Tuesday,13,February,2018,22:25:53:54234
VCDS Version: 17.8.1.0
Workshop Code: 552 08316 000000
VIN: WAUA7GFF1G1026550 License Plate: A3_ALL_WEATHER
Mileage: 34546km-21465mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF1G1026550 Mileage: 34546km-21465miles
Address 01: Engine (J623-CNSB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1D00122424000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3F8D31A7A6AE66BEA8-806A
Readiness: 1110 1101
Part No SW: 0D9 300 042 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4906
Revision: 06253104 Serial number: TFK01506040359
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 1939BF3F184A688E76-804C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62015000001070
Coding: 13FF6A9234220A72017C020581C329C8562C5080408194B4024100548208
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79F99FBFF80A888ED6-802C
Revision: 00021000 Serial number: 0374987175
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A7B40B3BD8C43969F-806E
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000695207
Coding: 03000014010000000000000000001400
VCID: 326B689365FCBBD657-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A2998BB7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061519800050
Coding: 04151C42C04122FD41C04004511007000800000000000000000000000000
Shop #: WSC 08316 552 00000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 7F0D71A7E62EA6BEE8-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150710 042 0585
Serial number: 150715213512
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24098735
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 23 11 2012 00000047
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000063211765
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000FJNI300000
Coding: 101F00
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331519803516
Coding: 0010150011
VCID: 43853D57CA46025ECC-8016
Component: AirbagVW20 010 0830
Serial number: 003GCR02UDN/
Coding: 9DCCFCC0000000005000001AC24800000065
VCID: 479D2947FE7E2E7E10-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A21071571217
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A22071540107
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001DCUYN
Coding: 303332
Subsystem 4 - Part No SW: ----------- HW: 480 001 507 15
Serial number: 357000000008F010851A
Subsystem 5 - Part No SW: ----------- HW: 480 001 507 15
Serial number: 3580000000026D20851A
Subsystem 6 - Part No SW: ----------- HW: 480 400 907 15
Serial number: 3510002A11B7E8F3A39H
Subsystem 7 - Part No SW: ----------- HW: 480 401 607 15
Serial number: 3520002B71C52F41C242
Subsystem 8 - Part No SW: ----------- HW: 480 400 805 15
Serial number: 3550002BF1A2DCD3712J
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 805 15
Serial number: 3560002A31A91E71633+
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 23071508490747
Coding: A018
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 0501E34F84F2FC6EA2-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 960 M HW: 8V0 920 960 M
Component: KOMBI H03 6420
Coding: 0BED19192B80D7050200A8001800000000000000
VCID: 4581234FC4723C6EE2-8010
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 17071510800707
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 75E1938FD412ECEEB2-8020
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 03 07 2015 C0013266
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000173143005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34676E8B9FE8B5E645-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 040715BG317548
Coding: 00101B204000048000000002
VCID: 4189375FD05A104EDE-8014
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 100715BGA08623
Coding: 001013204000048000000002
VCID: 408F325BDB501946D1-8014
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 011E000020220200
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
Subsystem 1 - Part No SW: 7PP 941 472 A HW: 7PP 941 472 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H06 5050
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 A HW: 7PP 941 472 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H06 5050
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 C HW: 7PP 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo links H01 4000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 C HW: 7PP 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 4000
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 013 0660
Serial number: A7A01207150603
Coding: 01730100FF0A000011220001001A00002F0001440100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 39795FBFB88A488E96-806C
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30C77Z
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000013051500030284
B11CF 53 [009] - Deactivated
Reset counter: 8
Mileage: 34546 km
Date: 2018.02.07
Time: 06:33:02
Voltage terminal 30: 12.3 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAVW428.rod
VCID: 306F629B6BF089C621-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 020715BG20801B
Coding: 000013204000048000000002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Component: TSG HBFS 020 0041
Serial number: 020715BG208018
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
