Wednesday,20,March,2019,13:29:09:27520
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
VIN: WUAC6AFR6DA902467 License Plate:
Mileage: 89540km-55637mi Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
52 53 56 5F 6C
VIN: WUAC6AFR6DA902467 Mileage: 89540km-55637miles
02-Auto Trans -- Status: Malfunction 1010
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (------CFSA) Labels:. 079-907-560-CFS.clb
Part No SW: 8T2 907 560 F HW: 8T1 907 560
Component: 4.2l JHM.B / H04 0005
Revision: NAH04---
Coding: 1A25003225C6080D3000
ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
ROD: EV_ECM42FSI0118T2907560F.rod
VCID: 3FDBBD3337FB04FFA77-806A
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Mileage: 89549 km
Date: 2019.03.19
Time: 23:16:01
Engine speed: 0.00 /min
Coolant temperature: 51 ∞C
Intake air temperature: 46 ∞C
Voltage terminal 30: 12.415 V
AFS dm: 0.0 kg/h
Median injection timing: 0.000 ms
Engine operating condition: Idling
Readiness: 1110 0101
Part No SW: 8T0 927 156 F HW: 0B5 927 156 J
Component: 0B5 42 FSINAR H01 0008
Revision: --H01---
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 40D9BECF4A057B07DED-8014
18147 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Engine speed: 0 /min
Transmission input speed: 0 /min
Engine torque: -64 Nm
Transmission fluid temperature: 55 ∞C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 12.500 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.901 V
8008 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [032] - -
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Voltage terminal 30: 12.600 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.899 V
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 302D1A
VCID: 45D7AFDB55A75E2FEDB-8010
Reset counter: 4
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x000E
Hex Value: 0x809B
Hex Value: 0x0000
Fault Status: 00101101
Reset counter: 6
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x001C
Hex Value: 0x029B
Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
Reset counter: 6
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x000F
Hex Value: 0x509B
Hex Value: 0x0000
Reset counter: 6
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x000B
Hex Value: 0x939B
Hex Value: 0x0000
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H12 0633
Coding: 0D804000000000000000
VCID: 045172DF1E1DA727BA5-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000016339008
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 220
Mileage: 89499 km
Date: 2019.03.18
Time: 23:18:44
Reset counter: 6
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 E HW: 8T0 959 760 E
Component: MEM-BFS H10 0076
Revision: AA000000 Serial number: 00000051213831
Coding: 00037025002C00000000
Shop #: WSC 06342 000 00000
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01200220130492
Coding: 4802200000
VCID: 392FD32B295F2ACF993-806C
Fault Status: 01100101
Reset counter: 215
Mileage: 89309 km
Date: 2019.03.15
Time: 18:18:02
Fault Status: 00100011
Fault Frequency: 19
Reset counter: 7
Mileage: 89309 km
Date: 2019.03.15
Time: 19:05:04
Voltage: 12.30 V
Temperature: 19.0∞C
Temperature: 21.0∞C
Count: 25000
Count: 10941
Bin. Bits: 01000000
Bin. Bits: 10001011
Time: 2.55 s
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000554864301
Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
Shop #: WSC 92630 444 123950
VCID: 7AAD0C276CD9E1D7D09-802E
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150213 H15 0080
Serial number: SWF13020150148
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 21004112
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Serial number: 00000000000502130647
Component: USHL4.2 H30 0030
Serial number: 0000002274555R4SYJ02
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 7C48C296000000000001
Reset counter: 5
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 C HW: 8K0 907 561 C
Component: ACC3 H11 0100
Coding: 00333E
VCID: 323DE407F429D997589-8066
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Temperature: 23.0∞C
Voltage: 12.42 V
Hex Value: 0x0077
Lateral Accel.: 0.00 m/s^2
Reset counter: 7
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Temperature: 27.0∞C
Voltage: 12.54 V
Hex Value: 0x00BF
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Temperature: 23.0∞C
Voltage: 12.42 V
Hex Value: 0x00C0
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD91EW3S
Coding: 303343334830303030304A55304C38543053
VCID: 4ACD9CE77C39B157009-801E
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R130000CJ7S
Serial number: 6334MSME780331656
Serial number: 6344MSME78406157C
Serial number: 6352QSME62282B44G
Serial number: 6362QSME5F2C5372T
Serial number: 63732SME712B0F585
Serial number: 63832SME542B2F444
Part No SW: 8R0 953 568 S HW: 8R0 953 568 S
Component: Lenks.Modul H07 0171
Revision: 00000000 Serial number: 20130219001040
Coding: 00003E
VCID: 51FF8B8B91EF828F413-8004
Part No SW: 8T0 920 984 A HW: 8T0 920 984 A
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UVA266K2E
Coding: 83BF0100AF03D705020000
VCID: 3D27C73B3D7716EFB5B-8068
Reset counter: 6
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0055
Revision: 1Z100027 Serial number: 2741Z13204008E
Coding: 80E3031600
VCID: 4CC19AFF76CDAF67325-8018
Serial number: 1367620003
Reset counter: 5
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Bin. Bits: 10111
Voltage: 12.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Bin. Bits: 10111
Voltage: 12.60 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 J HW: 8K0 907 144 J
Component: DYNAMIKLENK. H06 0690
