2007 VW Passat P0441 help
mattmc0416
C?ID=344511
First off I am very new to VW. I bought a used Passat and shortly after the engine light came on. I bought vcds and started tinkering. In doing so I have replaced the n80, gas cap, charcoal canister, and LDP. Cleared the codes and boom light comes back on after driving and sitting at idle. I am humbly asking for assistance to someone that is very new and not so smart about all this. I understand how it works and the layout of the actual system I am just completely unsure what to do next with the p0441 flow issue. Thank you so much I’m advance.
mattmc0416
C?ID=344511
Could you perhaps show an autoscan (see below) so we can see what the car is made of?
--> http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
Saturday,18,August,2018,15:19:43:27941
VIN: WVWJK73C67P007775   License Plate: 0818
Mileage: 268530km-166856mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWJK73C67P007775   Mileage: 268530km-166856miles
44-Steering Assist -- Status: Sporadic communication error 1000
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 25157 444 85672
   VCID: 303913F9162581D7C14-8064
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - MIL ON
                    Fault Status: 11100010
                    Mileage: 268329 km
                    Date: 2018.08.17
                    Time: 07:39:49
                    RPM: 828 /min
                    Load: 34.5 %
                    Temperature: 98.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
   Component: AQ 250 6F           1068
   Revision: 00H38000    Serial number:
   Coding: 0000072
   VCID: 00598339E605D157714-8054
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667540301
   Coding: 0013755
   Shop #: WSC 00028 028 00001
   VCID: 323D19F11829B3C7B70-8066
   Part No: 1K0 820 047 FP
   VCID: 77ABE8E5B3CB96EF40E-8022
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000005707043
   Coding: 10840F0340041A00470000000F00000000285D435C0000
   VCID: 372B28E5F34B56EF80E-8062
   Subsystem 1 - Part No: 3AB 955 419 A  Labels: 1KX-955-119.CLB
   Component: WWS471  071113 024  0654
   Coding: 00282069
   Shop #: WSC 00028
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0N AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P9PRS9A
   Coding: 0012366
   VCID: 2E050D810C119727D38-807A
   Subsystem 1 - Part No: 3C0 959 339 A
   Component: BF-Gewichtsens. 006 0002
   Subsystem 2 - Serial number: 0000000003AGBZ
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME11511403Uÿ†63
   Subsystem 5 - Serial number: 11403Uÿ†6342MSME11510C394ÿ†63
   Subsystem 6 - Serial number: 10C394ÿ†6351HTS6QLL6S9B24ÿ†63
   Subsystem 7 - Serial number: 6S9B24ÿ†6361HTS6OLLI19D2Xÿ†63
   Subsystem 8 - Serial number: I19D2Xÿ†63727TS6QLLEO893%ÿ†63
   Subsystem 9 - Serial number: EO893%ÿ†63827TS6SH9MERU2Nÿ
   Subsystem 10 - Serial number: MERU2Nÿ
   Part No SW: 3C0 953 549 H    HW: 3C0 953 549 H
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507R
   Coding: 0002013
   VCID: 313F16FD1D2F88DFCEA-8064
   Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 25157 444 68381
   VCID: 2313ECB557D32A4F4C6-8076
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C06513024F
   Coding: 3FFD0E04D21002
   VCID: 211FE6BD4DCF385F5EA-8074
                    Reset counter: 247
                    Mileage: 267476 km
                    Date: 2016.09.24
                    Time: 05:25:20
                    Reset counter: 9
                    Mileage: 267476 km
                    Date: 2016.09.24
                    Time: 05:25:33
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 251
                    Mileage: 267539 km
                    Date: 2017.10.03
                    Time: 00:01:03
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TQLVE05
   VCID: 6D87CA8DC1972C3FAA2-8038
   Part No SW: 3C0 959 433 AA    HW: 3C0 959 433 AA
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 25157 444 85837
   VCID: 698FBE9DF57F301FC6A-803C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Component: J386  TUER-SG FT    1123
   Revision: 12007001    Serial number: 00000552168907
   Coding: 0001205
   Shop #: WSC 25807 128 53510
   VCID: 3B2334D5CF63728F646-806E
                    Fault Status: 01101100
                    Reset counter: 239
                    Mileage: 268524 km
                    Date: 2018.08.17
                    Time: 15:08:08
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.135 H07 1806
   VCID: 34311FE9E23DBDF7A5C-8060
   Component:    KSG PQ46 RDK 051 0218
   Coding: 13910F8001862E521004141FF08A0F0E085800
   Component: J387  TUER-SG BT    1123
   Revision: 12007001    Serial number: 00000623468906
   Coding: 0001204
   VCID: 3C2137C9CA6D75B76DC-8068
   Revision:   013
   Coding: 0000013
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0016
   Revision: 00014000    Serial number: VWZ4Z7F6140399
   Coding: 0040401
   VCID: 1E65DD417CB107A7638-804A
   Component: J388   TUER-SG HL   1110
   Revision: 12004001    Serial number: 00000000112564
   Coding: 0001168
   VCID: 3E253DC1DC7167A7438-806A
   Component:    RDK              0420
   Coding: 0100101
   Component: J389   TUER-SG HR   1110
   Revision: 12004001    Serial number: 00000000110868
   Coding: 0001168
   VCID: 3FDB40C5DB7B6EAF48E-806A
End----------(Elapsed Time: 01:20, VBatt start/end: 13.7V/13.4V)-----------
mattmc0416
C?ID=344511
Thanks for any help you can provide. I truly appreciate it!!!
