Adv. Measuring values logging issue
Ape Factory
C?ID=321067
Currently using VCDS v18.9.1 and I use a program called MegaLog Viewer HD (unfortunate name I know) to view and graph the logged data. I've noticed since switching to the latest VCDS version that when I group them together I'm getting multiple time stamps in the file, one for each parameter I've chosen to log. Prior to the update, there'd be one time stamp followed by the eight parameters I was logging (turbo mode).
In addition, when I log the pre-cat wideband 02 (lambda), I'm getting lambda as well as voltage now, separated by a backslash (/). I can no longer graph that parameter through the MegaLog Viewer since there are two measuring values where there should be one.
I would, prior to the update, be able to select all eight parameters I recorded to the .csv file through the viewer to graph but now only first four appear. The viewer has a pull-down menu for up to four parameters in one graph. You can stack multiple graphs so you have four parameters in one, four in the second one directly below. Now I get four parameters period and no option to view the other four that are in the file. Not sure if it has something to do with the time stamp appearing eight times.
Anyone know if changes were made to the logging function or am I perhaps seeing an issue created by the log viewer?
I'm using a Hex V2 cable.
Thanks in advance!
Ape Factory
C?ID=321067
I went back and looked at one of my older logs through Excel and the multiple time stamps are there but the lambda value features the lambda value only, not the voltage reading. I'm able to see the data for all eight recorded parameters. In the later version, I'm unable to see more than four through the log viewer program even though there are eight in the file, viewable in Excel.
Please post some sample logs illustrating the difference.
Ape Factory
C?ID=321067
My apologies for the super late reply, working on a number of little projects and forgot to post two logs up. I can't attach actual logs so I did a screen grab of them both in excel.
Here's one from September that MegaLog Viewer can read no problem. I'm looking at blocks G096 and G100. Both show the current of the oxygen sensor but NOT lambda. I captured the VCDS build number at the top but here it is again: Monday 17 September 2018 13:18:00:27520-VCID:3B23C92323E318DF646-806E VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.2
In the second, more recent log, the voltage and lambda are displayed. The blocks are now G100 and G103. I forgot to capture the build so it's copied and pasted here: Saturday 23 February 2019 15:01:07:27520-VCID:3FDBBD3337FB04FFA77-806A VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
Not sure if this is an actual change or if I've perhaps inadvertently clicked something causing the changes listed above.
You can certainly copy and paste the CSV data into a post (preferably between [code] and [/code] tags.
However, since these two files are not from of the exact same measuring values, you're asking to compare apples and oranges here. I would recommend loging the exact same data as in a file that MegaLog Viewer HD previously had no problems with.
Ape Factory
C?ID=321067
That's just it...I'm selecting the same thing to monitor. Specifically, the current of the wideband oxygen sensor pre-cat. The only difference is now it's showing lambda/voltage instead of just voltage with the update. I'm assuming, when you select a parameter to monitor, the VCDS is choosing to name that parameter. If you look at both, I have G100 in each log yet the data is different in that one includes the lambda and one does not. And 096 is the same as 103 in the newer version.
Anyway, the log viewer I use can't parse the data when it's presented as lambda/voltage. That's my main issue. I can't even select it since it doesn't read the data from the log at all.
OK, I see it now.
Do you have a scans from this car so we can see what the ASAM IDs are, and what ROD files VCDS is using?
Ape Factory
C?ID=321067
I can do that. Want me to take a complete snapshot and post it? It'd be great to have just lambda separately from voltage as I can convert that to air/fuel and graph it easily.
Maybe, but if what VCDS is showing/logging here for those measuring values matches what the factory software shows, then we're not going to change it.
In the meanwhile, we need the ECU ID data to investigate.
Ape Factory
C?ID=321067
Here's a full scan. I'll do another post with the ECU ID.
