A6 C7 - Side Assist failure - ACC failure
Razor77
New Member
hexa193-00c68a-88b6d8-ccb527-tjhahh-5d05
Hello, my ACC is not working,
I have a low milage Audi A6 C7, delivered September 2013, I think that makes it MY2014?
A week back I noticed ACC would not work, when i tried it triggered the dash error message "ACC and Audi braking guard:not available". I pressed a few buttons, including the Side Assist button and got the error message "Audi side assist: system fault!"
An auto-scan revealed a lot of malfunctions, I assume all are connected to one failure. I found by resetting the "3C Lane Change" faults, while they immediately repopulate in VCDS and trigger the dash "Audi side assist: system fault!", ACC and brake guard will work for so long if I don't turn the engine off. During this period of working, the Side Assist light in the right wing mirror glows at about 5% (just visable), when the ACC fails again, the glow goes.
Doing a Output Tests on 3C yields the following results;
"Warning Lamp for Lane Change Assitance (in left exterior mirror) (K233)" The lamp on the left mirror does not light up, the lamp on the right mirror does - brightly (28s in the video).
"Warning Lamp for Lane Change Assitance (in right exterior mirror) (K234)" Neither lamp is bright, but both have a trace of light, about 5%. (48s and 50s in the video, it's there, but can barely be noticed)
Could it be as easy as needing to swap out the Side Assist lamp in the right mirror? Or is the "007 - Short to Ground" in the auto-scan misleading? Also having Googled "02850 - Control Module 2 for Lane Change Assistance (J770) 014 - Defective" it suggests J770 may need to be replaced, and will require calibration. I am hoping this is not required, and just a consequence of something simpler.
Other factors that might help;
  • I've had the car from new, it had minor damage last September when the front bumper hit a short post. Requiring a new bumper, which incurred need to calibrate all sensors. Could the cause be related?
  • I didn't have the bumper repaired immediately, but about 6 weeks later, during that time for the period of a week and ACC stopped working with the same dash message. I made presumption it was related to the ACC radar, as the damage was near this location.
  • I don't really pay attention to Side Assist, so I can't say when it first failed.
Here is the auto-scan
Sunday,25,February,2018,20:05:26:46808
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.2.0.3 (x64)
VIN: WAUZZZ4G9EN035975   License Plate: xxx
Mileage: 64671km-40184mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 3B 3C 42 44 46 52
          53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4G9EN035975   Mileage: 64671km-40184miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 C    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0002
   Revision: 57H25---
   Coding: 122A4032256603020000
   Shop #: WSC 57891 001 1048576
   ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
   ROD: EV_ECM30BTD_AU57.rod
   VCID: 3467FD9B9F8DB7E4CC-8061
   Part No SW: 4G0 927 158 K    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1003
   Revision: --H16---
   Coding: 000001
   VCID: 3663C79389F1A5F4F2-8063
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Coding: 49B79F0192EDF980DB00
   VCID: 3B75D6A7B2D3789C0D-806F
   Part No SW: 4H0 907 064 DN    HW: 4H0 907 064 DN
   Component: BCM2 2.0      H35 0510
   Coding: 01B93046000000000000
   VCID: 78FF09ABCB65938420-802D
   Serial number: 2313000123598002
   Part No SW: 4G0 820 043 AB    HW: 4G0 820 043 AB
   Component: KLIMA 2 ZONEN H11 0087
   Serial number: 09071300111071
   Coding: 3622000825
   ASAM Dataset: EV_AirCondiBasisUDS 002045
   VCID: 5FCD4237468B44BC41-800B
0019 - Motor for Fresh Air / Recirculated Air Flap
          B11AF 07 [008] - Mechanical Failure
                    Fault Frequency: 11
                    Reset counter: 139
                    Mileage: 60468 km
                    Date: 2017.12.19
                    Time: 16:57:23
                    Voltage terminal 30: 13.32 V
                    Outside air temperature: 8.5 °C
                    Interior temperature: 13.14 °C
                    Fresh air door motor-Act.val.: 11133
                    Fresh air door motor-Specified value: 10106
                    Fresh air door motor-Stop open: 11391
                    Fresh air door motor-Stop closed: 10000
0035 - Motor for Recirculation Flap
          B1092 07 [008] - Mechanical Failure
                    Reset counter: 121
                    Mileage: 60250 km
                    Date: 2017.12.15
                    Time: 11:10:22
                    Voltage terminal 30: 13.22 V
                    Outside air temperature: 12.5 °C
                    Interior temperature: 20.72 °C
                    Recirculation flap motor-Act.val.: 10770
                    Recirculation flap motor-Specified value: 11741
                    Recirculation flap motor-Stop open: 11440
                    Recirculation flap motor-Stop closed: 10000
   Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
   Revision: 19012002    Serial number: 00000001595824
   Coding: 2600201040749FE2A18100C000001D0CCF9DC7082F09020100  0004606100
   Shop #: WSC 37488 001 1048576
   VCID: 6DD128FFB427262CC3-8039
   Component: WWS57X 130629  H36 0080
   Serial number:         130702115015
   Coding: 0045F7
   Serial number: 21535273
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 08 07 2013  00002041
   Serial number: A66949B6000000000001
   Revision: 11001001    Serial number: 61061319701882
   Coding: A8EB08
   VCID: 71E9348FA01FC2CCE7-8025
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 285F19EB5345C30470-807D
145152 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 100
                    Mileage: 64171 km
                    Date: 2018.02.20
