not active
MAS01490-MAS02390	Energy management-Shutoff	67
MAS01490-MAS05795	Energy management-Rear seat heater	Enabled
MAS01490-MAS05796	Energy management-Emergency shut-down	0
MAS01490-MAS05887	Energy management-Battery cut out relay 2	not enabled
MAS01490-MAS06551	Energy management-Seat ventilation	not coded/not installed
MAS01490-MAS06552	Energy management-Seat heater front	Enabling stage 3
MAS01490-MAS06553	Energy management-Display consumer switch-off	not active
MAS01490-MAS06554	Energy management-Switch-off priority while driving	0
MAS01490-MAS06555	Energy management-Maximum switch-off priority while driving	6
MAS01490-MAS06556	Energy management-Switch-off with voltage drops	0
MAS01490-MAS06557	Energy management-Switch-off priority with vehicle crash	0
MAS01490-MAS06558	Energy management-Current negative charge balance	0	 %
MAS01490-MAS06559	Energy management-Switch-off priority with engine off	0
MAS01490-MAS06560	Energy management-Short distance drive	1
MAS01597-IDE00542	Sunroof-Excessive temperature protection	not active
MAS01597-IDE03114	Sunroof-Comfort function	not active
MAS01597-MAS01979	Sunroof-Adapting	Not adapted
MAS01597-MAS02282	Sunroof-Position	0	 %
MAS01597-MAS02447	Sunroof-Release	not active
MAS01597-MAS03656	Sunroof-Reverse	not active
MAS01597-MAS05563	Sunroof-Norming	not normed
MAS01597-MAS05737	Sunroof-Position	Tilt out posi.
MAS03835-MAS01737	Parking light-Diagnosis	normal
MAS03835-MAS02248	Parking light-Signal state	not active
MAS03835-MAS03873	Parking light-Duty cycle	0	 %
MAS03835-MAS04351	Parking light-Connector terminal number	10
MAS03835-MAS04352	Parking light-Connector number	Plug B
MAS03836-MAS01737	Rear fog light-Diagnosis	not coded/not installed
MAS03836-MAS02248	Rear fog light-Signal state	Measured value not available
MAS03836-MAS03873	Rear fog light-Duty cycle	0	 %
MAS03836-MAS04351	Rear fog light-Connector terminal number	0
MAS03836-MAS04352	Rear fog light-Connector number	not coded/not installed
MAS07959-IDE00787	Remote start history data-Cause for cancellation	no reason for cancellation
MAS07959-MAS00107	Remote start history data-Month	15
MAS07959-MAS00108	Remote start history data-Day	31
MAS07959-MAS00109	Remote start history data-Hours	31
MAS07959-MAS00110	Remote start history data-Minutes	63
MAS07959-MAS07960	Remote start history data-Stop or cancel cause	No reason for prevention
MAS08228-MAS01632	Light sensor-Status	not coded/not installed
MAS08228-MAS02851	Light sensor-Brightness	22860	 lx
MAS08228-MAS04121	Light sensor-Voltage	25.4	 V
MAS13141	Test voltage	0	 V
ENG116910	Control unit internal measured value (supplier)	31 36 30 32 30 30 30 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG117285-ENG115839	Cycle_Protection_Counter-central_locking_cycle_protection_counter	0
ENG117285-ENG115840	Cycle_Protection_Counter-general_cycle_protection_counter	0
ENG117285-ENG124947	Cycle_Protection_Counter-last_wake_up	keine Stoerschutzursache
ENG116908-ENG115779	Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an	0	 H
ENG116908-ENG115778	Ecu_Intern_Meas._Values_2-Hours_of_operation	0	 H
ENG116908-ENG115775	Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper	0
ENG116908-ENG115776	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper	0
ENG116908-ENG115777	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper	0
ENG117286-ENG116724	Kopfraumheizung_Entwicklung-KRH_l_Error	not coded/not installed
ENG117286-ENG116725	Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit	not coded/not installed
ENG117286-ENG116723	Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error	not coded/not installed
ENG117286-ENG116727	Kopfraumheizung_Entwicklung-KRH_l_PTC_Error	not coded/not installed
ENG117286-ENG116726	Kopfraumheizung_Entwicklung-KRH_l_ResponseError	not coded/not installed
ENG117286-ENG116730	Kopfraumheizung_Entwicklung-KRH_r_Error	not coded/not installed
ENG117286-ENG116731	Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit	not coded/not installed
ENG117286-ENG116728	Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error	not coded/not installed
ENG117286-ENG116729	Kopfraumheizung_Entwicklung-KRH_r_PTC_Error	not coded/not installed
ENG117286-ENG116732	Kopfraumheizung_Entwicklung-KRH_r_ResponseError	not coded/not installed
ENG116909-ENG107391	LIN activity-LIN 1	active
ENG116909-ENG107392	LIN activity-LIN 2	not coded/not installed
ENG116909-ENG114948	LIN activity-LIN 3	not coded/not installed
ENG116909-ENG114949	LIN activity-LIN 4	not coded/not installed
ENG116909-ENG114950	LIN activity-LIN 5	not coded/not installed
ENG116909-ENG114951	LIN activity-LIN 6	not coded/not installed
ENG116793	Monitor 1	00 00 00 00 00 00 00 00
ENG116802	Monitor 10	00 00 00 00 00 00 00 00
ENG116794	Monitor 2	00 00 00 00 00 00 00 00
ENG116795	Monitor 3	00 00 00 00 00 00 00 00
ENG116796	Monitor 4	00 00 00 00 00 00 00 00
ENG116797	Monitor 5	00 00 00 00 00 00 00 00
ENG116798	Monitor 6	00 00 00 00 00 00 00 00
ENG116799	Monitor 7	00 00 00 00 00 00 00 00
ENG116800	Monitor 8	00 00 00 00 00 00 00 00
ENG116801	Monitor 9	00 00 00 00 00 00 00 00
ENG128380	Parametermonitor_0	82 14 64 64 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116806	Parametermonitor_1	00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG130145	Parametermonitor_10	00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A A7 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116807	Parametermonitor_2	0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116808-ENG115827	Parametermonitor_3-parameter_monitor_3_climatic	FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116808-ENG115828	Parametermonitor_3-parameter_monitor_3_wiper	0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116809	Parametermonitor_4	04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116810	Parametermonitor_5	0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116811	Parametermonitor_6	00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116911	Parametermonitor_7	00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116812	Parametermonitor_FF	00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG126653-MAS00107	Personalized_Account_Key_History-Month	8
ENG126653-MAS00108	Personalized_Account_Key_History-Day	26
ENG126653-MAS00109	Personalized_Account_Key_History-Hours	9
ENG126653-MAS00110	Personalized_Account_Key_History-Minutes	18
ENG126653-MAS01551	Personalized_Account_Key_History-Key number	1
ENG126653-ENG28771	Personalized_Account_Key_History-Account	2
ENG126652-MAS03692	Personalized_key__Setting-Key 1	1
ENG126652-MAS03693	Personalized_key__Setting-Key 2	1
ENG126652-MAS03694	Personalized_key__Setting-Key 3	0
ENG126652-MAS03695	Personalized_key__Setting-Key 4	0
ENG126652-MAS03696	Personalized_key__Setting-Key 5	0
ENG126652-MAS03697	Personalized_key__Setting-Key 6	0
ENG126652-MAS03698	Personalized_key__Setting-Key 7	0
ENG126654-MAS00107	Personalized_Signals-Month	8
ENG126654-MAS00108	Personalized_Signals-Day	26
ENG126654-MAS00109	Personalized_Signals-Hours	9
ENG126654-MAS00110	Personalized_Signals-Minutes	18
ENG126654-ENG30061	Personalized_Signals-Perso_Aktiv	1
ENG126654-ENG28925	Personalized_Signals-Perso_Bedienstelle	0
ENG126654-ENG28926	Personalized_Signals-Perso_Freigabe_Verstellung	0
ENG126654-ENG28772	Personalized_Signals-Perso_Konto	2
ENG126654-ENG28775	Personalized_Signals-Perso_Status	1
ENG126654-ENG28773	Personalized_Signals-Perso_Steuerung	0
ENG126654-ENG28774	Personalized_Signals-Perso_Steuerungs_parameter	0
ENG116792-ENG115817	Power up history-Funktionsanforderung	1
ENG130589-MAS16304	Remotestart_Monitor-Number of driver takeovers from RemoteStart	0
ENG130589-MAS16305	Remotestart_Monitor-Number of duplicate activations	0
ENG130589-MAS16306	Remotestart_Monitor-Number of incorrect takeovers	0
ENG130589-MAS16307	Remotestart_Monitor-Average running time: group 1	0
ENG130589-MAS16308	Remotestart_Monitor-Average running time: group 2	0
ENG130589-MAS16309	Remotestart_Monitor-Average running time: group 3	0
ENG130589-MAS16333	Remotestart_Monitor-Number of RemoteStarts	0
ENG130589-MAS16334	Remotestart_Monitor-RemoteStart cancellations counter	0
ENG116790-MAS00711	Supply voltage history-Odometer reading	22	 km
ENG116790-ENG115814	Supply voltage history-highest voltage ever measured	15.6	 V
ENG116790-ENG115815	Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung	15	 V
ENG116790-ENG115816	Supply voltage history-voltage measurement: intern	14.6	 V
ENG116791	Temperatures	23.5	 °C
ENG116907-IDE00020	Zusaetzliche Umgebungsdaten-Terminal 15 status	On
ENG116907-IDE01716	Zusaetzliche Umgebungsdaten-Terminal 50 status	OFF
ENG116907-IDE02515	Zusaetzliche Umgebungsdaten-Low beam	not activated
ENG116907-IDE07956	Zusaetzliche Umgebungsdaten-redundant signal line	infinite
ENG116907-MAS01957	Zusaetzliche Umgebungsdaten-Outside air temperature	23.5	 °C
ENG116907-MAS02462	Zusaetzliche Umgebungsdaten-Automatic high beam assist	not activated
ENG116907-MAS02788	Zusaetzliche Umgebungsdaten-CAN	On
ENG116907-MAS03835	Zusaetzliche Umgebungsdaten-Parking light	not activated
ENG116907-MAS04121	Zusaetzliche Umgebungsdaten-Voltage	14.6	 V
ENG116907-MAS06466	Zusaetzliche Umgebungsdaten-Parking light left	not activated
ENG116907-MAS06467	Zusaetzliche Umgebungsdaten-Parking light right	not activated
ENG116907-ENG124952	Zusaetzliche Umgebungsdaten-last_wakeup	keine Stoerschutzursache
ENG116907-ENG09169	Zusaetzliche Umgebungsdaten-LDS 0-Stellung	operated
ENG116907-ENG115838	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN)	OFF
ENG116907-ENG115837	Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW)	OFF
Elapsed Time: 00:41
Dana
Western PA, USA
15-Airbags
adpmap-15-5Q0-959-655-J_3VWH17AU5JM758941-20180826-1119.CSV
;SW:5Q0-959-655-J   HW:5Q0-959-655-J ---  Airbags
;Component:AirbagVW20    010 0830	 Coding:8CCCFC00000000005000001AC24800000065
;EV_AirbaVW20SMEVW37X	2144	EV_AirbaVW20SMEVW37X.rod
;Sunday	26	August	2018	11:19:10:04045
;VCID: 47C851756F2D08EF108-8012
IDE06314-Calibration data: pre-crash	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	18
MAS00975-IDE01755-Airbag adaptations-Rollover protection system	not defined 	8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery	not defined 	8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter	activated 	8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter	activated 	8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter	activated 	8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter	activated 	8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter	not defined 	8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter	not defined 	8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter	activated 	8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter	activated 	8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter	not defined 	8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter	not defined 	8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter	activated 	8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter	activated 	8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter	not defined 	8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter	not defined 	8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt	not defined 	8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition	not defined 	8
MAS00975-MAS00079-Airbag adaptations-Key switch	Airbag deactivation key switch not parameterized 	8
MAS00975-MAS00478-Airbag adaptations-Reserved	2	8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood	not defined 	8
Elapsed Time: 00:03
blockmap-15-5Q0-959-655-J_3VWH17AU5JM758941-20180826-1118.CSV
;Sunday	26	August	2018	11:18:59:04045
IDE00821	Safety belt switch 2nd row driver side	not installed
IDE00822	Safety belt switch 2nd row frt.passenger side	not installed
IDE00823	Safety belt switch 2nd row center	not installed
IDE00824	Driver side 3rd row seat belt switch	not installed
IDE00825	Passenger side 3rd row seat belt switch	not installed
IDE00919	Driver side airbag igniter ohm value	3.1	 Ohm
IDE00956	Occupation status: frt.passenger seat	Adult
IDE01100	Passenger side airbag igniter ohm value	2.3	 Ohm
IDE01101	Passenger side airbag igniter 2 ohm value	2.2	 Ohm
IDE01102	Driver's side airbag igniter ohm value	2.5	 Ohm
IDE01103	Passenger side side airbag igniter ohm value	2.5	 Ohm
IDE01104	driver side rear airbag igniter ohm value	no measured value present
IDE01105	Ft. pass.side rear airbag igniter ohm value	no measured value present
IDE01106	Driver side head curtain airbag igniter ohm value	2.4	 Ohm
IDE01107	Frt.pass. side head curtain airbag igniter ohm value	2.4	 Ohm
IDE01108	Driver side knee airbag igniter ohm value	no measured value present
IDE01109	Frt.pass. side knee airbag igniter ohm value	no measured value present
IDE01110	Driver side belt tensioner igniter ohm value	2.4	 Ohm
IDE01111	Frt.pass. side belt tensioner igniter ohm value	2.4	 Ohm
IDE01112	Driver side belt tensioner igniter 2 ohm value	2.2	 Ohm
IDE01113	Frt.pass. side belt tensioner igniter 2 ohm value	2.3	 Ohm
IDE01114	Driver side belt force limiter igniter ohm value	2.4	 Ohm
IDE01115	side belt force limiter igniter ohm value	2.4	 Ohm
IDE01116	driver side rear belt tensioner igniter ohm value	no measured value present
IDE01117	Passenger side rear belt tensioner igniter ohm value	no measured value present
IDE01119	Battery open circuit igniter ohm value	no measured value present
IDE01193	Driver belt tensioner ohm value	too Low
IDE01194	Frt.pass. belt tensioner ohm value	too Low
IDE01195	Front passenger side seat occupancy detection: Ohm value	no measured value present
IDE01197	Key switch contact 1 ohm value	too High
IDE01198	Key switch contact 2 ohm value	too High
IDE01200	Driver seat position sensor current value	6.1	 mA
IDE01201	Frt.pass. seat position sensor current value	6	 mA
IDE01205	Safety belt switch 2nd row driver side ohm value	no measured value present
IDE01206	Safety belt switch 2nd row frt.pass. side ohm value	no measured value present
IDE01207	Safety belt switch center 2nd row ohm value	no measured value present
IDE01208	Seat belt switch 3rd row driver side ohm value	no measured value present
IDE01209	Seat belt switch 3rd row frt.pass. side ohm value	no measured value present
IDE01271	Number of rollover bar deployments	0
IDE01555	Number of frontal crashes	0
IDE01556	Number of side crashes driver side	0
IDE01557	Number of side crashes frt.pass. side	0
IDE01558	Number of rear crashes	0
IDE01559	Number of rollover crashes	0
IDE02246	Number of activations of pedestrian protection	0
IDE02852	Igniter for battery interrupt: high voltage battery	not installed
IDE02853	Igniter for batt. interrupt: high volt. batt. ohm value	no measured value present
IDE03870	Seat occupied recognition malfunction status	0
IDE06959	Seat occupant detection: diagnosis signal	33.5	 %
IDE06960	Seat occupant detection: msmt. signal	17	 %
IDE06961	Seat occupant detection: ref. signal	2	 %
MAS00001	Driver airbag igniter	correct
MAS00003	Passenger airbag igniter	correct
MAS00004	Front passenger airbag igniter 2	correct
MAS00005	Driver thorax airbag igniter	correct
MAS00006	Front passenger side airbag igniter	correct
MAS00007	Driver side rear thorax airbag igniter	cannot be measured currently
MAS00008	Passenger side rear thorax airbag igniter	cannot be measured currently
MAS00009	Driver head curtain airbag igniter	correct
MAS00010	Front passenger head curtain airbag igniter	correct
MAS00011	Driver knee airbag igniter	cannot be measured currently
MAS00012	Front passenger knee airbag igniter	cannot be measured currently
MAS00013	Driver side seat belt tension igniter	correct
MAS00014	Front passenger side seat belt tension igniter	correct
MAS00015	Driver seat belt tensioner igniter 2	correct
MAS00016	Front passenger side seat belt tensioner igniter 2	correct
MAS00017	Driver side belt force limiter igniter	correct
MAS00018	Front passenger side belt force limiter igniter	correct
MAS00019	Driver side rear safety belt tension igniter	cannot be measured currently
MAS00020	Passenger side rear safety belt tension igniter	cannot be measured currently
MAS00022	Igniter for battery interrupt	cannot be measured currently
MAS00025	Driver seat belt switch	not connected
MAS00026	Front passenger side safety belt switch	not connected
MAS00030	Seat occupied recognition	assigned
MAS00031	Airbag deactivation status	On
MAS00032	Key switch terminal 1	not installed
MAS00033	Key switch terminal 2	not installed
MAS00035	Seat position sensor: driver side	Rear
MAS00036	Seat position sensor: front passenger side	Rear
MAS00037	Calibration status	0
MAS00044	Supply voltage: Terminal 15	14.5	 V
MAS01634	Supply voltage	correct
Elapsed Time: 00:10
Dana
Western PA, USA
16-Steering wheel
adpmap-16-5Q0-953-507-GH_3VWH17AU5JM758941-20180826-1119.CSV
;SW:5Q0-953-507-GH   HW:5Q0-953-549-E ---  Steering wheel
;Component:Lenks. Modul  003 0140	 Coding:0410
;EV_SMLSKLOMQB	20002	EV_SMLSKLOMQB_VW37.rod
;Sunday	26	August	2018	11:19:20:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 025E8061048FEDC7876-8056
ENG126411-p_k_i	0.040 %/s	1
ENG126415-p_k_i_offset	4 K	1
ENG126410-p_k_p	13.00%	1
ENG126419-p_leistung_lrh	110 W	1
ENG126417-p_n_fehler_p_verriegelt	250	1
ENG120504-p_s_NWDF_spg	0	1
ENG102189-p_t_blinker_entprellen	40 ms	1
ENG102332-p_t_blinker_err_el_kurzschluss	200 ms	1
ENG104011-p_t_blinker_err_el_unterbrechung	1000 ms	1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus	5000 ms	1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein	300 s	1
ENG104185-p_t_blinker_err_gra_haengt_aus	5000 ms	1
ENG100988-p_t_blinker_err_gra_haengt_ein	300 s	1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus	5000 ms	1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein	300 s	1
ENG100923-p_t_blinker_err_unplausibel	200 ms	1
ENG103471-p_t_blinker_gra_entprellen	40 ms	1
ENG101294-p_t_blinker_sperrzeit	100 ms	1
ENG127114-p_t_entprellung_p_unplausibel	400 ms	1
ENG104033-p_t_entprellzeit_ueberspannung	90000 ms	1
ENG101392-p_t_entprellzeit_unterspannung	90000 ms	1
ENG102689-p_t_fas_entprellen	40 ms	1
ENG120505-p_t_gra_ea_error	200 ms	1
ENG101014-p_t_grahebel_entprellen	40 ms	1
ENG104117-p_t_grahebel_err_el_kurzschluss	200 ms	1
ENG102950-p_t_grahebel_err_el_unterbrechung	1000 ms	1
ENG103784-p_t_grahebel_err_gra_haengt_aus	5000 ms	1
ENG102546-p_t_grahebel_err_gra_haengt_ein	300 s	1
ENG103536-p_t_grahebel_err_unplausibel	200 ms	1
ENG126416-p_t_grenze_v	10 km/h	1
ENG99436-p_t_hupe_entprellen	40 ms	1
ENG102496-p_t_hupe_err_hinweis	2000 ms	1
ENG101071-p_t_hupe_err_hupe_haengt_aus	5000 ms	1
ENG101518-p_t_hupe_err_hupe_haengt_ein	60 s	1
ENG101702-p_t_hupe_indien_entprellen	500 ms	1
ENG126421-p_t_lrh_kurzschluss_entprellen	200 ms	1
ENG126422-p_t_lrh_unterbrechung_entprellen	1000 ms	1
ENG103999-p_t_p_verriegelt_entprellen	40 ms	1
ENG126412-p_t_soll_0	39 °C	1
ENG126413-p_t_soll_1	43 °C	1
ENG126414-p_t_soll_2	47 °C	1
ENG100796-p_t_spannung_obere_schwelle	16.7 V	1
ENG102338-p_t_spannung_untere_schwelle	8.5 V	1
ENG100559-p_t_wischer_entprellen	40 ms	1
ENG103039-p_t_wischer_err_el_kurzschluss	200 ms	1
ENG101343-p_t_wischer_err_el_unterbrechung	1000 ms	1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus	5000 ms	1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein	300 s	1
ENG101059-p_t_wischer_err_mfa_haengt_aus	5000 ms	1
ENG100346-p_t_wischer_err_mfa_haengt_ein	300 s	1
ENG103464-p_t_wischer_err_waschen_haengt_aus	5000 ms	1
ENG100423-p_t_wischer_err_waschen_haengt_ein	300 s	1
ENG99933-p_t_wischer_err_wischen_haengt_aus	5000 ms	1
ENG102586-p_t_wischer_err_wischen_haengt_ein	300 s	1
ENG101592-p_t_wischer_intervall_entprellen	40 ms	1
ENG103607-p_t_wischer_winterstellung	60 s	1
ENG126423-p_temp_lenkradheizung_aus	50 °C	1
ENG126420-p_zeit_temperatur_statisch_lrh	300 s	1
Elapsed Time: 00:26
blockmap-16-5Q0-953-507-GH_3VWH17AU5JM758941-20180826-1119.CSV
;Sunday	26	August	2018	11:19:18:04045
Group	Description	Actual
IDE00030-ENG99298	Status of actuator test-State	not active
IDE00323	Security Access: Number of invalid keys	0
IDE00329-MAS00232	Buttons for multi-function display-MFI button UP	not coded/not installed
IDE00329-MAS00233	Buttons for multi-function display-MFI button DOWN	not coded/not installed
IDE00329-MAS00234	Buttons for multi-function display-MFI button RESET / OK	not coded/not installed
IDE00329-MAS00236	Buttons for multi-function display-MFI buttons: number 3/4	not coded/not installed
IDE00329-MAS00688	Buttons for multi-function display-Multifunction indicator	not coded/not installed
IDE00333	Driver assistance systems button	not coded/not installed
IDE00333-MAS00243	Driver assistance systems button-Buttons for driver assistance systems: status	not coded/not installed
IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	not coded/not installed
IDE00356-MAS00125	Cruise Control System (CCS): switch position-Cruise control system	not coded/not installed
IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	not coded/not installed
IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	not coded/not installed
IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	not coded/not installed
IDE00356-MAS00324	Cruise Control System (CCS): switch position-Accelerate tap	not coded/not installed
IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	not coded/not installed
IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	not coded/not installed
IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	not coded/not installed
IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	not coded/not installed
IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	not coded/not installed
IDE00356-MAS04522	Cruise Control System (CCS): switch position-Delay tip level 2	not coded/not installed
IDE00356-MAS04523	Cruise Control System (CCS): switch position-Accelerate tip level 2	not coded/not installed
IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	Initializing
IDE02486	Data logger triggering	not active
IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	On
IDE02588-IDE01715	Terminal signals and start release-Status terminal S	On
IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
IDE02693-IDE02335	Turn signals and parking lights-Signal light switch position	not activated
IDE02694-MAS01288	Signal horn activation-Signal horn	not activated
IDE02695-IDE01268	Front wiping: front washing-Windshield wiper	not activated
IDE02695-MAS02338	Front wiping: front washing-Windshield wiper: intermittent stage	Stage 1
IDE02695-MAS02339	Front wiping: front washing-Windshield washer system	not activated
IDE02696-IDE02711	Rear wiping: rear washing-Rear Window Wiper	not activated
IDE02696-MAS02341	Rear wiping: rear washing-Rear window washer system	not activated
IDE02743	High Beam	not activated
IDE02744-MAS01632	Steering wheel heater-Status	OFF
IDE02744-MAS04136	Steering wheel heater-Current	0	 A
IDE02744-MAS09022	Steering wheel heater-PWM value	0	 %
IDE02744-MAS09758	Steering wheel heater-Temperature sensor	-50	 °C
IDE02745-IDE00096	Ignition key removal lock-Selector lever position	Current
IDE02745-MAS08202	Ignition key removal lock-CAN p locked	Engaged and locked
IDE02745-MAS08203	Ignition key removal lock-CAN p locked: qualified	Not qualified
IDE02745-MAS08204	Ignition key removal lock-Hardware input: p_verriegelt	Open
IDE02745-MAS08205	Ignition key removal lock-CAN ESP valid speed	Qualified
IDE02745-MAS08206	Ignition key removal lock-CAN ESP speed	0	 km/h
IDE02745-MAS08207	Ignition key removal lock-CAN GWB obsolete transmission	Current
ENG120506-ENG100300	CCS_in_indic-lever-E: Blinkerhebel GRA Cancel	not activated
ENG120506-ENG103377	CCS_in_indic-lever-E: Blinkerhebel GRA Fehler	No malfunction detected
ENG120506-ENG103714	CCS_in_indic-lever-E: Blinkerhebel GRA OFF	not activated
ENG120506-ENG102330	CCS_in_indic-lever-E: Blinkerhebel GRA ON	not activated
ENG120506-ENG120475	CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter	OFF
ENG120506-ENG103991	CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus	not activated
ENG120506-ENG100605	CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus	not activated
ENG120506-ENG120476	CCS_in_indic-lever-E: GRA_E_A	OFF
ENG120507-ENG100163	CCS_in_third_lever-E: 3.ter Hebel ADR Fehler	No malfunction detected
ENG120507-ENG99937	CCS_in_third_lever-E: 3.ter Hebel ADR Minus	not activated
ENG120507-ENG101800	CCS_in_third_lever-E: 3.ter Hebel ADR Plus	not activated
ENG120507-ENG101234	CCS_in_third_lever-E: 3.ter Hebel GRA Cancel	not activated
ENG120507-ENG103820	CCS_in_third_lever-E: 3.ter Hebel GRA Fehler	No malfunction detected
ENG120507-ENG99143	CCS_in_third_lever-E: 3.ter Hebel GRA OFF	not activated
ENG120507-ENG100333	CCS_in_third_lever-E: 3.ter Hebel GRA ON	not activated
ENG120507-ENG101903	CCS_in_third_lever-E: 3.ter Hebel GRA Resume	not activated
ENG120507-ENG101230	CCS_in_third_lever-E: 3.ter Hebel GRA Set	not activated
ENG120507-ENG129309	CCS_in_third_lever-E: 3.ter Hebel GRA Speedlimiter	not activated
ENG120507-ENG126425	CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen	not activated
ENG120507-ENG126426	CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzögern	not activated
ENG120507-ENG120477	CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen	not activated
ENG120507-ENG120478	CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzögern	not activated
ENG120507-ENG120476	CCS_in_third_lever-E: GRA_E_A	OFF
ENG126424-ENG126428	LRH-LRH_current	0	 A
ENG126424-ENG126430	LRH-LRH_level	Middle
ENG126424-ENG126429	LRH-LRH_status	OFF
ENG126424-ENG126427	LRH-LRH_temperature_NTC	204	 °C
Elapsed Time: 00:02
Dana
Western PA, USA
17-Instruments
adpmap-17-5G1-920-840-C_3VWH17AU5JM758941-20180826-1111.CSV
;SW:5G1-920-840-C   HW:5G1-920-840-C ---  Instruments
;Component:KOMBI         242 0310	 Coding:0BB4100DA180CF0502082B001000000000000000
;EV_DashBoardVDDMQBAB	9060	EV_DashBoardVDDMQBAB_009_VW37.rod
;Sunday	26	August	2018	11:11:45:04045
;VCID: 2708F1F5CF6DE8EFF08-8072
IDE00295-Oil temperature display	OFF 	1
IDE00301-Distance	138 km	3
IDE00342-ESI: Resetting ESI	no warning 	1
IDE00343-Language version	US English 	1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK	Manual reset: not possible 	3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel	MFA3-Reset 	3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas	MFA3-Reset 	3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection	MFA3-Reset 	3
IDE00499-Display correction of consumptions and operating range	100%	1
IDE00500-Hour	11 H	1
IDE00501-Minute	11 min	1
IDE00502-Year	2018 yr	2
IDE00503-Month	8 mon	1
IDE00504-Day	26 d	1
IDE00510-ESI: distance driven from inspection	138 km	3
IDE00511-ESI: time from inspection	303 d	2
IDE00512-ESI: minimum value km-driving distance/inspection	15000 km	2
IDE00513-ESI: maximum value km-driving distance/inspection	30000 km	2
IDE00514-ESI: maximum value of time between inspections	730 d	2
IDE00515-ESI: oil quality	poor oil quality 	1
IDE00517-ESI: soot entry	0 km	2
IDE00518-ESI: thermal load	1100 km	2
IDE00819-Day counter	302 d	2
IDE00820-Activating and deactivating all development messages	not active 	1
IDE00827-ESI: minimum value of time between inspections	365 d	2
IDE01153-SIA: maximum value of distance to service	16100 km	2
IDE01154-SIA: maximum value of time to service	365 d	2
IDE02489-Display depiction	Version 1 	1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration	-12.8 l	5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1	-12.8 l	5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2	-12.8 l	5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3	12.7 l	5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4	12.7 l	5
IDE03329-Driving profiled for range remaining	8.6 l/100km	2
IDE03346-IDE00301-Units adjusted-Distance	Kilometers 	3
IDE03346-MAS01230-Units adjusted-Date	mm_dd_yy 	3
IDE03346-MAS01456-Units adjusted-Speed	Kilometers per hour 	3
IDE03346-MAS02201-Units adjusted-Temperature	Degrees Celsius 	3
IDE03346-MAS02957-Units adjusted-Time	12h AM_PM 	3
IDE03346-MAS03032-Units adjusted-Volume	Liter 	3
IDE03346-MAS03034-Units adjusted-Pressure	bar 	3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas)	kg per 100 km 	3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas)	Liters per 100 km 	3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive	kWh per 100 km 	3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground	kilogram (kg) 	3
IDE03348-MAS01456-Speed warning-Speed	0	2
IDE03348-MAS01561-Speed warning-Unit	Kilometers per hour 	2
IDE03348-Speed warning-	not active 	2
IDE03349-FIX: Max. distance until next mileage-related inspection	32200 km	2
IDE03350-FIX: Maximum time until next time-dependent inspection	730 d	2
IDE03351-FIX: Distance covered since last mileage-dependent inspection	100 km	2
IDE03352-FIX: Time since last time-dependent inspection	303 d	2
IDE03372-Source for synchronization of time	internal clock 	1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function	On 	5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time	10 s	5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic	On 	5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless	On 	5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed	20 km/h	5
IDE03568-ENG103545-Service-key settings-p_write_delay_time	40 s	5
IDE03568-ENG104099-Service-key settings-p_write_distance	20 km	5
IDE03867-Deactivate seat belt warning	No 	1
IDE05930-Service notification in days	30 d	1
IDE05931-FIX: Reset value for next mileage-dependent inspection	32200 km	2
IDE05932-FIX: Reset value for next time-dependent inspections	730 d	2
IDE05971-Vehicle Positioning System Interface Control Module	not installed 	1
IDE06425-Roller test bench mode: functional	not activated 	1
IDE06588-Ignition active message: actuator	Driver door 	1
IDE06922-No-voltage display	Unknown (2)	1
IDE07221-Cylinder shut-off	Display 	1
IDE11086-Service notification	30 d	1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation	not active 	1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS	not active 	1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter	not active 	1
MAS03685-Digital speedometer	Display 	1
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1	OFF 	20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10	OFF 	20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11	OFF 	20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12	OFF 	20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13	OFF 	20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14	OFF 	20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15	OFF 	20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16	OFF 	20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17	OFF 	20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18	OFF 	20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19	OFF 	20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2	OFF 	20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20	OFF 	20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21	OFF 	20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22	OFF 	20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23	OFF 	20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24	OFF 	20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25	OFF 	20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26	OFF 	20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27	OFF 	20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28	OFF 	20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29	OFF 	20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3	OFF 	20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30	OFF 	20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31	OFF 	20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32	OFF 	20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33	OFF 	20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34	OFF 	20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35	OFF 	20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36	OFF 	20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37	OFF 	20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38	OFF 	20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39	OFF 	20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4	OFF 	20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5	OFF 	20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6	OFF 	20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7	OFF 	20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8	OFF 	20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9	OFF 	20
