- Joined
- Apr 9, 2014
- Messages
- 2,310
- Reaction score
- 2,258
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Sunday,05,August,2018,20:05:04:36026
VCDS Version: 18.7.0.0 (x64) HEX-NET CB: 0.4429.4
Data version: 20180518 DS292.0
VIN: WAUZZZFY3J2 License Plate: Q5 TIMMI
Mileage: 23km-14mi Repair Order:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 18 19 22 29 39 42 44 46 52 5F 69 6D
81 A5 AC BB BC D6 D7
VIN: WAUZZZFY3J2 Mileage: 23km-14miles
Address 01: Engine (J623-DETB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CE HW: 04L 907 309 L
Component: R4 2.0l TDI H35 3928
Revision: B1H35---
Coding: 2A65403A253605083400
ASAM Dataset: EV_ECM20TDI01104L906026CE 004004
ROD: EV_ECM20TDI01104L906026CE_004.rod
VCID: EFAE98F03611363266-80BA
14690 - Loading Mode active
P169A 00 [175] - -
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:57
Coolant temperature: 32 °C
Intake air temperature: 30 °C
Voltage terminal 30: 12.220 V
Unlearning counter according OBD: 0
Cruise Control System (CCS): status-Bits 0-7: 2
selected gear-Bits 0-7: 0
Readiness: 1 1 0 0 1
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 155 AL HW: 0CJ 927 156
Component: 0CJ 20TDI RdW H04 0001
Revision: --H04--- Serial number: 0000000130
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU48.rod
VCID: F3A694805A3912D282-80A6
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 0C4 0572
Serial number: 75117081170143001819
Part No SW: 80A 907 379 B HW: 80A 907 379
Component: ESP9 Plus H11 0766
Coding: 14AA48BE28A50A9FD1A5589720815292E4A5D2281214508B1A044A4927A54B
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: AE1045F4F19B7F3A2D-80FA
297728 - Transport Mode Active
U1105 00 [047] - -
[Transport_Mode_is_activated]
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:57
7A 00 80 00 C2 00 00 80 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 K HW: 80A 820 043 K
Component: Klima Zone 3 H55 0210
Coding: 641840195544400D02000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: A502BAD8A46D3C62DC-80F0
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001489761
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: FF02DBA880PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
262914 - High Pressure Sensor
B10AE 21 [008] - Signal Amplitude Too Low
Reset counter: 45
Mileage: 23 km
Date: 2018.08.05
Time: 09:12:12
Outside air temperature: 23.00 °C
Engine speed: 885 /min
Compressor current: actual value: 0.00 A
Temperature after evaporator: 23.70 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501943E11800CD050500109CBF80F9110B3108000000000000000020001A010A440122025601
VCID: 8248C14415832B5A99-80D6
Subsystem 1 - Part No SW: 80B 955 119 HW: 80B 955 119
Component: 426 LL 170410 040 0570
Serial number: 00000001704022104623
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20482953X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 01 08 2017 72130388
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE121071723510825
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 G HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00019472
Coding: 0D0104
Subsystem 6 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000155269003
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 031 0513
Serial number: 003WBM0205YN
Coding: AACCF0C00C800000585400FFF00C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: BE3075B421FB8FBABD-80EA
Subsystem 1 - Part No SW: ----------- HW: 480 000 106 17
Serial number: 35700000000051E41524
Subsystem 2 - Part No SW: ----------- HW: 480 000 106 17
Serial number: 35800000000351490522
Subsystem 3 - Part No SW: ----------- HW: 480 031 705 17
Component: SideSensor_Dr 002 0149
Serial number: 351000C2444C50704DD3
Subsystem 4 - Part No SW: ----------- HW: 480 031 705 17
Component: SideSensor_Pr 002 0149
Serial number: 352000C244485E70ADBI
Subsystem 5 - Part No SW: ----------- HW: 480 033 105 17
Component: FrontSensor_D 002 0149
Serial number: 355000C24ED191A02E7G
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 033 105 17
Component: FrontSensor_P 002 0149
Serial number: 356000C2443A52211CC+
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 480 031 606 17
Component: PedP_Sensor_C 002 0149
Serial number: 230000C244341A709B7-
Subsystem 8 - Part No SW: ----------- HW: 480 003 005 17
Component: PedPSensor_P2 001 0887
Serial number: I0N0000000026251C1A.
