This 2018 left over Alltrack S is the latest addition to our family. It doesn't have much but we did get a RLS (Auto wipers/Auto headlights w/coming and leaving home) and heated (fake leather) front seats.
Original files located here: https://drive.google.com/drive/folders/1-Z71JvypNLqjodVhgRDcUQ7RRCF1gV7W?usp=sharing
Scan shortly after delivery @ Mileage: 138km-85mi:
Press kit main page: https://media.vw.com/press-kits/2018-golf-alltrack-press-kit
Sunday,26,August,2018,11:23:08:04045
VCDS Version: 18.7.2.1 (x64) HEX-V2 CB: 0.4432.4
Data version: 20180808 DS295.0
VIN: 3VWH17AU5JM758941 License Plate: 2018 ALLTRACK MAP SCAN
Mileage: 138km-85mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 5F
VIN: 3VWH17AU5JM758941 Mileage: 138km-85miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311D00122426002F0000
Shop #: WSC 00066 790 00075
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D65C71682711E7EBE-8012
Readiness: 0000 0100
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01706220029
ROD: EV_TCMDQ250021.rod
VCID: 59EC870DC9998E1FB6C-800C
Address 03: ABS Brakes (J104) Labels:| 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 52407000000109
Coding: 43FA6AA1342509748080030480C429C2562C9001C001943C00435050E009430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 005A8A690A83FFD7912-8054
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 G HW: 5GM 907 426 G
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 02020004200110000000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4CC26E59764BEBB73DA-8018
B10CD 00 [008] - -
Reset counter: 58
Mileage: 58 km
Date: 2011.10.25
Time: 06:30:10
Voltage terminal 30: 11.9 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Back-up light: OFF
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C864290917029K
Shop #: WSC 00066 790 00249
ROD: EV_BCMBOSCH_018.rod
VCID: 0B40AD4533C5AC8FF40-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170803 043 0551
Serial number: 97022066170820234314
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S7Y17M07D24H00M23S20
Coding: 00A8DD
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR08WNXP
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47C851756F2D08EF108-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007SMW28
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 000 508 17
Serial number: 3570000000099CB0A62V
Subsystem 3 - Part No SW: ----------- HW: 480 000 508 17
Serial number: 35800000000CACB0A62-
Subsystem 4 - Part No SW: ----------- HW: 480 401 209 17
Serial number: 351000199270BC657721
Subsystem 5 - Part No SW: ----------- HW: 480 401 109 17
Serial number: 3520001AB269FFC4D2D.
Subsystem 6 - Part No SW: ----------- HW: 480 400 707 17
Serial number: 3550002B324F3852D140
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 707 17
Component: FrontSensor_P 001 6149
Serial number: 3560002B124F3852108X
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 29091708490917
Coding: 0410
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 025E8061048FEDC7876-8056
Part No SW: 5G1 920 840 C HW: 5G1 920 840 C
Component: KOMBI 242 0310
Coding: 0BB4100DA180CF0502082B001000000000000000
VCID: 2708F1F5CF6DE8EFF08-8072
Part No SW: 3Q0 907 530 F HW: 3Q0 907 530 B
Component: GW MQB Mid 517 5304
Serial number: 11101700842535
Coding: 0101000830085900FB0020081E0F00000001070000000000000000000000
Shop #: WSC 00066 790 00067
ROD: EV_GatewNF_VW27.rod
VCID: 323E10A1F4AF9D47576-8066
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 26170001893500121439
Coding: 31FFFF
Serial number: HA1-00010.07.17
Coding: 0001
VCID: 4ACE68417C3FF5870F6-801E
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5037727600716
Coding: 003A03200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000007088038
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FF87955875DD0AF588-801A
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038726301305
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000007073405
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G6 035 868 HW: 5G6 035 868
Component: MU-E--ER 671 8395
Serial number: 07081700021741
Coding: 02731200FF00000041220001001000009F0008D40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 70BADAA93A23EF57612-8024
End------(Elapsed Time: 10:17, VBatt start/end: 14.4V/14.4V, Deb=2)--------
Vehicle Identification No. 3VWH17AU5JM758941 Model Golf variant 1,8
GOVDate of production 30.10.2017 Year 2018 Sales type BX6CN7 Engine Code CXBB Transmission Code SYL Axle drive 6A Equipment XW Roof color 2T Carpet color code Exterior color / Paint Code 2T / C9X
Press release info https://newspress-vwusamedia.s3.amazonaws.com/documents/original/8671-2018VolkswagenGolfAlltrackRelease.pdf
Special editions E0A No special edition Lockable wheel bolts 1PF Standard wheel bolts Vehicle class differentiation
units/platform components7II Vehicle class differentiation -5GM- tail pipe 0P1 Rear side exhaust tailpipe drive-off assistance UG1 Hill hold control Emission standard 0GT Emission standard SULEV Trailer hitch 1D0 without trailer towing airbag 4UM Airbag für Fahrer und Beifahrer (NAR)
mit Beifahrer-Airbag-Deaktivierung
