Oil light on
victor35ma
Los Angeles CA.
C?ID=242342
Hello here I am again. thanks for your help.
I got an Audi with engine oil pressure light on when cold or at start up. Pressure is fine 18 psi at idle and maybe 50 psi at full rev. I replaced the reduced oil pressure sw already and have checked the oil pressure regulator valve which passed the test. also talking about oil pressure reg... is there any way to see Duty Cycle percentage DC% right out VCDS pids?
any comment is welcome.
open
Tuesday,27,March,2018,11:41:19:23194
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
VIN: WAUCF78K29N061048   License Plate: 6HTJ603
Mileage: 107590km-66853mi   Repair Order: 40000
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 62 65 67 6C 72 77
VIN: WAUCF78K29N061048   Mileage: 107590km-66853miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Revision: E1H14---
   Coding: 0104010A02070160
   Shop #: WSC 42225 444 999999
   VCID: F9BA8A4A7883488CDF-80AC
5582 - Oil Pressure Switch for reduced Oil Pressure
          P164D 00 [044] - Malfunction
                    Mileage: 107592 km
                    Date: 2018.03.27
                    Time: 10:13:01
                    Engine speed: 761.50 /min
                    Normed load value: 8.6 %
                    Coolant temperature: 101 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 13.947 V
Readiness: 1110 0101
   Part No SW: 8K0 927 155 AD    HW: 0AW 927 156 H
   Component: 0AW 20TFSIUSA H01 0003
   Revision: --H01---    Serial number: 0000001214
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02005
   ROD: EV_TCMVL381.rod
   VCID: F5A2867A549B2CECBB-80A0
   Part No SW: 8K0 907 379 AE    HW: 8K0 907 379 AE
   Component: ESP8 front    H04 0240
   Coding: 080500
   Shop #: WSC 02391 823 56573
   VCID: FCB4935E7FB17DA4C4-80A8
   Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
   Component: BCM2 1.1      H80 0145
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: B3267862126F72DC55-80E6
   Serial number: 0509000003070007
   Serial number: 0208000112998012
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340BJ097519052
   Coding: 0000003
   Shop #: WSC 02135 785 00200
   VCID: C3C628A282CFC25CC5-8096
   Subsystem 1 - Part No: 8T0 919 609 A
   Subsystem 2 - Serial number: 00000000228487
   Subsystem 3 - Serial number: 0128.01.090000000100010499ÿ
   Subsystem 4 - Serial number: 010499ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01030220090862
   Coding: 64002000
   VCID: F2A8BD662DF53BD49E-80A6
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Revision: 05022001    Serial number: 00000000203017
   Coding: 26001091063CAF010000080300003D0D0F1C52080001016100  0000
   VCID: B02C776EE37949C428-80E4
   Component: WWS 300109  H06 0070
   Serial number: SWF09010307036
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10377548
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000002801090317
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBI8739857
   VCID: AA18650605A53314E6-80FE
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 M    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0160
   Revision: 00005010    Serial number: AUZ4Z7I0510412
   Coding: 0000100
   VCID: B12A726A287340CC27-80E4
            000 -  -
                    Reset counter: 85
                    Mileage: 107544 km
                    Date: 2018.03.19
                    Time: 22:42:10
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 F    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0040
   Revision: 11001001    Serial number: 40140903505297
   Coding: 200103
   VCID: BC34535E3F31BDA484-80E8
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Serial number: 0039KD14U6CC
   VCID: C0CC27AE5BD9D944D8-8094
   Serial number: 5810000R090000362J
   Serial number: 6334MSME4613244B8
   Serial number: 6344MSME4352727AE
   Serial number: 6352QSME66162936G
   Serial number: 6362QSME5A1C0D24P
   Serial number: 63732SME3715060CX
   Serial number: 63832SME0D064122S
   Component: Lenks.Modul   H15 0013
   Revision: --------    Serial number: 90304IB300026
   Coding: 000016
   VCID: BD325E5A242BB4ACB3-80E8
   Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
   Component: KOMBIINSTR.   H18 0224
   Revision: 00200000    Serial number: 9E164LU19
   Coding: 8B1609000300D705020000
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E0912983A3
   Coding: 000303
   VCID: CED00996998D3F345A-809A
   Component: J367-BDM  H04 0150
   Serial number: 190617D3140109
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: AB166002CA5F2A1C1D-80FE