Central Sensor XY:
Subsystem 9 - Part No SW: ----------- HW: 480 022 504 17
Component: CentrSensorXY 000 0108
Serial number: I0O00019B24FDE43060
9735465 - Pedestrian Protection Crash Sensor 2; Driver Side
B148D 29 [137] - Signal Implausible
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:59
9451547 - Igniter 1 for pedestrian protection
B1038 1B [137] - Resistance Too High
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:58
9451803 - Igniter 2 for pedestrian protection
B1039 1B [137] - Resistance Too High
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:58
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 AC HW: 80A 907 129 AC
Component: Lenks.Modul H02 0003
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: E99AF6E808F5D80238-80BC
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 80A 920 771 A HW: 80A 920 771 A
Component: MMQ5T18DIERW H04 0512
Revision: 0512v0.2 Serial number: 0B359103918T
Coding: 05A48EC4A88000080C23A8601000200000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: A404A7DCAF57C56ACB-80F0
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H11 0090
Coding: 0D0F01
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: A91AB6E8C8751802F8-80FC
Part No SW: 8W5 907 468 E HW: 8W5 907 468 E
Component: Gateway H42 0116
Revision: 6A010002 Serial number: 0286A262617624
Coding: 03010001000006404107000000590032483A0007100000000175078F10000000
ASAM Dataset: EV_CGateCONTIAU491 003092
ROD: EV_GatewCONTIAU736.rod
VCID: CBD62C6062492A122A-809E
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0002
Serial number: 20170630235519 00339
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0897775200
262659 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[BAP_Timeout_ParkHeater]
Reset counter: 45
Mileage: 23 km
Date: 2018.08.05
Time: 09:13:00
527872 - Transport Mode Active
U1105 00 [009] - -
[transport_mode_aktive]
Reset counter: 5
Mileage: 23 km
Date: 2018.08.04
Time: 15:30:58
Address 22: AWD (J492) Labels: None
Part No SW: 80A 927 755 HW: 0CJ 927 749
Component: Q5_DL3_N_SD4 H18 0004
Serial number: 1716533496
Coding: 01070000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: N/A
VCID: EC948FFC0707CD2A43-80B8
No ASAM data for: "EV_AWDCQUOD31" (AU49)
Address 29: Left Light (J1018) Labels: None
Part No SW: 80A 907 397 B HW: 80A 907 397 B
Component: LCM_MLBevo H06 0017
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
Address 39: Right Light (J1023) Labels: None
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W1 959 593 HW: 8W1 959 593
Component: TSG FS001 0737
Serial number: CLSM1QFB00HIC
Coding: 00108B014000040000001080
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 885CD36C33BF010AC7-80DC
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000934447
Coding: 90002001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: B424579C1FB755EA5B-80E0
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 DM HW: 8W0 907 064 DM
Component: BCM2 MLBevo 019 0366
Coding: 01340000002000E06301A0000600D80233020000804306502F00000000040030001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
VCID: 8A58E9642DB3731AD1-80DE
Part No SW: 8W1 959 392 HW: 8W1 959 392
Component: TSG BFS001 0737
Serial number: CLSM1QE800AZQ
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 8542DA5804AD1C62BC-80D0
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0216
Revision: 9A001003 Serial number: 0445012461
Coding: 0110000202000000
VCID: B32654801AB952D242-80E6
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
Coding: 0790
ROD: EV_DeckLidCONTIAU736_AU37.rod
VCID: C8DC136C733FC10A07-809C
Address 81: Gear Shift (J587) Labels: None
Part No SW: 80B 713 041 L HW: 80B 713 041 L
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20170703003420
ROD: EV_GSMWaehlZFAU736.rod
VCID: A600BDD4D96B377AD5-80F2
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H15 0050
Coding: 0404020600000401022000A1A50000FE00F0C0200000
ROD: EV_BVSMLBevKOSTAAU736.rod
Address AC: Reductant Control (J880) Labels: None
Part No SW: 80A 907 355 E HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0003
ASAM Dataset: EV_RDCMHelbaAU426 003010
ROD: EV_RDCMHelbaAU426.rod
VCID: AB164CE0C2890A120A-80FE
Part No SW: 8W1 959 595 HW: 8W1 959 595
Component: TSG HFS001 0737
Serial number: CLSM1QGH00P1P
Coding: 000089000000040000001080
ROD: EV_DCU2RearDriveMAXHCONT.rod
Component: TSG HBFS001 0737
Serial number: CLSM1QGH00MJK
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 977E80106E019EF25E-80C2
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 01:41, VBatt start/end: 12.4V/12.4V)-----------
Missing ASAM for 22- AWD, otherwise seemed good. Transport mode turned off with Application -> Turn Off Transport Mode.
PS! Post "fell off a delivery truck" repairs.
