Audi A3 8V 2016 Lane change + Adaptive cruise control + MMI navigation Plus
Autokorektas
Lithuania
C?ID=273842
Hello members,
I have some oncoming projects with an Audi A3 8V 2016 year and want to be sure of some things before starting.
As you saw I wish to have Lane change assist, ACC, and MMI navigation plus (7 inch screen instead of mine 5").
The questions are :
1.Am I thinking of purchasing correct parts?
For Lane change:
- A pair of radar sensors with brackets in the rear bumper;
- A pair of rear view mirror covers with orange indicator LED's;
For Adaptive cruise control:
-Acc "eye" in the front of the car;
-Cruise control stalk with acc option;
-Instrument cluster? (now I have single color (White/black) Instrument cluster);
For MMI Navigation Plus:
-7 inch screen;
-MMI navi + control head (with 2 sd card slots);
2.Will my car accept all the things? How to check i.e. if ABS will accept Acc?
3.Which modules will have component protection?
If anyone has any info, did something similar, or can help me anyhow, will be much appreciated!
Thanks in advance!
CGL
C?ID=20836
Full scan first!
1 CAN Gateway (J533) must be MQB High for
ACC
Lane change assist
Front camera assist system
LED or Xenon control
2 CP CAN Gateway
Instrument cluster
MMI control head
Cent. Elect.
3 Instrument cluster YES
PRCode: 8T3 = Adaptive Cruise Control and cruise control system
PRCode: 8T5 = Distance control plus cruise control
4 Abs change coding
WHT 003 857 A rear speed sensor x2
Autokorektas
Lithuania
C?ID=273842
My full scan:
Tuesday,13,February,2018,22:25:53:54234
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
Workshop Code: 552 08316 000000
VIN: WAUA7GFF1G1026550   License Plate: A3_ALL_WEATHER
Mileage: 34546km-21465mi   Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF1G1026550   Mileage: 34546km-21465miles
Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1D00122424000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3F8D31A7A6AE66BEA8-806A
Readiness: 1110 1101
   Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01506040359
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 1939BF3F184A688E76-804C
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62015000001070
   Coding: 13FF6A9234220A72017C020581C329C8562C5080408194B4024100548208
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 79F99FBFF80A888ED6-802C
   Revision: 00021000    Serial number: 0374987175
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A7B40B3BD8C43969F-806E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000695207
   Coding: 03000014010000000000000000001400
   VCID: 326B689365FCBBD657-8066
   Serial number: A2998BB7000000000001
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061519800050
   Coding: 04151C42C04122FD41C04004511007000800000000000000000000000000
   Shop #: WSC 08316 552 00000
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 7F0D71A7E62EA6BEE8-802A
   Component: WWS371 150710  042 0585
   Serial number:         150715213512
   Coding: 0A47F7
   Serial number: 24098735
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 23 11 2012  00000047
   Serial number: 00000000000063211765
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000FJNI300000
   Coding: 101F00
   Revision: --------    Serial number: 39331519803516
   Coding: 0010150011
   VCID: 43853D57CA46025ECC-8016
   Serial number: 003GCR02UDN/
   VCID: 479D2947FE7E2E7E10-8012
   Belt Pretensioner left:
   Serial number: 34230167A21071571217
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A22071540107
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001DCUYN
   Coding: 303332
   Subsystem 4 - Part No SW: -----------    HW: 480 001 507 15
   Serial number: 357000000008F010851A
   Subsystem 5 - Part No SW: -----------    HW: 480 001 507 15
   Serial number: 3580000000026D20851A
   Subsystem 6 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3510002A11B7E8F3A39H
   Subsystem 7 - Part No SW: -----------    HW: 480 401 607 15
   Serial number: 3520002B71C52F41C242
   Subsystem 8 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3550002BF1A2DCD3712J
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 805 15
   Serial number: 3560002A31A91E71633+
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 23071508490747
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0501E34F84F2FC6EA2-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6420
   Coding: 0BED19192B80D7050200A8001800000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 4581234FC4723C6EE2-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17071510800707
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 75E1938FD412ECEEB2-8020
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 03 07 2015  C0013266
   Revision: 00000000    Serial number: 15000173143005
   Coding: 5D00000000000000
   VCID: 34676E8B9FE8B5E645-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 040715BG317548
   Coding: 00101B204000048000000002
   VCID: 4189375FD05A104EDE-8014
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 100715BGA08623
   Coding: 001013204000048000000002
   VCID: 408F325BDB501946D1-8014
   Component: AFS-ECU       H01 0091
   Coding: 011E000020220200
   Subsystem 1 - Part No SW: 7PP 941 472 A    HW: 7PP 941 472 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H06 5050
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 A    HW: 7PP 941 472 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H06 5050
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 C    HW: 7PP 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 4000
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 C    HW: 7PP 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 4000
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     013 0660
   Serial number: A7A01207150603
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 39795FBFB88A488E96-806C
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30C77Z
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000013051500030284
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 8
                    Mileage: 34546 km
                    Date: 2018.02.07
                    Time: 06:33:02
                    Voltage terminal 30: 12.3 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 306F629B6BF089C621-8064
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 020715BG20801B
   Coding: 000013204000048000000002
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
   Serial number: 020715BG208018
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
Another question : Is it necessary to have front camera assist system, if I want acc?
downtime
Finland
C?ID=280813
No, ACC will also work without front assist camera system.
BUT 8V is MQB platform A3. ACC retrofit is not just install the parts and code them away.
First of all, if your car does not have ACC from factory, the car does not have the FEC (feature enablement code) for it and ACC is disconnected immediately when it talks with gateway. You CANNOT buy the feature from Audi as aftermarket. Factory only I'm afraid. And no way to circumvent it easily.
Only option is to get hacked ACC radar, install that and have an authorized workshop to remove component protection from the radar to make the gateway accept it.
Positive side, your gateway is ok for ACC and also your ABS module should be fine. What you would need to change are the rear ABS sensors to WHT3864A if your car does not have park assist system (the one that automatically parks the car).
Autokorektas
Lithuania
C?ID=273842
Thanks for your reply. I see now that it's not as easy as I thought.
And what about lane change assist? (sensors ir rear bumper, LED's in side mirrors). This one could be retrofitted, right?
And mmi navi +?
vastechnics
C?ID=143747
ACC is very difficult due to the SWAP codes. Lane change assist is possible with the good ABS module and als Gateway High is needed. MMI + is also possible ask for APG. They deliver complete sets.
DarkyUK
C?ID=61560
And mmi navi +?
Hi Autokorektas
Did you get any further with this? I'm considering adding ACC to my A5 and looking at the SWAP Code or alternative routes.
Cheers, Andy