(zweistufig)Aktivkohlebehälter / Ottopartikelfilter 1E7 Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fuelingTray areas package QE0 Without tray areas package/box Storage compartment 7N3 Comfort overhead storage compartment Aerials 8L6 "diversity" window antenna Exterior mirror setting 6XN Exterior mirrors, power-adjustable/
separately heatedFollow-on warranty EA0 Without subsequent warranty Left exterior mirror 5SH Left exterior mirror, flat (US) Electronic engine sound measures GM1 Standard electronic engine sound Right exterior mirror 5RR Right exterior mirror, convex (US) Alternative drive system 0K0 Without alternative drive system Drive type 1X1 Four-wheel drive "Multimedia"video/DVD/notebook connection 9WT Mirror Link Equipment levels A8T Executive equipment Area monitoring systems 6K0 Without forward collision warning/
autonomous emergency brakingBrake type in rear 1KS Disc brakes in rear (Geomet D) batteries J1L Battery 280 A (60 Ah) Brake type, front 1ZD Disc brakes in front (Geomet D) Components with special surface 6FJ Black exterior mirror housings Battery/alternator capacity NY0 Standard battery/alternator capacity Component part sets with
country-specific design requirementsB0D Assembly kit, USA corresponding vehicle
version (not California), various partsvehicle tools and jack 1S1 vehicle tools and jack Brake systems 1AT Electronic stability control (ESC) Owner's manuals 0VM Information kit in American English Operating voltage 9Z0 Operating voltage 12 V brake wear indicator 9U0 Without brake pad wear indicator Heated washer nozzles 9T1 Heated washer nozzles in front CD ROM/DVD/SD card 7QA Without CD/DVD for navigation "Charism" 2H5 Driving profile selection and
conventional shock absorberChrome package QJ1 Chrome package General operating permit, alterations C00 Operating permit, initial registration Roof rails/roof load rack 3S1 Bright roof rails Roof insert/convertible top 3FA roof without cut out Suspension system in rear UC5 Rear shock absorption Suspension system in front G25 Shock absorption in front Differential lock 1Y3 Electronic differential lock XDS,
dynamic traction supportECO function for driving profiles and
Drive selectEF0 Without ECO function Installation differentiation for components 0ES Installation differentiation for
transmission DQ250
-- vehicle components --Theft protection system 7AZ Preparation for anti-theft alarm system Inserts 5MQ Decorative inserts Scuff plates 7M5 Without protective film for scuff plate Park distance control 7X0 Without park distance control Extended safety system 7W0 Without extended safety system Electric interface for external use UI5 External, USB type A, 1x USB socket Manufacturing sequence differentiation 0FA Standard manufacturing sequence window regulator 4R4 Power windows with comfort operation and
circuit breakerfire extinguisher 6A0 without fire extinguisher Pedestrian protection VL0 Standard pedestrian protection measures Pedal cluster VF1 pedal cluster Headlight activation 9C9 Separate daytime running light and
automatic headlight control -NAR- with
Coming Home and Leaving Home featureFresh air intake for passenger
compartment (with particulate filter)2V5 Fresh air intake with activated charcoal filter Parking brake UH0 Parking brake Alternators 9G2 Alternator 100-150 A Weight category rear axle 0YK Weight range 10
installation control only, no
requirement forecastWeight category front axle L47 Suspension range 47
requirement forecastBase engine TI5 4-cylinder SI engine 1.8 l unit 06K.K Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest Luggage compartment cover 3U2 Sliding trunk cover cruise control system 8T2 Electronic cruise control system (CCS) Transmission specifications G0R 6-speed automatic transmission for
four-wheel drivehandle for hand brake lever 6PC handbrake lever grip (leather) Rear spoiler 5J0 Without rear spoiler Rear window wiper and washer system 8M1 Rear window wiper and washer system
with intermittent controlRear axle 0N4 4-link rear suspension Molded headliner 6NA Unsplit molding roof liner Rear seats 3NU Rücksitzbank ungeteilt, Lehne geteilt
umlegbar mit MittelarmlehneHeating and air-conditioning system KH6 Air conditioning system with electronic control Headlamps 8IE H7 headlamps with separate LED daytime
running lightsInterior light in footwell 6T1 Interior light in footwell Instrument clusters U5C Instrument cluster, mph speedometer
- USA -Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror,
dimmingBody style K8D Wagon/Avant Camera/distance sensor QK0 Without multifunction camera Folding table 1U8 W/o folding table on front seat backrest Climatic zones 0Y4 Cold and tropical climatic zones (US) Compass/road sign display QR8 without road sign recognition headrest for seat, rear 3Q9 Three rear head restraints Head restraints 5ZF Front head restraints Fuel quantity for initial filling 1Z0 Initial standard fuel filling Fuel systems 1A5 Fuel system for SI engine Body measures 5C1 Body measures for increased safety
requirementsCamera systems/accident sensors KA1 With rear view camera system (type 1) Radiator grille 6KG Radiator grille refrigerant KK3 Refrigerant R1234yf License plate lighting KL1 LED license plate lighting License plate carrier 31N License plate carrier in front and rear
(NAR)Paint preservative/transit coating 5K7 Transport protection film (minimum