Wednesday,20,March,2019,13:29:09:27520
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WUAC6AFR6DA902467   License Plate:
Mileage: 89540km-55637mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C
VIN: WUAC6AFR6DA902467   Mileage: 89540km-55637miles
02-Auto Trans -- Status: Malfunction 1010
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l JHM.B /  H04 0005
   Revision: NAH04---
   Coding: 1A25003225C6080D3000
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
   ROD: EV_ECM42FSI0118T2907560F.rod
   VCID: 3FDBBD3337FB04FFA77-806A
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:16:01
                    Coolant temperature: 51 ∞C
                    Intake air temperature: 46 ∞C
                    Voltage terminal 30: 12.415 V
                    AFS dm: 0.0 kg/h
Readiness: 1110 0101
   Part No SW: 8T0 927 156 F    HW: 0B5 927 156 J
   Component: 0B5 42 FSINAR H01 0008
   Revision: --H01---
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001012
   ROD: EV_TCMDL501021.rod
   VCID: 40D9BECF4A057B07DED-8014
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Reset counter: 40
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
                    Engine speed: 0 /min
                    Transmission input speed: 0 /min
                    Transmission output speed: 0 /min
                    Engine torque: -64 Nm
                    Transmission fluid temperature: 55 ∞C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 12.500 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.901 V
8008 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
                    Reset counter: 40
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
                    Voltage terminal 30: 12.600 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.899 V
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Coding: 302D1A
   VCID: 45D7AFDB55A75E2FEDB-8010
                    Reset counter: 4
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x000E
                    Hex Value: 0x809B
                    Hex Value: 0x0000
                    Fault Status: 00101101
                    Reset counter: 6
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x001C
                    Hex Value: 0x029B
                    Hex Value: 0x0000
                    Reset counter: 6
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x000F
                    Hex Value: 0x509B
                    Hex Value: 0x0000
                    Reset counter: 6
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x000B
                    Hex Value: 0x939B
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0D804000000000000000
   VCID: 045172DF1E1DA727BA5-8050
   Serial number: 2313000016339008
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 220
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:18:44
                    Reset counter: 6
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000051213831
   Coding: 00037025002C00000000
   Shop #: WSC 06342 000 00000
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01200220130492
   Coding: 4802200000
   VCID: 392FD32B295F2ACF993-806C
                    Fault Status: 01100101
                    Reset counter: 215
                    Mileage: 89309 km
                    Date: 2019.03.15
                    Time: 18:18:02
                    Fault Status: 00100011
                    Fault Frequency: 19
                    Reset counter: 7
                    Mileage: 89309 km
                    Date: 2019.03.15
                    Time: 19:05:04
                    Voltage: 12.30 V
                    Temperature: 19.0∞C
                    Temperature: 21.0∞C
                    Count: 25000
                    Count: 10941
                    Bin. Bits: 01000000
                    Bin. Bits: 10001011
                    Time: 2.55 s
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000554864301
   Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
   Shop #: WSC 92630 444 123950
   VCID: 7AAD0C276CD9E1D7D09-802E
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150213  H15 0080
   Serial number: SWF13020150148
   Coding: 00FD11
   Serial number: 21004112
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000502130647
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4SYJ02
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 7C48C296000000000001
                    Reset counter: 5
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
   Component: ACC3          H11 0100
   Coding: 00333E
   VCID: 323DE407F429D997589-8066
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Temperature: 23.0∞C
                    Voltage: 12.42 V
                    Hex Value: 0x0077
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 7
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Temperature: 27.0∞C
                    Voltage: 12.54 V
                    Hex Value: 0x00BF
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Temperature: 23.0∞C
                    Voltage: 12.42 V
                    Hex Value: 0x00C0
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD91EW3S
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD9CE77C39B157009-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000CJ7S
   Serial number: 6334MSME780331656
   Serial number: 6344MSME78406157C
   Serial number: 6352QSME62282B44G
   Serial number: 6362QSME5F2C5372T
   Serial number: 63732SME712B0F585
   Serial number: 63832SME542B2F444
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20130219001040
   Coding: 00003E
   VCID: 51FF8B8B91EF828F413-8004
   Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
   Component: KOMBIINSTR.   H35 0556
   Revision: 00300000    Serial number: UVA266K2E
   Coding: 83BF0100AF03D705020000
   VCID: 3D27C73B3D7716EFB5B-8068
                    Reset counter: 6
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z13204008E
   Coding: 80E3031600
   VCID: 4CC19AFF76CDAF67325-8018
   Serial number: 1367620003
                    Reset counter: 5
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Bin. Bits:    10111
                    Voltage: 12.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
                    Bin. Bits:    10111
                    Voltage: 12.60 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
   Component: DYNAMIKLENK.  H06 0690
   Coding: 030000
   VCID: 3635D8171841C5B7741-8062