ENG119875-defuel_threshold	9 l	1
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1	0	12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2	32	12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3	66	12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4	96	12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5	DC 	12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6	FD 	12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1	0	12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2	0	12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3	0	12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4	5	12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5	14	12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6	64	12
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1	0	12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2	0A 	12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3	32	12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4	64	12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5	96	12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6	FD 	12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1	2	12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2	2	12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3	0E 	12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4	1E 	12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5	32	12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6	64	12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1	0	12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2	0A 	12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3	32	12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4	64	12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5	DC 	12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6	FD 	12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1	3	12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2	3	12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3	10	12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4	1E 	12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5	55	12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6	64	12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1	0	12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2	0A 	12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3	32	12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4	64	12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5	96	12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6	FD 	12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1	5	12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2	5	12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3	0C 	12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4	17	12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5	32	12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6	64	12
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1	00 00 	20
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2	00 32 	20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3	00 64 	20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4	00 C8 	20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5	01 F4 	20
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1	00 00 	20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2	00 0E 	20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3	00 41 	20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4	00 C8 	20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5	00 FD 	20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1	0	12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2	0A 	12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3	32	12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4	64	12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5	96	12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6	FD 	12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1	1	12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2	1	12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3	7	12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4	0E 	12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5	1E 	12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6	64	12
ENG119874-Gas_functionality	not active 	1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim	terminal_58xd_log_bus_parkinglight 	1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm	parking_light 	1
ENG119882-init_fuel_algorithm	No 	1
ENG130585-Leaving_warning_delay	1.6 s	1
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0	15 s	16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature	4 °C	16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature	6 °C	16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta	25 °C	16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0	5.0 km	16
ENG102605-ENG103631-outside_temperature-P_speed_threshold	20 km/h	16
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off	180 min	16
ENG102605-ENG104179-outside_temperature-p_tendency_damping	15 s	16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold	1.0 °C	16
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1	40 s	16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping	2	16
ENG119825-Picture_Upload_Download	not active 	1
ENG126396-Scale_switching_algorithm	lowbeam_foglight 	1
ENG119876-Service_Key_Clear_All_Counter	Yes 	1
ENG130584-Statistic_phev_mileage	5 km	1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms	2.0 s	18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms	5 s	18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt	35 s	18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF	300 ms	18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms	255 s	18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms	5 s	18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms	6 s	18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms	20 s	18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms	900 s	18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms	10 s	18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms	3 s	18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms	10 s	18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ	0.40 s	18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse	3	18
ENG109442-ENG101663-time_parameter_display-tDD15_off	0.3	18
ENG109442-ENG103975-time_parameter_display-tDD15_on	0	18
ENG109442-ENG100026-time_parameter_display-tDDWUP	0	18
ENG112418-ENG112412-total_range_gas-consumption_factor	0	4
ENG112418-ENG112411-total_range_gas-consumption_profile	consumption_profile_calculation 	4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor	consumption_factor_CAN 	4
ENG112418-ENG99298-total_range_gas-State	not active 	4
Elapsed Time: 00:25
blockmap-17-5G1-920-840-C_3VWH17AU5JM758941-20180826-1111.CSV
;Sunday	26	August	2018	11:11:32:04045
IDE00019	Voltage terminal 30	14.4	 V
IDE00021	Engine speed	0	 /min
IDE00025	Coolant temperature	81	 °C
IDE00075	Vehicle speed	0	 km/h
IDE00196	Engine oil temperature	67	 °C
IDE00301	Distance	138	 km
IDE00310	Outside air temperature	23.5	 °C
IDE00316-IDE00500	Time-Hour	11	 H
IDE00316-IDE00501	Time-Minute	11	 min
IDE00316-MAS00111	Time-Seconds	13	 s
IDE00317-IDE00502	Date-Year	2018	 yr
IDE00317-IDE00503	Date-Month	8	 mon
IDE00317-IDE00504	Date-Day	26	 d
IDE00510	ESI: distance driven from inspection	138	 km
IDE00511	ESI: time from inspection	303	 d
IDE00512	ESI: minimum value km-driving distance/inspection	15000	 km
IDE00513	ESI: maximum value km-driving distance/inspection	30000	 km
IDE00514	ESI: maximum value of time between inspections	730	 d
IDE00515	ESI: oil quality	poor oil quality
IDE00517	ESI: soot entry	0	 km
IDE00518	ESI: thermal load	1100	 km
IDE00520	Phototransistor	251
IDE00695	ESI: service exceedance in km	0	 km
IDE00696	ESI: service exceedance in days	0	 d
IDE00697	ESI: remaining distance	15970	 km
IDE00698	ESI: remaining running time	62	 d
IDE00787-IDE02689	Cause for cancellation-Complete tank calibration	not performed
IDE00787-IDE02690	Cause for cancellation-Wet dry tank calibration	not performed
IDE00819	Day counter	302	 d
IDE00827	ESI: minimum value of time between inspections	365	 d
IDE00843	Starting impulse recognized	No
IDE00845-MAS03213	Wheel circ.-Average wheel circumference for trip distance	1976	 mm
IDE00845-MAS03214	Wheel circ.-Maximum wheel circumference for speed	1976	 mm
IDE00935	ESI: Theoretical service interval	15000	 km
IDE01076	Time since ignition off	260	 s
IDE01153	SIA: maximum value of distance to service	16100	 km
IDE01154	SIA: maximum value of time to service	365	 d
IDE01285	Counter of component protection malfunctions	0
IDE01985-MAS06854	FAZIT identification test sum-Version	3
IDE01985-MAS06855	FAZIT identification test sum-Test sum	AE 46 D0 B8
IDE02307	Parking brake status	operated
IDE02642	Outside temp.: displayed value	22.5	 °C
IDE03193-MAS02352	Terminal 58 status-Display dimming terminal 58d	FD
IDE03193-MAS02353	Terminal 58 status-Switch dimming terminal 58s	0
IDE03193-MAS02916	Terminal 58 status-Dimmer: duty cycle terminal 58st	64
IDE03193-MAS02917	Terminal 58 status-Sensor for detecting light in the instrument panel insert	122
IDE03349	FIX: Max. distance until next mileage-related inspection	32200	 km
IDE03350	FIX: Maximum time until next time-dependent inspection	730	 d
IDE03351	FIX: Distance covered since last mileage-dependent inspection	100	 km
IDE03352	FIX: Time since last time-dependent inspection	303	 d
IDE03471-IDE03640	Vehicle configuration-Dynamic AFS light	Correct coding
IDE03471-IDE03726	Vehicle configuration-Parallel Parking Assistance	Correct coding
IDE03471-IDE04525	Vehicle configuration-Wheel Dampening Electronics	Correct coding
IDE03471-IDE04939	Vehicle configuration-Tire pressure monitoring display	Correct coding
IDE03471-IDE07016	Vehicle configuration-Tire Pressure Monitoring	Correct coding
IDE03471-MAS00809	Vehicle configuration-Electro-Mechanical Parking Brake Control Module	Correct coding
IDE03471-MAS00811	Vehicle configuration-Active steering control module	Correct coding
IDE03471-MAS00911	Vehicle configuration-All Wheel Drive (AWD)	Correct coding
IDE03471-MAS01091	Vehicle configuration-Automated manual transmission	Correct coding
IDE03471-MAS01891	Vehicle configuration-Lane assistant	Correct coding
IDE03471-MAS01938	Vehicle configuration-Road sign detection	Correct coding
IDE03471-MAS02570	Vehicle configuration-Lock Electronics	Correct coding
IDE03471-MAS03385	Vehicle configuration-Lane change assistance	Correct coding
IDE03471-MAS04384	Vehicle configuration-Electrical steering column lock control module	Correct coding
IDE03471-MAS05723	Vehicle configuration-Adaptive cruise control or reducing stopping distance	Correct coding
IDE03471-MAS08201	Vehicle configuration-Trailer positioning assistant	Correct coding
IDE03472-MAS03806	Volume after refueling-Last displayed quantity before refueling	18	 l
IDE03472-MAS03807	Volume after refueling-Last displayed quantity after refueling	54	 l
IDE03472-MAS03808	Volume after refueling-Last sensor final value at end of refueling	57.5	 l
IDE03472-MAS03809	Volume after refueling-Last reference quantity	19.5	 l
IDE03472-MAS03810	Volume after refueling-Penultimate displayed quantity before refueling	5.4	 l
IDE03472-MAS03811	Volume after refueling-Penultimate displayed quantity after refueling	20.9	 l
IDE03472-MAS03812	Volume after refueling-Penultimate sensor final value at end of refueling	18.5	 l
IDE03472-MAS03813	Volume after refueling-Penultimate reference quantity	3	 l
IDE03472-MAS03814	Volume after refueling-Third-last displayed volume before refueling	1.7	 l
IDE03472-MAS03815	Volume after refueling-Third-last displayed volume after refueling	14.3	 l
IDE03472-MAS03816	Volume after refueling-Third-last sensor final value at end of refueling	12.6	 l
IDE03472-MAS03817	Volume after refueling-Third-last reference quantity	0	 l
IDE03472-MAS03818	Volume after refueling-Fourth-last displayed volume before refueling	0.7	 l
IDE03472-MAS03819	Volume after refueling-Fourth-last displayed volume after refueling	9.2	 l
IDE03472-MAS03820	Volume after refueling-Fourth-last sensor final value at end of refueling	9.2	 l
IDE03472-MAS03821	Volume after refueling-Fourth-last reference quantity	0.7	 l
IDE03472-MAS03822	Volume after refueling-Last error status	0
IDE03472-MAS03823	Volume after refueling-Penultimate error status	0
IDE03472-MAS03824	Volume after refueling-Third-last error status	0
IDE03472-MAS03825	Volume after refueling-Fourth-last error status	0
IDE03472-MAS06153	Volume after refueling-Last distance	0
IDE03472-MAS06154	Volume after refueling-Penultimate distance	0
IDE03472-MAS06155	Volume after refueling-Third to last distance	0
IDE03472-MAS06156	Volume after refueling-Fourth to last distance	0
IDE03473-IDE00730	Fuel tank sens-Fuel level sensor 1 including soiling resistance	79	 Ohm
IDE03473-IDE00731	Fuel tank sens-Fuel level sensor 2 including soiling resistance	94	 Ohm
IDE03473-IDE00732	Fuel tank sens-Fuel level sensor 1 soiling resistance	2	 Ohm
IDE03473-IDE00733	Fuel tank sens-Fuel level sensor 2 soiling resistance	2	 Ohm
IDE03473-IDE03494	Fuel tank sens-Fuel level sensor 3 including soiling resistance	65535	 Ohm
IDE03473-IDE03495	Fuel tank sens-Fuel level sensor 3 soiling resistance	-32768	 Ohm
IDE03473-IDE03496	Fuel tank sens-Fuel level sensor 4 including soiling resistance	65535	 Ohm
IDE03473-IDE03497	Fuel tank sens-Fuel level sensor 4 soiling resistance	-32768	 Ohm
IDE03473-MAS03798	Fuel tank sens-Raw value sensor 1 resistor 1	1176
IDE03473-MAS03799	Fuel tank sens-Raw value sensor 1 resistor 2	2340
IDE03473-MAS03800	Fuel tank sens-Raw value sensor 2 resistor 1	1328
IDE03473-MAS03801	Fuel tank sens-Raw value sensor 2 resistor 2	2286
IDE03473-MAS03802	Fuel tank sens-Raw value sensor 3 resistor 1	65535
IDE03473-MAS03803	Fuel tank sens-Raw value sensor 3 resistor 2	65535
IDE03473-MAS03804	Fuel tank sens-Raw value sensor 4 resistor 1	65535
IDE03473-MAS03805	Fuel tank sens-Raw value sensor 4 resistor 2	65535
IDE03474-IDE00304	Calculated volume-Fuel level	49.9	 l
IDE03474-IDE00306	Calculated volume-Fuel Level Sensor 1	77	 Ohm
IDE03474-IDE00307	Calculated volume-Fuel Level Sensor 2	92	 Ohm
IDE03474-IDE00308	Calculated volume-Fuel Level Sensor 3	65535	 Ohm
IDE03474-IDE00309	Calculated volume-Fuel Level Sensor 4	65535	 Ohm
IDE03474-IDE00312	Calculated volume-Fuel level from sensor 1	22.8	 l
IDE03474-IDE00313	Calculated volume-Fuel level from sensor 2	27.5	 l
IDE03474-IDE00314	Calculated volume-Fuel level from sensor 3	0	 l
IDE03474-IDE00315	Calculated volume-Fuel level from sensor 4	0	 l
IDE03474-MAS03826	Calculated volume-Quality sensor 1	10
IDE03474-MAS03827	Calculated volume-Quality sensor 2	10
IDE03474-MAS03828	Calculated volume-Quality sensor 3	not installed
IDE03474-MAS03829	Calculated volume-Quality sensor 4	not installed
IDE03474-MAS10338	Calculated volume-Non-calibrated volume: sensor 1	23.2	 l
IDE03474-MAS10339	Calculated volume-Non-calibrated volume: sensor 2	27.5	 l
IDE03474-MAS10340	Calculated volume-Non-calibrated volume: sensor 3	-32768	 l
IDE03474-MAS10341	Calculated volume-Non-calibrated volume: sensor 4	-32768	 l
IDE03474-ENG103155	Calculated volume-accelerated_linking_x	1	 m/s
IDE03474-ENG103517	Calculated volume-accelerated_linking_y	1	 m/s
IDE03474-ENG102894	Calculated volume-averaged_volume	50.3	 l
IDE03474-ENG99406	Calculated volume-averaged_volume_clipped	50.3	 l
IDE03474-ENG101619	Calculated volume-calibrated_volume_total	50.3	 l
IDE03474-ENG99553	Calculated volume-linking	0
IDE03474-ENG101669	Calculated volume-prefiltered_acceleration_x	-0.1875	 m/s
IDE03474-ENG102339	Calculated volume-prefiltered_acceleration_y	0
IDE03474-ENG101623	Calculated volume-reference_volume	50.2	 l
IDE03474-ENG102479	Calculated volume-speed_based_linking	0	 m/s
IDE03474-ENG99683	Calculated volume-version_of_application	111
IDE03474-ENG102081	Calculated volume-volume_based_linking	0.0016661
IDE03475-MAS00216	Control button in instrument cluster-External button for daily distance driven	not active
IDE03475-MAS02915	Control button in instrument cluster-Button for auto check system	not active
IDE03475-MAS03929	Control button in instrument cluster-Menu button	not active
IDE03477-IDE00500	GPS time-Hour	0	 H
IDE03477-IDE00501	GPS time-Minute	0	 min
IDE03477-IDE00502	GPS time-Year	2000	 yr
IDE03477-IDE00503	GPS time-Month	1	 mon
IDE03477-IDE00504	GPS time-Day	1	 d
IDE03477-MAS00111	GPS time-Seconds	0	 s
IDE03477-MAS03493	GPS time-last synchronization year	2000	 yr
IDE03506	Distance: high resolution	00 02 1C 9A
IDE03911-MAS01390	Service -interval- display: history 1-Block 1	FF FF FF FF
IDE03911-MAS01391	Service -interval- display: history 1-Block 2	FF FF FF FF
IDE03911-MAS01392	Service -interval- display: history 1-Block 3	FF FF FF FF
IDE03911-MAS01393	Service -interval- display: history 1-Block 4	FF FF FF FF
IDE03911-MAS01394	Service -interval- display: history 1-Block 5	FF FF FF FF
IDE03911-MAS01395	Service -interval- display: history 1-Block 6	FF FF FF FF
IDE03911-MAS01396	Service -interval- display: history 1-Block 7	FF FF FF FF
IDE03911-MAS01397	Service -interval- display: history 1-Block 8	FF FF FF FF
IDE03911-MAS01398	Service -interval- display: history 1-Block 9	FF FF FF FF
IDE03911-MAS01399	Service -interval- display: history 1-Block 10	FF FF FF FF
IDE03911-MAS01400	Service -interval- display: history 1-Block 11	FF FF FF FF
IDE03911-MAS01401	Service -interval- display: history 1-Block 12	FF FF FF FF
IDE03911-MAS01402	Service -interval- display: history 1-Block 13	FF FF FF FF
IDE03911-MAS01403	Service -interval- display: history 1-Block 14	FF FF FF FF
IDE03911-MAS01404	Service -interval- display: history 1-Block 15	FF FF FF FF
IDE03911-MAS01405	Service -interval- display: history 1-Block 16	FF FF FF FF
IDE03912-MAS01390	Service -interval- display: history 2-Block 1	FF FF FF FF
IDE03912-MAS01391	Service -interval- display: history 2-Block 2	FF FF FF FF
IDE03912-MAS01392	Service -interval- display: history 2-Block 3	FF FF FF FF
IDE03912-MAS01393	Service -interval- display: history 2-Block 4	FF FF FF FF
IDE03912-MAS01394	Service -interval- display: history 2-Block 5	FF FF FF FF
IDE03912-MAS01395	Service -interval- display: history 2-Block 6	FF FF FF FF
IDE03912-MAS01396	Service -interval- display: history 2-Block 7	FF FF FF FF
IDE03912-MAS01397	Service -interval- display: history 2-Block 8	FF FF FF FF
IDE03912-MAS01398	Service -interval- display: history 2-Block 9	FF FF FF FF
IDE03912-MAS01399	Service -interval- display: history 2-Block 10	FF FF FF FF
IDE03912-MAS01400	Service -interval- display: history 2-Block 11	FF FF FF FF
IDE03912-MAS01401	Service -interval- display: history 2-Block 12	FF FF FF FF
IDE03912-MAS01402	Service -interval- display: history 2-Block 13	FF FF FF FF
IDE03912-MAS01403	Service -interval- display: history 2-Block 14	FF FF FF FF
IDE03912-MAS01404	Service -interval- display: history 2-Block 15	FF FF FF FF
IDE03912-MAS01405	Service -interval- display: history 2-Block 16	FF FF FF FF
IDE03913-MAS01390	Service -interval- display: history 3-Block 1	FF FF FF FF
IDE03913-MAS01391	Service -interval- display: history 3-Block 2	FF FF FF FF
IDE03913-MAS01392	Service -interval- display: history 3-Block 3	FF FF FF FF
IDE03913-MAS01393	Service -interval- display: history 3-Block 4	FF FF FF FF
IDE03913-MAS01394	Service -interval- display: history 3-Block 5	FF FF FF FF
IDE03913-MAS01395	Service -interval- display: history 3-Block 6	FF FF FF FF
IDE03913-MAS01396	Service -interval- display: history 3-Block 7	FF FF FF FF
IDE03913-MAS01397	Service -interval- display: history 3-Block 8	FF FF FF FF
IDE03913-MAS01398	Service -interval- display: history 3-Block 9	FF FF FF FF
IDE03913-MAS01399	Service -interval- display: history 3-Block 10	FF FF FF FF
IDE03913-MAS01400	Service -interval- display: history 3-Block 11	FF FF FF FF
IDE03913-MAS01401	Service -interval- display: history 3-Block 12	FF FF FF FF
IDE03913-MAS01402	Service -interval- display: history 3-Block 13	FF FF FF FF
IDE03913-MAS01403	Service -interval- display: history 3-Block 14	FF FF FF FF
IDE03913-MAS01404	Service -interval- display: history 3-Block 15	FF FF FF FF
IDE03913-MAS01405	Service -interval- display: history 3-Block 16	FF FF FF FF
IDE03914-MAS01390	Service -interval- display: history 4-Block 1	FF FF FF FF
IDE03914-MAS01391	Service -interval- display: history 4-Block 2	FF FF FF FF
IDE03914-MAS01392	Service -interval- display: history 4-Block 3	FF FF FF FF
IDE03914-MAS01393	Service -interval- display: history 4-Block 4	FF FF FF FF
IDE03914-MAS01394	Service -interval- display: history 4-Block 5	FF FF FF FF
IDE03914-MAS01395	Service -interval- display: history 4-Block 6	FF FF FF FF
IDE03914-MAS01396	Service -interval- display: history 4-Block 7	FF FF FF FF
IDE03914-MAS01397	Service -interval- display: history 4-Block 8	FF FF FF FF
IDE03914-MAS01398	Service -interval- display: history 4-Block 9	FF FF FF FF
IDE03914-MAS01399	Service -interval- display: history 4-Block 10	FF FF FF FF
IDE03914-MAS01400	Service -interval- display: history 4-Block 11	FF FF FF FF
IDE03914-MAS01401	Service -interval- display: history 4-Block 12	FF FF FF FF
IDE03914-MAS01402	Service -interval- display: history 4-Block 13	FF FF FF FF
IDE03914-MAS01403	Service -interval- display: history 4-Block 14	FF FF FF FF
IDE03914-MAS01404	Service -interval- display: history 4-Block 15	FF FF FF FF
IDE03914-MAS01405	Service -interval- display: history 4-Block 16	FF FF FF FF
IDE05931	FIX: Reset value for next mileage-dependent inspection	32200	 km
IDE05932	FIX: Reset value for next time-dependent inspections	730	 d
IDE06566-IDE00008	Key identification-Softwareversion	006A
IDE06566-IDE00016	Key identification-Hardwareversion	H91
IDE06566-MAS04970	Key identification-Part Number	5G0959753BD
IDE09552-IDE07944	Vehicle configuration 2-electronic brake booster	Correct coding
IDE09552-MAS06008	Vehicle configuration 2-Internal noise sound actuator	Correct coding
IDE09552-MAS08940	Vehicle configuration 2-Collision warning	Correct coding
ENG124477-MAS06854	Adapted_transponders_checksum-Version	1
ENG124477-MAS06855	Adapted_transponders_checksum-Test sum	5E 80 C1 23
ENG105830-ENG104002	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC	53	 %
ENG105830-ENG119807	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial	64	 %
ENG105830-ENG101889	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand	73	 %
ENG105830-ENG100477	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights	75	 %
ENG105830-ENG103803	dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field	68	 %
ENG106303-ENG99140	ESI_active_warning-advance_warning_fixed_days	not active
ENG106303-ENG100265	ESI_active_warning-advance_warning_fixed_km	not active
ENG106303-ENG101600	ESI_active_warning-advance_warning_WIV_days	not active
ENG106303-ENG102887	ESI_active_warning-advance_warning_WIV_km	not active
ENG106303-ENG99971	ESI_active_warning-in_calculation	not active
ENG106303-ENG101015	ESI_active_warning-no_calculation_available	active
ENG106303-ENG101477	ESI_active_warning-service_warning_fixed_days	not active
ENG106303-ENG101550	ESI_active_warning-service_warning_fixed_km	not active
ENG106303-ENG101709	ESI_active_warning-service_warning_WIV_days	not active
ENG106303-ENG102993	ESI_active_warning-service_warning_WIV_km	not active
ENG119883	ESI_mileage_per_day	100	 km
ENG106922	Immobilizer - Challenge	8D 32 37 C6
ENG99439	Instrument_recorder	03 03 31 00 4D 51 42 56 57 31 37 53 31 4D 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 01 4A 00 3E 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 7E 3B
ENG107920-ENG100914	onboard_computer-current_consumption	0
ENG107920-ENG119788	onboard_computer-range_average_consumption	8.6	 l/100km
ENG107920-ENG119789	onboard_computer-range_average_consumption_high	8.6	 l/100km
ENG107920-ENG119790	onboard_computer-range_average_consumption_low	9	 l/100km
ENG107920-ENG119791	onboard_computer-range_display_value	540	 km
ENG107920-ENG119792	onboard_computer-range_R	541
ENG107920-ENG112418	onboard_computer-total_range_gas	540	 km
ENG107953-ENG100938	outside_temp_algorithm_group-coolant_temperature_outdated_bit	not active
ENG107953-ENG101136	outside_temp_algorithm_group-distance_threshold_not_yet_reached	active
ENG107953-ENG99778	outside_temp_algorithm_group-downward_tendency	not active
ENG107953-ENG99788	outside_temp_algorithm_group-engine_running_detection_MSG	not active
ENG107953-ENG102352	outside_temp_algorithm_group-ice_warning_symbol	not active
ENG107953-ENG99520	outside_temp_algorithm_group-no_blockage_active	not active
ENG107953-ENG99784	outside_temp_algorithm_group-outside_temperature_filtered	145
ENG107953-ENG99258	outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit	not active
ENG107953-ENG102589	outside_temp_algorithm_group-outside_temperature_old	not active
ENG107953-ENG102387	outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit	not active
ENG103405	read_out_measured_value_block	0
ENG119885-ENG103300	Service_Key_current_data-Service_Data	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG108925-ENG103300	Service_Key_Data_Current_Page-Service_Data	D7 95 07 22 28 C0 12 08 1A 0A 24 00 89 00 00 00 A0 10 3E 10 41 11 AB 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5C FF FF 00 00 40 10
ENG108926-ENG103300	Service_Key_Data_Previous_Page-Service_Data	F0 E9 07 22 28 80 0B 04 0D 03 20 0B 13 00 00 00 64 30 07 11 C8 30 74 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 1A FF FF 00 00 40 10
ENG108927-ENG119819	Service_Key_Master_Counter-Counter_ID_Kessy	27
ENG108927-ENG119811	Service_Key_Master_Counter-Counter_Key_ID_1	4
ENG108927-ENG119812	Service_Key_Master_Counter-Counter_Key_ID_2	23
ENG108927-ENG119813	Service_Key_Master_Counter-Counter_Key_ID_3	0
ENG108927-ENG119814	Service_Key_Master_Counter-Counter_Key_ID_4	0
ENG108927-ENG119815	Service_Key_Master_Counter-Counter_Key_ID_5	0
ENG108927-ENG119816	Service_Key_Master_Counter-Counter_Key_ID_6	0
ENG108927-ENG119817	Service_Key_Master_Counter-Counter_Key_ID_7	0
ENG108927-ENG119818	Service_Key_Master_Counter-Counter_Key_ID_8	0
ENG108927-ENG119821	Service_Key_Master_Counter-Counter_Trigger	0
ENG108927-ENG119822	Service_Key_Master_Counter-Error_Counter	0
ENG108927-ENG119823	Service_Key_Master_Counter-Immo_Key	0
ENG108927-ENG119820	Service_Key_Master_Counter-Last_Key	Update_Error
ENG108927-ENG99298	Service_Key_Master_Counter-State	Engine_off
ENG119884-ENG119838	Service_Key_Mileage_Date-CRC_Block_0	BF B1
ENG119884-ENG119860	Service_Key_Mileage_Date-CRC_Block_1	BF B3
ENG119884-ENG119856	Service_Key_Mileage_Date-CRC_Block_2	E2 33
ENG119884-ENG119857	Service_Key_Mileage_Date-CRC_Block_3	00 00
ENG119884-ENG119858	Service_Key_Mileage_Date-CRC_Block_4	00 00
ENG119884-ENG119859	Service_Key_Mileage_Date-CRC_Block_5	00 00
ENG119884-ENG119861	Service_Key_Mileage_Date-CRC_Block_6	00 00
ENG119884-ENG119873	Service_Key_Mileage_Date-CRC_Block_7	38 4E
ENG119884-ENG119837	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0	13	 d
ENG119884-ENG119867	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1	13	 d
ENG119884-ENG119868	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2	26	 d
ENG119884-ENG119866	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3	0	 d
ENG119884-ENG119865	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_4	0	 d
ENG119884-ENG119864	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_5	0	 d
ENG119884-ENG119863	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_6	0	 d
ENG119884-ENG119872	Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_7	1	 d
ENG119884-ENG119870	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0	4	 mon
ENG119884-ENG119836	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1	4	 mon
ENG119884-ENG119850	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2	8	 mon
ENG119884-ENG119851	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3	0	 mon
ENG119884-ENG119852	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_4	0	 mon
ENG119884-ENG119853	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_5	0	 mon
ENG119884-ENG119854	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_6	0	 mon
ENG119884-ENG119855	Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_7	1	 mon
ENG119884-ENG119869	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0	2011	 yr
ENG119884-ENG119835	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1	2011	 yr
ENG119884-ENG119845	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2	2018	 yr
ENG119884-ENG119846	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3	2000	 yr
ENG119884-ENG119847	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_4	2000	 yr
ENG119884-ENG119848	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_5	2000	 yr
ENG119884-ENG119849	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_6	2000	 yr
ENG119884-ENG119862	Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_7	2011	 yr
ENG119884-ENG119834	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0	17
ENG119884-ENG119839	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1	19
ENG119884-ENG119840	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2	137
ENG119884-ENG119841	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3	0
ENG119884-ENG119842	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_4	0
ENG119884-ENG119843	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_5	0
ENG119884-ENG119844	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_6	0
ENG119884-ENG119871	Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_7	7
ENG108929-ENG99961	Service_Key_Pointer-Current_Bank	Bank_1
ENG108929-ENG119808	Service_Key_Pointer-Write_Pointer_Adr_159	4
ENG108929-ENG119809	Service_Key_Pointer-Write_Pointer_Adr_191	4
ENG108929-ENG119810	Service_Key_Pointer-Write_Pointer_Adr_223	4
ENG100879-ENG118224	State Blocking Time-blocking_time	00 00 00 00 00 00
ENG103899-ENG99298	State of Immobilizer-State	02 01 03 6A 02 00 00 00 00 00
ENG103284-ENG118223	State of Immobilizer Slaves-ELV_State	0
ENG103284-ENG118222	State of Immobilizer Slaves-GSG_State	F8
ENG103284-ENG118217	State of Immobilizer Slaves-Immobilizer_State	0
ENG103284-ENG118216	State of Immobilizer Slaves-key_state	FC
ENG103284-ENG118218	State of Immobilizer Slaves-MSG_1_State	F8
ENG103284-ENG118219	State of Immobilizer Slaves-MSG_2_State	0
ENG103284-ENG118220	State of Immobilizer Slaves-MSG_3_State	0
ENG103284-ENG118221	State of Immobilizer Slaves-MSG_4_State	0
ENG103284-ENG20775	State of Immobilizer Slaves-OCU_state	0
ENG103284-ENG20776	State of Immobilizer Slaves-VTS_state	0
ENG109575	Transponder ID current Key	09 88 8F 19
ENG109576	Transponder ID Key 1	09 88 8F 19
ENG109577	Transponder ID Key 2	09 88 E6 91
Elapsed Time: 00:12
Keithuk
Stoke on Trent, England
C?ID=122432
Chassis Type: AU-VW37 (3Q0)
AutoScan.txt doesn't list 3Q or Alltrack are you using your works VCDS?