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001194677
   Coding: 00581300000000000000
   VCID: F7BE8C7246975EFCA9-80A2
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341BM097523833
   Shop #: WSC 02335 785 00200
   VCID: B83C4F4ECB09918460-80EC
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008397790
   Coding: 011C03204E00410001
   VCID: C1CA22AA58D3D04CD7-8094
   Revision: 00002001    Serial number: 0116981784
   Coding: 0106023A007A440400B001
   Component: GTO BF  H06 0040
   Serial number: 00000000000000115975
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 85
                    Mileage: 107556 km
                    Date: 2018.03.19
                    Time: 23:48:40
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 85
                    Mileage: 107556 km
                    Date: 2018.03.20
                    Time: 04:48:26
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
   Component: DSP STD       H08 0300
   Revision: S2600000
   Coding: 020101
   VCID: F0ACB76E23F909C468-80A4
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008360091
   VCID: C0CC27AE53D9D944D8-8094
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 00000000288337
   VCID: B2287D66ED757BD45E-80E6
   Part No: 8K5 907 357
   Coding: 0000004
   VCID: F7BE8C7286975EFCA9-80A2
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Revision: 00000000    Serial number: 379AX097573019
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100705628
   Coding: 010C03204000210001
   VCID: C4C42BBE47C1C564FC-8090
Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140790102451
   Coding: 0CD154
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000901230012
   Shop #: WSC 12336 024 394758
   VCID: B4247B7ED76175E44C-80E0
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J9190DD
   Coding: 1000006
   VCID: B73E4C72C6179EFC69-80E2
   Revision:             Serial number: 0000100705631
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005078205
   Coding: 0010900
   VCID: A81C9F0E1BA90104F0-80FC
End----------(Elapsed Time: 02:15, VBatt start/end: 12.6V/12.4V)-----------
[video]https://drive.google.com/open?id=1lFHqnyPOR0XkWA7wG_qCWXAq3htUpPvh[/video]
Hey Victor how's things man?
Great documentation........! :)
Component: 2.0l R4/4V TF H14 0001 <<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed 0003 or higher!
Otherwise Change oil pump & verify sump for fuel dilution or sludge damage........
Any other history on this car?
victor35ma
Los Angeles CA.
C?ID=242342
Hello Jack thanks for your help, it is always appreciated. I am good Mr Jack thanks for asking... Well, the history of this car is clean, only us have done maintenance on it. I am going to proceed re flashing the firmware to the latest and greatest as you are advising. then i will post you back. got it.
Well we have to follow the repair manual instructions & TSB/TPI's for process right or we have nothing to go by?
I hope it helps but if it doesn't than regulation with a possible pump will be required to be addressed.
Did you happen to inspect the pickup screen for sludge migration & from FOD sump contamination?
victor35ma
Los Angeles CA.
C?ID=242342
Not Yet. tomorrow mornig i guess i will.... but easy part first (Software). then I'll keep you posted. thanks again.
and yes you are right. on that.
Dana
Western PA, USA
Hi Victor,
I'm with Jack on mechanical issues related to oil pressure but make sure the reduced Oil Pressure switch was replaced. If memory serves, one is wired to the BCM or cluster an the reduced switch is wired to the ECM. They are two different colors and part numbers so if in doubt post the info from the new one.
Although unlikely a faulty (or low quality aftermarket) oil filer, or damaged black plastic spring loaded mechanism under the screw-on filter, can cause this issue and result in low oil pressure. In other cases however this code can be set right before the engine blows. For instance a catastrophic timing chain tensioner failure or cam bridge blow out (see the last pick of the sink screen blow out here) isn't uncommon with low oil pressure.
In a more recent case we had a shop with that reduced oil pressure code in addition to P0016 and after they sorted the cam bridge missing screen problem and tossed a new filter/oil change/oil pressure senor on it ... the HPFP continued to leak fuel into the oil and blew it up. They obviously didn't realize the fuel pump was blowing fuel into the crankcase. The fact that those cars don't have a dipstick doesn't help matters.
