- Joined
- Apr 9, 2014
- Messages
- 2,310
- Reaction score
- 2,259
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [096] - Implausible Signal
15202 - Actuator Module for Turbocharger 1
P00AF 00 [109] - Stuck
Issue here was, that customer went to dealer as warranty has just ran out. Dealer suggested new turbocharger to be fitted.
He then came to us by hearing we might have other solution.
At initial diagnostic we confirmed the same thing that waste gate doesn't move. My thought was that it must have similar issue to 1.2-1.4 engines waste gate rod getting seized.
Read here: https://forums.ross-tech.com/showth...t-TSI-MK7-Golf&p=106771&viewfull=1#post106771 and here: https://www.golfmk7.com/forums/showthread.php?t=28690
It was not possible to remove circlip just from underneath the car and we suggested removing the turbocharger to have better access.
While starting the removal process it became clear that circlip can be easily accessed if right driveshaft and catalytic converter are removed.
Circlip removal was easy, removing spindle wasn't, as it was seized pretty good. Using heat and lot of patience it gave up and was finally removed.
Left to do here was only to clean spindle really good, reinstall it with good grease and assemble everything else.
Using output test of VCDS showed good movement of spindle and rod with no resistance what-so-ever.
Most of the credit goes to my good co-worker Roland who didn't gave up and fixed this issue for customer.
I believe this issue might be happening on all EA888 engines... .
And autoscan for reference.
Friday,16,August,2019,08:59:03:39429
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Tarfor OÜ
VIN: TMBJE9NE8E0 License Plate:
Mileage: 101350km-62975mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69 A9
VIN: TMBJE9NE8E0 Mileage: 101350km-62975miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0007
Revision: --H13---
Coding: 0C1900322434010B0000
Shop #: WSC 73430 031 00133
ASAM Dataset: EV_ECM20TFS0215G0906259 001011
ROD: EV_ECM20TFS0215G0906259.rod
VCID: EB96BF86021F7517DC-80BE
Mileage: 101069 km
Date: 2019.08.09
Time: 11:09:33
Vehicle speed: 2 km/h
Coolant temperature: 45 °C
Intake air temperature: 27 °C
Voltage terminal 30: 10.000 V
Unlearning counter according OBD: 28
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor: 2.5342 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 23.84 %
Charge air pressure control valve activation pulse duty factor: -35.94 %
Charge air pressure control valve voltage: position closed: 3.2474 V
STATE_BPA[0]: AD
Mileage: 101069 km
Date: 2019.08.09
Time: 11:09:00
Engine speed: 2571.00 /min
Vehicle speed: 23 km/h
Coolant temperature: 36 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.531 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 1.7676 V
Charge air pressure control valve position: target value: 89.24 %
Charge air pressure control valve position: actual value: 49.32 %
Charge air pressure control valve activation pulse duty factor: 77.41 %
STATE_BPA[0]: OPM
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 61124000000A4A
Coding: 1C076B915422296F007D060941CA2938D62A9400608294F600400070C009
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: CBD61F06625F9517BC-809E
Part No SW: 5E0 907 044 N HW: 5E0 907 044 N
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 02010004000100011005000100100000
VCID: B02C68EAEBB9D6CFA9-80E4
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 Q HW: 5Q0 937 086 Q
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86580205141019
Coding: 0C020A66C24722FB07A04082B11C07280000000000000000000000000000
Shop #: WSC 73430 790 00133
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: C8DC200A73297E0F91-809C
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140415 041 0570
Serial number: 140424090521
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M05D07H05M46S30S8
Coding: 02805D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140511W06
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000059363646
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831411900727
Coding: 0001050101
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: B83C50CA03C90E8FE1-80EC
Part No SW: 3Q0 959 655 AB HW: 3Q0 959 655 AB
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P3P2QMLNL
Coding: 98FCC000000000005C5400CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: FEB086D2616DF0BF6B-80AA
Subsystem 1 - Part No SW: ----------- HW: 454 002 204 14
Serial number: 3576U0000008C890AF0R
Subsystem 2 - Part No SW: ----------- HW: 454 001 904 14
Serial number: 3586U000000B6D796F0X
Subsystem 3 - Part No SW: ----------- HW: 454 802 004 14
Component: SideSensor_Dr 111 0148
Serial number: 3516RA5D863030000004
Subsystem 4 - Part No SW: ----------- HW: 454 802 004 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RC3EA8503000000C
Subsystem 5 - Part No SW: ----------- HW: 454 801 903 14
Component: FrontSensor_D 114 0149
Serial number: 3556VE57A2D03000000I
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 30041404400743
Coding: 1400
VCID: F7BE93F64E57C1F728-80A2
Part No SW: 5E0 920 871 C HW: 5E0 920 871 C
Component: KOMBI 333 2210
Coding: 07A509002980000801082A00000000
VCID: A81C808AD3699E0F71-80FC
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001924458
Coding: 030100342F085900EF00026A080F00010001050000000000000000000000
ROD: EV_GatewLear_010.rod
VCID: BFCE3BD626E739B720-80EA
Subsystem 2 - Part No SW: 5E0 919 719 A HW: 5E0 919 719 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1229250414
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6463323203
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000101630324
Coding: 001D0020D000040000001100
VCID: C4C4343A4F015A6F7D-8090
Serial number: 00000000000002520980
Coding: 010200
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: B52259FE14DBF3E7FA-80E0
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000101598853
VCID: C3C637264A0F5D5744-8096
Serial number: 00000000000002480637
Coding: 190200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DA02003F000000
Shop #: WSC 73430 790 00063
VCID: C0CC382A5B19464F59-8094
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 840 A HW: 5E0 035 840 A
Component: MU-S--ER 040 0490
Serial number: S3E00405140572
Coding: 037352000000000011110002000100002F0001A40100010000
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 9F0E9B56862759B700-80CA
Subsystem 1 - Part No SW: 5E0 919 605 B HW: 5E0 919 605 B
Component: ABT_Std_Plus H50 0022
Serial number: SKZ8Z9PK60150S
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H11 0030
Revision: 6A001003 Serial number: 00008200286511
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: F4A4A4FA5F21AAEF0D-80A0
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140331200219
VCID: E99AC58E08E36707AE-80BC
End----(Elapsed Time: 01:40, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