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Count: 52
                    Count: 1
                    Hex Value: 0x0A35
                    Hex Value: 0x7B02
                    Hex Value: 0x0000
                    Hex Value: 0xF03F
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001302130001758
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F3BED73E79BF47F377-807A
0212 - No Communication with Transmission Control Module
          U0101 00 [008] - -
          [Getriebe - Steuerger‰t keine Kommunikation DTC_CAN_GETRIEBE_NO_COM]
                    Reset counter: 5
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
0221 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_01_NO_COM]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
0297 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_03_NO_COM]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [008] - -
          [ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000051211560
   Coding: 001B7B25002C00000000
   Shop #: WSC 11251 001 1048576
03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                    Reset counter: 215
                    Mileage: 89309 km
                    Date: 2019.03.15
                    Time: 18:18:01
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H04 0060
   Serial number: 0192285845
   Coding: 010211
   Shop #: WSC 06324 000 00000
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H04 0060
   Serial number: 0192294703
   Coding: 000102
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F57897B801E5B7941-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0012646993
   Coding: 010000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3431E21F0EBDD7A74A5-8060
3158274 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Botschaftsausfall des Motor-Steuerger‰ts]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Write only channel
   Revision: 00002001    Serial number: 0301332569
   Coding: 0106069A00FAC10581B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000634856
   Component: J245EE20SKB13  H05 0220
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA104645000002650945
                    Reset counter: 4
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:13
                    Reset counter: 6
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:17
00230 - Transmission Park Selector Switch (F305)
                    Reset counter: 222
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:11:18
   Revision: 00005001    Serial number: 94813011143102
   VCID: 2D07F77BED17866F05B-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F77F9BA507EEAF9DB-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000227161
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D62F12D533C766D-806C
6 Faults Found:
334080 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_02_MESSAGE_TIMEOUT]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Voltage terminal 30: 12.7 V
                    Internal Fault ID: 51
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
329728 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                    Reset counter: 5
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:12
                    Voltage terminal 30: 12.6 V
                    Internal Fault ID: 94
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
329984 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                    Reset counter: 5
                    Mileage: 89499 km
                    Date: 2019.03.18
                    Time: 23:21:12
                    Internal Fault ID: 95
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331264 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_01_MESSAGE_TIMEOUT]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Internal Fault ID: 99
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331520 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_03_MESSAGE_TIMEOUT]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Internal Fault ID: 100
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
331776 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:16
                    Internal Fault ID: 101
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156B50D7693479
   Coding: 020007010000000001
   VCID: 25170F5BB5E7BE2FCDB-8070
03278 - Functionality Limited due to Missing Messages
            000 -  -  - Intermittent
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:21
                    Bin. Bits: 00000000 00001000
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 1040
   Revision: --------    Serial number: 204BT0D7561283
   Coding: 150200020306A9EF75028B4E00000403140000000000000000
   VCID: 3FDBBD33377B04FFA77-806A
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Component: DU7 High  H42 0104
   Serial number: A130BX0D2659970
   Serial number: 00000001419689
   Component: CD-Database  4949
                    Reset counter: 215
                    Mileage: 89309 km
                    Date: 2019.03.15
                    Time: 18:18:41
                    Text: DUA130,Front,M,0,0,6
                    Reset counter: 7
                    Mileage: 89549 km
                    Date: 2019.03.19
                    Time: 23:10:27
                    Bin. Bits: 00010000 00000000
                    Bin. Bits: 00000000 00010000
   Revision: --H07---    Serial number: 525PA8-J2Z91FG
   Coding: 1021008
   VCID: 3829D62F1E5533C766D-806C
End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Wednesday,20,March,2019,13:33:42:27520
          52 53 56 5F 6C
   Revision: NAH04---
Readiness: 1110 1101
   Revision: --H01---
   Coding: 000001
   Coding: 302D1A
   Coding: 4802200000
                    Reset counter: 223
                    Mileage: 89549 km
                    Date: 2019.03.20
                    Time: 12:29:17
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 00333E
   Coding: 00003E
   Coding: 80E3031600
   Coding: 030000
                    Reset counter: 223
                    Mileage: 89549 km
                    Date: 2019.03.20
                    Time: 12:29:17
   Coding: 010211
   Coding: 000102
                    Reset counter: 223
                    Mileage: 89549 km
                    Date: 2019.03.20
                    Time: 12:29:22
   Coding: 1021008
End----(Elapsed Time: 01:55, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Ape Factory
C?ID=321067
Just happened to have scanned the ECU ID on Friday...
