Where are the air quality sensors?
paddyz1
C?ID=273783
I have issues with the interior air temperature. I have to have the temp on max to get any heat (which becomes too hot) or it is cold on any other setting.
I have done a scan but got no idea where the sensors are in order to replace them.
Can anyone tell me where they are based on this scan if possible. Thanks.
 Sunday,16,February,2020,18:45:38:40439
VCDS Version: 19.6.2.2 (x64)
VIN: WVWZZZ13ZAV437053   License Plate: MA10RZN
Mileage: 267580km-166266mi   Repair Order: 16/02/20
Chassis Type: 13-VW36 (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 4F 52 55 56
          77
VIN: WVWZZZ13ZAV437053   Mileage: 267580km-166266miles
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2,0L EDC 0000SG  6166
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 00020 790 00000
   VCID: 71E9A7EF6834EDC75A-8024
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 763B40F5492500016E0B02E9921C0082300000
   VCID: 78FF9ACBCB4EBC8F9D-802C
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 7EF38CD3E16A82BFD7-802A
9479185 - Signal Line for Air Quality Sensor
          B10A4 11 [008] - Short to Ground
                    Fault Frequency: 7
                    Reset counter: 98
                    Mileage: 267368 km
                    Date: 2020.02.13
                    Time: 15:54:47
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [008] - Open or Short to Plus
                    Fault Frequency: 15
                    Reset counter: 99
                    Mileage: 267342 km
                    Date: 2020.02.13
                    Time: 15:25:47
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 4C100A3B9025E10040080080740049E643550B88736D8560648000000000
   VCID: 366354F381DA8AFF4F-8062
   Subsystem 1 - Part No: 1K8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 11011  22  0614
   Coding: 009795
   Component: RLS 160210 05  54  0403
   Coding: 0330ED
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 103
                    Reset counter: 54
                    Mileage: 255812 km
                    Date: 2014.02.14
                    Time: 17:56:60
                    Voltage: 13.90 V
01134 - Alarm Horn (H12)
                    Fault Frequency: 30
                    Reset counter: 96
                    Mileage: 258624 km
                    Date: 2014.03.20
                    Time: 13:59:01
                        Term 15 Off
                    Voltage: 12.05 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 100001
   VCID: 3A7B40C3B5C26E9FAB-806E
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 08021003800002
   Coding: 000180
   VCID: 275D89B75670E377C4-8072
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D0249DF
   Coding: 0012360
   VCID: 6FEDA1977E00FB374C-803A
   Subsystem 1 - Serial number: 6332MSME4F04295CM
   Subsystem 2 - Serial number: 6342MSME4E722F78V
   Subsystem 3 - Serial number: 6352QSME3D4C0002B
   Subsystem 4 - Serial number: 6362QSME4E4E4508V
   Part No SW: 5K0 953 521 T    HW: 5K0 953 569 D
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100213200752
   Coding: 108A040000
   ASAM Dataset: EV_SMLSNGVOLWS A01002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D714BDFACEC59A78E-8068
   Coding: 820000
   Part No SW: 1K8 920 971 C    HW: 1K8 920 971 C
   Component: KOMBI         H05 0305
   Coding: 470F00
   VCID: 33656DE79AA89FD768-8066
   Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
   Component: J533  Gateway   H06 0112
   Revision:   H06 01    Serial number: 270110F2001357
   Coding: E9A91F06400613004001
   Shop #: WSC 00400 210 83203
   VCID: 6ADBB08345E21E1F1B-803E
   Component: IMMO          H05 0305
   VCID: 6ADBB0838DE21E1F1B-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7667802176
   VCID: 264384B3517AFA7FFF-8072
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 F
   Component: RNS-MID       H60 5238
   Revision: AB001001    Serial number: VWZ6Z7L4234015
   Coding: 04000402040000A0000F
   Shop #: WSC 05314 123 12345
   VCID: 3B7545C7BAF85797B0-806E
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2124
   Coding: 0016949
   VCID: 39795FCF70C46587A2-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 177    3001
   Revision: 00H17000
   VCID: 316967EFA8B4ADC71A-8064
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0112
   Coding: 01030100
   VCID: 66C3C4B391FA3A7F3F-8032
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 003400000817
   Coding: 000005
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, the air quality sensor is located close to the wiper motor. In my view, it has nothing to do with your problem. I think that either a sensor for outflow temperature or the sensor for sun position is the cause. Have you made a basic setting for the flaps? What is the temperature difference between the heating hose and the return hose?
paddyz1
C?ID=273783
Thanks. I have no idea. Only things I have done is reset the flaps to see if that helped and an aircon service. None of which helped.
The temp differance is worse when the aircon is on.
It is steadily getting worse with aircon off.
Are there temp sensors in any of the ducts and if so, where.
downtime
C?ID=280813
There's only one air quality sensor and on a LHD car it's under the passenger side wiper in the "rain tray" or whatever it's called :)
It could be the sensor or it could be wiring to the sensor.
DV52
C?ID=194404
^^^^ like this (pics from my-gti.com):
Although (like ai_Ingo) I wouldn't have thought that a faulty air quality sensor would produce the symptoms described. Still, the sensor is relatively easy to replace-so it does eliminate a possible cause(I guess)
PS: the written stuff from the manufacturer has lots of warning labels about the need to keep the new sensor clear from any contaminants during the replacement process. Apparently these sensors are prone to failure if exposed to pollutants (so don't chuck the new sensor into a grubby, oily tool box while you access the plenum chamber)
paddyz1
C?ID=273783
Thanks guys. I will get that one replaced this week.
Do you know if there are any sensors inside the air ducts on the dash? The two by each door and the two above the radio (or anywhere else where there is a duct)
I hope I don't have to remove the dash but if needs be then it will have to be done.
Thanks again.
downtime
C?ID=280813
I agree with ai_Ingo and Don that the faulty air quality sensor does not affect the amount of hot or cold air blown inside, sorry I somehow did not register the actual problem, I was just staring at the fault codes :)
The air quality sensors only affects the automatic recirculation. So changing the sensor does not fix the poor heat output problem. To me this sounds like a faulty or blocked heater matrix : https://forums.vwvortex.com/showthread.php?7373777-Heater-core-flush
siLc
Tallinn, Estonia
C?ID=330192
Open module 08, have a look at measurement blocks for left and right side temperature flaps V158 and V159. Change the temperature through its range and see how the measurement blocks change - if it's smooth and linear or jumpy and erratic?
paddyz1
C?ID=273783
Thank you. Not checked yet but will do this weekend
