Can anyone assist me with adding an RNS510 and Bluetooth module 1K8035730D to my 2011 Polo 6R please? I've installed the devices and initially Bluetooth pairs when the ignition is switched on and the RNS510 seems to work ok but always starts in Germany (Regensburg syndrome). Bluetooth connectivity does work but does not interface to the RNS 510 and so to answer or make a call you have to use the phone rather than the touch screen.
I assumed this was due to the car being unaware of the Bluetooth and RNS510 and so added them using the coding assistant. However once the coding is complete the Bluetooth no longer pairs and the RNS 510 is unable to find any satellites. If I remove the coding and set it back as it was the systems all work fine but with the original limitations.
Can anyone offer any thoughts as to why this might be please?
Wednesday,02,August,2017,11:04:29:30096
VCDS Version: 17.8.0.1
VIN: WVWZZZ6RZBU039512 License Plate:
Mileage: 79960km-49684mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 37 44 56 77
VIN: WVWZZZ6RZBU039512 Mileage: 79960km-49684miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00053 210 89422
VCID: 6CD1A7B64CFE672646-5164
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 230224E3217000BBC42A24E384D300801100
Shop #: WSC 31414 790 31414
VCID: 0605F51EB552BD76B0-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 356742D29C34E6EE69-8060
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 F HW: 6R0 937 086
Component: BCM PQ25 M++4 H46 0221
Revision: BD046001 Serial number: 0343 266101082
Coding: 24B02BBF08A10000003000003D2B0CD00040410F60060000200000000000
VCID: 3F8B20FAAE082CBEB3-806A
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU007.09.1010737
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU003.09.1011464
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU001.09.1012719
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU009.09.1011534
Coding: 08BC32
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag00N H09 0020
Revision: -------- Serial number: 003GX00A7DWS
Coding: 00304E
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A9D012EEDCA991614-801E
Serial number: 3572SRB40000C9DC726J
Serial number: 3582SRB40000C8995237
Serial number: 3515RRB40616VQ8AGHI7
Serial number: 3525RRB40636VQ8A5OMA
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6R0 920 960 F HW: 6R0 920 960 F
Component: KOMBI H04 0304
Coding: 440200
Shop #: WSC 31414 790 50316
ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
VCID: 38794BE683261B8672-806C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086
Component: GW-K-CAN TP20 0221
Coding: 002300
VCID: 70E9B3C6A3D683C67A-8024
Mileage: 79965 km
Date: 2011.12.22
Time: 21:15:12
Component: IMMO H04 0304
VCID: 6ADDA1AE8D0A791634-803E
Part No SW: 1T0 035 680 L HW: 1T0 035 680 P
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z747071112
Coding: 04000402040000000001
Shop #: WSC 05314 123 12345
VCID: 377B48DA863814FE7B-8062
Component: EU West V14 8477
00857 - CD Changer Unit (R41)
Reset counter: 84
Mileage: 77760 km
00876 - Treble Speaker Rear Left (R14)
Fault Status: 00101011
Fault Frequency: 11
Reset counter: 84
Mileage: 79960 km
00877 - Treble Speaker Rear Right (R16)
Fault Frequency: 11
Reset counter: 84
Mileage: 79960 km
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F6B70BAEA68DC3E23-807A
Reset counter: 84
Mileage: 77760 km
Fault Frequency: 11
Reset counter: 84
Mileage: 79960 km
Fault Frequency: 11
Reset counter: 84
Mileage: 79960 km
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A08700500
Coding: 412020
Shop #: WSC 00078 790 00190
VCID: 2A5D61AE458AB916F4-807E
End-------------------------(Elapsed Time: 03:00)--------------------------