protection) with additional transport
protection measuresPaint coating FB0 standard paint coating Rear cargo area 3GD Plane rear cargo area Light package (lighting) QQ3 Interior ambient lighting and surround
lightingVehicle inlet ES0 Without vehicle inlet Steering system arrangement L0L Left-hand drive Reading lamp 8S6 2 reading lights in front steering 1N3 Speed-related variable steering assist
(Servotronic)Backrest release 3H0 Without backrest release for front seats Light control systems 8G0 Without Light Assist Lumbar support 7P4 Manually adjustable lumbar support in
front seatssteering wheels 1XX Leather-wrapped multi-function sports
steering wheel with tiptronicDriving on the left/on the right AV2 Driving on the right (NAR) Speaker installation 8RM 8 speakers (passive) Headlight range control 8Q0 Without headlight range control Center armrest 6E3 Front center armrest Versions FM0 Basic equipment variant Multi-function display/trip computer 9S5 Multi-function display/trip computer
"Medium"center console 3D2 center console Driver alert system EM0 Without driver alert system Engine cooling 8Z6 Hot country Engine specifications D6J 4-cylinder SI engine 1.8 l/125 kW (16V)
turbo FSI, homogeneous, base engine is
TH2/TJ2/TF6/TQ6/TF5/TK5/TI5Navigation device 7Q0 without navigation system rear fog lamp 8TA witout rear fog lamp Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp Online services EL0 Without online service Rear of platform module base 4P3 Rear floor panel module, type 4 Hubcaps 1NL Trims for alloy wheels Wheels U89 Alloy wheels 7J x 17 Radios I8C . Smoker's/non-smoker's package 9JF Non-smoking package (NAR) Regional code for radio ER3 Regional code " NAR " for radio Tire pressure monitoring system 7K6 Tire pressure monitoring system tire I84 All-season tires 205/55 R17 95H xl (NAR) Tire suppliers V0A Tires without specification of tire
brandSpare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary
use, radial tire
(5-hole)Wheelbases 0B1 Wheelbase Restraint systems, front 4QQ 3-point seat belts in front with
pretensioner and height adjustment,
US labelSide airbag 4X3 Side airbag in front, with curtain
airbagGearshift knob/handle 6Q2 Gearshift knob/handle in leather Special labels/plates 0SC Labels in English Tail lamp assemblies 8SQ LED rear combination lamp Service indicator QI7 Service indicator 10 000 miles or
1 year (fix)Seat belt check 9P7 Visual and acoustic seat belt reminder,
electric contact in buckleOuter rear seat belts 3ZD 3-point seat belts, outer rear with US
labelCenter rear seat belts 3C8 3-point seat belt, center rear with US
labelseat covers N4Q Seat trim covers in leatherette Seat adjustment 3PT Manual height adjustment for front seats seat heater 4A3 Seat heater for front seats
separately controlledStart-stop system/regenerative braking 7L3 Without start/stop system without
regenerative brakingHorns 8Y1 Two-tone horn sun visors 5XX Sun visors with mirror, illuminated
(NAR)Audio-response system/voice control QH0 without voice control Lane change assist/lane keeping system 7Y0 Without lane change assist Side and rear windows 4KC Side and rear windows in heat-insulating
glasspower outlet 7B3 12-volt socket(s) Bumper 2JE Partially painted bumpers Rear stabilizer 0BF Rear stabilizer Front stabilizer bar 0AF Front stabilizer bar Drawers under front seats QN0 Without drawers under front seats Headlamp washer system 8X0 Without headlamp washer system Windshield wiper intermittent control/
light/rain sensor8N6 Windshield wiper intermittent control
with light/rain sensorNameplate set 0NW Nameplate set "TSI" Mass damper for steering wheels 1Q2 Mass damper for steering wheel, 36 Hz Door and lid locking system 4K0 Central locking w/ radio remote control
and interior controlsType approval countries/countries with
special requirementsBU2 Legal requirements for USA 2
States with CARB requirementCarrier frequency for remote control 5D2 Carrier frequency 315 MHz Partition 3CA Without partition Door and side trim panels 3LJ Door and side trim panel in foam film,
insert in leatherettedoors 0A2 4 doors TV reception/digital radio reception QV0 without TV/digital radio reception Front underbody guard 1SB Additional front underbody guard Identification plates 1EB Ohne Typschild Delivery equipment 2A8 Delivery equipment, water border First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle Two-way radio installation preparation 9D0 without prepared for two way radio system Front seats Q2J convenience seat Rear seat catch UK3 Mechanical rear seat release Telephone / telematics 9ZX Telephone preparation for cellphone Additional warning lights 9TC Additional retro-reflectors (door area) LongLife Service Regime QG1 LongLife Service Regime Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating Windshield Glass 4GF Windshield in heat-insulating glass Washer fluid level indicator 8W1 Washer fluid level indicator Additional tires (snow tires) 2WA without spare tyre floor mats 0TD Floor mats in front and rear Decorative trims 4ZN Bright decorative trims Additional child seat anchors 3B7 Child seat anchors as per Canadian
requirements a. ISOFIX child seat systemAuxiliary heating system 9M0 Without auxiliary heater/parking heater
