09 - Central Electronics faults - MK5 Golf (1K)
DazJ
C?ID=138512
Hi all,
Looking at the below scan of my car, could you let me know the options to rectify please?
Could this be a faulty 1K0 937 049 T module?
Thursday,15,June,2017,21:41:41:20472
VCDS Version: 17.1.3.0
Dealer/Shop Name: S81 Diagnostics
VIN: WVWZZZ1KZ5W086199   License Plate: YC05YPG
Mileage: 146190km-90838mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5W086199   Mileage: 146190km-90838miles
56-Radio -- Status: Not registered 0001
   Part No SW: 06F 906 056 DE    HW: Hardware No
   Component: MED9.5.10        00 7224
   Revision: 00000000    Serial number: VWZ7Z0D0539519
   Coding: 0000072
   Shop #: WSC 00600 210 91852
   VCID: 6FE7DFF67ED2F43900-803A
   Subsystem 1 - Part No: 06F 907 807 F
   Component: NOX  0908280063 002 0409
   06F907807F  NOX  0908280063 002 0409
19490 - Intake Air Temperature Sensor 2 (G299)
            P3034 - 002 - Signal too Large - Intermittent
Readiness: 0000 0001
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   Shop #: WSC 01279 785 00200
   VCID: 3A713EA275106191E7-806E
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   VCID: 67D7B7D656222C7948-8032
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000945140
   Coding: E5050E060004181E001400001400000000
   VCID: 40854C4A13CC3B41A9-8014
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
02398 - Control Circuit for Rear Windshield Washer Pump
            009 - Open or Short to Ground
00156 - Control Circuit for Windshield Washer Pump
02401 - Terminal 75x
            006 - Short to Plus - Intermittent
01800 - Light Switch (E1)
00897 - Windshield Washer Pump (V5)
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 02 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0K0XZV
   Coding: 0012338
   Shop #: WSC 01268 785 00200
   VCID: 3163198EA866A2C956-8064
   Subsystem 1 - Serial number: 6332MSME50357E05
   Subsystem 2 - Serial number: 6342MSME48211405
   Subsystem 3 - Serial number: 6351HSME75416F03
   Subsystem 4 - Serial number: 6361HSME015A6A03
   Part No SW: 1K0 953 549 AM    HW: 1K0 953 549 AM
   Component: J0527           036 0071
   Coding: 0000012
   VCID: 7DFBF5BE24BE96A982-8028
   Part No: 1K0 920 961 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003403
   Shop #: WSC 00600 067 57207
   VCID: 2855F4EA9BBCE30181-807C
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 251109F2001669
   Coding: E9807F06000002000003
   VCID: 69D3B1EE40361A095E-803C
            000 -  -
                    Mileage: 146094 km
                    Time: 21:26:37
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   VCID: 30651C8AA36CABC159-8064
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.1       1301
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 98C802087F2D8505485FC69010
   Shop #: WSC 00000 785 00200
   VCID: 7BFFFBA63AAA9899BC-802E
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio FO3       021 0014
   Revision: 00021000    Serial number: VWZ7Z2G0009276
   Coding: 0010400
   Shop #: WSC 00221 210 64224
   VCID: 3777279646027CF918-8062
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End-------------------------(Elapsed Time: 02:01)--------------------------
downtime
Finland
C?ID=280813
Does the rear washer pump work?
Does it leak? The design of these washer pump connections especially to the rear are a bit poor. This causes sometimes the pipe to leak inside the boot door and cause all shorts of electrical failures.
Remove the boot lid inner cover and check first that the washer pipe is not leaking. The symptoms look a bit like it is.
DazJ
C?ID=138512
Nope, neither of the washer pumps work, no sign of water behind boot lid trim.
All fuses are okay, and reversing lamp is working in a different car.
downtime
Finland
C?ID=280813
Maybe the pump has then given it's final breath? :)
Open or short to ground indicates that there's a short circuit somewhere. Either in the pump itself or in the wiring to the pump. You could of course remove the pump and try to run it with external 12v power to see if the pump really is the issue.
DazJ
C?ID=138512
Thank you,
Can you confirm that 1J6955651 is the right part number for the pump?
downtime
Finland
C?ID=280813
Sorry, looked first at the rear wiper motor.
Pump is 1K6955651 according to ETKA.
DazJ
C?ID=138512
Ordered a new pump, will keep you updated
DazJ
C?ID=138512
New pump fitted and still not working.
Going to try relay once it's found
downtime
Finland
C?ID=280813
Have you checked the wiring? Especially wires inside the tube between hatch door and frame
DazJ
C?ID=138512
Faulty relay. Replaced relay behind panel next to steering wheel.
Works okay now.
