VCDS wont update and beeps
WheelerKB
C?ID=244679
My vcds wi beep three times then pause and repeat 4 times when I plug it into a car or usb to a computer. It will not update the firmware after the download is finished I get "error code -11"
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Try to press reset button over 45 sec, please.
Shaun
That is a problem mounting the interface to your PC to write files to it. What is your PC setup like, are you running in a virtual machine? Do you have antivirus software or something like that which might be grabbing it?
WheelerKB
C?ID=244679
I am running windows 10 home. No antivirus or virtual machine.
WheelerKB
C?ID=244679
I am getting an "unable to read versions. If the interface is n an not i use, try rebooting it."
Shaun
Unplug and replug the interface, then try again. If it still doesn't work, describe what the leds are doing.
WheelerKB
C?ID=244679
Light 1 from the left
g--r-g-gr-ararg-ararg-ararg-g-g-g-g
Light 2 from the left
r--r- r- r -ggggggggggggggggggggggg
Shaun
Can you post a screenshot of the updates tab in VCIConfig?
WheelerKB
C?ID=244679
I don't know how to post images to this thread. How do I do it?
WheelerKB
C?ID=244679
Dkk3sYEUYAADXOp.jpg:large
Is that what you needed?
Dana
Western PA, USA
Yep, that's exactly what we needed. It looks like the SD card is failing and those are specially formatted so we need to send you one.
We need to confirm the shipping address so I'll send you an email shortly.
WheelerKB
C?ID=244679
I installed the new sd card but the app now says there is something wrong with the sd card and I need to contact you guys about it.
Have you paired the new card with the HEX-NET? The procedure is as follows:
With the HEX-NET powered up (either from a USB power source or plugged into a car, it doesn't matter), press and hold the red button for 45 to 50 seconds. Use a timepiece of some sort. When you release the button, you should get a short confirmation beep. Once you do, leave the HEX-NET powered up for a while (5 minutes or so), then remove power and let it sit unpowered for a bit before powering it back up.
PetrolDave
Westbury, UK
C?ID=1423
I can confirm this procedure works, this is what got my HEX-NET working again earlier this week.
