Razor77
New Member
- Feb 25, 2018
- 4
- 0
- UK
- hexa193-00c68a-88b6d8-ccb527-tjhahh-5d05
Hello, my ACC is not working,
I have a low milage Audi A6 C7, delivered September 2013, I think that makes it MY2014?
A week back I noticed ACC would not work, when i tried it triggered the dash error message "ACC and Audi braking guard:not available". I pressed a few buttons, including the Side Assist button and got the error message "Audi side assist: system fault!"
An auto-scan revealed a lot of malfunctions, I assume all are connected to one failure. I found by resetting the "3C Lane Change" faults, while they immediately repopulate in VCDS and trigger the dash "Audi side assist: system fault!", ACC and brake guard will work for so long if I don't turn the engine off. During this period of working, the Side Assist light in the right wing mirror glows at about 5% (just visable), when the ACC fails again, the glow goes.
Doing a Output Tests on 3C yields the following results;
"Warning Lamp for Lane Change Assitance (in left exterior mirror) (K233)" The lamp on the left mirror does not light up, the lamp on the right mirror does - brightly (28s in the video).
"Warning Lamp for Lane Change Assitance (in right exterior mirror) (K234)" Neither lamp is bright, but both have a trace of light, about 5%. (48s and 50s in the video, it's there, but can barely be noticed)
Could it be as easy as needing to swap out the Side Assist lamp in the right mirror? Or is the "007 - Short to Ground" in the auto-scan misleading? Also having Googled "02850 - Control Module 2 for Lane Change Assistance (J770) 014 - Defective" it suggests J770 may need to be replaced, and will require calibration. I am hoping this is not required, and just a consequence of something simpler.
Other factors that might help;
Here is the auto-scan
- I've had the car from new, it had minor damage last September when the front bumper hit a short post. Requiring a new bumper, which incurred need to calibrate all sensors. Could the cause be related?
- I didn't have the bumper repaired immediately, but about 6 weeks later, during that time for the period of a week and ACC stopped working with the same dash message. I made presumption it was related to the ACC radar, as the damage was near this location.
- I don't really pay attention to Side Assist, so I can't say when it first failed.
Sunday,25,February,2018,20:05:26:46808
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.2.0.3 (x64)
VIN: WAUZZZ4G9EN035975 License Plate: xxx
Mileage: 64671km-40184mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 3B 3C 42 44 46 52
53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4G9EN035975 Mileage: 64671km-40184miles
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 C HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0002
Revision: 57H25---
Coding: 122A4032256603020000
Shop #: WSC 57891 001 1048576
ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
ROD: EV_ECM30BTD_AU57.rod
VCID: 3467FD9B9F8DB7E4CC-8061
Part No SW: 4G0 927 158 K HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1003
Revision: --H16---
VCID: 3663C79389F1A5F4F2-8063
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 49B79F0192EDF980DB00
Shop #: WSC 02391 785 00200
VCID: 3B75D6A7B2D3789C0D-806F
Part No SW: 4H0 907 064 DN HW: 4H0 907 064 DN
Component: BCM2 2.0 H35 0510
Coding: 01B93046000000000000
VCID: 78FF09ABCB65938420-802D
Serial number: 2313000123598002
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AB HW: 4G0 820 043 AB
Component: KLIMA 2 ZONEN H11 0087
Serial number: 09071300111071
Coding: 3622000825
ASAM Dataset: EV_AirCondiBasisUDS 002045
VCID: 5FCD4237468B44BC41-800B
0019 - Motor for Fresh Air / Recirculated Air Flap
B11AF 07 [008] - Mechanical Failure
Fault Frequency: 11
Reset counter: 139
Mileage: 60468 km
Date: 2017.12.19
Time: 16:57:23
Voltage terminal 30: 13.32 V
Outside air temperature: 8.5 °C
Interior temperature: 13.14 °C
Fresh air door motor-Act.val.: 11133
Fresh air door motor-Specified value: 10106
Fresh air door motor-Stop open: 11391
Fresh air door motor-Stop closed: 10000
0035 - Motor for Recirculation Flap
B1092 07 [008] - Mechanical Failure
Fault Frequency: 6
Reset counter: 121
Mileage: 60250 km
Date: 2017.12.15
Time: 11:10:22
Voltage terminal 30: 13.22 V
Outside air temperature: 12.5 °C
Interior temperature: 20.72 °C
Recirculation flap motor-Act.val.: 10770
Recirculation flap motor-Specified value: 11741
Recirculation flap motor-Stop open: 11440
Recirculation flap motor-Stop closed: 10000
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001595824
Coding: 2600201040749FE2A18100C000001D0CCF9DC7082F09020100 0004606100
Shop #: WSC 37488 001 1048576
VCID: 6DD128FFB427262CC3-8039
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 130629 H36 0080
Serial number: 130702115015
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21535273
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 08 07 2013 00002041
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: A66949B6000000000001
Revision: 11001001 Serial number: 61061319701882