BA,VW Golf Variant VII (2014 >),00
Dana
Western PA, USA
19-CAN Gateway
adpmap-19-3Q0-907-530-F_3VWH17AU5JM758941-20180826-1113.CSV
;SW:3Q0-907-530-F   HW:3Q0-907-530-B ---  CAN Gateway
;Component:GW MQB Mid    517 5304	 Coding:0101000830085900FB0020081E0F00000001070000000000000000000000
;EV_GatewNF	13023	EV_GatewNF_VW27.rod
;Sunday	26	August	2018	11:13:12:04045
;VCID: 323E10A1F4AF9D47576-8066
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys	Deactivating 	3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation	Deactivating 	3
IDE00002-Transport mode	not active 	1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation	12.1 V	2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering	12.1 V	2
IDE01211-Static current measuring mode	not activated 	1
IDE01457-Energy management deactivation stage	Mode not active 	1
IDE01459-Energy management heat output control status	Mode not active 	1
IDE01844-Increase idle speed request	Mode not active 	1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time	-- 	3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation	Mode not active 	3
IDE01860-Generator specified voltage value variable	10.6 V	1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1	coded 	32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module	coded 	32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1	coded 	32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side	Not coded 	32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning	coded 	32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics	coded 	32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater	Not coded 	32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1	Not coded 	32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control	Not coded 	32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics	Not coded 	32
IDE01996-SFT00021-Installation list: specified installations-Airbag	coded 	32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics	coded 	32
IDE01996-SFT00023-Installation list: specified installations-Dash Board	coded 	32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater	Not coded 	32
IDE01996-SFT00025-Installation list: specified installations-Gateway	1	32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection	Not coded 	32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance	Not coded 	32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2	Not coded 	32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control	coded 	32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost	Not coded 	32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control	Not coded 	32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking	Not coded 	32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2	Not coded 	32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics	Not coded 	32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side	Not coded 	32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant	Not coded 	32
IDE01996-SFT00061-Installation list: specified installations-Special Function	Not coded 	32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor	Not coded 	32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side	coded 	32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance	coded 	32
IDE01996-SFT00071-Installation list: specified installations-Sound System	Not coded 	32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Not coded 	32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module	Not coded 	32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side	coded 	32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation	Not coded 	32
IDE01996-SFT00086-Installation list: specified installations-Radio	Not coded 	32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner	Not coded 	32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1	coded 	32
IDE01996-SFT00096-Installation list: specified installations-Tachograph	Not coded 	32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1	Not coded 	32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function	Not coded 	32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View	Not coded 	32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit	Not coded 	32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	Not coded 	32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance	Not coded 	32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1	Not coded 	32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display	Not coded 	32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module	Not coded 	32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System	Not coded 	32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit	Not coded 	32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound	Not coded 	32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface	Not coded 	32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side	Not coded 	32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side	Not coded 	32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management	Not coded 	32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left	Not coded 	32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right	Not coded 	32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise	Not coded 	32
IDE01996-SFT00197-Installation list: specified installations-Thermal management	Not coded 	32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module	Not coded 	32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof	Not coded 	32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module	Not coded 	32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2	Not coded 	32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01	Not coded 	32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02	Not coded 	32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03	Not coded 	32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04	Not coded 	32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05	Not coded 	32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06	Not coded 	32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07	Not coded 	32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08	Not coded 	32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D	Not coded 	32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11	Not coded 	32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16	Not coded 	32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17	Not coded 	32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A	Not coded 	32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D	Not coded 	32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F	Not coded 	32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20	Not coded 	32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21	Not coded 	32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22	Not coded 	32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24	Not coded 	32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25	Not coded 	32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26	Not coded 	32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27	Not coded 	32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28	Not coded 	32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29	Not coded 	32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A	Not coded 	32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E	Not coded 	32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F	Not coded 	32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35	Not coded 	32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36	Not coded 	32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37	Not coded 	32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38	Not coded 	32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39	Not coded 	32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A	Not coded 	32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C	Not coded 	32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D	Not coded 	32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40	Not coded 	32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41	Not coded 	32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43	Not coded 	32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45	Not coded 	32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48	Not coded 	32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49	Not coded 	32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51	Not coded 	32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52	Not coded 	32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53	Not coded 	32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55	Not coded 	32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56	Not coded 	32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58	Not coded 	32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59	Not coded 	32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A	Not coded 	32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B	Not coded 	32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C	Not coded 	32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D	Not coded 	32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E	Not coded 	32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F	Not coded 	32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60	Not coded 	32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61	Not coded 	32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62	Not coded 	32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66	Not coded 	32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68	Not coded 	32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B	Not coded 	32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C	Not coded 	32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E	Not coded 	32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74	Not coded 	32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75	Not coded 	32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78	Not coded 	32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79	Not coded 	32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A	Not coded 	32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D	Not coded 	32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E	Not coded 	32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F	Not coded 	32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80	Not coded 	32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81	Not coded 	32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82	Not coded 	32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83	Not coded 	32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86	Not coded 	32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87	Not coded 	32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88	Not coded 	32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89	Not coded 	32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B	Not coded 	32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C	Not coded 	32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D	Not coded 	32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E	Not coded 	32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F	Not coded 	32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90	Not coded 	32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91	Not coded 	32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92	Not coded 	32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93	Not coded 	32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94	Not coded 	32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95	Not coded 	32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96	Not coded 	32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97	Not coded 	32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98	Not coded 	32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99	Not coded 	32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A	Not coded 	32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B	Not coded 	32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D	Not coded 	32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E	Not coded 	32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F	Not coded 	32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0	Not coded 	32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1	Not coded 	32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2	Not coded 	32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3	Not coded 	32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5	Not coded 	32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6	Not coded 	32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7	Not coded 	32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8	Not coded 	32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA	Not coded 	32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB	Not coded 	32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC	Not coded 	32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD	Not coded 	32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF	Not coded 	32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0	Not coded 	32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1	Not coded 	32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2	Not coded 	32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3	Not coded 	32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4	Not coded 	32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5	Not coded 	32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6	Not coded 	32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7	Not coded 	32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8	Not coded 	32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9	Not coded 	32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA	Not coded 	32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB	Not coded 	32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC	Not coded 	32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD	Not coded 	32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE	Not coded 	32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF	Not coded 	32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0	Not coded 	32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1	Not coded 	32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2	Not coded 	32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3	Not coded 	32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4	Not coded 	32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5	Not coded 	32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6	Not coded 	32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7	Not coded 	32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8	Not coded 	32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9	Not coded 	32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA	Not coded 	32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB	Not coded 	32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC	Not coded 	32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD	Not coded 	32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE	Not coded 	32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF	Not coded 	32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0	Not coded 	32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1	Not coded 	32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2	Not coded 	32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3	Not coded 	32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4	Not coded 	32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5	Not coded 	32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6	Not coded 	32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7	Not coded 	32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8	Not coded 	32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9	Not coded 	32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA	Not coded 	32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB	Not coded 	32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC	Not coded 	32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD	Not coded 	32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE	Not coded 	32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF	Not coded 	32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0	Not coded 	32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1	Not coded 	32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2	Not coded 	32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3	Not coded 	32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4	Not coded 	32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5	Not coded 	32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6	Not coded 	32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7	Not coded 	32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8	Not coded 	32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9	Not coded 	32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA	Not coded 	32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB	Not coded 	32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC	Not coded 	32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED	Not coded 	32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE	Not coded 	32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF	Not coded 	32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0	Not coded 	32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1	Not coded 	32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2	Not coded 	32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3	Not coded 	32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4	Not coded 	32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5	Not coded 	32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6	Not coded 	32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7	Not coded 	32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8	Not coded 	32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9	Not coded 	32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA	Not coded 	32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB	Not coded 	32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC	Not coded 	32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD	Not coded 	32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE	Not coded 	32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF	Not coded 	32
IDE02332-Deactivate production mode	0	3
IDE03256-MAS06105-Battery adaptation-Rated battery capacity	60 Ah	15
IDE03256-MAS06106-Battery adaptation-Battery technology	Wet 	15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer	JCB 	15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number	1111111111	15
IDE03903-Production process data 1	00 00 	2
IDE04159-Deactivation of start-stop function	Mode not active 	1
IDE04186-Battery terminal recognition	connected 	1
IDE04330-Transfer of release code for a SWaP function	0	1
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE06530-Distance left for deactivation of static current measuring mode	2	1
IDE06541-Distance left for deactivation of transport mode	50	1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof	activated 	4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM	activated 	4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start	activated 	4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)	activated 	4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system	activated 	4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system	activated 	4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof	not activated 	4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D	activated 	4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill	activated 	4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)	activated 	4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill	activated 	4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C	activated 	4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater	activated 	4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater	activated 	4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater	activated 	4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation	activated 	4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater	activated 	4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light	activated 	4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light	not activated 	4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission	activated 	4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater	activated 	4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater	activated 	4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater	activated 	4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater	activated 	4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation	activated 	4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection	ECO tips independent of driver profile selection 	4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption	activated 	4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency	Until temperature threshold: with after-run: with switch 	4
IDE07838-Counter for inconsistent states	0	2
IDE08348-Start/stop start voltage limit	7.6 V	1
IDE08624-MKE Check box	activated 	1
IDE10735-Number requests autonomous recharging	3	1
IDE10736-Cyclization limitation request battery service	0	1
IDE10748-MAS11262-Range gain-Range gain AC system	activated 	3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater	activated 	3
IDE10748-MAS11264-Range gain-Range gain window defogger	activated 	3
IDE10748-MAS11265-Range gain-Range gain seat heater front	activated 	3
IDE10748-MAS11266-Range gain-Range gain front set ventilation	activated 	3
IDE10748-MAS11267-Range gain-Range gain rear heater	activated 	3
IDE10748-MAS11268-Range gain-Range gain fog light	activated 	3
IDE10748-MAS11269-Range gain-Range gain rear fog light	not activated 	3
IDE10748-MAS11270-Range gain-Range gain windshield heating	activated 	3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater	activated 	3
IDE10748-MAS11272-Range gain-Range gain mirror heater	activated 	3
IDE10748-MAS11273-Range gain-Range gain rear seat heater	activated 	3
IDE10748-MAS11274-Range gain-Range gain rear seat heater	activated 	3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system	not activated 	3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system	not activated 	3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption	not activated 	3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain	not activated 	3
IDE10748-MAS11279-Range gain-List at engine still stand	activated 	3
IDE10748-MAS12689-Range gain-Catalogue range display	activated 	3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display	activated 	3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting	activated 	3
IDE10748-MAS19099-Range gain-Convenience consumption socket	activated 	3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption	activated 	3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating	activated 	3
IDE11689-48V-System: locking	regular operation 	1
MAS16372-Security version number	2	2
SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch	installed 	3
SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage	Unknown (3)	3
SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version	Unknown (4)	3
SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor	not installed 	3
SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run	active 	3
SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function	not active 	3
SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function	active 	3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset	active 	12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation	100	12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation	60000 ms	12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation	10000 ms	12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption	3000 ms	12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption	0 ms	12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation	180000 ms	12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation	1500 ms	12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation	0 ms	12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption	2500 ms	12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen	Mode not active 	4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level	Mode not active 	4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen	Mode not active 	4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen	Mode not active 	4
ENG137075-EM_heating_power_quota_adjustment	1000 W	1
ENG137061-EM_nominal_voltage_limitation_low_beams	12.1 V	1
ENG137064-EM_requirement_cyclic_time_voltage_measurement	0 s	1
ENG137063-EM_requirement_reduction_air_blowers	Mode not active 	1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature	-50.0 °C	2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature	-50.0 °C	2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1	Enabled 	32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module	Enabled 	32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1	not enabled 	32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side	Enabled 	32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning	Enabled 	32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics	Enabled 	32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater	Enabled 	32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1	Enabled 	32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control	Enabled 	32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics	Enabled 	32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag	not enabled 	32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics	Enabled 	32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board	Enabled 	32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater	Enabled 	32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway	Enabled 	32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection	Enabled 	32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance	Enabled 	32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2	Enabled 	32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control	Enabled 	32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost	Enabled 	32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control	Enabled 	32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking	Enabled 	32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2	Enabled 	32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics	Enabled 	32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side	Enabled 	32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant	Enabled 	32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function	Enabled 	32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor	Enabled 	32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side	Enabled 	32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance	Enabled 	32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System	Enabled 	32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module	Enabled 	32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module	Enabled 	32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side	Enabled 	32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation	Enabled 	32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio	Enabled 	32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner	Enabled 	32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1	Enabled 	32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph	Enabled 	32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1	Enabled 	32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function	Enabled 	32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View	Enabled 	32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit	Enabled 	32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit	Enabled 	32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance	Enabled 	32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1	Enabled 	32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display	Enabled 	32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module	Enabled 	32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System	Enabled 	32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit	Enabled 	32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound	Enabled 	32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface	Enabled 	32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side	Enabled 	32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side	Enabled 	32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management	Enabled 	32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left	Enabled 	32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right	Enabled 	32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise	Enabled 	32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management	Enabled 	32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module	Enabled 	32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof	Enabled 	32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module	Enabled 	32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2	Enabled 	32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00	Enabled 	32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01	Enabled 	32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02	Enabled 	32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03	Enabled 	32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04	Enabled 	32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05	Enabled 	32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06	Enabled 	32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07	Enabled 	32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08	Enabled 	32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D	Enabled 	32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11	Enabled 	32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16	Enabled 	32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17	Enabled 	32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A	Enabled 	32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D	Enabled 	32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F	Enabled 	32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20	Enabled 	32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21	Enabled 	32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22	Enabled 	32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24	Enabled 	32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25	Enabled 	32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26	Enabled 	32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27	Enabled 	32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28	Enabled 	32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29	Enabled 	32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A	Enabled 	32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E	Enabled 	32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F	Enabled 	32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35	Enabled 	32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36	Enabled 	32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37	Enabled 	32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38	Enabled 	32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39	Enabled 	32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A	Enabled 	32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C	Enabled 	32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D	Enabled 	32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40	Enabled 	32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41	Enabled 	32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43	Enabled 	32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45	Enabled 	32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48	Enabled 	32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49	Enabled 	32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51	Enabled 	32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52	Enabled 	32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53	Enabled 	32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55	Enabled 	32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56	Enabled 	32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58	Enabled 	32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59	Enabled 	32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A	Enabled 	32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B	Enabled 	32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C	Enabled 	32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D	Enabled 	32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E	Enabled 	32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F	Enabled 	32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60	Enabled 	32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61	Enabled 	32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62	Enabled 	32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66	Enabled 	32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68	Enabled 	32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B	Enabled 	32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C	Enabled 	32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E	Enabled 	32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74	Enabled 	32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75	Enabled 	32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78	Enabled 	32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79	Enabled 	32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A	Enabled 	32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D	Enabled 	32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E	Enabled 	32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F	Enabled 	32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80	Enabled 	32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81	Enabled 	32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82	Enabled 	32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83	Enabled 	32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86	Enabled 	32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87	Enabled 	32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88	Enabled 	32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89	Enabled 	32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B	Enabled 	32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C	Enabled 	32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D	Enabled 	32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E	Enabled 	32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F	Enabled 	32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90	Enabled 	32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91	Enabled 	32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92	Enabled 	32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93	Enabled 	32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94	Enabled 	32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95	Enabled 	32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96	Enabled 	32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97	Enabled 	32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98	