- Joined
- Mar 13, 2018
- Messages
- 22
- Reaction score
- 6
- Location
- Norway
- VCDS Serial number
- C?ID=288196 (NRRT)
Hi, I'm new in here. I have used vag-com a little but not much.
I got this car on my shop, with defective j500, no communication with j500.
I changed the pump, and now the powersteering works a bit but it is not good and the yellow steering wheel in instrument stil lightning.
I have tried to change the coding but it falls back to 00140 all the time.
now the car dont have fail cods in 44 (light stil lightning in instrument) but som times it missing signal fron g269 and this car dont have the sensor.
What can i do?
What can i do?
Monday,05,March,2018,13:13:21:20376
VCDS Version: 17.8.1.0 (x64)
VIN: WVWZZZ6RZDY086219 License Plate: SV33380
Mileage: 31240km-19411mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61
VIN: WVWZZZ6RZDY086219 Mileage: 31240km-19411miles
Address 01: Engine (J623-CGPA) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 A HW: 03E 906 019 A
Component: SIMOS11.3 H04 9803
Revision: --H04--- Serial number:
Coding: 001100B6002401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019A 001009
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 224A6E2835806956A7-8076
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210224E3217500B8842724E384DA00501300
VCID: 020A0EA89940895687-8056
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387EAC408B1C138669-806C
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 241120082
Coding: 24B02BBF08A10000203009F06D2B0DD05FC0612F7E860049200000000000
VCID: 4188C1A4D8C6524EDE-8014
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU011091200011653
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005091200015262
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003091200013102
Coding: 58BC32
Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU004091200013936
Coding: 58BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361224301241
Coding: 108001
ASAM Dataset: EV_VW250ParkiAssis2 S01008
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E72BA58A1382DB6A3-806A
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag01J H10 0020
Revision: -------- Serial number: 003GY0071FPF
Coding: 00314A
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4B94E38CE28A881E34-801E
Serial number: 3575HRB40571JM5G39LF
Serial number: 3585HRB40551JM5GA9DD
Serial number: 3515RRB404R1D2B6K10$
Serial number: 3525RRB40551AP6031CN
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0605
Coding: 140E01
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
VCID: 3C76B050B7243FA68D-8068
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 E HW: 1K0 907 951
Component: J533 Gateway H38 0041
Revision: H38 Serial number: 060912F1000162
Coding: 250002
VCID: 3560A5749C0EEEEE72-8060
Mileage: 31247 km
Date: 2018.03.05
Time: 04:05:49
Component: IMMO H05 0605
VCID: 6ADA46088D3071162F-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663431718
Coding: 010100
VCID: 2A5A860845B0B116EF-807E
Part No: 6Q0 423 156 AB
Component: LenkhilfeSEI V202
Coding: 00140
Shop #: WSC 12345
VCID: 6FEC571C2AD2943E78-803A
Address 56: Radio
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0041
Coding: 032B7A64
VCID: 74E65870D7F4B7E685-8020
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970096847
End-------------------------(Elapsed Time: 02:30)--------------------------
Tuesday,06,March,2018,11:05:58:20376
Readiness: 0110 0101
Revision: --------
Revision: V0000000
Coding: 58BC30
Coding: 58BC30
Coding: 58BC32
Coding: 58BC32
Coding: 108001
Coding: 00314A
Coding: 140E01
Coding: 250002
Coding: 010100
Coding: 00140
Shop #: WSC 12345
00816 - Power Steering Sensor (G250)
30-00 - Open or Short to Plus
08448 - Unknown Error Code
00-00 - -
Address 56: Radio
Coding: 032B7A64
End-------------------------(Elapsed Time: 02:33)--------------------------