                    Time: 08:49:17
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 13.039 V
                    Velocity_vehicle_reference: -0.54 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.88 m/s²
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Revision: --------    Serial number: 003JG00E778V
   Coding: 3032343631334E303539554A305234473053
   Serial number: 3575HRB400G50GS8B1QI
   Serial number: 3585HRB400I50GS8G1CC
   Serial number: 3515JRB401650K2GB8N
   Serial number: 3525JRB401G50K2GDPHJ
   Serial number: 3554VRB400Q50KJOK1PF
   Serial number: 3564VRB400650KBAHP2F
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372MGB000BX
   Coding: 0000FD
   VCID: 377DCA9786FB5CFCE9-8063
   Serial number: 27 06 2013  E0188090
   Part No SW: 4G8 920 984 P    HW: 4G8 920 984 P
   Component: TDieGb Acc    H80 0618
   Revision: 30460230    Serial number: 658240613596009
   Coding: 338F11008F512600010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 4385AE47CA23005C45-8017
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000001026414
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 3844710903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Serial number: 130509000000000001A0
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 8
                    Mileage: 60724 km
                    Date: 2018.01.05
                    Time: 07:37:11
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Revision: AA001002
   Coding: 02028264747464545425363E00
   VCID: 7CF715BBFF5DBFA444-8029
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0013
   Serial number: 000207130001630
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 275D1AD75E5BCC7C79-8073
   Component: SARA 6D red   H02 0056
   Revision: --------    Serial number: EJ1BPA7E00KBFI
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377DCA978EFB5CFCE9-8063
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0060
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   Coding: 0001102
   VCID: 306FF18BA3958BC4A8-8065
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0060
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F16.07.1300H03000AMS15750ÿ
   Subsystem 4 - Serial number: S15750ÿ
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 84
                    Mileage: 64171 km
                    Date: 2018.02.20
                    Time: 08:49:16
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
                    Fault Status: 01100111
                    Reset counter: 100
                    Mileage: 64671 km
                    Date: 2018.02.25
                    Time: 17:58:10
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F16005C01628002080013
   VCID: 4581B05FCC173E6C6B-8011
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0014675563
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326BFB836599B9D4DE-8067
   Revision: 00002001    Serial number: 0311070386
   Coding: 013B0622A0B93080832009040C010F47000000000000000000  0000000000
   Coding: 011F16005E01628002080002
   VCID: 4683B753F111357462-8013
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000761878
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C57E5FB47BDEF2494-8079
   Serial number: 130717-0002-126
   Coding: 1122A6101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D51E8FF7CA7E62C83-8079
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109G20D7693338
   Coding: 010103020100000001
   VCID: 264317D35151D57442-8073
   Part No SW: 4G0 035 670 K    HW: 4G0 035 670 H
   Component: H-BNT-EU      H51 0732
   Revision: --------    Serial number: 190E40G7558366
   Coding: 050101010003E9EF3D90CB3E00000003000001000000000000
   Shop #: WSC 55157 001 1048576
   VCID: 2B55E6E74AB3E81C9D-807F
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD0029GCO
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Serial number: 90349MGI000I7
   Component: CD-Database  5298
   Coding: 010F14004001628002080002
   VCID: 4999BC6FE00FDA0C8F-801D
   Revision: --H07---    Serial number: 525 PA8J36G80T
   Coding: 1080005
   VCID: 264317D39151D57442-8073
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 185300125
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3561C09F94F7AEECFB-8061
Address 85: On Board Cam. (J852)       Labels:* None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 264317D35951D57442-8073
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X_002.rod
          U1113 00 [009] - -
                    Reset counter: 100
                    Mileage: 64171 km
                    Date: 2018.02.20
                    Time: 08:49:16
                    Control Module temperature: 5 °C
                    Voltage terminal 15: 13.661 V
                    Velocity_vehicle_reference: -0.57 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.86 m/s²
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000120507137
   Coding: 04C2381A1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0063 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 100
                    Mileage: 64171 km
                    Date: 2018.02.20
                    Time: 08:49:17
                    Outside air temperature: 6.5 °C
                    Voltage terminal 15: 13.6 V
                    Control Module temperature: 8.0 °C
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169F48F609F82CCA7-8065
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 130606200478
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 2B55E6E742B3E81C9D-807F
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0004
   Serial number: 130704200929
   VCID: 24470DDB2F6D27645C-8071
End-------------------------(Elapsed Time: 07:36)--------------------------
I think the root of the problem lies here:
            014 - Defective
Razor77
New Member
TSB 96-12-35
Thanks for the quick reply Uwe.