Jack, I don't want to hijack Victor's thread but I just got a 2017 UC 3.6L Gas T'reg. If you happen to have a VW/Audi part number on a proper dipstick to shove in that hole please let me know. I'll post my own thread in the Reference Scans and Maps of Non-Broken Cars section but that VIN is WVGRF7BP0HD004431​
https://s14.postimg.org/dcz6p28wh/DANAS_DIP_STICK_DATA.png
x
Special editions E04 "Wolfsburg Edition"
Lockable wheel bolts 1PF Standard wheel bolts
Vehicle class differentiation units/platform components 7KJ Vehicle class differentiation -7P0-
tail pipe 0P3 Polished stainless steel sports tail pipe
Emission standard 7GB Emission standard ULEV 2
Trailer hitch 1D6 Trailer hitch
airbag 4UM Driver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
Tray areas package QE4 stowage package 2
Bolt-on kit 6GA without exterior body styling kit
Aerials 8L6 "diversity" window antenna
Exterior mirror setting 6XC Exterior mirrors: power-adjustable
Follow-on warranty EA0 Without subsequent warranty
Left exterior mirror 5SG Left exterior mirror, flat
Right exterior mirror 5RR Right exterior mirror, convex (US)
Alternative drive system 0K0 Without alternative drive system
"Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Equipment levels A8B basic outfit
Brake type in rear 1KQ Disc brakes in rear
batteries J0Z Battery 520 A (110 Ah)
Brake type, front 1LE Disc brakes in front
Beverage holders 4M3 Beverage holders
Battery/alternator capacity NY0 Standard battery/alternator capacity
Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack 1S1 vehicle tools and jack
Brake systems 1AT Electronic stability control (ESC)
Owner's manuals 0VM Information kit in American English
Operating voltage 9Z2 12-V operating voltage and 115-V inverter
Heated washer nozzles 9T1 Heated washer nozzles in front
CD changer/CD player 7A0 Without CD changer/CD player
Chrome package QJ1 Chrome package
General operating permit, alterations C14 Operating permit, alteration
Shock absorption/suspension, chassis 1BW Comfort suspension 2
Roof rails/roof load rack 3S1 Bright roof rails
Roof insert/convertible top 3FU Big roof system
Decorative films / emblems 6F0 Without decorative films/emblems
Differential lock 1Y0 Without differential lock
Insert for the filling up of unleaded fuel/fuel type 2G4 Insert for the filling up of unleaded fuel
Theft protection system 7AJ Electronic immobilizer, with anti-theft alarm system and backup horn
Inserts 5TE Decorative aluminum inserts
Scuff plates 7M1 Scuff plates in door apertures with metal inserts
Park distance control 7X2 Park distance control, front and rear
Electric interface for external use UF1 Electric interface for external use
Tachograph/logbook 9NX Without electronic logbook
fire extinguisher 6A0 without fire extinguisher
Pedestrian protection VL0 Standard pedestrian protection measures
Fußhebelwerk VF1 pedal cluster
Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
Parking brake UH2 Parking brake
Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
Interior noise suppression measures 3W4 Acoustics package "Standard"
Alternators 9G1 Alternator 220 A
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Weight category front axle 0JA Weight category front axle weight range 1
Base engine TV1 6-cyl. petrol engine 3.6 l assembly 03H.X
Luggage compartment cover 3U4 Luggage compartment cover
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
cruise control system 8T3 Adaptive Cruise Control
Garage door opener VC2 Garage door opener
Transmission specifications G1G 8-speed automatic transmission for four-wheel drive
Entry grab handle (A/B-pillar) 6X0 Without entry grab handle
Molded headliner 6NW Unsplit molding roof liner
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Heating and air-conditioning system 9AD Climatronic, free of cfc
Headlamps 8IM Gas discharge headlights with dynamic bending light
Interior lighting 9MA Interior lighting in basic equipment
Customized installation FC1 Customized installation
Instrument clusters U5C Instrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
Sticker (customized or special edition) 0KA Without decals and emblems
Body style K8G Hatchback
Luggage compartment floor covering 6SF Standard trunk floor covering
Fuel tank capacity 0M1 Fuel tank
coolbox 1W2 Glove compartment cooling system
child safety 4H5 Electrically operated child lock
Climatic zones 0Y3 Cold zones
Compass/road sign display QR8 without road sign recognition
Seat ventilation/massage seat 4D3 Seat ventilation, front
Head restraints 5ZC Headrests for front seats (x-adjustment)
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Tire categorization A60 Category 0
Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