Friday,15,March,2019,20:32:32:27520
Address 01: Engine
Control Module Part Number: 8T2 907 560 F
Component and/or Version: 4.2l JHM.9X/ H04 0005
Software Coding: 1A25003225C6080D3000
Work Shop Code: WSC 00000
Advanced Identification/FAZIT
Identification: BPG-810
Revision: NAH04---
Date: 14.02.13
Manufacturer number: 1328
Test stand number: 0017
Flash Status
Programming Attempts(application): 0/0/0/0/0
Successful Attempts(application): 0/0/0/0/0
Flash Date: 00.00.00
Misc.
Hardware number: 8T1 907 560
Workshop System Name: -----
ASAM Dataset Revision: 001004
Car Info
Chassis Number: WUAC6AFR6DA902467
Engine code: CFSA
VCDS Info:
Labels: 079-907-560-CFS.clb
Readiness: No script available
So the data type for IDE00565 in EV_ECM42FSI0118T2907560F is "OBD", and it corresponds to PID PID 52/0x34, which calls for the display of "Fuel–Air Equivalence Ratio (lambda) and Oxygen Sensor Current".
See chart here:
https://en.wikipedia.org/wiki/OBD-II_PIDs#Service_01
I'm not sure why older versions didn't show the current. I've checked previous versions back to to DS251 and the data type has not changed. Eric has also looked at the VCDS source and hasn't found any relevant changes. So the only thing we can think of is that your ECU's ASAM ID may have changed between the 0002 software version you had in the first log that you posted and the 0005 version in the second log that you posted. Do you have any scans that show your ECU's ASAM ID with the 0002 software in it?
If you'd like to split the two values into separate columns, I'd suggest a find & replace in that column, to replace the slash with a comma.
Ape Factory
C?ID=321067
I'll look as I have more than a few scans saved. And thanks for the tip. Can't stand excel but I'm sure I can figure how to do a find and replace.
Ape Factory
C?ID=321067
Here's an old one.
Thursday,11,January,2018,21:43:56:27520
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
Mileage: 63530km-39475mi   Repair Order:
          52 53 56 5F 6C
VIN: WUAC6AFR6DA902467   Mileage: 63530km-39475miles
   Part No SW: 8T2 907 560 B    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0004
   Revision: NAH04---
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM42FSI0118T2907560B 001005
   ROD: EV_ECM42FSI0118T2907560B.rod
   VCID: 3B23C92323E318DF4F3-806E
   Revision: --H01---
   Coding: 000001
   VCID: 40D9BECF4A057B071A1-8014
   Coding: 302D1A
   VCID: 45D7AFDB55A75E2F297-8010
   VCID: 045172DF1E1DA7277E9-8050
   Coding: 4802200000
   VCID: 392FD32B295F2ACF5DF-806C
   VCID: 7AAD0C276CD9E1D7145-802E
   Coding: 00FD11
   Coding: 02005D
H01 0031
H01 0031
   Coding: 00333E
   VCID: 323DE407F429D9979C5-8066
   VCID: 4ACD9CE77C39B157C45-801E
   Coding: 00003E
   VCID: 51FF8B8B91EF828F85F-8004
   VCID: 3D27C73B3D7716EF717-8068
   Coding: 80E3031600
   VCID: 4CC19AFF76CDAF67F69-8018
   Coding: 030000
   VCID: 3635D8171841C5B7B0D-8062
   VCID: 2F3BED73E79BF47FF3B-807A
                    Reset counter: 34
                    Mileage: 59658 km
                    Date: 2017.10.26
                    Time: 22:55:48
03321 - Switch for Height Adjustment: Down
                    Reset counter: 223
                    Mileage: 63390 km
                    Date: 2018.01.08
                    Time: 14:07:49
03325 - Switch for Backrest Angle Adjustment: Back
                    Reset counter: 223
                    Mileage: 63390 km
                    Date: 2018.01.08
                    Time: 14:07:49
   Coding: 010211
   VCID: 3FDBBD3337FB04FF63B-806A
   Coding: 000102
733696 - Control Module 2 for Lane-Change Assist
          C1115 F5 [008] - Limited Visibility
                    Mileage: 61628 km
                    Date: 2017.12.07
                    Time: 17:51:39
   VCID: 56F57897B801E5B750D-8002
   VCID: 3431E21F0EBDD7A78E9-8060
   VCID: 2D07F77BED17866FC17-8078
   VCID: 55F77F9BA507EEAF597-8000
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3829D62F12D533C7A21-806C
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   VCID: 221D1447A4C949176C5-8076
   Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
   Component: H-BNT-NA      H44 0624
   VCID: 372BD5131F4B3CBFABB-8062
   Coding: 1021008
   VCID: 3829D62F1E5533C7A21-806C
End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.0V)-----------
Here's an old one.