I have just found a TSB 96-12-35 - can I upload a PDF?
Basically, it reads if a DTC of 02853 or 02854 exists then replace affected lamp.
Any chance this could cause the 02850 failure? Clearly, I'd prefer it to be this way as the lamp is a considerably lower cost fix!
can I upload a PDF?
Nope. Last I looked, TSBs were copyrighted works. ;)
Now I realize that some sites ignore this and host 'em anyway, but I really wish to minimize any potential for interaction with VWAG's attorneys. BTDT, didn't like it very much.
I don't know. But if it were mine, I'd probably try that. :)
thedru13
C?ID=67849
No expert by any means but also may want to check that you don't have any wiring issue. 02854 code may be a bulb issue or maybe the ground wire came loose.
Possible symptoms:
Lamp does not work
Possible causes:
Wiring and / or connections are defective
(K234) defective
Possible solutions:
Check / repair wiring and connections
Check (measured value blocks) / replace (K234)
CuturiloD
Serbia
C?ID=361908
Hello to everyone, I also have a problem with side assist.
This is the frame from my auto scan
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H06 0060
Serial number: 0366301422
Coding: 040311
VCID: 392F2F19A9D27BEFAFD-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H06 0060
Serial number: 0367089970
Coding: 040311
730378 - Warning Lamp for Lane Change Assistance in Driver-Side Ext. Mirror
C1116 15 [009] - Open or Short to Plus
Reset counter: 110
Mileage: 138796 km
Date: 2019.03.26
Time: 16:24:36
PetrolDave
Westbury, UK
C?ID=1423
We'll need you to post the full unedited Auto-Scan so we can see the context of those fault codes.
CuturiloD
Serbia
C?ID=361908
Tuesday,26,March,2019,16:27:13:48786
VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4502.4
Data version: 20190131 DS301.0
VIN: WAUZZZ4GXFN075726   License Plate: SU106USS
Mileage: 138796km-86243mi   Repair Order:
Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 36 3B 3C 42 44 46 52
          53 55 5F 62 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4GXFN075726   Mileage: 138796km-86243miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 0A25401A234401080000
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEF19E952BBEFEFD-802C
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000000191
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002014
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 323D183574A488B76E7-8066
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 06A29E49604579929B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB4101B7F655DF919-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A8700E000000000000
   VCID: 7AADF015ECD4B0F7E67-802E
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 02031500110355
   Coding: 34110908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619FA77961C2432FC7D-8034
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001021731202
   Coding: 0105001440349FE2C1014083A0001800CF9CC3082E08020100000494E10114020040002C030000
   VCID: 71BFD739B1A2F3AF57D-8024
   Component: WWS57X 150211  H37 0080
   Serial number:         150216124312
   Coding: 0045F7
   Serial number: 23783453
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Serial number: 26 02 2015  00000172
   Serial number: 70884397000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 290FFF595972CB6FDFD-807C
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1003J2GQ
   Coding: 30333130313630323437554A304C34473053
   VCID: 3B233511A3EE49FFBD1-806E
   Serial number: 3575HRB405R33HNKA83Q
   Serial number: 3585HRB4055373K63137
   Serial number: 3515JRB405V35IMQ80V9
   Serial number: 3525JRB405136K44BPC
   Serial number: 3554VRB4055352USNH2
   Serial number: 3564VRB405L352USD9A2
   Revision: --------    Serial number: 90372OC40003T
   Coding: 0000DC
   VCID: 372B29219F466D9F599-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 14 02 2015  B0046748
   Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
   Component: TDieRdwAcc    H08 0043
   Revision: 04001037    Serial number: 658050315596015
   Coding: 138E0A004F452008010400
   ROD: EV_RBD4K.rod
   VCID: 33331D318BBE81BF651-8066
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
   Component: Standheizung  H24 0260
   Revision: 66006006    Serial number: 20140912135011
   Coding: 5D3F01
   VCID: 2615F46548ECE417F2F-8072
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001752716
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 73B3DD31CB3EC1BFA51-8026
   Serial number: 6114185803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1412220000000000033D
   Revision: AA001002
   VCID: 7CA1F60DE6E08EC7F4B-8028
   Revision: AA000000    Serial number: 00000138195316
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABE921DFC6AD9F999-8022
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82093LMG
