New member - going to need some help
25Tjetta
UC151166 (2nd hand?)
Hello all! Thanks for having me on the forum. My name is Jay and I have a 2008 (early model) Jetta S 5 cylinder. In 2015 I installed a Precision 5858 turbo with UM stage 3 software. Last year I began the process of swapping out the tiptronic for a 5 speed. UM flashed the ECU again for the 5 speed as well as adding their "PRO-MAF." So some wiring modifications were made 1) to add the Clutch Position Sensor 2)to add the MK3 IAT (intake air temp) sensor to compliment the PRO-MAF.
Now that it's back together, I am getting a crank/no start condition. I've done basic checks like fuses and cleaning my ground connections, but the VCDS is indicating a lot of items are receiving a low-voltage reading.
So that's the story. Once I am given permission to post in the Car repair forum I will post my VCDS logs. UPDATE - POSTING HERE
Thursday,29,March,2018,18:19:23:15384
VCDS Version: 18.2.0.3 (x64)
VIN: 3VWJM71K28M056478   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJM71K28M056478   Mileage: 284730km-176923miles
02-Auto Trans -- Status: Cannot be reached 1100
Address 01: Engine        Labels: None
   Part No SW: 07K 906 032 UM    HW: 07K 906 032 Q
   Component: United.342      G   19
   Revision: --H01---    Serial number: VWX7Z0G824R0JF
   Shop #: WSC 00001 000 00000
   VCID: 0831555D7B0F230450-805C
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -
                    Fault Status: 01100001
                    Mileage: 284739 km
                    Time: 00:31:18
                    Temperature: 13.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 12.700 V
000802 - Engine Speed Sensor (G28)
               P0322 - 004 - No Signal - Intermittent
                    Fault Status: 00110100
                    Mileage: 284739 km
                    Time: 00:31:33
                    Temperature: 3.0°C
                    Temperature: 4.0°C
                    Voltage: 8.382 V
008487 - Accelerator Position Sensor 2 (G185)
               P2127 - 002 - Signal too Low - Intermittent
                    Fault Status: 00110010
                    Mileage: 284739 km
                    Time: 01:00:16
                    Temperature: 3.0°C
                    Temperature: 3.0°C
                    Voltage: 12.827 V
Address 02: Auto Trans
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3FA38E816E41A4BC21-806A
18020 - Engine Control Module Incorrectly Coded
            P1612 - 000 -  - Intermittent
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6EFD03C579AB1D34FA-803A
00532 - Supply Voltage B+
00229 - Refrigerant Pressure
            013 - Check DTC Memory
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000750036
   Coding: 04050E234004150007140000001400000008730B5C000100000000000000
   Shop #: WSC 00066 123 12345
   VCID: 6FC31EC17EA1143CF1-803A
   Component: Wischer 260907 020  0501
   Coding: 00038805
   Shop #: WSC 00066
10 Faults Found:
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Fault Status: 01111100
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.85 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 13
                    Reset counter: 103
                    Mileage: 271509 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.95 V
                    Reset counter: 103
                    Mileage: 191222 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
02404 - Vehicle Exterior Illumination
                    Reset counter: 103
                    Mileage: 278591 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.10 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
   Revision: 05034000    Serial number: 003B6M0330NS
   Coding: 0013889
   VCID: 6CF909CD4FB7EF24D4-8038
   Subsystem 2 - Serial number: 6332MSME147F3A06H
   Subsystem 3 - Serial number: 6342MSME1B3F1472G
   Subsystem 4 - Serial number: 6351HSME0F7B400AE
   Subsystem 5 - Serial number: 6361HSME0F7A035BJ
   Subsystem 6 - Serial number: 63727SME0F11146D1
   Subsystem 7 - Serial number: 63827SME0E11457C5
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            008 - Implausible Signal - Intermittent - MIL ON
            010 - Open or Short to Plus - Intermittent - MIL ON
00591 - Seat Belt Switch; Driver (E24)
01217 - Side Airbag Igniter; Driver Side (N199)
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0010021
   VCID: 00214D7D533F1B4418-8054
00002 - Transmission Control Unit
02413 - Switch for Selector Lever Position P Lock (F319)
   Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0G824R0JF
   Coding: 0021203
   VCID: 2F43DEC1BE21543CB1-807A
6 Faults Found:
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Fault Frequency: 22
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 21:45:33
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Reset counter: 143
                    Fault Frequency: 60
                    Reset counter: 103
                    Mileage: 284739 km
                    Time: 01:18:54
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:07:58
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 290707F1000176
   Coding: ED807F070002021002
   VCID: 3041DDBDA31F4BC4A8-8064
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:08:00
                    Reset counter: 103
                    Mileage: 284739 km
                    Time: 01:18:56
                    Fault Status: 00101110
                    Mileage: 191322 km
                    Time: 23:33:36
                    Reset counter: 103
                    Mileage: 191222 km
                    Time: 08:18:12
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:43:36
   Component: IMMO            3HL 1212
02241 - Engine Control Module; Immobilizer Data not Adapted