Enabled 	32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99	Enabled 	32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A	Enabled 	32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B	Enabled 	32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D	Enabled 	32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E	Enabled 	32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F	Enabled 	32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0	Enabled 	32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1	Enabled 	32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2	Enabled 	32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3	Enabled 	32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5	Enabled 	32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6	Enabled 	32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7	Enabled 	32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8	Enabled 	32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA	Enabled 	32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB	Enabled 	32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC	Enabled 	32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD	Enabled 	32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF	Enabled 	32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0	Enabled 	32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1	Enabled 	32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2	Enabled 	32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3	Enabled 	32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4	Enabled 	32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5	Enabled 	32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6	Enabled 	32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7	Enabled 	32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8	Enabled 	32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9	Enabled 	32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA	Enabled 	32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB	Enabled 	32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC	Enabled 	32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD	Enabled 	32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE	Enabled 	32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF	Enabled 	32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0	Enabled 	32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1	Enabled 	32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2	Enabled 	32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3	Enabled 	32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4	Enabled 	32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5	Enabled 	32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6	Enabled 	32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7	Enabled 	32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8	Enabled 	32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9	Enabled 	32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA	Enabled 	32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB	Enabled 	32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC	Enabled 	32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD	Enabled 	32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE	Enabled 	32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF	Enabled 	32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0	Enabled 	32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1	Enabled 	32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2	Enabled 	32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3	Enabled 	32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4	Enabled 	32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5	Enabled 	32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6	Enabled 	32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7	Enabled 	32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8	Enabled 	32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9	Enabled 	32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA	Enabled 	32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB	Enabled 	32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC	Enabled 	32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD	Enabled 	32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE	Enabled 	32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF	Enabled 	32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0	Enabled 	32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1	Enabled 	32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2	Enabled 	32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3	Enabled 	32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4	Enabled 	32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5	Enabled 	32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6	Enabled 	32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7	Enabled 	32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8	Enabled 	32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9	Enabled 	32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA	Enabled 	32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB	Enabled 	32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC	Enabled 	32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED	Enabled 	32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE	Enabled 	32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF	Enabled 	32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0	Enabled 	32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1	Enabled 	32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2	Enabled 	32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3	Enabled 	32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4	Enabled 	32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5	Enabled 	32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6	Enabled 	32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7	Enabled 	32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8	Enabled 	32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9	Enabled 	32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA	Enabled 	32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB	Enabled 	32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC	Enabled 	32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD	Enabled 	32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE	Enabled 	32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF	Enabled 	32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus	Databus drivetrain 	2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ	not active 	2
ENG152379-MV-EM_adaption_48V_zero_potential	regular operation 	1
ENG137850-MVK_Warning	regular operation 	1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation	activated 	1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate	activated 	1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events	100	8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events	20	8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events	10	8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time	120 min	8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events	12 s	8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay	0 s	8
Elapsed Time: 00:23
blockmap-19-3Q0-907-530-F_3VWH17AU5JM758941-20180826-1112.CSV
;Sunday	26	August	2018	11:12:25:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
Group	Description	Actual
IDE00019	Voltage terminal 30	14.4	 V
IDE00020	Terminal 15 status	Terminal 15 on
IDE00030	Status of actuator test	not active
IDE00056-ENG20489	History data 1-Life Cycle Data String	-------------:--*--.-*--*-----***
IDE00057-ENG20489	History data 2-Life Cycle Data String	-------------:--*---*---*--.---*-------------*-*--*-----**
IDE00058-ENG20489	History data 3-Life Cycle Data String	       0000058km*1*0*020*006*0-0-0-0-1-0-0*0*0*00.0*00.0**
       0000045km*1*0*020*006*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000045km*1*0*020*006*0-0-1-0-1-0-0*0*0*00.0*00.0**
       0000031km*1*0*020*006*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000017km*T*0*100*100*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000016km*T*0*090*100*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000016km*T*0*100*100*0-0-0-0-0-0-0*0*0*00.0*00.0**
       0000016km*T*0*100*100*0-0-0-0-1-0-0*0*0*00.0*00.0**
IDE00059-ENG20489	History data 4-Life Cycle Data String	       0000000km*01*060*JCB*1111111111*10000*00000*000.0*000.0*000.0**
IDE00060-ENG20489	History data 5-Life Cycle Data String	-------------:--*-*--.---*--.--*---*--*---.-*-----*-----*------*-------------*-*-*-*--.-*--.-*---.-*--*--*--*--*--**
IDE00061-ENG20489	History data 6-Life Cycle Data String	2018-08-26-10:31*100*-40*+000.0*00.10*0.00*000**
2018-08-25-18:21*100*-40*+000.0*00.30*0.00*000**
2018-08-25-18:08*100*-40*+000.0*00.10*0.00*000**
2018-08-25-16:57*100*-40*+000.0*00.40*0.00*000**
2018-08-23-19:00*100*-40*+000.0*00.10*0.00*000**
2018-08-22-08:41*100*-40*+000.0*00.10*0.00*000**
2018-08-21-18:37*100*-40*+000.0*00.20*0.00*000**
       0000058km*100*-40*+000.0*00.20*0.00*000**
       0000045km*100*-40*+000.0*00.20*0.00*000**
       0000045km*100*-40*+000.0*00.10*0.00*000**
IDE00062-ENG20489	History data 7-Life Cycle Data String	-------------:--*---*----.-*---.-*--.-*--.-**
IDE00063-ENG20489	History data 8-Life Cycle Data String	2018-08-20-19:13*4*00*00*00*01*2011-10-25-06:34*01**
IDE00064-ENG20489	History data 9-Life Cycle Data String	       0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
IDE00065-ENG20489	History data 10-Life Cycle Data String	-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066-ENG20489	History data 11-Life Cycle Data String	-------------:--*---*---*---*---*----*---*--.-*--.-*---*---*---*---*--*-----*-----*-----*-----*-----**
IDE00067-ENG20489	History data 12-Life Cycle Data String	-------------:--*---------------**
IDE00068-ENG20489	History data 13-Life Cycle Data String	-------------:--*---------*---.-*-----**
IDE00071-ENG20489	History data 16-Life Cycle Data String	       0000138km**
00000*00000*00000*00000*00000**
00120*00012*00001*00000**
00839*00006*00000*00000**
00093*00024*00004*00003**
00113*00010*00001**
00017*00000*00000**
00000*00000*00000**
00006*00000*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
IDE00322	Status of basic setting	was not yet started
IDE00323	Security Access: Number of invalid keys	0
IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	No malfunction detected
IDE00356	Cruise Control System (CCS): switch position	OFF
IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	not activated
IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	Engaged ON
IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	not activated
IDE00356-MAS00324	Cruise Control System (CCS): switch position-Accelerate tap	not activated
IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	not activated
IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	not activated
IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	not activated
IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	5
IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	not activated
IDE00356-MAS04522	Cruise Control System (CCS): switch position-Delay tip level 2	not activated
IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	CCS Switch
IDE00356-MAS05812	Cruise Control System (CCS): switch position-Limit button	not installed
IDE00356-MAS06029	Cruise Control System (CCS): switch position-MFL message counter	3
IDE00356-MAS06879	Cruise Control System (CCS): switch position-Checksum	139
IDE00767-ENG123029	No. of unscheduled ECU resets-Counter_Watchdog_Resets	0
IDE00773	Terminal 15 status via CAN	On
IDE01285	Counter of component protection malfunctions	0
IDE01459	Energy management heat output control status	not active
IDE01805-ENG20489	History data 19-Life Cycle Data String	-------------:--*-----*---*---*---**
IDE01807-IDE07142	History data 21-Time since terminal 15 off	0	 H
IDE01807-MAS00106	History data 21-Year	2000
IDE01807-MAS00107	History data 21-Month	1
IDE01807-MAS00108	History data 21-Day	1
IDE01807-MAS00109	History data 21-Hours	0	 H
IDE01807-MAS00110	History data 21-Minutes	0	 min
IDE01807-MAS14375	History data 21-Cycle counter	0
IDE01807-MAS14376	History data 21-ECU 1	Node_0x-- $-- (empty entry)
IDE01807-MAS14377	History data 21-Alert maintenance time for ECU 1	0	 H
IDE01807-MAS14378	History data 21-Repetition counter for ECU 1	0
IDE01807-MAS14379	History data 21-ECU 2	Node_0x-- $-- (empty entry)
IDE01807-MAS14380	History data 21-Alert maintenance time for ECU 2	0	 H
IDE01807-MAS14381	History data 21-Repetition counter for ECU 2	0
IDE01807-MAS14382	History data 21-ECU 3	Node_0x-- $-- (empty entry)
IDE01807-MAS14383	History data 21-Alert maintenance time for ECU 3	0	 H
IDE01807-MAS14384	History data 21-Repetition counter for ECU 3	0
IDE01807-MAS14385	History data 21-ECU 4	Node_0x-- $-- (empty entry)
IDE01807-MAS14386	History data 21-Alert maintenance time for ECU 4	0	 H
IDE01807-MAS14387	History data 21-Repetition counter for ECU 4	0
IDE01807-MAS14388	History data 21-ECU 5	Node_0x-- $-- (empty entry)
IDE01807-MAS14389	History data 21-Alert maintenance time for ECU 5	0	 H
IDE01807-MAS14390	History data 21-Repetition counter for ECU 5	0
IDE01808-MAS03173	History data 22-Databus drivetrain	0	 H
IDE01808-MAS03174	History data 22-Comfort data bus	0	 H
IDE01808-MAS03175	History data 22-Databus extended	0	 H
IDE01808-MAS03176	History data 22-Display and control head databus	0	 H
IDE01808-MAS03177	History data 22-Databus Infotainment	0	 H
IDE01808-MAS03178	History data 22-Suspension data bus	0	 H
IDE01808-MAS03179	History data 22-Local data bus 2	0	 H
IDE01808-MAS03180	History data 22-Local data bus	0	 H
IDE01808-MAS05686	History data 22-Data bus diagnostics	0	 H
IDE01808-MAS14373	History data 22-All BUS systems	0	 H
IDE01809-IDE07142	History data 23-Time since terminal 15 off	0	 H
IDE01809-MAS00106	History data 23-Year	2000
IDE01809-MAS00107	History data 23-Month	1
IDE01809-MAS00108	History data 23-Day	1
IDE01809-MAS00109	History data 23-Hours	0	 H
IDE01809-MAS00110	History data 23-Minutes	0	 min
IDE01809-MAS14375	History data 23-Cycle counter	0
IDE01809-MAS14395	History data 23-Bus with maximum number of post alarms	Unknown
IDE01809-MAS14396	History data 23-Post alerts in current cycle	0
IDE01809-MAS14397	History data 23-Rousing ECU 1	Node_0x-- $-- (empty entry)
IDE01809-MAS14398	History data 23-Number of post alerts for control module 1	0
IDE01809-MAS14399	History data 23-CarWakeUp bit 1	0
IDE01809-MAS14400	History data 23-Rousing ECU 2	Node_0x-- $-- (empty entry)
IDE01809-MAS14401	History data 23-Number of post alerts for control module 2	0
IDE01809-MAS14402	History data 23-CarWakeUp bit 2	0
IDE01809-MAS14403	History data 23-Rousing ECU 3	Node_0x-- $-- (empty entry)
IDE01809-MAS14404	History data 23-Number of post alerts for control module 3	0
IDE01809-MAS14405	History data 23-CarWakeUp bit 3	0
IDE01809-MAS14406	History data 23-Rousing ECU 4	Node_0x-- $-- (empty entry)
IDE01809-MAS14407	History data 23-Number of post alerts for control module 4	0
IDE01809-MAS14408	History data 23-CarWakeUp bit 4	0
IDE01809-MAS14409	History data 23-Rousing ECU 5	Node_0x-- $-- (empty entry)
IDE01809-MAS14410	History data 23-Number of post alerts for control module 5	0
IDE01809-MAS14411	History data 23-CarWakeUp bit 5	0
IDE01810-IDE07142	History data 24-Time since terminal 15 off	41.6	 H
IDE01810-MAS00106	History data 24-Year	2018
IDE01810-MAS00107	History data 24-Month	8
IDE01810-MAS00108	History data 24-Day	25
IDE01810-MAS00109	History data 24-Hours	12	 H
IDE01810-MAS00110	History data 24-Minutes	45	 min
IDE01810-MAS14375	History data 24-Cycle counter	138
IDE01810-MAS14399	History data 24-CarWakeUp bit 1	0
IDE01810-MAS14402	History data 24-CarWakeUp bit 2	0
IDE01810-MAS14405	History data 24-CarWakeUp bit 3	0
IDE01810-MAS14408	History data 24-CarWakeUp bit 4	0
IDE01810-MAS14411	History data 24-CarWakeUp bit 5	0
IDE01810-MAS14412	History data 24-Bus with maximum number of alerts	Comfort data bus
IDE01810-MAS14413	History data 24-Alert events in current cycle	28
IDE01810-MAS14414	History data 24-ID of the alerting message 1	1B FC 72 0A
IDE01810-MAS14415	History data 24-Counter of the alerting message 1	4
IDE01810-MAS14416	History data 24-Bus of the alerting message 1	Comfort data bus
IDE01810-MAS14417	History data 24-ID of the alerting message 2	00 00 05 F4
IDE01810-MAS14418	History data 24-Counter of the alerting message 2	3
IDE01810-MAS14419	History data 24-Bus of the alerting message 2	Comfort data bus
IDE01810-MAS14420	History data 24-ID of the alerting message 3	1B 00 00 4A
IDE01810-MAS14421	History data 24-Counter of the alerting message 3	1
IDE01810-MAS14422	History data 24-Bus of the alerting message 3	Comfort data bus
IDE01810-MAS14423	History data 24-ID of the alerting message 4	1B 00 00 14
IDE01810-MAS14424	History data 24-Counter of the alerting message 4	1
IDE01810-MAS14425	History data 24-Bus of the alerting message 4	Comfort data bus
IDE01810-MAS14426	History data 24-ID of the alerting message 5	00 00 05 E1
IDE01810-MAS14427	History data 24-Counter of the alerting message 5	1
IDE01810-MAS14428	History data 24-Bus of the alerting message 5	Comfort data bus
IDE01812-MAS01468	History data 26-Terminal 15	142
IDE01812-MAS03173	History data 26-Databus drivetrain	6
IDE01812-MAS03174	History data 26-Comfort data bus	681
IDE01812-MAS03175	History data 26-Databus extended	0
IDE01812-MAS03177	History data 26-Databus Infotainment	0
IDE01812-MAS03178	History data 26-Suspension data bus	125
IDE01812-MAS03180	History data 26-Local data bus	0
IDE01812-MAS05686	History data 26-Data bus diagnostics	0
IDE01812-MAS14374	History data 26-Totals	812
IDE01813-MAS03173	History data 27-Databus drivetrain	130
IDE01813-MAS03174	History data 27-Comfort data bus	443
IDE01813-MAS03175	History data 27-Databus extended	0
IDE01813-MAS03177	History data 27-Databus Infotainment	61
IDE01813-MAS03178	History data 27-Suspension data bus	149
IDE01813-MAS14374	History data 27-Totals	783
IDE01814-MAS03173	History data 28-Databus drivetrain	0
IDE01814-MAS03174	History data 28-Comfort data bus	977
IDE01814-MAS03175	History data 28-Databus extended	0
IDE01814-MAS03177	History data 28-Databus Infotainment	0
IDE01814-MAS03178	History data 28-Suspension data bus	0
IDE01814-MAS14374	History data 28-Totals	977
IDE01816-IDE07142	History data 30-Time since terminal 15 off	2	 H
IDE01816-MAS00106	History data 30-Year	2011
IDE01816-MAS00107	History data 30-Month	4
IDE01816-MAS00108	History data 30-Day	5
IDE01816-MAS00109	History data 30-Hours	2	 H
IDE01816-MAS00110	History data 30-Minutes	3	 min
IDE01816-MAS14375	History data 30-Cycle counter	68
IDE01816-ENG20570	History data 30-Bus_1	Suspension data bus
IDE01816-ENG20572	History data 30-Bus_2	Unknown
IDE01816-ENG20574	History data 30-Bus_3	Unknown
IDE01816-ENG20576	History data 30-Bus_4	Unknown
IDE01816-ENG20578	History data 30-Bus_5	Unknown
IDE01816-ENG20571	History data 30-Bus_Active_Time_1	0.1	 H
IDE01816-ENG20573	History data 30-Bus_Active_Time_2	0	 H
IDE01816-ENG20575	History data 30-Bus_Active_Time_3	0	 H
IDE01816-ENG20577	History data 30-Bus_Active_Time_4	0	 H
IDE01816-ENG20579	History data 30-Bus_Active_Time_5	0	 H
IDE01817-IDE07142	History data 31-Time since terminal 15 off	0	 H
IDE01817-MAS00106	History data 31-Year	2000
IDE01817-MAS00107	History data 31-Month	1
IDE01817-MAS00108	History data 31-Day	1
IDE01817-MAS00109	History data 31-Hours	0	 H
IDE01817-MAS00110	History data 31-Minutes	0	 min
IDE01817-MAS14375	History data 31-Cycle counter	0
IDE01817-MAS14376	History data 31-ECU 1	Node_0x-- $-- (empty entry)
IDE01817-MAS14377	History data 31-Alert maintenance time for ECU 1	0	 H
IDE01817-MAS14378	History data 31-Repetition counter for ECU 1	0
IDE01817-MAS14379	History data 31-ECU 2	Node_0x-- $-- (empty entry)
IDE01817-MAS14380	History data 31-Alert maintenance time for ECU 2	0	 H
IDE01817-MAS14381	History data 31-Repetition counter for ECU 2	0
IDE01817-MAS14382	History data 31-ECU 3	Node_0x-- $-- (empty entry)
IDE01817-MAS14383	History data 31-Alert maintenance time for ECU 3	0	 H
IDE01817-MAS14384	History data 31-Repetition counter for ECU 3	0
IDE01817-MAS14385	History data 31-ECU 4	Node_0x-- $-- (empty entry)
IDE01817-MAS14386	History data 31-Alert maintenance time for ECU 4	0	 H
IDE01817-MAS14387	History data 31-Repetition counter for ECU 4	0
IDE01817-MAS14388	History data 31-ECU 5	Node_0x-- $-- (empty entry)
IDE01817-MAS14389	History data 31-Alert maintenance time for ECU 5	0	 H
IDE01817-MAS14390	History data 31-Repetition counter for ECU 5	0
IDE01818-IDE07142	History data 32-Time since terminal 15 off	0	 H
IDE01818-MAS00106	History data 32-Year	2000
IDE01818-MAS00107	History data 32-Month	1
IDE01818-MAS00108	History data 32-Day	1
IDE01818-MAS00109	History data 32-Hours	0	 H
IDE01818-MAS00110	History data 32-Minutes	0	 min
IDE01818-MAS14375	History data 32-Cycle counter	0
IDE01818-MAS14391	History data 32-Alerting ECU	Node_0x-- $-- (empty entry)
IDE01818-MAS14392	History data 32-CarWakeUp Bit	0
IDE01819-IDE07142	History data 33-Time since terminal 15 off	41.6	 H
IDE01819-MAS00106	History data 33-Year	2018
IDE01819-MAS00107	History data 33-Month	8
IDE01819-MAS00108	History data 33-Day	25
IDE01819-MAS00109	History data 33-Hours	12	 H
IDE01819-MAS00110	History data 33-Minutes	45	 min
IDE01819-MAS14375	History data 33-Cycle counter	138
IDE01819-MAS14393	History data 33-ID of the alerting message	1B FC 72 0A
IDE01819-MAS14394	History data 33-Bus of the alerting message	Comfort data bus
IDE01820-IDE07142	History data 34-Time since terminal 15 off	0	 H
IDE01820-MAS00106	History data 34-Year	2018
IDE01820-MAS00107	History data 34-Month	8
IDE01820-MAS00108	History data 34-Day	26
IDE01820-MAS00109	History data 34-Hours	11	 H
IDE01820-MAS00110	History data 34-Minutes	9	 min
IDE01820-MAS14375	History data 34-Cycle counter	145
IDE01820-MAS14393	History data 34-ID of the alerting message	1B 00 00 0E
IDE01823-IDE07142	History data 37-Time since terminal 15 off	0	 H
IDE01823-MAS00106	History data 37-Year	2011
IDE01823-MAS00107	History data 37-Month	1
IDE01823-MAS00108	History data 37-Day	1
IDE01823-MAS00109	History data 37-Hours	0	 H
IDE01823-MAS00110	History data 37-Minutes	3	 min
IDE01823-MAS01632	History data 37-Status	activated
IDE01823-MAS14375	History data 37-Cycle counter	146
IDE01823-MAS14429	History data 37-Time in current cycle	0	 H
IDE01827	Generator specified voltage value	10.6	 V
IDE01828	Generator DF Signal	0.025	 %
IDE01829	Generator exciter current	0	 A
IDE01830-MAS01632	Generator Status-Status	Thermal OK
IDE01830-MAS02970	Generator Status-Status 2:	Mechanical OK
IDE01830-MAS02971	Generator Status-Status 3:	Electrical OK
IDE01831-MAS03159	Generator variant-Manufacturer	Robert Bosch GmbH
IDE01831-MAS06310	Generator variant-Generator identifier	110A - 150A MOSFET
IDE01832-MAS06311	Generator regulator variant-ASIC manufacturer	0
IDE01832-MAS06312	Generator regulator variant-ASIC variant	4
IDE01834	Battery voltage	14.41	 V
IDE01836	Battery current	0	 A
IDE01837	Temperature of battery sensor	-40	 °C
IDE01838	Battery temperature	-40	 °C
IDE01839	Battery charge condition	70	 %
IDE01841	Battery internal resistance	51	 mOhm
IDE01842	Usable battery charge	100	 Ah
IDE01843	Battery voltage at rest	12.4	 V
IDE01844	Increase idle speed request	no request
IDE01845	Reduce internal fan request	no request
IDE01846	Static current shutdown level	Deactivation stage 0
IDE01847	Auxiliary heater activation restriction request	Permitted
IDE01847-MAS06319	Auxiliary heater activation restriction request-Allowed parking heater runtime	ERROR
IDE01848	Previous journey energy summary	0	 Ah
IDE01849	Previous journey duration	0	 H
IDE01852	Static current measurement: result	Initializing
IDE01853	Static current measurement: status	Cancel
IDE01854	Energy reclamation request	not active
IDE01855	Generator current	0	 A
IDE01948	Battery internal resistance not normed	51	 mOhm
IDE01985-ENG101043	FAZIT identification test sum-Checksum	20 6B B0 BC
IDE01985-ENG99027	FAZIT identification test sum-Version	129
IDE02578-ENG06041	Play protection status-fiddle_proofing_1	not active
IDE02578-ENG06043	Play protection status-fiddle_proofing_2	not active
IDE02578-ENG06044	Play protection status-fiddle_proofing_3	not active
IDE02578-ENG06045	Play protection status-fiddle_proofing_4	not active
IDE02578-ENG06046	Play protection status-fiddle_proofing_5	not active
IDE02578-ENG06047	Play protection status-fiddle_proofing_6	not active
IDE02578-ENG06048	Play protection status-fiddle_proofing_7	not active
IDE02578-ENG06049	Play protection status-fiddle_proofing_8	not active
IDE02578-ENG06042	Play protection status-function_calls_counter_1	0
IDE02578-ENG06050	Play protection status-function_calls_counter_2	0
IDE02578-ENG06051	Play protection status-function_calls_counter_3	0
IDE02578-ENG06052	Play protection status-function_calls_counter_4	0
IDE02578-ENG06053	Play protection status-function_calls_counter_5	0
IDE02578-ENG06054	Play protection status-function_calls_counter_6	0
IDE02578-ENG06055	Play protection status-function_calls_counter_7	0
IDE02578-ENG06056	Play protection status-function_calls_counter_8	0
IDE03008-IDE01838	Stop process prevented-Battery temperature	not active
IDE03008-IDE01844	Stop process prevented-Increase idle speed request	not active
IDE03008-MAS02193	Stop process prevented-Outside air temperature	not active
IDE03008-MAS04054	Stop process prevented-Consumer current too high	not active
IDE03008-MAS04055	Stop process prevented-Usable battery charge too low	not active
IDE03008-MAS04056	Stop process prevented-Battery charge condition too low	not active
IDE03008-MAS04062	Stop process prevented-Possible service life too short	not active
IDE03008-MAS06001	Stop process prevented-Energy management special veto	not active
IDE03008-MAS06002	Stop process prevented-DC/DC converter Veto	not active
IDE03008-MAS19121	Stop process prevented-Successful restart done through freight quota	not active
IDE03009-MAS01478	Start process requested-Insuff. voltage	not active
IDE03009-MAS02885	Start process requested-Restart because of outside temperature	not active
IDE03009-MAS04054	Start process requested-Consumer current too high	not active
IDE03009-MAS04055	Start process requested-Usable battery charge too low	not active
IDE03009-MAS04056	Start process requested-Battery charge condition too low	not active
IDE03009-MAS04058	Start process requested-Service life expired	not active
IDE03009-MAS06003	Start process requested-Charging contingent	not active
IDE03009-MAS06004	Start process requested-Special start requirements	not active
IDE03010-IDE01838	Number of prevented stop processes-Battery temperature	0
IDE03010-IDE01844	Number of prevented stop processes-Increase idle speed request	0
IDE03010-MAS02193	Number of prevented stop processes-Outside air temperature	0
IDE03010-MAS04054	Number of prevented stop processes-Consumer current too high	0
IDE03010-MAS04055	Number of prevented stop processes-Usable battery charge too low	0
IDE03010-MAS04056	Number of prevented stop processes-Battery charge condition too low	0
IDE03010-MAS04062	Number of prevented stop processes-Possible service life too short	0
IDE03010-MAS05998	Number of prevented stop processes-Frequency counter DC/DC converter Veto	0
IDE03010-MAS06350	Number of prevented stop processes-Frequency counter: energy management special veto	0
IDE03011-MAS01478	Number of requested start processes-Insuff. voltage	0
IDE03011-MAS02885	Number of requested start processes-Restart because of outside temperature	0
IDE03011-MAS04054	Number of requested start processes-Consumer current too high	0
IDE03011-MAS04055	Number of requested start processes-Usable battery charge too low	0
IDE03011-MAS04056	Number of requested start processes-Battery charge condition too low	0
IDE03011-MAS04058	Number of requested start processes-Service life expired	0
IDE03011-MAS05999	Number of requested start processes-Frequency counter charging contingent	0
IDE03011-MAS06000	Number of requested start processes-Frequency counter special start requirements	0
IDE03127-MAS00106	Prevented stop processes (ring memory)-Year	2127
IDE03127-MAS00107	Prevented stop processes (ring memory)-Month	15
IDE03127-MAS00108	Prevented stop processes (ring memory)-Day	31
IDE03127-MAS00109	Prevented stop processes (ring memory)-Hours	31
IDE03127-MAS00110	Prevented stop processes (ring memory)-Minutes	63
IDE03127-MAS00111	Prevented stop processes (ring memory)-Seconds	63
IDE03127-ENG118156	Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n	no measured value present
IDE03127-ENG118158	Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1	no measured value present
IDE03127-ENG118160	Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2	no measured value present
IDE03127-ENG118162	Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3	no measured value present
IDE03127-ENG118164	Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4	no measured value present
IDE03128-MAS00106	Requested start processes (ring memory)-Year	2127
IDE03128-MAS00107	Requested start processes (ring memory)-Month	15
IDE03128-MAS00108	Requested start processes (ring memory)-Day	31
IDE03128-MAS00109	Requested start processes (ring memory)-Hours	31
IDE03128-MAS00110	Requested start processes (ring memory)-Minutes	63
IDE03128-MAS00111	Requested start processes (ring memory)-Seconds	63
IDE03128-ENG118166	Requested start processes (ring memory)-Restart_n	no measured value present
IDE03128-ENG118168	Requested start processes (ring memory)-Restart_n-1	no measured value present
IDE03128-ENG118170	Requested start processes (ring memory)-Restart_n-2	no measured value present
IDE03128-ENG118172	Requested start processes (ring memory)-Restart_n-3	no measured value present
IDE03128-ENG118174	Requested start processes (ring memory)-Restart_n-4	no measured value present
IDE03212	Start-stop conditions	Stop release
IDE03213	Start-stop enabling	System malfunction
IDE03214	Engine stop using start-stop function	not active
IDE03215	Engine start using start-stop function	not active
IDE03256-MAS06105	Battery adaptation-Rated battery capacity	60	 Ah
IDE03256-MAS06106	Battery adaptation-Battery technology	Wet
IDE03256-MAS06107	Battery adaptation-Battery manufacturer	JCB
IDE03256-MAS06108	Battery adaptation-Battery Serial Number	1111111111
IDE03588-MAS05683	System malfunctions for active participants start/stop-Battery malfunction	0
IDE03588-MAS06321	System malfunctions for active participants start/stop-System malfunction generator	0
IDE03588-MAS06322	System malfunctions for active participants start/stop-System malfunction due to battery throughput	0
IDE03588-MAS06323	System malfunctions for active participants start/stop-Start/stop coordinator implausible	0
IDE03588-MAS06324	System malfunctions for active participants start/stop-DCDC converter system malfunction	0
IDE03588-MAS06326	System malfunctions for active participants start/stop-Communication malfunction battery data module	0
IDE03588-MAS06327	System malfunctions for active participants start/stop-Battery data module defective	0
IDE04186	Battery terminal recognition	connected
IDE04329-IDE04332	Status of all SWaP functions-Release code for a SWaP function	Not available
IDE04329-IDE05814	Status of all SWaP functions-Individualization characteristic	invalid
IDE04329-IDE06260	Status of all SWaP functions-ID number	10 00 03 00
IDE04329-MAS01340	Status of all SWaP functions-Functions	present
IDE04329-MAS01903	Status of all SWaP functions-Configuration	OK
IDE04329-MAS02934	Status of all SWaP functions-Prerequisites met	Condition not met
IDE04329-MAS05616	Status of all SWaP functions-Cancellation	Yes
IDE04329-MAS05617	Status of all SWaP functions-Authentication	invalid
IDE04332	Release code for a SWaP function	2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
IDE04334	Public key for SWaP function	99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
IDE04806-ENG06028	Driving profile selection button-Driving_Profile_Selection_Button_1	not activated
IDE04806-ENG06029	Driving profile selection button-Driving_Profile_Selection_Button_2	not activated
IDE04806-ENG06030	Driving profile selection button-Driving_Profile_Selection_Button_3	not activated
IDE04806-ENG06031	Driving profile selection button-Driving_Profile_Selection_Button_4	not activated
IDE04806-ENG06032	Driving profile selection button-Driving_Profile_Selection_Button_5	not activated
IDE04806-ENG06033	Driving profile selection button-Driving_Profile_Selection_Button_6	not activated
IDE04806-ENG06034	Driving profile selection button-Driving_Profile_Selection_Button_7	not activated
IDE04806-ENG06035	Driving profile selection button-Driving_Profile_Selection_Button_8	not activated
IDE05583-IDE02766	Pause recommendation-Malfunction status	not installed
IDE05583-MAS03095	Pause recommendation-Function status	not installed
IDE05583-MAS04622	Pause recommendation-Break recommend. message	No message
IDE05583-MAS13162	Pause recommendation-Icon deactivated	No
IDE05740-MAS05376	Driving profile selection: system status-Coordinator status	active
IDE05740-ENG05007	Driving profile selection: system status-profile_state_1	engaged
IDE05740-ENG05008	Driving profile selection: system status-profile_state_2	not engaged
IDE05740-ENG05009	Driving profile selection: system status-profile_state_3	not engaged
IDE05740-ENG05010	Driving profile selection: system status-profile_state_4	not engaged
IDE05740-ENG05011	Driving profile selection: system status-profile_state_5	not engaged
IDE05740-ENG05012	Driving profile selection: system status-profile_state_6	not engaged
IDE05740-ENG05013	Driving profile selection: system status-profile_state_7	not engaged
IDE05740-ENG05014	Driving profile selection: system status-profile_state_8	not engaged
IDE05814	Individualization characteristic	82 09 E1 0C E5
IDE06007-IDE00105	Driving profile history data 1-Malfunction type	Refused switch-over
IDE06007-IDE04805	Driving profile history data 1-Driving profile selection	0
IDE06007-IDE07643	Driving profile history data 1-Faulty function	Ambient light
IDE06007-MAS00106	Driving profile history data 1-Year	2018
IDE06007-MAS00107	Driving profile history data 1-Month	8
IDE06007-MAS00108	Driving profile history data 1-Day	26
IDE06007-MAS00109	Driving profile history data 1-Hours	9
IDE06007-MAS00110	Driving profile history data 1-Minutes	21
IDE06007-MAS00111	Driving profile history data 1-Seconds	34
IDE06007-MAS00711	Driving profile history data 1-Odometer reading	136	 km
IDE06007-MAS03095	Driving profile history data 1-Function status	Not available
IDE06008-IDE00105	Driving profile history data 2-Malfunction type	Refused switch-over
IDE06008-IDE04805	Driving profile history data 2-Driving profile selection	0
IDE06008-IDE07643	Driving profile history data 2-Faulty function	Start-stop
IDE06008-MAS00106	Driving profile history data 2-Year	2018
IDE06008-MAS00107	Driving profile history data 2-Month	8
IDE06008-MAS00108	Driving profile history data 2-Day	26
IDE06008-MAS00109	Driving profile history data 2-Hours	9
IDE06008-MAS00110	Driving profile history data 2-Minutes	21
IDE06008-MAS00111	Driving profile history data 2-Seconds	34
IDE06008-MAS00711	Driving profile history data 2-Odometer reading	136	 km
IDE06008-MAS03095	Driving profile history data 2-Function status	Initializing
IDE06009-IDE00105	Driving profile history data 3-Malfunction type	Refused switch-over
IDE06009-IDE04805	Driving profile history data 3-Driving profile selection	0
IDE06009-IDE07643	Driving profile history data 3-Faulty function	Reversible seat belt tensioner
IDE06009-MAS00106	Driving profile history data 3-Year	2018
IDE06009-MAS00107	Driving profile history data 3-Month	8
IDE06009-MAS00108	Driving profile history data 3-Day	26
