'04 Golf MK5, Several malfunctions. Windows, brake light switch, modules...etc.
JKB80
Norway
C?ID=227859
I'm checking my grandmother's Golf MK 5.
There are several problems that I know about:
1. Front wipers don't work. Ordered new motor.
2. Windows are not able to open/close. Don't know why..
3. Brake light is not working. Is it possible to test the sensor?
But it seems to be more problems as well according to VAGCOM.
It seems to be a problem with the comunication to several modules, what is the best way to troubleshoot?
I'm very thankfull for all help!
BR Jorn
Tuesday,11,November,2014,21:09:42:15915
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVWZZZ1KZ4W118524   License Plate:
Mileage: 106710km-66306mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ4W118524   Mileage: 106710km-66306miles
Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No SW: 036 906 032 AG    HW: xxxxxxxxxxx
   Component: BOSCH ME7.5.10      5612
   Revision: 00000000    Serial number: VWZ7Z0D9456574
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 55A1AA8EFC3F7D896CD-8000
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   VCID: 3D71122E644F85C944D-8068
   Part No: 1K0 820 047 CC
   Component: Climatic PQ35   080 0201
   VCID: 67DD90465653FF19CE1-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H30 0701
   Revision: 00030000    Serial number: 00000000560429
   Coding: 088F8F0600041800001400001400000000
   VCID: 377D00064673AF999E1-8062
   Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
00918 - Terminal 31
00576 - Terminal 15
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0L AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD0A219D
   Coding: 0012364
   Shop #: WSC 01371 785 00200
   VCID: 2A5B297285C1027111F-807F
   Subsystem 1 - Serial number: 6332MSME7C644402
   Subsystem 2 - Serial number: 6342MSME01744402
   Subsystem 3 - Serial number: 6351HSME10176901
   Subsystem 4 - Serial number: 6361HSME514C7201
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   VCID: 6FEDF8667EA32759861-803A
   Part No: 1K0 920 850 P
   Component: KOMBIINSTRUMENT VDD 3556
   Coding: 0005101
   Shop #: WSC 00011 888 96745
   VCID: 3467370A57054481BB3-8061
   Coding: 0005101
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 26001042280058
   Coding: 3D3F0340070002
   VCID: 275DD04696D33F190E1-8072
   Component: IMMO                3556
   Shop #: WSC 00220 218 16467
   Part No: 1K1 909 144 F
   Component: EPS_ZFLS Kl.0       1301
   VCID: 2E532562B9296E51CD7-807B
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 01:51)--------------------------
Bad Convenience CAN bus?
JKB80
Norway
C?ID=227859
Hi Uwe,
Do you have some further information, I'm not that experienced.. ;)
BR Jorn
golfi_vend
Tartu, Estonia
C?ID=195131
Can bus, like a internet in car, but with many networks and one can gateway(router) to handle traffic.. Ie convience can, drivetrain ie.... .
Seem like some module or wire is broken so traffic cannot occur on one network.
JKB80
Norway
C?ID=227859
I have some basic knowledge regarding bus communication.
What I need are some hints for how to troubleshoot.
Is there a place where I can find info regardring CAN BUS and how to trouble shoot, diagrams etc.
Appreciate your help so far!
BR Jorn
Your car has several CAN bus networks in it. One for the powertrain, one for the convenience systems, once for infotainment, etc. The Gateway acts as a router between them.
JKB80
Norway
C?ID=227859
I understand.
How should I start to troubleshoot?
Check cable connections etc?
I have tried to find electrical diagrams for Golf MK5, so far without any luck.
BR Jorn
JKB80
Norway
C?ID=227859
Thank you for the link!
I have investigated even more, and it seems that problem is a visit of......a cable eating mouse!! ;) ;)
I shall replace and do some soldering of cables, and hopefully I have fixed most of the problems.. :)
BR Jorn
Sometimes I think VWAG puts rodent-attracting pheromones in their wiring harnesses. ;)
Dana
Western PA, USA
Hi Jorn, I see you joined the forum on 10-19-2014 and registered with us directly on 10-22-2014 so we need to switch your Junior Member status to Verified. After we do that you will be able to post in the Car Repair (and similar) sub-forums.
P.S. MVBs 125 and up may be helpful after repairing CAN wiring. You can use those groups in just about any control module but I would focus on address 19-CAN Gateway.