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000606478827
   Coding: 0001205
   VCID: 3B5BFA917A59B89C0D-806E
                    Reset counter: 143
                    Mileage: 284739 km
                    Fault Status: 01100101
                    Reset counter: 103
                    Fault Status: 00111000
                    Reset counter: 139
                    Mileage: 284273 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Frequency: 18
                    Reset counter: 143
                    Mileage: 283441 km
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   VCID: 354FECA95C7D6EECFB-8060
                    Mileage: 284730 km
                    Temperature: 22.0°C
                    Voltage: 5.50 V
                    Voltage: 5.30 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 13.00 V
                    Voltage: 12.80 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 6.00 V
                    Voltage: 5.80 V
   Coding: 1B900F880186083F3F04058FB0880F0488DCA0
   VCID: 0429416D472707643C-8050
            000 -  -  - Intermittent
                    Fault Status: 00110000
                    Reset counter: 143
                    Mileage: 284238 km
                    Time: 23:17:09
                    Reset counter: 143
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000561678827
   Coding: 0001204
   VCID: 3C59F98D7F57BFA404-8068
                    Reset counter: 143
                    Mileage: 284739 km
                    Fault Status: 00100101
                    Reset counter: 129
Address 56: Radio
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000002155425
   Coding: 0001168
   VCID: 3E5DF385694BADB42A-806A
   Coding: 0100101
                    Fault Frequency: 51
                    Reset counter: 143
                    Mileage: 284392 km
00667 - Ambient Temperature Signal
                    Reset counter: 101
                    Mileage: 284701 km
00625 - Vehicle Speed Signal
                    Fault Frequency: 16
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:21:52
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000002151119
   Coding: 0001168
End-------------------------(Elapsed Time: 01:20)--------------------------
               P1643 - 001 -
                    Mileage: 284739 km
                    Time: 00:31:18
                    Temperature: 13.0°C
                    Temperature: 14.0°C
                    Voltage: 12.700 V
                    Mileage: 284739 km
                    Time: 00:31:33
                    Temperature: 3.0°C
                    Temperature: 4.0°C
                    Voltage: 8.382 V
                    Mileage: 284739 km
                    Time: 01:00:16
                    Temperature: 3.0°C
                    Temperature: 3.0°C
                    Voltage: 12.827 V
   Coding: 0017025
   Coding: 00038805
   Shop #: WSC 00066
10 Faults Found:
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.85 V
                    Fault Frequency: 13
                    Reset counter: 103
                    Mileage: 271509 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.95 V
                    Reset counter: 103
                    Mileage: 191222 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Reset counter: 103
                    Mileage: 278591 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.10 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
   Coding: 0013889
   Coding: 0010021
   Coding: 0021203
6 Faults Found:
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Fault Frequency: 22
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 21:45:33
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Reset counter: 143
                    Fault Frequency: 61
                    Reset counter: 103
                    Mileage: 284739 km
                    Time: 01:18:54
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:07:58
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:08:00
                    Reset counter: 103
                    Mileage: 284739 km
                    Time: 01:18:56
                    Mileage: 191322 km
                    Time: 23:33:36
                    Reset counter: 103
                    Mileage: 191222 km
                    Time: 08:18:12
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:43:36
   Coding: 0001205
                    Reset counter: 143
                    Mileage: 284739 km
                    Reset counter: 103
                    Reset counter: 139
                    Mileage: 284273 km
                    Fault Frequency: 18
                    Reset counter: 143
                    Mileage: 283441 km
                    Mileage: 284730 km
                    Temperature: 22.0°C
                    Voltage: 5.50 V
                    Voltage: 5.30 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 13.00 V
                    Voltage: 12.80 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 6.00 V
                    Voltage: 5.80 V
                    Reset counter: 143
                    Mileage: 284238 km
                    Time: 23:17:09
                    Reset counter: 143
   Coding: 0001204
                    Reset counter: 143
                    Mileage: 284739 km
                    Reset counter: 129
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
                    Fault Frequency: 51
                    Reset counter: 143
                    Mileage: 284392 km
                    Reset counter: 101
                    Mileage: 284701 km
                    Fault Frequency: 16
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:21:52
   Coding: 0001168
Thanks, talk with you soon!
