VCDS Mobile Autoscan Hangs at 14%
pschwa
C?ID=213853
Since performing the most recent firmware update to my Hex-Net (two days ago), I've had a problem when trying to complete an Auto-Scan with VCDS Mobile. Each time I try, it hangs while "Trying address 08," at 14% complete. It encounters the same issue whether in Access Point Mode or Infrastructure Mode, and I have tested it on two devices with identical results - first an iPhone (which also serves as the hotspot for Infrastructure Mode) and second a laptop running Firefox.
I have tried clearing the ROD files and the Data Cache, but continue to have the exact same problem. When I cleared the ROD files and try an Auto-Scan in Infrastructure Mode, after I cancel the Auto-Scan after it hangs, I receive a prompt asking if I want to download the ASAM data. When I respond that I do, it appeared to do so successfully. However, when I then go back and select individual modules, some come up as still requiring a download of the ASAM data. In this situation, it appears that those modules listed after Address 08 still require downloading of the ASAM data, while those prior to Address 08 do not. Address 08 itself does not come up as requiring an ASAM data download when I select it. However, the situation makes it seems like the problems I am having relate somehow to a corruption of the ASAM data that was downloaded following the firmware update I performed.
I am able to complete an Autoscan in VCDS on my laptop. Below is a copy of the Autoscan. Any help would be greatly appreciated.
Monday,05,November,2018,17:29:06:07492
VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
VIN: 3VWH17AU1JM762808   License Plate:
Mileage: 2954km-1835mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 CA D6 D7
VIN: 3VWH17AU1JM762808   Mileage: 2954km-1835miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 311D00322466002F1000
   Shop #: WSC 00066 790 00235
   ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
   ROD: EV_ECM18TFS0208V0906264M.rod
   VCID: 46C097BDF9BAA97AAF-8012
   Part No SW: 0D9 300 018     HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01711081627
   ROD: EV_TCMDQ250021.rod
   VCID: 59FA4CC158043682F2-800C
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 53227000001314
   Coding: 43FA6AA13426096E807F0300A0CB29C2562C9001C005943C36435050E0A5430000010312121212B435351919323200
   Shop #: WSC 01383 790 50316
   VCID: 77BE2A79CED000F2E4-8022
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0464212546
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C34F555B776E3AAC9-8068
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0202002410011800010400001211140A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 48DC9985F3AEBF0A5D-801C
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: C86408011800SK
   Shop #: WSC 00066 790 00147
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B566689A2581412B0-805E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    171125  043 0551
   Serial number: 97022066171201163457
   Coding: 0E4DFD
   Component: RLHS  047 0105
   Serial number: S4Y17M12D13H18M23S30
   Coding: 00A8DD
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000116644R18002
   Coding: 0271167811
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 50ECB1E50BFE77CA05-8004
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 350007C141FFC728949C810520401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E30FF5DA16AF1BAE7-806A
   Serial number: 003GCR08Y7P3
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47DE9AB9FEB0B07254-8012
   Occupant Detection:
   Serial number: IBH0000000000084TMJ%
   Coding: 303137
   Subsystem 2 - Part No SW: -----------    HW: 480 000 112 17
   Serial number: 3570000000002A810924
   Subsystem 3 - Part No SW: -----------    HW: 480 000 112 17
   Serial number: 35800000000EBB81092T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 511 17
   Serial number: 351000199285E68196CD
   Subsystem 5 - Part No SW: -----------    HW: 480 402 511 17
   Serial number: 3520001B7285E68555CD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 311 17
   Serial number: 3550002AD25629A1316/
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 311 17
   Serial number: 3560002A725629A372F8
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16121708490655
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 095A5C81A824060282-805C
   Part No SW: 5G1 920 840 C    HW: 5G1 920 840 C
   Component: KOMBI         242 0310
   Coding: 0BA5101DED88CF0502887B0B5001000080000000
   VCID: 271E3A395EF05072B4-8072
   Component: GW MQB High   518 5323
   Serial number: 26111700841943
   Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewNF_VW37.rod
   VCID: 383CE945834ECF8A2D-806C
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 28170002961430041439
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: U13DCAC  H25 0780
   Serial number: 0002519
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00025.09.17
   Coding: 0001
   VCID: 4CD4A595E7D6532A79-8018
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Revision: 00000000    Serial number: 17000342999006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424DD759F262BEA01-8060
   Component: HRE_Master    H12 0080
   Serial number: 0461929202
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D32F851AC6CEAA2FE-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0460294454
   Coding: 020111
   Serial number: 5038734401652
   Coding: 003F13205000020000000000
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000032996
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  172 1081
   Coding: 930A0000
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01BFHN
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E10CF1D710A013A77-807A
   Serial number: 24111700840400
   Coding: 000000050100211200110F01030000000000000000000000000000000000
   VCID: 72A81B6DA5B265DAD3-8026
   Serial number: 6038734200142
   Coding: 003F13205C00020000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000093141
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027312020000000051220002001808009F0508F401200505C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3326DE699A282CD218-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT3566733
   Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
   Component: NAR 2017/18  --- 0620
   Component: OCULowMQBUS   009 0570
   Coding: 02730202C2823A017F1E06020000
   ROD: EV_OCULowMQB.rod
   VCID: 43C68EA9CA889C5288-8016
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 06101741K21859
   Coding: 000307020002020100221354C150490084000E200120
   VCID: 085C5985B32E7F0A9D-805C
   Coding: 00804073720C
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393AEC41B844D682D2-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V)-----------
Shaun
Can you please make a debug log in VCDS-Mobile, [Options] -> debug level = 001F -> [Submit] then go back and do an autoscan. When that finishes, make sure the resulting debug log is synced to the cloud (from [View Saved Files] page) or email it to us.
