Basic Settings wont work
0120raptor
North West UK
C?ID=210440
Audi A3 2.0 tdi 170 ps BMN engine. I replaced my turbo ,just the central core but it came with the vane adjusting screw not set so I need to use Engine ,Basic Settings,Group 11(Charge Pressure Control) to cycle the turbo to reset the screw to give me 80 mbar change between vanes open and closed.
The four windows initially show 800rpm ------- 1009.6mbar(actual) 3.451v(duty cycle)
I press "ON" ,press brake and throttle and instead of the turbo cycling and revs going to 1400 rpm the engine stays at idle and the windows change to:
1.0 BRAKES CLUTCH1 OPERATE
I`m new to VCDS so I`m probably doing something wrong.Could anyone enlighten me please?
SCAN below
Neil
Wednesday,26,March,2014,19:10:30:44437
VCDS Version: 12.12.2.0
Data version: 20140212
Dealer/Shop Name: Bold Engineering
VIN: WAUZZZ8P17A136397   License Plate: N8OLD
Mileage: 142250km-88390mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P17A136397   Mileage: 142250km/88390miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 DN    HW: 03G 906 018 DN
   Component: R4 2.0l PPD1.2      4350
   Revision: --H42---    Serial number: AUX7Z0FDFNC11D
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 74E7D3921716BABE8FF-8021
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0023170
   Shop #: WSC 06314 000 00000
   VCID: 72EBD58A6D02B48E9D3-8027
   Part No SW: 8P0 820 043 AC    HW: 8P0 820 043 AC
   Component: KlimavollautomatH19 0360
   Revision: 082189      Serial number: 8P0820043AC
   VCID: 6DD1C6F6743C6B76401-8038
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000006497371
   Coding: 01884F01B014100000160000160000000008FE175C0100
   Shop #: WSC 06314 000 08192
   VCID: 408F4F42132E561EDB7-8015
   Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H13 4260
   Revision: 91H13426    Serial number: 003620G37HZ3
   Coding: 0071612
   VCID: 428B454A1D22440ECD3-8017
   Subsystem 1 - Serial number: 6332DRB404559013A
   Subsystem 2 - Serial number: 6342DRB404559113C
   Subsystem 3 - Serial number: 63528RB401F2E627R
   Subsystem 4 - Serial number: 63628RB401F2E499Z
   Subsystem 5 - Serial number: 63729RB401E5BC65.
   Subsystem 6 - Serial number: 63829RB401E5BC08Z
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           036 0070
   Coding: 0000012
   VCID: 78FFE7A20B7EDEDEA37-802D
   Part No SW: 8P0 920 981 F    HW: 8P0 920 981 F
   Component: KOMBIINSTR. VDO H20 0570
   Revision: D0H20004    Serial number: 224DF004008288
   Coding: 0005418
   Shop #: WSC 00694 210 83007
   VCID: 3B7538AE7AC835C68E5-806E
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 3300106B2204E4
   Coding: BD3F034007002103
   VCID: 2F6D1CFEBEB0D96632D-807A
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   VCID: 3663299A41EAE8AE71B-8063
   Revision: D0H20004    Serial number: AUX7Z0FDFNC11D
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0000688
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.079 H07 1806
   VCID: 35612E965CECE3B6781-8060
   Part No: 8P0 959 433 F
   Component:    KSG          H05 0070
   Coding: 9980202002186D098505489FC637
   VCID: 3F8D4CBE6ED029E6A2D-806A
   Component: Neigungssensor  005 0003
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0000688
   VCID: 41894A4618245F16D49-8014
   Part No SW: 8P0 035 195 G    HW: 8P0 035 195 G
   Component: R Symphony2+    H14 0220
   Revision: 00H14000    Serial number: AUZ1Z4F9005576
   Coding: 0010301
                    Time Indication: 15
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0070
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0000144
Hmm. I can't say I've ever done one of these, but it seems to me the ECU is asking you to operate the brakes and the clutch, not the brakes and the throttle.
Have you tried doing what the ECU is asking?
0120raptor
North West UK
C?ID=210440
UWE
Thanks for the quick reply.The writing on the screen says press brakes and throttle.I`ll try brakes and clutch see what happens.
Neil
Well, I can't see what's on your screen, but what you wrote here is:
0120raptor
North West UK
C?ID=210440
UWE
It`s underneath the 4 windows.When I click on "Charge Pressure Control" that block changes to "Engine on ,Press On ,press brake and throttle. That`s when all the windows change.When I press Off, they change back to what they were originally.Can`t reply now until tomorrow .
Neil
Niel,
OK, if you can't get it working tomorrow, please make screen-shots of everything. We'll never be able to reproduce this here since we didn't get any diesels with PPD engine management.
0120raptor
North West UK
C?ID=210440
UWE
Sorted. It`s a bit ambiguous as one screen says "brakes and throttle" but windows say "brakes and clutch". Tried brakes and clutch and it works superbly.Managed to set the stop screw correctly ,a job I must say that Audi main dealer failed to do twice.
Thanks again.
Neil
Neil, you're very welcome.
Can we impose on you to run it again and make screen-shots so we might see if there's a way for us to correct the apparently misleading "brakes and throttle" message?
0120raptor
North West UK
C?ID=210440
UWE
How do I take a screen shot?
The PrintScreen button on your keyboard will stuff the entire contents of your screen into the Windows Clipboard. From there, you can paste into Paint or Word or (my personal favorite for this kind of thing) Irfanview, then crop and Save As. If you're saving a screen shot as an image, .PNG is almost always a better choice than .JPG. (but .JPG is better for photos).
Pro-Tip: If you use Alt + Printscreen, you will get only the currently active window instead of the whole screen.
0120raptor
North West UK
C?ID=210440
UWE
Windows Vista doesn`t support clipboard and the Printscreen button has never worked on my laptop.I`ll take a photograph of the screen tomorrow and email it to Support@Ross-Tech.com for your attention.Hope that`s ok.
Regards
Neil
I can accept that your PrintScreen key doesn't work, but the idea that the Windows Clipboard doesn't work in Windows Vista is, well, let's just say "incorrect". I realize that Vista was a relatively crappy version of Windows, but it wasn't totally unusable, at least if one turned User Account Control off. ;)
If your PrintScreeen button doesn't work, you may want to try some 3rd party Print Screen utility.
0120raptor
North West UK
C?ID=210440
UWE
Sent that photo via email.Will sort out Print Screen when I have a minute. If you need any info from my car and I`m able to help please let me know.
Neil
Hah! Our instructions must be for an automatic transmission car. ;)