-J
iichel
Netherlands, eastern part
C?ID=284912
OP welcome and best of luck with the project. keep in mind, help is probably only possible when we see a full autoscan.
25Tjetta
Thanks, iichel. I went ahead and added my scan ~ hope that's OK here.
25Tjetta
Any suggestions regarding the lower limit supply voltage readings? I am going to start with replacing the ignition switch to see where that gets me.
iichel
C?ID=284912
i'd probably get the multimeter out and measure the relays between 30 and 87 points or the mass points of the battery.
you can check the ignition switch with multimeter as well and use WD to trace terminal 50 wires from ignition switch to ECU and starter relays
25Tjetta
Can you explain what you mean "the relays between 30 and 87 points" and "mass points?" ~electrical n00b
MasterTommy
Amsterdam
C?ID=295586
First; the supply voltage faults that do show details of the voltage readings read 8-9V. If that was the battery voltage at that time (assuming root cause is not faulty connnections) your battery took a hit. That voltage level damages a battery. Seeing as this project takes quite some time i'm assuming the car sat idle for an extended period of time. I would first and foremost charge the battery and then test it. If it sat at said voltage for a prolonged period of time you can pretty much write it off.
Second; since you removed the auto trans, remove the auto trans control unit from the gateway installation list so the gateway and associated modules stop throwing errors for missing communication from the auto trans control module.
25Tjetta
Thanks, MasterTommy. Your assumptions are correct; the car has sat for a while. The original battery was shot - so I'm using another VW rabbit battery that I am uncertain of the current status... It's on a trickle charge that shows full capacity, but when I put a load tester on it, it reads weak to fair. Given that, I still thought it was producing ~12V. Thoughts?
MasterTommy
Amsterdam
C?ID=295586
Trickle chargers (or any chargers i know of) don’t ‘test’ the condition of the battery. They show battery status based on the voltage they read. But even a dead battery will usually charge to 13 something volts which a battery charger will award with a green light. There are some exceptions to the dead battery and the charger story, but to keep it simple; for testing a battery you’ll need a dedicated battery tester.
Confirming my suspicions, the next step is to renew the battery (preferably OEM), adapt new battery to battery regulator if one is installed in your car, remove the auto trans module from the installion list and clear all DTC’s. It’s pointless to diagnose supply voltage faults (if any of those are real) with a dead battery. And a dead battery can definately still have enough juice to power the dash and interior illumination but not enough to even make the starter move.
25Tjetta
Last night I put the multimeter on the battery and it was reading 12.3V and that's after having not been charged since Thursday 3/29/18. But to your point, I'll take this battery to a local auto parts store and have them check the status. FYI - the car cranks like a champ - but I'm getting no spark.
Thanks for your help; I'll post the results of the battery test.
Is there a chance that these readings are the result of a broken wire somewhere?
MasterTommy
Amsterdam
C?ID=295586
Then i incorrectly assumend it didnt crank. My bad. Ill have a further look at your scan later today.
