Hi all,
Looking at the below scan of my car, could you let me know the options to rectify please?
Could this be a faulty 1K0 937 049 T module?
Thursday,15,June,2017,21:41:41:20472
VCDS Version: 17.1.3.0
Dealer/Shop Name: S81 Diagnostics
VIN: WVWZZZ1KZ5W086199 License Plate: YC05YPG
Mileage: 146190km-90838mi Repair Order:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ5W086199 Mileage: 146190km-90838miles
56-Radio -- Status: Not registered 0001
Address 01: Engine Labels: None
Part No SW: 06F 906 056 DE HW: Hardware No
Component: MED9.5.10 00 7224
Revision: 00000000 Serial number: VWZ7Z0D0539519
Coding: 0000072
Shop #: WSC 00600 210 91852
VCID: 6FE7DFF67ED2F43900-803A
Subsystem 1 - Part No: 06F 907 807 F
Component: NOX 0908280063 002 0409
06F907807F NOX 0908280063 002 0409
19490 - Intake Air Temperature Sensor 2 (G299)
P3034 - 002 - Signal too Large - Intermittent
Readiness: 0000 0001
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 01279 785 00200
VCID: 3A713EA275106191E7-806E
Part No: 1K0 907 044 AB
Component: ClimatronicPQ35 066 0404
VCID: 67D7B7D656222C7948-8032
01810 - Actuating Motor for Temperature Flap; Right (V159)
00716 - Air recirculation Flap Positioning Motor (V113)
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000945140
Coding: E5050E060004181E001400001400000000
VCID: 40854C4A13CC3B41A9-8014
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
02398 - Control Circuit for Rear Windshield Washer Pump
009 - Open or Short to Ground
00156 - Control Circuit for Windshield Washer Pump
02401 - Terminal 75x
01800 - Light Switch (E1)
00897 - Windshield Washer Pump (V5)
Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
Component: 02 AIRBAG VW8 023 0700
Revision: 06023000 Serial number: 00385D0K0XZV
Coding: 0012338
Shop #: WSC 01268 785 00200
VCID: 3163198EA866A2C956-8064
Subsystem 1 - Serial number: 6332MSME50357E05
Subsystem 2 - Serial number: 6342MSME48211405
Subsystem 3 - Serial number: 6351HSME75416F03
Subsystem 4 - Serial number: 6361HSME015A6A03
Part No SW: 1K0 953 549 AM HW: 1K0 953 549 AM
Component: J0527 036 0071
Coding: 0000012
VCID: 7DFBF5BE24BE96A982-8028
Part No: 1K0 920 961 A
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003403
Shop #: WSC 00600 067 57207
VCID: 2855F4EA9BBCE30181-807C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 251109F2001669
Coding: E9807F06000002000003
VCID: 69D3B1EE40361A095E-803C
Mileage: 146094 km
Time: 21:26:37
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
VCID: 30651C8AA36CABC159-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.1 1301
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 98C802087F2D8505485FC69010
Shop #: WSC 00000 785 00200
VCID: 7BFFFBA63AAA9899BC-802E
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Subsystem 3 - Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Part No SW: 1K0 035 186 T HW: 1K0 035 186 T
Component: Radio FO3 021 0014
Revision: 00021000 Serial number: VWZ7Z2G0009276
Coding: 0010400
Shop #: WSC 00221 210 64224
VCID: 3777279646027CF918-8062
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
End-------------------------(Elapsed Time: 02:01)--------------------------
