I have a friend whose 2006 Touareg is locked in park. It likely has other issues too, but for now we would just like to get it out of park. So far the only thing I have done is the auto scan. I have no clue what to do next. As far as I know the car is stock.
Any help is much appreciated. (a bigger hammer maybe?)
Here is my auto scan.
Thank you
Thank you
Thursday,04,May,2017,13:31:01:18849
VCDS Version: 17.1.3.0 (x64)
VIN: WVGZG77LX6D046461 License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZG77LX6D046461 Mileage: 165980km-103135miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 GT HW:
Component: MOTRONIC ME7.1.1G 9911
Revision: 00000000 Serial number: VWZ3Z0E2409350
Coding: 0000133
Shop #: WSC 45705 000 1048576
VCID: 63C54C8CA11C195994-5124
6 Faults Found:
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 002 - - MIL ON
Fault Status: 11100010
Mileage: 165390 km
RPM: 2092 /min
Load: 48.6 %
Speed: 90.0 km/h
Temperature: 64.0°C
Temperature: 9.0°C
Absolute Pres.: 970.0 mbar
Voltage: 0.000 V
005701 - Powertrain Data Bus
P1645 - 008 - Missing Message from AWD Controller
Mileage: 165390 km
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 008 -
Mileage: 165390 km
049409 - No Communication with Transmission Control Module
U0101 - 008 - - MIL ON
Mileage: 165390 km
049441 - No Communication with ABS Brake Control Module
U0121 - 008 -
Mileage: 165390 km
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - MIL ON
Mileage: 165390 km
Readiness: 0000 1100
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 HW: 5WK 484 91
Component: Kessy 6700
Revision: 67005614 Serial number: VWZ3Z0E2409350
Coding: 0000232
Shop #: WSC 31414 000 00000
VCID: 6ED32DB87ADEA4310B-5124
Component: ELV XXXX
6 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
009 - Open or Short to Ground
00576 - Terminal 15
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 L
Component: CLIMAtronic R/L 4017
Coding: 0020030
VCID: 3979CEE473103389EE-5142
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0100447
VCID: 4683B51832EE4C7193-5124
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0007101;
Coding: 0012341
VCID: 285F1BA098BABA0181-5124
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0000031
VCID: 4487AF1004D27E618D-5142
00532 - Supply Voltage B+
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 971 G
Component: KOMBIINSTRUMENT RB8 2111
Coding: 0006231
VCID: 3C77D7F07C2206A1F5-5124
02053 - Control Module for Transfer Case (J646)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70EF33C060EAB2C119-5124
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 4581B2140FE847699A-5124
00926 - Terminal 30
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 J
Component: HSG 5115
Coding: 0000085
VCID: 4385AC0C01DC7959B4-4AE8
Subsystem 1 - Part No: 7L0 959 701 F
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 F
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Subsystem 4 - Part No: 7L0 959 704 C
8 Faults Found:
00576 - Terminal 15
01312 - Powertrain Data Bus
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180 B
Component: Radio DE2 0016
Coding: 0001405
Shop #: WSC 01106 444 53990
VCID: 2C57E7B08C42962165-5124
00881 - Connection to Speaker Rear Right
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C77D7F07C2206A1F5-5142
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 31414
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 N
Component: DACHDISPLAY 0539
Revision: 00800539 Serial number: 2009289.07
VCID: 428BA9081EC67051BF-5124
End-------------------------(Elapsed Time: 09:21)--------------------------