pschwa
C?ID=213853
Just done. Docid 0000463A (debug) and 0000463F (canceled auto-scan that hanged at address 08).
Shaun
Do you have any problems talking to the 05 or 08 individually, outside of an autoscan?
I put your interface onto the alpha channel, so you should now be able to download a couple of testing updates if you check for updates again. I don't know if any of these will fix your issue, but for debugging purposes it's at least good to be running the latest stuff.
Can I get you to make two more debug logs of the autoscan, one with level 41F and one with level just 00F
If you want to get the ASAM data for modules after 08, you can go and talk to each of them manually and then go and check for updates when you're done with all of them, it should be able to get you all the ASAM data at once.
Shaun
pschwa I put your interface on the alpha channel and have a new alpha codeblock for you to test, V0.4444. Please check for updates and once you have that updated, go ahead and try autoscanning again.
n0vac
C?ID=321709
I have exactly the same problem with VCDS Mobile and 08 address (autoscan/individual scan). It was working a few months ago, but it took about a minute to scan 08 address.
Shaun can you also put my interface on the alpha channel? Do you need more debug logs?
Shaun
Sure I put you on alpha, but that may not be the same problem. Feel free to make debug logs if the alpha doesn't help.
pschwa
C?ID=213853
Hey Shaun,
That new alpha firmware seemed to do the trick for me. Auto scan completed successfully and new ASAM data was downloaded to complete the set for all modules. I am still having an issue with uploading saved files to VCDS Cloud, where the completion of upload is never confirmed from the Saved Files interface, and in many cases the file does not upload at all.
n0vac
C?ID=321709
I also tested the new alpha codeblock and now autoscan completed in my case too. Before I updated, I made three debug logs with the options 001F, 041F and 000F. When I tried to upload them to the cloud, upload never finished. I had to refresh the page to get rid of the ”Uploading” message. I just logged in to the vcds-cloud.com and the files are there. So I share pschwa’s findings about the file upload function.
Bentley
South Wales, UK
C?ID=263294
Hi, sorry to tag on the end of this. My VCDS Mobile also stops on Autoscan. Autoscaning Bentley GTs, but no other vehicles to test it on.
I've only had it about 6 weeks and usually use it with VCDS. I'm pretty sure it worked when I first got it and tried it.
I did do some debugs as above but was under time pressure so could not try much.
Tried it on a different Android phone yesterday with the same result.
Cheers in advance.
spanzo
C?ID=392003
Hello all,
I also have troubles with autoscan in VCDS-Mobile App.
It hangs at 4%.
Interface is updated to newest version.
I already created debug log in debug level = 001F and synced to cloud.
thank you in advance
  • Informative
Shaun
Thank you for the debug log. Can you post an autoscan from VCDS for this car?
spanzo
C?ID=392003
Hello Shaun,
attached my autoscan.
It's made with the german version of VCDS, hope this is also OK for you.