IDE06009-MAS00109	Driving profile history data 3-Hours	9
IDE06009-MAS00110	Driving profile history data 3-Minutes	21
IDE06009-MAS00111	Driving profile history data 3-Seconds	34
IDE06009-MAS00711	Driving profile history data 3-Odometer reading	136	 km
IDE06009-MAS03095	Driving profile history data 3-Function status	Not available
IDE06010-IDE00105	Driving profile history data 4-Malfunction type	Refused switch-over
IDE06010-IDE04805	Driving profile history data 4-Driving profile selection	0
IDE06010-IDE07643	Driving profile history data 4-Faulty function	A/C behavior
IDE06010-MAS00106	Driving profile history data 4-Year	2011
IDE06010-MAS00107	Driving profile history data 4-Month	1
IDE06010-MAS00108	Driving profile history data 4-Day	7
IDE06010-MAS00109	Driving profile history data 4-Hours	22
IDE06010-MAS00110	Driving profile history data 4-Minutes	58
IDE06010-MAS00111	Driving profile history data 4-Seconds	57
IDE06010-MAS00711	Driving profile history data 4-Odometer reading	9	 km
IDE06010-MAS03095	Driving profile history data 4-Function status	Available
IDE06011-ENG04999	Selected driving profile-driving_profile_1	AUTO
IDE06011-ENG05000	Selected driving profile-driving_profile_2	no function
IDE06011-ENG05001	Selected driving profile-driving_profile_3	no function
IDE06011-ENG05002	Selected driving profile-driving_profile_4	no function
IDE06011-ENG05003	Selected driving profile-driving_profile_5	no function
IDE06011-ENG05004	Selected driving profile-driving_profile_6	no function
IDE06011-ENG05005	Selected driving profile-driving_profile_7	no function
IDE06011-ENG05006	Selected driving profile-driving_profile_8	no function
IDE06165-MAS06193	Driving profile selection statistics-Profile 1	0
IDE06165-MAS06194	Driving profile selection statistics-Profile 2	108
IDE06165-MAS06195	Driving profile selection statistics-Profile 3	375
IDE06165-MAS06196	Driving profile selection statistics-Profile 4	0
IDE06165-MAS06197	Driving profile selection statistics-Profile 5	0
IDE06165-MAS06198	Driving profile selection statistics-Profile 6	0
IDE06165-MAS06199	Driving profile selection statistics-Profile 7	0
IDE06165-MAS06200	Driving profile selection statistics-Profile 8	0
IDE06165-MAS08875	Driving profile selection statistics-Profile 9	0
IDE06165-MAS08876	Driving profile selection statistics-Profile 10	0
IDE06165-MAS08877	Driving profile selection statistics-Profile 11	0
IDE06165-MAS08878	Driving profile selection statistics-Profile 12	0
IDE06230-MAS00106	Break recommend.: last message-Year	2000
IDE06230-MAS00107	Break recommend.: last message-Month	0
IDE06230-MAS00108	Break recommend.: last message-Day	0
IDE06230-MAS00109	Break recommend.: last message-Hours	0
IDE06230-MAS00110	Break recommend.: last message-Minutes	0
IDE06230-MAS00111	Break recommend.: last message-Seconds	0
IDE06230-MAS03095	Break recommend.: last message-Function status	Initializing
IDE06230-MAS04622	Break recommend.: last message-Break recommend. message	No message
IDE06592-MAS05002	Status: special functions-Showroom mode	OFF
IDE06592-MAS05003	Status: special functions-Debug functions	OFF
IDE07145-MAS06772	Component protection properties-Component protection generation	2
IDE07145-MAS06773	Component protection properties-KS Standard software main version nummer	2
IDE07145-MAS06774	Component protection properties-KS Standard software secondary version number	2
IDE07145-MAS06775	Component protection properties-KS Standard software correct number	0
IDE07145-MAS06776	Component protection properties-Komponent protection role	KS Master
IDE07145-MAS06781	Component protection properties-Secure Hardware Extension	used
IDE07145-MAS06782	Component protection properties-Master ECU Key	administered by component protection
IDE07145-MAS06785	Component protection properties-GFA key	used
IDE07145-MAS06786	Component protection properties-SSW RND Generation	Not Used
IDE07145-MAS06787	Component protection properties-Indiv Key Generation	used
IDE07145-MAS06788	Component protection properties-SHE Secure Boot	Not Used
IDE07145-MAS06789	Component protection properties-KSB Config Status 2	40
IDE07145-MAS07187	Component protection properties-KS Data version	1
IDE07184-MAS06023	MFL button for freely assignable function-Parameter actuation of Joker FPA button	not activated
IDE07184-MAS06024	MFL button for freely assignable function-Parameter programming of Joker FPA button	not active
IDE07424-IDE04447	Status: driving profile selection for engine-Function status	engaged
IDE07424-IDE06260	Status: driving profile selection for engine-ID number	1
IDE07424-MAS01156	Status: driving profile selection for engine-Communication status	OK
IDE07424-MAS01447	Status: driving profile selection for engine-Act.val.	2
IDE07425-IDE04447	Status: driving profile selection for start-stop function-Function status	Not available
IDE07425-IDE06260	Status: driving profile selection for start-stop function-ID number	2
IDE07425-MAS01156	Status: driving profile selection for start-stop function-Communication status	OK
IDE07425-MAS01447	Status: driving profile selection for start-stop function-Act.val.	0
IDE07426-IDE04447	Status: driving profile selection for transmission-Function status	engaged
IDE07426-IDE06260	Status: driving profile selection for transmission-ID number	3
IDE07426-MAS01156	Status: driving profile selection for transmission-Communication status	OK
IDE07426-MAS01447	Status: driving profile selection for transmission-Act.val.	2
IDE07427-IDE04447	Status: driving profile selection for power steering-Function status	engaged
IDE07427-IDE06260	Status: driving profile selection for power steering-ID number	5
IDE07427-MAS01156	Status: driving profile selection for power steering-Communication status	OK
IDE07427-MAS01447	Status: driving profile selection for power steering-Act.val.	2
IDE07428-IDE04447	Status: driving profile selection for damping adjustment-Function status	Not available
IDE07428-IDE06260	Status: driving profile selection for damping adjustment-ID number	7
IDE07428-MAS01156	Status: driving profile selection for damping adjustment-Communication status	Timeout
IDE07428-MAS01447	Status: driving profile selection for damping adjustment-Act.val.	0
IDE07429-IDE04447	Status: driving profile selection for A/C-Function status	Not available
IDE07429-IDE06260	Status: driving profile selection for A/C-ID number	8
IDE07429-MAS01156	Status: driving profile selection for A/C-Communication status	OK
IDE07429-MAS01447	Status: driving profile selection for A/C-Act.val.	0
IDE07430-IDE04447	Status: driving profile selection for adaptive cruise control-Function status	Not available
IDE07430-IDE06260	Status: driving profile selection for adaptive cruise control-ID number	9
IDE07430-MAS01156	Status: driving profile selection for adaptive cruise control-Communication status	Timeout
IDE07430-MAS01447	Status: driving profile selection for adaptive cruise control-Act.val.	0
IDE07431-IDE04447	Status: driv prof.select.for corn.light & headlamp range ctrl-Function status	Not available
IDE07431-IDE06260	Status: driv prof.select.for corn.light & headlamp range ctrl-ID number	11
IDE07431-MAS01156	Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status	Timeout
IDE07431-MAS01447	Status: driv prof.select.for corn.light & headlamp range ctrl-Act.val.	0
IDE07432-IDE04447	Status: driving profile selection for structure-borne noise-Function status	Not available
IDE07432-IDE06260	Status: driving profile selection for structure-borne noise-ID number	10
IDE07432-MAS01156	Status: driving profile selection for structure-borne noise-Communication status	Timeout
IDE07432-MAS01447	Status: driving profile selection for structure-borne noise-Act.val.	0
IDE07433-IDE04447	Status: driving profile selection for ambient lighting-Function status	Not available
IDE07433-IDE06260	Status: driving profile selection for ambient lighting-ID number	12
IDE07433-MAS01156	Status: driving profile selection for ambient lighting-Communication status	OK
IDE07433-MAS01447	Status: driving profile selection for ambient lighting-Act.val.	0
IDE07434-IDE04447	Status: driving profile selection for belt tensioner-Function status	Not available
IDE07434-IDE06260	Status: driving profile selection for belt tensioner-ID number	14
IDE07434-MAS01156	Status: driving profile selection for belt tensioner-Communication status	OK
IDE07434-MAS01447	Status: driving profile selection for belt tensioner-Act.val.	0
IDE07436-IDE04447	Status: driving profile selection for free-running hub-Function status	Not available
IDE07436-IDE06260	Status: driving profile selection for free-running hub-ID number	18
IDE07436-MAS01156	Status: driving profile selection for free-running hub-Communication status	OK
IDE07436-MAS01447	Status: driving profile selection for free-running hub-Act.val.	0
IDE07473-MAS06303	Generator limitation-Status overvoltage limitation	not active
IDE07473-MAS06304	Generator limitation-Status overvoltage diagnosis	not active
IDE07473-MAS06305	Generator limitation-Status of diagnosis for energy balance	not active
IDE07473-MAS06306	Generator limitation-Status generator release by engine	no request
IDE07473-MAS06307	Generator limitation-Status of battery charging function	not active
IDE07473-MAS06308	Generator limitation-Power steering support active	not active
IDE07473-MAS06309	Generator limitation-Coolant fan activation request by BEM	not active
IDE07474-MAS06313	Adapting for energy management-Adaptation static current management	not active
IDE07474-MAS06314	Adapting for energy management-Battery coding active	not active
IDE07616	Battery degradation for start/stop - operation	ERROR
IDE07619-IDE07621	Start/stop starting voltage prediction-Permitted engine stoppage time	Initializing
IDE07619-IDE07622	Start/stop starting voltage prediction-Power consumption during idle phase	155	 A
IDE07623-MAS06328	Open-circuit voltage gateway-Battery voltage last wakeup	12.4	 V
IDE07623-MAS06329	Open-circuit voltage gateway-Batter voltage penultimate wakeup	12.6	 V
IDE07623-MAS06330	Open-circuit voltage gateway-Open-circuit voltage valid	valid
IDE07628-IDE07629	Status power receptacle-Function release power receptacle	blocked
IDE07628-IDE07630	Status power receptacle-Pre-warning power receptacle	not active
IDE07628-MAS01581	Status power receptacle-Power consumption	0	 W
IDE07628-MAS06331	Status power receptacle-Enabling self-contained operation	blocked
IDE07628-MAS06332	Status power receptacle-Status function readiness	blocked
IDE07628-MAS06333	Status power receptacle-Status function	OFF
IDE07628-MAS06334	Status power receptacle-Status overtemperature	in permissible range
IDE07637	Current charge contingent for feedback	0	 As
IDE07638-MAS06339	Status condition determin. ready for idle-Sleep readiness BEM	active
IDE07638-MAS06340	Status condition determin. ready for idle-Busstat readiness BEM	Run busstat
IDE07638-MAS06341	Status condition determin. ready for idle-After-run for power receptacle	not active
IDE07640-MAS06344	Analysis of start voltage behavior-Minimum voltage at last engine start	Initializing
IDE07640-MAS06345	Analysis of start voltage behavior-Minimum voltage at last engine start recognized	not recognized
IDE07640-MAS06346	Analysis of start voltage behavior-Voltage drop through engine start recognized	not recognized
IDE07640-MAS06347	Analysis of start voltage behavior-Current voltage drop last start	Initializing
IDE07640-MAS06348	Analysis of start voltage behavior-Normed voltage drop	Initializing
IDE07640-MAS11064	Analysis of start voltage behavior-Current last engine start	1	 A
IDE07640-MAS11065	Analysis of start voltage behavior-Current delta last engine start	1	 A
IDE07681-MAS06086	Battery total charging throughput-Total re-charge	0	 Ah
IDE07681-MAS06087	Battery total charging throughput-Total energy throughput	0	 Ah
IDE07873-MAS06193	FPA enabled profiles-Profile 1	Not Used
IDE07873-MAS06194	FPA enabled profiles-Profile 2	AUTO
IDE07873-MAS06195	FPA enabled profiles-Profile 3	Dynamic
IDE07873-MAS06196	FPA enabled profiles-Profile 4	Offroad
IDE07873-MAS06197	FPA enabled profiles-Profile 5	ECONOMY
IDE07873-MAS06198	FPA enabled profiles-Profile 6	Not Used
IDE07873-MAS06199	FPA enabled profiles-Profile 7	INDIVIDUAL
IDE07873-MAS06200	FPA enabled profiles-Profile 8	Not Used
IDE07873-MAS08875	FPA enabled profiles-Profile 9	Not Used
IDE07873-MAS08876	FPA enabled profiles-Profile 10	Not Used
IDE07873-MAS08877	FPA enabled profiles-Profile 11	Not Used
IDE07873-MAS08878	FPA enabled profiles-Profile 12	Not Used
IDE07907	Bus communication	active
IDE08343	Immobilizer Challenge	05 38 58 F2
IDE08346-MAS06117	Generator Analysis-Rated voltage	10.6	 V
IDE08346-MAS06864	Generator Analysis-Generator actual voltage	14.5	 V
IDE08346-MAS06865	Generator Analysis-Voltage difference generator battery	0.1	 V
IDE08346-MAS06866	Generator Analysis-Generator speed	564	 /min
IDE08346-MAS06867	Generator Analysis-Generator chip temperature	52	 °C
IDE08347	adapted battery capacity	254	 Ah
IDE08354-IDE04447	Status: driv.profile select. for front axle differential lock-Function status	Not available
IDE08354-IDE06260	Status: driv.profile select. for front axle differential lock-ID number	21
IDE08354-MAS01156	Status: driv.profile select. for front axle differential lock-Communication status	Timeout
IDE08354-MAS01447	Status: driv.profile select. for front axle differential lock-Act.val.	0
IDE08355-IDE04447	Status: driving profile selection for external noise actuator-Function status	Not available
IDE08355-IDE06260	Status: driving profile selection for external noise actuator-ID number	20
IDE08355-MAS01156	Status: driving profile selection for external noise actuator-Communication status	Timeout
IDE08355-MAS01447	Status: driving profile selection for external noise actuator-Act.val.	0
IDE08680-MAS03173	Allocation data bus identifier-Databus drivetrain	11
IDE08680-MAS03174	Allocation data bus identifier-Comfort data bus	12
IDE08680-MAS03175	Allocation data bus identifier-Databus extended	15
IDE08680-MAS03177	Allocation data bus identifier-Databus Infotainment	13
IDE08680-MAS03178	Allocation data bus identifier-Suspension data bus	14
IDE08680-MAS03179	Allocation data bus identifier-Local data bus 2	52
IDE08680-MAS03180	Allocation data bus identifier-Local data bus	51
IDE08680-MAS05686	Allocation data bus identifier-Data bus diagnostics	10
IDE08680-MAS05972	Allocation data bus identifier-Local data bus 3	53
IDE08681-MAS03173	Data bus defect error-Databus drivetrain	OK
IDE08681-MAS03174	Data bus defect error-Comfort data bus	OK
IDE08681-MAS03175	Data bus defect error-Databus extended	not installed
IDE08681-MAS03177	Data bus defect error-Databus Infotainment	OK
IDE08681-MAS03178	Data bus defect error-Suspension data bus	OK
IDE08681-MAS03179	Data bus defect error-Local data bus 2	OK
IDE08681-MAS03180	Data bus defect error-Local data bus	OK
IDE08681-MAS05686	Data bus defect error-Data bus diagnostics	OK
IDE08681-MAS05972	Data bus defect error-Local data bus 3	not installed
IDE08682-MAS03173	Data bus single wire err.-Databus drivetrain	OK
IDE08682-MAS03174	Data bus single wire err.-Comfort data bus	OK
IDE08682-MAS03175	Data bus single wire err.-Databus extended	not installed
IDE08682-MAS03177	Data bus single wire err.-Databus Infotainment	OK
IDE08682-MAS03178	Data bus single wire err.-Suspension data bus	OK
IDE08682-MAS03179	Data bus single wire err.-Local data bus 2	Not coded
IDE08682-MAS03180	Data bus single wire err.-Local data bus	Not coded
IDE08682-MAS05686	Data bus single wire err.-Data bus diagnostics	Not coded
IDE08682-MAS05972	Data bus single wire err.-Local data bus 3	not installed
IDE08683-MAS03173	Data bus TimeOut error-Databus drivetrain	OK
IDE08683-MAS03174	Data bus TimeOut error-Comfort data bus	OK
IDE08683-MAS03175	Data bus TimeOut error-Databus extended	not installed
IDE08683-MAS03177	Data bus TimeOut error-Databus Infotainment	OK
IDE08683-MAS03178	Data bus TimeOut error-Suspension data bus	OK
IDE08683-MAS03179	Data bus TimeOut error-Local data bus 2	Not coded
IDE08683-MAS03180	Data bus TimeOut error-Local data bus	Not coded
IDE08683-MAS05686	Data bus TimeOut error-Data bus diagnostics	Not coded
IDE08683-MAS05972	Data bus TimeOut error-Local data bus 3	not installed
IDE08684-SFT09757	Allocation LIN system number-Alternator	00 1D
IDE08684-SFT09777	Allocation LIN system number-Multi Function Steering Wheel Control Module	00 31
IDE08684-SFT09783	Allocation LIN system number-Battery Monitoring Control Module	00 37
IDE08684-SFT09833	Allocation LIN system number-Power Converter DC AC	00 69
IDE08684-SFT09842	Allocation LIN system number-Analog clock	00 72
IDE08684-SFT10031	Allocation LIN system number-Operating Unit Drive Mode Selection	01 2F
IDE08684-SFT10046	Allocation LIN system number-Control module for steering wheel touch recognition	00 00
IDE08685-SFT09757	Status LIN user-Alternator	active
IDE08685-SFT09777	Status LIN user-Multi Function Steering Wheel Control Module	active
IDE08685-SFT09783	Status LIN user-Battery Monitoring Control Module	not active
IDE08685-SFT09833	Status LIN user-Power Converter DC AC	not active
IDE08685-SFT09842	Status LIN user-Analog clock	not active
IDE08685-SFT10031	Status LIN user-Operating Unit Drive Mode Selection	not active
IDE08685-SFT10046	Status LIN user-Control module for steering wheel touch recognition	not active
IDE08687-IDE04447	Status: driving profile select. for brake ctrl. sys.-Function status	engaged
IDE08687-IDE06260	Status: driving profile select. for brake ctrl. sys.-ID number	28
IDE08687-MAS01156	Status: driving profile select. for brake ctrl. sys.-Communication status	OK
IDE08687-MAS01447	Status: driving profile select. for brake ctrl. sys.-Act.val.	2
IDE08794-MAS06106	Battery cell analysis-Battery technology	Unknown
IDE08794-MAS07703	Battery cell analysis-Cell voltage	0	 V
IDE08794-MAS07704	Battery cell analysis-Cell temp.	-40	 °C
IDE08794-MAS07705	Battery cell analysis-Cell limit voltage (binary coded)	0
IDE08794-MAS07706	Battery cell analysis-Can be analyzed	Initializing
IDE08794-MAS07707	Battery cell analysis-Health condition acc. to calendar	126	 %
IDE08794-MAS07708	Battery cell analysis-Cut-off element	closed
IDE08796-IDE04447	Status: driving profile selec. for hill descent control-Function status	engaged
IDE08796-IDE06260	Status: driving profile selec. for hill descent control-ID number	44
IDE08796-MAS01156	Status: driving profile selec. for hill descent control-Communication status	OK
IDE08796-MAS01447	Status: driving profile selec. for hill descent control-Act.val.	2
IDE08797-IDE04447	Status: drive profile for area view-Function status	engaged
IDE08797-IDE06260	Status: drive profile for area view-ID number	0
IDE08797-MAS01156	Status: drive profile for area view-Communication status	Timeout
IDE08797-MAS01447	Status: drive profile for area view-Act.val.	0
IDE08799-IDE04447	Status: driv. profile selec. for rear spoiler-Function status	engaged
IDE08799-IDE06260	Status: driv. profile selec. for rear spoiler-ID number	0
IDE08799-MAS01156	Status: driv. profile selec. for rear spoiler-Communication status	OK
IDE08799-MAS01447	Status: driv. profile selec. for rear spoiler-Act.val.	0
IDE08804-IDE04447	Status: driv. profile selec. for ctr. differential-Function status	engaged
IDE08804-IDE06260	Status: driv. profile selec. for ctr. differential-ID number	0
IDE08804-MAS01156	Status: driv. profile selec. for ctr. differential-Communication status	OK
IDE08804-MAS01447	Status: driv. profile selec. for ctr. differential-Act.val.	2
IDE09561	Closed-circuit current of last LIN sleep phase	0	 A
IDE09562	Range extension counter: stage 2	0
IDE10674-MAS11055	Extended battery diagnosis-Pulse interior resistance	2.2	 mOhm
IDE10674-MAS11056	Extended battery diagnosis-Counter battery warning	0
IDE10674-MAS11059	Extended battery diagnosis-Power state LV battery singular operation	OK
IDE10674-MAS11060	Extended battery diagnosis-Status Handshake HVK	OK
IDE10737-IDE04447	Status: driving profile selection for range calculation-Function status	engaged
IDE10737-IDE06260	Status: driving profile selection for range calculation-ID number	0
IDE10737-MAS01156	Status: driving profile selection for range calculation-Communication status	OK
IDE10737-MAS01447	Status: driving profile selection for range calculation-Act.val.	0
IDE10738-IDE04447	Status driving profile selection for electronic brake booster-Function status	engaged
IDE10738-IDE06260	Status driving profile selection for electronic brake booster-ID number	0
IDE10738-MAS01156	Status driving profile selection for electronic brake booster-Communication status	Timeout
IDE10738-MAS01447	Status driving profile selection for electronic brake booster-Act.val.	0
IDE10739-IDE04447	Status: driving profile selection for oper. mode selection-Function status	engaged
IDE10739-IDE06260	Status: driving profile selection for oper. mode selection-ID number	0
IDE10739-MAS01156	Status: driving profile selection for oper. mode selection-Communication status	OK
IDE10739-MAS01447	Status: driving profile selection for oper. mode selection-Act.val.	0
IDE11573	Energy management in heating power allocation	1000	 W
IDE11673-MAS02246	Battery Management 2: prohibition on turning-on 48V-Timeout	not active
IDE11673-MAS03123	Battery Management 2: prohibition on turning-on 48V-Reduced performance	not active
IDE11673-MAS09519	Battery Management 2: prohibition on turning-on 48V-Message error	not active
IDE11673-MAS09541	Battery Management 2: prohibition on turning-on 48V-Act. mode init. error	not active
IDE11673-MAS09542	Battery Management 2: prohibition on turning-on 48V-Error status init. error	not active
IDE11673-MAS09543	Battery Management 2: prohibition on turning-on 48V-Operating mode error	not active
IDE11673-MAS09544	Battery Management 2: prohibition on turning-on 48V-No component function	not active
IDE11673-MAS09545	Battery Management 2: prohibition on turning-on 48V-Sequence error	not active
IDE11674-MAS02246	Voltage transformer: prohibition on turning-on 48V-Timeout	not active
IDE11674-MAS09519	Voltage transformer: prohibition on turning-on 48V-Message error	not active
IDE11674-MAS09541	Voltage transformer: prohibition on turning-on 48V-Act. mode init. error	not active
IDE11674-MAS09542	Voltage transformer: prohibition on turning-on 48V-Error status init. error	not active
IDE11674-MAS09543	Voltage transformer: prohibition on turning-on 48V-Operating mode error	not active
IDE11674-MAS09544	Voltage transformer: prohibition on turning-on 48V-No component function	not active
IDE11674-MAS09545	Voltage transformer: prohibition on turning-on 48V-Sequence error	not active
IDE11676-MAS00799	Airbag: prohibition on turning-on 48V-Airbag control module	not active
IDE11676-MAS02246	Airbag: prohibition on turning-on 48V-Timeout	not active
IDE11676-MAS09519	Airbag: prohibition on turning-on 48V-Message error	not active
IDE11676-MAS09521	Airbag: prohibition on turning-on 48V-Light accident detected	not active
IDE11676-MAS09522	Airbag: prohibition on turning-on 48V-Severe accident detected	not active
IDE11678-MAS02246	Engine electronics: prohibition on turning-on 48V-Timeout	not active
IDE11678-MAS09519	Engine electronics: prohibition on turning-on 48V-Message error	not active
IDE11678-MAS09541	Engine electronics: prohibition on turning-on 48V-Act. mode init. error	not active
IDE11678-MAS09545	Engine electronics: prohibition on turning-on 48V-Sequence error	not active
IDE11678-MAS09547	Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error	not active
IDE11678-MAS09548	Engine electronics: prohibition on turning-on 48V-Error status drive: init. error	not active
IDE11678-MAS09549	Engine electronics: prohibition on turning-on 48V-Drive condition: init. error	not active
IDE11678-MAS09554	Engine electronics: prohibition on turning-on 48V-no component function drive	not active
IDE11678-MAS13413	Engine electronics: prohibition on turning-on 48V-No component function of starter generator	not active
IDE11678-MAS13415	Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy	not active
IDE11679-MAS02246	Electrical compressor: prohibition on turning-on 48V-Timeout	not active
IDE11679-MAS09519	Electrical compressor: prohibition on turning-on 48V-Message error	not active
IDE11679-MAS09541	Electrical compressor: prohibition on turning-on 48V-Act. mode init. error	not active
IDE11679-MAS09542	Electrical compressor: prohibition on turning-on 48V-Error status init. error	not active
IDE11679-MAS09544	Electrical compressor: prohibition on turning-on 48V-No component function	not active
IDE11679-MAS09545	Electrical compressor: prohibition on turning-on 48V-Sequence error	not active
IDE11679-MAS13455	Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error	not active
IDE11681-MAS03182	Monitoring line disconnection: prohibition on turning-on 48V-Branch 1	not active
IDE11681-MAS03183	Monitoring line disconnection: prohibition on turning-on 48V-Branch 2	not active
IDE11683-MAS13705	Engine electronics: status of 48V network-Error status of starter generator	Initializing
IDE11683-MAS13708	Engine electronics: status of 48V network-Error status of electrical compressor	No error recognized
IDE11683-MAS13715	Engine electronics: status of 48V network-Electro compressor mode	Standby-mode
IDE11683-MAS13716	Engine electronics: status of 48V network-Error status of drive	Initializing
IDE11683-MAS13717	Engine electronics: status of 48V network-State of drive	Initializing
IDE11683-MAS13718	Engine electronics: status of 48V network-Handshake	255
IDE11684-MAS02832	Battery management 2: status for 48V power-Malfunction status	Initializing
IDE11684-MAS03001	Battery management 2: status for 48V power-Mode	Initializing
IDE11685-MAS02832	Voltage converter: status for 48V power-Malfunction status	Initializing
IDE11685-MAS03001	Voltage converter: status for 48V power-Mode	Initializing
IDE11911-MAS00799	48V activation restriction-Airbag control module	not active
IDE11911-MAS09516	48V activation restriction-Engine Electronics	not active
IDE11911-MAS10933	48V activation restriction-Roll stabilization	not active
IDE11911-MAS13411	48V activation restriction-48 V activation restriction due to open circuit	not active
IDE11911-MAS13412	48V activation restriction-48 V activation restriction due to deactivation	not active
IDE11911-SFT00033	48V activation restriction-Battery Energy Control Module 2	not active
IDE11911-SFT00196	48V activation restriction-DC/DC Converter Control Module	not active
IDE11911-SFT09769	48V activation restriction-Control module for auxiliary air heater	not active
IDE11911-SFT09997	48V activation restriction-Electrical Charger	not active
IDE12084	Status of component protection slaves	00 14 19 00 00 00 0E 11 00 00 00 57 20 00 00 00 15 11 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00
IDE12133-MAS01896	Freewheel - energy-Free run	155	 A
IDE12133-MAS14352	Freewheel - energy-Auxiliary store current	0	 A
IDE12133-MAS14353	Freewheel - energy-Loading release for additional memory	No enabling
IDE12133-MAS14357	Freewheel - energy-Generator start mode	First start
IDE12133-MAS14362	Freewheel - energy-Voltage limit boost mode	12.2	 V
IDE12134-MAS14344	Freewheel - condition-Status of coasting release	Release
IDE12134-MAS14348	Freewheel - condition-Status of freewheel engine off release	Freewheel engine off block
IDE12134-MAS14349	Freewheel - condition-Freewheel engine off block	0
IDE12134-MAS14350	Freewheel - condition-Store request	no request
IDE12134-MAS14351	Freewheel - condition-Freewheel engine off restart	0
IDE12135-MAS14363	Belt driven starter generator 12V-Specified voltage: lower limit	16.9	 V
IDE12135-MAS14364	Belt driven starter generator 12V-Specified voltage limit	16.9	 V
IDE12135-MAS14365	Belt driven starter generator 12V-Recommended specified voltage	10.6	 V
IDE12135-MAS14366	Belt driven starter generator 12V-Maximum ramp time	6	 s
IDE12135-MAS14367	Belt driven starter generator 12V-Minimum voltage for start	7.6	 V
IDE12135-MAS14368	Belt driven starter generator 12V-Specified voltage of the belt driven starter generator	15	 V
IDE12135-MAS14369	Belt driven starter generator 12V-Actual mode belt driven starter generator	Neutral
MAS00464-MAS00106	Standard - ambient data 1-Year	2018
MAS00464-MAS00107	Standard - ambient data 1-Month	8
MAS00464-MAS00108	Standard - ambient data 1-Day	26
MAS00464-MAS00109	Standard - ambient data 1-Hours	11
MAS00464-MAS00110	Standard - ambient data 1-Minutes	12
MAS00464-MAS00111	Standard - ambient data 1-Seconds	40
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
MAS00769-IDE02717	Multifunction steering wheel control module-Tiptronic upshift	not activated
MAS00769-IDE02718	Multifunction steering wheel control module-Tiptronic downshift	not activated
MAS00769-IDE07668	Multifunction steering wheel control module-MFL Variant code	4
MAS00769-MAS01065	Multifunction steering wheel control module-Brand	VW
MAS00769-MAS01288	Multifunction steering wheel control module-Signal horn	not activated
MAS00769-MAS02317	Multifunction steering wheel control module-Button code 1	Not operated
MAS00769-MAS02318	Multifunction steering wheel control module-Button code 2	Not operated
MAS00769-MAS02319	Multifunction steering wheel control module-Event code 1	No result
MAS00769-MAS02320	Multifunction steering wheel control module-Event code 2	No result
MAS00769-MAS06029	Multifunction steering wheel control module-MFL message counter	12
MAS00769-MAS06030	Multifunction steering wheel control module-MFL Toggle Bit	0
MAS00769-MAS06034	Multifunction steering wheel control module-MFL Local active	not active
MAS00769-MAS06035	Multifunction steering wheel control module-MFL M button	not activated
MAS04447-IDE06339	Engine running status-Hybrid readiness: status	not active
MAS04447-MAS01493	Engine running status-Engine running	Engine off
MAS04447-MAS03023	Engine running status-Driving mode	not active
MAS04447-MAS06320	Engine running status-Status rolling mode	not active
ENG118785-ENG118741	Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Error_Indication	0
ENG118785-ENG118742	Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Indication_State	0
ENG118785-ENG118743	Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State	0
ENG118785-ENG118744	Driv._Prof._Sel._Coord._BAP_State-Coordinator_Bap_Request_State_Value	0
ENG118784-ENG124497	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise	not active
ENG118784-ENG118736	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control	not active
ENG118784-ENG06039	Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK	not active
ENG118784-ENG124493	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition	not active
ENG118784-ENG118739	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination	not active
ENG118784-ENG124501	Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view	not active
ENG118784-ENG124495	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner	not active
ENG118784-ENG124499	Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system	not active
ENG118784-ENG124503	Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential	not active
ENG118784-ENG118734	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control	not active
ENG118784-ENG06040	Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS	not active
ENG118784-ENG126254	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster	not active
ENG118784-ENG118730	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control	not active
ENG118784-ENG20970	Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA	not active
ENG118784-ENG124498	Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock	not active
ENG118784-ENG124500	Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control	not active
ENG118784-ENG06038	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control	not active
ENG118784-ENG124494	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control	not active
ENG118784-ENG126252	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode	not active
ENG118784-ENG124496	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch	not active
ENG118784-ENG06036	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control	not active
ENG118784-ENG126251	Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation	not active
ENG118784-ENG124502	Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler	not active
ENG118784-ENG126253	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment	not active
ENG118784-ENG118737	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator	not active
ENG118784-ENG124492	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop	not active
ENG118784-ENG118733	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support	not active
ENG118784-ENG118732	Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control	not active
ENG118786-ENG06057	Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus	0
ENG118786-ENG06058	Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus	0
ENG118786-ENG06061	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM	0
ENG118786-ENG06063	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS	0
ENG118786-ENG06062	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction	0
ENG118786-ENG06060	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer	0
ENG118786-ENG06059	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus	not recognized
ENG118786-ENG118748	Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile	not recognized
ENG118787-ENG06066	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_AGK	0
ENG118787-ENG06070	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_EDS	0
ENG118787-ENG20951	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_FMA	0
ENG118787-ENG06074	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_HHC	0
ENG118787-ENG118757	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_IVB	0
ENG118787-ENG06078	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Characteristic_Value_PLA	0
ENG118787-ENG06067	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_AGK	Timeout
ENG118787-ENG06071	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_EDS	OK
ENG118787-ENG20952	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_FMA	Timeout
ENG118787-ENG06075	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_HHC	OK
ENG118787-ENG118759	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_IVB	OK
ENG118787-ENG06079	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Communication_State_PLA	Timeout
ENG118787-ENG06065	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_AGK	engaged
ENG118787-ENG20953	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_EDS	engaged
ENG118787-ENG20954	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_FMA	Not available
ENG118787-ENG06073	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_HHC	engaged
ENG118787-ENG118755	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_IVB	engaged
ENG118787-ENG06077	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_Engagement_State_PLA	engaged
ENG118787-ENG06064	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_AGK	0
ENG118787-ENG06072	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_BAS	0
ENG118787-ENG06068	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_EDS	0
ENG118787-ENG20955	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_FMA	75
ENG118787-ENG118753	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_IVB	0
ENG118787-ENG06076	Driv._Prof._Sel._Fnc._Master_Preliminary-Function_ID_PLA	0
ENG118783-ENG118728	Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value	5
ENG118783-ENG118729	Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State	active
ENG118766	eASS_operation_status	Emergency running mode
ENG06004-ENG118763	EM_battery_analog_monitoring-actual_difference_voltage	0.038	 V
ENG06004-ENG118760	EM_battery_analog_monitoring-battery_analog_voltage	14.4	 V
ENG06004-ENG118765	EM_battery_analog_monitoring-battery_off_counter	0
ENG06004-ENG118764	EM_battery_analog_monitoring-battery_off_status_intern	connected