Body measures 5C1 Body measures for increased safety requirements
Camera systems/accident sensors KA2 With rear view camera system (type 2)
Radiator grille 6KA Radiator grille
refrigerant KK1 Refrigerant R134a
License plate lighting KL1 LED license plate lighting
Rear license plate bracket 6P2 License plate bracket, rear (NAR)
Front license plate bracket 6W3 License plate bracket front (small, NAR)
Paint preservative/transit coating 5K4 Full body cover (shape-adapted system) with additional transport protection measures
Paint coating FB0 standard paint coating
Rear cargo area 3GD Plane rear cargo area
Country codes FE0 Without country code (no DVD player in vehicle)
Steering system arrangement L0L Left-hand drive
steering 1N3 Speed-related variable steering assist (Servotronic)
Light control systems 8G0 Without Light Assist
Load edge protection 2P2 Stainless steel loading edge protection
Lumbar support 7P2 Power adjustable lumbar support in front seats
steering wheels 1MR Leather-wrapped steering wheel
Driving on the left/on the right AV2 Driving on the right (NAR)
Speaker installation 8RM 8 speakers (passive)
Steering column systems 2C5 Steering column, adjusted axially and vertically
Air cleaner (engine) 1L1 Air cleaner for dusty regions
Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
Center armrest rear 6D1 Center armrest rear
Center armrest 6E3 Front center armrest
Versions FM0 Basic equipment variant
Multi-function display/trip computer 9Q2 Multi-function display/trip computer with check control
center console 3D5 center console
Driver alert system EM0 Without driver alert system
Engine cooling 8Z6 Hot country
Engine specifications D3B 6-cylinder SI engine 3.6 l/206 kW (24V) VR6, FSI, homogeneous base engine is T05/TA0/TH0/TV1/TV0
Navigation device 7Q8 Navigation system for NAR
rear fog lamp 8TA witout rear fog lamp
Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp
Online services EL0 Without online service
Upgrading measures GP1 Vehicles with special upgrade measures
Panic switch KP4 With additional switch
Hubcaps 1NS Covers for wheel hubs/wheel bolts
Wheels F06 Alloy wheels 9J x 20
Radios 8AY Radio navigation system
Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
Tire pressure monitoring system 7K3 Tire pressure monitoring system 433 MHz High
tire HL8 All-season tires 275/45 R20 110H x1 (NAR)
Spare wheel/breakdown kit 1G1 Space-saving spare wheel
Restraint systems, front 4QR 3-point seat belts in front, with pretensioner and height adjustment, US label
Call feature NZ0 without emergency call control unit
P43 Black Vienna leather package USA
WN1 Wolfsburg Edition
Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
Special labels/plates 0SC Labels in English
Tail lamp assemblies 8SL LED taillamp assembly (NAR)
Locking mechanism for boot lid/cover rear 4E6 Sensor-controlled luggage compartment opener
Service indicator QI7 Service indicator 10 000 miles or 1 year (fix)
Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
seat covers N1P Seat trim covers in part leather
Fuse box (for industrial engine only) KE2 Additional fuse
Seat adjustment 3L5 Both front seats power-adjustable
seat heater 4A3 seat heating for front seats separat controlable
Start-stop system/regenerative braking 7L7 Regenerative braking with 12.5 V
Horns 8Y1 Two-tone horn
sun visors 5XX Sun visors with mirror, illuminated (NAR)
Lane change assist/lane keeping system 7Y3 Lane change system plus lane keeping system
Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
Sunroof roller blind for rear/side windows 3Y0 without roller blind
power outlet 7B3 12-volt socket(s)
Bumper 2JC Comfort bumpers
Headlamp washer system 8X0 Without headlamp washer system
Special approval measures 3M0 Without special measures
Nameplate set 0NB Nameplate set in basic version
Mass damper for steering wheels 1Q3 Mass damper for steering wheel, XXHz
Door and lid locking system 4F6 Central locking system "Keyless Entry" without deadlock (NAR)
Type approval countries/countries with special requirements BU2 Legal requirements for USA 2 States with CARB requirement
Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
Partition 3CA without partition
Transit coating NT0 Transit coating (type 1)
Door and side trim panels 4AU door and side trim panels
TV reception/digital radio reception QV8 Satellite radio reception NAR
Front underbody guard 1SA Without additional front underbody guard
Identification plates 1EB without identification plate
Delivery equipment 2A0 Without delivery equipment
First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
Front seats Q1H convenience seat
Rear seat catch UK2 Electric rear seat release
Telephone / telematics 9ZF preperation for mobile phone with hands free teleph.