mattmc0416
C?ID=344511
I am certain the part numbers are accurate for the replaced parts. The LDP is attached to the canister so I am also certain I connected the lines back properly there really is no way to cross them. I will trace the lines to be certain. I am not sure how to run the vacuum tests. As I have stated I am relatively new to this. I am a software engineer so I am rather technical but this is very foreign to me. I appreciate the help and would love further explanation if possible. Thank you
mattmc0416
C?ID=344511
Check routing of the EVAP lines, proper part number parts are installed and work you have performed to not be reversed and isolate tests with crimp & vacuum gauge to authenticate mechanical function or seal of EVAP and LDP system!
JPPSG
https://forums.ross-tech.com/showth...gases-and-vacuum-amp-so-should-you!-Air-leaks!
Are you saying it could be a leak issue not a blockage? I was under the assumption that p0441 is a flow issue. As in not a clear path.
Indeed a leak or FOD blockage could be a flow issue, so can incorrect routing or a valve not closing or opening when supposed to........& why I say to authenticate a valves function or seal using a mityvac tester or vacuum gauge.
Mechanicals man........ test the mechanicals........... :rolleyes:
mattmc0416
C?ID=344511
Thank you. I just left down on business but will be back at it on Thursday. I will trace the lines and test the n80 and Evap canister and LDP. I will post what I find here.
mattmc0416
C?ID=344511
So I took at look at the lines and they seem to be in good condition. The line coming from the LDP is connected to the purge valve. The LDP is attached to the canister. From the LDP there is a line that goes to the N80 purge valve. And a line connected to the canister. On the canister there is one small quick connect line and one large quick connect line. I am unsure where those go to. I have watched many videos of how the evap woks and see that vacuum is applied to the LDP which energizes the pump and then pushes air to pressurize the system. So can I get some guidance on to actually what I need to check now that I have a bit more understanding?
mattmc0416
C?ID=344511
Also I do not see anywhere that lines could be crossed. I can’t seem to trace the lines off the canister to the engine compartment. Any basic advice would be great. Should I run a 070 and 071 to see if electronically things are working?
mattmc0416
C?ID=344511
More information. When I run the 070 it says evap not ok. However when I run readiness it shows evap emissions passed. It sounds like the purge valve is operating every 30 seconds or so. I am so thoroughly confused. Can anyone please help?
mattmc0416
C?ID=344511
This has been resolved when I found the lines to be crossed at the separation point in the engine compartment.
https://forums.ross-tech.com/showth...sat-P0441-help&p=138264&viewfull=1#post138264
Thanks for report OP!
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Where did you find this?
Th RTFB for routing of lines would be a great start now wouldn't it, still seeking magic answers versus an RTFB query?
Why are you willing to spend money on possible parts you don't need, but ignore getting access to the information you absolutely need? :banghead:
cschmitz20
C?ID=385099
Not magic just free. If I see someone on here who has encountered a similar issue I would just give them the answer instead of just shouting to RTFB. Some of us are busy and don't have all kinds of money to buy every manual and repair device available. Yea yea yea save your snarky remarks.
Somethings I indeed know the answers and refrain from stating, especially when it is clear that the person needs to do tests or be familiar with circuits/fuel systems safely & that can only be answered by having the RTFB to conduct repairs & again safely!
I indeed told you were to get your answer to verify it and the test materials.
The VCDS forum is not a substitute for the RTFB.
VCDS is to be used in conjunction with RTFB & to perform repairs or ask questions about VCDS blocks or functions & based on specification data in VCDS captions when available or the RTFB & that you might not understand in it, not getting you some free quick answer to circumvent buying or obtaining the RTFB!
Being argumentative and dismissive to someone who is actually trying to help you help yourself isn't wise!
Did you know that RT offers paid for tech support too, but I digress?