ENG06004-ENG118761	EM_battery_analog_monitoring-battery_voltage_filtered	14.4	 V
ENG06004-ENG118762	EM_battery_analog_monitoring-voltage_difference	0.35	 V
ENG106123	EM_blAlternator On	OFF
ENG106124	EM_blAlternator Valid	Yes
ENG106140	EM_Current_Control_Recu	not active
ENG20108	EM_electrical_system_current	0	 A
ENG118437	EM_IAlternatorReserve	0	 A
ENG118434	EM_LoadResponse Time	6	 s
ENG106154	EM_PAltMechanical	0	 W
ENG106155-ENG118436	EM_prcSoh-SOH_P	100	 %
ENG106155-ENG118435	EM_prcSoh-SOH_Q	100	 %
ENG106157	EM_RecuMode_Engine	Neutral
ENG118780-ENG115189	EM_Recuperation_Precondition-48V_emergency_run	0
ENG118780-ENG118443	EM_Recuperation_Precondition-acid_lamination	1
ENG118780-ENG118438	EM_Recuperation_Precondition-available_charge	1
ENG118780-ENG118442	EM_Recuperation_Precondition-battery_aging_charge	1
ENG118780-ENG118441	EM_Recuperation_Precondition-battery_aging_power	1
ENG118780-ENG118440	EM_Recuperation_Precondition-battery_charging_state	0
ENG118780-ENG118447	EM_Recuperation_Precondition-battery_regeneration	1
ENG118780-ENG103388	EM_Recuperation_Precondition-battery_temperature	0
ENG118780-ENG112320	EM_Recuperation_Precondition-Battery_Voltage	1
ENG118780-ENG36229	EM_Recuperation_Precondition-climate_electronics_enable	1
ENG118780-ENG118448	EM_Recuperation_Precondition-energy_net	1
ENG118780-ENG118445	EM_Recuperation_Precondition-generator_diagnosis	1
ENG118780-ENG118449	EM_Recuperation_Precondition-idle_increase	1
ENG118780-ENG36251	EM_Recuperation_Precondition-kfg_enable	1
ENG118780-ENG118439	EM_Recuperation_Precondition-LIN_communication	1
ENG118780-ENG118450	EM_Recuperation_Precondition-special_veto	1
ENG118781-ENG118671	EM_Recuperation_Restriction-component_protection_BDM	0
ENG118781-ENG118673	EM_Recuperation_Restriction-component_protection_engine	0
ENG118781-ENG118675	EM_Recuperation_Restriction-component_protection_EPS	0
ENG118781-ENG118674	EM_Recuperation_Restriction-component_protection_ESP	0
ENG118781-ENG118672	EM_Recuperation_Restriction-component_protection_high_beam_light	0
ENG118781-ENG118668	EM_Recuperation_Restriction-inside_light_active	0
ENG118781-ENG118670	EM_Recuperation_Restriction-left_turn_signal_active	0
ENG118781-ENG107413	EM_Recuperation_Restriction-low_beam_light_active	0
ENG118781-ENG110583	EM_Recuperation_Restriction-PLA	0
ENG118781-ENG113826	EM_Recuperation_Restriction-RekuLight	1
ENG118781-ENG118669	EM_Recuperation_Restriction-right_turn_signal_active	0
ENG118781-ENG36309	EM_Recuperation_Restriction-voltage_requirement_bcm	1
ENG118781-ENG36310	EM_Recuperation_Restriction-voltage_Requirement_kfg	0
ENG118781-ENG118667	EM_Recuperation_Restriction-workload_inside_blaster	0
ENG118782-ENG118462	Gateway app. software identification-software_version_BCmE	915
ENG118782-ENG118457	Gateway app. software identification-software_version_eASS	2015
ENG118782-ENG06026	Gateway app. software identification-software_version_ehr	----
ENG118782-ENG118454	Gateway app. software identification-software_version_em	1802
ENG118782-ENG118453	Gateway app. software identification-software_version_fpa	7240
ENG118782-ENG118455	Gateway app. software identification-software_version_history_data	500
ENG118782-ENG125888	Gateway app. software identification-software_version_hv-em	----
ENG118782-ENG118456	Gateway app. software identification-software_version_ks	----
ENG118782-ENG118458	Gateway app. software identification-software_version_mfl	200
ENG118782-ENG118463	Gateway app. software identification-software_version_mke	3148
ENG118782-ENG32644	Gateway app. software identification-software_version_mv-em
ENG118782-ENG32645	Gateway app. software identification-software_version_rtm	----
ENG118782-ENG122591	Gateway app. software identification-software_version_rwb	----
ENG118782-ENG118459	Gateway app. software identification-software_version_service_key_1a	100
ENG118782-ENG118460	Gateway app. software identification-software_version_SWaP	630
ENG118782-ENG118461	Gateway app. software identification-software_version_wakeup_monitor	100
ENG118782-ENG118452	Gateway app. software identification-version_routing_gateway	7170
ENG118666	MKE_HFC_filtrated	1
ENG126247-ENG126257	MKE_TTNR-TTNR_DS	60021
ENG126247-ENG126256	MKE_TTNR-TTNR_SW	60039
ENG20113-ENG09375	MV-EM_48V_electrical_system_components-48V_Ptc_installed	not installed
ENG20113-ENG09374	MV-EM_48V_electrical_system_components-48V_Rsg_installed	not installed
ENG20113-ENG09370	MV-EM_48V_electrical_system_components-DcDc_installed	not installed
ENG20113-ENG09372	MV-EM_48V_electrical_system_components-eAbc_installed	not installed
ENG20113-ENG09373	MV-EM_48V_electrical_system_components-eAv_installed	not installed
ENG20113-ENG09371	MV-EM_48V_electrical_system_components-eAws_installed	not installed
ENG20113-ENG09369	MV-EM_48V_electrical_system_components-LiIon_battery_installed	not installed
ENG20113-ENG09368	MV-EM_48V_electrical_system_components-sCap_installed	not installed
ENG20114-MAS01867	MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement	not OK
ENG20114-ENG09348	MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request	not requested
ENG20114-ENG09349	MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current	Initializing
ENG20115-MAS01867	MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement	not OK
ENG20115-ENG09351	MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active	not active
ENG20115-ENG09344	MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage	Initializing
ENG20115-ENG09352	MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage	Initializing
ENG20115-ENG09356	MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage	0	 V
ENG20115-ENG09355	MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage	0	 V
ENG20115-ENG09357	MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage	0	 V
ENG20115-ENG09354	MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage	0	 V
ENG20115-ENG09353	MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage	0	 V
ENG20115-ENG09358	MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag	Initializing
ENG20116-MAS01867	MV-EM_48V_overvoltage_check-Measurement	not OK
ENG20116-ENG09344	MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage	Initializing
ENG20116-ENG09345	MV-EM_48V_overvoltage_check-Bms_48V_Soc	102.25	 %
ENG20117-MAS11874	MV-EM_48V_Zero_potential_status-Overall status	Initializing
ENG20118-ENG09366	MV-EM_coldstart_requirement_engine-requirement_12V_start	not active
ENG20118-ENG09367	MV-EM_coldstart_requirement_engine-requirement_48V_start	not active
ENG20119	MV-EM_dc_current_Mv	-204	 A
ENG20120	MV-EM_dc_power_desired	-6325	 W
ENG20121	MV-EM_DC_voltage_desired	0	 V
ENG20122	MV-EM_dc_voltage_Mv	0	 V
ENG20123-ENG09198	MV-EM_Derating_voltage-Derating_group_A	0	 V
ENG20123-ENG09199	MV-EM_Derating_voltage-Derating_group_B	0	 V
ENG20123-ENG09200	MV-EM_Derating_voltage-Derating_group_C	0	 V
ENG20123-ENG09337	MV-EM_Derating_voltage-Derating_Umax_feedback	0	 V
ENG20124	MV-EM_EMG_level_of_capacity	0.025	 %
ENG20125	MV-EM_Mv_current	-511	 A
ENG20126-ENG09342	MV-EM_recommendation_Dcdc-Dcdc_boost_mode	not active
ENG20126-ENG09343	MV-EM_recommendation_Dcdc-Dcdc_buck_mode	not active
ENG20127-ENG09338	MV-EM_release-12V_coldstart_release	No enabling
ENG20127-ENG09339	MV-EM_release-12V_warmstart_release	No enabling
ENG20127-ENG09340	MV-EM_release-48V_coldstart_release	No enabling
ENG20127-ENG09341	MV-EM_release-start_stopp_support_release	No enabling
ENG20128	MV-EM_RSG_maximal_current	0	 A
ENG20129	MV-EM_RSG_maximal_voltage	0	 V
Elapsed Time: 00:46
Dana
Western PA, USA
22-AWD
adpmap-22-0CQ-907-554-H_3VWH17AU5JM758941-20180826-1119.CSV
;SW:0CQ-907-554-H   HW:0CQ-525-130 ---  AWD
;Component:Haldex4Motion H52 7083	 Coding:0001
;EV_AllWheelContrHA1VW37X	4013	EV_AllWheelContrHA1VW37X_004.rod
;Sunday	26	August	2018	11:19:54:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 4ACE68417C3FF5870F6-801E
IDE06425-Roller test bench mode: functional	not activated 	1
IDE07843-ENG142105-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4	0	8
IDE07843-ENG142107-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5	1700	8
IDE07843-ENG142109-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6	1700	8
IDE07843-ENG142111-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus	1700	8
IDE07843-ENG142104-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4	0	8
IDE07843-ENG142106-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5	1300	8
IDE07843-ENG142108-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6	1300	8
IDE07843-ENG142110-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus	1300	8
IDE07844-ENG142113-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4	0	8
IDE07844-ENG142115-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5	2000	8
IDE07844-ENG142117-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6	2000	8
IDE07844-ENG142119-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus	2000	8
IDE07844-ENG142112-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4	0	8
IDE07844-ENG142114-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5	1300	8
IDE07844-ENG142116-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6	1300	8
IDE07844-ENG142118-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus	1300	8
MAS06098-Acoustic measure: wiring logic	Standard 	1
Elapsed Time: 00:02
blockmap-22-0CQ-907-554-H_3VWH17AU5JM758941-20180826-1119.CSV
;Sunday	26	August	2018	11:19:50:04045
Group	Description	Actual
IDE00019	Voltage terminal 30	14.5	 V
IDE00030	Status of actuator test	not active
IDE00102	Control Module temperature	28	 °C
IDE00322	Status of basic setting	was not yet started
IDE00323	Security Access: Number of invalid keys	0
IDE00920	Front left wheel speed	0	 km/h
IDE00921	Front right wheel speed	0	 km/h
IDE00922	Left rear wheel speed	0	 km/h
IDE00923	Right rear wheel speed	0	 km/h
IDE01617	Clutch temperature	28	 °C
IDE02271-IDE02384	CAN output signal(s) status-Status of event memory	not active
IDE02271-MAS01464	CAN output signal(s) status-Emergency running mode	not active
IDE02271-MAS01480	CAN output signal(s) status-Excess temp.	not active
IDE02404	Checksum calculation	82 FC EF 04
IDE02486	Data logger triggering	not active
IDE04502-MAS04730	Haldex clutch status-Degree of blockage	0	 %
IDE05609	Cooling fin temperature	26.9	 °C
IDE05610	Duration of overtemperature	0	 min
IDE05707	Haldex clutch pump current	0.005	 A
IDE05708	Haldex clutch pump PWM signal	0	 %
IDE05710	Haldex clutch pump voltage	0	 V
IDE06111	Axle speed deltas	0	 km/h
IDE06425	Roller test bench mode: functional	not activated
IDE12115	Pumps diagnostic: number of tests during service life	0
IDE12116	Pumps diagnostic: anomalies during service life	0
IDE12117	Pump diagnostic: anomalies in current driving cycle	0
IDE12118	Pump diagnostic: total of defined anomalies	0
IDE80003-ENG119372	Analysis 3-Exeedance_Intergral_1_traction_slip_controller	0
IDE80003-ENG119373	Analysis 3-Exeedance_Intergral_2_extreme_slip_event	0
IDE80003-ENG119374	Analysis 3-Undercut_Integral_3_differential_lock_too_far_closed	0
IDE80004-ENG119372	Analysis 4-Exeedance_Intergral_1_traction_slip_controller	0
IDE80004-ENG119373	Analysis 4-Exeedance_Intergral_2_extreme_slip_event	0
IDE80004-ENG119374	Analysis 4-Undercut_Integral_3_differential_lock_too_far_closed	0
MAS00464-MAS00110	Standard - ambient data 1-Minutes	19
MAS00464-MAS00111	Standard - ambient data 1-Seconds	31
MAS03129	Reset counter	4
ENG119394-ENG119379	Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_EEPROM	1549
ENG119394-ENG119380	Pump_Calibration_Values-Calibration_Value_at_1_Bar_Current_Last_Measurement	0
ENG119394-ENG119378	Pump_Calibration_Values-Calibration_Value_at_1_Bar_Pressure_EEPROM	1
ENG119394-ENG119381	Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_EEPROM	2224
ENG119394-ENG119382	Pump_Calibration_Values-Calibration_Value_at_1_Bar_Voltage_Last_Measurement	0
ENG119394-ENG119384	Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_EEPROM	5047
ENG119394-ENG119385	Pump_Calibration_Values-Calibration_Value_at_15_Bar_Current_Interpolation	0
ENG119394-ENG119383	Pump_Calibration_Values-Calibration_Value_at_15_Bar_Pressure_EEPROM	15
ENG119394-ENG119386	Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_EEPROM	4817
ENG119394-ENG119387	Pump_Calibration_Values-Calibration_Value_at_15_Bar_Voltage_Interpolation	0
ENG119394-ENG119389	Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_EEPROM	9913
ENG119394-ENG119390	Pump_Calibration_Values-Calibration_Value_at_42_Bar_Current_Last_Measurement	0
ENG119394-ENG119388	Pump_Calibration_Values-Calibration_Value_at_42_Bar_Pressure_EEPROM	35
ENG119394-ENG119391	Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_EEPROM	7360
ENG119394-ENG119392	Pump_Calibration_Values-Calibration_Value_at_42_Bar_Voltage_Last_Measurement	0
ENG119394-ENG119377	Pump_Calibration_Values-Series_Number_Pump	8866668
ENG119394-ENG119376	Pump_Calibration_Values-Temperature_Value_at_Calibration	29	 °C
ENG119375	Upper Limit of Temperature Duration	0	 min
Elapsed Time: 00:04
Dana
Western PA, USA
42-Door Elect, Driver
adpmap-42-5Q4-959-593-E_3VWH17AU5JM758941-20180826-1120.CSV
;SW:5Q4-959-593-E   HW:5Q4-959-593-B ---  Door Elect	 Driver
;Component:TSG FS        011 0032	 Coding:003A03200000020000000000
;EV_DCUDriveSideEWMAXCONT	6001	EV_DCUDriveSideEWMAXCONT.rod
;Sunday	26	August	2018	11:20:10:04045
;VCID: 47C851756F2D08EF108-8012
IDE00001-Production mode	00000000 00000000 00000000  	3
IDE02332-Deactivate production mode	00000000 00000000 00000000  	3
ENG117304-Patch_Code_Driver_Side_Rear	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 33 48 	128
ENG117297-Reversing_Threshold_Driver_Side_Front	90%	1
ENG117299-Reversing_Threshold_Driver_Side_Rear	90%	1
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1	6D 4E 83 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 01 01 4C 00 00 02 03 05 14 75 33 00 00 00 D7 A3 	128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear	14 04 30 03 48 1F 13 00 14 14 00 28 00 22 02 58 01 90 02 58 0A 7D 0C 1E 2E 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 0C 0C 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 34 38 30 31 03 00 00 00 00 00 00 00 00 00 BA 54 	88
Elapsed Time: 00:06
blockmap-42-5Q4-959-593-E_3VWH17AU5JM758941-20180826-1120.CSV
;Sunday	26	August	2018	11:20:01:04045
IDE01766-MAS02248	Distance impulses-Signal state	Not available
IDE02260-IDE00773	Supply voltage for door control module: rear: left-Terminal 15 status via CAN	active
IDE02260-IDE01715	Supply voltage for door control module: rear: left-Status terminal S	active
IDE02260-IDE05835	Supply voltage for door control module: rear: left-Supply voltage for central locking	14.4	 V
IDE02262	synchronous mirror adjustment	not active
IDE02267-IDE00773	Supply voltage for door control module: front: driver side-Terminal 15 status via CAN	active
IDE02267-IDE01715	Supply voltage for door control module: front: driver side-Status terminal S	active
IDE02267-IDE05835	Supply voltage for door control module: front: driver side-Supply voltage for central locking	14.5	 V
IDE02668	Central window regulator switch	not installed
IDE04215-MAS02428	Mirror adjustment switch-Switch positions	Left
IDE04216-MAS01458	Mirror heater-Operating condition	not_active
IDE04216-MAS02965	Mirror heater-Performance percentage	0	 %
IDE04216-MAS04247	Mirror heater-Button	not activated
IDE04217	Fuel filler door release button	not installed
IDE04218	Turn signal in exterior rear-view mirror	not active
IDE04219-IDE02266	Window regulator control unit: driver side-Passenger side rear power window button	not activated
IDE04219-IDE04220	Window regulator control unit: driver side-Driver power window button	not activated
IDE04219-IDE06621	Window regulator control unit: driver side-Driver side rear power window button	not activated
IDE04219-IDE06872	Window regulator control unit: driver side-Front passenger power window button	not activated
IDE04220	Driver power window button	not activated
IDE04411	Child Safety Lock Switch	not activated
IDE04539-MAS01634	Mirror memory-Supply voltage	not active
IDE04539-MAS02228	Mirror memory-X coordinate	255	 %
IDE04539-MAS02229	Mirror memory-Y coordinate	255	 %
IDE04539-MAS02476	Mirror memory-install	not installed
IDE04540	Mirror adjustment (X/Y-direction)	Position center
IDE04580	Dimming of inside door handle lighting	94	 %
IDE04581	Dimming for interior ambient lighting	255	 %
IDE04586	Mirror fold-in activation	not installed
IDE05720-IDE02589	Front driver side door status-Rotary latch status	Open
IDE05720-IDE04213	Front driver side door status-Central locking button	not activated
IDE05720-IDE04214	Front driver side door status-Key switch in door lock	not activated
IDE05720-MAS06256	Front driver side door status-Status door lock	Signal from door lock: released
IDE05725	Terminal 58xs dimmer	0	 %
IDE05726	Terminal 58xd dimmer	100	 %
IDE05825-MAS02594	DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch	OFF
IDE05825-MAS04247	DWA Interior monitoring/vehicle inclination sensor button-Button	not activated
IDE06206-MAS01453	Front window regulator status: driver side-Blocking detection	not active
IDE06206-MAS02039	Front window regulator status: driver side-Force limitation	not active
IDE06206-MAS02097	Front window regulator status: driver side-Window position	96.5	 %
IDE06206-MAS02098	Front window regulator status: driver side-Power window control standardized	Yes
IDE06206-MAS03548	Front window regulator status: driver side-Motor current	0	 A
IDE06206-MAS04642	Front window regulator status: driver side-Before upper stop	not active
IDE06206-MAS05370	Front window regulator status: driver side-Direction of movement	Position bottom
IDE06208-MAS01453	Rear window regulator status: driver side-Blocking detection	not active
IDE06208-MAS02039	Rear window regulator status: driver side-Force limitation	not active
IDE06208-MAS02097	Rear window regulator status: driver side-Window position	0	 %
IDE06208-MAS02098	Rear window regulator status: driver side-Power window control standardized	Yes
IDE06208-MAS03548	Rear window regulator status: driver side-Motor current	215	 A
IDE06208-MAS04642	Rear window regulator status: driver side-Before upper stop	active
IDE06208-MAS05370	Rear window regulator status: driver side-Direction of movement	Position top
IDE06469	Ambient illumination for speaker	255	 %
IDE06621	Driver side rear power window button	not activated
IDE06931-MAS01159	Ident. of rear window regulator programming: driver side-Version number	4801
IDE06933	Front window regulator relay: driver side	Open
IDE06935	Rear window regulator relay: driver side	Open
IDE06937-MAS02545	Front window regulator reversing position: driver side-Last	127.5	 %
IDE06937-MAS02546	Front window regulator reversing position: driver side-Second to last	127.5	 %
IDE06937-MAS02547	Front window regulator reversing position: driver side-Third to last	127.5	 %
IDE06937-MAS02548	Front window regulator reversing position: driver side-Fourth to last	127.5	 %
IDE06937-MAS05380	Front window regulator reversing position: driver side-fifth to last	127.5	 %
IDE06939-MAS02545	Rear window regulator reversing position: driver side-Last	127.5	 %
IDE06939-MAS02546	Rear window regulator reversing position: driver side-Second to last	127.5	 %
IDE06939-MAS02547	Rear window regulator reversing position: driver side-Third to last	127.5	 %
IDE06939-MAS02548	Rear window regulator reversing position: driver side-Fourth to last	127.5	 %
IDE06939-MAS05380	Rear window regulator reversing position: driver side-fifth to last	127.5	 %
IDE06940	Rear window regulator child lock: driver side	not active
IDE07110-MAS01632	Recognition of motor variant for window regul.-Status	not recognized
IDE07110-MAS04606	Recognition of motor variant for window regul.-Parameter set	2
IDE07222	Window regulator child lock: driver side	Not available
IDE07405-IDE03114	Enable driver front window regulator relay-Comfort function	No
IDE07405-MAS02447	Enable driver front window regulator relay-Release	Yes
IDE07407-IDE03114	Enable driver-side rear window regulator-Comfort function	No
IDE07407-MAS02447	Enable driver-side rear window regulator-Release	Yes
IDE07409-MAS01632	Excessive temper. disconnect: front window regulator: driv.side-Status	not active
IDE07409-MAS02955	Excessive temper. disconnect: front window regulator: driv.side-Engine temperature	33	 °C
IDE07411-MAS01632	Excess.temp.disconnect: rear window regulator: driver side-Status	not active
IDE07411-MAS02955	Excess.temp.disconnect: rear window regulator: driver side-Engine temperature	42	 °C
IDE07413	Comfort function for front window regulator: driver side	not active
IDE07415	Comfort function for rear window regulator: driver side	not active
IDE07543	Vehicle speed	0	 km/h
IDE08061	Child safety lock button 2	not installed
IDE08697-MAS07302	Number of driving cycles without opening door-Max. number of driving cycles without opening door	0
IDE08697-MAS07303	Number of driving cycles without opening door-Actual number of driving cycles without opening door	0
MAS00464-MAS00111	Standard - ambient data 1-Seconds	46
MAS01872	Rear lid remote release button	not installed
MAS02099	Switch for inside door handle	not installed
MAS02100	Switch for outside door handle	not installed
MAS02101	Child safety	not active
MAS06010	Ambient light	90	 %
ENG117313-ENG99000	control_event_memory_driver_side_rear-Value	01 0B 09 05 08 05 3B 11 00 0B 09 05 08 06 01 12 88 0B 01 01 06 15 1A 12 BD 00 00 00 00 00 00 00 00 00 00 00 00
ENG117295-MAS00966	Driver_Rear_VW_FAZIT_Identification_String-Manufacture location index	SVM-403
ENG117295-MAS00968	Driver_Rear_VW_FAZIT_Identification_String-Day of manufacture	26.05.17
ENG117295-MAS00969	Driver_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number	10
ENG117295-MAS00970	Driver_Rear_VW_FAZIT_Identification_String-Running manufacturer number	785
ENG117309	Window_Regulator_Driver_Side_Rear_Sleep_Indication	not active
ENG117315-ENG99000	Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-Value	J926
Elapsed Time: 00:08
Dana
Western PA, USA
44-Steering Assist
adpmap-44-5QM-909-144-A_3VWH17AU5JM758941-20180826-1120.CSV
;SW:5QM-909-144-A   HW:5QM-909-144-A ---  Steering Assist
;Component:EPS_MQB_ZFLS  171 1072	 Coding:8102
;EV_SteerAssisMQB	13144	EV_SteerAssisMQB_013.rod
;Sunday	26	August	2018	11:20:26:04045
;VCID: 4FF87955875DD0AF588-801A
IDE00820-Activating and deactivating all development messages	not active 	1
IDE03724-Straight line running	active 	1
IDE03734-Support power	100%	1
IDE04130-Characteristic curve of steering assistance	Driving profile selection button 	1
IDE04555-Activation of pwr steering asst without engine running	not active 	1
IDE05162-Software end stop	active 	1
IDE06419-Driving profile switchover	Incremental: controlled over time 	1
IDE07540-Download without rest bus	not active 	1
IDE09571-RPM monitoring	active 	1
MAS02080-XCP calibration protocol	not active 	1
Elapsed Time: 00:02
blockmap-44-5QM-909-144-A_3VWH17AU5JM758941-20180826-1120.CSV
;Sunday	26	August	2018	11:20:18:04045
IDE00018	Voltage terminal 15	14.42	 V
IDE00019	Voltage terminal 30	14.33	 V
IDE00020	Terminal 15 status	Terminal 15 on
IDE00021	Engine speed	0	 /min
IDE00075	Vehicle speed	0	 km/h
IDE00102	Control Module temperature	39	 °C
IDE00550-IDE03737	Identification of parameterization-Index characteristic curve	0B
IDE00550-MAS01078	Identification of parameterization-Vehicle type	A2
IDE00550-MAS05566	Identification of parameterization-Version of system parameters	21
IDE00550-MAS05567	Identification of parameterization-Version of characteristic curves	3
IDE00550-MAS05568	Identification of parameterization-Version of memory map	A1
IDE02006-IDE02955	Lane assistant-System status	Function cannot be performed
IDE02006-IDE04227	Lane assistant-Directional stab. asst w/ pwr steering asst: steering status	31.999	 Nm
IDE02006-MAS03095	Lane assistant-Function status	not activated
IDE02006-MAS03368	Lane assistant-Steering wheel vibration	not active
IDE02202	End stage temperature	31	 °C
IDE02216-IDE05795	Steering angle sensor: basic setting-End basic setting	Not permitted
IDE02216-IDE06673	Steering angle sensor: basic setting-Initialization status	initialized
IDE02216-MAS01632	Steering angle sensor: basic setting-Status	calibrated
IDE02216-MAS03161	Steering angle sensor: basic setting-Start	Not permitted
IDE02955	System status	Waiting for start request
IDE03682-IDE04457	Sensor for motor position-Electric motor speed	N/A---
IDE03682-MAS02961	Sensor for motor position-Engine angle	155.5	 °
IDE03682-MAS03083	Sensor for motor position-Cosine signal	1.935	 V
IDE03682-MAS03211	Sensor for motor position-Sine signal	0.58	 V
IDE03682-MAS05053	Sensor for motor position-Reference value	Condition met
IDE03725-IDE03734	Steering Assistance-Support power	0	 %
IDE03725-MAS03001	Steering Assistance-Mode	Unknown (3)
IDE03725-MAS03095	Steering Assistance-Function status	not activated
IDE03726-IDE02955	Parallel Parking Assistance-System status	not active
IDE03726-IDE05159	Parallel Parking Assistance-Steering angle: target value	4095.9	 °
IDE03726-IDE05160	Parallel Parking Assistance-Steering angle: target-actual deviation	-4090.8	 °
IDE03726-MAS03095	Parallel Parking Assistance-Function status	not activated
IDE03735	Steering torque	N/A---
IDE03735-MAS01632	Steering torque-Status	OK
IDE03736	Steering torque 2	N/A---
IDE03736-MAS01632	Steering torque 2-Status	OK
IDE04118-IDE05157	Straight line running correction-Long term learning condition	Condition not met
IDE04118-IDE05158	Straight line running correction-Short term learning condition	Condition not met
IDE04118-MAS02998	Straight line running correction-Angle value offset	0.2	 °
IDE04118-MAS03095	Straight line running correction-Function status	activated
IDE04118-MAS03528	Straight line running correction-Long term adaptation value	0.2	 °
IDE04118-MAS03529	Straight line running correction-Short term adaptation value	0	 °
IDE04119-MAS03738	Active reset-Restoring force: setpoint	0	 N
IDE04183	Steering assistance: target engine torque	0	 Nm
IDE04184	Steering assistance: engine output	0	 %
IDE04185	Terminal 30 voltage filtered	14.41	 V
IDE04186	Battery terminal recognition	connected
IDE04187	Steering torque: raw value 1	12.598	 %
IDE04187-MAS01632	Steering torque: raw value 1-Status	OK
IDE04188	Steering torque: raw value 2	-82.91	 %
IDE04188-MAS01632	Steering torque: raw value 2-Status	OK
IDE04189	Steering torque: raw value 3	12.598	 %
IDE04189-MAS01632	Steering torque: raw value 3-Status	OK
IDE04190	Steering torque: raw value 4	-82.91	 %
IDE04190-MAS01632	Steering torque: raw value 4-Status	OK
IDE04191-MAS03084	Steering assistance: PWM signal for motor-Phase 1	2.39	 %
IDE04191-MAS03085	Steering assistance: PWM signal for motor-Phase 2	2.4	 %
IDE04191-MAS03086	Steering assistance: PWM signal for motor-Phase 3	2.39	 %
IDE04192-MAS03084	Steering assistance: motor current-Phase 1	0	 A
IDE04192-MAS03085	Steering assistance: motor current-Phase 2	0	 A
IDE04192-MAS03086	Steering assistance: motor current-Phase 3	0	 A
IDE04194	Steering assistance: electromotor power	N/A---
IDE04448-IDE00924	Steering angle sensor: angle-Steering angle	-4.3	 °
IDE04448-MAS01632	Steering angle sensor: angle-Status	valid
IDE04454-MAS01632	Steering angle sensor: angle speed-Status	valid
IDE04454-MAS02984	Steering angle sensor: angle speed-Steering angle speed	0	 °
IDE04458-MAS02996	Steering angle sensor: mechanical steering stroke-Steering stroke measured	160.91	 mm
IDE04458-MAS03731	Steering angle sensor: mechanical steering stroke-Mechanical center position determined	Yes
IDE04459	Steering angle sensor: offset index mark mechanical center	0.15	 mm
IDE04460	Steering angle sensor: offset straight line running	N/A---
IDE04510-MAS03732	Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve	not recognized
IDE04510-MAS03733	Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve	not recognized
IDE04510-MAS03734	Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve	not recognized
IDE04510-MAS03735	Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve	not recognized
IDE04510-MAS03736	Steering angle sensor: slope detection index-Index mark	1
IDE04511	Steering angle sensor external via CAN: angle	Measured value not available
IDE04512	Steering angle sensor external via CAN: angular velocity	Measured value not available
IDE04513	Steering angle sensor external via CAN: status	not active
IDE04514	Steering angle sensor external via CAN: basic setting	Calibration not possible
IDE04765-IDE02955	Counter steer support-System status	operational
IDE04765-MAS03095	Counter steer support-Function status	activated
IDE04765-MAS03739	Counter steer support-Steering torque request: brake electronics	0	 Nm
IDE04766-IDE04116	Replacement values-Vehicle speed replacement value	No
IDE04766-MAS00371	Replacement values-Engine speed	No
IDE04787	Hybrid status	not active
IDE04805-IDE02955	Driving profile selection-System status	operational
IDE04805-IDE06419	Driving profile selection-Driving profile switchover	no request
IDE04805-MAS01447	Driving profile selection-Act.val.	2
IDE04805-MAS01448	Driving profile selection-Specified value	2
IDE04805-MAS05058	Driving profile selection-Compatibility	Yes
IDE05155	Power steering current consumption	N/A---
IDE05162-IDE03723	Software end stop-End stops for steering	Adapted
IDE05162-MAS01849	Software end stop-Left	80.6	 mm
IDE05162-MAS01850	Software end stop-Right	-80.3	 mm
IDE05162-MAS03095	Software end stop-Function status	active
IDE05713-IDE01864	Network diagnosis-Status of current bus communication	active
IDE05713-MAS00102	Network diagnosis-valid	Yes
IDE05713-MAS02447	Network diagnosis-Release	Yes
IDE05993-ENG120753	Steering wheel angle load-0_to_50_degrees	1972
IDE05993-ENG120755	Steering wheel angle load-100_to_150_degrees	0
IDE05993-ENG120751	Steering wheel angle load--100_to_-50_degrees	0
IDE05993-ENG120750	Steering wheel angle load--150_to_-100_degrees	0
IDE05993-ENG120756	Steering wheel angle load-150_to_200_degrees	0
IDE05993-ENG120749	Steering wheel angle load--200_to_-150_degrees	0
IDE05993-ENG120757	Steering wheel angle load-200_to_250_degrees	0
IDE05993-ENG120748	Steering wheel angle load--250_to_-200_degrees	0
IDE05993-ENG120758	Steering wheel angle load-250_to_300_degrees	0
IDE05993-ENG120747	Steering wheel angle load--300_to_-250_degrees	0
IDE05993-ENG120759	Steering wheel angle load-300_to_350_degrees	0
IDE05993-ENG120746	Steering wheel angle load--350_to_-300_degrees	0
IDE05993-ENG120760	Steering wheel angle load-350_to_400_degrees	0
IDE05993-ENG120745	Steering wheel angle load--400_to_-350_degrees	0
IDE05993-ENG120761	Steering wheel angle load-400_to_450_degrees	0
IDE05993-ENG120744	Steering wheel angle load--450_to_-400_degrees	0
IDE05993-ENG120762	Steering wheel angle load-450_to_500_degrees	0
IDE05993-ENG120752	Steering wheel angle load--50_to_0_degrees	2010
IDE05993-ENG120754	Steering wheel angle load-50_to_100_degrees	0
IDE05993-ENG120743	Steering wheel angle load--500_to_-450_degrees	0
IDE05993-ENG120763	Steering wheel angle load-500_to_550_degrees	0
IDE05993-ENG120742	Steering wheel angle load--550_to_500_degrees	0
IDE05993-ENG120764	Steering wheel angle load-above_550_degrees	0
IDE05993-ENG120741	Steering wheel angle load-below_-550_degrees	0
IDE05994-ENG120729	Engine specified torque load-0_to_1_kilo_newton	93
IDE05994-ENG120728	Engine specified torque load--1_to_0_kilo_newton	694
IDE05994-ENG120730	Engine specified torque load-1_to_2_kilo_newton	1
IDE05994-ENG120719	Engine specified torque load--10_to_-9_kilo_newton	1
IDE05994-ENG120727	Engine specified torque load--2_to_-1_kilo_newton	83
IDE05994-ENG120731	Engine specified torque load-2_to_3_kilo_newton	0
IDE05994-ENG120726	Engine specified torque load--3_to_-2_kilo_newton	0
IDE05994-ENG120732	Engine specified torque load-3_to_4_kilo_newton	0
IDE05994-ENG120725	Engine specified torque load--4_to_-3_kilo_newton	0
IDE05994-ENG120733	Engine specified torque load-4_to_5_kilo_newton	0
IDE05994-ENG120724	Engine specified torque load--5_to_-4_kilo_newton	0
IDE05994-ENG120734	Engine specified torque load-5_to_6_kilo_newton	0
IDE05994-ENG120723	Engine specified torque load--6_to_-5_kilo_newton	0
IDE05994-ENG120735	Engine specified torque load-6_to_7_kilo_newton	0
IDE05994-ENG120722	Engine specified torque load--7_to_-6_kilo_newton	0
IDE05994-ENG120736	Engine specified torque load-7_to_8_kilo_newton	0
IDE05994-ENG120721	Engine specified torque load--8_to_-7_kilo_newton	0
IDE05994-ENG120737	Engine specified torque load-8_to_9_kilo_newton	1
IDE05994-ENG120738	Engine specified torque load-9_to_10_kilo_newton	0
IDE05994-ENG120720	Engine specified torque load--9_to_-8_kilo_newton	0
IDE05994-ENG120739	Engine specified torque load-above_10_kilo_newton	3
IDE05994-ENG120718	Engine specified torque load-below_-10_kilo_newton	0
IDE05995-ENG120703	ECU temperature load-0_to_10_degrees_celsius	0
IDE05995-ENG120702	ECU temperature load--10_to_0_degrees_celsius	36840
IDE05995-ENG120704	ECU temperature load-10_to_20_degrees_celsius	43
IDE05995-ENG120713	ECU temperature load-100_to_110_degrees_celsius	0
IDE05995-ENG120714	ECU temperature load-110_to_120_degrees_celsius	0
IDE05995-ENG120701	ECU temperature load--20_to_-10_degrees_celsius	0
IDE05995-ENG120705	ECU temperature load-20_to_30_degrees_celsius	117
IDE05995-ENG120700	ECU temperature load--30_to_-20_degrees_celsius	0
IDE05995-ENG120706	ECU temperature load-30_to_40_degrees_celsius	49
IDE05995-ENG120699	ECU temperature load--40_to_-30_degrees_celsius	0
IDE05995-ENG120707	ECU temperature load-40_to_50_degrees_celsius	19
IDE05995-ENG120708	ECU temperature load-50_to_60_degrees_celsius	0
IDE05995-ENG120709	ECU temperature load-60_to_70_degrees_celsius	0
IDE05995-ENG120710	ECU temperature load-70_to_80_degrees_celsius	0
IDE05995-ENG120711	ECU temperature load-80_to_90_degrees_celsius	0
IDE05995-ENG120712	ECU temperature load-90_to_100_degrees_celsius	0
IDE05995-ENG120715	ECU temperature load-above_120_degrees_celsius	0
IDE05995-ENG120698	ECU temperature load-below_-40_degrees_celsius	0
IDE05996-ENG120766	Steering wheel angle speed load-360_to_600_degrees_per_second	1158
IDE05996-ENG120765	Steering wheel angle speed load-50_to_360_degrees_per_second	1138
IDE05996-ENG120767	Steering wheel angle speed load-600_to_800_degrees_per_second	253
IDE05996-ENG120768	Steering wheel angle speed load-above_800_degrees_per_second	222
IDE06678-IDE03458	Pull compensation-Steering torque offset	0	 Nm
IDE06678-MAS03000	Pull compensation-Adapt. value	0.12	 Nm
IDE06678-MAS03095	Pull compensation-Function status	not activated
IDE07399	Engine type	0
IDE07400-MAS03084	Phase disconnect: status-Phase 1	closed
IDE07400-MAS03085	Phase disconnect: status-Phase 2	closed
IDE07400-MAS03086	Phase disconnect: status-Phase 3	closed
IDE07542-MAS00370	Prerequisites: basic setting-Vehicle speed	Condition met
IDE07542-MAS01468	Prerequisites: basic setting-Terminal 15	Condition met
IDE07542-MAS01634	Prerequisites: basic setting-Supply voltage	Condition met
IDE07542-MAS01746	Prerequisites: basic setting-Regulation active	Condition not met
IDE07542-MAS02980	Prerequisites: basic setting-Manual steering torque	Condition met
MAS00464-MAS00110	Standard - ambient data 1-Minutes	20
MAS00976-IDE80003	Counter-Analysis 3	2977518421
MAS00976-IDE80004	Counter-Analysis 4	1
MAS01172-MAS01156	Development messages-Communication status	active
MAS01172-MAS03095	Development messages-Function status	not active
MAS02126-MAS01632	Steering angle sensor: status-Status	active
MAS02126-MAS02247	Steering angle sensor: status-CAN message	valid
ENG120769-MAS00973	identification_add-on_parts_steering_assistance-Construction version	Series
ENG120769-ENG120622	identification_add-on_parts_steering_assistance-moment_sensor	magnetoresistiv
ENG120769-ENG120621	identification_add-on_parts_steering_assistance-system_supplier	ZFO
Elapsed Time: 00:07
Dana
Western PA, USA
52-Door Elect, Pass.
adpmap-52-5Q4-959-592-E_3VWH17AU5JM758941-20180826-1120.CSV
;SW:5Q4-959-592-E   HW:5Q4-959-592-B ---  Door Elect	 Pass.