   Revision: NAH04---
Well, that's not the 0002 software in your first log, but it solves the mystery anway.
Your ECU software part number has changed, and so has the ASAM identifier.
And guess what, that older ECU software had two separate values that could be logged:
IDE00565-MAS04135 --0 Current of oxygen sensor bank 2 sensor 1 (broadband sensor) - Oxygen sensor value,LINEAR,lambda
and
IDE00565-MAS04136 -- Current of oxygen sensor bank 2 sensor 1 (broadband sensor) - Current,LINEAR,mA
Whereas your new ECU software only has:
IDE00565-ENG167462 -- Current of oxygen sensor bank 2 sensor 1 (broadband sensor),OBD,
So the difference is in the software in your ECU, as opposed to something that has changed in VCDS.  :thanks:
Ape Factory
C?ID=321067
Huh, I checked with the calibration engineer just to make sure and he states nothing was changed in the communication with the com lines. I'll double check with him.
Also, is there any way to have the logging function automatically change the file name each and every time? I did a bunch of logging only to have it all overwritten as the same file name is being chosen by the software. I'm logging completely different parameters but it's the same name each and every time regardless. When working quickly, this would be a huge benefit.
Another suggestion is when you save a group of logging parameters that it also saves the "turbo" mode option as well as the UDS grouping/time stamp if checked when saving a group of parameters.
It's extremely tough to work quickly with the VCDS logging feature when you're constantly having to change one character or having to check a bunch of small boxes. Automation is your friend.
There's nothing to double check. The software part number of your ECU changed, as did its ASAM identifier. It's all there in black and white. :)
I'm a bit puzzled why that would happen if you're logging "completely different parameters". Also, I don't think logs ever get overwritten; if the same file name is used, new data should be appended to the existing data in the file.
That's not a bad idea.
Ape Factory
C?ID=321067
I would literally jump with joy if that could be implemented. The interface aspect and logistics of logging, as it now stands, are tedious and it makes it hard when you're using a small, lightweight laptop like I am. Battery lasts forever and it's cheap, so it makes a good VCDS-only tool. But it's also super hard to see anything when it's in the seat next to you and as mentioned, tedious to get everything right.
It's so easy to forget to check or uncheck one box, to rename the file, etc... I literally overwrote a ton of really valuable data today due to the fact it doesn't automatically rename a file or at least warn you the data is being overwritten.
In addition, I'd suggest, from a graphics point of view, to make the "buttons" or boxes bigger. Heck, make the whole logging window larger or even make it expandable to full screen mode. If looking at the computer, in the car, there are times where I can't even see if it says start or stop. Big buttons with larger text would be super helpful from an interface standpoint.
Appreciate you're receptive to this!
Again, I do not think logs are ever overwritten; if the file name is the same, new data gets appended to an existing file.
Have you adjusted the Window Size here?
Ape Factory
C?ID=321067
Ah didn't realize you could do that! I'll try that for the window size.
As for the files being overwritten, I'm closing out each log. So if I'm logging the transmission, I'll do that, stop it, close it out and open the ECU and then log. Same file name but totally different parameters being logged.
Now if I'm logging the same parameters over again, and I hit resume, yes, it's being appended. But I checked my files and only one log appeared when I had recorded six different logs previously. If the coding saved each file via the date and time, that would prevent files from being overwritten.
