Polo 6r Address 44: Steering Assist
dnb9170
Norway
C?ID=288196 (NRRT)
Hi, I'm new in here. I have used vag-com a little but not much.
I got this car on my shop, with defective j500, no communication with j500.
I changed the pump, and now the powersteering works a bit but it is not good and the yellow steering wheel in instrument stil lightning.
I have tried to change the coding but it falls back to 00140 all the time.
now the car dont have fail cods in 44 (light stil lightning in instrument) but som times it missing signal fron g269 and this car dont have the sensor.
What can i do?
 Monday,05,March,2018,13:13:21:20376
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: WVWZZZ6RZDY086219   License Plate: SV33380
Mileage: 31240km-19411mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61
VIN: WVWZZZ6RZDY086219   Mileage: 31240km-19411miles
Address 01: Engine (J623-CGPA)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 A    HW: 03E 906 019 A
   Component: SIMOS11.3     H04 9803
   Revision: --H04---    Serial number:
   Coding: 001100B6002401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12MPI02103E906019A 001009
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 224A6E2835806956A7-8076
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3217500B8842724E384DA00501300
   VCID: 020A0EA89940895687-8056
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 387EAC408B1C138669-806C
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 0456 241120082
   Coding: 24B02BBF08A10000203009F06D2B0DD05FC0612F7E860049200000000000
   VCID: 4188C1A4D8C6524EDE-8014
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU011091200011653
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005091200015262
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003091200013102
   Coding: 58BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU004091200013936
   Coding: 58BC32
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361224301241
   Coding: 108001
   ASAM Dataset: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E72BA58A1382DB6A3-806A
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag01J H10 0020
   Revision: --------    Serial number: 003GY0071FPF
   Coding: 00314A
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 4B94E38CE28A881E34-801E
   Serial number: 3575HRB40571JM5G39LF
   Serial number: 3585HRB40551JM5GA9DD
   Serial number: 3515RRB404R1D2B6K10$
   Serial number: 3525RRB40551AP6031CN
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 860 K    HW: 6R0 920 860 K
   Component: KOMBI         H05 0605
   Coding: 140E01
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
   VCID: 3C76B050B7243FA68D-8068
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 E    HW: 1K0 907 951
   Component: J533  Gateway H38 0041
   Revision:   H38       Serial number: 060912F1000162
   Coding: 250002
   VCID: 3560A5749C0EEEEE72-8060
            000 -  -  - Intermittent
                    Mileage: 31247 km
                    Date: 2018.03.05
                    Time: 04:05:49
   Component: IMMO          H05 0605
   VCID: 6ADA46088D3071162F-803E
   Revision: A1001003    Serial number: 7663431718
   Coding: 010100
   VCID: 2A5A860845B0B116EF-807E
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeSEI        V202
   Coding: 00140
   Shop #: WSC 12345
   VCID: 6FEC571C2AD2943E78-803A
Address 56: Radio
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0041
   Coding: 032B7A64
   VCID: 74E65870D7F4B7E685-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970096847
End-------------------------(Elapsed Time: 02:30)--------------------------
Tuesday,06,March,2018,11:05:58:20376
Readiness: 0110 0101
   Revision: --------
   Revision: V0000000
   Coding: 58BC30
   Coding: 58BC30
   Coding: 58BC32
   Coding: 58BC32
   Coding: 108001
   Coding: 00314A
   Coding: 140E01
   Coding: 250002
   Coding: 010100
   Coding: 00140
   Shop #: WSC 12345
00816 - Power Steering Sensor (G250)
            30-00 - Open or Short to Plus
08448 - Unknown Error Code
            00-00 -  -
Address 56: Radio
   Coding: 032B7A64
End-------------------------(Elapsed Time: 02:33)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
try something like 11241 for your 44 coding
dnb9170
Norway
C?ID=288196 (NRRT)
it loses the code when i go out of 44. when i go back in its 00140 again.
iichel
Eindhoven, NB, NL
C?ID=284912
update your VCDS to 18.2
check fuse 26
try coding it again to 11241 or 01241 or 01240
as long as the coding has the 01 in it instead of 12 it will give you the error 00618
dnb9170
Norway
C?ID=288196 (NRRT)
check fuse 26
i wiil try tomorrow
dnb9170
Norway
C?ID=288196 (NRRT)
now whith the new update 18.2. it got new fail code in 44. The car dont have G250.
and the codings jumps straigth back to 00140 after change.
Friday,16,March,2018,08:32:52:20376
VCDS Version: 18.2.0.3 (x64)
   VCID: 224A6E28358069542E-8076
Readiness: 0010 0101
   Revision: --------
   VCID: 020A0EA8994089540E-8056
   Revision: V0000000
   VCID: 387EAC408B1C1384E0-806C
   VCID: 4188C1A4D8C6524C57-8014
   Coding: 58BC30
   Coding: 58BC30
   Coding: 58BC32
   Coding: 58BC32
   Coding: 108001
   VCID: 3E72BA58A1382DB42A-806A
   Coding: 00314A
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4B94E38CE28A881CBD-801E
   Coding: 140E01
   VCID: 3C76B050B7243FA404-8068
   Coding: 250002
   VCID: 3560A5749C0EEEECFB-8060
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADA46088D307114A6-803E
   Coding: 010100
   VCID: 2A5A860845B0B11466-807E
   Coding: 00140
   Shop #: WSC 12345
   VCID: 6FEC571C2AD2943CF1-803A
Address 56: Radio
   Coding: 032B7A64
   VCID: 74E65870D7F4B7E40C-8020
End-------------------------(Elapsed Time: 02:59)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
that is really strange. did you check the fuse? do you see any errors? or does it say coding accepted?
dnb9170
Norway
C?ID=288196 (NRRT)
yes i check the fuse, cant se anything wrong.
Yes when i put in the coding it is writhing the code, but when i leave the address 44 and go back in its 00140 again.
iichel
Eindhoven, NB, NL
C?ID=284912
OK, so now I'm slightly lost.
Are you sure 6Q0423156AB is a proper replacement for your car? What was the part number of the original pump? do you still have it?
dnb9170
Norway
C?ID=288196 (NRRT)
that was the pump i got, on the old one it was writet 6R0423156C... yes i still have the pump.
iichel
Eindhoven, NB, NL
C?ID=284912
OK well what I can quickly find is, that AB comes in the Polo 9N based cars. You on the other hand have a Polo 6R. Maybe that's why it's not accepting, since the part is not compatible.
dnb9170
Norway
C?ID=288196 (NRRT)
Hi, im back... you have absolutly right, i call the dealer and they sendt me a new one...
Now evrything is working. thanks.