Montag,13,September,2021,20:43:21:24231
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows XP x86(VirtualBox)
VCDS Version PCI 19.6.2.1  HEX-NET CB: 0.4555.4
Datenstand: 20191020 DS308.0
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: WAUZZZ8EX8A083909   KFZ-Kennzeichen:
Kilometerstand: 171800km   Reparaturauftrag:
Fahrzeugtyp: 8E (00 -  Audi A4 V6)
Scan: 01 03 08 09 15 16 17 25 37 46 55 56 76 77
Fahrzeug-Ident.-Nr.: WAUZZZ8EX8A083909   Kilometerstand: 171800km
Adresse 01: Motorelektronik (AUK)       Labeldatei:. 06E-910-559-BKH.clb
   Teilenummer SW: 8E1 910 559     HW: 8E0 907 559 H
   Bauteil: 3.2l V6 FSI         0040
   Revision: --H20---    Seriennummer: XXXXXXXXXXXXXX
   Codierung: 010C0003180F0920
   Betriebsnr.: WSC 06335 000 00000
   VCID: 6B96E7264ADB571763-803F
Readiness: 0110 0101
Adresse 03: Bremsenelektronik        Labeldatei: DRV\8E0-910-517.clb
   Teilenummer SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Bauteil: ESP8 quattro    H06 0140
   Revision: 00000000    Seriennummer: 00000000000000
   Codierung: 0004379
   VCID: 2E102E32B949E23F04-807B
Adresse 08: Klima-/Heizungsel.        Labeldatei: DRV\8E0-820-043.lbl
   Teilenummer: 8E0 820 043 BM
   Bauteil:   A4 Klimaautomat   3233
   Codierung: 00000
   Betriebsnr.: WSC 00000
   VCID: 6D92E93E25CF59277D-50F5
Adresse 09: Zentralelektrik        Labeldatei: DRV\8E0-907-279-8EC.lbl
   Teilenummer: 8E0 907 279 N
   Bauteil: int. Lastmodul  ECE 0907
   Codierung: 11121
   Betriebsnr.: WSC 65536
   VCID: 3D32197E352F09A78D-4AA5
Adresse 15: Airbag        Labeldatei: DRV\8E0-959-655-94.lbl
   Teilenummer SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Bauteil:    Airbag 9.41  H14 4230
   Revision: 91H14423    Seriennummer: 0036M0GA6PHJ
   Codierung: 0031612
   VCID: 3B3617667A3B0797B3-806F
   Subsystem 1 - Seriennummer: 6332DRB405CDCBABE
   Subsystem 2 - Seriennummer: 6342DRB405C9C82F4
   Subsystem 3 - Seriennummer: 6352ARB402D368BE$
   Subsystem 4 - Seriennummer: 6362ARB402D7F971.
   Subsystem 5 - Seriennummer: 63729RB402A9CED33
   Subsystem 6 - Seriennummer: 63829RB402A9C628X
Adresse 16: Lenkradelektronik        Labeldatei: DRV\8E0-953-549.lbl
   Teilenummer: 8E0 953 549 Q
   Bauteil: Lenksáulenmodul     0701
   Codierung: 04042
   VCID: 41CA658E49D76D47E9-4AA5
Adresse 17: Schalttafeleinsatz        Labeldatei: DRV\8E0-920-9xx-8EC.lbl
   Teilenummer SW: 8E0 920 932 A    HW: 8E0 920 932 A
   Bauteil: KOMBI+WFS 4     H10 0200
   Revision: 0200        Seriennummer: 00000000000000
   Codierung: 0005048
   Betriebsnr.: WSC 03159 004 1048576
   VCID: 271EDB1697B3B377C7-5119
Adresse 25: Wegfahrsperre        Labeldatei: DRV\8E0-920-9xx-8EC.lbl
   Codierung: 0005048
Adresse 37: Navigation        Labeldatei: DRV\8E0-035-192-RNSE.clb
   Teilenummer SW: 8E0 035 192 Q    HW: 8E0 035 192 Q
   Bauteil: RNS-E HIGH EU   H74 0600
   Revision:      04S    Seriennummer: AUZBZ7G1150389
   Codierung: 0309717
   VCID: 32283A42AF71C6DF60-5161
Adresse 46: Komfortsystem        Labeldatei:. DRV\8E0-959-433-MAX.clb
   Teilenummer: 8E0 959 433 CM
   Bauteil: Komfortgerát T23    4336
   Codierung: 07008
   VCID: 7EB0DE7278A9D2BFD4-4AA5
   Subsystem 1 - Teilenummer: 8E1959801G
   Bauteil: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Teilenummer: 8E1959802G
   Bauteil: Tõrsteuer.BF BRM 0706
   Subsystem 3 - Teilenummer: 8E0959801E
   Bauteil: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Teilenummer: 8E0959802E
   Bauteil: Tõrsteuer.HR BRM 0606
Adresse 55: Leuchtweitenreg.        Labeldatei: DRV\4F0-910-357.lbl
   Teilenummer SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Bauteil: AFS 1           H01 0020
   Revision: 00000001    Seriennummer:
   Codierung: 0000019
   VCID: 291ADD2E80A78507D1-807D
   Subsystem 1 - Teilenummer: 8E0 941 329 A
   Bauteil: AFS-Modul links H05 0030
   Subsystem 2 - Teilenummer: 8E0 941 329 A
   Bauteil: AFS-Modul rechtsH05 0030
Adresse 56: Radio        Labeldatei: DRV\8E0-035-192-RNSE.clb
   Codierung: 0309717
Adresse 76: Einparkhilfe        Labeldatei: DRV\8E0-919-283-8EC.lbl
