- Apr 5, 2017
- 180
- 43
- Yuengling Country
- C?ID=306296
Hello everybody,
I have a 2017 Q3 base model.
The main reason I got the HEX-V2 is to enable TMPS.
My Pontiac had it 10 years ago and it was the real TMPS not the fake ABS relative speed one.
I tried to enable it though VCDS following some instructions on the web, by enabling the green menu first.
That didn't work, 5F, Channel 06 remains at 0 even though I tried to set it to 1 and it said OK.
I also found some instructions on the ABS module, but my part isn't known to VCDS so I didn't dare to do it blindly.
That called for byte 16, bit 2, which won't even show up as a checkbox for my part.
Not to mention that my byte 16 was 0x04, which I think means bit 2 is already set.
I could really use some directions on how to achieve this goal.
A kind mechanic at the dealer looked up my PR codes and said it could be enabled by "third party" tools, but no dealer will do it because that is how they distinguish between "models". In other words, you don't pay, you don't get it, even though.... anyway... enough ranting.
Soooo, I am wondering if there is a solution to this.
I do have the 1AT ABS, but the other part is unknown to VCDS.
I posted my scan on the pre-sales forum, but I will post it here as well.
Thank you for any suggestions and please let me know if any other info is needed.
Thursday,20,April,2017,17:51:05:35103
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: WA1ECCFSXHR0xxxxx License Plate:
Mileage: 1960km-1217mi Repair Order:
Chassis Type: FS (8U0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 5F 62 6D 72
VIN: WA1ECCFSXHR0xxxxx Mileage: 1960km-1217miles
Address 01: Engine (CCT) Labels: None
Part No SW: 8U0 907 115 L HW: 8U0 907 115 J
Component: 2.0l R4/4V TFSI 06 0002
Revision: PAH05--- Serial number:
Coding: 0123010A190F01A0
Shop #: WSC 00049 770 00119
VCID: 40DA496FE68B52F76D9-8014
Part No SW: 09G 927 750 NL HW: 09G 927 750 NL
Component: AQ 250 6F 2696
Revision: 00H97000 Serial number:
Coding: 0000840
Shop #: WSC 00049 770 00131
VCID: 084A914F8E3BAAB7659-805C
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CF HW: 5N0 614 109 CJ
Component: ESC-EBC460iV1 H12 0013
Serial number: A01DDR6
Coding: 42FF269F492143702077420964C592C20424D000508B4883
Shop #: WSC 00049 770 00154
VCID: 71BCDCAB91218B7FD27-8024
Part No SW: 8U0 820 047 G HW: 8U0 820 047 G
Component: J255 Klima Man 0030
Revision: 00H02001 Serial number: 00000000000000
VCID: 392C248B8551033F2A7-806C
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 AG HW: 8X0 907 063 AG
Component: BCM PQ35 M 113 0821
Revision: AB113821
Coding: AF000A0FA80336C4A4184BC121440D4D50FF66AA016F9523E40A06840045
Shop #: WSC 00049 770 00015
VCID: 015C8C6BA1019BFF227-8054
Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119
Component: WWS316 161110 H38 0090
Serial number: 161202235421
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 D HW: 8U0 955 559 A Labels: 8U0-955-559.CLB
Component: G397_RLS H06 0004
Serial number: 50080466
Coding: 02006E
Subsystem 3 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
01134 - Alarm Horn (H12)
Reset counter: 75
Mileage: 82 km
Date: 2017.03.19
Time: 11:47:58
Term 15 On
Voltage: 9.10 V
Term 50 On
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8U0 959 655 A HW: 8U0 959 655 A
Component: AirbagVW-AU10 H53 0723
Serial number: 003LQD12VCBY
Coding: 303932313231413130304A55304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 002001
ROD: EV_AirbaAU10SMEAU316_002.rod
VCID: 45D4587BF52977DF5EF-8010
Subsystem 1 - Part No SW: 8U0 959 339 HW: 8U0 959 339
Component: BF-Gewichtss. H02 0020
Serial number: 5810000R160000FXJ7
Component: S.Sens.Fahr.V
Serial number: 3574MSME7953485BZZZ4
Component: S.Sens.Beif.V
Serial number: 3584MSME1D644B5CZZZ9
Serial number: 3516KSME4A652040ZZZK
Serial number: 3526KSME056E0F40ZZZY
Subsystem 6 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME490E1140ZZZZ
Subsystem 7 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3565USME58121140ZZZP
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: FF010018 Serial number: 20161215100521
Coding: 1984204000
VCID: 3B203E8383ED312F38B-806E
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Serial number: 09 12 2016 C0014777
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8U0 920 930 H HW: 8U0 920 930 H
Component: KOMBI_MEDIUM H05 0540
Coding: 32CF00
VCID: 3C223D9F86E33617311-8068
Part No SW: 8U0 907 468 AS HW: 8U0 907 468 J
Component: GAT 4CAN 2L M H13 0090
Revision: 1R190044 Serial number: 4441R16B3002B7
Coding: F3460A5A050B0D610253
VCID: 1370B623CB7D196F80B-8046
Subsystem 1 - Part No SW: 8U0 959 591 A HW: 8V3 959 591 A
Component: J245 PS11.403 H03 0004
Serial number: 0000FST001BLWSL00000
Coding: 101E00
Subsystem 2 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 33342I01145831018801
Subsystem 3 - Part No SW: 8U0 959 591 A HW: 8V3 959 591 A
Component: J394 PS11.403 H03 0004
Serial number: 0000FST001BLWTM00000
Coding: 001E00
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00015.11.16
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 52FE73273467D067CBD-8006
Component: IMMO H05 0540
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 K HW: 8X0 959 793 K
Component: TSG FA H11 0415
Coding: 011E03200000000000
VCID: 55F4883B0509C75F2EF-8000
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.377 1501
Revision: 1BH04843 Serial number: 00163140160701
Coding: 0000258
VCID: 42DE4367E88740E77BD-8016
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 K HW: 8X0 959 792 K
Component: TSG BF H11 0415
VCID: 54F2753F0EF3DE57D91-8000
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Serial number: 161206-0002-130
Coding: 16C7A41010022400
ROD: EV_HeadlRegulBasic.rod
VCID: 44D2457FFE134ED7491-8010
Part No SW: 8U1 035 187 B HW: 8U1 035 187 A
Component: RMC Cnct Sir H62 0170
Coding: 01000600028051070023000102010000010000
VCID: 382A218FB25B1A37D59-806C
Subsystem 1 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H43 0018
Serial number: AUZ8ZDGCS038WS0
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415
Coding: 010E03200000000000
VCID: 4FF87A5327D5BD8FE43-801A
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 8U0 959 107 A HW: 8U0 959 107 A
Component: HDSG-Modul H02 0552
Revision: 15001001 Serial number: 328601189
Coding: 183307C102
ASAM Dataset: EV_HDSGAU316 001001
ROD: EV_HDSGAU316.rod
VCID: 3D24309B9DF93F1F06F-8068
Component: TSG HR H08 0415
End----------(Elapsed Time: 01:15, VBatt start/end: 12.5V/12.5V)-----------
