- Apr 9, 2014
- 2,306
- 2,253
- Tartu, Estonia
- C?ID=195131
If it had DSG, ACC, Xenon, Aux.Heat and Lane assist, it would be best budget car.
Friday,21,July,2017,15:59:10:36026
VCDS Version: 17.6.0.2 (x64) HEX-NET CB: 0.4346.4
Data version: 20170602 DS274
VIN: TMBEN6NJXHZ License Plate: SKODA
Mileage: 7218km-4485mi Repair Order:
Chassis Type: NJ (6C0)
Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F
VIN: TMBEN6NJXHZ Mileage: 7218km-4485miles
Address 01: Engine (J623-CJZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 9086
Revision: R4H23---
Coding: 01190032232415080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
ROD: EV_ECM12TFS01104E906027BC.rod
VCID: E680FDD419EBF777DB-80B2
CAN Converter 01:
Part No SW: 6C0 907 379 R HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08512591161026
Coding: 41F5487D4B2C33C10918106F00518212D2CC9008000DCBF98F00
Shop #: WSC 13765 031 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: BE3075B421FB8FB773-80EA
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0421560960
Coding: 032C0C
Shop #: WSC 13765 790 00000
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: BB367CA032E99A9F54-80EE
Address 08: Auto HVAC (J255) Labels:| 6C0-907-044.clb
Part No SW: 6V0 907 044 B HW: 6V0 907 044 B
Component: Climatronic H01 0203
Serial number: 1610263A-0094
Coding: 100000001111100001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: B6206D9409CB47F7AB-80E2
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-090-V1.clb
Part No SW: 6C0 937 090 D HW: 6C0 937 090
Component: BCM PQ26 HiKR H10 0094
Serial number: 006318014581
Coding: 0C01085042050AFB43804000403D07080800D900D2013500000000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_SK25.rod
VCID: A91AB6E8C875180F36-80FC
Subsystem 1 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y16M11D11H05M58S55
Coding: 00185E
Component: PARKHILFE 7K H03 0054
Revision: -------- Serial number: 39331630901159
Coding: 0031051041
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: C3C604404A19E25F1C-8096
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 K HW: 5Q0 907 572 K
Component: ACC Bosch MQB H05 0402
Serial number: 08111604533929
Coding: 00000000FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: BFCE08B026F186BF78-80EA
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 K HW: 6C0 959 655 K
Component: VW20Airbag743 002 0380
Revision: -------- Serial number: 003TJ008JKZ4
Coding: 88CCC000000000005C5400CF000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
Subsystem 1 - Part No SW: ----------- HW: 410 822 410 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00C522656514368
Subsystem 2 - Part No SW: ----------- HW: 410 822 410 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A722AE86130BQ
Subsystem 3 - Part No SW: ----------- HW: 442 152 210 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00C12182425538-
Subsystem 4 - Part No SW: ----------- HW: 442 152 210 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12182423724W
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6V0 920 746 B HW: 6V0 920 746 B
Component: KOMBI 202 2310
Coding: 072501102180000801882A011000000000000000
Shop #: WSC 73430 031 12345
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: BA3879A43DD3A3974F-80EE
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 090
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006318014581
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: A600BDD4D96B37771B-80F2
Subsystem 1 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B1472281016
Subsystem 2 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 63300B22185881837337
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
Reset counter: 146
Mileage: 7011 km
Date: 2017.07.14
Time: 17:46:55
Terminal 15: OFF
8531970 - Quiescent Current
U1406 00 [008] - Too High
Fault Frequency: 45
Reset counter: 158
Mileage: 5759 km
Date: 2017.06.07
Time: 22:47:21
Supply voltage: Terminal 30: 12.3 V
Terminal 15: OFF
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000183831010
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: B424579C1FB755E795-80E0
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AJ HW: 6C1 909 144 D
Component: EPS_TRW_ALow 313 3242
Serial number: CGB80849
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: F0AC9B8C2B2F29C7B1-80A4
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 B HW: 5Q0 035 840 B
Component: MU-S--ER H30 0359
Serial number: SKZAZ2S5260767
Coding: 03620000BE00000011110004000808002F0107C40120010002
Shop #: WSC 73430 790 12345
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: AC144FFCC7870D27CD-80F8
Subsystem 1 - Part No SW: 6V0 919 604 B HW: 6V0 919 604 B
Component: ABTm_Std2 H42 1041
Serial number: SKZ8Z9SLX00MTH
End----------(Elapsed Time: 01:39, VBatt start/end: 14.4V/14.4V)-----------