;Component:TSG BFS       011 0032	 Coding:003A03200000020000000000
;EV_DCUPasseSideEWMAXCONT	6001	EV_DCUPasseSideEWMAXCONT.rod
;Sunday	26	August	2018	11:20:40:04045
;VCID: 46D65C71682711E7EBE-8012
ENG117308-Patch_Code_Passenger_Side_Rear	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 33 48 	128
ENG117298-Reversing_Threshold_Passenger_Side_Front	90%	1
ENG117300-Reversing_Threshold_Passenger_Side_Rear	90%	1
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1	67 4E 83 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 02 01 4C 00 00 02 03 05 14 75 33 00 00 00 F9 4E 	128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear	14 04 30 03 48 1F 13 00 14 14 00 28 00 22 02 58 01 90 02 58 0A 7D 0C 1E 2E 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 00 00 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 34 38 30 31 03 00 00 00 00 00 00 00 00 00 7F 94 	88
Elapsed Time: 00:06
blockmap-52-5Q4-959-592-E_3VWH17AU5JM758941-20180826-1120.CSV
;Sunday	26	August	2018	11:20:32:04045
IDE02261-IDE00773	Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN	active
IDE02261-IDE01715	Supply voltage for door control module: rear: frt.pass. side-Status terminal S	active
IDE02261-IDE05835	Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking	14.4	 V
IDE02266	Passenger side rear power window button	not activated
IDE02268-IDE00773	Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN	active
IDE02268-IDE01715	Supply voltage for door control module: front: frt.pass. side-Status terminal S	active
IDE02268-IDE05835	Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking	14.5	 V
IDE04540	Mirror adjustment (X/Y-direction)	not installed
IDE05727-IDE02589	Front passenger side door status-Rotary latch status	closed
IDE05727-IDE04213	Front passenger side door status-Central locking button	not activated
IDE05727-IDE04214	Front passenger side door status-Key switch in door lock	not installed
IDE05727-MAS06256	Front passenger side door status-Status door lock	Signal from door lock: released
IDE06207-MAS01453	Front window regulator status: frt.pass. side-Blocking detection	not active
IDE06207-MAS02039	Front window regulator status: frt.pass. side-Force limitation	not active
IDE06207-MAS02097	Front window regulator status: frt.pass. side-Window position	96.5	 %
IDE06207-MAS02098	Front window regulator status: frt.pass. side-Power window control standardized	Yes
IDE06207-MAS03548	Front window regulator status: frt.pass. side-Motor current	0	 A
IDE06207-MAS04642	Front window regulator status: frt.pass. side-Before upper stop	not active
IDE06207-MAS05370	Front window regulator status: frt.pass. side-Direction of movement	Position bottom
IDE06209-MAS01453	Rear window regulator status: frt.pass. side-Blocking detection	not active
IDE06209-MAS02039	Rear window regulator status: frt.pass. side-Force limitation	not active
IDE06209-MAS02097	Rear window regulator status: frt.pass. side-Window position	0	 %
IDE06209-MAS02098	Rear window regulator status: frt.pass. side-Power window control standardized	Yes
IDE06209-MAS03548	Rear window regulator status: frt.pass. side-Motor current	215	 A
IDE06209-MAS04642	Rear window regulator status: frt.pass. side-Before upper stop	active
IDE06209-MAS05370	Rear window regulator status: frt.pass. side-Direction of movement	Position top
IDE06872	Front passenger power window button	not activated
IDE06932-MAS01159	Ident. of rear window regulator programming: frt.pass. side-Version number	4801
IDE06934	Front window regulator relay: frt.pass. side	Open
IDE06936	Rear window regulator relay: frt.pass. side	Open
IDE06938-MAS02545	Front window regulator reversing position: frt. pass. side-Last	127.5	 %
IDE06938-MAS02546	Front window regulator reversing position: frt. pass. side-Second to last	127.5	 %
IDE06938-MAS02547	Front window regulator reversing position: frt. pass. side-Third to last	127.5	 %
IDE06938-MAS02548	Front window regulator reversing position: frt. pass. side-Fourth to last	127.5	 %
IDE06938-MAS05380	Front window regulator reversing position: frt. pass. side-fifth to last	127.5	 %
IDE06941	Rear window regulator child lock: frt.pass. side	not active
IDE07223	Window regulator child lock: frt.pass. side	Not available
IDE07406-IDE03114	Enable front passenger window regulator relay-Comfort function	No
IDE07406-MAS02447	Enable front passenger window regulator relay-Release	Yes
IDE07408-IDE03114	Enable frt.pass.-side rear window regulator-Comfort function	No
IDE07408-MAS02447	Enable frt.pass.-side rear window regulator-Release	Yes
IDE07410-MAS01632	Excess.temp. disconnect: front window regulator: frt.pass. side-Status	not active
IDE07410-MAS02955	Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature	33	 °C
IDE07412-MAS01632	Excess.temp.disconnect for rear window regulator: frt.pass.side-Status	not active
IDE07412-MAS02955	Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature	42	 °C
IDE07414	Comfort function for front window regulator: frt.pass. side	not active
IDE07416	Comfort function for rear window regulator: frt.pass. side	not active
IDE07417-MAS02545	Rear window regulator reversing position: frt.pass. side-Last	127.5	 %
IDE07417-MAS02546	Rear window regulator reversing position: frt.pass. side-Second to last	127.5	 %
IDE07417-MAS02547	Rear window regulator reversing position: frt.pass. side-Third to last	127.5	 %
IDE07417-MAS02548	Rear window regulator reversing position: frt.pass. side-Fourth to last	127.5	 %
IDE07417-MAS05380	Rear window regulator reversing position: frt.pass. side-fifth to last	127.5	 %
MAS00464-MAS00111	Standard - ambient data 1-Seconds	16
ENG117314-ENG99000	control_event_memory_passenger_side_rear-Value	00 0B 01 01 06 15 1B 12 BF 0B 01 01 06 10 1E 12 A9 0B 01 01 06 15 02 11 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG117296-MAS00966	Passenger_Rear_VW_FAZIT_Identification_String-Manufacture location index	SVM-403
ENG117296-MAS00968	Passenger_Rear_VW_FAZIT_Identification_String-Day of manufacture	24.05.17
ENG117296-MAS00969	Passenger_Rear_VW_FAZIT_Identification_String-Manufacturer- test stand number	10
ENG117296-MAS00970	Passenger_Rear_VW_FAZIT_Identification_String-Running manufacturer number	992
ENG117310	Window_Regulator_Passenger_Side_Rear_Sleep_Indication	not active
ENG117316-ENG99000	Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-Value	J927
Elapsed Time: 00:07
Dana
Western PA, USA
5F-Information Electr.
adpmap-5F-5G6-035-868_3VWH17AU5JM758941-20180826-1121.CSV
;SW:5G6-035-868   HW:5G6-035-868 ---  Information Electr.
;Component:MU-E--ER      671 8395	 Coding:02731200FF00000041220001001000009F0008D40000010000
;EV_MUEnt4CGen2LGE	1041	EV_MUEnt4CGen2LGE_VW12.rod
;Sunday	26	August	2018	11:21:07:04045
;VCID: 70BADAA93A23EF57612-8024
IDE00001-Production mode	00 00 00 	3
IDE00346-Summertime-automatic	manual 	1
IDE00758-Base volume of telephone	50%	1
IDE00760-Microphone sensitivity	0 dB	1
IDE00769-Number 1 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00770-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF 	1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF 	1
IDE02063-Time display for start screen	2.0 s	1
IDE02122-Developer mode	not activated 	1
IDE02330-Number 2 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02331-Number 2 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02332-Deactivate production mode	0	3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic 	49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz	49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	27	49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz	49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	27	49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz	49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	27	49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz	49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	27	49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz	49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	27	49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz	49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	27	49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz	49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	27	49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz	49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	27	49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz	49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	27	49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz	49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	27	49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz	49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	27	49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz	49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	27	49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz	49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	27	49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz	49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	27	49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz	49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	27	49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz	49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	27	49
IDE02502-Confirmation of installation change	DF 07 	2
IDE02699-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE02701-Number 1 (roaming) for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 	23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF 	30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing	OFF 	30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On 	30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless	OFF 	30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life	OFF 	30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios	OFF 	30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless	OFF 	30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless	OFF 	30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb	blocked 	30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant	0	30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	OFF 	30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support	OFF 	30
IDE03471-ENG185778-Vehicle configuration-FoD	SWaP 	30
IDE03471-ENG130248-Vehicle configuration-Google_GAL	On 	30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless	OFF 	30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	OFF 	30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	OFF 	30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	OFF 	30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	OFF 	30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data	not activated 	30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender	Deactivated 	30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present 	30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present 	30
IDE03471-ENG127492-Vehicle configuration-LGI	OFF 	30
IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated 	30
IDE03471-ENG142142-Vehicle configuration-map_email_support	OFF 	30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support	OFF 	30
IDE03471-ENG142141-Vehicle configuration-map_sms_support	OFF 	30
IDE03471-ENG142152-Vehicle configuration-Map_Style	0	30
IDE03471-ENG152537-Vehicle configuration-media_control	not activated 	30
IDE03471-ENG138662-Vehicle configuration-Mirror_link	On 	30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code	MIB_NAR 	30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference	RGB565 	30
IDE03471-ENG117843-Vehicle configuration-my_audi	OFF 	30
IDE03471-ENG117845-Vehicle configuration-online_dictation	OFF 	30
IDE03471-ENG127495-Vehicle configuration-online_media	OFF 	30
IDE03471-ENG117840-Vehicle configuration-online_navigation	OFF 	30
IDE03471-ENG117837-Vehicle configuration-online_POI	OFF 	30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice	OFF 	30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	OFF 	30
IDE03471-ENG152553-Vehicle configuration-online_radio	Deactivated 	30
IDE03471-ENG117841-Vehicle configuration-online_street_view	OFF 	30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF 	30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold	0	30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis	0	30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy	0	30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	Data & language service active 	30
IDE03471-ENG117844-Vehicle configuration-picture_navi	OFF 	30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking	not activated 	30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use	not activated 	30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest	0	30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF 	30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo	OFF 	30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5 	30
IDE03471-ENG117846-Vehicle configuration-remote_HMI	OFF 	30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component	activated 	30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open	not activated 	30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold	not activated 	30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe	not activated 	30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input	FBAS 	30
IDE03471-ENG152556-Vehicle configuration-scon_telephony	not activated 	30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation	no restriction 	30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag	no_region 	30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch	not activated 	30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	Not Present 	30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support	OFF 	30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi	activated 	30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	0	30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF 	30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	OFF 	30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone	OFF 	30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location	OFF 	30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF 	30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving	blocked 	30
IDE03471-ENG137647-Vehicle configuration-UOTA	OFF 	30
IDE03471-ENG167532-Vehicle configuration-UOTA_2	OFF 	30
IDE03471-ENG117852-Vehicle configuration-UPnP	OFF 	30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound	not activated 	30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound	not activated 	30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte	not activated 	30
IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF 	30
IDE03471-ENG127494-Vehicle configuration-VZO	OFF 	30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI	OFF 	30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	OFF 	30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch	not activated 	30
IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP 	1
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF 	4
IDE04550-Bluetooth: Sniff mode	OFF 	1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128	40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	-128	40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128	40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128	40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128	40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128	40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128	40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128	40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128	40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128	40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128	40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128	40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128	40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128	40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128	40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128	40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128	40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128	40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128	40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128	40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-128	40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128	40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128	40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128	40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128	40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	-128	40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128	40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128	40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128	40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128	40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128	40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128	40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128	40
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated 	4
IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated 	4
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated 	4
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated 	4
IDE11122-Country identification: country of sale HMI	US 	2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0	blocked 	21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked 	21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked 	21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11	blocked 	21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12	blocked 	21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked 	21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked 	21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked 	21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked 	21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked 	21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked 	21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked 	21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2	blocked 	21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked 	21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked 	21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked 	21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked 	21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3	blocked 	21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked 	21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked 	21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked 	21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7	blocked 	21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked 	21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked 	21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked 	21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	blocked 	21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	blocked 	21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	blocked 	21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	blocked 	21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	blocked 	21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked 	21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	blocked 	21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked 	21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked 	21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked 	21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked 	21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked 	21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked 	21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked 	21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked 	21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked 	21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	blocked 	21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	non_blocked 	21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	blocked 	21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked 	21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	blocked 	21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	blocked 	21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	blocked 	21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0	blocked 	21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked 	21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10	blocked 	21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11	blocked 	21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12	non_blocked 	21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13	blocked 	21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14	non_blocked 	21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked 	21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked 	21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked 	21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18	blocked 	21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19	blocked 	21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2	blocked 	21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20	blocked 	21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked 	21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22	blocked 	21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked 	21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked 	21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked 	21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked 	21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked 	21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked 	21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked 	21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked 	21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30	blocked 	21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked 	21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked 	21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked 	21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked 	21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked 	21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked 	21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked 	21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked 	21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked 	21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked 	21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked 	21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked 	21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked 	21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked 	21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44	blocked 	21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45	blocked 	21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46	blocked 	21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47	blocked 	21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5	blocked 	21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked 	21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked 	21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked 	21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9	blocked 	21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0	non_blocked 	21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked 	21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked 	21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked 	21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked 	21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked 	21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked 	21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked 	21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked 	21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked 	21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked 	21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked 	21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked 	21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked 	21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21	non_blocked 	21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked 	21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked 	21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked 	21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked 	21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked 	21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked 	21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked 	21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked 	21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked 	21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked 	21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked 	21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked 	21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked 	21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked 	21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked 	21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked 	21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked 	21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked 	21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked 	21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4	non_blocked 	21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked 	21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6	non_blocked 	21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked 	21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked 	21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9	non_blocked 	21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	blocked 	21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked 	21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked 	21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked 	21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked 	21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked 	21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked 	21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked 	21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked 	21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked 	21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	non_blocked 	21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	blocked 	21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	non_blocked 	21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	blocked 	21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked 	21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked 	21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked 	21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked 	21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked 	21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked 	21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked 	21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked 	21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked 	21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked 	21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked 	21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	blocked 	21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	blocked 	21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	non_blocked 	21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	non_blocked 	21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	blocked 	21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked 	21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked 	21
IDE13183-Deactivation/activation of the pop-up for active tracking services	00 00 00 00 	4
MAS00951-Bluetooth	On 	1
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz	6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz	6
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz	6
ENG117917-BAP_Debug_Mode_Release	not_released 	1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated 	60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated 	60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated 	60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated 	60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated 	60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation	not activated 	60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer	not activated 	60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off	not activated 	60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high	not activated 	60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill	not activated 	60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent	not activated 	60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer	not activated 	60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off	not activated 	60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high	not activated 	60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill	not activated 	60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	not activated 	60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated 	60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated 	60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	not activated 	60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated 	60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated 	60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated 	60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated 	60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated 	60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated 	60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated 	60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated 	60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated 	60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated 	60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated 	60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated 	60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated 	60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated 	60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated 	60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated 	60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated 	60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated 	60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated 	60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated 	60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated 	60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated 	60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated 	60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated 	60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated 	60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated 	60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated 	60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated 	60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated 	60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated 	60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated 	60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated 	60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated 	60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated 	60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	not activated 	60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated 	60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated 	60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	not activated 	60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated 	60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated 	60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated 	60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated 	60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated 	60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated 	60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated 	60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated 	60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated 	60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated 	60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated 	60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated 	60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated 	60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated 	60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated 	60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated 	60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated 	60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated 	60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated 	60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated 	60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated 	60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated 	60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated 	60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated 	60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated 	60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated 	60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated 	60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated 	60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated 	60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated 	60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated 	60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated 	60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated 	60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated 	60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated 	60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated 	60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated 	60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated 	60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated 	60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated 	60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated 	60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated 	60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated 	60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated 	60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated 	60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated 	60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated 	60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated 	60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated 	60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	not activated 	60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated 	60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated 	60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	not activated 	60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated 	60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated 	60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated 	60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated 	60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated 	60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated 	60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated 	60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated 	60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated 	60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated 	60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated 	60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated 	60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated 	60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	not activated 	60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated 	60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated 	60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	not activated 	60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated 	60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated 	60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated 	60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated 	60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated 	60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated 	60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	not activated 	60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated 	60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated 	60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	not activated 	60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated 	60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated 	60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated 	60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated 	60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated 	60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated 	60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated 	60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated 	60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated 	60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated 	60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated 	60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated 	60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated 	60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated 	60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated 	60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated 	60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated 	60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated 	60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated 	60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated 	60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated 	60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	not activated 	60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated 	60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated 	60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	not activated 	60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated 	60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated 	60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated 	60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated 	60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated 	60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated 	60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated 	60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated 	60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated 	60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated 	60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated 	60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated 	60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated 	60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated 	60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated 	60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated 	60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	not activated 	60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated 	60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated 	60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	not activated 	60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated 	60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated 	60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated 	60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated 	60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated 	60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated 	60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated 	60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated 	60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated 	60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated 	60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated 	60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated 	60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated 	60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated 	60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated 	60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated 	60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated 	60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated 	60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated 	60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated 	60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated 	60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated 	60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated 	60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated 	60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated 	60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated 	60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated 	60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated 	60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated 	60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated 	60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated 	60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated 	60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated 	60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated 	60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated 	60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated 	60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated 	60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated 	60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated 	60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated 	60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated 	60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated 	60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated 	60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated 	60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated 	60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated 	60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated 	60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated 	60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated 	60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated 	60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated 	60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated 	60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated 	60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated 	60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated 	60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated 	60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated 	60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated 	60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated 	60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated 	60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated 	60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated 	60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated 	60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated 	60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated 	60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated 	60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated 	60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated 	60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated 	60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated 	60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated 	60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated 	60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated 	60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated 	60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated 	60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated 	60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated 	60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated 	60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated 	60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated 	60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated 	60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated 	60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated 	60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated 	60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated 	60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated 	60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated 	60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated 	60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated 	60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated 	60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated 	60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated 	60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated 	60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated 	60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	not activated 	60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated 	60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated 	60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated 	60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated 	60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated 	60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated 	60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated 	60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated 	60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated 	60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated 	60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated 	60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated 	60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated 	60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated 	60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated 	60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated 	60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	not activated 	64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended 	64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated 	64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus 	64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated 	64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment 	64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated 	64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated 	64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated 	64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus 	64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	not activated 	64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15 	64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated 	64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain 	64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated 	64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment 	64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated 	64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus 	64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated 	64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus 	64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated 	64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment 	64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated 	64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus 	64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated 	64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus 	64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated 	64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus 	64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated 	64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus 	64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated 	64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated 	64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated 	64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus 	64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	not activated 	64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus 	64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	not activated 	64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated 	64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	not activated 	64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus 	64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38	not activated 	64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus	Comfort data bus 	64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated 	64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus 	64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated 	64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus 	64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated 	64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain 	64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated 	64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus 	64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	not activated 	64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended 	64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated 	64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus 	64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated 	64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment 	64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated 	64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus 	64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated 	64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated 	64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	not activated 	64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15 	64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated 	64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus 	64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated 	64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended 	64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated 	64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment 	64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated 	64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus 	64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated 	64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain 	64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated 	64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus 	64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated 	64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus 	64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated 	64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus 	64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated 	64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus 	64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated 	64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated 	64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated 	64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus 	64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated 	64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment 	64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated 	64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended 	64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated 	64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus 	64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated 	64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended 	64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated 	64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus 	64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated 	64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus 	64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated 	64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15 	64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated 	64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus 	64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated 	64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Databus Infotainment 	64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated 	64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment 	64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated 	64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus 	64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available 	8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus 	8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available 	8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment 	8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available 	8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment 	8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available 	8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain 	8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Not available 	8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus 	8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved	Not available 	8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1	Comfort data bus 	8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2	Comfort data bus 	8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3	Not available 	8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available 	8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus 	8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0	6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50	6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100	6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0	6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50	6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100	6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0	12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10	12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	50	12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	100	12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	150	12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253	12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%	12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%	12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	3%	12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	6%	12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	44%	12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%	12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency	Speed_threshold 	5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length	activated 	5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration	activated 	5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input	activated 	5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback	activated 	5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input	not activated 	5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists	not activated 	5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists	not activated 	5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps	not activated 	5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard	activated 	5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad	not activated 	5
ENG117809-p_damping_Display	5 ms	1
ENG117808-p_HMI_Display	13%	1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0	2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0	2
Elapsed Time: 00:26
blockmap-5F-5G6-035-868_3VWH17AU5JM758941-20180826-1120.CSV
;SW:5G6-035-868   HW:5G6-035-868 ---  Information Electr.