25Tjetta
I took the battery to autozone, but the kid working was less than knowledgeable. We were not sure of the CCA of the OEM bosch battery as the battery only states 61Ah and 330A. He cross referenced to his battery and used 615 CCA for his test. Can anyone confirm the correct CCA for these batteries?
Based on 615 CCA it was reading low... 65%.
25Tjetta
The battery states 330A, so that's the CCA rating that should be used.
Thanks, PetrolDave. Was not sure if those were indeed one and the same. Time for a RETEST!
25Tjetta
OK all. The battery I was using was bad per test at Autozone. I installed a brand new battery and a new (G28) Crankshaft Position Sensor, and I removed Auto Trans from my gateway installation list. I am still seeing the same results; can you take a took at this scan and give me an idea of what is causing these issues? FYI headlights, front driver seat, and ambient temp sensor have not been reinstalled at this time.
Saturday,14,April,2018,18:19:17:15384
Mileage: 284730km-176923mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
               P1643 - 001 -
                    Mileage: 284739 km
                    Time: 03:57:24
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Voltage: 11.938 V
   Coding: 0017025
   Coding: 00038805
   Shop #: WSC 00066
10 Faults Found:
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.10 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 103
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.85 V
                    Fault Frequency: 13
                    Reset counter: 103
                    Mileage: 271509 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.95 V
                    Reset counter: 103
                    Mileage: 191222 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Reset counter: 103
                    Mileage: 278591 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.10 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
                    Reset counter: 143
                    Mileage: 284739 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.70 V
   Coding: 0013889
   Coding: 0010021
   Coding: 0021203
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Fault Frequency: 22
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 21:45:33
                    Reset counter: 103
                    Mileage: 274490 km
                    Time: 10:41:32
                    Reset counter: 143
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:07:58
   Coding: E9807F070002021002
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 00:08:00
                    Reset counter: 103
                    Mileage: 284739 km
                    Time: 01:18:56
                    Mileage: 191322 km
                    Time: 23:33:36
                    Reset counter: 103
                    Mileage: 191222 km
                    Time: 08:18:12
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:43:36
   Coding: 0001205
                    Reset counter: 143
                    Mileage: 284739 km
                    Reset counter: 103
                    Reset counter: 139
                    Mileage: 284273 km
                    Fault Frequency: 18
                    Reset counter: 143
                    Mileage: 283441 km
                    Mileage: 284730 km
                    Temperature: 22.0°C
                    Voltage: 5.50 V
                    Voltage: 5.30 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 13.00 V
                    Voltage: 12.80 V
                    Mileage: 284730 km
                    Temperature: 9.0°C
                    Voltage: 6.00 V
                    Voltage: 5.80 V
                    Reset counter: 143
                    Mileage: 284238 km
                    Time: 23:17:09
                    Reset counter: 143
   Coding: 0001204
                    Reset counter: 143
                    Mileage: 284739 km
                    Reset counter: 129
Address 56: Radio
   Coding: 0001168
   Coding: 0100101
                    Fault Frequency: 51
                    Reset counter: 143
                    Mileage: 284392 km
                    Reset counter: 101
                    Mileage: 284701 km
                    Fault Frequency: 16
                    Reset counter: 143
                    Mileage: 284739 km
                    Time: 22:21:52
   Coding: 0001168
End-------------------------(Elapsed Time: 01:18)--------------------------
PetrolDave
Westbury, UK
C?ID=1423
Did you clear all the fault codes after replacing the battery?
25Tjetta
Yes, correct.
PetrolDave
Westbury, UK
C?ID=1423
Given that so many modules are reporting under voltage and this fault code is present:
005699 - Please check <acronym title="Diagnostic Trouble Code (fault code)">DTC</acronym> Memory of Electric Load Controller                 P1643 - 001 -
                    Mileage: 284739 km
                    Time: 03:57:24
                    Temperature: 24.0°C
                    Temperature: 26.0°C
                    Voltage: 11.938 V
I wonder if the Battery Management system is shutting down power because it hasn't been told about the new battery?
25Tjetta
Dave, I will try doing the battery adaptation and see where that gets me. In my history with the car I never had to do this when switching batteries - but its worth a shot.
What else do you think it could be?