Additional warning lights 9TG Additional warning lights (door area) in front
LongLife Service Regime QG1 LongLife Service Regime
Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
Windshield Glass 4GF Windshield in heat-insulating glass
floor mats 0TD Front and rear floor mats
Additional body panels, side 6EA Without additional side body covers (stone guard)
Auxiliary heating system 9M0 Without auxiliary heater/parking heater
Power latching for tailgate GY1 Power latching for tailgate
x
Vehicle Identification No. WVGRF7BP0HD004431
Model Touareg TOUA
Date of production 18.12.2016
Year 2017
Sales type 7P6208
Engine Code CGRA
Transmission Code NXL
Axle drive 8A
Equipment TO
Roof color 2T
Carpet color code
Exterior color / Paint Code 2T / C9X
victor35ma
Los Angeles CA.
C?ID=242342
Victor .................Report!
reporting:
Jack I did the home work on the oil pump sump/ sludge conditions and everything checks out. also i replaced the oil according to specs. 5w40 4.5L. i am reflashing as well. thanks.
Question: the oil pressure reg valve, is it NC then ecm open it up by Duty cycling it?
Dana:
yeah after re flashing, we are entertaining that idea.... and please don't hijack :rolleyes: Jack follow ups. thank you guys.
Victor please be more specific?
Is the update done and is there a change for DTC?
ECU should control regulation yes and be forewarned as Dana aforementioned that correct sensors are installed with respective part numbers.
victor35ma
Los Angeles CA.
C?ID=242342
Report........?
open
hi jack Car is Ok now, thank you.. re flashed was done as well. oil pump replacement did the miracle. this is oil pressure after replacement.
[video]https://drive.google.com/file/d/1zhY9z_mJo5BOlOiw45Hy8xPd8ZkGyQDK/view?usp=sharing[/video]
and this is the first oil pressure test
i just didn't quite get to understand how the oil pressure regulator valve works in this systems since apprear to be off most of the time.... anyway. thank you. I got 2 more same dtc along with some others.
Thank you Victor........
Please Post new auto-scan........
CCYT
Wilson, NC, USA
C?ID=363210
Is there any way I can disable low oil light with VCDS? I recently replaced cam bridge, oil sensor, spring where you screw on oil filter, oil pump, checked fro any debry or slump in oil mesh inside oil pan, replaced timing upper timing guides with timing tensioner, send the cylinder head to get it rebuilt, 08 passat works fine the only flaw is that when I drive it in the city the annoying chime and turn of engine light will come on(low pressure oil) but if I drive it on highway speeds, the light will never come on, I just need to disable the light somehow
RGH0
Australia
C?ID=433612
I would investigate more about why the light is coming on before I tried to disable it
EuroX
Northern NJ USA
C?ID=208579
Light can be disabled but I will not be sharing how to bypass a crucial failsafe warning. Address the pressure issue before that thing spins a bearing or seizes.
CCYT
Wilson, NC, USA
C?ID=363210
@RGH0 @EuroX i agree with you too, that was my soul purpose in this project(08 passat) 2.0L TSI EA888. I want to do things the right way, but there is times that you just have to use the bypass lane. The only two things left, 1 is to reflash or update ECM. 2 is to check crankshaft bearings clearance, but I don’t really believe crankshaft bearing clearing should be the issue, because my sister drives the car every day from school to work, engine has not fail. I was hoping it would fail by now, then I could just replace the engine hoping that light chime will go away.
EuroX
Northern NJ USA
C?ID=208579
I would check oil pressure with a manual gauge Or check both oil pressure switches. Perhaps you have oil leaking into a oil pressure switch. I've seen it the right way is to fix the issue or diagnose the issue and determine cause or repair.
CCYT
Wilson, NC, USA
C?ID=363210
@EuroX yes sir I will but honestly I won’t be able to find the issue, I tried for over a year and now I’m just to the point on driving the car like it is.