Revision: 52001005 Serial number: --------------
Coding: 030000
VCID: 3635D8171841C5B7741-8062
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Count: 52
Count: 1
Hex Value: 0x0A35
Hex Value: 0x7B02
Hex Value: 0x0000
Hex Value: 0xF03F
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H14 0100
Serial number: 001302130001758
VCID: 2F3BED73E79BF47F377-807A
0212 - No Communication with Transmission Control Module
U0101 00 [008] - -
[Getriebe - Steuerger‰t keine Kommunikation DTC_CAN_GETRIEBE_NO_COM]
Reset counter: 5
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
0221 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
[Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_01_NO_COM]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
0297 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
[Motorsteuerger‰t keine Kommunikation DTC_CAN_MOTOR_03_NO_COM]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
0059 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [008] - -
[ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H10 0076
Revision: AA000000 Serial number: 00000051211560
Coding: 001B7B25002C00000000
Shop #: WSC 11251 001 1048576
03339 - Force Limit for Fore/Aft Seat Adjustment: Back
Reset counter: 215
Mileage: 89309 km
Date: 2019.03.15
Time: 18:18:01
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0192285845
Coding: 010211
Shop #: WSC 06324 000 00000
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0192294703
Coding: 000102
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13224E00120102
VCID: 56F57897B801E5B7941-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0012646993
Coding: 010000010001
ROD: EV_RCEPSAU48X_008.rod
VCID: 3431E21F0EBDD7A74A5-8060
3158274 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Botschaftsausfall des Motor-Steuerger‰ts]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Write only channel
Revision: 00002001 Serial number: 0301332569
Coding: 0106069A00FAC10581B0003200000000
Component: GTO BF H01 0080
Serial number: 00000000000000634856
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0028
Serial number: WA104645000002650945
Reset counter: 4
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:13
Reset counter: 6
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:17
00230 - Transmission Park Selector Switch (F305)
Fault Status: 01101000
Reset counter: 222
Mileage: 89549 km
Date: 2019.03.19
Time: 23:11:18
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813011143102
VCID: 2D07F77BED17866F05B-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F77F9BA507EEAF9DB-8000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000227161
ROD: EV_ParkiBrake_AU48.rod
VCID: 3829D62F12D533C766D-806C
334080 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_02_MESSAGE_TIMEOUT]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Voltage terminal 30: 12.7 V
Internal Fault ID: 51
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Set
Status ParkingBrake right: Set
329728 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_GETRIEBE_03_MESSAGE_TIMEOUT]
Reset counter: 5
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:12
Voltage terminal 30: 12.6 V
Internal Fault ID: 94
RWU: not active
DSD: not active
HTR: not active
ECD: not active
329984 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_GETRIEBE_04_MESSAGE_TIMEOUT]
Reset counter: 5
Mileage: 89499 km
Date: 2019.03.18
Time: 23:21:12
Internal Fault ID: 95
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331264 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_01_MESSAGE_TIMEOUT]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Internal Fault ID: 99
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_03_MESSAGE_TIMEOUT]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Internal Fault ID: 100
RWU: not active
DSD: not active
HTR: not active
ECD: not active
331776 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_MOTOR_CODE_01_MESSAGE_TIMEOUT]
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:16
Internal Fault ID: 101
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156B50D7693479
Coding: 020007010000000001
VCID: 25170F5BB5E7BE2FCDB-8070
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:21
Bin. Bits: 00000000 00001000
Part No SW: 8R1 035 746 K HW: 8R1 035 746 B
Component: H-BNT-NA H44 1040
Revision: -------- Serial number: 204BT0D7561283
Coding: 150200020306A9EF75028B4E00000403140000000000000000
VCID: 3FDBBD33377B04FFA77-806A
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130BX0D2659970
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001419689
Component: CD-Database 4949
Reset counter: 215
Mileage: 89309 km
Date: 2019.03.15
Time: 18:18:41
Text: DUA130,Front,M,0,0,6
Reset counter: 7
Mileage: 89549 km
Date: 2019.03.19
Time: 23:10:27
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00010000
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2Z91FG
Coding: 1021008
VCID: 3829D62F1E5533C766D-806C
End----(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Wednesday,20,March,2019,13:33:42:27520
52 53 56 5F 6C
Revision: NAH04---
Readiness: 1110 1101
Revision: --H01---
Coding: 302D1A
Coding: 4802200000
Reset counter: 223
Mileage: 89549 km
Date: 2019.03.20
Time: 12:29:17
Coding: 00FD11
Coding: 02005D
H01 0031
H01 0031
Coding: 00333E
Coding: 00003E
Coding: 80E3031600
Coding: 030000
Reset counter: 223
Mileage: 89549 km
Date: 2019.03.20
Time: 12:29:17
Coding: 010211
Coding: 000102
Reset counter: 223
Mileage: 89549 km
Date: 2019.03.20
Time: 12:29:22
Coding: 1021008
End----(Elapsed Time: 01:55, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