Coding: A8EB08
VCID: 71E9348FA01FC2CCE7-8025
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E04010202
VCID: 285F19EB5345C30470-807D
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 100
Mileage: 64171 km
Date: 2018.02.20
Time: 08:49:17
Control Module temperature: 6 °C
Voltage terminal 15: 13.039 V
Velocity_vehicle_reference: -0.54 m/s
Longitudinal_acceleration_vehicle_reference: 0.88 m/s²
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00E778V
Coding: 3032343631334E303539554A305234473053
Serial number: 3575HRB400G50GS8B1QI
Serial number: 3585HRB400I50GS8G1CC
Serial number: 3515JRB401650K2GB8N
Serial number: 3525JRB401G50K2GDPHJ
Serial number: 3554VRB400Q50KJOK1PF
Serial number: 3564VRB400650KBAHP2F
Revision: -------- Serial number: 90372MGB000BX
Coding: 0000FD
VCID: 377DCA9786FB5CFCE9-8063
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 27 06 2013 E0188090
Part No SW: 4G8 920 984 P HW: 4G8 920 984 P
Component: TDieGb Acc H80 0618
Revision: 30460230 Serial number: 658240613596009
Coding: 338F11008F512600010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 4385AE47CA23005C45-8017
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001026414
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 3844710903
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130509000000000001A0
12290 - Quiescent Current
U1406 00 [009] - Too High
Reset counter: 8
Mileage: 60724 km
Date: 2018.01.05
Time: 07:37:11
Voltage terminal 30: 11.9 V
Voltage terminal 15: 0.0 V
System status: LIN_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02028264747464545425363E00
VCID: 7CF715BBFF5DBFA444-8029
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 000207130001630
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 275D1AD75E5BCC7C79-8073
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00KBFI
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 377DCA978EFB5CFCE9-8063
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0001102
VCID: 306FF18BA3958BC4A8-8065
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F16.07.1300H03000AMS15750ÿ
Subsystem 4 - Serial number: S15750ÿ
014 - Defective
Fault Status: 01101110
Reset counter: 84
Mileage: 64171 km
Date: 2018.02.20
Time: 08:49:16
02854 - Warning Lamp for Lane Change Assistance (in right exterior mirror) (K234)
Fault Status: 01100111
Reset counter: 100
Mileage: 64671 km
Date: 2018.02.25
Time: 17:58:10
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F16005C01628002080013
VCID: 4581B05FCC173E6C6B-8011
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0014675563
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BFB836599B9D4DE-8067
Revision: 00002001 Serial number: 0311070386
Coding: 013B0622A0B93080832009040C010F47000000000000000000 0000000000
Component: TSG BF H03 0507
Coding: 011F16005E01628002080002
VCID: 4683B753F111357462-8013
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000761878
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C57E5FB47BDEF2494-8079
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130717-0002-126
Coding: 1122A6101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D51E8FF7CA7E62C83-8079
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109G20D7693338
Coding: 010103020100000001
VCID: 264317D35151D57442-8073
Part No SW: 4G0 035 670 K HW: 4G0 035 670 H
Component: H-BNT-EU H51 0732
Revision: -------- Serial number: 190E40G7558366
Coding: 050101010003E9EF3D90CB3E00000003000001000000000000
Shop #: WSC 55157 001 1048576
VCID: 2B55E6E74AB3E81C9D-807F
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD0029GCO
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Serial number: 90349MGI000I7
Component: CD-Database 5298
Component: TSG HL H03 0507
Coding: 010F14004001628002080002
VCID: 4999BC6FE00FDA0C8F-801D
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H07--- Serial number: 525 PA8J36G80T
Coding: 1080005
VCID: 264317D39151D57442-8073
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 185300125
Coding: 097205C010
ROD: EV_HDSGAu571.rod
VCID: 3561C09F94F7AEECFB-8061
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 264317D35951D57442-8073
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E04010202
U1113 00 [009] - -
Reset counter: 100
Mileage: 64171 km
Date: 2018.02.20
Time: 08:49:16
Control Module temperature: 5 °C
Voltage terminal 15: 13.661 V
Velocity_vehicle_reference: -0.57 m/s
Longitudinal_acceleration_vehicle_reference: 0.86 m/s²
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000120507137
Coding: 04C2381A1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 100
Mileage: 64171 km
Date: 2018.02.20
Time: 08:49:17
Outside air temperature: 6.5 °C
Voltage terminal 15: 13.6 V
Control Module temperature: 8.0 °C
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169F48F609F82CCA7-8065
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 130606200478
VCID: 2B55E6E742B3E81C9D-807F
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 130704200929
VCID: 24470DDB2F6D27645C-8071
End-------------------------(Elapsed Time: 07:36)--------------------------