   Teilenummer SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Bauteil: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Seriennummer: 00067802120725
   Codierung: 0010114
   VCID: 32283A42AF71C6DF60-5185
Adresse 77: Telefon        Labeldatei: DRV\8P0-862-335.lbl
   Teilenummer SW: 8P0 862 335 Q    HW: 8P0 862 335 Q
   Bauteil: FSE_255x BT     H26 0350
   Revision: 00000000    Seriennummer: 00000005252714
   Codierung: 0011811
   VCID: 44C46C9A06C5786FC2-50D1
Ende--------(Dauer: 02:12, Batt.-Spannung Start/Ende: 12.4V/12.4V)---------
Greetings from the USA, from what I have observed, they are going to want / prefer the English version of the VCDS Auto-scan, it will function right along with your current German version ; so no need to delete or uninstall anything. You can find the English version (at the bottom of the page) > HERE < .
spanzo
C?ID=392003
Thanks for the hint.
Here the log of English version.
Wednesday,15,September,2021,08:47:55:24231
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WAUZZZ8EX8A083909   License Plate:
Mileage: 171820km-106763mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8EX8A083909   Mileage: 171820km-106763miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E1 910 559     HW: 8E0 907 559 H
   Component: 3.2l V6 FSI         0040
   Revision: --H20---    Serial number: XXXXXXXXXXXXXX
   Coding: 010C0003180F0920
   Shop #: WSC 06335 000 00000
   VCID: 6B96E7264ADB57D184-803E
   VINID: 9D196AAAA215A084402032402435C4A13A
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004379
   VCID: 2E102E32B949E2F9E3-807A
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6D92E93E25CF59E19A-50F4
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11121
   Shop #: WSC 65536
   VCID: 3D32197E352F09616A-4AA4
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H14 4230
   Revision: 91H14423    Serial number: 0036M0GA6PHJ
   Coding: 0031612
   VCID: 3B3617667A3B075154-806E
   Subsystem 1 - Serial number: 6332DRB405CDCBABE
   Subsystem 2 - Serial number: 6342DRB405C9C82F4
   Subsystem 3 - Serial number: 6352ARB402D368BE$
   Subsystem 4 - Serial number: 6362ARB402D7F971.
   Subsystem 5 - Serial number: 63729RB402A9CED33
   Subsystem 6 - Serial number: 63829RB402A9C628X
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04042
   Shop #: WSC 06335
   VCID: 41CA658E49D76D810E-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 932 A    HW: 8E0 920 932 A
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0005048
   Shop #: WSC 03159 004 1048576
   VCID: 271EDB1697B3B3B120-5118
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0005048
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 Q    HW: 8E0 035 192 Q
   Component: RNS-E HIGH EU   H74 0600
   Revision:      04S    Serial number: AUZBZ7G1150389
   Coding: 0309717
   VCID: 32283A42AF71C61987-5160
   Part No: 8E0 959 433 CM
   Component: Komfortgerát T23    4336
   Coding: 07008
   Shop #: WSC 06335
   VCID: 7EB0DE7278A9D27933-4AA4
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Component: Tõrsteuer.HR BRM 0606
   Coding: 0000019
   VCID: 291ADD2E80A785C136-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0309717
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802120725
   Coding: 0010114
   VCID: 32283A42AF71C61987-5184
   Part No SW: 8P0 862 335 Q    HW: 8P0 862 335 Q
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005252714
   Coding: 0011811
   VCID: 44C46C9A06C578A925-50D0
End----------(Elapsed Time: 04:44, VBatt start/end: 12.4V/12.4V)-----------
Shaun
Thank you, feel free to bump this thread in a couple days if I haven't gotten back to you with an alpha CB to test.
spanzo
C?ID=392003
Hello Shaun, any news about alpha CB?
Shaun
Ok I put your interface on the alpha channel, you will need to check for updates and download the couple of new updates found. Once you have CB V0.4602, then please try autoscanning again.
spanzo
C?ID=392003
Hello Shaun, I updated the interface, but autoscan still hangs at 4%