   ROD: EV_SARA2.rod
   VCID: 3635242598CC949742F-8062
   Coding: 040311
   Coding: 040311
                    Reset counter: 110
                    Mileage: 138796 km
                    Date: 2019.03.26
                    Time: 16:24:36
   Coding: 011F17015E00628002080013
   VCID: 45D753E9D5AA0F0FDB5-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0020537707
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 009013
   Revision: 00002001    Serial number: 0362711599
   Coding: 0100063800B93080C32008840C010E470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00011413809
   Coding: 011F17015E00628002080002
   VCID: 46D554E5E8AC0417D2F-8012
   Revision: --------    Serial number: 00000001381341
   VCID: 2D070B496D9AD74F335-8078
   Coding: 04FA02102A600200
   VCID: 34311E2D8EB086877CB-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
   Component: RMC Cnct Nav  H61 0139
   Coding: 0100000101D5DB474C2B060301010000000001
   VCID: 221DE87524C418379E7-8076
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464B/0F2705992
   Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OC50006O
   Coding: 010F15004000628002080002
   VCID: 49CF5FD9F9B2EB6F3FD-801C
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 044500038
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001022
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H27 0081
   Coding: 7A060000
   VCID: 2C01064D5680DE4724B-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7A04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270BF9614F66FD1FC99-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000620503157
   Coding: 04C099181211
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ROD: EV_RGS_L.rod
   VCID: 313F173971A2B3AF17D-8064
   ROD: EV_RGS_R.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150360032
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.2V)-----------
"Open or Short to Plus" for a warning lamp should be fairly straightforward. Check continuity from control module to lamp. Check lamp itself. Check ground connection on other side of lamp.
CuturiloD
Serbia
C?ID=361908
Unfortunately I was checked this few things.
Both of led light is good. Wiring installation from SLAVE modul to both lights in outside mirror is OK. No Open or Short to Plus.
I don't know what else I can check.
One more important thing, my side assist is retrofited.
I was instaled everything acording ELSA, coded the modules, and........nothing good. :(
Maybe someone have some idea.
One more thing, if I try to test output I reccive next message:
Dana
Western PA, USA
I replied to CuturiloD's email but failed to notice the photo above. The output test result may be perfect normal (meaning unsupported or unable to test due to the DTC). I wouldn't worry about that at this time.
My suggestions via email included starting a new thread in the Retrofits section rather than using this one in the New User sub-forum. Additionally I located an existing C1116 or C1117 thread:
https://forums.ross-tech.com/showth...bus-connection&p=138151&viewfull=1#post138151
.. which was solved in post #78 due to a discrepancy between terminal 30 (constant battery power) and terminal 15 power (switched power).
After reviewing the diagrams for this car; SF panel fuse ST4, SF5 should be terminal 15 (after the J329 - Terminal 15 voltage supply relay) so I would firstly make sure the power to J769 is switched.
Razor77
New Member
J770 replaced, error now "No or Incorrect Basic Setting / Adaptation"
            014 - Defective
Uwe, you were correct. Yes it's taken me until now to get a few steps further! I have replaced J770, and when I do the output test of 3C the blindspot indicators light up correctly.
I still have errors on 3C "No or Incorrect Basic Setting / Adaptation" Would I be correct to assume the units now need calibration to function? Or can I manually add the correct Basic Settings / Adaptation?
Ideally, I want to save the excessive cost of calibration at about £350+20%VAT. If that's required I might attempt to make my own board if I can find the software.
Saturday,04,July,2020,13:43:06:46808
VCDS Version: 20.4.1.0
VIN: WAUZZZ*  License Plate:
VIN: WAUZZZ*   Mileage: 117972km-73304miles
   Coding: 0001102
   VCID: 306FF18BA3958B06BB-8064
   Subsystem 3 - Serial number: 5F23.07.1300H03000AMS15788ÿ
   Subsystem 4 - Serial number: S15788ÿ
02849 - Control Module for Lane Change Assistance (J769)
                    Fault Status: 01100101
                    Fault Frequency: 17
                    Reset counter: 229
                    Mileage: 102052 km
                    Date: 2019.08.23
                    Time: 20:48:48
                    Fault Frequency: 17
                    Reset counter: 229
                    Mileage: 102052 km
                    Date: 2019.08.23
                    Time: 20:48:48