;Component:MU-E--ER      671 8395	 Coding:02731200FF00000041220001001000009F0008D40000010000
;EV_MUEnt4CGen2LGE	1041	EV_MUEnt4CGen2LGE_VW12.rod
;Sunday	26	August	2018	11:20:49:04045
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 70BADAA93A23EF57612-8024
Group	Description	Actual
IDE00019	Voltage terminal 30	14.4	 V
IDE00020	Terminal 15 status	On
IDE00021	Engine speed	0	 /min
IDE00075	Vehicle speed	0	 km/h
IDE00323	Security Access: Number of invalid keys	0
IDE00655-MAS01424	Temperature of processor circuit board-max.value	85	 °C
IDE00655-MAS01425	Temperature of processor circuit board-min.value	-13	 °C
IDE00655-MAS02238	Temperature of processor circuit board-Current	45	 °C
IDE00668-MAS03231	Microphone current consumption-Microphone 1	5.9	 mA
IDE00668-MAS03232	Microphone current consumption-Microphone 2	25.5	 mA
IDE00767	No. of unscheduled ECU resets	0	 counts
IDE00916-IDE02127	Speaker status-Left front speaker	OK
IDE00916-IDE02128	Speaker status-Right front speaker	OK
IDE00916-IDE02129	Speaker status-Left rear speaker	OK
IDE00916-IDE02130	Speaker status-Right rear speaker	OK
IDE00916-ENG117413	Speaker status-loudspeaker_channel_10	Measured value not available
IDE00916-ENG117414	Speaker status-loudspeaker_channel_11	Measured value not available
IDE00916-ENG117415	Speaker status-loudspeaker_channel_12	Measured value not available
IDE00916-ENG117416	Speaker status-loudspeaker_channel_13	Measured value not available
IDE00916-ENG117417	Speaker status-loudspeaker_channel_14	Measured value not available
IDE00916-ENG117418	Speaker status-loudspeaker_channel_15	Measured value not available
IDE00916-ENG117419	Speaker status-loudspeaker_channel_16	Measured value not available
IDE00916-ENG117408	Speaker status-loudspeaker_channel_5	Measured value not available
IDE00916-ENG117409	Speaker status-loudspeaker_channel_6	Measured value not available
IDE00916-ENG117410	Speaker status-loudspeaker_channel_7	Measured value not available
IDE00916-ENG117411	Speaker status-loudspeaker_channel_8	Measured value not available
IDE00916-ENG117412	Speaker status-loudspeaker_channel_9	Measured value not available
IDE01285-ENG101364	Counter of component protection malfunctions-Theft Protection Error Counter	00 00
IDE01351	Terminal 75 status	On
IDE01442-MAS06123	Pressing a button-Eject button	Not available
IDE01698-MAS07206	Status audio signal outputs-Audio signal output channel 1	Measured value not available
IDE01698-MAS07207	Status audio signal outputs-Audio signal output channel 2	Measured value not available
IDE01698-MAS07208	Status audio signal outputs-Audio signal output channel 3	Measured value not available
IDE01698-MAS07209	Status audio signal outputs-Audio signal output channel 4	Measured value not available
IDE01700-MAS01763	Status of tuner for digital radio (DAB)-Signal Strength	255	 dBµV
IDE01700-MAS01765	Status of tuner for digital radio (DAB)-Audio Signal	Not available
IDE01700-MAS02572	Status of tuner for digital radio (DAB)-Mute	not activated
IDE01700-MAS02949	Status of tuner for digital radio (DAB)-Frequency	0	 kHz
IDE01700-MAS03786	Status of tuner for digital radio (DAB)-Audio Codec	Not available
IDE01700-ENG117350	Status of tuner for digital radio (DAB)-Audio_Mode	0
IDE01700-ENG117354	Status of tuner for digital radio (DAB)-Audio_Quality	0
IDE01700-ENG117330	Status of tuner for digital radio (DAB)-availability_traffic_data_TMC	Not available
IDE01700-ENG117329	Status of tuner for digital radio (DAB)-availability_traffic_data_TP	Not available
IDE01700-ENG117348	Status of tuner for digital radio (DAB)-Bit_Rate	65535	 kbps
IDE01700-ENG117346	Status of tuner for digital radio (DAB)-Charset	0
IDE01700-ENG117327	Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_FIC	16.777215
IDE01700-ENG117326	Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_MSC	16.777215
IDE01700-ENG117328	Status of tuner for digital radio (DAB)-DAB_Bit_Error_Rate_NET	16.777215
IDE01700-ENG117340	Status of tuner for digital radio (DAB)-Data_Service_Identifier	00 00 00 00
IDE01700-ENG117341	Status of tuner for digital radio (DAB)-Data_Service_Label
IDE01700-ENG117345	Status of tuner for digital radio (DAB)-Data_Service_Label_Mask	00 00
IDE01700-ENG117331	Status of tuner for digital radio (DAB)-Ensemble_ID	00 00 00 00
IDE01700-ENG117332	Status of tuner for digital radio (DAB)-Ensemble_Label
IDE01700-ENG117333	Status of tuner for digital radio (DAB)-Ensemble_Label_Mask	00 00
IDE01700-ENG117334	Status of tuner for digital radio (DAB)-Extended_Country_Code	0
IDE01700-ENG117342	Status of tuner for digital radio (DAB)-Label_Masks	00 00
IDE01700-ENG117335	Status of tuner for digital radio (DAB)-Program_Service_Identifier	00 00 00 00
IDE01700-ENG117351	Status of tuner for digital radio (DAB)-Protection_Level	Not available
IDE01700-ENG117349	Status of tuner for digital radio (DAB)-Sample_Rate	65535	 kHz
IDE01700-ENG117336	Status of tuner for digital radio (DAB)-Service_Component_Identifier	0
IDE01700-ENG117338	Status of tuner for digital radio (DAB)-Service_Label
IDE01700-ENG117343	Status of tuner for digital radio (DAB)-Service_Label_Mask	00 00
IDE01700-ENG117325	Status of tuner for digital radio (DAB)-signal_quality	0
IDE01700-ENG117337	Status of tuner for digital radio (DAB)-Sub_Channel_Identifier	0
IDE01700-ENG117339	Status of tuner for digital radio (DAB)-Sub_Service_Label
IDE01700-ENG117344	Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask	00 00
IDE01700-ENG117353	Status of tuner for digital radio (DAB)-SYNC/OFDM_Lock	not activated
IDE01700-ENG117352	Status of tuner for digital radio (DAB)-Transmission_Mode	0
IDE01715	Status terminal S	On
IDE01716	Terminal 50 status	OFF
IDE01767-MAS00940	Status of telephone-Antenna diagnostic	Not available
IDE01767-MAS00941	Status of telephone-Telephone baseplate diagnostic	not connected
IDE01767-MAS00955	Status of telephone-Handset in handset holder (cradle)	not selected
IDE01767-MAS01806	Status of telephone-Handset holder (cradle)	not connected
IDE01768-MAS01808	Status of antenna 1 for radio-Antenna current	63	 mA
IDE01768-MAS03938	Status of antenna 1 for radio-Connection between radio and antenna amplifier	Electrical OK
IDE01768-MAS03939	Status of antenna 1 for radio-Connection between antenna amplifier and antenna	Electrical OK
IDE01768-MAS03991	Status of antenna 1 for radio-Reception level antenna 1	41	 dBµV
IDE01769-MAS01808	Status of antenna 2 for radio-Antenna current	48	 mA
IDE01769-MAS03938	Status of antenna 2 for radio-Connection between radio and antenna amplifier	Electrical OK
IDE01769-MAS03939	Status of antenna 2 for radio-Connection between antenna amplifier and antenna	Electrical OK
IDE01769-MAS04344	Status of antenna 2 for radio-Reception level antenna 2	37	 dBµV
IDE01771-MAS01808	Status of digital radio antenna 1-Antenna current	0	 mA
IDE01771-MAS03938	Status of digital radio antenna 1-Connection between radio and antenna amplifier	Electrical OK
IDE01771-MAS03939	Status of digital radio antenna 1-Connection between antenna amplifier and antenna	Electrical OK
IDE01771-ENG117327	Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC	1.068326
IDE01771-ENG117326	Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC	1.068323
IDE02070-IDE02060	Wake-up cause-Eject optical medium\ (CD/DVD Eject)	No
IDE02070-IDE04544	Wake-up cause-Media type in optical drive	No
IDE02070-MAS03177	Wake-up cause-Databus Infotainment	Yes
IDE02070-MAS03180	Wake-up cause-Local data bus	No
IDE02070-MAS03690	Wake-up cause-Telephone	No
IDE02070-MAS03782	Wake-up cause-WLAN	No
IDE02070-MAS03833	Wake-up cause-Optical data bus	No
IDE02486	Data logger triggering	not active
IDE02508-MAS00951	Bluetooth: Visibility-Bluetooth	On
IDE02508-MAS03001	Bluetooth: Visibility-Mode	Bluetooth available
IDE04312-MAS00109	System run time-Hours	0	 H
IDE04312-MAS00110	System run time-Minutes	10	 min
IDE04317-MAS00108	Total system run time-Day	0	 d
IDE04317-MAS00109	Total system run time-Hours	11	 H
IDE04317-MAS00110	Total system run time-Minutes	33	 min
IDE04329-IDE04332	Status of all SWaP functions-Release code for a SWaP function	Available
IDE04329-IDE05814	Status of all SWaP functions-Individualization characteristic	valid
IDE04329-IDE06260	Status of all SWaP functions-ID number	00 06 03 00
IDE04329-MAS01340	Status of all SWaP functions-Functions	Available
IDE04329-MAS01903	Status of all SWaP functions-Configuration	OK
IDE04329-MAS02934	Status of all SWaP functions-Prerequisites met	Condition met
IDE04329-MAS05616	Status of all SWaP functions-Cancellation	No
IDE04329-MAS05617	Status of all SWaP functions-Authentication	valid
IDE04332	Release code for a SWaP function	Not available
IDE04334-MAS02643	Public key for SWaP function-Key	B4 CF 3F 44 7C B9 D4 C5 21 6D 4A 2F 2B 1A 20 5F E9 9E 80 90 EB BF 1C 29 EE 40 C2 C8 9F 54 41 7E 1E E2 AD 0C 42 E2 28 A7 7E 20 1F BB D8 61 70 21 DC 61 A6 00 5A 15 05 EA E6 24 85 A8 45 50 4E B8 AA FC F5 AC 93 02 8F 27 89 14 26 07 6B 49 3A BD F4 94 57 E7 44 E8 60 61 A2 76 5D 68 5B C3 9D 13 ED 44 00 C6 23 F0 F3 B9 B4 43 83 70 41 06 49 EF EE B9 94 98 C4 95 7D 6E 51 AF 23 15 D8 67 45 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
IDE04541-MAS03621	Status of active media source at output 1-Video codec	--------------------
IDE04541-MAS03622	Status of active media source at output 1-Horizontal video resolution	65535
IDE04541-MAS03623	Status of active media source at output 1-Vertical video resolution	65535
IDE04541-MAS03778	Status of active media source at output 1-Active media source	Not available
IDE04541-MAS03783	Status of active media source at output 1-Video Bitrate	65535	 kbps
IDE04541-MAS03784	Status of active media source at output 1-Audio Bitrate	Not available
IDE04541-MAS03785	Status of active media source at output 1-Digital rights management (DRM)	Not available
IDE04541-MAS03786	Status of active media source at output 1-Audio Codec	--------------------
IDE04541-MAS03787	Status of active media source at output 1-Image format	--------------------
IDE04541-MAS03788	Status of active media source at output 1-Horizontal image resolution	65535
IDE04541-MAS03789	Status of active media source at output 1-Vertical image resolution	65535
IDE04541-MAS03793	Status of active media source at output 1-Color depth	65535	 bit
IDE04547	Traffic information	OFF
IDE04639-IDE02060	Last wake-up cause-Eject optical medium\ (CD/DVD Eject)	No
IDE04639-IDE04544	Last wake-up cause-Media type in optical drive	No
IDE04639-MAS03177	Last wake-up cause-Databus Infotainment	Yes
IDE04639-MAS03180	Last wake-up cause-Local data bus	No
IDE04639-MAS03690	Last wake-up cause-Telephone	No
IDE04639-MAS03782	Last wake-up cause-WLAN	No
IDE04639-MAS03833	Last wake-up cause-Optical data bus	No
IDE04640	Over-temperature protection for amplifier	no restriction
IDE04641	Speed-dependent volume adjustment	0	 dB
IDE04749-ENG117444	Mute-am_fm_tuner	No
IDE04749-ENG117443	Mute-audiomanager	No
IDE04749-ENG117447	Mute-component_protection	No
IDE04749-ENG117445	Mute-dab_sdars_tuner	No
IDE04749-ENG117446	Mute-drm_hd_tuner	No
IDE04749-ENG113342	Mute-Hardware	No
IDE04767-MAS01240	Update software via medium-Programming status	not active
IDE04767-MAS02111	Update software via medium-Data consistency	valid
IDE04767-MAS02112	Update software via medium-Programmability	no request
IDE04768	Bluetooth device address	48 F0 7B 1C 9B 96
IDE05040-MAS01632	Video input status-Status	Not available
IDE05040-MAS04390	Video input status-Active source	Not available
IDE05597-IDE03615	Bluetooth: Paired device 1-Version	N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ
IDE05597-IDE04768	Bluetooth: Paired device 1-Bluetooth device address	40 4E 36 B8 AD 9F
IDE05597-MAS01483	Bluetooth: Paired device 1-Softwareversion	N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ
IDE05597-MAS02159	Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP)	40 4E
IDE05597-MAS02160	Bluetooth: Paired device 1-Hands free profile (HFP)	40 4E
IDE05597-MAS03159	Bluetooth: Paired device 1-Manufacturer	N6¸*Ÿ Pixel 2
     ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿ
IDE05597-MAS04326	Bluetooth: Paired device 1-Device name	Pixel 2
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05597-ENG117431	Bluetooth: Paired device 1-A2DP	40 4E
IDE05597-ENG117440	Bluetooth: Paired device 1-ACTIVESYNCML	40 4E
IDE05597-ENG105233	Bluetooth: Paired device 1-AT	40 4E
IDE05597-ENG117432	Bluetooth: Paired device 1-AVRCP	40 4E
IDE05597-ENG117434	Bluetooth: Paired device 1-DUN	40 4E
IDE05597-ENG106692	Bluetooth: Paired device 1-FTP	40 4E
IDE05597-ENG117435	Bluetooth: Paired device 1-HIDP	40 4E
IDE05597-ENG117429	Bluetooth: Paired device 1-HSP	40 4E
IDE05597-ENG117437	Bluetooth: Paired device 1-IRMC	40 4E
IDE05597-ENG101499	Bluetooth: Paired device 1-map	40 4E
IDE05597-ENG117436	Bluetooth: Paired device 1-OBEX	40 4E
IDE05597-ENG117439	Bluetooth: Paired device 1-OPP	40 4E
IDE05597-ENG117433	Bluetooth: Paired device 1-PAN	40 4E
IDE05597-ENG108174	Bluetooth: Paired device 1-PBAP	40 4E
IDE05597-ENG117427	Bluetooth: Paired device 1-SDAP	40 4E
IDE05597-ENG117428	Bluetooth: Paired device 1-SPP	40 4E
IDE05597-ENG117438	Bluetooth: Paired device 1-SYNCML	40 4E
IDE05598-IDE03615	Bluetooth: Paired device 2-Version	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-IDE04768	Bluetooth: Paired device 2-Bluetooth device address	FF FF FF FF FF FF
IDE05598-MAS01483	Bluetooth: Paired device 2-Softwareversion	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-MAS02159	Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP)	FF FF
IDE05598-MAS02160	Bluetooth: Paired device 2-Hands free profile (HFP)	FF FF
IDE05598-MAS03159	Bluetooth: Paired device 2-Manufacturer	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05598-MAS04326	Bluetooth: Paired device 2-Device name	--
IDE05598-ENG117431	Bluetooth: Paired device 2-A2DP	FF FF
IDE05598-ENG117440	Bluetooth: Paired device 2-ACTIVESYNCML	FF FF
IDE05598-ENG105233	Bluetooth: Paired device 2-AT	FF FF
IDE05598-ENG117432	Bluetooth: Paired device 2-AVRCP	FF FF
IDE05598-ENG117434	Bluetooth: Paired device 2-DUN	FF FF
IDE05598-ENG106692	Bluetooth: Paired device 2-FTP	FF FF
IDE05598-ENG117435	Bluetooth: Paired device 2-HIDP	FF FF
IDE05598-ENG117429	Bluetooth: Paired device 2-HSP	FF FF
IDE05598-ENG117437	Bluetooth: Paired device 2-IRMC	FF FF
IDE05598-ENG101499	Bluetooth: Paired device 2-map	FF FF
IDE05598-ENG117436	Bluetooth: Paired device 2-OBEX	FF FF
IDE05598-ENG117439	Bluetooth: Paired device 2-OPP	FF FF
IDE05598-ENG117433	Bluetooth: Paired device 2-PAN	FF FF
IDE05598-ENG108174	Bluetooth: Paired device 2-PBAP	FF FF
IDE05598-ENG117427	Bluetooth: Paired device 2-SDAP	FF FF
IDE05598-ENG117428	Bluetooth: Paired device 2-SPP	FF FF
IDE05598-ENG117438	Bluetooth: Paired device 2-SYNCML	FF FF
IDE05599-IDE03615	Bluetooth: Paired device 3-Version	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05599-IDE04768	Bluetooth: Paired device 3-Bluetooth device address	FF FF FF FF FF FF
IDE05599-MAS01483	Bluetooth: Paired device 3-Softwareversion	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05599-MAS02159	Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP)	FF FF
IDE05599-MAS02160	Bluetooth: Paired device 3-Hands free profile (HFP)	FF FF
IDE05599-MAS03159	Bluetooth: Paired device 3-Manufacturer	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05599-MAS04326	Bluetooth: Paired device 3-Device name	--
IDE05599-ENG117431	Bluetooth: Paired device 3-A2DP	FF FF
IDE05599-ENG117440	Bluetooth: Paired device 3-ACTIVESYNCML	FF FF
IDE05599-ENG105233	Bluetooth: Paired device 3-AT	FF FF
IDE05599-ENG117432	Bluetooth: Paired device 3-AVRCP	FF FF
IDE05599-ENG117434	Bluetooth: Paired device 3-DUN	FF FF
IDE05599-ENG106692	Bluetooth: Paired device 3-FTP	FF FF
IDE05599-ENG117435	Bluetooth: Paired device 3-HIDP	FF FF
IDE05599-ENG117429	Bluetooth: Paired device 3-HSP	FF FF
IDE05599-ENG117437	Bluetooth: Paired device 3-IRMC	FF FF
IDE05599-ENG101499	Bluetooth: Paired device 3-map	FF FF
IDE05599-ENG117436	Bluetooth: Paired device 3-OBEX	FF FF
IDE05599-ENG117439	Bluetooth: Paired device 3-OPP	FF FF
IDE05599-ENG117433	Bluetooth: Paired device 3-PAN	FF FF
IDE05599-ENG108174	Bluetooth: Paired device 3-PBAP	FF FF
IDE05599-ENG117427	Bluetooth: Paired device 3-SDAP	FF FF
IDE05599-ENG117428	Bluetooth: Paired device 3-SPP	FF FF
IDE05599-ENG117438	Bluetooth: Paired device 3-SYNCML	FF FF
IDE05600-IDE03615	Bluetooth: Paired device 4-Version	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05600-IDE04768	Bluetooth: Paired device 4-Bluetooth device address	FF FF FF FF FF FF
IDE05600-MAS01483	Bluetooth: Paired device 4-Softwareversion	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05600-MAS02159	Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP)	FF FF
IDE05600-MAS02160	Bluetooth: Paired device 4-Hands free profile (HFP)	FF FF
IDE05600-MAS03159	Bluetooth: Paired device 4-Manufacturer	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05600-MAS04326	Bluetooth: Paired device 4-Device name	--
IDE05600-ENG117431	Bluetooth: Paired device 4-A2DP	FF FF
IDE05600-ENG117440	Bluetooth: Paired device 4-ACTIVESYNCML	FF FF
IDE05600-ENG105233	Bluetooth: Paired device 4-AT	FF FF
IDE05600-ENG117432	Bluetooth: Paired device 4-AVRCP	FF FF
IDE05600-ENG117434	Bluetooth: Paired device 4-DUN	FF FF
IDE05600-ENG106692	Bluetooth: Paired device 4-FTP	FF FF
IDE05600-ENG117435	Bluetooth: Paired device 4-HIDP	FF FF
IDE05600-ENG117429	Bluetooth: Paired device 4-HSP	FF FF
IDE05600-ENG117437	Bluetooth: Paired device 4-IRMC	FF FF
IDE05600-ENG101499	Bluetooth: Paired device 4-map	FF FF
IDE05600-ENG117436	Bluetooth: Paired device 4-OBEX	FF FF
IDE05600-ENG117439	Bluetooth: Paired device 4-OPP	FF FF
IDE05600-ENG117433	Bluetooth: Paired device 4-PAN	FF FF
IDE05600-ENG108174	Bluetooth: Paired device 4-PBAP	FF FF
IDE05600-ENG117427	Bluetooth: Paired device 4-SDAP	FF FF
IDE05600-ENG117428	Bluetooth: Paired device 4-SPP	FF FF
IDE05600-ENG117438	Bluetooth: Paired device 4-SYNCML	FF FF
IDE05601-IDE03615	Bluetooth: Paired device 5-Version	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05601-IDE04768	Bluetooth: Paired device 5-Bluetooth device address	FF FF FF FF FF FF
IDE05601-MAS01483	Bluetooth: Paired device 5-Softwareversion	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05601-MAS02159	Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP)	FF FF
IDE05601-MAS02160	Bluetooth: Paired device 5-Hands free profile (HFP)	FF FF
IDE05601-MAS03159	Bluetooth: Paired device 5-Manufacturer	ÿÿÿÿÿ--------ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
IDE05601-MAS04326	Bluetooth: Paired device 5-Device name	--
IDE05601-ENG117431	Bluetooth: Paired device 5-A2DP	FF FF
IDE05601-ENG117440	Bluetooth: Paired device 5-ACTIVESYNCML	FF FF
IDE05601-ENG105233	Bluetooth: Paired device 5-AT	FF FF
IDE05601-ENG117432	Bluetooth: Paired device 5-AVRCP	FF FF
IDE05601-ENG117434	Bluetooth: Paired device 5-DUN	FF FF
IDE05601-ENG106692	Bluetooth: Paired device 5-FTP	FF FF
IDE05601-ENG117435	Bluetooth: Paired device 5-HIDP	FF FF
IDE05601-ENG117429	Bluetooth: Paired device 5-HSP	FF FF
IDE05601-ENG117437	Bluetooth: Paired device 5-IRMC	FF FF
IDE05601-ENG101499	Bluetooth: Paired device 5-map	FF FF
IDE05601-ENG117436	Bluetooth: Paired device 5-OBEX	FF FF
IDE05601-ENG117439	Bluetooth: Paired device 5-OPP	FF FF
IDE05601-ENG117433	Bluetooth: Paired device 5-PAN	FF FF
IDE05601-ENG108174	Bluetooth: Paired device 5-PBAP	FF FF
IDE05601-ENG117427	Bluetooth: Paired device 5-SDAP	FF FF
IDE05601-ENG117428	Bluetooth: Paired device 5-SPP	FF FF
IDE05601-ENG117438	Bluetooth: Paired device 5-SYNCML	FF FF
IDE05602-MAS01763	Bluetooth: connected device 1-Signal Strength	-69
IDE05602-MAS04326	Bluetooth: connected device 1-Device name	2.2634E+16
IDE05603-MAS01763	Bluetooth: connected device 2-Signal Strength	Not available
IDE05603-MAS04326	Bluetooth: connected device 2-Device name	0
IDE05604-MAS01763	Bluetooth: connected device 3-Signal Strength	Not available
IDE05604-MAS04326	Bluetooth: connected device 3-Device name	0
IDE05605-MAS01763	Bluetooth: connected device 4-Signal Strength	Not available
IDE05605-MAS04326	Bluetooth: connected device 4-Device name	0
IDE05606-MAS01763	Bluetooth: connected device 5-Signal Strength	Not available
IDE05606-MAS04326	Bluetooth: connected device 5-Device name	0
IDE05700-MAS01456	USB connection-Speed	Not available
IDE05700-MAS01632	USB connection-Status	Not available
IDE05700-MAS03159	USB connection-Manufacturer	FF FF
IDE05700-MAS04393	USB connection-USB device class	FF
IDE05700-MAS04394	USB connection-Connection status	not connected
IDE05700-MAS04436	USB connection-USB device sub-class	FF
IDE05700-ENG111957	USB connection-usb_product_id	FF FF
IDE05700-ENG111955	USB connection-usb_protocol	FF
IDE05713-MAS01632	Network diagnosis-Status	Enabled
IDE05725	Terminal 58xs dimmer	0	 %
IDE05726	Terminal 58xd dimmer	99.94	 %
IDE05814	Individualization characteristic	89 5E 9A 22 17
IDE06028-MAS02317	Control head button operation-Button code 1	FF
IDE06028-MAS02318	Control head button operation-Button code 2	FF
IDE06028-MAS04151	Control head button operation-Joystick	FF
IDE06028-MAS04413	Control head button operation-Push-and rotary knob for selection	0
IDE06028-MAS04414	Control head button operation-Volume control	0
IDE06425	Roller test bench mode: functional	not activated
IDE06516-MAS01424	Temperature: optical drive-max.value	205	 °C
IDE06516-MAS01425	Temperature: optical drive-min.value	205	 °C
IDE06516-MAS02238	Temperature: optical drive-Current	205	 °C
IDE06517-MAS01424	Temperature: audio amplifier-max.value	85	 °C
IDE06517-MAS01425	Temperature: audio amplifier-min.value	-13	 °C
IDE06517-MAS02238	Temperature: audio amplifier-Current	42	 °C
IDE06521-MAS01424	Temperature of MMX PC boards-max.value	205	 °C
IDE06521-MAS01425	Temperature of MMX PC boards-min.value	205	 °C
IDE06521-MAS02238	Temperature of MMX PC boards-Current	205	 °C
IDE07589-IDE07590	Update programming: status-Currently processed module	0
IDE07589-IDE07591	Update programming: status-Number of modules to be programmed	0
IDE07589-MAS01632	Update programming: status-Status	not active
IDE07589-MAS10948	Update programming: status-control	Diagnosis
IDE07938	Cause of system start	Data bus
IDE07939	Last cause of system start	Data bus
IDE10478-MAS01632	Interface for external media: status-Status	OK
IDE10479-MAS01482	Interface for external media: identification-Hardwareversion	---
IDE10479-MAS01483	Interface for external media: identification-Softwareversion	----
IDE10479-MAS04970	Interface for external media: identification-Part Number	-----------
IDE10843-MAS01482	Function module: identification-Hardwareversion	100
IDE10843-MAS04326	Function module: identification-Device name	MU
IDE10843-MAS11354	Function module: identification-Bootloader version	8395
IDE10843-MAS11355	Function module: identification-Application version	8395
IDE10843-MAS11356	Function module: identification-Module Name	CPU
IDE10857-MAS02476	Touchless loading of mobile phone: status-install	Not available
IDE10857-MAS11500	Touchless loading of mobile phone: status-Foreign object	No
IDE10857-MAS11501	Touchless loading of mobile phone: status-charge	No
IDE11127-IDE04332	Error-causing FS ID with status-Release code for a SWaP function	Not available
IDE11127-IDE05814	Error-causing FS ID with status-Individualization characteristic	invalid
IDE11127-IDE06260	Error-causing FS ID with status-ID number	00 00 00 00
IDE11127-MAS01340	Error-causing FS ID with status-Functions	Not available
IDE11127-MAS01903	Error-causing FS ID with status-Configuration	not OK
IDE11127-MAS02934	Error-causing FS ID with status-Prerequisites met	Condition not met
IDE11127-MAS05616	Error-causing FS ID with status-Cancellation	Yes
IDE11127-MAS05617	Error-causing FS ID with status-Authentication	Condition not met
IDE12277-MAS01632	External optical drive (USB): status-Status	Measured value not available
IDE12420-MAS01482	iPod chip: identification-Hardwareversion	1
IDE12420-MAS01483	iPod chip: identification-Softwareversion	3
IDE12420-MAS02832	iPod chip: identification-Malfunction status	0
MAS00464-MAS00106	Standard - ambient data 1-Year	2018
MAS00464-MAS00107	Standard - ambient data 1-Month	8
MAS00464-MAS00108	Standard - ambient data 1-Day	26
MAS00464-MAS00109	Standard - ambient data 1-Hours	11
MAS00464-MAS00110	Standard - ambient data 1-Minutes	20
MAS00464-MAS00111	Standard - ambient data 1-Seconds	42
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	28
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	138	 km
MAS00481-ENG117777	BAP-BAP_Function_ID	0
MAS00951-IDE04058	Bluetooth-Bluetooth: devices found	0
MAS00951-MAS04324	Bluetooth-Bluetooth: connected devices	1
MAS00951-MAS04325	Bluetooth-Bluetooth: Paired devices	1
MAS01760-MAS01765	Radio Tuner 1-Audio Signal	Analog
MAS01760-MAS02949	Radio Tuner 1-Frequency	91.3	 MHz
MAS01760-MAS03991	Radio Tuner 1-Reception level antenna 1	41	 dBµV
MAS01760-MAS04344	Radio Tuner 1-Reception level antenna 2	24	 dBµV
MAS01760-MAS04345	Radio Tuner 1-Frequency (AM)	1310	 kHz
MAS01760-ENG117356	Radio Tuner 1-iboc_audio_signal	Not available
MAS01760-ENG117358	Radio Tuner 1-iboc_count	0
MAS01760-ENG117355	Radio Tuner 1-iboc_error_rate	255
MAS01760-ENG117357	Radio Tuner 1-iboc_service	no tuned IBOC Audio Service
MAS01991-IDE00010	Card reader-Serial number	FF FF FF FF
MAS01991-IDE01001	Card reader-Application	--
MAS01991-MAS01632	Card reader-Status	not connected
MAS01991-MAS03159	Card reader-Manufacturer	FF
MAS01991-MAS03375	Card reader-Major version	15
MAS01991-MAS03376	Card reader-Minor version	15
MAS01991-MAS03959	Card reader-Write-protection	Not available
MAS01991-MAS04388	Card reader-Card type	-----
MAS01991-MAS13476	Card reader-Manufacturing date: month	15	 mon
MAS01991-MAS13477	Card reader-Manufacturing date: year	2255	 yr
MAS04324-MAS04326	Bluetooth: connected devices-Device name	2.2634E+16
MAS04324-MAS04327	Bluetooth: connected devices-Bluetooth connection profile	Hands free profile (HFP)
MAS04325-MAS04326	Bluetooth: Paired devices-Device name	9.32839E+14
MAS04325-MAS04327	Bluetooth: Paired devices-Bluetooth connection profile	Hands free profile (HFP)
ENG117872-ENG117778	Byte_Coding_Condition-byte_0_condition	OK
ENG117872-ENG117779	Byte_Coding_Condition-byte_1_condition	OK
ENG117872-ENG117788	Byte_Coding_Condition-byte_10_condition	OK
ENG117872-ENG117789	Byte_Coding_Condition-byte_11_condition	OK
ENG117872-ENG117790	Byte_Coding_Condition-byte_12_condition	OK
ENG117872-ENG117791	Byte_Coding_Condition-byte_13_condition	OK
ENG117872-ENG117792	Byte_Coding_Condition-byte_14_condition	OK
ENG117872-ENG117793	Byte_Coding_Condition-byte_15_condition	OK
ENG117872-ENG117794	Byte_Coding_Condition-byte_16_condition	OK
ENG117872-ENG117795	Byte_Coding_Condition-byte_17_condition	OK
ENG117872-ENG117796	Byte_Coding_Condition-byte_18_condition	OK
ENG117872-ENG117797	Byte_Coding_Condition-byte_19_condition	OK
ENG117872-ENG117780	Byte_Coding_Condition-byte_2_condition	OK
ENG117872-ENG117798	Byte_Coding_Condition-byte_20_condition	OK
ENG117872-ENG117799	Byte_Coding_Condition-byte_21_condition	OK
ENG117872-ENG117800	Byte_Coding_Condition-byte_22_condition	OK
ENG117872-ENG117801	Byte_Coding_Condition-byte_23_condition	OK
ENG117872-ENG117802	Byte_Coding_Condition-byte_24_condition	OK
ENG117872-ENG117803	Byte_Coding_Condition-byte_25_condition	dont care
ENG117872-ENG117804	Byte_Coding_Condition-byte_26_condition	dont care
ENG117872-ENG117805	Byte_Coding_Condition-byte_27_condition	dont care
ENG117872-ENG117781	Byte_Coding_Condition-byte_3_condition	OK
ENG117872-ENG117782	Byte_Coding_Condition-byte_4_condition	OK
ENG117872-ENG117783	Byte_Coding_Condition-byte_5_condition	OK
ENG117872-ENG117784	Byte_Coding_Condition-byte_6_condition	OK
ENG117872-ENG117785	Byte_Coding_Condition-byte_7_condition	OK
ENG117872-ENG117786	Byte_Coding_Condition-byte_8_condition	OK
ENG117872-ENG117787	Byte_Coding_Condition-byte_9_condition	OK
ENG117866-ENG117457	DAB_FM_linking-dab_mute_status	Mute
ENG117866-ENG117456	DAB_FM_linking-DAB_quality	0	 %
ENG117866-ENG117455	DAB_FM_linking-fm_quality	0	 %
ENG117866-ENG117458	DAB_FM_linking-service_linking_status	no_link
ENG117857-MAS00109	Last_System_Operating_Time-Hours	0	 H
ENG117857-MAS00110	Last_System_Operating_Time-Minutes	1	 min
ENG117856-MAS00106	Last_System_Operating_Time/Mins.-Year	0	 yr
ENG117856-MAS00107	Last_System_Operating_Time/Mins.-Month	0	 mon
ENG117856-MAS00108	Last_System_Operating_Time/Mins.-Day	0	 d
ENG117856-MAS00109	Last_System_Operating_Time/Mins.-Hours	0	 H
ENG117856-MAS00110	Last_System_Operating_Time/Mins.-Minutes	0	 min
ENG117856-MAS00111	Last_System_Operating_Time/Mins.-Seconds	0	 s
ENG117864-MAS01632	Status_Position_Touchscreen_1-Status	not activated
ENG117864-ENG117402	Status_Position_Touchscreen_1-calibrate_delta_x	65535
ENG117864-ENG117403	Status_Position_Touchscreen_1-calibrate_delta_y	65535
ENG117864-ENG117396	Status_Position_Touchscreen_1-position_x1	0
ENG117864-ENG117397	Status_Position_Touchscreen_1-position_x2	65535
ENG117864-ENG117398	Status_Position_Touchscreen_1-position_x3	65535
ENG117864-ENG117399	Status_Position_Touchscreen_1-position_y1	0
ENG117864-ENG117400	Status_Position_Touchscreen_1-position_y2	65535
ENG117864-ENG117401	Status_Position_Touchscreen_1-position_y3	65535
Elapsed Time: 00:17
Chassis Type: AU-VW37 (3Q0)
AutoScan.txt doesn't list 3Q or Alltrack are you using your works VCDS?
Please don't confuse the Gateway Part Number and the Chassis Designation.
Veedubgti
New Member
Dana, does this car have factory installed footwell lights?
Thank you
